path: root/drivers/ata/libata-scsi.c
2014-01-21Merge branch 'for-3.14' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/libata Pull libata updates from Tejun Heo: "Support for some new embedded controllers. A couple late (<= a week) fixes have stable cc'd and one patch ("SATA: MV: Add support for the optional PHYs") got committed yesterday because otherwise the resulting kernel would fail boot on an embedded board due to interdependent changes in its platform tree. Other than that, nothing too noteworthy" * 'for-3.14' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/libata: SATA: MV: Add support for the optional PHYs sata-highbank: Remove unnecessary ahci_platform.h include libata: disable LPM for some WD SATA-I devices ARM: mvebu: update the SATA compatible string for Armada 370/XP ata: sata_mv: fix disk hotplug for Armada 370/XP SoCs ata: sata_mv: introduce compatible string "marvell, armada-370-sata" ata: pata_samsung_cf: Remove unused macros ata: pata_samsung_cf: Use devm_ioremap_resource() ata: pata_samsung_cf: Merge pata_samsung_cf.h into pata_samsung_cf.c ata: pata_samsung_cf: Move plat/regs-ata.h to drivers/ata drivers: ata: Mark the function as static in libahci.c drivers: ata: Mark the function ahci_init_interrupts() as static in ahci.c ahci: imx: fix the error handling in imx_ahci_probe() ahci: imx: ahci_imx_softreset() can be static ahci: imx: Add i.MX53 support ahci: imx: Pull out the clock enable/disable calls libata, dt: Document sata_rcar bindings sata_rcar: Add R-Car Gen2 SATA PHY support ahci: mcp89: enter AHCI mode under Apple BIOS emulation ata: libata-eh: Remove unnecessary snprintf arithmetic
2014-01-16libata: disable LPM for some WD SATA-I devicesTejun Heo
For some reason, some early WD drives spin up and down drives erratically when the link is put into slumber mode which can reduce the life expectancy of the device significantly. Unfortunately, we don't have full list of devices and given the nature of the issue it'd be better to err on the side of false positives than the other way around. Let's disable LPM on all WD devices which match one of the known problematic model prefixes and are SATA-I. As horkage list doesn't support matching SATA capabilities, this is implemented as two horkages - WD_BROKEN_LPM and NOLPM. The former is set for the known prefixes and sets the latter if the matched device is SATA-I. Note that this isn't optimal as this disables all LPM operations and partial link power state reportedly works fine on these; however, the way LPM is implemented in libata makes it difficult to precisely map libata LPM setting to specific link power state. Well, these devices are already fairly outdated. Let's just disable whole LPM for now. Signed-off-by: Tejun Heo <tj@kernel.org> Reported-and-tested-by: Nikos Barkas <levelwol@gmail.com> Reported-and-tested-by: Ioannis Barkas <risc4all@yahoo.com> References: https://bugzilla.kernel.org/show_bug.cgi?id=57211 Cc: stable@vger.kernel.org
2013-12-24Merge branch 'for-3.13-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/libata Pull libata fixes from Tejun Heo: "There's one interseting commit - "libata, freezer: avoid block device removal while system is frozen". It's an ugly hack working around a deadlock condition between driver core resume and block layer device removal paths through freezer which was made more reproducible by writeback being converted to workqueue some releases ago. The bug has nothing to do with libata but it's just an workaround which is easy to backport. After discussion, Rafael and I seem to agree that we don't really need kernel freezables - both kthread and workqueue. There are few specific workqueues which constitute PM operations and require freezing, which will be converted to use workqueue_set_max_active() instead. All other kernel freezer uses are planned to be removed, followed by the removal of kthread and workqueue freezer support, hopefully. Others are device-specific fixes. The most notable is the addition of NO_NCQ_TRIM which is used to disable queued TRIM commands to Micro M500 SSDs which otherwise suffers data corruption" * 'for-3.13-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/libata: libata, freezer: avoid block device removal while system is frozen libata: implement ATA_HORKAGE_NO_NCQ_TRIM and apply it to Micro M500 SSDs libata: disable a disk via libata.force params ahci: bail out on ICH6 before using AHCI BAR ahci: imx: Explicitly clear IMX6Q_GPR13_SATA_MPLL_CLK_EN libata: add ATA_HORKAGE_BROKEN_FPDMA_AA quirk for Seagate Momentus SpinPoint M8
2013-12-19libata, freezer: avoid block device removal while system is frozenTejun Heo
