path: root/drivers/ata/pata_legacy.c
2011-07-23ata: Convert ata_<foo>_printk(KERN_<LEVEL> to ata_<foo>_<level>Joe Perches
Saves text by removing nearly duplicated text format strings by creating ata_<foo>_printk functions and printf extension %pV. ata defconfig size shrinks ~5% (~8KB), allyesconfig ~2.5% (~13KB) Format string duplication comes from: #define ata_link_printk(link, lv, fmt, args...) do { \ if (sata_pmp_attached((link)->ap) || (link)->ap->slave_link) \ printk("%sata%u.%02u: "fmt, lv, (link)->ap->print_id, \ (link)->pmp , ##args); \ else \ printk("%sata%u: "fmt, lv, (link)->ap->print_id , ##args); \ } while(0) Coalesce long formats. $ size drivers/ata/built-in.* text data bss dec hex filename 544969 73893 116584 735446 b38d6 drivers/ata/built-in.allyesconfig.ata.o 558429 73893 117864 750186 b726a drivers/ata/built-in.allyesconfig.dev_level.o 141328 14689 4220 160237 271ed drivers/ata/built-in.defconfig.ata.o 149567 14689 4220 168476 2921c drivers/ata/built-in.defconfig.dev_level.o Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2010-11-12pata_legacy: fix CONFIG_PATA_WINBOND_VLB_MODULE testTejun Heo
pata_legacy is incorrectly testing PATA_WINBOND_VLB_MODULE instead of CONFIG_PATA_WINBOND_VLB_MODULE. Fix it. Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: "Robert P. J. Day" <rpjday@crashcourse.ca> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-08-25libata: remove no longer needed pata_winbond driverBartlomiej Zolnierkiewicz
Winbond W83759A controller is fully supported by pata_legacy driver so remove no longer needed pata_winbond driver. Leave PATA_WINBOND_VLB config option for compatibility reasons and teach pata_legacy to preserve the old behavior of pata_winbond driver. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-12-03pata_legacy: add pointers to QDI65x0 documentationBartlomiej Zolnierkiewicz
2009-12-03pata_legacy: fix access to control register for QDI6580Bartlomiej Zolnierkiewicz
We need to mask out the port offset from the port number cached in ld_qdi->timing. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-12-03pata_legacy: fix QDI6580DP supportBartlomiej Zolnierkiewicz
Dual port QDI6580 has shared PIO timings for master/slave devices so it needs to use custom ->qc_issue method. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-06-05pata_legacy: wait for async probingJames Bottomley
The basic problem here that pata_legacy attaches the host, sees if it found any devices and detaches it if none were found. With async probing, it's not waiting until discovery is finished before deciding it has no devices and trying the detach leading to this warning: ata1: PATA max PIO4 cmd 0x1f0 ctl 0x3f6 irq 14 ------------[ cut here ]------------ WARNING: at drivers/ata/libata-core.c:6222 ata_host_detach+0x75/0x90() Modules linked in: Pid: 1, comm: swapper Not tainted 2.6.30-rc7 #1 Call Trace: [<c01fbb05>] ? ata_host_detach+0x75/0x90 [<c01fbb05>] ? ata_host_detach+0x75/0x90 [<c01139b5>] ? warn_slowpath_common+0x45/0x80 [<c01139fa>] ? warn_slowpath_null+0xa/0x10 [<c01fbb05>] ? ata_host_detach+0x75/0x90 [<c02f40e0>] ? legacy_init+0x44e/0x87f [<c02f3c92>] ? legacy_init+0x0/0x87f [<c0101021>] ? _stext+0x21/0x140 [<c01890ff>] ? proc_register+0x2f/0x190 [<c018938c>] ? create_proc_entry+0x5c/0xc0 [<c0135ebe>] ? register_irq_proc+0x6e/0x90 [<c02e6484>] ? kernel_init+0x6e/0xbf [<c02e6416>] ? kernel_init+0x0/0xbf [<c01031d7>] ? kernel_thread_helper+0x7/0x10 ---[ end trace ef1ee36e873ae3a0 ]--- Because it detaches before the probe is complete. One way to fix it would be to put an async_synchronize_full() before looking for devices, which this patch does. A better way might be to separate libata into its own domain and only wait for that. Reported-by: Mikael Pettersson <mikpe@it.uu.se> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-04-17[libata] fix build error on drivers/ata/pata_legacy.cZhenwen Xu
fix those errors: drivers/ata/pata_legacy.c: In function ‘pdc_data_xfer_vlb’: drivers/ata/pata_legacy.c:289: error: ‘ap’ undeclared (first use in this function) drivers/ata/pata_legacy.c:289: error: (Each undeclared identifier is reported only once drivers/ata/pata_legacy.c:289: error: for each function it appears in.) drivers/ata/pata_legacy.c: At top level: drivers/ata/pata_legacy.c:869: error: ‘ATA_PFLAG_PIO32_CHANGE’ undeclared here (not in a +function) make[2]: *** [drivers/ata/pata_legacy.o] Error 1 make[1]: *** [drivers/ata] Error 2 Signed-off-by: Zhenwen Xu <helight.xu@gmail.com> Acked-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-04-16ata: Report 16/32bit PIO as best we canAlan Cox
