path: root/drivers/ata/pata_cypress.c
2007-07-09[libata] PATA drivers: remove ATA_FLAG_SRSTJeff Garzik
This flag only has meaning in old-EH drivers, and these drivers have already been converted to the new EH. Remove. Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-05-21libata: bump versionsJeff Garzik
2007-05-11libata: clean up SFF init messTejun Heo
The intention of using port_mask in SFF init helpers was to eventually support exoctic configurations such as combination of legacy and native port on the same controller. This never became actually necessary and the related code always has been subtly broken one way or the other. Now that new init model is in place, there is no reason to make common helpers capable of handling all corner cases. Exotic cases can simply dealt within LLDs as necessary. This patch removes port_mask handling in SFF init helpers. SFF init helpers don't take n_ports argument and interpret it into port_mask anymore. All information is carried via port_info. n_ports argument is dropped and always two ports are allocated. LLD can tell SFF to skip certain port by marking it dummy. Note that SFF code has been treating unuvailable ports this way for a long time until recent breakage fix from Linus and is consistent with how other drivers handle with unavailable ports. This fixes 1-port legacy host handling still broken after the recent native mode fix and simplifies SFF init logic. The following changes are made... * ata_pci_init_native_host() and ata_init_legacy_host() both now try to initialized whatever they can and mark failed ports dummy. They return 0 if any port is successfully initialized. * ata_pci_prepare_native_host() and ata_pci_init_one() now doesn't take n_ports argument. All info should be specified via port_info array. Always two ports are allocated. * ata_pci_init_bmdma() exported to be used by LLDs in exotic cases. * port_info handling in all LLDs are standardized - all port_info arrays are const stack variable named ppi. Unless the second port is different from the first, its port_info is specified as NULL (tells libata that it's identical to the last non-NULL port_info). * pata_hpt37x/hpt3x2n: don't modify static variable directly. Make an on-stack copy instead as ata_piix does. * pata_uli: It has 4 ports instead of 2. Don't use ata_pci_prepare_native_host(). Allocate the host explicitly and use init helpers. It's simple enough. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-05-11libata: reimplement suspend/resume support using sdev->manage_start_stopTejun Heo
Reimplement suspend/resume support using sdev->manage_start_stop. * Device suspend/resume is now SCSI layer's responsibility and the code is simplified a lot. * DPM is dropped. This also simplifies code a lot. Suspend/resume status is port-wide now. * ata_scsi_device_suspend/resume() and ata_dev_ready() removed. * Resume now has to wait for disk to spin up before proceeding. I couldn't find easy way out as libata is in EH waiting for the disk to be ready and sd is waiting for EH to complete to issue START_STOP. * sdev->manage_start_stop is set to 1 in ata_scsi_slave_config(). This fixes spindown on shutdown and suspend-to-disk. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-04-28pata: cable methodsAlan Cox
Versus upstream as requested Last of the trivial switches to cable_detect methods. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-03-02libata: add missing CONFIG_PM in LLDsTejun Heo
Add missing #ifdef CONFIG_PM conditionals around all PM related parts in libata LLDs. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-09libata: add another IRQ calls (libata drivers)Akira Iguchi
This patch is against each libata driver. Two IRQ calls are added in ata_port_operations. - irq_on() is used to enable interrupts. - irq_ack() is used to acknowledge a device interrupt. In most drivers, ata_irq_on() and ata_irq_ack() are used for irq_on and irq_ack respectively. In some drivers (ex: ahci, sata_sil24) which cannot use them as is, ata_dummy_irq_on() and ata_dummy_irq_ack() are used. Signed-off-by: Kou Ishizaki <kou.ishizaki@toshiba.co.jp> Signed-off-by: Akira Iguchi <akira2.iguchi@toshiba.co.jp> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-09libata: convert to iomapTejun Heo
Convert libata core layer and LLDs to use iomap. * managed iomap is used. Pointer to pcim_iomap_table() is cached at host->iomap and used through out LLDs. This basically replaces host->mmio_base. * if possible, pcim_iomap_regions() is used Most iomap operation conversions are taken from Jeff Garzik <jgarzik@pobox.com>'s iomap branch. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-09libata: update libata LLDs to use devresTejun Heo
Update libata LLDs to use devres. Core layer is already converted to support managed LLDs. This patch simplifies initialization and fixes many resource related bugs in init failure and detach path. For example, all converted drivers now handle ata_device_add() failure gracefully without excessive resource rollback code. As most resources are released automatically on driver detach, many drivers don't need or can do with much simpler ->{port|host}_stop(). In general, stop callbacks are need iff port or host needs to be given commands to shut it down. Note that freezing is enough in many cases and ports are automatically frozen before being detached. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-12-03[PATCH] libata: kill unnecessary sht->max_sectors initializationsTejun Heo
sht->max_sectors is overrided unconditionally in ->slave_configure. There's no reason to set it to any value. Signed-off-by: Tejun Heo <htejun@gmail.com>
2006-12-01[PATCH] PATA libata: suspend/resume simple casesAlan
This patch adds the suspend/resume callbacks for drivers which don't need any additional help (beyond the pci resume quirk patch I posted earlier anyway). Also bring version numbers back inline with master copies. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-11-29[PATCH] libata: add missing sht->slave_destroyTejun Heo
Many LLDs are missing sht->slave_destroy. The method is mandatory to support device warm unplugging (echo 1 > /sys/.../delete). Without it, libata might access released scsi device. Signed-off-by: Tejun Heo <htejun@gmail.com>
2006-09-28[libata] PCI ID table cleanup in various driversJeff Garzik
* Use PCI_VDEVICE() macro * const-ify pci_device_id table * standardize list terminator as "{ }" * convert spaces to tab in pci_driver struct (Alan-ism) * various minor whitespace cleanups Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-09-27[libata] Don't use old-EH ->eng_timeout() hook when not neededJeff Garzik
The PATA driver set got converted to the new error handling setup, but the old hooks were accidentally left in place. Now, removed. Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-08-31[libata #pata-drivers] Trim trailing whitespace.Jeff Garzik
2006-08-29[libata] Add a bunch of PATA drivers.Jeff Garzik
The vast majority of drivers and changes are from Alan Cox. Albert Lee contributed and maintains pata_pdc2027x. Adrian Bunk, Andrew Morton, and Tejun Heo contributed various minor fixes and updates. Signed-off-by: Jeff Garzik <jeff@garzik.org>
