path: root/drivers/ata/libata-acpi.c
2008-04-25libata-acpi.c: remove unneeded #if'sAdrian Bunk
These #if's are unneeded since they: - did anyway not handle the CONFIG_ACPI_DOCK_MODULE case correctly and - this is already handled in include/acpi/acpi_drivers.h and - it's now correctly handled in kconfig. Signed-off-by: Adrian Bunk <bunk@kernel.org> Acked-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-17ata-acpi: don't call _GTF for disabled driveShaohua Li
I got below log after a S3 resume in a ASUS A6VC laptop. The system has only one IDE drive. It appears there is no reason calling _GTF for disabled drive. ACPI Error (dsopcode-0483): Attempt to CreateField of length zero [20070126] ACPI Error (psparse-0537): Method parse/execution failed [\_SB_.PCI0.IDE0.RATA] (Node df822a7c), AE_AML_OPERAND_VALUE ACPI Error (psparse-0537): Method parse/execution failed [\_SB_.PCI0.IDE0.CHN1.DRV0._GTF] (Node df822bd0), AE_AML_OPERAND_VALUE ata2.00: _GTF evaluation failed (AE 0x3006) ACPI Error (dsopcode-0483): Attempt to CreateField of length zero [20070126] ACPI Error (psparse-0537): Method parse/execution failed [\_SB_.PCI0.IDE0.RATA] (Node df822a7c), AE_AML_OPERAND_VALUE ACPI Error (psparse-0537): Method parse/execution failed [\_SB_.PCI0.IDE0.CHN1.DRV1._GTF] (Node df822b94), AE_AML_OPERAND_VALUE ata2.01: _GTF evaluation failed (AE 0x3006) Signed-off-by: Shaohua Li <shaohua.li@intel.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-17libata: implement PMP helpersTejun Heo
Implement helpers to test whether PMP is supported, attached and determine pmp number to use when issuing SRST to a link. While at it, move ata_is_host_link() so that it's together with the two new PMP helpers. This change simplifies LLDs and helps making PMP support optional. Signed-off-by: Tejun Heo <htejun@gmail.com>
2008-03-17libata-acpi: improve dock event handlingTejun Heo
Improve ACPI hotplug handling such that dock event is handled properly. * Register handlers for dock events. * Directly detach device on EJECT_REQUEST instead of signaling hotplug event. This prevents libata from accessing severed controller and/or device. * While at it, use named constants for ACPI events and move uevent signaling inside host lock. Original patch and testing by Holger Macht. Signed-off-by: Tejun Heo <htejun@gmail.com> Cc: Holger Macht <hmacht@suse.de> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-03-10ata: replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-01-23libata: reimplement ata_acpi_cbl_80wire() using ata_acpi_gtm_xfermask()Tejun Heo
Reimplement ata_acpi_cbl_80wire() using ata_acpi_gtm_xfermask() and while at it relocate the function below ata_acpi_gtm_xfermask(). New ata_acpi_cbl_80wire() implementation takes @gtm, in both pata_via and pata_amd, use the initial GTM value. Both are trying to peek initial BIOS configuration, so using initial caching value makes sense. This fixes ACPI part of cable detection in pata_amd which previously always returned 0 because configuring PIO0 during reset clears DMA configuration. Signed-off-by: Tejun Heo <htejun@gmail.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-01-23libata: implement ata_timing_cycle2mode() and use it in libata-acpi and ↵Tejun Heo
pata_acpi libata-acpi is using separate timing tables for transfer modes although libata-core has the complete ata_timing table. Implement ata_timing_cycle2mode() to look for matching mode given transfer type and cycle duration and use it in libata-acpi and pata_acpi to replace private timing tables. Signed-off-by: Tejun Heo <htejun@gmail.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-01-23libata: fix ata_acpi_gtm_xfermask()Tejun Heo
ata_acpi_gtm_xfermask() as separated out from pacpi_discover_modes() has various bugs. Fix them. * The wrong comparison operator is used when finding for matching cycle resulting totally bogus result. * With the comparion operator fixed, boundary condtion handling is clumsy. * Setting of any DMA mask bit set all bits in PIO mask. * MWDMA and UDMA blocks are swapped. Signed-off-by: Tejun Heo <htejun@gmail.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-01-23libata: separate out ata_acpi_gtm_xfermask() from pacpi_discover_modes()Tejun Heo
Finding out matching transfer mode from ACPI GTM values is useful for other purposes too. Separate out the function and timing tables from pata_acpi::pacpi_discover_modes(). Other than checking shared-configuration bit after doing ata_acpi_gtm() in pacpi_discover_modes() which should be safe, this patch doesn't introduce any behavior change. Signed-off-by: Tejun Heo <htejun@gmail.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-01-23libata-acpi: add ACPI _PSx methodShaohua Li
