path: root/drivers/ata/pata_ixp4xx_cf.c
2011-07-23ata: Add and use ata_print_version_onceJoe Perches
Use a single mechanism to show driver version. Reduces text a tiny bit too. Remove uses of static int printed_version Add and use ata_print_version(const struct device *, const char *ver) and ata_print_version_once. $ size drivers/ata/built-in.* text data bss dec hex filename 544969 73893 116584 735446 b38d6 drivers/ata/built-in.allyesconfig.ata.o 543870 73893 116592 734355 b34ad drivers/ata/built-in.allyesconfig.print_once.o 141328 14689 4220 160237 271ed drivers/ata/built-in.defconfig.ata.o 141212 14689 4220 160121 27179 drivers/ata/built-in.defconfig.print_once.o Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2011-07-23ata: Convert ata_<foo>_printk(KERN_<LEVEL> to ata_<foo>_<level>Joe Perches
Saves text by removing nearly duplicated text format strings by creating ata_<foo>_printk functions and printf extension %pV. ata defconfig size shrinks ~5% (~8KB), allyesconfig ~2.5% (~13KB) Format string duplication comes from: #define ata_link_printk(link, lv, fmt, args...) do { \ if (sata_pmp_attached((link)->ap) || (link)->ap->slave_link) \ printk("%sata%u.%02u: "fmt, lv, (link)->ap->print_id, \ (link)->pmp , ##args); \ else \ printk("%sata%u: "fmt, lv, (link)->ap->print_id , ##args); \ } while(0) Coalesce long formats. $ size drivers/ata/built-in.* text data bss dec hex filename 544969 73893 116584 735446 b38d6 drivers/ata/built-in.allyesconfig.ata.o 558429 73893 117864 750186 b726a drivers/ata/built-in.allyesconfig.dev_level.o 141328 14689 4220 160237 271ed drivers/ata/built-in.defconfig.ata.o 149567 14689 4220 168476 2921c drivers/ata/built-in.defconfig.dev_level.o Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2011-07-23ata: Convert dev_printk(KERN_<LEVEL> to dev_<level>(Joe Perches
Saves a bit of text as the call takes fewer args. Coalesce a few formats. Convert a few bare printks to pr_cont. $ size drivers/ata/built-in.o* text data bss dec hex filename 558429 73893 117864 750186 b726a drivers/ata/built-in.o.allyesconfig.new 559574 73893 117888 751355 b76fb drivers/ata/built-in.o.allyesconfig.old 149567 14689 4220 168476 2921c drivers/ata/built-in.o.defconfig.new 149851 14689 4220 168760 29338 drivers/ata/built-in.o.defconfig.old Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2011-03-29drivers: Final irq namespace conversionThomas Gleixner
Scripted with coccinelle. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-02libata: remove ATA_FLAG_NO_LEGACYSergei Shtylyov
All checks of ATA_FLAG_NO_LEGACY have been removed by the commits c791c30670ea61f19eec390124128bf278e854fe ([libata] minor PCI IDE probe fixes and cleanups) and f0d36efdc624beb3d9e29b9ab9e9537bf0f25d5b (libata: update libata core layer to use devres), so I think it's time to finally get rid of this flag... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2011-03-02libata: remove ATA_FLAG_MMIOSergei Shtylyov
Commit 0d5ff566779f894ca9937231a181eb31e4adff0e (libata: convert to iomap) removed all checks of ATA_FLAG_MMIO but neglected to remove the flag itself. Do it now, at last... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-04-07dma-mapping: replace all DMA_32BIT_MASK macro with DMA_BIT_MASK(32)Yang Hongyang
Replace all DMA_32BIT_MASK macro with DMA_BIT_MASK(32) Signed-off-by: Yang Hongyang<yanghy@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-24[libata] convert drivers to use ata.h mode mask definesErik Inge Bolsø
No functional changes in this patch. Signed-off-by: Erik Inge Bolsø <knan-lkml@anduin.net> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-12-28libata: beef up iteratorsTejun Heo
There currently are the following looping constructs. * __ata_port_for_each_link() for all available links * ata_port_for_each_link() for edge links * ata_link_for_each_dev() for all devices * ata_link_for_each_dev_reverse() for all devices in reverse order Now there's a need for looping construct which is similar to __ata_port_for_each_link() but iterates over PMP links before the host link. Instead of adding another one with long name, do the following cleanup. * Implement and export ata_link_next() and ata_dev_next() which take @mode parameter and can be used to build custom loop. * Implement ata_for_each_link() and ata_for_each_dev() which take looping mode explicitly. The following iteration modes are implemented. * ATA_LITER_EDGE : loop over edge links * ATA_LITER_HOST_FIRST : loop over all links, host link first * ATA_LITER_PMP_FIRST : loop over all links, PMP links first * ATA_DITER_ENABLED : loop over enabled devices * ATA_DITER_ENABLED_REVERSE : loop over enabled devices in reverse order * ATA_DITER_ALL : loop over all devices * ATA_DITER_ALL_REVERSE : loop over all devices in reverse order This change removes exlicit device enabledness checks from many loops and makes it clear which ones are iterated over in which direction. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-07-27[ARM] 5179/1: Replace obsolete IRQT_* and __IRQT_* values with IRQ_TYPE_*Dmitry Baryshkov
