path: root/drivers/ata/libata.h
2016-04-04libata: Implement control mode page to select sense formatHannes Reinecke
Implement MODE SELECT for the control mode page to allow the OS to switch to descriptor sense. tj: Dropped s/sb/cmd->sense_buffer/ in ata_gen_ata_sense(). Added @dev description to ata_msense_ctl_mode(). Signed-off-by: Hannes Reinecke <hare@suse.de> Signed-off-by: Tejun Heo <tj@kernel.org>
2016-04-04libata-eh: Set 'information' field for autosenseHannes Reinecke
If NCQ autosense or the sense data reporting feature is enabled the LBA of the offending command should be stored in the sense data 'information' field. tj: s/(u64)-1/U64_MAX/ Signed-off-by: Hannes Reinecke <hare@suse.de> Signed-off-by: Tejun Heo <tj@kernel.org>
2016-04-04libata: sanitize ata_tf_read_block()Hannes Reinecke
Return U64_MAX if ata_tf_read_block() could not decode the LBA address, and do not set the information sense descriptor in ata_gen_ata_sense() in these cases. tj: s/(u64)-1/U64_MAX/ Signed-off-by: Hannes Reinecke <hare@suse.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2016-04-04libata: Implement NCQ autosenseHannes Reinecke
Some newer devices support NCQ autosense (cf ACS-4), so we should be using it to retrieve the sense code and speed up recovery. Signed-off-by: Hannes Reinecke <hare@suse.de> Signed-off-by: Tejun Heo <tj@kernel.org>
2015-08-03Revert "libata: Implement NCQ autosense"Tejun Heo
This reverts commit 42b966fbf35da9c87f08d98f9b8978edf9e717cf. As implemented, ACS-4 sense reporting for ATA devices bypasses error diagnosis and handling in libata degrading EH behavior significantly. Revert the related changes for now. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Hannes Reinecke <hare@suse.de> Cc: stable@vger.kernel.org #v4.1+
2015-08-03Revert "libata-eh: Set 'information' field for autosense"Tejun Heo
This reverts commit a1524f226a02aa6edebd90ae0752e97cfd78b159. As implemented, ACS-4 sense reporting for ATA devices bypasses error diagnosis and handling in libata degrading EH behavior significantly. Revert the related changes for now. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Hannes Reinecke <hare@suse.de> Cc: stable@vger.kernel.org #v4.1+
2015-03-27libata-eh: Set 'information' field for autosenseHannes Reinecke
If NCQ autosense or the sense data reporting feature is enabled the LBA of the offending command should be stored in the sense data 'information' field. Signed-off-by: Hannes Reinecke <hare@suse.de> Signed-off-by: Tejun Heo <tj@kernel.org>
2015-03-27libata: Implement NCQ autosenseHannes Reinecke
2015-02-12Merge branch 'for-3.20/drivers' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull block driver changes from Jens Axboe: "This contains: - The 4k/partition fixes for brd from Boaz/Matthew. - A few xen front/back block fixes from David Vrabel and Roger Pau Monne. - Floppy changes from Takashi, cleaning the device file creation. - Switching libata to use the new blk-mq tagging policy, removing code (and a suboptimal implementation) from libata. This will throw you a merge conflict, since a bug in the original libata tagging code was fixed since this code was branched. Trivial. From Shaohua. - Conversion of loop to blk-mq, from Ming Lei. - Cleanup of the io_schedule() handling in bsg from Peter Zijlstra. He claims it improves on unreadable code, which will cost him a beer. - Maintainer update or NDB, now handled by Markus Pargmann. - NVMe: - Optimization from me that avoids a kmalloc/kfree per IO for smaller (<= 8KB) IO. This cuts about 1% of high IOPS CPU overhead. - Removal of (now) dead RCU code, a relic from before NVMe was converted to blk-mq" * 'for-3.20/drivers' of git://git.kernel.dk/linux-block: xen-blkback: default to X86_32 ABI on x86 xen-blkfront: fix accounting of reqs when migrating xen-blkback,xen-blkfront: add myself as maintainer block: Simplify bsg complete all floppy: Avoid manual call of device_create_file() NVMe: avoid kmalloc/kfree for smaller IO MAINTAINERS: Update NBD maintainer libata: make sata_sil24 use fifo tag allocator libata: move sas ata tag allocation to libata-scsi.c libata: use blk taging NVMe: within nvme_free_queues(), delete RCU sychro/deferred free null_blk: suppress invalid partition info brd: Request from fdisk 4k alignment brd: Fix all partitions BUGs axonram: Fix bug in direct_access loop: add blk-mq.h include block: loop: don't handle REQ_FUA explicitly block: loop: introduce lo_discard() and lo_req_flush() block: loop: say goodby to bio block: loop: improve performance via blk-mq
2015-01-24libata: move sas ata tag allocation to libata-scsi.cShaohua Li
