[ Upstream commit 1d72f7aec3595249dbb83291ccac041a2d676c57 ]
If the call to scsi_add_host_with_dma() in ata_scsi_add_hosts() fails,
then we may get use-after-free KASAN warns:
BUG: KASAN: use-after-free in kobject_put+0x24/0x180
Read of size 1 at addr ffff0026b8c80364 by task swapper/0/1
CPU: 1 PID: 1 Comm: swapper/0 Tainted: G W 5.6.0-rc3-00004-g5a71b206ea82-dirty #1765
Hardware name: Huawei TaiShan 200 (Model 2280)/BC82AMDD, BIOS 2280-V2 CS V3.B160.01 02/24/2020
Call trace:
dump_backtrace+0x0/0x298
show_stack+0x14/0x20
dump_stack+0x118/0x190
print_address_description.isra.9+0x6c/0x3b8
__kasan_report+0x134/0x23c
kasan_report+0xc/0x18
__asan_load1+0x5c/0x68
put_device+0x10/0x20
scsi_host_put+0x10/0x18
ata_devres_release+0x74/0xb0
release_nodes+0x2d0/0x470
devres_release_all+0x50/0x78
really_probe+0x2d4/0x560
driver_probe_device+0x7c/0x148
device_driver_attach+0x94/0xa0
__driver_attach+0xa8/0x110
bus_for_each_dev+0xe8/0x158
driver_attach+0x30/0x40
bus_add_driver+0x220/0x2e0
driver_register+0xbc/0x1d0
__pci_register_driver+0xbc/0xd0
ahci_pci_driver_init+0x20/0x28
do_one_initcall+0xf0/0x608
kernel_init_freeable+0x31c/0x384
kernel_init+0x10/0x118
ret_from_fork+0x10/0x18
Allocated by task 5:
save_stack+0x28/0xc8
__kasan_kmalloc.isra.8+0xbc/0xd8
kasan_kmalloc+0xc/0x18
__kmalloc+0x1a8/0x280
scsi_host_alloc+0x44/0x678
ata_scsi_add_hosts+0x74/0x268
ata_host_register+0x228/0x488
ahci_host_activate+0x1c4/0x2a8
ahci_init_one+0xd18/0x1298
local_pci_probe+0x74/0xf0
work_for_cpu_fn+0x2c/0x48
process_one_work+0x488/0xc08
worker_thread+0x330/0x5d0
kthread+0x1c8/0x1d0
Freed by task 5:
__kasan_slab_free+0x118/0x180
kasan_slab_free+0x10/0x18
slab_free_freelist_hook+0xa4/0x1a0
kfree+0xd4/0x3a0
scsi_host_dev_release+0x100/0x148
device_release+0x7c/0xe0
kobject_put+0xb0/0x180
ata_scsi_add_hosts+0x210/0x268
kthread+0x1c8/0x1d0
There is also refcount issue, as well:
WARNING: CPU: 1 PID: 1 at lib/refcount.c:28 refcount_warn_saturate+0xf8/0x170
The issue is that we make an erroneous extra call to scsi_host_put()
for that host:
So in ahci_init_one()->ata_host_alloc_pinfo()->ata_host_alloc(), we setup
a device release method - ata_devres_release() - which intends to release
the SCSI hosts:
static void ata_devres_release(struct device *gendev, void *res)
for (i = 0; i < host->n_ports; i++) {
struct ata_port *ap = host->ports[i];
if (!ap)
continue;
if (ap->scsi_host)
scsi_host_put(ap->scsi_host);
However in the ata_scsi_add_hosts() error path, we also call
scsi_host_put() for the SCSI hosts.
Fix by removing the the scsi_host_put() calls in ata_scsi_add_hosts() and
leave this to ata_devres_release().
Fixes: f31871951b38 ("libata: separate out ata_host_alloc() and ata_host_register()")
Signed-off-by: John Garry <john.garry@huawei.com>
commit 2d7271501720038381d45fb3dcbe4831228fc8cc upstream.
For passthrough requests, libata-scsi takes what the user passes in
as gospel. This can be problematic if the user fills in the CDB
incorrectly. One example of that is in request sizes. For read/write
commands, the CDB contains fields describing the transfer length of
the request. These should match with the SG_IO header fields, but
libata-scsi currently does no validation of that.
Check that the number of blocks in the CDB for passthrough requests
matches what was mapped into the request. If the CDB asks for more
data then the validated SG_IO header fields, error it.