IRQT_* and __IRQT_* were obsoleted long ago by patch [3692/1]. Remove them completely. Sed script for the reference: s/__IRQT_RISEDGE/IRQ_TYPE_EDGE_RISING/g s/__IRQT_FALEDGE/IRQ_TYPE_EDGE_FALLING/g s/__IRQT_LOWLVL/IRQ_TYPE_LEVEL_LOW/g s/__IRQT_HIGHLVL/IRQ_TYPE_LEVEL_HIGH/g s/IRQT_RISING/IRQ_TYPE_EDGE_RISING/g s/IRQT_FALLING/IRQ_TYPE_EDGE_FALLING/g s/IRQT_BOTHEDGE/IRQ_TYPE_EDGE_BOTH/g s/IRQT_LOW/IRQ_TYPE_LEVEL_LOW/g s/IRQT_HIGH/IRQ_TYPE_LEVEL_HIGH/g s/IRQT_PROBE/IRQ_TYPE_PROBE/g s/IRQT_NOEDGE/IRQ_TYPE_NONE/g Signed-off-by: Dmitry Baryshkov <dbaryshkov@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-04-25ATA/IDE: fix platform driver hotplug/coldplugKay Sievers
Since 43cc71eed1250755986da4c0f9898f9a635cb3bf, the platform modalias is prefixed with "platform:". Add MODULE_ALIAS() to the hotpluggable ATA and IDE platform drivers, to re-enable auto loading. NOTE: both ata/pata_platform.c and ide/legacy/ide_platform.c claim to provide "the" platform_pata driver, and there's no build-time mutual exclusion mechanism. This means that configs which enable both drivers will make some trouble when hotplugging... [dbrownell@users.sourceforge.net: more drivers, registration fixes] Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Tejun Heo <htejun@gmail.com> Acked-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-17libata: rename SFF port opsTejun Heo
Add sff_ prefix to SFF specific port ops. This rename is in preparation of separating SFF support out of libata core layer. This patch strictly renames ops and doesn't introduce any behavior difference. Signed-off-by: Tejun Heo <htejun@gmail.com>
2008-04-17libata: rename SFF functionsTejun Heo
SFF functions have confusing names. Some have sff prefix, some have bmdma, some std, some pci and some none. Unify the naming by... * SFF functions which are common to both BMDMA and non-BMDMA are prefixed with ata_sff_. * SFF functions which are specific to BMDMA are prefixed with ata_bmdma_. * SFF functions which are specific to PCI but apply to both BMDMA and non-BMDMA are prefixed with ata_pci_sff_. * SFF functions which are specific to PCI and BMDMA are prefixed with ata_pci_bmdma_. * Drop generic prefixes from LLD specific routines. For example, bfin_std_dev_select -> bfin_dev_select. The following renames are noteworthy. ata_qc_issue_prot() -> ata_sff_qc_issue() ata_pci_default_filter() -> ata_bmdma_mode_filter() ata_dev_try_classify() -> ata_sff_dev_classify() This rename is in preparation of separating SFF support out of libata core layer. This patch strictly renames functions and doesn't introduce any behavior difference. Signed-off-by: Tejun Heo <htejun@gmail.com>
2008-04-17libata: implement and use ops inheritanceTejun Heo
libata lets low level drivers build ata_port_operations table and register it with libata core layer. This allows low level drivers high level of flexibility but also burdens them with lots of boilerplate entries. This becomes worse for drivers which support related similar controllers which differ slightly. They share most of the operations except for a few. However, the driver still needs to list all operations for each variant. This results in large number of duplicate entries, which is not only inefficient but also error-prone as it becomes very difficult to tell what the actual differences are. This duplicate boilerplates all over the low level drivers also make updating the core layer exteremely difficult and error-prone. When compounded with multi-branched development model, it ends up accumulating inconsistencies over time. Some of those inconsistencies cause immediate problems and fixed. Others just remain there dormant making maintenance increasingly difficult. To rectify the problem, this patch implements ata_port_operations inheritance. To allow LLDs to easily re-use their own ops tables overriding only specific methods, this patch implements poor man's class inheritance. An ops table has ->inherits field which can be set to any ops table as long as it doesn't create a loop. When the host is started, the inheritance chain is followed and any operation