The legacy old IDE ioctl API for this is a bit primitive so we try and map stuff sensibly onto it. - Set PIO over DMA devices to report 32bit - Add ability to change the PIO32 settings if the controller permits it - Add that functionality into the sff drivers - Add that functionality into the VLB legacy driver - Turn on the 32bit PIO on the ninja32 and add support there Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-04-16pata_legacy: fix no device fail pathTejun Heo
When pata_legacy can't detect any device, it unregisters the platform_device and fails detection. However, it forgets to detach ata host triggering weird failures as the host later gets freed by devres while still attached. Fix it. Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-03-24[libata] convert drivers to use ata.h mode mask definesErik Inge Bolsø
No functional changes in this patch. Signed-off-by: Erik Inge Bolsø <knan-lkml@anduin.net> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-02-25[libata] pata_legacy: for VLB 32bit PIO don't try tricks with slopAlan Cox
These devices are generally used with ATA anyway and it seems that some ATAPI will need us to issue the right number of words. Therefore as we can't switch mid burst on VLB devices we should only use 32bit I/O for suitable block sizes. Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-12-28[libata] Update kernel-doc comments to match source codeQinghuang Feng
Signed-off-by: Qinghuang Feng <qhfeng.kernel@gmail.com>
2008-12-28libata: beef up iteratorsTejun Heo
There currently are the following looping constructs. * __ata_port_for_each_link() for all available links * ata_port_for_each_link() for edge links * ata_link_for_each_dev() for all devices * ata_link_for_each_dev_reverse() for all devices in reverse order Now there's a need for looping construct which is similar to __ata_port_for_each_link() but iterates over PMP links before the host link. Instead of adding another one with long name, do the following cleanup. * Implement and export ata_link_next() and ata_dev_next() which take @mode parameter and can be used to build custom loop. * Implement ata_for_each_link() and ata_for_each_dev() which take looping mode explicitly. The following iteration modes are implemented. * ATA_LITER_EDGE : loop over edge links * ATA_LITER_HOST_FIRST : loop over all links, host link first * ATA_LITER_PMP_FIRST : loop over all links, PMP links first * ATA_DITER_ENABLED : loop over enabled devices * ATA_DITER_ENABLED_REVERSE : loop over enabled devices in reverse order * ATA_DITER_ALL : loop over all devices * ATA_DITER_ALL_REVERSE : loop over all devices in reverse order This change removes exlicit device enabledness checks from many loops and makes it clear which ones are iterated over in which direction. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-10-27ata: Switch all my stuff to a common addressAlan Cox
2008-07-14ata: endianness annotations in pata driversHarvey Harrison
drivers/ata/pata_qdi.c:142:9: warning: incorrect type in assignment (different base types) drivers/ata/pata_qdi.c:142:9: expected unsigned int [unsigned] [usertype] pad drivers/ata/pata_qdi.c:142:9: got restricted __le32 [usertype] <noident> drivers/ata/pata_qdi.c:146:15: warning: cast to restricted __le32 drivers/ata/pata_winbond.c:110:9: warning: incorrect type in assignment (different base types) drivers/ata/pata_winbond.c:110:9: expected unsigned int [unsigned] [usertype] pad drivers/ata/pata_winbond.c:110:9: got restricted __le32 [usertype] <noident> drivers/ata/pata_winbond.c:114:15: warning: cast to restricted __le32 drivers/ata/pata_legacy.c:310:9: warning: incorrect type in assignment (different base types) drivers/ata/pata_legacy.c:310:9: expected unsigned int [unsigned] [usertype] pad drivers/ata/pata_legacy.c:310:9: got restricted __le32 [usertype] <noident> drivers/ata/pata_legacy.c:314:15: warning: cast to restricted __le32 drivers/ata/pata_legacy.c:752:11: warning: cast to restricted __le32 drivers/ata/pata_legacy.c:756:9: warning: incorrect type in assignment (different base types) drivers/ata/pata_legacy.c:756:9: expected unsigned int [unsigned] [addressable] [assigned] [usertype] pad drivers/ata/pata_legacy.c:756:9: got restricted __le32 [usertype] <noident> Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-05-19ata: remove FIT() macroHarvey Harrison
