For some mysterious reason, certain hardware reacts badly to usual EH
actions while the system is going for suspend. As the devices won't
be needed until the system is resumed, ask EH to skip usual autopsy
and recovery and proceed directly to suspend.
Tested-by: Stephan Diestelhorst <stephan.diestelhorst@amd.com>
Cc: stable@kernel.org
ata_qc_issue() BUG_ON()s on data commands w/o data, which may be
submitted via SG_IO. Be less of a drama queen and just trigger
WARN_ON_ONCE() and fail the command with AC_ERR_SYSTEM.
Reported-by: Stefan Hübner <stefan.huebner@stud.tu-ilmenau.de>
'make htmldocs' has a fatal error when processing libata.xml, as seen
below. The string "Example patterns:" (or any string with "example.*:"
in it AFAIK) causes some part of the doc generation tool chain to try to
produce an <informalexample> block without a beginning <para>, but
there is an ending </para> generated, which throws things out of kilter.
I don't even know where (what program) this is happening in.
I searched in docproc and xmlto and in some XML stylesheets without
finding anything. If anyone can give me pointers about this, please do.
Until this is fixed, let's just spell "Example" as "Sample"
and match up the double quotation marks while there.
Documentation/DocBook/libata.xml:6575: parser error : Opening and ending tag mismatch: programlisting line 6573 and para
</para><para>
Documentation/DocBook/libata.xml:6580: parser error : Opening and ending tag mismatch: para line 6575 and programlisting
</programlisting></informalexample>
unable to parse Documentation/DocBook/libata.xml
make[2]: *** [Documentation/DocBook/libata.html] Error 1
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq: (55 commits)
workqueue: mark init_workqueues() as early_initcall()
workqueue: explain for_each_*cwq_cpu() iterators
fscache: fix build on !CONFIG_SYSCTL
slow-work: kill it
gfs2: use workqueue instead of slow-work
drm: use workqueue instead of slow-work
cifs: use workqueue instead of slow-work
fscache: drop references to slow-work
fscache: convert operation to use workqueue instead of slow-work
fscache: convert object to use workqueue instead of slow-work
workqueue: fix how cpu number is stored in work->data
workqueue: fix mayday_mask handling on UP
workqueue: fix build problem on !CONFIG_SMP
workqueue: fix locking in retry path of maybe_create_worker()
async: use workqueue for worker pool
workqueue: remove WQ_SINGLE_CPU and use WQ_UNBOUND instead
workqueue: implement unbound workqueue
workqueue: prepare for WQ_UNBOUND implementation
libata: take advantage of cmwq and remove concurrency limitations
workqueue: fix worker management invocation without pending works
Fixed up conflicts in fs/cifs/* as per Tejun. Other trivial conflicts in
include/linux/workqueue.h, kernel/trace/Kconfig and kernel/workqueue.c
Take further advantage of the new glob_match() function to reduce
the blacklist size, this time making use of "character ranges" in
the patterns.
Signed-off-by: Mark Lord <mlord@pobox.com>
Enable use of hyphenated pattern ranges in glob_match(), similar to how
shell globbing works, and how developers might expect things to work.
the blacklist size. There are even more savings possible, but how
far do we want to go with this?
Take advantage of the new glob_match() function to reduce the blacklist
size somewhat. There are further savings possible, but these are
the most obvious biggies.
Replace rudimentry pattern matching with more capable shell-style globbing.
This will enable shrinking ata_device_blacklist[] table in subsequent patches,
and helps with future editions to the table, such as matching only the end
of a firmware revision string etc..
libata has two concurrency related limitations.
a. ata_wq which is used for polling PIO has single thread per CPU. If
there are multiple devices doing polling PIO on the same CPU, they
can't be executed simultaneously.
b. ata_aux_wq which is used for SCSI probing has single thread. In
cases where SCSI probing is stalled for extended period of time
which is possible for ATAPI devices, this will stall all probing.
#a is solved by increasing maximum concurrency of ata_wq. Please note
that polling PIO might be used under allocation path and thus needs to
be served by a separate wq with a rescuer.
#b is solved by using the default wq instead and achieving exclusion
via per-port mutex.
Acked-by: Jeff Garzik <jgarzik@pobox.com>
Implement ata_scsi_unlock_native_capacity() which will be called
through SCSI layer when block layer notices that partitions on a
device extend beyond the end of the device. It requests EH to unlock
HPA, waits for completion and returns the current device capacity.
This allows libata to unlock HPA on demand instead of having to decide
whether to unlock upfront. Unlocking on demand is safer than
unlocking by upfront because some BIOSes write private data to the
area beyond HPA limit. This was suggested by Ben Hutchings.