Freezable kthreads and workqueues are fundamentally problematic in that they effectively introduce a big kernel lock widely used in the kernel and have already been the culprit of several deadlock scenarios. This is the latest occurrence. During resume, libata rescans all the ports and revalidates all pre-existing devices. If it determines that a device has gone missing, the device is removed from the system which involves invalidating block device and flushing bdi while holding driver core layer locks. Unfortunately, this can race with the rest of device resume. Because freezable kthreads and workqueues are thawed after device resume is complete and block device removal depends on freezable workqueues and kthreads (e.g. bdi_wq, jbd2) to make progress, this can lead to deadlock - block device removal can't proceed because kthreads are frozen and kthreads can't be thawed because device resume is blocked behind block device removal. 839a8e8660b6 ("writeback: replace custom worker pool implementation with unbound workqueue") made this particular deadlock scenario more visible but the underlying problem has always been there - the original forker task and jbd2 are freezable too. In fact, this is highly likely just one of many possible deadlock scenarios given that freezer behaves as a big kernel lock and we don't have any debug mechanism around it. I believe the right thing to do is getting rid of freezable kthreads and workqueues. This is something fundamentally broken. For now, implement a funny workaround in libata - just avoid doing block device hot[un]plug while the system is frozen. Kernel engineering at its finest. :( v2: Add EXPORT_SYMBOL_GPL(pm_freezing) for cases where libata is built as a module. v3: Comment updated and polling interval changed to 10ms as suggested by Rafael. v4: Add #ifdef CONFIG_FREEZER around the hack as pm_freezing is not defined when FREEZER is not configured thus breaking build. Reported by kbuild test robot. Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: Tomaž Šolc <tomaz.solc@tablix.org> Reviewed-by: "Rafael J. Wysocki" <rjw@rjwysocki.net> Link: https://bugzilla.kernel.org/show_bug.cgi?id=62801 Link: http://lkml.kernel.org/r/20131213174932.GA27070@htj.dyndns.org Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Len Brown <len.brown@intel.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: stable@vger.kernel.org Cc: kbuild test robot <fengguang.wu@intel.com>
2013-11-29[SCSI] Disable WRITE SAME for RAID and virtual host adapter driversMartin K. Petersen
Some host adapters do not pass commands through to the target disk directly. Instead they provide an emulated target which may or may not accurately report its capabilities. In some cases the physical device characteristics are reported even when the host adapter is processing commands on the device's behalf. This can lead to adapter firmware hangs or excessive I/O errors. This patch disables WRITE SAME for devices connected to host adapters that provide an emulated target. Driver writers can disable WRITE SAME by setting the no_write_same flag in the host adapter template. [jejb: fix up rejections due to eh_deadline patch] Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Cc: stable@kernel.org Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2013-10-17ATA / ACPI: remove power dependent device handlingAaron Lu
Previously, we wanted SCSI devices corrsponding to ATA devices to be runtime resumed when the power resource for those ATA device was turned on by some other device, so we added the SCSI device to the dependent device list of the ATA device's ACPI node. However, this code has no effect after commit 41863fc (ACPI / power: Drop automaitc resume of power resource dependent devices) and the mechanism it was supposed to implement is regarded as a bad idea now, so drop it. [rjw: Changelog] Signed-off-by: Aaron Lu <aaron.lu@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-09-03Merge branch 'for-3.12' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/libata Pull libata changes from Tejun Heo: "Two interesting changes. - libata acpi handling has been restructured so that the association between ata devices and ACPI handles are less convoluted. This change shouldn't change visible behavior. - Queued TRIM support, which enables sending TRIM to the device without draining in-flight RW commands, is added. Currently only enabled for ahci (and likely to stay that way for the foreseeable future). Other changes are driver-specific updates / fixes" * 'for-3.12' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/libata: libata: bugfix: Remove __le32 in ata_tf_to_fis() libata: acpi: Remove ata_dev_acpi_handle stub in libata.h libata: Add support for queued DSM TRIM libata: Add support for SEND/RECEIVE FPDMA QUEUED libata: Add H2D FIS "auxiliary" port flag libata: Populate host-to-device FIS "auxiliary" field ata: acpi: rework the ata acpi bind support sata, highbank: send extra clock cycles in SGPIO patterns sata, highbank: set tx_atten override bits devicetree: create a separate binding description for sata_highbank drivers/ata/sata_rcar.c: simplify use of devm_ioremap_resource sata highbank: enable 64-bit DMA mask when using LPAE ata: pata_samsung_cf: add missing __iomem annotation ata: pata_arasan: Staticize local symbols sata_mv: Remove unneeded CONFIG_HAVE_CLK ifdefs ata: use dev_get_platdata() sata_mv: Remove unneeded forward declaration libata: acpi: remove dead code for ata_acpi_(un)bind libata: move 'struct ata_taskfile' and friends from ata.h to libata.h