Basically move the sas ata tag allocation to libata-scsi.c to make it clear these staffs are just for sas. Signed-off-by: Shaohua Li <shli@fb.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2015-01-23libata: use blk tagingShaohua Li
libata uses its own tag management which is duplication and the implementation is poor. And if we switch to blk-mq, tag is build-in. It's time to switch to generic taging. The SAS driver has its own tag management, and looks we can't directly map the host controler tag to SATA tag. So I just bypassed the SAS case. I changed the code/variable name for the tag management of libata to make it self contained. Only sas will use it. Later if libsas implements its tag management, the tag management code in libata can be deleted easily. Cc: Jens Axboe <axboe@fb.com> Cc: Christoph Hellwig <hch@infradead.org> Signed-off-by: Shaohua Li <shli@fb.com> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <axboe@fb.com>
2015-01-11ata: libata-core: Remove unused functionRickard Strandqvist
Remove the function ata_do_simple_cmd() that is not used anywhere. This was partially found by using a static code analysis program called cppcheck. Signed-off-by: Rickard Strandqvist <rickard_strandqvist@spectrumdigital.se> Signed-off-by: Tejun Heo <tj@kernel.org>
2014-07-17scsi: use 64-bit LUNsHannes Reinecke
The SCSI standard defines 64-bit values for LUNs, and large arrays employing large or hierarchical LUN numbers become more and more common. So update the linux SCSI stack to use 64-bit LUN numbers. Signed-off-by: Hannes Reinecke <hare@suse.de> Reviewed-by: Christoph Hellwig <hch@infradead.org> Reviewed-by: Ewan Milne <emilne@redhat.com> Signed-off-by: Christoph Hellwig <hch@lst.de>
2013-10-17ATA / ACPI: remove power dependent device handlingAaron Lu
Previously, we wanted SCSI devices corrsponding to ATA devices to be runtime resumed when the power resource for those ATA device was turned on by some other device, so we added the SCSI device to the dependent device list of the ATA device's ACPI node. However, this code has no effect after commit 41863fc (ACPI / power: Drop automaitc resume of power resource dependent devices) and the mechanism it was supposed to implement is regarded as a bad idea now, so drop it. [rjw: Changelog] Signed-off-by: Aaron Lu <aaron.lu@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-08-27libata: acpi: Remove ata_dev_acpi_handle stub in libata.hAaron Lu
The ata_dev_acpi_handle is defined in libata-acpi.c and the only external user is libata-zpodd.c, which is built when CONFIG_ATA_ACPI is set, so there is no need to make an empty stub function for ONFIG_ATA_ACPI case in libata.h. It also causes compile errors due to acpi_handle is not defined when !CONFIG_ACPI. This patch fixes this problem by removing the empty stub. Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Aaron Lu <aaron.lu@intel.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2013-08-23ata: acpi: rework the ata acpi bind supportAaron Lu
Binding ACPI handle to SCSI device has several drawbacks, namely: 1 During ATA device initialization time, ACPI handle will be needed while SCSI devices are not created yet. So each time ACPI handle is needed, instead of retrieving the handle by ACPI_HANDLE macro, a namespace scan is performed to find the handle for the corresponding ATA device. This is inefficient, and also expose a restriction on calling path not holding any lock. 2 The binding to SCSI device tree makes code complex, while at the same time doesn't bring us any benefit. All ACPI handlings are still done in ATA module, not in SCSI. Rework the ATA ACPI binding code to bind ACPI handle to ATA transport devices(ATA port and ATA device). The binding needs to be done only once, since the ATA transport devices do not go away with hotplug. And due to this, the flush_work call in hotplug handler for ATA bay is no longer needed. Tested on an Intel test platform for binding and runtime power off for ODD(ZPODD) and hard disk; on an ASUS S400C for binding and normal boot and S3, where its SATA port node has _SDD and _GTF control methods when configured as an AHCI controller and its PATA device node has _GTF control method when configured as an IDE controller. SATA PMP binding and ATA hotplug is not tested. Signed-off-by: Aaron Lu <aaron.lu@intel.com> Tested-by: Dirk Griesbach <spamthis@freenet.de> Signed-off-by: Tejun Heo <tj@kernel.org>
2013-07-25libata: acpi: remove dead code for ata_acpi_(un)bindAaron Lu
Commit 7381fe737 "libata-acpi: remove redundent code for power resource handling" removed ata_acpi_(un)bind but left their prototypes in libata.h, so remove them. Signed-off-by: Aaron Lu <aaron.lu@intel.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2013-06-25libata-acpi: add back ACPI based hotplug functionalityAaron Lu