ACPI spec (ver 3.0a, p289) requires IDE power on/off executes ACPI _PSx methods. As recently most PATA drivers use libata, this patch adds _PSx method support in libata. ACPI spec doesn't mention if SATA requires the same _PSx method. Signed-off-by: Shaohua Li <shaohua.li@intel.com> Acked-by: Len Brown <len.brown@intel.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2007-12-17libata-acpi: implement _GTF command filteringTejun Heo
Implement _GTF command filtering which can be controlled by libata.acpi_filter kernel parameter. Currently SETXFER and LOCK commands are filtered. libata configures transfer mode by itself and _GTF SETXFER commands can potentially disrupt device configuration. _GTM/_STM mechanism can't handle hotplugging too well and when _GTF is executed, controller is in PIO0 rather than the mode _STM configured. Note that detecting SET MAX LOCK requires looking at the previous command. This adds a bit to code complexity. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-12-17libata-acpi: improve _GTF execution error handling and reportingTejun Heo
As _GTF commands can't transfer data, device error never signals transfer error. It indicates that the device vetoed the operation, so it's meaningless to retry. This patch makes libata-acpi to report and continue on device errors when executing _GTF commands. Also commands rejected by device don't contribute to the number of _GTF commands executed. While at it, update _GTF execution reporting such that all successful commands are logged at KERN_DEBUG and rename taskfile_load_raw() to ata_acpi_run_tf() for consistency. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-12-17libata-acpi: improve ACPI disablingTejun Heo
* If _GTF evalution fails, it's pointless to retry. If nothing else is wrong, just ignore the error. * After disabling ACPI, return success iff the number of executed _GTF command equals zero. Otherwise, tell EH to retry. This change fixes bogus 1 return bug where ata_acpi_on_devcfg() expects the caller to reload IDENTIFY data and continue but the caller interprets it as an error. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-12-17libata-acpi: implement dev->gtf_cache and evaluate _GTF right after _STM ↵Tejun Heo
during resume On certain implementations, _GTF evaluation depends on preceding _STM and both can be pretty picky about the configuration. Using _GTM result cached during controller initialization satisfies the most neurotic _STM implementation. However, libata evaluates _GTF after reset during device configuration and the hardware state can be different from what _GTF expects and can cause evaluation failure. This patch adds dev->gtf_cache and updates ata_dev_get_GTF() such that it uses the cached value if available. Cache is cleared with a call to ata_acpi_clear_gtf(). Because for SATA ACPI nodes _GTF must be evaluated after _SDD which can't be done till IDENTIFY is complete, _GTF caching from ata_acpi_on_resume() is used only for IDE ACPI nodes. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-12-17libata-acpi: implement and use ata_acpi_init_gtm()Tejun Heo
_GTM fetches currently configured transfer mode while _STM configures controller according to _GTM parameter and prepares transfer mode configuration TFs for _GTF. In many cases _GTM and _STM implementations are quite brittle and can't cope with configuration changed by libata. libata does not depend on ATA ACPI to configure devices. The only reason libata performs _GTM and _STM are to make _GTF evaluation succeed and libata also doesn't care about how _GTF TFs configure transfer mode. It overrides that configuration anyway, so from libata's POV, it doesn't matter what value is feeded to _STM as long as evaluation succeeds for _STM and following _GTF. This patch adds dev->__acpi_init_gtm and store initial _GTM values on host initialization before modified by reset and mode configuration. If the field is valid, ata_acpi_init_gtm() returns pointer to the saved _GTM structure; otherwise, NULL. This saved value is used for _STM during resume and peek at BIOS/firmware programmed initial timing for later use. The accessor is there to make building w/o ACPI easy as dev->__acpi_init doesn't exist if ACPI is not enabled. On driver detach, the initial BIOS configuration is restored by executing _STM with the initial _GTM values such that the next driver can also use the initial BIOS configured values. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-12-17libata-acpi: add new hooks ata_acpi_dissociate() and ata_acpi_on_disable()Tejun Heo