Use the kernel-provided clamp_val() macro. FIT was always applied to a member of struct ata_timing (unsigned short) and two constants. clamp_val will not cast to short anymore. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: Jeff Garzik <jeff@garzik.org> Cc: Tejun Heo <htejun@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-17libata: rename SFF port opsTejun Heo
Add sff_ prefix to SFF specific port ops. This rename is in preparation of separating SFF support out of libata core layer. This patch strictly renames ops and doesn't introduce any behavior difference. Signed-off-by: Tejun Heo <htejun@gmail.com>
2008-04-17libata: rename SFF functionsTejun Heo
SFF functions have confusing names. Some have sff prefix, some have bmdma, some std, some pci and some none. Unify the naming by... * SFF functions which are common to both BMDMA and non-BMDMA are prefixed with ata_sff_. * SFF functions which are specific to BMDMA are prefixed with ata_bmdma_. * SFF functions which are specific to PCI but apply to both BMDMA and non-BMDMA are prefixed with ata_pci_sff_. * SFF functions which are specific to PCI and BMDMA are prefixed with ata_pci_bmdma_. * Drop generic prefixes from LLD specific routines. For example, bfin_std_dev_select -> bfin_dev_select. The following renames are noteworthy. ata_qc_issue_prot() -> ata_sff_qc_issue() ata_pci_default_filter() -> ata_bmdma_mode_filter() ata_dev_try_classify() -> ata_sff_dev_classify() This rename is in preparation of separating SFF support out of libata core layer. This patch strictly renames functions and doesn't introduce any behavior difference. Signed-off-by: Tejun Heo <htejun@gmail.com>
2008-04-17libata: implement and use ops inheritanceTejun Heo
libata lets low level drivers build ata_port_operations table and register it with libata core layer. This allows low level drivers high level of flexibility but also burdens them with lots of boilerplate entries. This becomes worse for drivers which support related similar controllers which differ slightly. They share most of the operations except for a few. However, the driver still needs to list all operations for each variant. This results in large number of duplicate entries, which is not only inefficient but also error-prone as it becomes very difficult to tell what the actual differences are. This duplicate boilerplates all over the low level drivers also make updating the core layer exteremely difficult and error-prone. When compounded with multi-branched development model, it ends up accumulating inconsistencies over time. Some of those inconsistencies cause immediate problems and fixed. Others just remain there dormant making maintenance increasingly difficult. To rectify the problem, this patch implements ata_port_operations inheritance. To allow LLDs to easily re-use their own ops tables overriding only specific methods, this patch implements poor man's class inheritance. An ops table has ->inherits field which can be set to any ops table as long as it doesn't create a loop. When the host is started, the inheritance chain is followed and any operation which isn't specified is taken from the nearest ancestor which has it specified. This operation is called finalization and done only once per an ops table and the LLD doesn't have to do anything special about it other than making the ops table non-const such that libata can update it. libata provides four base ops tables lower drivers can inherit from - base, sata, pmp, sff and bmdma. To avoid overriding these ops accidentaly, these ops are declared const and LLDs should always inherit these instead of using them directly. After finalization, all the ops table are identical before and after the patch except for setting .irq_handler to ata_interrupt in drivers which didn't use to. The .irq_handler doesn't have any actual effect and the field will soon be removed by later patch. * sata_sx4 is still using old style EH and currently doesn't take advantage of ops inheritance. Signed-off-by: Tejun Heo <htejun@gmail.com>
2008-04-17libata: implement and use SHT initializersTejun Heo
libata lets low level drivers build scsi_host_template and register it to the SCSI layer. This allows low level drivers high level of flexibility but also burdens them with lots of boilerplate entries. This patch implements SHT initializers which can be used to initialize all the boilerplate entries in a sht. Three variants of them are implemented - BASE, BMDMA and NCQ - for different types of drivers. Note that entries can be overriden by putting individual initializers after the helper macro. All sht tables are identical before and after this patch. Signed-off-by: Tejun Heo <htejun@gmail.com>
