regardless of firmware revision
It's unlikely NOSETXFER works for a revision of drive but doesn't for
another and pioneer doesn't seem to be fixing firmwares for the
affected drives. Apply NOSETXFER to the affected pioneer drives
regardless of firmware revision.
http://article.gmane.org/gmane.linux.ide/49734
Reported-by: fl-00@gmx.de
Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
Give users the option of completely powering off unoccupied
SATA ports using the existing min_power link_power_management_policy
option. When the use selects this option on an empty port, we
will power the port off by setting DET to off. For occupied ports,
behavior is unchanged.
Signed-off-by: Kristen Carlson Accardi <kristen@linux.intel.com>
Commit 4a5610a04d415ed94af75bb1159d2621d62c8328 fixed an issue with
the Pioneer DVR-212D not handling SETXFER correctly. An openSUSE user
reported a similar issue with his DVR-216D that the NOSETXFER horkage
worked around for him as well.
This patch adds the DVR-216D (1.08) to the horkage list for NOSETXFER.
The issue was reported at:
https://bugzilla.novell.com/show_bug.cgi?id=679143
Reported-by: Volodymyr Kyrychenko <vladimir.kirichenko@gmail.com>
Signed-off-by: Jeff Mahoney <jeffm@suse.com>
The ahci_pmp_attach() & ahci_pmp_detach() unmask port irqs, but they
are also called during port initialization, before ahci host irq
handler is registered. On ce4100 platform, this sometimes triggers
"irq 4: nobody cared" message when loading driver.
Fixed this by not touching the register if the port is in frozen
state, and mark all uninitialized port as frozen.
Signed-off-by: Maxime Bizon <mbizon@freebox.fr>
Acked-by: Tejun Heo <tj@kernel.org>
Cc: stable@kernel.org
The function ata_sas_port_init() has always really done its own thing.
However, as a precursor to moving to the libata new eh, it has to be
properly using the standard libata scan paths. This means separating
the current libata scan paths into pieces which can be shared with
libsas and pieces which cant (really just the async call and the host
scan).
Signed-off-by: James Bottomley <James.Bottomley@suse.de>
PIONEER DVR-212D can't do SETXFER like its sibling DVRTD08. Add
ATA_HORKAGE_NOSETXFER for it. Reported in bko#27502.
https://bugzilla.kernel.org/show_bug.cgi?id=27502
Signed-off-by: Francesco Antonacci <fraanto@gmail.com>
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits)
Documentation/trace/events.txt: Remove obsolete sched_signal_send.
writeback: fix global_dirty_limits comment runtime -> real-time
ppc: fix comment typo singal -> signal
drivers: fix comment typo diable -> disable.
m68k: fix comment typo diable -> disable.
wireless: comment typo fix diable -> disable.
media: comment typo fix diable -> disable.
remove doc for obsolete dynamic-printk kernel-parameter
remove extraneous 'is' from Documentation/iostats.txt
Fix spelling milisec -> ms in snd_ps3 module parameter description
Fix spelling mistakes in comments
Revert conflicting V4L changes
i7core_edac: fix typos in comments
mm/rmap.c: fix comment
sound, ca0106: Fix assignment to 'channel'.
hrtimer: fix a typo in comment
init/Kconfig: fix typo
anon_inodes: fix wrong function name in comment
fix comment typos concerning "consistent"
poll: fix a typo in comment
Fix up trivial conflicts in:
- drivers/net/wireless/iwlwifi/iwl-core.c (moved to iwl-legacy.c)
- fs/ext4/ext4.h
Also fix missed 'diabled' typo in drivers/net/bnx2x/bnx2x.h while at it.
* 'for-2.6.38' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq: (33 commits)
usb: don't use flush_scheduled_work()
speedtch: don't abuse struct delayed_work
media/video: don't use flush_scheduled_work()
media/video: explicitly flush request_module work
ioc4: use static work_struct for ioc4_load_modules()
init: don't call flush_scheduled_work() from do_initcalls()
s390: don't use flush_scheduled_work()
rtc: don't use flush_scheduled_work()
mmc: update workqueue usages
mfd: update workqueue usages
dvb: don't use flush_scheduled_work()
leds-wm8350: don't use flush_scheduled_work()
mISDN: don't use flush_scheduled_work()
macintosh/ams: don't use flush_scheduled_work()
vmwgfx: don't use flush_scheduled_work()
tpm: don't use flush_scheduled_work()
sonypi: don't use flush_scheduled_work()
hvsi: don't use flush_scheduled_work()
xen: don't use flush_scheduled_work()
gdrom: don't use flush_scheduled_work()
Fixed up trivial conflict in drivers/media/video/bt8xx/bttv-input.c
as per Tejun.
ata_qc_complete() contains special handling for certain commands. For
example, it schedules EH for device revalidation after certain
configurations are changed. These shouldn't be applied to EH
commands but they were.
