Add Toshiba S1800-814 to whitelist for both pata_ali and alim15x3,
as it is correctly detected as 40-wire connected but this cable is
short enough to still use transfer modes higher than UDMA33.
Signed-off-by: Daniel Exner <dex@dragonslave.de>
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
Bump the versions for drivers that were modified, but had not already
had a version number bump.
Signed-off-by: Jeff Garzik <jeff@garzik.org>
Signed-off-by: Alan Cox <alan@redhat.com>
Instead of all drivers reading pci config space to get the revision
ID, they can now use the pci_device->revision member.
This exposes some issues where drivers where reading a word or a dword
for the revision number, and adding useless error-handling around the
read. Some drivers even just read it for no purpose of all.
In devices where the revision ID is being copied over and used in what
appears to be the equivalent of hotpath, I have left the copy code
and the cached copy as not to influence the driver's performance.
Compile tested with make all{yes,mod}config on x86_64 and i386.
Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com>
Acked-by: Dave Jones <davej@redhat.com>
The ATA_UDMAx masks are self-documenting, and far better than manually
writing in the hex mask.
Note that pata_it8213 mask differed from the comment. Added a FIXME there.
This flag only has meaning in old-EH drivers, and these drivers have
already been converted to the new EH. Remove.
This patch was found to fix some of the problems with the
pata_ali driver.
https://bugzilla.redhat.com/bugzilla/attachment.cgi?id=156482
The intention of using port_mask in SFF init helpers was to eventually
support exoctic configurations such as combination of legacy and
native port on the same controller. This never became actually
necessary and the related code always has been subtly broken one way
or the other. Now that new init model is in place, there is no reason
to make common helpers capable of handling all corner cases. Exotic
cases can simply dealt within LLDs as necessary.
This patch removes port_mask handling in SFF init helpers. SFF init
helpers don't take n_ports argument and interpret it into port_mask
anymore. All information is carried via port_info. n_ports argument
is dropped and always two ports are allocated. LLD can tell SFF to
skip certain port by marking it dummy. Note that SFF code has been
treating unuvailable ports this way for a long time until recent
breakage fix from Linus and is consistent with how other drivers
handle with unavailable ports.
This fixes 1-port legacy host handling still broken after the recent
native mode fix and simplifies SFF init logic. The following changes
are made...
* ata_pci_init_native_host() and ata_init_legacy_host() both now try
to initialized whatever they can and mark failed ports dummy. They
return 0 if any port is successfully initialized.
* ata_pci_prepare_native_host() and ata_pci_init_one() now doesn't
take n_ports argument. All info should be specified via port_info
array. Always two ports are allocated.
* ata_pci_init_bmdma() exported to be used by LLDs in exotic cases.
* port_info handling in all LLDs are standardized - all port_info
arrays are const stack variable named ppi. Unless the second port
is different from the first, its port_info is specified as NULL
(tells libata that it's identical to the last non-NULL port_info).
* pata_hpt37x/hpt3x2n: don't modify static variable directly. Make an
on-stack copy instead as ata_piix does.
* pata_uli: It has 4 ports instead of 2. Don't use
ata_pci_prepare_native_host(). Allocate the host explicitly and use
init helpers. It's simple enough.
Signed-off-by: Tejun Heo <htejun@gmail.com>
Reimplement suspend/resume support using sdev->manage_start_stop.
* Device suspend/resume is now SCSI layer's responsibility and the
code is simplified a lot.
* DPM is dropped. This also simplifies code a lot. Suspend/resume
status is port-wide now.
* ata_scsi_device_suspend/resume() and ata_dev_ready() removed.
* Resume now has to wait for disk to spin up before proceeding. I
couldn't find easy way out as libata is in EH waiting for the
disk to be ready and sd is waiting for EH to complete to issue
START_STOP.
* sdev->manage_start_stop is set to 1 in ata_scsi_slave_config().
This fixes spindown on shutdown and suspend-to-disk.
With Tejun having added adev->ap some time ago we can get rid of the
almost unused port being passed to mode filters. And while we are
doing filters, lets turn on the !IORDY filter as well.