Add two hooks - ata_acpi_dissociate() which is called during driver detach after the whole host is shutdown and ata_acpi_on_disable() which is called when a device is disabled. Signed-off-by: Tejun heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-12-17libata-acpi: adjust constness in ata_acpi_gtm/stm() parametersTejun Heo
* No internal function uses const ata_port. Drop const from @ap. * Make ata_acpi_stm() copy @stm before using it and change @stm to const. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-11-10libata: Don't fail device revalidation for bad _GTF methodsMatthew Garrett
Experience suggests that the _GTF method may be bad. We currently fail device revalidation in that case, which seems excessive. Signed-off-by: Matthew Garrett <mjg59@srcf.ucam.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-23[libata] checkpatch-inspired cleanupsJeff Garzik
Tackle the relatively sane complaints of checkpatch --file. The vast majority is indentation and whitespace changes, the rest are * #include fixes * printk KERN_xxx prefix addition * BSS/initializer cleanups Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2007-10-12libata: add @timeout to ata_exec_internal[_sg]()Tejun Heo
Add @timeout argument to ata_exec_internal[_sg](). If 0, default timeout ata_probe_timeout is used. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-12libata-core: Expose gtm methods for driver useAlan Cox
Talk to the dark side our driver has to, yes. Much misleading is the data. Store it in a structure we do so that it may be parsed. Signed-off-by: Alan Cox <alan@redhat.com> -- Whats small, old and shouts phrases out of order across mountains ? Yodla.. Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-12libata: Integrate ACPI-based PATA/SATA hotplug - version 5Matthew Garrett
Modern laptops with hotswap bays still tend to utilise a PATA interface on a SATA bridge, generally with the host controller in some legacy emulation mode rather than AHCI. This means that the existing hotplug code in libata is unable to work. The ACPI specification states that these devices can send notifications when hotswapped, which avoids the need to obtain notification from the controller. This patch uses the existing libata-acpi code and simply registers a notification in order to trigger a rescan whenever the firmware signals an event. Signed-off-by: Matthew Garrett <mjg59@srcf.ucam.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-12libata-pmp: extend ACPI support to cover PMPTejun Heo
Extend ata_acpi_associate_sata_port() such that it can handle PMP and call it when PMP is attached and detached. Build breakage when !CONFIG_ATA_ACPI was spotted and fixed by Petr Vandrovec. Signed-off-by: Tejun Heo <htejun@gmail.com> Cc: Petr Vandrovec <petr@vandrovec.name> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-12[libata] add ACPI cable detect APIAlan Cox
Combined from two Alan Cox patches: 1) libata: ACPI checks for 80wire cable We can use the ACPI mode information with several drivers as a hint to cable type. If the ACPI mode set by the BIOS is faster than UDMA33 then we know the BIOS thinks there are 80wire cables. If it doesn't set such a mode or it has no ACPI method then we get no further information and can rely on existing approaches Introduce the function headers needed. Null it out for non ACPI boxes Signed-off-by: Alan Cox <alan@redhat.com> 2) libata: ACPI checks for 80wire cable Provide actual methods for checking if the ACPI support thinks the cable is 80wire, or doesn't know Signed-off-by: Alan Cox <alan@redhat.com> Combined into a single changeset and Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-12libata-link: implement and use link/device iteratorsTejun Heo
Multiple links and different number of devices per link should be considered to iterate over links and devices. This patch implements and uses link and device iterators - ata_port_for_each_link() and ata_link_for_each_dev() - and ata_link_max_devices(). This change makes a lot of functions iterate over only possible devices instead of from dev 0 to dev ATA_MAX_DEVICES. All such changes have been examined and nothing should be broken. While at it, add a separating comment before device helpers to distinguish them better from link helpers and others. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-12libata-link: introduce ata_linkTejun Heo