which isn't specified is taken from the nearest ancestor which has it specified. This operation is called finalization and done only once per an ops table and the LLD doesn't have to do anything special about it other than making the ops table non-const such that libata can update it. libata provides four base ops tables lower drivers can inherit from - base, sata, pmp, sff and bmdma. To avoid overriding these ops accidentaly, these ops are declared const and LLDs should always inherit these instead of using them directly. After finalization, all the ops table are identical before and after the patch except for setting .irq_handler to ata_interrupt in drivers which didn't use to. The .irq_handler doesn't have any actual effect and the field will soon be removed by later patch. * sata_sx4 is still using old style EH and currently doesn't take advantage of ops inheritance. Signed-off-by: Tejun Heo <htejun@gmail.com>
2008-04-17libata: implement and use SHT initializersTejun Heo
libata lets low level drivers build scsi_host_template and register it to the SCSI layer. This allows low level drivers high level of flexibility but also burdens them with lots of boilerplate entries. This patch implements SHT initializers which can be used to initialize all the boilerplate entries in a sht. Three variants of them are implemented - BASE, BMDMA and NCQ - for different types of drivers. Note that entries can be overriden by putting individual initializers after the helper macro. All sht tables are identical before and after this patch. Signed-off-by: Tejun Heo <htejun@gmail.com>
2008-04-17libata: normalize port_info, port_operations and sht tablesTejun Heo
Over the time, port info, ops and sht structures developed quite a bit of inconsistencies. This patch updates drivers. * Enable/disable_pm callbacks added to all ahci ops tables. * Every driver for SFF controllers now uses ata_sff_port_start() instead of ata_port_start() unless the driver has custom implementation. * Every driver for SFF controllers now uses ata_pci_default_filter() unless the driver has custom implementation. * Removed an odd port_info->sht initialization from ata_piix.c. Likely a merge byproduct. * A port which has ATA_FLAG_SATA set doesn't need to set cable_detect to ata_cable_sata(). Remove it from via and mv port ops. * Some drivers had unnecessary .max_sectors initialization which is ignored and was missing .slave_destroy callback. Fixed. * Removed unnecessary sht initializations port_info's. * Removed onsolete scsi device suspend/resume callbacks from pata_bf54x. * No reason to set ata_pci_default_filter() and bmdma functions for PIO-only drivers. Remove those callbacks and replace ata_bmdma_irq_clear with ata_noop_irq_clear. * pata_platform sets port_start to ata_dummy_ret0. port_start can just be set to NULL. * sata_fsl supports NCQ but was missing qc_defer. Fixed. * pata_rb600_cf implements dummy port_start. Removed. Signed-off-by: Tejun Heo <htejun@gmail.com>
2008-04-17libata: implement and use ata_noop_irq_clear()Tejun Heo
->irq_clear() is used to clear IRQ bit of a SFF controller and isn't useful for drivers which don't use libata SFF HSM implementation. However, it's a required callback and many drivers implement their own noop version as placeholder. This patch implements ata_noop_irq_clear and use it to replace those custom placeholders. Also, SFF drivers which don't support BMDMA don't need to use ata_bmdma_irq_clear(). It becomes noop if BMDMA address isn't initialized. Convert them to use ata_noop_irq_clear(). Signed-off-by: Tejun Heo <htejun@gmail.com>
2008-01-23libata: update ->data_xfer hook for ATAPITejun Heo
Depending on how many bytes are transferred as a unit, PIO data transfer may consume more bytes than requested. Knowing how much data is consumed is necessary to determine how much is left for draining. This patch update ->data_xfer such that it returns the number of consumed bytes. While at it, it also makes the following changes. * s/adev/dev/ * use READ/WRITE constants for rw indication * misc clean ups Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-01-10pata_ixp4xx_cf: fix compilation introduced by ata_port_desc() conversionRod Whitby
Fixes a compilation error caused by ata_port_desc() conversion (cbcdd87593a1d85c5c4b259945a3a09eee12814d). Signed-off-by: Rod Whitby <rod@whitby.id.au> Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-12libata: implement and use ata_port_desc() to report port configurationTejun Heo
