[ Upstream commit 5f6b0f2d037c8864f20ff15311c695f65eb09db5 ]
The f_CNT register (at the PCI config. address 0x78) is 16-bit, not
8-bit! The bug was there from the very start... :-(
Signed-off-by: Sergey Shtylyov <s.shtylyov@omp.ru>
Fixes: 669a5db411d8 ("[libata] Add a bunch of PATA drivers.")
Cc: stable@vger.kernel.org
Signed-off-by: Damien Le Moal <damien.lemoal@opensource.wdc.com>
commit 8d093e02e898b24c58788b0289e3202317a96d2a upstream.
The HPT371 chip physically has only one channel, the secondary one,
however the primary channel registers do exist! Thus we have to
manually disable the non-existing channel if the BIOS hasn't done this
already. Similarly to the pata_hpt3x2n driver, always disable the
primary channel.
Add SPDX license identifiers to all files which:
- Have no license information of any form
- Have MODULE_LICENCE("GPL*") inside which was used in the initial
scan/conversion to ignore the file
These files fall under the project license, GPL v2 only. The resulting SPDX
license identifier is:
GPL-2.0-only
The new helper returns index of the matching string in an array.
We are going to use it here.
None of these files are actually using any __init type directives
and hence don't need to include <linux/init.h>. Most are just a
left over from __devinit and __cpuinit removal, or simply due to
code getting copied from one driver to the next.
Cc: linux-ide@vger.kernel.org
This patch converts the drivers in drivers/ata/* to use module_pci_driver()
macro which makes the code smaller and a bit simpler.
Cc: Alan Cox <alan@linux.intel.com>
Cc: Jeff Garzik <jgarzik@pobox.com>
Cc: Mikael Pettersson <mikpe@it.uu.se>
Cc: Mark Lord <kernel@teksavvy.com>
Cc: Jeremy Higdon <jeremy@sgi.com>
Commit 40d69ba029c8d5de51aaeb5358999266c482d00a
("pata_hpt{37x|3x2n}: use pr_*(DRV_NAME ...) instead of printk(KERN_* ...)")
used pr_<level>.
Add #define pr_fmt and remove DRV_NAME.
Increment driver version numbers.
Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
Commit ab81a505ae6be069be5b67acd7e1bab3cfb53968 (pata_hpt37x: unify ->pre_reset
methods) neglected to remove the initializer for the prereset() method from
'hpt374_fn1_port_ops' (it's inherited from 'hpt372_port_ops' anyway), as well
as to update the comment in hpt37x_init_one()...
hpt37x_init_one() has a large *if* statement which should really be folded into
the *switch* statement that currently constitutes its *else* branch, reducing
one level of indentation...
... the same as the 'pata_hpt366' driver does.
... in hpt_dma_blacklisted().
The driver clearly tries to limit HPT370[A] to UltraDMA/66 if the PCI clock is
less than 50 MHz but due to cut&paste type mistake this code has no effect...
Fix 12 errors and 15 warnings given by checkpatch.pl:
- *switch* and *case* not on the same indentation level;
- no space between *for*/*switch*/*while* and open parenthesis;
- space between an unary operator and its operand;
- drive blacklist arrays not being *const*;
- spaces before tabs;
- lines over 80 characters.
In addition to these changes, also do the following:
- add new line after variable definitions;
- fix the style of some multi-line comments.
The Marvell bridge chips used on HighPoint SATA cards do not seem to support
the UltraDMA modes 1, 2, and 3 as well as any MWDMA modes; these cards are
based on HPT372/372A/372N/374 chips (judging from the vendor drivers), so
the Linux drivers need to have a mode_filter() method for these chips...
Separate out ata_pci_bmdma_prepare_host() and ata_pci_bmdma_init_one()
from their SFF counterparts. SFF ones no longer try to initialize
BMDMA or set PCI master.