In most cases, it doesn't cause an actual problem because EH doesn't
issue any command which would trigger special handling; however, ACPI
can issue such commands via _GTF which can cause weird interactions.
Restructure ata_qc_complete() such that EH commands are always passed
on to __ata_qc_complete().
stable: Please apply to -stable only after 2.6.38 is released.
Reported-by: Kyle McMartin <kyle@mcmartin.ca>
cancel_delayed_work_sync()
cancel_rearming_delayed_work[queue]() has been superceded by
cancel_delayed_work_sync() quite some time ago. Convert all the
in-kernel users. The conversions are completely equivalent and
trivial.
Acked-by: "David S. Miller" <davem@davemloft.net>
Acked-by: Evgeniy Polyakov <zbr@ioremap.net>
Cc: Jeff Garzik <jgarzik@pobox.com>
Cc: Mauro Carvalho Chehab <mchehab@infradead.org>
Cc: netdev@vger.kernel.org
Cc: Anton Vorontsov <cbou@mail.ru>
Cc: "J. Bruce Fields" <bfields@fieldses.org>
Cc: Neil Brown <neilb@suse.de>
Cc: Alex Elder <aelder@sgi.com>
Cc: xfs-masters@oss.sgi.com
Cc: Pekka Enberg <penberg@cs.helsinki.fi>
Cc: netfilter-devel@vger.kernel.org
Cc: Trond Myklebust <Trond.Myklebust@netapp.com>
Cc: linux-nfs@vger.kernel.org
"gadget", "through", "command", "maintain", "maintain", "controller", "address",
"between", "initiali[zs]e", "instead", "function", "select", "already",
"equal", "access", "management", "hierarchy", "registration", "interest",
"relative", "memory", "offset", "already",
In libata, the non-EH code paths should always take and release
ap->lock explicitly when accessing hardware or shared data structures.
However, once EH is active, it's assumed that the port is owned by EH
and EH methods don't explicitly take ap->lock unless race from irq
handler or other code paths are expected. However, libata EH didn't
guarantee exclusion among EHs for ports of the same host. IOW,
multiple EHs may execute in parallel on multiple ports of the same
controller.
In many cases, especially in SATA, the ports are completely
independent of each other and this doesn't cause problems; however,
there are cases where different ports share the same resource, which
lead to obscure timing related bugs such as the one fixed by commit
213373cf (ata_piix: fix locking around SIDPR access).
This patch implements exclusion among EHs of the same host. When EH
begins, it acquires per-host EH ownership by calling ata_eh_acquire().
When EH finishes, the ownership is released by calling
ata_eh_release(). EH ownership is also released whenever the EH
thread goes to sleep from ata_msleep() or explicitly and reacquired
after waking up.
This ensures that while EH is actively accessing the hardware, it has
exclusive access to it while allowing EHs to interleave and progress
in parallel as they hit waiting stages, which dominate the time spent
in EH. This achieves cross-port EH exclusion without pervasive and
fragile changes while still allowing parallel EH for the most part.
This was first reported by yuanding02@gmail.com more than three years
ago in the following bugzilla. :-)
https://bugzilla.kernel.org/show_bug.cgi?id=8223
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
Reported-by: yuanding02@gmail.com
Add optional @ap argument to ata_wait_register() and replace msleep()
calls with ata_msleep() which take optional @ap in addition to the
duration. These will be used to implement EH exclusion.
This patch doesn't cause any behavior difference.
The current LPM implementation has the following issues.
* Operation order isn't well thought-out. e.g. HIPM should be
configured after IPM in SControl is properly configured. Not the
other way around.
* Suspend/resume paths call ata_lpm_enable/disable() which must only
be called from EH context directly. Also, ata_lpm_enable/disable()
were called whether LPM was in use or not.
* Implementation is per-port when it should be per-link. As a result,
it can't be used for controllers with slave links or PMP.
* LPM state isn't managed consistently. After a link reset for
whatever reason including suspend/resume the actual LPM state would
be reset leaving ap->lpm_policy inconsistent.