2013-08-25libata: Add support for queued DSM TRIMMarc Carino
Some new SSDs support the queued version of the DSM TRIM command. Let the driver use the new command if supported. Signed-off-by: Marc Carino <marc.ceeeee@gmail.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2013-08-23ata: acpi: rework the ata acpi bind supportAaron Lu
Binding ACPI handle to SCSI device has several drawbacks, namely: 1 During ATA device initialization time, ACPI handle will be needed while SCSI devices are not created yet. So each time ACPI handle is needed, instead of retrieving the handle by ACPI_HANDLE macro, a namespace scan is performed to find the handle for the corresponding ATA device. This is inefficient, and also expose a restriction on calling path not holding any lock. 2 The binding to SCSI device tree makes code complex, while at the same time doesn't bring us any benefit. All ACPI handlings are still done in ATA module, not in SCSI. Rework the ATA ACPI binding code to bind ACPI handle to ATA transport devices(ATA port and ATA device). The binding needs to be done only once, since the ATA transport devices do not go away with hotplug. And due to this, the flush_work call in hotplug handler for ATA bay is no longer needed. Tested on an Intel test platform for binding and runtime power off for ODD(ZPODD) and hard disk; on an ASUS S400C for binding and normal boot and S3, where its SATA port node has _SDD and _GTF control methods when configured as an AHCI controller and its PATA device node has _GTF control method when configured as an IDE controller. SATA PMP binding and ATA hotplug is not tested. Signed-off-by: Aaron Lu <aaron.lu@intel.com> Tested-by: Dirk Griesbach <spamthis@freenet.de> Signed-off-by: Tejun Heo <tj@kernel.org>
2013-07-22libata: replace strict_strtol() with kstrtol()Jingoo Han
The usage of strict_strtol() is not preferred, because strict_strtol() is obsolete. Thus, kstrtol() should be used. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2013-07-02Merge branch 'libata/for-3.10-fixes' into libata/for-3.11Tejun Heo
libata/for-3.10-fixes never got submitted during v3.10 cycle. Merge it into for-3.11 so that it can be routed together with other changes scheduled for v3.11. Three trivial conflicts in drivers/ata/sata_rcar.c. All are caused by 1b20f6a9ad ("sata_rcar: add 'base' local variable to some functions") conflicting with logic updates in for-3.10-fixes. The offending commit simply adds local variable @base on functions which dereferences sata_rcar_priv->base multiple times. The resolutions are trivial - applying s/priv->base/base/ in the conflicting logic updates. Signed-off-by: Tejun Heo <tj@kernel.org>
2013-06-18libata: cleanup SAT error translationGwendal Grignou
- Remove duplicate Medium Error Entry. - Fix translations to match SAT2 translation table. - Remove warning messages when translation is not found when decoding error or status register. - Goes through status register decoding when only ABRT bit is set in error register. Tested: When a disk fails, it sets Status = 0x71 [DRDY DF ERR] , Error = 0x4 [ABRT] This patch will make the sense key HARDWARE_ERROR instead. When there is a simple command syntax error: Status = 0x51 [DRDY ERR] , Error = 0x4 [ABRT] The sense key remains ABORTED_COMMAND. tj: Some updates to the description and comments. Signed-off-by: Gwendal Grignou <gwendal@google.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2013-05-14libata: update "Maintained by:" tagsTejun Heo
Jeff moved on to a greener pasture. s/Maintained by: Jeff Garzik/Maintained by: Tejun Heo/g Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Jeff Garzik <jgarzik@pobox.com>
2013-04-11[libata] SCSI: really use SATL version in VPDBaruch Even
As per c78968bb by Jeff Garzik ([libata] SCSI: simulator version, not device version, belongs in VPD) We need to provide the SATL driver version and not the disk firmware version but the code overwrites the driver version with the disk version. Signed-off-by: Baruch Even <baruch@ev-en.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2013-04-03libata-acpi: remove redundent code for power resource handlingAaron Lu