Suggested-by: Ben Hutchings <ben@decadent.org.uk>
After late HPA unlock, libata kept using the original capacity
ignoring the new larger native capacity. Enlarging device on the fly
doesn't cause any harm. Use the larger native capacity instead. This
will enable on-demand HPA unlocking.
Cc: Ben Hutchings <ben@decadent.org.uk>
Add dump_id libata.force parameter. If specified, libata dumps full
IDENTIFY data during device configuration. This is to aid debugging.
Cc: Larry Baker <baker@usgs.gov>
There are ATAPI devices which raise AN when hit by commands issued by
open(). This leads to infinite loop of AN -> MEDIA_CHANGE uevent ->
udev open() to check media -> AN.
Both ACS and SerialATA standards don't define in which case ATAPI
devices are supposed to raise or not raise AN. They both list media
insertion event as a possible use case for ATAPI ANs but there is no
clear description of what constitutes such events. As such, it seems
a bit too naive to export ANs directly to userland as MEDIA_CHANGE
events without further verification (which should behave similarly to
windows as it apparently is the only thing that some hardware vendors
are testing against).
This patch adds libata.atapi_an module parameter and disables ATAPI AN
by default for now.
Cc: Kay Sievers <kay.sievers@vrfy.org>
Cc: Nick Bowler <nbowler@elliptictech.com>
Cc: David Zeuthen <david@fubar.dk>
port_task is tightly bound to the standard SFF PIO HSM implementation.
Using it for any other purpose would be error-prone and there's no
such user and if some drivers need such feature, it would be much
better off using its own. Move it inside CONFIG_ATA_SFF and rename it
to sff_pio_task.
The only function which is exposed to the core layer is
ata_sff_flush_pio_task() which is renamed from ata_port_flush_task()
and now also takes care of resetting hsm_task_state to HSM_ST_IDLE,
which is possible as it's now specific to PIO HSM.
ap->[last_]ctl are specific to SFF controllers. Put them inside
CONFIG_ATA_SFF and move initialization into ata_sff_port_init().
In preparation of proper SFF/BMDMA separation, introduce
ata_sff_init/exit() and ata_sff_port_init(). These functions
currently don't do anything.
When BMDMA initialization failed or BMDMA was not available for
whatever reason, bmdma_addr was left at zero and used as an indication
that BMDMA shouldn't be used. This leads to the following problems.
p1. For BMDMA drivers which don't use traditional BMDMA register,
ata_bmdma_mode_filter() incorrectly inhibits DMA modes. Those
drivers either have to inherit from ata_sff_port_ops or clear
->mode_filter explicitly.
p2. non-BMDMA drivers call into BMDMA PRD table allocation. It
doesn't actually allocate PRD table if bmdma_addr is not
initialized but is still confusing.
p3. For BMDMA drivers which don't use traditional BMDMA register, some
methods might not be invoked as expected (e.g. bmdma_stop from
ata_sff_post_internal_cmd()).
p4. SFF drivers w/ custom DMA interface implement noop BMDMA ops
worrying libata core might call into one of them.
These problems are caused by the muddy line between SFF and BMDMA and
the assumption that all BMDMA controllers initialize bmdma_addr.
This patch fixes p1 and p2 by removing the bmdma_addr assumption and
moving prd allocation to BMDMA port start. Later patches will fix the
remaining issues.
This patch improves BMDMA initialization such that
* When BMDMA register initialization fails, falls back to PIO instead
of failing. ata_pci_bmdma_init() never fails now.
* When ata_pci_bmdma_init() falls back to PIO, it clears
ap->mwdma_mask and udma_mask instead of depending on
ata_bmdma_mode_filter(). This makes ata_bmdma_mode_filter()
unnecessary thus resolving p1.
* ata_port_start() which actually is BMDMA specific is moved to
ata_bmdma_port_start(). ata_port_start() and ata_sff_port_start()
are killed.
* ata_sff_port_start32() is moved and renamed to
ata_bmdma_port_start32().
Drivers which no longer call into PRD table allocation are...
pdc_adma, sata_inic162x, sata_qstor, sata_sx4, pata_cmd640 and all
drivers which inherit from ata_sff_port_ops.
pata_icside sets ->port_start to ATA_OP_NULL as it doesn't need PRD
but is a BMDMA controller and doesn't have custom port_start like
other such controllers.
Note that with the previous patch which makes all and only BMDMA
drivers inherit from ata_bmdma_port_ops, this change doesn't break
drivers which need PRD table.