* Generic/driver-specific logic boundary isn't clear. Currently,
libahci has to mangle stuff which libata EH proper should be
handling. This makes the implementation unnecessarily complex and
fragile.
* Tied to ALPM. Doesn't consider DIPM only cases and doesn't check
whether the device allows HIPM.
* Error handling isn't implemented.
Given the extent of mismatch with the rest of libata, I don't think
trying to fix it piecewise makes much sense. This patch reimplements
LPM support.
* The new implementation is per-link. The target policy is still
port-wide (ap->target_lpm_policy) but all the mechanisms and states
are per-link and integrate well with the rest of link abstraction
and can work with slave and PMP links.
* Core EH has proper control of LPM state. LPM state is reconfigured
when and only when reconfiguration is necessary. It makes sure that
LPM state is reset when probing for new device on the link.
Controller agnostic logic is now implemented in libata EH proper and
driver implementation only has to deal with controller specifics.
* Proper error handling. LPM config failure is attributed to the
device on the link and LPM is disabled for the link if it fails
repeatedly.
* ops->enable/disable_pm() are replaced with single ops->set_lpm()
which takes @policy and @hints. This simplifies driver specific
implementation.
Link power management is about to be reimplemented. Prepare for it.
* Implement sata_link_scr_lpm().
* Drop static from ata_dev_set_feature() and make it available to
other libata files.
* Trivial whitespace adjustments.
Link power management related symbols are in confusing state w/ mixed
usages of lpm, ipm and pm. This patch cleans up lpm related symbols
and sysfs show/store functions as follows.
* lpm states - NOT_AVAILABLE, MIN_POWER, MAX_PERFORMANCE and
MEDIUM_POWER are renamed to ATA_LPM_UNKNOWN and
ATA_LPM_{MIN|MAX|MED}_POWER.
* Pre/postfixes are unified to lpm.
* sysfs show/store functions for link_power_management_policy were
curiously named get/put and unnecessarily complex. Renamed to
show/store and simplified.
Currently, sata_fsl, mv and nv call ata_qc_complete() multiple times
from their interrupt handlers to indicate completion of NCQ commands.
This limits the visibility the libata core layer has into how commands
are being executed and completed, which is necessary to support IRQ
expecting in generic way. libata already has an interface to complete
multiple commands at once - ata_qc_complete_multiple() which ahci and
sata_sil24 already use.
This patch updates the three drivers to use ata_qc_complete_multiple()
too and updates comments on ata_qc_complete[_multiple]() regarding
their usages with NCQ completions. This change not only provides
better visibility into command execution to the core layer but also
simplifies low level drivers.
* sata_fsl: It already builds done_mask. Conversion is straight
forward.
* sata_mv: mv_process_crpb_response() no longer checks for illegal
completions, it just returns whether the tag is completed or not.
mv_process_crpb_entries() builds done_mask from it and passes it to
ata_qc_complete_multiple() which will check for illegal completions.
* sata_nv adma: Similar to sata_mv. nv_adma_check_cpb() now just
returns the tag status and nv_adma_interrupt() builds done_mask from
it and passes it to ata_qc_complete_multiple().
* sata_nv swncq: It already builds done_mask. Drop unnecessary
illegal transition checks and call ata_qc_complete_multiple().
In the long run, it might be a good idea to make ata_qc_complete()
whine if called when multiple NCQ commands are in flight.
Cc: Ashish Kalra <ashish.kalra@freescale.com>
Cc: Saeed Bishara <saeed@marvell.com>
Cc: Mark Lord <liml@rtr.ca>
Cc: Robert Hancock <hancockr@shaw.ca>
This is a scheleton for libata transport class.
All information is read only, exporting information from libata:
- ata_port class: one per ATA port
- ata_link class: one per ATA port or 15 for SATA Port Multiplier
- ata_device class: up to 2 for PATA link, usually one for SATA.
Signed-off-by: Gwendal Grignou <gwendal@google.com>
Reviewed-by: Grant Grundler <grundler@google.com>
For some mysterious reason, certain hardware reacts badly to usual EH
actions while the system is going for suspend. As the devices won't
be needed until the system is resumed, ask EH to skip usual autopsy
and recovery and proceed directly to suspend.