With commit: bc9b6407bd6df3ab7189e5622816bbc11ae9d2d8 ACPI / PM: Rework the handling of devices depending on power resources The ACPI core now takes care of the power resources an acpi device depends on in that when the power resources are turned on, any devices that are bound to or in the dependent list of this acpi device will be runtime resumed. So there is no need for ata acpi code to duplicate this effort, and thus, the ata_acpi_(un)register_power_resource functions are no longer needed. The above commit thinks the scsi device is not bound to the acpi device, so needs to be added to the dependent list. But actually, it is. So there is no need to add it to the dependent list, or it will be runtime resumed twice(though this wouldn't cause any problem). This patch fixes it, and as a result, the ata_acpi_(un)register_power_resource and ata_acpi_(un)bind functions are removed. Signed-off-by: Aaron Lu <aaron.lu@intel.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2013-04-03[libata] Fix HDIO_DRIVE_* ioctl() Linux 3.9 regressionKrzysztof Mazur
On Mon, Mar 25, 2013 at 06:26:50PM +0100, Ronald wrote: > In reply to [1]: I have the same issue. Git bisect took 50+ rebuilds xD > > Smartd does not work anymore since 84a9a8cd9 ([libata] Set proper SK > when CK_COND is set.). > [1] http://www.spinics.net/lists/linux-ide/msg45268.html It seems that the SAM_STAT_CHECK_CONDITION is not cleared causing -EIO, because that patch modified sensebuf and the check for clearing SAM_STAT_CHECK_CONDITION is no longer valid. Fix that. Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2013-02-20[libata] Set proper SK when CK_COND is set.Gwendal Grignou
When the user application sends a ATA_12 or ATA_16 PASSTHROUGH scsi command, put the task file register in the sense data with the proper Sense Key. Instead of NO SENSE, set RECOVERED, as specified in [SAT2]12.2.5 Table 92. Tested: Using udev ata_id to generate a passthrough command, IDENTIFY: before: sd 0:0:0:0: [sda] CDB: ATA command pass through(12)/Blank: \ a1 08 2e 00 01 00 00 00 00 ec 00 00 sd 0:0:0:0: [sda] Sense Key : No Sense [current] [descriptor] Descriptor sense data with sense descriptors (in hex): 72 00 00 00 00 00 00 0e 09 0c 00 00 00 00 00 3f 00 18 00 a6 e0 50 after sd 0:0:0:0: [sda] CDB: ATA command pass through(12)/Blank: \ a1 08 2e 00 01 00 00 00 00 ec 00 00 sd 0:0:0:0: [sda] Sense Key : Recovered Error [current] [descriptor] Descriptor sense data with sense descriptors (in hex): 72 01 00 1d 00 00 00 0e 09 0c 00 00 00 01 00 00 00 00 00 00 00 50 Signed-off-by: Gwendal Grignou <gwendal@google.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2013-01-21libata: identify and init ZPODD devicesAaron Lu
The ODD can be enabled for ZPODD if the following three conditions are satisfied: 1 The ODD supports device attention; 2 The platform can runtime power off the ODD through ACPI; 3 The ODD is either slot type or drawer type. For such ODDs, zpodd_init is called and a new structure is allocated for it to store ZPODD related stuffs. And the zpodd_dev_enabled function is used to test if ZPODD is currently enabled for this ODD. A new config CONFIG_SATA_ZPODD is added to selectively build ZPODD code. Signed-off-by: Aaron Lu <aaron.lu@intel.com> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2012-12-14[libata] fix Null pointer dereference on disk errorXiaotian Feng
Following oops were observed when disk error happened: [ 4272.896937] sd 0:0:0:0: [sda] Unhandled error code [ 4272.896939] sd 0:0:0:0: [sda] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK [ 4272.896942] sd 0:0:0:0: [sda] CDB: Read(10): 28 00 00 5a de a7 00 00 08 00 [ 4272.896951] end_request: I/O error, dev sda, sector 5955239 [ 4291.574947] BUG: unable to handle kernel NULL pointer dereference at (null) [ 4291.658305] IP: [] ahci_activity_show+0x1/0x40 [ 4291.730090] PGD 76dbbc067 PUD 6c4fba067 PMD 0 [ 4291.783408] Oops: 0000 [#1] SMP [ 4291.822100] last sysfs file: /sys/devices/pci0000:00/0000:00:1f.2/host0/target0:0:0/0:0:0:0/sw_activity [ 4291.934235] CPU 9 [ 4291.958301] Pid: 27942, comm: hwinfo ...... ata_scsi_find_dev could return NULL, so ata_scsi_activity_{show,store} should check if atadev is NULL. Signed-off-by: Xiaotian Feng <dannyfeng@tencent.com> Cc: James Bottomley <JBottomley@Parallels.com> Cc: stable@kernel.org Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2012-11-13[SCSI] sd: Implement support for WRITE SAMEMartin K. Petersen
Implement support for WRITE SAME(10) and WRITE SAME(16) in the SCSI disk driver. - We set the default maximum to 0xFFFF because there are several devices out there that only support two-byte block counts even with WRITE SAME(16). We only enable transfers bigger than 0xFFFF if the device explicitly reports MAXIMUM WRITE SAME LENGTH in the BLOCK LIMITS VPD. - max_write_same_blocks can be overriden per-device basis in sysfs. - The UNMAP discovery heuristics remain unchanged but the discard limits are tweaked to match the "real" WRITE SAME commands. - In the error handling logic we now distinguish between WRITE SAME with and without UNMAP set. The discovery process heuristics are: - If the device reports a SCSI level of SPC-3 or greater we'll issue READ SUPPORTED OPERATION CODES to find out whether WRITE SAME(16) is supported. If that's the case we will use it. - If the device supports the block limits VPD and reports a MAXIMUM WRITE SAME LENGTH bigger than 0xFFFF we will use WRITE SAME(16). - Otherwise we will use WRITE SAME(10) unless the target LBA is beyond 0xFFFFFFFF or the block count exceeds 0xFFFF. - no_write_same is set for ATA, FireWire and USB. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Reviewed-by: Mike Snitzer <snitzer@redhat.com> Reviewed-by: Jeff Garzik <jgarzik@redhat.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-11-13[SCSI] Add a report opcode helperMartin K. Petersen