2008-04-17libata: implement and use ata_noop_irq_clear()Tejun Heo
->irq_clear() is used to clear IRQ bit of a SFF controller and isn't useful for drivers which don't use libata SFF HSM implementation. However, it's a required callback and many drivers implement their own noop version as placeholder. This patch implements ata_noop_irq_clear and use it to replace those custom placeholders. Also, SFF drivers which don't support BMDMA don't need to use ata_bmdma_irq_clear(). It becomes noop if BMDMA address isn't initialized. Convert them to use ata_noop_irq_clear(). Signed-off-by: Tejun Heo <htejun@gmail.com>
2008-02-20ata: fix sparse warnings in pata_legacy.cHarvey Harrison
Use ld_qdi and ld_winbond to avoid shadowing static int variables qdi and winbond. The ld_ prefix refers to legacy_data. drivers/ata/pata_legacy.c:777:21: warning: symbol 'qdi' shadows an earlier one drivers/ata/pata_legacy.c:128:12: originally declared here drivers/ata/pata_legacy.c:811:21: warning: symbol 'qdi' shadows an earlier one drivers/ata/pata_legacy.c:128:12: originally declared here drivers/ata/pata_legacy.c:848:21: warning: symbol 'qdi' shadows an earlier one drivers/ata/pata_legacy.c:128:12: originally declared here drivers/ata/pata_legacy.c:882:21: warning: symbol 'qdi' shadows an earlier one drivers/ata/pata_legacy.c:128:12: originally declared here drivers/ata/pata_legacy.c:1040:21: warning: symbol 'winbond' shadows an earlier one drivers/ata/pata_legacy.c:129:12: originally declared here Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-02-15pata_legacy: don't call ata_host_detach() after initialization failureTejun Heo
ata_host_detach() detaches an attached port and shouldn't be called on a port which hasn't been attached yet. pata_legacy incorrectly calls ata_host_detach() on unattached port after initialization failure causing oops. Fix it. Signed-off-by: Tejun Heo <htejun@gmail.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Ingo Molnar <mingo@elte.hu> Cc: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-02-11pata_legacy: typo fixAlan Cox
Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-01-23pata_legacy: Merge winbond supportAlan Cox
This puts winbond VLB in with the other ISA/VLB support and means we can lose pata_winbond.c. With all the VLB/ISA probe in one space (and out of the core libata) this makes legacy probing work sanely. Also switch to devm_ for resource handling on the ports post probe Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-01-23pata_legacy: resychronize with upstream changes and resubmitAlan Cox
Update the legacy driver so it can handle VLB ports nicely, and has an internal structure for nailing new ISA/VLB forms in. Anyone got an ALI14xx and a spare day ;) Also adds an "all" parameter so you can load this driver after all the PCI ones in a boot time kernel and tell it to grab anything ST412 compatible even if it is an unknown PCI device. That allows libata to offer the same "just get me a disk somehow" fallback that old IDE did. Obsoletes pata_qdi. Signed-off-by: Alan Cox <alan@redhat.com> Cc: Tejun Heo <htejun@gmail.com> Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-01-23[libata] pata_legacy: typo fixAndrew Morton
Cc: Jeff Garzik <jeff@garzik.org> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-01-23libata: update ->data_xfer hook for ATAPITejun Heo
Depending on how many bytes are transferred as a unit, PIO data transfer may consume more bytes than requested. Knowing how much data is consumed is necessary to determine how much is left for draining. This patch update ->data_xfer such that it returns the number of consumed bytes. While at it, it also makes the following changes. * s/adev/dev/ * use READ/WRITE constants for rw indication * misc clean ups Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-01-15libata fixes for sparse-found problemsAl Viro
In pata_legacy and pata_winbond we've got bugs - cpu_to_le16() instead of cpu_to_le32(). Fortunately, both affected suckers are VLB, thus l-e-only, so we might get away with that unless we hit it with slop == 3 (hadn't checked if playing with badly aligned sg could trigger that). Still buggy... Moreover, pata_legacy, pata_winbond and pata_qdi forgot to initialize pad on the write side of 32bit case in their ->data_xfer(). Hopefully the hardware does't care, but still, sending uninitialized data to it... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-12libata: implement and use ata_port_desc() to report port configurationTejun Heo