Introduce ata_link. It abstracts PHY and sits between ata_port and ata_device. This new level of abstraction is necessary to support SATA Port Multiplier, which basically adds a bunch of links (PHYs) to a ATA host port. Fields related to command execution, spd_limit and EH are per-link and thus moved to ata_link. This patch only defines the host link. Multiple link handling will be added later. Also, a lot of ap->link derefences are added but many of them will be removed as each part is converted to deal directly with ata_link instead of ata_port. This patch introduces no behavior change. Signed-off-by: Tejun Heo <htejun@gmail.com> Cc: James Bottomley <James.Bottomley@SteelEye.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-09libata-acpi: implement _GTM/_STM supportTejun Heo
Implement _GTM/_STM support. acpi_gtm is added to ata_port which stores _GTM parameters over suspend/resume cycle. A new hook ata_acpi_on_suspend() is responsible for storing _GTM parameters during suspend. _STM is executed in ata_acpi_on_resume(). With this change, invoking _GTF is safe on IDE hierarchy and acpi_sata check before _GTF is removed. ata_acpi_gtm() and ata_acpi_stm() implementation is taken from Alan Cox's pata_acpi implementation. ata_acpi_gtm() is fixed such that the result parameter is not shifted by sizeof(union acpi_object). Signed-off-by: Tejun Heo <htejun@gmail.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-09libata-acpi: remove redundant checksTejun Heo
Remove remaining unnecessary feature and status checks. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-09libata: reimplement ACPI invocationTejun Heo
This patch reimplements ACPI invocation such that, instead of exporting ACPI details to the rest of libata, ACPI event handlers - ata_acpi_on_resume() and ata_acpi_on_devcfg() - are used. These two functions are responsible for determining whether specific ACPI method is used and when. On resume, _GTF is scheduled by setting ATA_DFLAG_ACPI_PENDING device flag. This is done this way to avoid performing the action on wrong device device (device swapping while suspended). On every ata_dev_configure(), ata_acpi_on_devcfg() is called, which performs _SDD and _GTF. _GTF is performed only after resuming and, if SATA, hardreset as the ACPI spec specifies. As _GTF may contain arbitrary commands, IDENTIFY page is re-read after _GTF taskfiles are executed. If one of ACPI methods fails, ata_acpi_on_devcfg() retries on the first failure. If it fails again on the second try, ACPI is disabled on the device. Note that successful configuration clears ACPI failed status. With all feature checks moved to the above two functions, do_drive_set_taskfiles() is trivial and thus collapsed into ata_acpi_exec_tfs(), which is now static and converted to return the number of executed taskfiles to be used by ata_acpi_on_resume(). As failures are handled properly, ata_acpi_push_id() now returns -errno on errors instead of unconditional zero. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-09libata-acpi: miscellaneous cleanupsTejun Heo
* Add missing LOCKING: and RETURNS: to function comment. * Don't conditionalize warning messages with ata_msg_probe(). Print directly with KERN_WARNING. * Drop duplicate debug messages. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-09libata-acpi: clean up ata_acpi_exec_tfs()Tejun Heo
This patch cleans up ata_acpi_exec_tfs() and its friends. * Rename taskfile_array to ata_acpi_gtf and make it __packed as it's used as argument to ACPI method, and use pointer to ata_acpi_gtf and number of taskfiles to represent _GTF taskfiles instead of a pointer casted into unsigned long and byte count. This makes argument re-checking in do_drive_set_taskfiles() unnecessary. * Pointer in void * not in unsigned long. * Clean up do_drive_get_GTF() error handling and make do_drive_get_GTF() return number of taskfiles on success, 0 if _GTF doesn't exist or doesn't contain valid ata. -errno on other errors. * Remove superflous check for acpi->buffer.pointer. * Update taskfile_load_raw() such that printed messages look similar to the messages printed by ata_eh_report(). * s/do_drive_get_GTF/ata_dev_get_GTF/ s/do_drive_set_taskfiles/ata_dev_set_taskfiles/ Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-09libata-acpi: implement ata_acpi_associate()Tejun Heo
* Add acpi_handle to ata_host and ata_port. Rename ata_device->obj_handle to ->acpi_handle and move it above such that it doesn't get cleared on reconfiguration. * Replace ACPI node association which ata_acpi_associate() which is called once during host initialization. Unlike the previous implementation, ata_acpi_associate() uses ATA_FLAG_ACPI_SATA to choose between IDE or SATA ACPI hierarchy and uses simple child look up instead of recursive walk to match the nodes. This is way safer and simpler. Please read the following message for more info. http://article.gmane.org/gmane.linux.ide/17554 Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-05-16libata-acpi: add ATA_FLAG_ACPI_SATA port flagTejun Heo