Commit 30dcf76acc69 "libata: migrate ACPI code over to new bindings" mistakenly dropped the code to register hotplug notificaion handler for ATA port/devices, causing regression for people using ATA bay, as kernel bug #59871 shows. Fix this by adding back the hotplug notification handler registration code. Since this code has to be run once and notification needs to be installed on every ATA port/devices handle no matter if there is actual device attached, we can't do this in binding time for ATA device ACPI handle, as the binding only occurs when a SCSI device is created, i.e. there is device attached. So introduce the ata_acpi_hotplug_init() function to loop scan all ATA ACPI handles and if it is available, install the notificaion handler for it during ATA init time. With the ATA ACPI handle binding to SCSI device tree, it is possible now that when the SCSI hotplug work removes the SCSI device, the ACPI unbind function will find that the corresponding ACPI device has already been deleted by dock driver, causing a scaring message like: [ 128.263966] scsi 4:0:0:0: Oops, 'acpi_handle' corrupt Fix this by waiting for SCSI hotplug task finish in our notificaion handler, so that the removal of ACPI device done in ACPI unbind function triggered by the removal of SCSI device is run earlier when ACPI device is still available. [rjw: Rebased] References: https://bugzilla.kernel.org/show_bug.cgi?id=59871 Reported-bisected-and-tested-by: Dirk Griesbach <spamthis@freenet.de> Signed-off-by: Aaron Lu <aaron.lu@intel.com> Acked-by: Tejun Heo <tj@kernel.org> Cc: 3.6+ <stable@vger.kernel.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-01-21libata: handle power transition of ODDAaron Lu
When ata port is runtime suspended, it will check if the ODD attched to it is a zero power(ZP) capable ODD and if the ZP capable ODD is in zero power ready state. And if this is not the case, the highest acpi state will be limited to ACPI_STATE_D3_HOT to avoid powering off the ODD. And if the ODD can be powered off, runtime wake capability needs to be enabled and powered_off flag will be set to let resume code knows that the ODD was in powered off state. And on resume, before it is powered on, if it was powered off during suspend, runtime wake capability needs to be disabled. After it is recovered, the ODD is considered functional, post power on processing like eject tray if the ODD is drawer type is done, and several ZPODD related fields will also be reset. Signed-off-by: Aaron Lu <aaron.lu@intel.com> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2013-01-21libata: check zero power ready status for ZPODDAaron Lu
Per the Mount Fuji spec, the ODD is considered zero power ready when: - For slot type ODD, no media inside; - For tray type ODD, no media inside and tray closed. The information can be retrieved by either the returned information of command GET_EVENT_STATUS_NOTIFICATION(the command is used to poll for media event) or sense code. The information provided by the media status byte is not accurate, it is possible that after a new disc is just inserted, the status byte still returns media not present. So this information can not be used as the deciding factor, we use sense code to decide if zpready status is true. When we first sensed the ODD in the zero power ready state, the zp_sampled will be set and timestamp will be recoreded. And after ODD stayed in this state for some pre-defined period, the ODD is considered as power off ready and the zp_ready flag will be set. The zp_ready flag serves as the deciding factor other code will use to see if power off is OK for the ODD. The Mount Fuji spec suggests a delay should be used here, to avoid the case user ejects the ODD and then instantly inserts a new one again, so that we can avoid a power transition. And some ODDs may be slow to place its head to the home position after disc is ejected, so a delay here is generally a good idea. And the delay time can be changed via the module param zpodd_poweroff_delay. The zero power ready status check is performed in the ata port's runtime suspend code path, when port is not frozen yet, as we need to issue some IOs to the ODD. Signed-off-by: Aaron Lu <aaron.lu@intel.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2013-01-21libata: identify and init ZPODD devicesAaron Lu