Currently, port configuration reporting has the following problems. * iomapped address is reported instead of raw address * report contains irrelevant fields or lacks necessary fields for non-SFF controllers. * host->irq/irq2 are there just for reporting and hacky. This patch implements and uses ata_port_desc() and ata_port_pbar_desc(). ata_port_desc() is almost identical to ata_ehi_push_desc() except that it takes @ap instead of @ehi, has no locking requirement, can only be used during host initialization and " " is used as separator instead of ", ". ata_port_pbar_desc() is a helper to ease reporting of a PCI BAR or an offsetted address into it. LLD pushes whatever description it wants using the above two functions. The accumulated description is printed on host registration after "[S/P]ATA max MAX_XFERMODE ". SFF init helpers and ata_host_activate() automatically add descriptions for addresses and irq respectively, so only LLDs which isn't standard SFF need to add custom descriptions. In many cases, such controllers need to report different things anyway. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-12[libata] Remove ->port_disable() hookJeff Garzik
It was always set to ata_port_disable(). Removed the hook, and replaced the very few ap->ops->port_disable() callsites with direct calls to ata_port_disable(). Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-12[libata] Remove ->irq_ack() hook, and ata_dummy_irq_on()Jeff Garzik
* ->irq_ack() is redundant to what the irq handler already performs... chk-status + irq-clear. Furthermore, it is only called in one place, when screaming-irq-debugging is enabled, so we don't want to bother with a hook just for that. * ata_dummy_irq_on() is only ever used in drivers that have no callpath reaching ->irq_on(). Remove .irq_on hook from those drivers, and the now-unused ata_dummy_irq_on() Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-12libata-link: linkify config/EH related functionsTejun Heo
Make the following functions deal with ata_link instead of ata_port. * ata_set_mode() * ata_eh_autopsy() and related functions * ata_eh_report() and related functions * suspend/resume related functions * ata_eh_recover() and related functions Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-12libata-link: implement and use link/device iteratorsTejun Heo
Multiple links and different number of devices per link should be considered to iterate over links and devices. This patch implements and uses link and device iterators - ata_port_for_each_link() and ata_link_for_each_dev() - and ata_link_max_devices(). This change makes a lot of functions iterate over only possible devices instead of from dev 0 to dev ATA_MAX_DEVICES. All such changes have been examined and nothing should be broken. While at it, add a separating comment before device helpers to distinguish them better from link helpers and others. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-12libata-link: introduce ata_linkTejun Heo
Introduce ata_link. It abstracts PHY and sits between ata_port and ata_device. This new level of abstraction is necessary to support SATA Port Multiplier, which basically adds a bunch of links (PHYs) to a ATA host port. Fields related to command execution, spd_limit and EH are per-link and thus moved to ata_link. This patch only defines the host link. Multiple link handling will be added later. Also, a lot of ap->link derefences are added but many of them will be removed as each part is converted to deal directly with ata_link instead of ata_port. This patch introduces no behavior change. Signed-off-by: Tejun Heo <htejun@gmail.com> Cc: James Bottomley <James.Bottomley@SteelEye.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-05-21libata: bump versionsJeff Garzik
2007-04-28libata: convert the remaining PATA drivers to new init modelTejun Heo
Convert pdc_adma, pata_cs5520, pata_isapnp, pata_ixp4xx_cf, pata_legacy, pata_mpc52xx, pata_mpiix, pata_pcmcia, pata_pdc2027x, pata_platform, pata_qdi, pata_scc and pata_winbond to new init model. * init_one()'s now follow more consistent init order * cs5520 now registers one host with two ports, not two hosts. If any of the two ports are disabled, it's made dummy as other drivers do. Tested pdc_adma and pata_legacy. Both are as broken as before. The rest are compile tested only. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-04-28[libata] More PATA driver ->cable_detect supportJeff Garzik