When BMDMA initialization failed or BMDMA was not available for
whatever reason, bmdma_addr was left at zero and used as an indication
that BMDMA shouldn't be used. This leads to the following problems.
p1. For BMDMA drivers which don't use traditional BMDMA register,
ata_bmdma_mode_filter() incorrectly inhibits DMA modes. Those
drivers either have to inherit from ata_sff_port_ops or clear
->mode_filter explicitly.
p2. non-BMDMA drivers call into BMDMA PRD table allocation. It
doesn't actually allocate PRD table if bmdma_addr is not
initialized but is still confusing.
p3. For BMDMA drivers which don't use traditional BMDMA register, some
methods might not be invoked as expected (e.g. bmdma_stop from
ata_sff_post_internal_cmd()).
p4. SFF drivers w/ custom DMA interface implement noop BMDMA ops
worrying libata core might call into one of them.
These problems are caused by the muddy line between SFF and BMDMA and
the assumption that all BMDMA controllers initialize bmdma_addr.
This patch fixes p1 and p2 by removing the bmdma_addr assumption and
moving prd allocation to BMDMA port start. Later patches will fix the
remaining issues.
This patch improves BMDMA initialization such that
* When BMDMA register initialization fails, falls back to PIO instead
of failing. ata_pci_bmdma_init() never fails now.
* When ata_pci_bmdma_init() falls back to PIO, it clears
ap->mwdma_mask and udma_mask instead of depending on
ata_bmdma_mode_filter(). This makes ata_bmdma_mode_filter()
unnecessary thus resolving p1.
* ata_port_start() which actually is BMDMA specific is moved to
ata_bmdma_port_start(). ata_port_start() and ata_sff_port_start()
are killed.
* ata_sff_port_start32() is moved and renamed to
ata_bmdma_port_start32().
Drivers which no longer call into PRD table allocation are...
pdc_adma, sata_inic162x, sata_qstor, sata_sx4, pata_cmd640 and all
drivers which inherit from ata_sff_port_ops.
pata_icside sets ->port_start to ATA_OP_NULL as it doesn't need PRD
but is a BMDMA controller and doesn't have custom port_start like
other such controllers.
Note that with the previous patch which makes all and only BMDMA
drivers inherit from ata_bmdma_port_ops, this change doesn't break
drivers which need PRD table.
This allows parallel scan and the like to be set without having to stop
using the existing full helper functions. This patch merely adds the argument
and fixes up the callers. It doesn't undo the special cases already in the
tree or add any new parallel callers.
Signed-off-by: Alan Cox <alan@linux.intel.com>
Describe UDMA timing bits 18-20 and 21 separately; add a note to bit
31 about it being meaningful for PIO only. Reformat the whole comment,
while at it...
As these drivers' set_piomode() and set_dmamode() methods are almost
identical, factor out the common hpt{37x|3x2n}_set_mode() function
to be called by both of them, the same as in 'pata_hpt366' driver.
This results in ~5% decrease in the 'pata_hpt37x' driver binary
size and in ~4% decrease in the 'pata_hpt3x2n' driver binary size
(as measured on x86-32).
Use ATA_DMA_* constants instead of the bare numbers for the BMIDE registers.
Some places were using PCI_CLASS_REVISION instead of PCI_REVISION_ID, so
they weren't converted by commit 44c10138fd4bbc4b6d6bff0873c24902f2a9da65
(PCI: Change all drivers to use pci_device->revision).
These drivers inherited from the older 'hpt366' IDE driver the buggy timing
register masks in their set_piomode() metods. As a result, too low command
cycle active time is programmed for slow PIO modes. Quite fortunately, it's
later "fixed up" by the set_dmamode() methods which also "helpfully" reprogram
the command timings, usually to PIO mode 4; unfortunately, setting an UltraDMA
mode #N also reprograms already set PIO data timings, usually to MWDMA mode #
max(N, 2) timings...