Currently, port configuration reporting has the following problems. * iomapped address is reported instead of raw address * report contains irrelevant fields or lacks necessary fields for non-SFF controllers. * host->irq/irq2 are there just for reporting and hacky. This patch implements and uses ata_port_desc() and ata_port_pbar_desc(). ata_port_desc() is almost identical to ata_ehi_push_desc() except that it takes @ap instead of @ehi, has no locking requirement, can only be used during host initialization and " " is used as separator instead of ", ". ata_port_pbar_desc() is a helper to ease reporting of a PCI BAR or an offsetted address into it. LLD pushes whatever description it wants using the above two functions. The accumulated description is printed on host registration after "[S/P]ATA max MAX_XFERMODE ". SFF init helpers and ata_host_activate() automatically add descriptions for addresses and irq respectively, so only LLDs which isn't standard SFF need to add custom descriptions. In many cases, such controllers need to report different things anyway. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-12[libata] Remove ->port_disable() hookJeff Garzik
It was always set to ata_port_disable(). Removed the hook, and replaced the very few ap->ops->port_disable() callsites with direct calls to ata_port_disable(). Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-12[libata] Remove ->irq_ack() hook, and ata_dummy_irq_on()Jeff Garzik
* ->irq_ack() is redundant to what the irq handler already performs... chk-status + irq-clear. Furthermore, it is only called in one place, when screaming-irq-debugging is enabled, so we don't want to bother with a hook just for that. * ata_dummy_irq_on() is only ever used in drivers that have no callpath reaching ->irq_on(). Remove .irq_on hook from those drivers, and the now-unused ata_dummy_irq_on() Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-12libata-link: linkify config/EH related functionsTejun Heo
Make the following functions deal with ata_link instead of ata_port. * ata_set_mode() * ata_eh_autopsy() and related functions * ata_eh_report() and related functions * suspend/resume related functions * ata_eh_recover() and related functions Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-12libata-link: implement and use link/device iteratorsTejun Heo
Multiple links and different number of devices per link should be considered to iterate over links and devices. This patch implements and uses link and device iterators - ata_port_for_each_link() and ata_link_for_each_dev() - and ata_link_max_devices(). This change makes a lot of functions iterate over only possible devices instead of from dev 0 to dev ATA_MAX_DEVICES. All such changes have been examined and nothing should be broken. While at it, add a separating comment before device helpers to distinguish them better from link helpers and others. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-12libata-link: introduce ata_linkTejun Heo
Introduce ata_link. It abstracts PHY and sits between ata_port and ata_device. This new level of abstraction is necessary to support SATA Port Multiplier, which basically adds a bunch of links (PHYs) to a ATA host port. Fields related to command execution, spd_limit and EH are per-link and thus moved to ata_link. This patch only defines the host link. Multiple link handling will be added later. Also, a lot of ap->link derefences are added but many of them will be removed as each part is converted to deal directly with ata_link instead of ata_port. This patch introduces no behavior change. Signed-off-by: Tejun Heo <htejun@gmail.com> Cc: James Bottomley <James.Bottomley@SteelEye.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-03drivers/ata/pata_ixp4xx_cf.c: ioremap return code checkScott Thompson
Add missing ioremap return checks. Signed-off-by: Scott Thompson <postfail <at> hushmail.com> Acked-by: Tejun Heo <htejun@gmail.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-09[libata] pata_ixp4xx: kill unused varJeff Garzik
Reported by Michael-Luke Jones. Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-09[libata] pata_ixp4xx: convert to new EHAlessandro Zummo
2007-07-09[libata] drivers: remove 'void __iomem *' casts from pre-iomap daysJeff Garzik
2007-05-21libata: bump versionsJeff Garzik
2007-05-11libata: reimplement suspend/resume support using sdev->manage_start_stopTejun Heo