Reported-by: Krishna Ram Prakash R <krp@gtux.in>
commit 058f58e235cbe03e923b30ea7c49995a46a8725f upstream.
syzkaller reported a crash in ata_bmdma_fill_sg() when writing to
/dev/sg1. The immediate cause was that the ATA command's scatterlist
was not DMA-mapped, which causes 'pi - 1' to underflow, resulting in a
write to 'qc->ap->bmdma_prd[0xffffffff]'.
Strangely though, the flag ATA_QCFLAG_DMAMAP was set in qc->flags. The
root cause is that when __ata_scsi_queuecmd() is preparing to relay a
SCSI command to an ATAPI device, it doesn't correctly validate the CDB
length before copying it into the 16-byte buffer 'cdb' in 'struct
ata_queued_cmd'. Namely, it validates the fixed CDB length expected
based on the SCSI opcode but not the actual CDB length, which can be
larger due to the use of the SG_NEXT_CMD_LEN ioctl. Since 'flags' is
the next member in ata_queued_cmd, a buffer overflow corrupts it.
Fix it by requiring that the actual CDB length be <= 16 (ATAPI_CDB_LEN).
[Really it seems the length should be required to be <= dev->cdb_len,
but the current behavior seems to have been intentionally introduced by
commit 607126c2a21c ("libata-scsi: be tolerant of 12-byte ATAPI commands
in 16-byte CDBs") to work around a userspace bug in mplayer. Probably
the workaround is no longer needed (mplayer was fixed in 2007), but
continuing to allow lengths to up 16 appears harmless for now.]
Here's a reproducer that works in QEMU when /dev/sg1 refers to the
CD-ROM drive that qemu-system-x86_64 creates by default:
#include <fcntl.h>
#include <sys/ioctl.h>
#include <unistd.h>
#define SG_NEXT_CMD_LEN 0x2283
int main()
char buf[53] = { [36] = 0x7e, [52] = 0x02 };
int fd = open("/dev/sg1", O_RDWR);
ioctl(fd, SG_NEXT_CMD_LEN, &(int){ 17 });
write(fd, buf, sizeof(buf));
The crash was:
BUG: unable to handle kernel paging request at ffff8cb97db37ffc
IP: ata_bmdma_fill_sg drivers/ata/libata-sff.c:2623 [inline]
IP: ata_bmdma_qc_prep+0xa4/0xc0 drivers/ata/libata-sff.c:2727
PGD fb6c067 P4D fb6c067 PUD 0
Oops: 0002 [#1] SMP
CPU: 1 PID: 150 Comm: syz_ata_bmdma_q Not tainted 4.15.0-next-20180202 #99
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.11.0-20171110_100015-anatol 04/01/2014
Call Trace:
ata_qc_issue+0x100/0x1d0 drivers/ata/libata-core.c:5421
ata_scsi_translate+0xc9/0x1a0 drivers/ata/libata-scsi.c:2024
__ata_scsi_queuecmd drivers/ata/libata-scsi.c:4326 [inline]
ata_scsi_queuecmd+0x8c/0x210 drivers/ata/libata-scsi.c:4375
scsi_dispatch_cmd+0xa2/0xe0 drivers/scsi/scsi_lib.c:1727
scsi_request_fn+0x24c/0x530 drivers/scsi/scsi_lib.c:1865
__blk_run_queue_uncond block/blk-core.c:412 [inline]
__blk_run_queue+0x3a/0x60 block/blk-core.c:432
blk_execute_rq_nowait+0x93/0xc0 block/blk-exec.c:78
sg_common_write.isra.7+0x272/0x5a0 drivers/scsi/sg.c:806
sg_write+0x1ef/0x340 drivers/scsi/sg.c:677
__vfs_write+0x31/0x160 fs/read_write.c:480
vfs_write+0xa7/0x160 fs/read_write.c:544
SYSC_write fs/read_write.c:589 [inline]
SyS_write+0x4d/0xc0 fs/read_write.c:581
do_syscall_64+0x5e/0x110 arch/x86/entry/common.c:287
entry_SYSCALL_64_after_hwframe+0x21/0x86
Fixes: 607126c2a21c ("libata-scsi: be tolerant of 12-byte ATAPI commands in 16-byte CDBs")
Reported-by: syzbot+1ff6f9fcc3c35f1c72a95e26528c8e7e3276e4da@syzkaller.appspotmail.com
Cc: <stable@vger.kernel.org> # v2.6.24+
commit 59a5e266c3f5c1567508888dd61a45b86daed0fa upstream.