Roll-up of ->cable_detect feature addition patches, authored and signed-off-by Alan Cox. Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-03-06pata_legacy: fix io/irq mismatchMikael Pettersson
pata_legacy fails to detect the disk on my old ISA/VLB 486: it starts to probe io=0x1f0 ctr=0x3f6 irq=15, complains loudly about IDENTIFYs timing out, and finally fails. (Sorry I couldn't capture the kernel's boot messages.) It turns out that the driver's mapping from io to irq in legacy_irq[] is wrong: index 0 for io=0x1f0 has irq=15 but should have irq=14, and index 1 for io=0x170 has irq=14 but should have irq=15. This is confirmed by a comparison with include/asm-i386/ide.h:ide_default_irq(). This patch swaps the first two elements in legacy_irq[], which makes pata_legacy work on my 486. Signed-off-by: Mikael Pettersson <mikpe@it.uu.se> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-03-02[libata] pata_{legacy,sc1200,sl82c105}: add missing hooksJeff Garzik
Alan Cox noticed several hooks in pata_* drivers were missing, when he authored his ->cable_detect hook patches. This patch extracts just those fixes from Alan's patches, adding the necessary hooks (usually ->freeze, ->thaw, and ->post_internal_cmd) to the drivers. Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-26[libata] bump versionsJeff Garzik
Bump versions based on changes submitted during 2.6.21 merge window. Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-15libata: Add a host flag to indicate lack of IORDY capabilityAlan Cox
This is the first preparation to doing the !IORDY cases properly. Further diffs will then add the needed logic to do it right. Signed-off-by: Alan Cox <alan@redhat.com> Cc: Jeff Garzik <jeff@garzik.org> Cc: Tejun Heo <htejun@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-09libata: add another IRQ calls (libata drivers)Akira Iguchi
This patch is against each libata driver. Two IRQ calls are added in ata_port_operations. - irq_on() is used to enable interrupts. - irq_ack() is used to acknowledge a device interrupt. In most drivers, ata_irq_on() and ata_irq_ack() are used for irq_on and irq_ack respectively. In some drivers (ex: ahci, sata_sil24) which cannot use them as is, ata_dummy_irq_on() and ata_dummy_irq_ack() are used. Signed-off-by: Kou Ishizaki <kou.ishizaki@toshiba.co.jp> Signed-off-by: Akira Iguchi <akira2.iguchi@toshiba.co.jp> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-09libata: convert to iomapTejun Heo
Convert libata core layer and LLDs to use iomap. * managed iomap is used. Pointer to pcim_iomap_table() is cached at host->iomap and used through out LLDs. This basically replaces host->mmio_base. * if possible, pcim_iomap_regions() is used Most iomap operation conversions are taken from Jeff Garzik <jgarzik@pobox.com>'s iomap branch. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-09libata: update libata LLDs to use devresTejun Heo
Update libata LLDs to use devres. Core layer is already converted to support managed LLDs. This patch simplifies initialization and fixes many resource related bugs in init failure and detach path. For example, all converted drivers now handle ata_device_add() failure gracefully without excessive resource rollback code. As most resources are released automatically on driver detach, many drivers don't need or can do with much simpler ->{port|host}_stop(). In general, stop callbacks are need iff port or host needs to be given commands to shut it down. Note that freezing is enough in many cases and ports are automatically frozen before being detached. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-01-24libata: set_mode, Fix the FIXMEAlan
When set_mode() changed ->set_mode didn't adapt. This makes the needed changes and removes the relevant FIXME case. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-12-16[PATCH] ata: fix platform_device_register_simple() error checkAkinobu Mita
The return value of platform_device_register_simple() should be checked by IS_ERR(). Cc: Jeff Garzik <jgarzik@pobox.com> Acked-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-12-03[PATCH] libata: kill unnecessary sht->max_sectors initializationsTejun Heo
sht->max_sectors is overrided unconditionally in ->slave_configure. There's no reason to set it to any value. Signed-off-by: Tejun Heo <htejun@gmail.com>
2006-11-29[PATCH] libata: add missing sht->slave_destroyTejun Heo
Many LLDs are missing sht->slave_destroy. The method is mandatory to support device warm unplugging (echo 1 > /sys/.../delete). Without it, libata might access released scsi device. Signed-off-by: Tejun Heo <htejun@gmail.com>