Tested-by: Stephan Diestelhorst <stephan.diestelhorst@amd.com>
ata_qc_issue() BUG_ON()s on data commands w/o data, which may be
submitted via SG_IO. Be less of a drama queen and just trigger
WARN_ON_ONCE() and fail the command with AC_ERR_SYSTEM.
Reported-by: Stefan Hübner <stefan.huebner@stud.tu-ilmenau.de>
'make htmldocs' has a fatal error when processing libata.xml, as seen
below. The string "Example patterns:" (or any string with "example.*:"
in it AFAIK) causes some part of the doc generation tool chain to try to
produce an <informalexample> block without a beginning <para>, but
there is an ending </para> generated, which throws things out of kilter.
I don't even know where (what program) this is happening in.
I searched in docproc and xmlto and in some XML stylesheets without
finding anything. If anyone can give me pointers about this, please do.
Until this is fixed, let's just spell "Example" as "Sample"
and match up the double quotation marks while there.
Documentation/DocBook/libata.xml:6575: parser error : Opening and ending tag mismatch: programlisting line 6573 and para
</para><para>
Documentation/DocBook/libata.xml:6580: parser error : Opening and ending tag mismatch: para line 6575 and programlisting
</programlisting></informalexample>
unable to parse Documentation/DocBook/libata.xml
make[2]: *** [Documentation/DocBook/libata.html] Error 1
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq: (55 commits)
workqueue: mark init_workqueues() as early_initcall()
workqueue: explain for_each_*cwq_cpu() iterators
fscache: fix build on !CONFIG_SYSCTL
slow-work: kill it
gfs2: use workqueue instead of slow-work
drm: use workqueue instead of slow-work
cifs: use workqueue instead of slow-work
fscache: drop references to slow-work
fscache: convert operation to use workqueue instead of slow-work
fscache: convert object to use workqueue instead of slow-work
workqueue: fix how cpu number is stored in work->data
workqueue: fix mayday_mask handling on UP
workqueue: fix build problem on !CONFIG_SMP
workqueue: fix locking in retry path of maybe_create_worker()
async: use workqueue for worker pool
workqueue: remove WQ_SINGLE_CPU and use WQ_UNBOUND instead
workqueue: implement unbound workqueue
workqueue: prepare for WQ_UNBOUND implementation
libata: take advantage of cmwq and remove concurrency limitations
workqueue: fix worker management invocation without pending works
Fixed up conflicts in fs/cifs/* as per Tejun. Other trivial conflicts in
include/linux/workqueue.h, kernel/trace/Kconfig and kernel/workqueue.c
Take further advantage of the new glob_match() function to reduce
the blacklist size, this time making use of "character ranges" in
the patterns.
Signed-off-by: Mark Lord <mlord@pobox.com>
Enable use of hyphenated pattern ranges in glob_match(), similar to how
shell globbing works, and how developers might expect things to work.
the blacklist size. There are even more savings possible, but how
far do we want to go with this?
Take advantage of the new glob_match() function to reduce the blacklist
size somewhat. There are further savings possible, but these are
the most obvious biggies.
Replace rudimentry pattern matching with more capable shell-style globbing.
This will enable shrinking ata_device_blacklist[] table in subsequent patches,
and helps with future editions to the table, such as matching only the end
of a firmware revision string etc..
libata has two concurrency related limitations.
a. ata_wq which is used for polling PIO has single thread per CPU. If
there are multiple devices doing polling PIO on the same CPU, they
can't be executed simultaneously.
b. ata_aux_wq which is used for SCSI probing has single thread. In
cases where SCSI probing is stalled for extended period of time
which is possible for ATAPI devices, this will stall all probing.
#a is solved by increasing maximum concurrency of ata_wq. Please note
that polling PIO might be used under allocation path and thus needs to
be served by a separate wq with a rescuer.
#b is solved by using the default wq instead and achieving exclusion
via per-port mutex.
Acked-by: Jeff Garzik <jgarzik@pobox.com>
Implement ata_scsi_unlock_native_capacity() which will be called
through SCSI layer when block layer notices that partitions on a
device extend beyond the end of the device. It requests EH to unlock
HPA, waits for completion and returns the current device capacity.
This allows libata to unlock HPA on demand instead of having to decide
whether to unlock upfront. Unlocking on demand is safer than
unlocking by upfront because some BIOSes write private data to the
area beyond HPA limit. This was suggested by Ben Hutchings.