However, the drivers added some breakage of their own too: the bit that they
set/clear to control the FIFO is sometimes wrong -- it's actually the MSB of
the command cycle setup time; also, setting it in DMA mode is wrong as this
bit is only for PIO actually and clearing it for PIO modes is not needed as
no mode in any timing table has it set...
Fix all this, inverting the masks while at it, like in the 'hpt366' and
'pata_hpt366' drivers; bump the drivers' versions, accounting for recent
patches that forgot to do it...
Cc: stable@kernel.org
Alan Cox reported that cable detection sometimes works unreliably
for HPT3xxN and that the issue is fixed by adding debounce delay
as used by the vendor driver.
Sergei Shtylyov also noticed that debounce delay is needed for all
HPT37x and HPT3xxN chipsets according to vendor drivers.
Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
We can use the same ->pre_reset method for all HPT37x chipsets now.
A comment fix in drivers/ata/pata_hpt37x.c.
Signed-off-by: Krzysztof Ha³asa <khc@pm.waw.pl>
The libata driver has copied the code from the IDE driver which caused a post
2.4.18 regression on many HPT370[A] chips -- DMA stopped to work completely,
only causing timeouts. Now remove hpt370_bmdma_start() for good...
No functional changes in this patch.
Signed-off-by: Erik Inge Bolsø <knan-lkml@anduin.net>
SFF functions have confusing names. Some have sff prefix, some have
bmdma, some std, some pci and some none. Unify the naming by...
* SFF functions which are common to both BMDMA and non-BMDMA are
prefixed with ata_sff_.
* SFF functions which are specific to BMDMA are prefixed with
ata_bmdma_.
* SFF functions which are specific to PCI but apply to both BMDMA and
non-BMDMA are prefixed with ata_pci_sff_.
* SFF functions which are specific to PCI and BMDMA are prefixed with
ata_pci_bmdma_.
* Drop generic prefixes from LLD specific routines. For example,
bfin_std_dev_select -> bfin_dev_select.
The following renames are noteworthy.
ata_qc_issue_prot() -> ata_sff_qc_issue()
ata_pci_default_filter() -> ata_bmdma_mode_filter()
ata_dev_try_classify() -> ata_sff_dev_classify()
This rename is in preparation of separating SFF support out of libata
core layer. This patch strictly renames functions and doesn't
introduce any behavior difference.
Signed-off-by: Tejun Heo <htejun@gmail.com>
Currently reset methods are not specified directly in the
ata_port_operations table. If a LLD wants to use custom reset
methods, it should construct and use a error_handler which uses those
reset methods. It's done this way for two reasons.
First, the ops table already contained too many methods and adding
four more of them would noticeably increase the amount of necessary
boilerplate code all over low level drivers.
Second, as ->error_handler uses those reset methods, it can get
confusing. ie. By overriding ->error_handler, those reset ops can be
made useless making layering a bit hazy.
Now that ops table uses inheritance, the first problem doesn't exist
anymore. The second isn't completely solved but is relieved by
providing default values - most drivers can just override what it has
implemented and don't have to concern itself about higher level
callbacks. In fact, there currently is no driver which actually
modifies error handling behavior. Drivers which override
->error_handler just wraps the standard error handler only to prepare
the controller for EH. I don't think making ops layering strict has
any noticeable benefit.
This patch makes ->prereset, ->softreset, ->hardreset, ->postreset and
their PMP counterparts propoer ops. Default ops are provided in the
base ops tables and drivers are converted to override individual reset
methods instead of creating custom error_handler.
* ata_std_error_handler() doesn't use sata_std_hardreset() if SCRs
aren't accessible. sata_promise doesn't need to use separate
error_handlers for PATA and SATA anymore.
* softreset is broken for sata_inic162x and sata_sx4. As libata now
always prefers hardreset, this doesn't really matter but the ops are
forced to NULL using ATA_OP_NULL for documentation purpose.