The REPORT SUPPORTED OPERATION CODES command can be used to query whether a given opcode is supported by a device. Add a helper function that allows us to look up commands. We only issue RSOC if the device reports compliance with SPC-3 or later. But to err on the side of caution we disable the command for ATA, FireWire and USB. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Acked-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-08-17[libata] scsi: implement MODE SELECT commandPaolo Bonzini
The cache_type file in sysfs lets users configure the disk cache in write-through or write-back modes. However, ata disks do not support writing to the file because they do not implement the MODE SELECT command. This patch adds a translation from MODE SELECT (for the caching page only) to the ATA SET FEATURES command. The set of changeable parameters answered by MODE SENSE is also adjusted accordingly. Signed-off-by: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2012-08-17[libata] scsi: support MODE SENSE request for changeable and default parametersPaolo Bonzini
Since the next patch will introduce support for MODE SELECT, it makes sense to start advertising which bits are actually changeable. For now, the answer is none. Default parameters can also be reported, they are simply the same as the current parameters. Signed-off-by: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2012-08-17[libata] scsi: Remove unlikely() from FUA checkJeff Garzik
Some other unlikely() should probably be removed as well. A fresh look reveals an over-enthusiasm for unlikely() in libata-scsi.c. Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2012-06-29libata-acpi: add ata port runtime D3Cold supportLin Ming
ATA port may support runtime D3Cold state, for example, Zero-power ODD case. This patch adds wakeup notifier and enable/disable run_wake during supend/resume. Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2012-04-23[SCSI] libsas, libata: fix start of life for a sas ata_portDan Williams
This changes the ordering of initialization and probing events from: 1/ allocate rphy in PORTE_BYTES_DMAED, DISCE_REVALIDATE_DOMAIN 2/ allocate ata_port and schedule port probe in DISCE_PROBE ...to: 1/ allocate ata_port in PORTE_BYTES_DMAED, DISCE_REVALIDATE_DOMAIN 2/ allocate rphy in PORTE_BYTES_DMAED, DISCE_REVALIDATE_DOMAIN 3/ schedule port probe in DISCE_PROBE This ordering prevents PHYE_SIGNAL_LOSS_EVENTS from sneaking in to destrory ata devices before they have been fully initialized: BUG: unable to handle kernel paging request at 0000000000003b10 IP: [<ffffffffa0053d7e>] sas_ata_end_eh+0x12/0x5e [libsas] ... [<ffffffffa004d1af>] sas_unregister_common_dev+0x78/0xc9 [libsas] [<ffffffffa004d4d4>] sas_unregister_dev+0x4f/0xad [libsas] [<ffffffffa004d5b1>] sas_unregister_domain_devices+0x7f/0xbf [libsas] [<ffffffffa004c487>] sas_deform_port+0x61/0x1b8 [libsas] [<ffffffffa004bed0>] sas_phye_loss_of_signal+0x29/0x2b [libsas] ...and kills the awkward "sata domain_device briefly existing in the domain without an ata_port" state. Reported-by: Michal Kosciowski <michal.kosciowski@intel.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com> Acked-by: Jeff Garzik <jgarzik@redhat.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-04-22[SCSI] libata: Pass correct DMA device to scsi hostLin Ming
Use scsi_add_host_with_dma in ata_scsi_add_hosts to pass in the correct DMA device(ATA host). Bug report: http://marc.info/?l=linux-ide&m=133177818318187&w=2 Reported-and-tested-by: Jörg Sommer <joerg@alea.gnuu.de> Acked-by: Jeff Garzik <jgarzik@redhat.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-04-12libata: make ata_print_id atomicDan Williams
This variable is incremented from multiple contexts (module_init via libata-lldds and the libsas discovery thread). Make it atomic to head off any chance of libsas and libata creating duplicate ids. Acked-by: Jacek Danecki <jacek.danecki@intel.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2012-02-29[SCSI] libsas: async ata scanningDan Williams
libsas ata error handling is already async but this does not help the scan case. Move initial link recovery out from under host->scan_mutex, and delay synchronization with eh until after all port probe/recovery work has been queued. Device ordering is maintained with scan order by still calling sas_rphy_add() in order of domain discovery. Since we now scan the domain list when invoking libata-eh we need to be careful to check for fully initialized ata ports. Acked-by: Jack Wang <jack_wang@usish.com> Acked-by: Jeff Garzik <jgarzik@redhat.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-01-08ata: add ata port runtime PM callbacksLin Ming