ATA_FLAG_DISABLED is only used by drivers which don't use
->error_handler framework and is largely broken. Its only meaningful
function is to make irq handlers skip processing if the flag is set,
which is largely useless and even harmful as it makes those ports more
likely to cause IRQ storms.
Kill ATA_FLAG_DISABLED and makes the callers disable attached devices
instead. ata_port_probe() and ata_port_disable() which manipulate the
flag are also killed.
This simplifies condition check in IRQ handlers. While updating IRQ
handlers, remove ap NULL check as libata guarantees consecutive port
allocation (unoccupied ports are initialized with dummies) and
long-obsolete ATA_QCFLAG_ACTIVE check (checked by ata_qc_from_tag()).
Use __ratelimit() instead of its own private rate limit implementation.
Cc: Jeff Garzik <jgarzik@pobox.com>
Cc: linux-ide@vger.kernel.org
There are some SATA devices which take relatively long to get out of
0xff status after reset. In libata, this timeout is determined by
ATA_TMOUT_FF_WAIT. Quantum GoVault is the worst requring about 2s for
reliable detection. However, because 2s 0xff timeout can introduce
rather long spurious delay during boot, libata has been compromising
at the next longest timeout of 800ms for HHD424020F7SV00 iVDR drive.
Now that parallel scan is in place for common drivers, libata can
afford 2s 0xff timeout. Use 2s 0xff timeout if parallel scan is
enabled.
Please note that the chance of spurious wait is pretty slim w/ working
SCR access so this will only affect SATA controllers w/o SCR access
which isn't too common these days.
Please read the following thread for more information on the GoVault
drive.
http://thread.gmane.org/gmane.linux.ide/14545/focus=14663
Cc: Gary Hade <garyhade@us.ibm.com>
Some BIOSes don't configure HPA during boot but do so while resuming.
This causes harddrives to shrink during resume making libata detach
and reattach them. This can be worked around by unlocking HPA if old
size equals native size.
Add ATA_DFLAG_UNLOCK_HPA so that HPA unlocking can be controlled
per-device and update ata_dev_revalidate() such that it sets
ATA_DFLAG_UNLOCK_HPA and fails with -EIO when the above condition is
detected.
This patch fixes the following bug.
https://bugzilla.kernel.org/show_bug.cgi?id=15396
Reported-by: Oleksandr Yermolenko <yaa.bta@gmail.com>
Crucial said,
Thank you for contacting us. We know that with our M225 line of SSDs
you sometimes need to disable NCQ (native command queuing) to avoid
just the type of errors you're seeing. Our recommendation for the
M225 is to add libata.force=noncq to your Linux kernel boot options,
under the kernel ATA library option.
I have sent your feedback to the engineers working on the C300, and
asked them to please pass it on to the firmware team. I have been
notified that they are in the process of testing and finalizing a
new firmware version, that you can expect to see released around the
end of April. We’ll keep you posted as to when it will be available
for download.
So, turn off NCQ on the drive w/ the current firmware revision.
Reported in the following bug.
https://bugzilla.kernel.org/show_bug.cgi?id=15573
Reported-by: lethalwp@scarlet.be
Reported-by: Luke Macken <lmacken@redhat.com>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Documentation/filesystems/proc.txt
arch/arm/mach-u300/include/mach/debug-macro.S
drivers/net/qlge/qlge_ethtool.c
drivers/net/qlge/qlge_main.c
drivers/net/typhoon.c
Use standard cycle timing for CFA PIO5 and PIO6 modes.
Based on commit 74638c8 for IDE subsystem.
Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
Some comments misspell "should" or "shouldn't"; this fixes them. No code changes.
Signed-off-by: Adam Buchbinder <adam.buchbinder@gmail.com>
Interestingly, when SIDPR is used in ata_piix, writes to DET in
SControl sometimes get ignored leading to detection failure. Update
sata_link_resume() such that it reads back SControl after clearing DET
and retry if it's not clear.
Reported-by: fengxiangjun <fengxiangjun@neusoft.com>
Reported-by: Jim Faulkner <jfaulkne@ccs.neu.edu>
Based on:
http://lkml.indiana.edu/hypermail/linux/kernel/0908.2/01420.html
In each case, if the NULL test on qc is needed, then the derefernce
should be after the NULL test.
A simplified version of the semantic match that detects this problem is as
follows (http://coccinelle.lip6.fr/):
// <smpl>
@match exists@
expression x, E;
identifier fld;
* x->fld
... when != \(x = E\|&x\)
* x == NULL
// </smpl>
When an internal command fails, it should be failed directly without
invoking EH. In the original implemetation, this was accomplished by
letting internal command bypass failure handling in ata_qc_complete().