Reimplement suspend/resume support using sdev->manage_start_stop. * Device suspend/resume is now SCSI layer's responsibility and the code is simplified a lot. * DPM is dropped. This also simplifies code a lot. Suspend/resume status is port-wide now. * ata_scsi_device_suspend/resume() and ata_dev_ready() removed. * Resume now has to wait for disk to spin up before proceeding. I couldn't find easy way out as libata is in EH waiting for the disk to be ready and sd is waiting for EH to complete to issue START_STOP. * sdev->manage_start_stop is set to 1 in ata_scsi_slave_config(). This fixes spindown on shutdown and suspend-to-disk. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-04-28libata: convert the remaining PATA drivers to new init modelTejun Heo
Convert pdc_adma, pata_cs5520, pata_isapnp, pata_ixp4xx_cf, pata_legacy, pata_mpc52xx, pata_mpiix, pata_pcmcia, pata_pdc2027x, pata_platform, pata_qdi, pata_scc and pata_winbond to new init model. * init_one()'s now follow more consistent init order * cs5520 now registers one host with two ports, not two hosts. If any of the two ports are disabled, it's made dummy as other drivers do. Tested pdc_adma and pata_legacy. Both are as broken as before. The rest are compile tested only. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-04-28[libata] More PATA driver ->cable_detect supportJeff Garzik
Roll-up of ->cable_detect feature addition patches, authored and signed-off-by Alan Cox. Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-03-19pata_ixp4xx_cf: fix interruptAlessandro Zummo
As per compact flash specifications, the default irq mode upon cf insertion is pulse mode. this patch fixes the driver to cope with that. Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-03-19pata_ixp4xx_cf: fix oops on detachTejun Heo
pata_ixp4xx_cf dodged dont-clear-drvdata-in-LLD bombing run as it used platform_set_drvdata() instead of dev_set_drvdata(). This causes OOPS on devres host release. Kill it. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-26[libata] bump versionsJeff Garzik
Bump versions based on changes submitted during 2.6.21 merge window. Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-21pata_ixp4xx: Fix up set_mode() function and display Configured for PIO infoAlan
Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-09libata: add another IRQ calls (libata drivers)Akira Iguchi
This patch is against each libata driver. Two IRQ calls are added in ata_port_operations. - irq_on() is used to enable interrupts. - irq_ack() is used to acknowledge a device interrupt. In most drivers, ata_irq_on() and ata_irq_ack() are used for irq_on and irq_ack respectively. In some drivers (ex: ahci, sata_sil24) which cannot use them as is, ata_dummy_irq_on() and ata_dummy_irq_ack() are used. Signed-off-by: Kou Ishizaki <kou.ishizaki@toshiba.co.jp> Signed-off-by: Akira Iguchi <akira2.iguchi@toshiba.co.jp> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-09libata: convert to iomapTejun Heo
Convert libata core layer and LLDs to use iomap. * managed iomap is used. Pointer to pcim_iomap_table() is cached at host->iomap and used through out LLDs. This basically replaces host->mmio_base. * if possible, pcim_iomap_regions() is used Most iomap operation conversions are taken from Jeff Garzik <jgarzik@pobox.com>'s iomap branch. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-09libata: update libata LLDs to use devresTejun Heo
Update libata LLDs to use devres. Core layer is already converted to support managed LLDs. This patch simplifies initialization and fixes many resource related bugs in init failure and detach path. For example, all converted drivers now handle ata_device_add() failure gracefully without excessive resource rollback code. As most resources are released automatically on driver detach, many drivers don't need or can do with much simpler ->{port|host}_stop(). In general, stop callbacks are need iff port or host needs to be given commands to shut it down. Note that freezing is enough in many cases and ports are automatically frozen before being detached. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-01-24libata: set_mode, Fix the FIXMEAlan
When set_mode() changed ->set_mode didn't adapt. This makes the needed changes and removes the relevant FIXME case. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-12-03[PATCH] libata: kill unnecessary sht->max_sectors initializationsTejun Heo
sht->max_sectors is overrided unconditionally in ->slave_configure. There's no reason to set it to any value. Signed-off-by: Tejun Heo <htejun@gmail.com>
2006-12-03[PATCH] libata: add missing sht->slave_destroyTejun Heo
Add missing sht->slave_destroy. Most drivers received this fix in didn't. Fix those four drives. Signed-off-by: Tejun Heo <htejun@gmail.com>
2006-12-01[libata] ARM: add ixp4xx PATA driverAlessandro Zummo