Add ata port runtime suspend/resume/idle callbacks. Set ->eh_noresume to skip the runtime PM calls on scsi host in the error handler to avoid dead lock. Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2012-01-08ata: make ata port as parent device of scsi hostLin Ming
Currently, the device tree of ata port and scsi host looks as below, /sys/devices/pci0000:00/0000:00:1f.2 (ahci controller) |-- ata1 (ata port) |-- host0 (scsi host) |-- target0:0:0 (scsi target) |-- 0:0:0:0 (disk) This patch makes ata port as parent device of scsi host, then it becomes /sys/devices/pci0000:00/0000:00:1f.2 (ahci controller) |-- ata1 (ata port) |-- host0 (scsi host) |-- target0:0:0 (scsi target) |-- 0:0:0:0 (disk) With this change, the ata port runtime PM is easier. For example, the ata port runtime suspend will happen as, disk suspend --> scsi target suspend --> scsi host suspend --> ata port suspend. Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2011-11-09[libata] libata-scsi.c: Add function parameter documentationMarcos Paulo de Souza
Add the documentation of parameters of ata_change_queue_depth to silence the warning of make xmldocs Signed-off-by: Marcos paulo de Souza <marcos.mage@gmail.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2011-10-31ide/ata: Add export.h for EXPORT_SYMBOL/THIS_MODULE where neededPaul Gortmaker
They were getting this implicitly by an include of module.h from device.h -- but we are going to clean that up and break that include chain, so include export.h explicitly now. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-02[SCSI] libsas,libata: fix ->change_queue_{depth|type} for sata devicesDan Williams
Pass queue_depth change requests to libata, and prevent queue_type changes for ATA devices. Otherwise: 1/ we do not honor the libata specific restrictions on the queue depth 2/ libsas drivers that do not set sdev->tagged_supported are unable to change the queue_depth of ata devices via sysfs Signed-off-by: Dan Williams <dan.j.williams@intel.com> Acked-by: Jeff Garzik <jgarzik@redhat.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2011-07-23ata: Convert ata_<foo>_printk(KERN_<LEVEL> to ata_<foo>_<level>Joe Perches
Saves text by removing nearly duplicated text format strings by creating ata_<foo>_printk functions and printf extension %pV. ata defconfig size shrinks ~5% (~8KB), allyesconfig ~2.5% (~13KB) Format string duplication comes from: #define ata_link_printk(link, lv, fmt, args...) do { \ if (sata_pmp_attached((link)->ap) || (link)->ap->slave_link) \ printk("%sata%u.%02u: "fmt, lv, (link)->ap->print_id, \ (link)->pmp , ##args); \ else \ printk("%sata%u: "fmt, lv, (link)->ap->print_id , ##args); \ } while(0) Coalesce long formats. $ size drivers/ata/built-in.* text data bss dec hex filename 544969 73893 116584 735446 b38d6 drivers/ata/built-in.allyesconfig.ata.o 558429 73893 117864 750186 b726a drivers/ata/built-in.allyesconfig.dev_level.o 141328 14689 4220 160237 271ed drivers/ata/built-in.defconfig.ata.o 149567 14689 4220 168476 2921c drivers/ata/built-in.defconfig.dev_level.o Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2011-06-23libata/sas: only set FROZEN flag if new EH is supportedNishanth Aravamudan
On 16.06.2011 [08:28:39 -0500], Brian King wrote: > On 06/16/2011 02:51 AM, Tejun Heo wrote: > > On Wed, Jun 15, 2011 at 04:34:17PM -0700, Nishanth Aravamudan wrote: > >>> That looks like the right thing to do. For ipr's usage of > >>> libata, we don't have the concept of a port frozen state, so this flag > >>> should really never get set. The alternate way to fix this would be to > >>> only set ATA_PFLAG_FROZEN in ata_port_alloc if ap->ops->error_handler > >>> is not NULL. > >> > >> It seemed like ipr is as you say, but I wasn't sure if it was > >> appropriate to make the change above in the common libata-scis code or > >> not. I don't want to break some other device on accident. > >> > >> Also, I tried your suggestion, but I don't think that can happen in > >> ata_port_alloc? ata_port_alloc is allocated ap itself, and it seems like > >> ap->ops typically gets set only after ata_port_alloc returns? > > > > Maybe we can test error_handler in ata_sas_port_start()? > > Good point. Since libsas is converted to the new eh now, we would need to have > this test. Commit 7b3a24c57d2eeda8dba9c205342b12689c4679f9 ("ahci: don't enable port irq before handler is registered") caused a regression for CD-ROMs attached to the IPR SATA bus on Power machines: ata_port_alloc: ENTER ata_port_probe: ata1: bus probe begin ata1.00: ata_dev_read_id: ENTER ata1.00: failed to IDENTIFY (I/O error, err_mask=0x40) ata1.00: ata_dev_read_id: ENTER ata1.00: failed to IDENTIFY (I/O error, err_mask=0x40) ata1.00: limiting speed to UDMA7:PIO5 ata1.00: ata_dev_read_id: ENTER ata1.00: failed to IDENTIFY (I/O error, err_mask=0x40) ata1.00: disabled ata_port_probe: ata1: bus probe end scsi_alloc_sdev: Allocation failure during SCSI scanning, some SCSI devices might not be configured The FROZEN flag added in that commit is only cleared by the new EH code, which is not used by ipr. Clear this flag in the SAS code if we don't support new EH. Reported-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2011-05-25Merge branch 'for-2.6.40/core' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.40/core' of git://git.kernel.dk/linux-2.6-block: (40 commits) cfq-iosched: free cic_index if cfqd allocation fails cfq-iosched: remove unused 'group_changed' in cfq_service_tree_add() cfq-iosched: reduce bit operations in cfq_choose_req() cfq-iosched: algebraic simplification in cfq_prio_to_maxrq() blk-cgroup: Initialize ioc->cgroup_changed at ioc creation time block: move bd_set_size() above rescan_partitions() in __blkdev_get() block: call elv_bio_merged() when merged cfq-iosched: Make IO merge related stats per cpu cfq-iosched: Fix a memory leak of per cpu stats for root group backing-dev: Kill set but not used var in bdi_debug_stats_show() block: get rid of on-stack plugging debug checks blk-throttle: Make no throttling rule group processing lockless blk-cgroup: Make cgroup stat reset path blkg->lock free for dispatch stats blk-cgroup: Make 64bit per cpu stats safe on 32bit arch blk-throttle: Make dispatch stats per cpu blk-throttle: Free up a group only after one rcu grace period blk-throttle: Use helper function to add root throtl group to lists blk-throttle: Introduce a helper function to fill in device details blk-throttle: Dynamically allocate root group blk-cgroup: Allow sleeping while dynamically allocating a group ...
2011-05-19libata: Use Maximum Write Same Length to report discard size limitMartin K. Petersen
Previously we used Maximum Unmap LBA Count in the Block Limits VPD to signal the maximum number of sectors we could handle in a single Write Same command. Starting with SBC3r26 the Block Limits VPD has an explicit limit on the number of blocks in a Write Same. This means we can stop abusing a field related to the Unmap command and let our SAT use the proper value in the VPD (Maximum Write Same Length). Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com> Cc: stable@kernel.org
2011-05-06SATA: enable non-queueable flush flagshaohua.li@intel.com
Enable non-queueable flush flag for SATA. Stable: 2.6.39 only Cc: stable@kernel.org Signed-off-by: Shaohua Li <shaohua.li@intel.com> Acked-by: Tejun Heo <tj@kernel.org> Acked-by: Jeff Garzik <jgarzik@redhat.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-03-14libata: Include WWN ID in inquiry VPD emulationHannes Reinecke
As per SAT-3 the WWN ID should be included in the VPD page 0x83 (device identification) emulation. Signed-off-by: Hannes Reinecke <hare@suse.de> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2011-03-02libata: fix locking for sas pathsJames Bottomley
For historical reasons, libsas uses the scsi host lock as the ata port lock, and libata always uses the ata host. For the old eh, this was largely irrelevant since the two locks were never mixed inside the code. However, the new eh has a case where it nests acquisition of the host lock inside the port lock (this does look rather deadlock prone). Obviously this would be an instant deadlock if the port lock were the host lock, so switch the libsas paths to use the ata host lock as well. Signed-off-by: James Bottomley <James.Bottomley@suse.de> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2011-03-02libata: plumb sas port scan into standard libata pathsJames Bottomley
The function ata_sas_port_init() has always really done its own thing. However, as a precursor to moving to the libata new eh, it has to be properly using the standard libata scan paths. This means separating the current libata scan paths into pieces which can be shared with libsas and pieces which cant (really just the async call and the host scan). Signed-off-by: James Bottomley <James.Bottomley@suse.de> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2011-01-28libata: set queue DMA alignment to sector size for ATAPI tooTejun Heo
ata_pio_sectors() expects buffer for each sector to be contained in a single page; otherwise, it ends up overrunning the first page. This is achieved by setting queue DMA alignment. If sector_size is smaller than PAGE_SIZE and all buffers are sector_size aligned, buffer for each sector is always contained in a single page. This wasn't applied to ATAPI devices but IDENTIFY_PACKET is executed as ATA_PROT_PIO and thus uses ata_pio_sectors(). Newer versions of udev issue IDENTIFY_PACKET with unaligned buffer triggering the problem and causing oops. This patch fixes the problem by setting sdev->sector_size to ATA_SECT_SIZE on ATATPI devices and always setting DMA alignment to sector_size. While at it, add a warning for the unlikely but still possible scenario where sector_size is larger than PAGE_SIZE, in which case the alignment wouldn't be enough. Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: John Stanley <jpsinthemix@verizon.net> Tested-by: John Stanley <jpsinthemix@verizon.net> Cc: stable@kernel.org Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2011-01-05[libata] avoid needlessly passing around ptr to SCSI completion funcJeff Garzik