My static checker complains that "devno" can be negative, meaning that
we read before the start of the loop. I've looked at the code, and I
think the warning is right. This come from /proc so it's root only or
it would be quite a quite a serious bug. The call tree looks like this:
proc_scsi_write() <- gets id and channel from simple_strtoul()
-> scsi_add_single_device() <- calls shost->transportt->user_scan()
-> ata_scsi_user_scan()
-> ata_find_dev()
commit 287e6611ab1eac76c2c5ebf6e345e04c80ca9c61 upstream.
As reported by Soohoon Lee, the HDIO_GET_32BIT ioctl does not
work correctly in compat mode with libata.
I have investigated the issue further and found multiple problems
that all appeared with the same commit that originally introduced
HDIO_GET_32BIT handling in libata back in linux-2.6.8 and presumably
also linux-2.4, as the code uses "copy_to_user(arg, &val, 1)" to copy
a 'long' variable containing either 0 or 1 to user space.
The problems with this are:
* On big-endian machines, this will always write a zero because it
stores the wrong byte into user space.
* In compat mode, the upper three bytes of the variable are updated
by the compat_hdio_ioctl() function, but they now contain
uninitialized stack data.
* The hdparm tool calling this ioctl uses a 'static long' variable
to store the result. This means at least the upper bytes are
initialized to zero, but calling another ioctl like HDIO_GET_MULTCOUNT
would fill them with data that remains stale when the low byte
is overwritten. Fortunately libata doesn't implement any of the
affected ioctl commands, so this would only happen when we query
both an IDE and an ATA device in the same command such as
"hdparm -N -c /dev/hda /dev/sda"
* The libata code for unknown reasons started using ATA_IOC_GET_IO32
and ATA_IOC_SET_IO32 as aliases for HDIO_GET_32BIT and HDIO_SET_32BIT,
while the ioctl commands that were added later use the normal
HDIO_* names. This is harmless but rather confusing.
This addresses all four issues by changing the code to use put_user()
on an 'unsigned long' variable in HDIO_GET_32BIT, like the IDE subsystem
does, and by clarifying the names of the ioctl commands.
Reported-by: Soohoon Lee <Soohoon.Lee@f5.com>
Tested-by: Soohoon Lee <Soohoon.Lee@f5.com>
Pull final round of SCSI updates from James Bottomley:
"Sorry for the delay in this patch which was mostly caused by getting
the merger of the mpt2/mpt3sas driver, which was seen as an essential
item of maintenance work to do before the drivers diverge too much.
Unfortunately, this caused a compile failure (detected by linux-next),
which then had to be fixed up and incubated.
In addition to the mpt2/3sas rework, there are updates from pm80xx,
lpfc, bnx2fc, hpsa, ipr, aacraid, megaraid_sas, storvsc and ufs plus
an assortment of changes including some year 2038 issues, a fix for a
remove before detach issue in some drivers and a couple of other minor
issues"
* tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: (141 commits)
mpt3sas: fix inline markers on non inline function declarations
sd: Clear PS bit before Mode Select.
ibmvscsi: set max_lun to 32
ibmvscsi: display default value for max_id, max_lun and max_channel.
mptfusion: don't allow negative bytes in kbuf_alloc_2_sgl()
scsi: pmcraid: replace struct timeval with ktime_get_real_seconds()
mvumi: 64bit value for seconds_since1970
be2iscsi: Fix bogus WARN_ON length check
scsi_scan: don't dump trace when scsi_prep_async_scan() is called twice
mpt3sas: Bump mpt3sas driver version to 09.102.00.00
mpt3sas: Single driver module which supports both SAS 2.0 & SAS 3.0 HBAs
mpt2sas, mpt3sas: Update the driver versions
mpt3sas: setpci reset kernel oops fix
mpt3sas: Added OEM Gen2 PnP ID branding names
mpt3sas: Refcount fw_events and fix unsafe list usage
mpt3sas: Refcount sas_device objects and fix unsafe list usage
mpt3sas: sysfs attribute to report Backup Rail Monitor Status
mpt3sas: Ported WarpDrive product SSS6200 support
mpt3sas: fix for driver fails EEH, recovery from injected pci bus error
mpt3sas: Manage MSI-X vectors according to HBA device type
This patch changes the !blk-mq path to the same defaults as the blk-mq
I/O path by always enabling block tagging, and always using host wide
tags. We've had blk-mq available for a few releases so bugs with
this mode should have been ironed out, and this ensures we get better
coverage of over tagging setup over different configs.
Acked-by: Jens Axboe <axboe@kernel.dk>
Reviewed-by: Hannes Reinecke <hare@suse.de>
Signed-off-by: James Bottomley <JBottomley@Odin.com>
Enable LBA in taskfile flags for ata_scsi_pass_thru()
Signed-off-by: Vinayak Kale <vinayak.kale@seagate.com>
This patch is needed to make NCQ commands with FPDMA protocol value
(eg READ/WRITE FPDMA) work over SCSI Generic (SG) interface.