However, later changes added post-successful-completion handling to
that code path and the success path is no longer adequate as internal
command failure path. One of the visible problems is that internal
command failure due to timeout or other freeze conditions would
spuriously trigger WARN_ON_ONCE() in the success path.
This patch updates failure path such that internal command failure
handling is contained there.
Add ->gtf_filter to ata_device and set it to ata_acpi_gtf_filter when
initializing ata_link. This is to allow quirks which apply different
gtf filters.
Commit 54c38444fad6a99b4b19512f8f0055d69115e69e makes libata abort qcs
after the port is frozen. This is necessary to guarantee that TF
registers are accessed after the DMA engine is shutdown after an
error. However, this triggers WARN_ON_ONCE() check in
ata_qc_complete() spuriously. Move WARN_ON_ONCE() downwards such that
failing commands while frozen doesn't trigger it.
Cc: stable <stable@kernel.org>
ata_tf_read_block() has off-by-one error when converting CHS address
to LBA. The bug isn't very visible because ata_tf_read_block() is
used only when generating sense data for a failed RW command and CHS
addressing isn't used too often these days.
This problem was spotted by Atsushi Nemoto.
Reported-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp>
Hopefully results in fewer on-the-wire FIS's and no breakage. We'll see!
Signed-off-by: Shaohua Li <shaohua.li@intel.com>
OCZ Vertex SSD can't do HPA and not in a usual way. It reports HPA,
allows unlocking but then fails all IOs which fall in the unlocked
area. Quirk it so that HPA unlocking is not used for the device.
Reported by Daniel Perup in bnc#522414.
https://bugzilla.novell.com/show_bug.cgi?id=522414
Reported-by: Daniel Perup <probe@spray.se>
On certain configurations, HPA isn't or can't be unlocked during
probing but it somehow ends up unlocked afterwards. In the following
thread, the problem can be reliably reproduced after resuming from
STR. The BIOS turns on HPA during boot but forgets to do it during
resume.
http://thread.gmane.org/gmane.linux.kernel/858310
This patch updates libata revalidation such that it considers native
n_sectors. If the device size has increased to match native
n_sectors, it's assumed that HPA has been unlocked involuntarily and
the device is recognized as the same one. This should be fairly safe
while nicely working around the problem.
Reported-by: Christof Warlich <christof@warlich.name>
PIONEER DVD-RW DVRTD08 times out SETXFER if no media is present. The
device is SATA and simply skipping SETXFER works around the problem.
Implement ATA_HORKAGE_NOSETXFER and apply it to the device.
Reported by Moritz Rigler in the following thread.
http://thread.gmane.org/gmane.linux.ide/36790
and by Lars in bko#9540.
Updated to whine and ignore NOSETXFER if PATA component is detected as
suggested by Alan Cox.
Reported-by: Moritz Rigler <linux-ide@momail.e4ward.com>
Reported-by: Lars <lars21ce@gmx.de>
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
Before issuing reset, libata configures xfermode to PIO0 which makes
some drivers turn on IORDY which may cause the controller to lock up
if the port is not occupied. IORDY isn't necessary at this point
anyway. Make ata_pio_need_iordy() return zero if it's being called
for reset.
This fixes bko#11703. Reported and tracked down by Daniel Gnoutcheff
and Constantine Gavrilov.
Reported-by: Daniel Gnoutcheff <gnoutchd@union.edu>
Cc: Constantine Gavrilov <constantine.gavrilov@gmail.com>
1. add defaults to description where possible
2. add value definition (off=0, on=1) where missing
v2: reformatted as per request by Jeff Garzik <jgarzik@pobox.com>
"Enable foo (0=off, 1=on [default])"
Signed-off-by: Evgeni Golov <sargentd@die-welt.net>
We very rarely (if ever) complete more than one command in the
sactive mask at the time, even for extremely high IO rates. So
looping over the entire range of possible tags is pointless,
instead use __ffs() to just find the completed tags directly.
Updated to clear the tag from the done_mask instead of shifting
done_mask down as suggested by From: Tejun Heo <htejun@gmail.com>
Verified with a user space tester to produce the same results.