The ODD can be enabled for ZPODD if the following three conditions are satisfied: 1 The ODD supports device attention; 2 The platform can runtime power off the ODD through ACPI; 3 The ODD is either slot type or drawer type. For such ODDs, zpodd_init is called and a new structure is allocated for it to store ZPODD related stuffs. And the zpodd_dev_enabled function is used to test if ZPODD is currently enabled for this ODD. A new config CONFIG_SATA_ZPODD is added to selectively build ZPODD code. Signed-off-by: Aaron Lu <aaron.lu@intel.com> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2012-09-13ahci: implement aggressive SATA device sleep supportShane Huang
Device Sleep is a feature as described in AHCI 1.3.1 Technical Proposal. This feature enables an HBA and SATA storage device to enter the DevSleep interface state, enabling lower power SATA-based systems. Aggressive Device Sleep enables the HBA to assert the DEVSLP signal as soon as there are no commands outstanding to the device and the port specific Device Sleep idle timer has expired. This enables autonomous entry into the DevSleep interface state without waiting for software in power sensitive systems. This patch enables Aggressive Device Sleep only if both host controller and device support it. Tested on AMD reference board together with Device Sleep supported device sample. Signed-off-by: Shane Huang <shane.huang@amd.com> Reviewed-by: Aaron Lu <aaron.lwe@gmail.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2012-07-25libata-acpi: add missing inlines in libata.hLin Ming
Adds inline for ata_acpi_unregister/ata_acpi_bind/ata_acpi_unbind in drivers/ata/libata.h for !CONFIG_ATA_ACPI to fix below warnings. warning: 'ata_acpi_unregister' defined but not used [-Wunused-function] warning: 'ata_acpi_bind' defined but not used [-Wunused-function] warning: 'ata_acpi_unbind' defined but not used [-Wunused-function] Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2012-06-29libata-acpi: add ata port runtime D3Cold supportLin Ming
ATA port may support runtime D3Cold state, for example, Zero-power ODD case. This patch adds wakeup notifier and enable/disable run_wake during supend/resume. Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2012-06-29libata: migrate ACPI code over to new bindingsMatthew Garrett
Now that we have the ability to directly glue the ACPI namespace to the driver model in libata, we don't need the custom code to handle the same thing. Remove it and migrate the functions over to the new code. Signed-off-by: Matthew Garrett <mjg@redhat.com> Signed-off-by: Holger Macht <holger@homac.de> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2012-06-29libata: bind the Linux device tree to the ACPI device treeMatthew Garrett
Associate the ACPI device tree and libata devices. This patch uses the generic ACPI glue framework to do so. Signed-off-by: Matthew Garrett <mjg@redhat.com> Signed-off-by: Holger Macht <holger@homac.de> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2012-04-12libata: make ata_print_id atomicDan Williams
This variable is incremented from multiple contexts (module_init via libata-lldds and the libsas discovery thread). Make it atomic to head off any chance of libsas and libata creating duplicate ids. Acked-by: Jacek Danecki <jacek.danecki@intel.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2012-02-29[SCSI] libsas: async ata scanningDan Williams
libsas ata error handling is already async but this does not help the scan case. Move initial link recovery out from under host->scan_mutex, and delay synchronization with eh until after all port probe/recovery work has been queued. Device ordering is maintained with scan order by still calling sas_rphy_add() in order of domain discovery. Since we now scan the domain list when invoking libata-eh we need to be careful to check for fully initialized ata ports. Acked-by: Jack Wang <jack_wang@usish.com> Acked-by: Jeff Garzik <jgarzik@redhat.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-02-19[SCSI] libsas: execute transport link resets with libata-eh via host workqueueDan Williams
Link resets leave ata affiliations intact, so arrange for libsas to make an effort to avoid dropping the device due to a slow-to-recover link. Towards this end carry out reset in the host workqueue so that it can check for ata devices and kick the reset request to libata. Hard resets, in contrast, bypass libata since they are meant for associating an ata device with another initiator in the domain (tears down affiliations). Need to add a new transport_sas_phy_reset() since the current sas_phy_reset() is a utility function to libsas lldds. They are not prepared for it to loop back into eh. Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-01-08ata: add ata port system PM callbacksLin Ming
Change ata_host_request_pm to ata_port_request_pm which performs port suspend/resume. Add ata port type driver which implements port PM callbacks. Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2011-03-02libata: plumb sas port scan into standard libata pathsJames Bottomley