When calling ->done before releasing resources we could run into a
race where the SCSI midlayer sends another command and races with
the resources beeing manipulated. For libata this can't currently
happen as synchronization happens at a higher level, but I'd still
like to fix it to future proof libata and to avoid copy & paste
into SCSI drivers where this pattern has led to reproducible crashes.
Remove an incorrect comment and untangle an if statement in
ata_scsi_qc_complete.
If the AHCI ports' HPCP or ESP bits are set, the port
should be considered external (e.g. eSATA) and is marked
as removable. Userspace tools like udisks then treat it
like an usb drive.
With this patch applied, when I plug a drive into the esata port,
KDE pops up a window asking what to do with the drives(s), just
like it does for any random USB stick.
Removability is indicated to the upper layers by way of the
SCSI RMB bit, as I haven't found another way to signal
userspace to treat a sata disk like any usb stick.
Signed-off-by: Manuel Lauss <manuel.lauss@gmail.com>
This reverts commit 42b966fbf35da9c87f08d98f9b8978edf9e717cf.
As implemented, ACS-4 sense reporting for ATA devices bypasses error
diagnosis and handling in libata degrading EH behavior significantly.
Revert the related changes for now.
Cc: Hannes Reinecke <hare@suse.de>
Cc: stable@vger.kernel.org #v4.1+
This reverts commit a1524f226a02aa6edebd90ae0752e97cfd78b159.
Some devices lose data on TRIM whether queued or not. This patch adds
a horkage to disable TRIM.
tj: Collapsed unnecessary if() nesting.
Signed-off-by: Arne Fitzenreiter <arne_f@ipfire.org>
If NCQ autosense or the sense data reporting feature is enabled
the LBA of the offending command should be stored in the sense
data 'information' field.
Signed-off-by: Hannes Reinecke <hare@suse.de>
Some newer devices support NCQ autosense (cf ACS-4), so we should
be using it to retrieve the sense code and speed up recovery.
Use the bit definitions for better readability.
ATA-8 defines bit 1 as 'ATA_SENSE', not 'ATA_IDX'.
sata_sil24 for some reason pukes when tags are allocated round-robin
which helps tag ordered controllers. To work around the issue,
72dd299d5039 ("libata: allow sata_sil24 to opt-out of tag ordered
submission") introduced ATA_FLAG_LOWTAG which tells libata tag
allocation to do lowest-first.
However, with the recent switch to blk-mq tag allocation, the liata
tag allocation code path is no longer used and the workaround is now
implemented in the block layer and selected by setting
scsi_host_template->tag_alloc_policy to BLK_TAG_ALLOC_FIFO. See
9269e23496dd ("libata: make sata_sil24 use fifo tag allocator").
This leaves ATA_FLAG_LOWTAG withoout any actual user. Remove it.
Cc: Shaohua Li <shli@fb.com>
Cc: Dan Williams <dan.j.williams@intel.com>
Pull block driver changes from Jens Axboe:
"This contains:
- The 4k/partition fixes for brd from Boaz/Matthew.
- A few xen front/back block fixes from David Vrabel and Roger Pau
Monne.
- Floppy changes from Takashi, cleaning the device file creation.
- Switching libata to use the new blk-mq tagging policy, removing
code (and a suboptimal implementation) from libata. This will
throw you a merge conflict, since a bug in the original libata
tagging code was fixed since this code was branched. Trivial.
From Shaohua.
- Conversion of loop to blk-mq, from Ming Lei.
- Cleanup of the io_schedule() handling in bsg from Peter Zijlstra.
He claims it improves on unreadable code, which will cost him a
beer.
- Maintainer update or NDB, now handled by Markus Pargmann.
- NVMe:
- Optimization from me that avoids a kmalloc/kfree per IO for
smaller (<= 8KB) IO. This cuts about 1% of high IOPS CPU
overhead.