79b42babbac2a5a522b8e269fb2811b6e1063030 fixed identifying ATA devices
reporting 3c/c3 signature which belongs to SEMB devices now. However,
suspending the machine with such device (WDC WD2500AAJS-6 01.0) fails
with the following:
hda: host max PIO4 wanted PIO255(auto-tune) selected PIO4
hda: UDMA/100 mode selected
hdb: host max PIO4 wanted PIO255(auto-tune) selected PIO4
hdb: UDMA/66 mode selected
sd 1:0:0:0: [sda] Starting disk
ata5: SATA link down (SStatus 0 SControl 300)
ata1: SATA link down (SStatus 0 SControl 300)
ata3: SATA link down (SStatus 0 SControl 300)
ata6: SATA link down (SStatus 0 SControl 300)
ata2: softreset failed (device not ready)
ata2: failed due to HW bug, retry pmp=0
ata4: softreset failed (device not ready)
ata4: failed due to HW bug, retry pmp=0
ata4: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
ata2: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
ata2.00: class mismatch 1 != 7
ata2.00: revalidation failed (errno=-19)
ata2: limiting SATA link speed to 1.5 Gbps
ata4.00: configured for UDMA/133
ata2: SATA link up 1.5 Gbps (SStatus 113 SControl 310)
ata2.00: disabled
sd 1:0:0:0: rejecting I/O to offline device
sd 1:0:0:0: [sda] START_STOP FAILED
sd 1:0:0:0: [sda] Result: hostbyte=0x01 driverbyte=0x00
PM: Device 1:0:0:0 failed to thaw: error 65536
sd 3:0:0:0: [sdb] Starting disk
due to a class mismatch in ata_dev_revalidate(). Fix it by adding the
ATA_DEV_SEMB device class to the check.
CC: Tejun Heo <htejun@gmail.com>
Signed-off-by: Borislav Petkov <petkovbb@gmail.com>
Use ATA_ID_CFA_* constants for CFA specific identify data words 162 and 163.
WDC WD1600JS-62MHB5 successfully hits the window between ATA/ATAPI-7
and Serial ATA II standards and reports 3c/c3 signature which now is
assigned to SEMB. Make ata_dev_classify() report ATA_DEV_SEMB on the
sig and let ata_dev_read_id() work around it by trying IDENTIFY once.
This fixes bko#11579.
Reported-by: David Haun <drhaun88@gmail.com>
Reported-by: Lars Wirzenius <liw@liw.fi>
Reported-by: Juan Manuel <jmcarranza@gmail.com>
Also remove the now-useless debug printouts which are supposed to
tell us when the scan starts and ends.
Signed-off-by: Vegard Nossum <vegard.nossum@gmail.com>
Make libata more robust when parsing the multi_count
field from a drive's identify data. This prevents us from
attempting to use dubious multi_count values ad infinitum.
Reset dev->multi_count to zero and reprobe it each time
through this routine, as it can change on device reset.
Also ensure that the reported "maximum" value is valid
and is a power of two, and that the reported "count" value
is valid and also a power of two. And that the "count"
value is not greater than the "maximum" value.
Hanno Böck reported a problem where an old Conner CP30254 240MB hard drive
was reported as 1.1TB in capacity by libata:
http://lkml.org/lkml/2009/2/13/134
This was caused by libata trusting the drive's reported current capacity in
sectors in identify words 57 and 58 if the drive does not support LBA and the
current CHS translation values appear valid. Unfortunately it seems older
ATA specs were vague about what this field should contain and a number of drives
used values with wrong byte order or that were totally bogus. There's no
unique information that it conveys and so we can just calculate the number
of sectors from the reported current CHS values.
While we're at it, clean up this function to use named constants for the
identify word values.
Signed-off-by: Robert Hancock <hancockrwd@gmail.com>
libata passes the returned value of dma_map_sg() to
dma_unmap_sg(),which is the misuse of dma_unmap_sg().
DMA-mapping.txt says:
To unmap a scatterlist, just call:
pci_unmap_sg(pdev, sglist, nents, direction);
Again, make sure DMA activity has already finished.
PLEASE NOTE: The 'nents' argument to the pci_unmap_sg call must be
the _same_ one you passed into the pci_map_sg call,
it should _NOT_ be the 'count' value _returned_ from the
pci_map_sg call.
Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
Acked-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
Acked-by: Tejun Heo <tj@kernel.org>
3Gbps is often much more prone to transmission failures. It's usually
okay to let EH handle speed down after transmission failures but some
WD My Book drives completely shutdown after certain transmission
failures and after it only power cycling can revive them. Combined
with the fact that external drives often end up with cable assembly
which is longer than usual and more likely to have intervening gender,
this makes these drives very likely to shutdown under certain
configurations virtually rendering them unusable.
This patch implements HOARKGE_1_5_GBPS and applies it to WD My Book
such that 1.5Gbps is forced once the device is identified.
Please take a look at the following bz for related reports.
http://bugzilla.kernel.org/show_bug.cgi?id=9913