* pata_hpt374 needs to use different prereset for the first and second
PCI functions. This used to be done by branching from
hpt374_error_handler(). The proper way to do this is to use
separate ops and port_info tables for each function. Converted.
port_info->private_data is currently used for two purposes - to record
private data about the port_info or to specify host->private_data to
use when allocating ata_host.
This overloading is confusing and counter-intuitive in that
port_info->private_data becomes host->private_data instead of
port->private_data. In addition, port_info and host don't correspond
to each other 1-to-1. Currently, the first non-NULL
port_info->private_data is used.
This patch makes port_info->private_data just be what it is -
private_data for the port_info where LLD can jot down extra info.
libata no longer sets host->private_data to the first non-NULL
port_info->private_data, @host_priv argument is added to
ata_pci_init_one() instead. LLDs which use ata_pci_init_one() can use
this argument to pass in pointer to host private data. LLDs which
don't should use init-register model anyway and can initialize
host->private_data directly.
Adding @host_priv instead of using init-register model for LLDs which
use ata_pci_init_one() is suggested by Alan Cox.
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
ata_pci_init_one() is the only function which uses ops->irq_handler
and pi->sht. Other initialization functions take the same information
as arguments. This causes confusion and duplicate unused entries in
structures.
Make ata_pci_init_one() take sht as an argument and use ata_interrupt
implicitly. All current users use ata_interrupt and if different irq
handler is necessary open coding ata_pci_init_one() using
ata_prepare_sff_host() and ata_activate_sff_host can be done under ten
lines including error handling and driver which requires custom
interrupt handler is likely to require custom initialization anyway.
As ata_pci_init_one() was the last user of ops->irq_handler, this
patch also kills the field.
libata lets low level drivers build ata_port_operations table and
register it with libata core layer. This allows low level drivers
high level of flexibility but also burdens them with lots of
boilerplate entries.
This becomes worse for drivers which support related similar
controllers which differ slightly. They share most of the operations
except for a few. However, the driver still needs to list all
operations for each variant. This results in large number of
duplicate entries, which is not only inefficient but also error-prone
as it becomes very difficult to tell what the actual differences are.
This duplicate boilerplates all over the low level drivers also make
updating the core layer exteremely difficult and error-prone. When
compounded with multi-branched development model, it ends up
accumulating inconsistencies over time. Some of those inconsistencies
cause immediate problems and fixed. Others just remain there dormant
making maintenance increasingly difficult.
To rectify the problem, this patch implements ata_port_operations
inheritance. To allow LLDs to easily re-use their own ops tables
overriding only specific methods, this patch implements poor man's
class inheritance. An ops table has ->inherits field which can be set
to any ops table as long as it doesn't create a loop. When the host
is started, the inheritance chain is followed and any operation which
isn't specified is taken from the nearest ancestor which has it
specified. This operation is called finalization and done only once
per an ops table and the LLD doesn't have to do anything special about
it other than making the ops table non-const such that libata can
update it.
libata provides four base ops tables lower drivers can inherit from -
base, sata, pmp, sff and bmdma. To avoid overriding these ops
accidentaly, these ops are declared const and LLDs should always
inherit these instead of using them directly.
After finalization, all the ops table are identical before and after
the patch except for setting .irq_handler to ata_interrupt in drivers
which didn't use to. The .irq_handler doesn't have any actual effect
and the field will soon be removed by later patch.
* sata_sx4 is still using old style EH and currently doesn't take
advantage of ops inheritance.
libata lets low level drivers build scsi_host_template and register it
to the SCSI layer. This allows low level drivers high level of
flexibility but also burdens them with lots of boilerplate entries.
This patch implements SHT initializers which can be used to initialize
all the boilerplate entries in a sht. Three variants of them are
implemented - BASE, BMDMA and NCQ - for different types of drivers.
Note that entries can be overriden by putting individual initializers
after the helper macro.
All sht tables are identical before and after this patch.