The function ata_sas_port_init() has always really done its own thing. However, as a precursor to moving to the libata new eh, it has to be properly using the standard libata scan paths. This means separating the current libata scan paths into pieces which can be shared with libsas and pieces which cant (really just the async call and the host scan). Signed-off-by: James Bottomley <James.Bottomley@suse.de> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-10-21libata: implement cross-port EH exclusionTejun Heo
In libata, the non-EH code paths should always take and release ap->lock explicitly when accessing hardware or shared data structures. However, once EH is active, it's assumed that the port is owned by EH and EH methods don't explicitly take ap->lock unless race from irq handler or other code paths are expected. However, libata EH didn't guarantee exclusion among EHs for ports of the same host. IOW, multiple EHs may execute in parallel on multiple ports of the same controller. In many cases, especially in SATA, the ports are completely independent of each other and this doesn't cause problems; however, there are cases where different ports share the same resource, which lead to obscure timing related bugs such as the one fixed by commit 213373cf (ata_piix: fix locking around SIDPR access). This patch implements exclusion among EHs of the same host. When EH begins, it acquires per-host EH ownership by calling ata_eh_acquire(). When EH finishes, the ownership is released by calling ata_eh_release(). EH ownership is also released whenever the EH thread goes to sleep from ata_msleep() or explicitly and reacquired after waking up. This ensures that while EH is actively accessing the hardware, it has exclusive access to it while allowing EHs to interleave and progress in parallel as they hit waiting stages, which dominate the time spent in EH. This achieves cross-port EH exclusion without pervasive and fragile changes while still allowing parallel EH for the most part. This was first reported by yuanding02@gmail.com more than three years ago in the following bugzilla. :-) https://bugzilla.kernel.org/show_bug.cgi?id=8223 Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Reported-by: yuanding02@gmail.com Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-10-21libata: implement LPM support for port multipliersTejun Heo
Port multipliers can do DIPM on fan-out links fine. Implement support for it. Tested w/ SIMG 57xx and marvell PMPs. Both the host and fan-out links enter power save modes nicely. SIMG 37xx and 47xx report link offline on SStatus causing EH to detach the devices. Blacklisted. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-10-21libata: reimplement link power managementTejun Heo
The current LPM implementation has the following issues. * Operation order isn't well thought-out. e.g. HIPM should be configured after IPM in SControl is properly configured. Not the other way around. * Suspend/resume paths call ata_lpm_enable/disable() which must only be called from EH context directly. Also, ata_lpm_enable/disable() were called whether LPM was in use or not. * Implementation is per-port when it should be per-link. As a result, it can't be used for controllers with slave links or PMP. * LPM state isn't managed consistently. After a link reset for whatever reason including suspend/resume the actual LPM state would be reset leaving ap->lpm_policy inconsistent. * Generic/driver-specific logic boundary isn't clear. Currently, libahci has to mangle stuff which libata EH proper should be handling. This makes the implementation unnecessarily complex and fragile. * Tied to ALPM. Doesn't consider DIPM only cases and doesn't check whether the device allows HIPM. * Error handling isn't implemented. Given the extent of mismatch with the rest of libata, I don't think trying to fix it piecewise makes much sense. This patch reimplements LPM support. * The new implementation is per-link. The target policy is still port-wide (ap->target_lpm_policy) but all the mechanisms and states are per-link and integrate well with the rest of link abstraction and can work with slave and PMP links. * Core EH has proper control of LPM state. LPM state is reconfigured when and only when reconfiguration is necessary. It makes sure that LPM state is reset when probing for new device on the link. Controller agnostic logic is now implemented in libata EH proper and driver implementation only has to deal with controller specifics. * Proper error handling. LPM config failure is attributed to the device on the link and LPM is disabled for the link if it fails repeatedly. * ops->enable/disable_pm() are replaced with single ops->set_lpm() which takes @policy and @hints. This simplifies driver specific implementation. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-10-21libata: implement sata_link_scr_lpm() and make ata_dev_set_feature() globalTejun Heo