Suggested-by: Ben Hutchings <ben@decadent.org.uk>
After late HPA unlock, libata kept using the original capacity
ignoring the new larger native capacity. Enlarging device on the fly
doesn't cause any harm. Use the larger native capacity instead. This
will enable on-demand HPA unlocking.
Cc: Ben Hutchings <ben@decadent.org.uk>
Add dump_id libata.force parameter. If specified, libata dumps full
IDENTIFY data during device configuration. This is to aid debugging.
Cc: Larry Baker <baker@usgs.gov>
There are ATAPI devices which raise AN when hit by commands issued by
open(). This leads to infinite loop of AN -> MEDIA_CHANGE uevent ->
udev open() to check media -> AN.
Both ACS and SerialATA standards don't define in which case ATAPI
devices are supposed to raise or not raise AN. They both list media
insertion event as a possible use case for ATAPI ANs but there is no
clear description of what constitutes such events. As such, it seems
a bit too naive to export ANs directly to userland as MEDIA_CHANGE
events without further verification (which should behave similarly to
windows as it apparently is the only thing that some hardware vendors
are testing against).
This patch adds libata.atapi_an module parameter and disables ATAPI AN
by default for now.
Cc: Kay Sievers <kay.sievers@vrfy.org>
Cc: Nick Bowler <nbowler@elliptictech.com>
Cc: David Zeuthen <david@fubar.dk>
port_task is tightly bound to the standard SFF PIO HSM implementation.
Using it for any other purpose would be error-prone and there's no
such user and if some drivers need such feature, it would be much
better off using its own. Move it inside CONFIG_ATA_SFF and rename it
to sff_pio_task.
The only function which is exposed to the core layer is
ata_sff_flush_pio_task() which is renamed from ata_port_flush_task()
and now also takes care of resetting hsm_task_state to HSM_ST_IDLE,
which is possible as it's now specific to PIO HSM.
ap->[last_]ctl are specific to SFF controllers. Put them inside
CONFIG_ATA_SFF and move initialization into ata_sff_port_init().
In preparation of proper SFF/BMDMA separation, introduce
ata_sff_init/exit() and ata_sff_port_init(). These functions
currently don't do anything.
When BMDMA initialization failed or BMDMA was not available for
whatever reason, bmdma_addr was left at zero and used as an indication
that BMDMA shouldn't be used. This leads to the following problems.
p1. For BMDMA drivers which don't use traditional BMDMA register,
ata_bmdma_mode_filter() incorrectly inhibits DMA modes. Those
drivers either have to inherit from ata_sff_port_ops or clear
->mode_filter explicitly.
p2. non-BMDMA drivers call into BMDMA PRD table allocation. It
doesn't actually allocate PRD table if bmdma_addr is not
initialized but is still confusing.
p3. For BMDMA drivers which don't use traditional BMDMA register, some
methods might not be invoked as expected (e.g. bmdma_stop from
ata_sff_post_internal_cmd()).
p4. SFF drivers w/ custom DMA interface implement noop BMDMA ops
worrying libata core might call into one of them.
These problems are caused by the muddy line between SFF and BMDMA and
the assumption that all BMDMA controllers initialize bmdma_addr.
This patch fixes p1 and p2 by removing the bmdma_addr assumption and
moving prd allocation to BMDMA port start. Later patches will fix the
remaining issues.
This patch improves BMDMA initialization such that
* When BMDMA register initialization fails, falls back to PIO instead
of failing. ata_pci_bmdma_init() never fails now.
* When ata_pci_bmdma_init() falls back to PIO, it clears
ap->mwdma_mask and udma_mask instead of depending on
ata_bmdma_mode_filter(). This makes ata_bmdma_mode_filter()
unnecessary thus resolving p1.
* ata_port_start() which actually is BMDMA specific is moved to
ata_bmdma_port_start(). ata_port_start() and ata_sff_port_start()
are killed.
* ata_sff_port_start32() is moved and renamed to
ata_bmdma_port_start32().
Drivers which no longer call into PRD table allocation are...
pdc_adma, sata_inic162x, sata_qstor, sata_sx4, pata_cmd640 and all
drivers which inherit from ata_sff_port_ops.
pata_icside sets ->port_start to ATA_OP_NULL as it doesn't need PRD
but is a BMDMA controller and doesn't have custom port_start like
other such controllers.
Note that with the previous patch which makes all and only BMDMA
drivers inherit from ata_bmdma_port_ops, this change doesn't break
drivers which need PRD table.