- Removal of (now) dead RCU code, a relic from before NVMe was
converted to blk-mq"
* 'for-3.20/drivers' of git://git.kernel.dk/linux-block:
xen-blkback: default to X86_32 ABI on x86
xen-blkfront: fix accounting of reqs when migrating
xen-blkback,xen-blkfront: add myself as maintainer
block: Simplify bsg complete all
floppy: Avoid manual call of device_create_file()
NVMe: avoid kmalloc/kfree for smaller IO
MAINTAINERS: Update NBD maintainer
libata: move sas ata tag allocation to libata-scsi.c
libata: use blk taging
NVMe: within nvme_free_queues(), delete RCU sychro/deferred free
null_blk: suppress invalid partition info
brd: Request from fdisk 4k alignment
brd: Fix all partitions BUGs
axonram: Fix bug in direct_access
loop: add blk-mq.h include
block: loop: don't handle REQ_FUA explicitly
block: loop: introduce lo_discard() and lo_req_flush()
block: loop: say goodby to bio
block: loop: improve performance via blk-mq
git://git.kernel.org/pub/scm/linux/kernel/git/tj/libata into for-3.20
09c32aaa3683 ("ahci_xgene: Fix the dma state machine lockup for the
ATA_CMD_SMART PIO mode command.") missed 3.19 release. Fold it into
for-3.20.
Basically move the sas ata tag allocation to libata-scsi.c to make it clear
these staffs are just for sas.
Signed-off-by: Shaohua Li <shli@fb.com>
Signed-off-by: Jens Axboe <axboe@fb.com>
libata uses its own tag management which is duplication and the
implementation is poor. And if we switch to blk-mq, tag is build-in.
It's time to switch to generic taging.
The SAS driver has its own tag management, and looks we can't directly
map the host controler tag to SATA tag. So I just bypassed the SAS case.
I changed the code/variable name for the tag management of libata to
make it self contained. Only sas will use it. Later if libsas implements
its tag management, the tag management code in libata can be deleted
easily.
Cc: Jens Axboe <axboe@fb.com>
Acked-by: Tejun Heo <tj@kernel.org>
As defined, the DRAT (Deterministic Read After Trim) and RZAT (Return
Zero After Trim) flags in the ATA Command Set are unreliable in the
sense that they only define what happens if the device successfully
executed the DSM TRIM command. TRIM is only advisory, however, and the
device is free to silently ignore all or parts of the request.
In practice this renders the DRAT and RZAT flags completely useless and
because the results are unpredictable we decided to disable discard in
MD for 3.18 to avoid the risk of data corruption.
Hardware vendors in the real world obviously need better guarantees than
what the standards bodies provide. Unfortuntely those guarantees are
encoded in product requirements documents rather than somewhere we can
key off of them programatically. So we are compelled to disabling
discard_zeroes_data for all devices unless we explicitly have data to
support whitelisting them.
This patch whitelists SSDs from a few of the main vendors. None of the
whitelists are based on written guarantees. They are purely based on
empirical evidence collected from internal and external users that have
tested or qualified these drives in RAID deployments.
The whitelist is only meant as a starting point and is by no means
comprehensive:
- All intel SSD models except for 510
- Micron M5?0/M600
- Samsung SSDs
- Seagate SSDs
Changes the spelling typos of removeable to removable where
ata_id_removeable is defined in ata.h and called in libata-scsi.c
respectively.
Signed-off-by: Nicholas Krause <xerofoify@gmail.com>
Pull libata changes from Tejun Heo:
"The only interesting piece is the support for shingled drives. The
changes in libata layer are minimal. All it does is identifying the
new class of device and report upwards accordingly"
* 'for-3.19' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/libata:
libata: Remove FIXME comment in atapi_request_sense()
sata_rcar: Document deprecated "renesas,rcar-sata"
sata_rcar: Add clocks to sata_rcar bindings
ahci_sunxi: Make AHCI_HFLAG_NO_PMP flag configurable with a module option
libata-scsi: Update SATL for ZAC drives
libata: Implement ATA_DEV_ZAC
libsas: use ata_dev_classify()
drivers/scsi/scsi_debug.c
Agreed and tested resolution to a merge problem between a fix in scsi_debug
and a driver update
Signed-off-by: James Bottomley <JBottomley@Parallels.com>
Remove the FIXME comment in atapi_request_sense() asking whether
memset of sense buffer is necessary. The buffer may be partially or
fully filled by the device. We want it to be cleared.
tj: Updated description.
SPC-3 defines SERVICE ACTION IN(12) and SERVICE ACTION IN(16).
So rename SERVICE_ACTION_IN to SERVICE_ACTION_IN_16 to be
consistent with SPC and to allow for better distinction.
Tested-by: Robert Elliott <elliott@hp.com>
Reviewed-by: Robert Elliott <elliott@hp.com>
Drop the now unused reason argument from the ->change_queue_depth method.
Also add a return value to scsi_adjust_queue_depth, and rename it to
scsi_change_queue_depth now that it can be used as the default
->change_queue_depth implementation.