Link power management is about to be reimplemented. Prepare for it. * Implement sata_link_scr_lpm(). * Drop static from ata_dev_set_feature() and make it available to other libata files. * Trivial whitespace adjustments. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-10-21libata: clean up lpm related symbols and sysfs show/store functionsTejun Heo
Link power management related symbols are in confusing state w/ mixed usages of lpm, ipm and pm. This patch cleans up lpm related symbols and sysfs show/store functions as follows. * lpm states - NOT_AVAILABLE, MIN_POWER, MAX_PERFORMANCE and MEDIUM_POWER are renamed to ATA_LPM_UNKNOWN and ATA_LPM_{MIN|MAX|MED}_POWER. * Pre/postfixes are unified to lpm. * sysfs show/store functions for link_power_management_policy were curiously named get/put and unnecessarily complex. Renamed to show/store and simplified. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-10-21[libata] Add ATA transport classGwendal Grignou
This is a scheleton for libata transport class. All information is read only, exporting information from libata: - ata_port class: one per ATA port - ata_link class: one per ATA port or 15 for SATA Port Multiplier - ata_device class: up to 2 for PATA link, usually one for SATA. Signed-off-by: Gwendal Grignou <gwendal@google.com> Reviewed-by: Grant Grundler <grundler@google.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-07-02libata: take advantage of cmwq and remove concurrency limitationsTejun Heo
libata has two concurrency related limitations. a. ata_wq which is used for polling PIO has single thread per CPU. If there are multiple devices doing polling PIO on the same CPU, they can't be executed simultaneously. b. ata_aux_wq which is used for SCSI probing has single thread. In cases where SCSI probing is stalled for extended period of time which is possible for ATAPI devices, this will stall all probing. #a is solved by increasing maximum concurrency of ata_wq. Please note that polling PIO might be used under allocation path and thus needs to be served by a separate wq with a rescuer. #b is solved by using the default wq instead and achieving exclusion via per-port mutex. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Jeff Garzik <jgarzik@pobox.com>
2010-05-19libata-sff: separate out BMDMA EHTejun Heo
Some of error handling logic in ata_sff_error_handler() and all of ata_sff_post_internal_cmd() are for BMDMA. Create ata_bmdma_error_handler() and ata_bmdma_post_internal_cmd() and move BMDMA part into those. While at it, change DMA protocol check to ata_is_dma(), fix post_internal_cmd to call ap->ops->bmdma_stop instead of directly calling ata_bmdma_stop() and open code hardreset selection so that ata_std_error_handler() doesn't have to know about sff hardreset. As these two functions are BMDMA specific, there's no reason to check for bmdma_addr before calling bmdma methods if the protocol of the failed command is DMA. sata_mv and pata_mpc52xx now don't need to set .post_internal_cmd to ATA_OP_NULL and pata_icside and sata_qstor don't need to set it to their bmdma_stop routines. ata_sff_post_internal_cmd() becomes noop and is removed. This fixes p3 described in clean-up-BMDMA-initialization patch. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-05-19libata-sff: port_task is SFF specificTejun Heo
port_task is tightly bound to the standard SFF PIO HSM implementation. Using it for any other purpose would be error-prone and there's no such user and if some drivers need such feature, it would be much better off using its own. Move it inside CONFIG_ATA_SFF and rename it to sff_pio_task. The only function which is exposed to the core layer is ata_sff_flush_pio_task() which is renamed from ata_port_flush_task() and now also takes care of resetting hsm_task_state to HSM_ST_IDLE, which is possible as it's now specific to PIO HSM. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-05-19libata-sff: introduce ata_sff_init/exit() and ata_sff_port_init()Tejun Heo
In preparation of proper SFF/BMDMA separation, introduce ata_sff_init/exit() and ata_sff_port_init(). These functions currently don't do anything. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-05-14libata-sff: kill unused prototype and make ata_dev_select() staticTejun Heo