With some hand massaging from
It used to be impossible to get from ata_device to ata_port but that is
no longer true. Various methods have been cleaned up over time but
dev_config still takes both and most users don't need both anyway. Tidy
this one up
Add missing #ifdef CONFIG_PM conditionals around all PM related parts
in libata LLDs.
Bump versions based on changes submitted during 2.6.21 merge window.
This patch is against each libata driver.
Two IRQ calls are added in ata_port_operations.
- irq_on() is used to enable interrupts.
- irq_ack() is used to acknowledge a device interrupt.
In most drivers, ata_irq_on() and ata_irq_ack() are used for
irq_on and irq_ack respectively.
In some drivers (ex: ahci, sata_sil24) which cannot use them
as is, ata_dummy_irq_on() and ata_dummy_irq_ack() are used.
Signed-off-by: Kou Ishizaki <kou.ishizaki@toshiba.co.jp>
Signed-off-by: Akira Iguchi <akira2.iguchi@toshiba.co.jp>
Convert libata core layer and LLDs to use iomap.
* managed iomap is used. Pointer to pcim_iomap_table() is cached at
host->iomap and used through out LLDs. This basically replaces
host->mmio_base.
* if possible, pcim_iomap_regions() is used
Most iomap operation conversions are taken from Jeff Garzik
<jgarzik@pobox.com>'s iomap branch.
Update libata LLDs to use devres. Core layer is already converted to
support managed LLDs. This patch simplifies initialization and fixes
many resource related bugs in init failure and detach path. For
example, all converted drivers now handle ata_device_add() failure
gracefully without excessive resource rollback code.
As most resources are released automatically on driver detach, many
drivers don't need or can do with much simpler ->{port|host}_stop().
In general, stop callbacks are need iff port or host needs to be given
commands to shut it down. Note that freezing is enough in many cases
and ports are automatically frozen before being detached.
There were several places where ATA ID strings are manually terminated
and in some places possibly unterminated strings were passed to string
functions which don't limit length like strstr(). This patch converts
all of them over to ata_id_c_string().
* Kill _OFS suffixes in ATA_ID_{SERNO|FW_REV|PROD}_OFS for consistency
with other ATA_ID_* constants.
* Kill ATA_SERNO_LEN
* Add and use ATA_ID_SERNO_LEN, ATA_ID_FW_REV_LEN and ATA_ID_PROD_LEN.
This change also makes ata_device_blacklisted() use proper length
for fwrev.
Most of these contributed by that mysterious figger known as A.C.
Switch to pci_get_bus_and_slot because some x86 systems seem to be
handing us a device with dev->bus = NULL. Also don't apply the isa fixup
to revision C6 and later of the chip.
Really we need to work out wtf is handing us pdev->bus = NULL, but firstly
and more importantly we need the drivers working.
sht->max_sectors is overrided unconditionally in ->slave_configure.
There's no reason to set it to any value.
Various chipset functions must be reprogrammed on a resume from RAM,
without this things like ATAPI DMA stop working on resume with some
chipset variants. Split the chipset programming and init time method selection into two functions.
detection
[deweerdt@free.fr: build fix]
Signed-off-by: Frederik Deweerdt <deweerdt@free.fr>
Cc: Tejun Heo <htejun@gmail.com>
Many LLDs are missing sht->slave_destroy. The method is mandatory to
support device warm unplugging (echo 1 > /sys/.../delete). Without
it, libata might access released scsi device.
This fixes support for rev c8 of the ALi/ULi PATA, and keeps pcmcia in
sync so ide_cs and pata_pcmcia are interchangable, both are only changes
to constants.
Right now rev 0xC8 and higher don't work with libata but 0xc8 is in the
field now.
* Use PCI_VDEVICE() macro
* const-ify pci_device_id table
* standardize list terminator as "{ }"
* convert spaces to tab in pci_driver struct (Alan-ism)
* various minor whitespace cleanups
The PATA driver set got converted to the new error handling setup, but
the old hooks were accidentally left in place. Now, removed.
The vast majority of drivers and changes are from Alan Cox. Albert Lee
contributed and maintains pata_pdc2027x. Adrian Bunk, Andrew Morton,
and Tejun Heo contributed various minor fixes and updates.