It's stored in struct scsi_cmnd->scsi_done, making several 'done' parameters to functions redundant. Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-11-17[libata] remove SCSI host lock and serial number usage from ata_scsi_queuecmdJeff Garzik
cmd->serial_number is never tested in any path we reach; therefore we may remove the call to scsi_cmd_get_serial() inside DEF_SCSI_QCMD, the SCSI host_lock acquisition surrounding it, and our own SCSI host_lock unlock+relock cycle. Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-11-16SCSI host lock push-downJeff Garzik
Move the mid-layer's ->queuecommand() invocation from being locked with the host lock to being unlocked to facilitate speeding up the critical path for drivers who don't need this lock taken anyway. The patch below presents a simple SCSI host lock push-down as an equivalent transformation. No locking or other behavior should change with this patch. All existing bugs and locking orders are preserved. Additionally, add one parameter to queuecommand, struct Scsi_Host * and remove one parameter from queuecommand, void (*done)(struct scsi_cmnd *) Scsi_Host* is a convenient pointer that most host drivers need anyway, and 'done' is redundant to struct scsi_cmnd->scsi_done. Minimal code disturbance was attempted with this change. Most drivers needed only two one-line modifications for their host lock push-down. Signed-off-by: Jeff Garzik <jgarzik@redhat.com> Acked-by: James Bottomley <James.Bottomley@suse.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-11-12libata: fix NULL sdev dereference race in atapi_qc_complete()Tejun Heo
SCSI commands may be issued between __scsi_add_device() and dev->sdev assignment, so it's unsafe for ata_qc_complete() to dereference dev->sdev->locked without checking whether it's NULL or not. Fix it. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: stable@kernel.org Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-10-21libata: Signal that our SATL supports WRITE SAME(16) with UNMAPMartin K. Petersen
Until now identifying that a device supports WRITE SAME(16) with the UNMAP bit set has been black magic. Implement support for the SBC-3 Thin Provisioning VPD page and set the TPWS bit. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-10-21libata: reimplement link power managementTejun Heo
The current LPM implementation has the following issues. * Operation order isn't well thought-out. e.g. HIPM should be configured after IPM in SControl is properly configured. Not the other way around. * Suspend/resume paths call ata_lpm_enable/disable() which must only be called from EH context directly. Also, ata_lpm_enable/disable() were called whether LPM was in use or not. * Implementation is per-port when it should be per-link. As a result, it can't be used for controllers with slave links or PMP. * LPM state isn't managed consistently. After a link reset for whatever reason including suspend/resume the actual LPM state would be reset leaving ap->lpm_policy inconsistent. * Generic/driver-specific logic boundary isn't clear. Currently, libahci has to mangle stuff which libata EH proper should be handling. This makes the implementation unnecessarily complex and fragile. * Tied to ALPM. Doesn't consider DIPM only cases and doesn't check whether the device allows HIPM. * Error handling isn't implemented. Given the extent of mismatch with the rest of libata, I don't think trying to fix it piecewise makes much sense. This patch reimplements LPM support. * The new implementation is per-link. The target policy is still port-wide (ap->target_lpm_policy) but all the mechanisms and states are per-link and integrate well with the rest of link abstraction and can work with slave and PMP links. * Core EH has proper control of LPM state. LPM state is reconfigured when and only when reconfiguration is necessary. It makes sure that LPM state is reset when probing for new device on the link. Controller agnostic logic is now implemented in libata EH proper and driver implementation only has to deal with controller specifics. * Proper error handling. LPM config failure is attributed to the device on the link and LPM is disabled for the link if it fails repeatedly. * ops->enable/disable_pm() are replaced with single ops->set_lpm() which takes @policy and @hints. This simplifies driver specific implementation. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