ata_irq_on() was renamed to ata_sff_irq_on() and exported a while ago but prototype for the original function lingered in drivers/ata/libata.h. Kill it. Also, ata_dev_select() is only used inside drivers/ata/libata-sff.c. Make it static. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-10-06libata: make gtf_filter per-devTejun Heo
Add ->gtf_filter to ata_device and set it to ata_acpi_gtf_filter when initializing ata_link. This is to allow quirks which apply different gtf filters. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-09-01libata: add command name parsing for error outputRobert Hancock
This patch improve libata's output for error/notification messages to allow easier comprehension and debugging: When ATAPI commands issued through the SCSI layer fail, use SCSI functions to print the CDB in human-readable form instead of just dumping out the CDB in hex. Print out the name of the failed command (as defined by the ATA specification) in error handling output along with the raw register contents. When reporting status of ACPI taskfile commands executed on resume, also output the names of the commands being executed (or not) in readable form. Since the extra data for printing command names increases kernel size slightly, a config option has been added to allow disabling command name output (as well as some of the error register parsing) for those highly sensitive to kernel text size. Signed-off-by: Robert Hancock <hancockrwd@gmail.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-03-24[libata] Export ata_pio_queue_task() so that it can be used from sata_mv.Mark Lord
Signed-off-by: Mark Lord <mlord@pobox.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-02-02libata: add @spd_limit to sata_down_spd_limit()Tejun Heo
Add @spd_limit to sata_down_spd_limit() so that the caller can specify the SPD limit it wants. This parameter doesn't get in the way even when it's too low. The closest possible limit is applied. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-02-02libata: move ata_dev_disable() to libata-eh.cTejun Heo
ata_dev_disable() is about to be more tightly integrated into EH logic. Move it to libata-eh.c. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-11-10libata: revert convert-to-block-tagging patchesTejun Heo
This patch reverts the following three commits which convert libata to use block layer tagging. 43a49cbdf31e812c0d8f553d433b09b421f5d52c e013e13bf605b9e6b702adffbe2853cfc60e7806 2fca5ccf97d2c28bcfce44f5b07d85e74e3cd18e Although using block layer tagging is the right direction, due to the tight coupling among tag number, data structure allocation and hardware command slot allocation, libata doesn't work correctly with the current conversion. The biggest problem is guaranteeing that tag 0 is always used for non-NCQ commands. Due to the way blk-tag is implemented and how SCSI starts and finishes requests, such guarantee can't be made. I'm not sure whether this would actually break any low level driver but it doesn't look like a good idea to break such assumption given the frailty of ATA controllers. So, for the time being, keep using the old dumb in-libata qc allocation. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Jens Axobe <jens.axboe@oracle.com> Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-23libata: switch to using block layer tagging supportJens Axboe
libata currently has a pretty dumb ATA_MAX_QUEUE loop for finding a free tag to use. Instead of fixing that up, convert libata to using block layer tagging - gets rid of code in libata, and is also much faster. Signed-off-by: Jens Axboe <jens.axboe@oracle.com> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-10Merge branch 'for-2.6.28' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.28' of git://git.kernel.dk/linux-2.6-block: (132 commits) doc/cdrom: Trvial documentation error, file not present block_dev: fix kernel-doc in new functions block: add some comments around the bio read-write flags block: mark bio_split_pool static block: Find bio sector offset given idx and offset block: gendisk integrity wrapper block: Switch blk_integrity_compare from bdev to gendisk block: Fix double put in blk_integrity_unregister block: Introduce integrity data ownership flag block: revert part of d7533ad0e132f92e75c1b2eb7c26387b25a583c1 bio.h: Remove unused conditional code block: remove end_{queued|dequeued}_request() block: change elevator to use __blk_end_request() gdrom: change to use __blk_end_request() memstick: change to use __blk_end_request() virtio_blk: change to use __blk_end_request() blktrace: use BLKTRACE_BDEV_SIZE as the name size for setup structure block: add lld busy state exporting interface block: Fix blk_start_queueing() to not kick a stopped queue include blktrace_api.h in headers_install ...