PCI device should be powered up or powered up before its PCI regsiters
are accessed. Although PCI configuration register access is allowed
in D3hot, PCI device is free to reset its status when transiting from
D3hot to D0 causing configuration data to change.
Many libata SFF drivers which use ata_pci_init_one() read and update
configuration registers before calling ata_pci_init_one() which
enables the PCI device. Also, in resume paths, some drivers access
registers without resuming the PCI device.
This patch adds a call to pcim_enable_device() in init path if
register is accessed before calling ata_pci_init_one() and make resume
paths first resume PCI devices, access PCI configuration regiters then
resume ATA host.
While at it...
* cmd640 was strange in that it set ->resume even when CONFIG_PM is
not. This is by-product of minimal build fix. Updated.
* In cs5530, Don't BUG() on reinit failure. Just whine and fail
resume.
When masking, mask out the modes that are unsupported not the ones
that are supported. This makes life happier.
Signed-off-by: Alan Cox <alan@redhat.com>
Signed-off-by: Jeff Garzik <jeff@garzik.org>
WARNING: line over 80 characters
#70: FILE: drivers/ata/pata_hpt37x.c:850:
+ struct pci_dev *pdev_0 = pci_get_slot(pdev->bus, pdev->devfn - 1);
ERROR: else should follow close brace '}'
#78: FILE: drivers/ata/pata_hpt37x.c:858:
+ else
total: 1 errors, 1 warnings, 100 lines checked
Your patch has style problems, please review. If any of these errors
are false positives report them to the maintainer, see
CHECKPATCH in MAINTAINERS.
Please run checkpatch prior to sending patches
Bug #9261
- Read frequency correctly
- Correct cable detect handling
- Fix wrong filter test
This avoids allocating DMA buffers if not needed but at the moment is
mostly just a neatness item.
It was always set to ata_port_disable(). Removed the hook, and replaced
the very few ap->ops->port_disable() callsites with direct calls to
ata_port_disable().
* ->irq_ack() is redundant to what the irq handler already
performs... chk-status + irq-clear. Furthermore, it is only
called in one place, when screaming-irq-debugging is enabled,
so we don't want to bother with a hook just for that.
* ata_dummy_irq_on() is only ever used in drivers that have
no callpath reaching ->irq_on(). Remove .irq_on hook from
those drivers, and the now-unused ata_dummy_irq_on()
Make reset methods and related functions deal with ata_link instead of
ata_port.
* ata_do_reset()
* ata_eh_reset()
* all prereset/reset/postreset methods and related functions
This patch introduces no behavior change.
Fix several inconsistencies in these drivers WRT reporting the clocks:
- when using DPLL mode, 'pata_hpt37x' driver reported the DPLL frequency as the
PCI clock -- make it properly report both clocks and add the same ability to
the 'pata_hpt3x2n' driver;
- both drivers sometimes use "pata_hpt3*:" and sometimes "hpt3*:" in the
messages -- make them use only the former one;
- the message about failed DPLL stablizatios deserves KERN_ERR and a bang. :-)
The DPLL tuning code always set up it for 66 MHz due to wrong UltraDMA mask
including mode 5 used to check for the necessity of 66 MHz clocking -- this
caused 66 MHz clock to be used for HPT374 chip that does not tolerate it.
While fixing this, also remove PLL mode from the TODO list -- I don't think
it's still a relevant item.
Just one version of Linux ago
The PLL code broke - oh no!
But set the right mode
And fix up the code
Makes the PLL timing sync go
[whatever happened to the sailor from Nantucket, hero of many limericks? -jg]
Closes-bug: #8791
The ATA_UDMAx masks are self-documenting, and far better than manually
writing in the hex mask.
Note that pata_it8213 mask differed from the comment. Added a FIXME there.
This flag only has meaning in old-EH drivers, and these drivers have
already been converted to the new EH. Remove.
Propogate change from drivers/ide