ATA_FLAG_DISABLED is only used by drivers which don't use
->error_handler framework and is largely broken. Its only meaningful
function is to make irq handlers skip processing if the flag is set,
which is largely useless and even harmful as it makes those ports more
likely to cause IRQ storms.
Kill ATA_FLAG_DISABLED and makes the callers disable attached devices
instead. ata_port_probe() and ata_port_disable() which manipulate the
flag are also killed.
This simplifies condition check in IRQ handlers. While updating IRQ
handlers, remove ap NULL check as libata guarantees consecutive port
allocation (unoccupied ports are initialized with dummies) and
long-obsolete ATA_QCFLAG_ACTIVE check (checked by ata_qc_from_tag()).
Use __ratelimit() instead of its own private rate limit implementation.
Cc: linux-ide@vger.kernel.org
There are some SATA devices which take relatively long to get out of
0xff status after reset. In libata, this timeout is determined by
ATA_TMOUT_FF_WAIT. Quantum GoVault is the worst requring about 2s for
reliable detection. However, because 2s 0xff timeout can introduce
rather long spurious delay during boot, libata has been compromising
at the next longest timeout of 800ms for HHD424020F7SV00 iVDR drive.
Now that parallel scan is in place for common drivers, libata can
afford 2s 0xff timeout. Use 2s 0xff timeout if parallel scan is
enabled.
Please note that the chance of spurious wait is pretty slim w/ working
SCR access so this will only affect SATA controllers w/o SCR access
which isn't too common these days.
Please read the following thread for more information on the GoVault
drive.
http://thread.gmane.org/gmane.linux.ide/14545/focus=14663
Cc: Gary Hade <garyhade@us.ibm.com>
Some BIOSes don't configure HPA during boot but do so while resuming.
This causes harddrives to shrink during resume making libata detach
and reattach them. This can be worked around by unlocking HPA if old
size equals native size.
Add ATA_DFLAG_UNLOCK_HPA so that HPA unlocking can be controlled
per-device and update ata_dev_revalidate() such that it sets
ATA_DFLAG_UNLOCK_HPA and fails with -EIO when the above condition is
detected.
This patch fixes the following bug.
https://bugzilla.kernel.org/show_bug.cgi?id=15396
Reported-by: Oleksandr Yermolenko <yaa.bta@gmail.com>
Crucial said,
Thank you for contacting us. We know that with our M225 line of SSDs
you sometimes need to disable NCQ (native command queuing) to avoid
just the type of errors you're seeing. Our recommendation for the
M225 is to add libata.force=noncq to your Linux kernel boot options,
under the kernel ATA library option.
I have sent your feedback to the engineers working on the C300, and
asked them to please pass it on to the firmware team. I have been
notified that they are in the process of testing and finalizing a
new firmware version, that you can expect to see released around the
end of April. We’ll keep you posted as to when it will be available
for download.
So, turn off NCQ on the drive w/ the current firmware revision.
Reported in the following bug.
https://bugzilla.kernel.org/show_bug.cgi?id=15573
Reported-by: lethalwp@scarlet.be
Reported-by: Luke Macken <lmacken@redhat.com>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Documentation/filesystems/proc.txt
arch/arm/mach-u300/include/mach/debug-macro.S
drivers/net/qlge/qlge_ethtool.c
drivers/net/qlge/qlge_main.c
drivers/net/typhoon.c
Use standard cycle timing for CFA PIO5 and PIO6 modes.
Based on commit 74638c8 for IDE subsystem.
Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
Some comments misspell "should" or "shouldn't"; this fixes them. No code changes.
Signed-off-by: Adam Buchbinder <adam.buchbinder@gmail.com>
Interestingly, when SIDPR is used in ata_piix, writes to DET in
SControl sometimes get ignored leading to detection failure. Update
sata_link_resume() such that it reads back SControl after clearing DET
and retry if it's not clear.
Reported-by: fengxiangjun <fengxiangjun@neusoft.com>
Reported-by: Jim Faulkner <jfaulkne@ccs.neu.edu>
Based on:
http://lkml.indiana.edu/hypermail/linux/kernel/0908.2/01420.html
In each case, if the NULL test on qc is needed, then the derefernce
should be after the NULL test.
A simplified version of the semantic match that detects this problem is as
follows (http://coccinelle.lip6.fr/):
// <smpl>
@match exists@
expression x, E;
identifier fld;
* x->fld
... when != \(x = E\|&x\)
* x == NULL
// </smpl>