Reviewed-by: Mike Christie <michaelc@cs.wisc.edu>
Remove the tagged argument from scsi_adjust_queue_depth, and just let it
handle the queue depth. For most drivers those two are fairly separate,
given that most modern drivers don't care about the SCSI "tagged" status
of a command at all, and many old drivers allow queuing of multiple
untagged commands in the driver.
Instead we start out with the ->simple_tags flag set before calling
->slave_configure, which is how all drivers actually looking at
->simple_tags except for one worke anyway. The one other case looks
broken, but I've kept the behavior as-is for now.
Except for that we only change ->simple_tags from the ->change_queue_type,
and when rejecting a tag message in a single driver, so keeping this
churn out of scsi_adjust_queue_depth is a clear win.
Now that the usage of scsi_adjust_queue_depth is more obvious we can
also remove all the trivial instances in ->slave_alloc or ->slave_configure
that just set it to the cmd_per_lun default.
Reviewed-by: Martin K. Petersen <martin.petersen@oracle.com>
ZAC (zoned-access command) drives translate into ZBC (Zoned block
command) device type for SCSI. So implement the correct mappings
into libata-scsi and update the SCSI command set versions.
Acked-by: Christoph Hellwig <hch@lst.de>
Add new ATA device type for ZAC devices.
The SCSI standard defines 64-bit values for LUNs, and large arrays
employing large or hierarchical LUN numbers become more and more
common.
So update the linux SCSI stack to use 64-bit LUN numbers.
Reviewed-by: Christoph Hellwig <hch@infradead.org>
Reviewed-by: Ewan Milne <emilne@redhat.com>
The SCSI-to-ATA Translation standard says to use data words 25 and 26
unless they are spaces. For devices that use these words in the firmware
field, they are generally more useful anyway.
Signed-off-by: Keith Busch <keith.busch@intel.com>
Pull libata updates from Tejun Heo:
"Support for some new embedded controllers.
A couple late (<= a week) fixes have stable cc'd and one patch ("SATA:
MV: Add support for the optional PHYs") got committed yesterday
because otherwise the resulting kernel would fail boot on an embedded
board due to interdependent changes in its platform tree.
Other than that, nothing too noteworthy"
* 'for-3.14' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/libata:
SATA: MV: Add support for the optional PHYs
sata-highbank: Remove unnecessary ahci_platform.h include
libata: disable LPM for some WD SATA-I devices
ARM: mvebu: update the SATA compatible string for Armada 370/XP
ata: sata_mv: fix disk hotplug for Armada 370/XP SoCs
ata: sata_mv: introduce compatible string "marvell, armada-370-sata"
ata: pata_samsung_cf: Remove unused macros
ata: pata_samsung_cf: Use devm_ioremap_resource()
ata: pata_samsung_cf: Merge pata_samsung_cf.h into pata_samsung_cf.c
ata: pata_samsung_cf: Move plat/regs-ata.h to drivers/ata
drivers: ata: Mark the function as static in libahci.c
drivers: ata: Mark the function ahci_init_interrupts() as static in ahci.c
ahci: imx: fix the error handling in imx_ahci_probe()
ahci: imx: ahci_imx_softreset() can be static
ahci: imx: Add i.MX53 support
ahci: imx: Pull out the clock enable/disable calls
libata, dt: Document sata_rcar bindings
sata_rcar: Add R-Car Gen2 SATA PHY support
ahci: mcp89: enter AHCI mode under Apple BIOS emulation
ata: libata-eh: Remove unnecessary snprintf arithmetic
For some reason, some early WD drives spin up and down drives
erratically when the link is put into slumber mode which can reduce
the life expectancy of the device significantly. Unfortunately, we
don't have full list of devices and given the nature of the issue it'd
be better to err on the side of false positives than the other way
around. Let's disable LPM on all WD devices which match one of the
known problematic model prefixes and are SATA-I.
As horkage list doesn't support matching SATA capabilities, this is
implemented as two horkages - WD_BROKEN_LPM and NOLPM. The former is
set for the known prefixes and sets the latter if the matched device
is SATA-I.
Note that this isn't optimal as this disables all LPM operations and
partial link power state reportedly works fine on these; however, the
way LPM is implemented in libata makes it difficult to precisely map
libata LPM setting to specific link power state. Well, these devices
are already fairly outdated. Let's just disable whole LPM for now.