Whether a controller needs IDE or SATA ACPI hierarchy is determined by the programming interface of the controller not by whether the controller is SATA or PATA, or it supports slave device or not. This patch adds ATA_FLAG_ACPI_SATA port flags which tells libata-acpi that the port needs SATA ACPI nodes, and sets the flag for ahci and sata_sil24. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-05-11libata-acpi: clean up parameters and misc stuffTejun Heo
This patch cleans up libata-acpi such that it looks similar to other libata files. This patch doesn't introuce any behavior changes. * make libata-acpi functions take ata_device instead of ata_port + device index * s/atadev/dev/ * de-indent local variable declarations Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-05-09libata-acpi: fix _GTF command protocol for ATAPI devicesTejun Heo
_GTF command is never ATA_PROT_ATAPI_NODATA whether the device is ATAPI or not. It's always ATA_PROT_NODATA. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-03-28[libata] Disable ACPI by default; fix namespace problemsJeff Garzik
Not yet ready to turn on ATA ACPI by default, for either PATA or SATA. Also, rename the global-scope module parameter variable 'noacpi' to something more libata-specific, reducing the potential for namespace collision. Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-03-09Pull bugzilla-7907 into release branchLen Brown
2007-03-09libata-acpi: allow _GTF on SATA, but disable on PATA for nowKristen Accardi
The ACPI specification states, and BIOS implementations depend on, _STM being called before _GTF. SATA does this, but PATA does not. So for now, simply prevent execution of _GTF on PATA devices. Longer term we should implement ACPI support for PATA devices in libata. Signed-off-by: Kristen Accardi <kristen.c.accardi@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2007-03-08[PATCH] libata-acpi: Try and stop all the non PCI devices crashingAlan Cox
For 2.6.20 it mostly used to just not work, for 2.6.21-rc it crashes, this seems to be down to luck (bad or good). The libata-acpi code needs to avoid doing PCI work on non-PCI devices. This is one hack although it's not pretty and perhaps there is a "right" way to check if a struct device * is PCI ? Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-24[libata] ACPI: remove needless ->qc_issue hook existence testJeff Garzik
All drivers must implement this hook, otherwise ATA commands would go nowhere (and a lot of other oopsen would appear as well). Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-23libata: fix remaining ap->idTejun Heo
Merge order left libata-acpi and pata_scc with remainling usage of ap->id. Kill superflous id printing and substitute the remaining ones with ap->print_id. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-16[PATCH] libata: wrong sizeof for BUFFERFiodor Suietov
I have reproduced the AE_AML_BUFFER_LIMIT exception mentioned in <http://bugzilla.kernel.org/show_bug.cgi?id=7689> basing on the SSDT ASL code and libata ata_acpi_push_id() code. There is an oversight in ata_acpi_push_id() causing the exception. The following update fixes it: Signed-off-by: Fiodor Suietov <fiodor.f.suietov@intel.com> Cc: Jeff Garzik <jeff@garzik.org> Cc: Tejun Heo <htejun@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-16[PATCH] libata: ACPI _SDD supportKristen Carlson Accardi
_SDD (Set Device Data) is an ACPI method that is used to tell the firmware what the identify data is of the device that is attached to the port. It is an optional method, and it's ok for it to be missing. Because of this, we always return success from the routine that calls this method, even if the execution fails. Signed-off-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Signed-off-by: Jeff Garzik <jeff@garzik.org> (cherry picked from 39aa79e0a1f5f2e28aa341f035940746a98b45b1 commit)
2007-02-16[PATCH] libata: ACPI and _GTF supportKristen Carlson Accardi
_GTF is an acpi method that is used to reinitialize the drive. It returns a task file containing ata commands that are sent back to the drive to restore it to boot up defaults. Signed-off-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Signed-off-by: Jeff Garzik <jeff@garzik.org> (cherry picked from 9c69cab24b51a89664f4c0dfaf8a436d32117624 commit)