Reported-and-tested-by: Nikos Barkas <levelwol@gmail.com>
Reported-and-tested-by: Ioannis Barkas <risc4all@yahoo.com>
References: https://bugzilla.kernel.org/show_bug.cgi?id=57211
Pull libata fixes from Tejun Heo:
"There's one interseting commit - "libata, freezer: avoid block device
removal while system is frozen". It's an ugly hack working around a
deadlock condition between driver core resume and block layer device
removal paths through freezer which was made more reproducible by
writeback being converted to workqueue some releases ago. The bug has
nothing to do with libata but it's just an workaround which is easy to
backport. After discussion, Rafael and I seem to agree that we don't
really need kernel freezables - both kthread and workqueue. There are
few specific workqueues which constitute PM operations and require
freezing, which will be converted to use workqueue_set_max_active()
instead. All other kernel freezer uses are planned to be removed,
followed by the removal of kthread and workqueue freezer support,
hopefully.
Others are device-specific fixes. The most notable is the addition of
NO_NCQ_TRIM which is used to disable queued TRIM commands to Micro
M500 SSDs which otherwise suffers data corruption"
* 'for-3.13-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/libata:
libata, freezer: avoid block device removal while system is frozen
libata: implement ATA_HORKAGE_NO_NCQ_TRIM and apply it to Micro M500 SSDs
libata: disable a disk via libata.force params
ahci: bail out on ICH6 before using AHCI BAR
ahci: imx: Explicitly clear IMX6Q_GPR13_SATA_MPLL_CLK_EN
libata: add ATA_HORKAGE_BROKEN_FPDMA_AA quirk for Seagate Momentus SpinPoint M8
Freezable kthreads and workqueues are fundamentally problematic in
that they effectively introduce a big kernel lock widely used in the
kernel and have already been the culprit of several deadlock
scenarios. This is the latest occurrence.
During resume, libata rescans all the ports and revalidates all
pre-existing devices. If it determines that a device has gone
missing, the device is removed from the system which involves
invalidating block device and flushing bdi while holding driver core
layer locks. Unfortunately, this can race with the rest of device
resume. Because freezable kthreads and workqueues are thawed after
device resume is complete and block device removal depends on
freezable workqueues and kthreads (e.g. bdi_wq, jbd2) to make
progress, this can lead to deadlock - block device removal can't
proceed because kthreads are frozen and kthreads can't be thawed
because device resume is blocked behind block device removal.
839a8e8660b6 ("writeback: replace custom worker pool implementation
with unbound workqueue") made this particular deadlock scenario more
visible but the underlying problem has always been there - the
original forker task and jbd2 are freezable too. In fact, this is
highly likely just one of many possible deadlock scenarios given that
freezer behaves as a big kernel lock and we don't have any debug
mechanism around it.
I believe the right thing to do is getting rid of freezable kthreads
and workqueues. This is something fundamentally broken. For now,
implement a funny workaround in libata - just avoid doing block device
hot[un]plug while the system is frozen. Kernel engineering at its
finest. :(
v2: Add EXPORT_SYMBOL_GPL(pm_freezing) for cases where libata is built
as a module.
v3: Comment updated and polling interval changed to 10ms as suggested
by Rafael.
v4: Add #ifdef CONFIG_FREEZER around the hack as pm_freezing is not
defined when FREEZER is not configured thus breaking build.
Reported by kbuild test robot.
Reported-by: Tomaž Šolc <tomaz.solc@tablix.org>
Reviewed-by: "Rafael J. Wysocki" <rjw@rjwysocki.net>
Link: https://bugzilla.kernel.org/show_bug.cgi?id=62801
Link: http://lkml.kernel.org/r/20131213174932.GA27070@htj.dyndns.org
Cc: Len Brown <len.brown@intel.com>
Cc: kbuild test robot <fengguang.wu@intel.com>
Some host adapters do not pass commands through to the target disk
directly. Instead they provide an emulated target which may or may not
accurately report its capabilities. In some cases the physical device
characteristics are reported even when the host adapter is processing
commands on the device's behalf. This can lead to adapter firmware hangs
or excessive I/O errors.
This patch disables WRITE SAME for devices connected to host adapters
that provide an emulated target. Driver writers can disable WRITE SAME
by setting the no_write_same flag in the host adapter template.
[jejb: fix up rejections due to eh_deadline patch]
Cc: stable@kernel.org
Previously, we wanted SCSI devices corrsponding to ATA devices to
be runtime resumed when the power resource for those ATA device was
turned on by some other device, so we added the SCSI device to the
dependent device list of the ATA device's ACPI node. However, this
code has no effect after commit 41863fc (ACPI / power: Drop automaitc
resume of power resource dependent devices) and the mechanism it was
supposed to implement is regarded as a bad idea now, so drop it.
[rjw: Changelog]
Signed-off-by: Aaron Lu <aaron.lu@intel.com>
"Two interesting changes.
- libata acpi handling has been restructured so that the association
between ata devices and ACPI handles are less convoluted. This
change shouldn't change visible behavior.
- Queued TRIM support, which enables sending TRIM to the device
without draining in-flight RW commands, is added. Currently only
enabled for ahci (and likely to stay that way for the foreseeable
future).
Other changes are driver-specific updates / fixes"
* 'for-3.12' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/libata:
libata: bugfix: Remove __le32 in ata_tf_to_fis()
libata: acpi: Remove ata_dev_acpi_handle stub in libata.h
libata: Add support for queued DSM TRIM
libata: Add support for SEND/RECEIVE FPDMA QUEUED
libata: Add H2D FIS "auxiliary" port flag
libata: Populate host-to-device FIS "auxiliary" field
ata: acpi: rework the ata acpi bind support
sata, highbank: send extra clock cycles in SGPIO patterns
sata, highbank: set tx_atten override bits
devicetree: create a separate binding description for sata_highbank
drivers/ata/sata_rcar.c: simplify use of devm_ioremap_resource
sata highbank: enable 64-bit DMA mask when using LPAE
ata: pata_samsung_cf: add missing __iomem annotation
ata: pata_arasan: Staticize local symbols
sata_mv: Remove unneeded CONFIG_HAVE_CLK ifdefs
ata: use dev_get_platdata()
sata_mv: Remove unneeded forward declaration
libata: acpi: remove dead code for ata_acpi_(un)bind
libata: move 'struct ata_taskfile' and friends from ata.h to libata.h
Some new SSDs support the queued version of the DSM TRIM command.
Let the driver use the new command if supported.
Signed-off-by: Marc Carino <marc.ceeeee@gmail.com>
Binding ACPI handle to SCSI device has several drawbacks, namely:
1 During ATA device initialization time, ACPI handle will be needed
while SCSI devices are not created yet. So each time ACPI handle is
needed, instead of retrieving the handle by ACPI_HANDLE macro,
a namespace scan is performed to find the handle for the corresponding
ATA device. This is inefficient, and also expose a restriction on
calling path not holding any lock.
2 The binding to SCSI device tree makes code complex, while at the same
time doesn't bring us any benefit. All ACPI handlings are still done
in ATA module, not in SCSI.
Rework the ATA ACPI binding code to bind ACPI handle to ATA transport
devices(ATA port and ATA device). The binding needs to be done only once,
since the ATA transport devices do not go away with hotplug. And due to
this, the flush_work call in hotplug handler for ATA bay is no longer
needed.
Tested on an Intel test platform for binding and runtime power off for
ODD(ZPODD) and hard disk; on an ASUS S400C for binding and normal boot
and S3, where its SATA port node has _SDD and _GTF control methods when
configured as an AHCI controller and its PATA device node has _GTF
control method when configured as an IDE controller. SATA PMP binding
and ATA hotplug is not tested.
Tested-by: Dirk Griesbach <spamthis@freenet.de>
The usage of strict_strtol() is not preferred, because
strict_strtol() is obsolete. Thus, kstrtol() should be
used.
Signed-off-by: Jingoo Han <jg1.han@samsung.com>
libata/for-3.10-fixes never got submitted during v3.10 cycle. Merge
it into for-3.11 so that it can be routed together with other changes
scheduled for v3.11.
Three trivial conflicts in drivers/ata/sata_rcar.c. All are caused by
1b20f6a9ad ("sata_rcar: add 'base' local variable to some functions")
conflicting with logic updates in for-3.10-fixes. The offending
commit simply adds local variable @base on functions which
dereferences sata_rcar_priv->base multiple times. The resolutions are
trivial - applying s/priv->base/base/ in the conflicting logic
updates.
- Remove duplicate Medium Error Entry.
- Fix translations to match SAT2 translation table.
- Remove warning messages when translation is not found when decoding
error or status register.
- Goes through status register decoding when only ABRT bit is set in
error register.
Tested: When a disk fails, it sets
Status = 0x71 [DRDY DF ERR] , Error = 0x4 [ABRT]
This patch will make the sense key HARDWARE_ERROR instead.
When there is a simple command syntax error:
Status = 0x51 [DRDY ERR] , Error = 0x4 [ABRT]
The sense key remains ABORTED_COMMAND.
tj: Some updates to the description and comments.
Signed-off-by: Gwendal Grignou <gwendal@google.com>
Jeff moved on to a greener pasture.
s/Maintained by: Jeff Garzik/Maintained by: Tejun Heo/g
Cc: Jeff Garzik <jgarzik@pobox.com>
