path: root/drivers/ata/pata_octeon_cf.c
2010-05-25libata-sff: kill dummy BMDMA ops from sata_qstor and pata_octeon_cfTejun Heo
Now that SFF and BMDMA are completely separate, sata_qstor and pata_octeon_cf which inherit from ata_sff_port_ops don't need to worry about BMDMA ops being called. Kill the dummy BMDMA ops. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-05-17libata: kill ATA_FLAG_DISABLEDTejun Heo
ATA_FLAG_DISABLED is only used by drivers which don't use ->error_handler framework and is largely broken. Its only meaningful function is to make irq handlers skip processing if the flag is set, which is largely useless and even harmful as it makes those ports more likely to cause IRQ storms. Kill ATA_FLAG_DISABLED and makes the callers disable attached devices instead. ata_port_probe() and ata_port_disable() which manipulate the flag are also killed. This simplifies condition check in IRQ handlers. While updating IRQ handlers, remove ap NULL check as libata guarantees consecutive port allocation (unoccupied ports are initialized with dummies) and long-obsolete ATA_QCFLAG_ACTIVE check (checked by ata_qc_from_tag()). Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-05-14libata: make sff_irq_on() method optionalSergei Shtylyov
Now, with the introduction of the sff_set_devctl() method, we can use it in sff_irq_on() method too -- that way its implementations in 'pata_bf54x' and 'pata_scc' become virtually identical to ata_sff_irq_on(). The sff_irq_on() method now becomes quite superfluous, and the only reason not to remove it completely is the existence of the 'pata_octeon_cf' driver which implements it as an empty function. Just make the method optional then, with ata_sff_irq_on() becoming generic taskfile-bound function, still global for the 'pata_bf54x' driver to be able to call it from its thaw() and postreset() methods. While at it, make the sff_irq_on() method and ata_sff_irq_on() return 'void' as the result is always ignored anyway. Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-12-17pata_octeon_cf: use resource_size(), to fix resource sizing bugH Hartley Sweeten
It appears the size for cs1 is calculated using the wrong resource. Use the function resource_size to get the correct value. Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-09-11drivers/ata: use resource_sizeJulia Lawall
Use the function resource_size, which reduces the chance of introducing off-by-one errors in calculating the resource size. The semantic patch that makes this change is as follows: (http://www.emn.fr/x-info/coccinelle/) // <smpl> @@ struct resource *res; @@ - (res->end - res->start) + 1 + resource_size(res) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-09-01drivers/ata: Remove unnecessary semicolonsJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-07-28libata: remove superfluous NULL pointer checksBartlomiej Zolnierkiewicz
host->ports[] always contain pointers to valid port structures since a "dummy port" structure is used in case if there is no physical port. This patch takes care of two entries from Dan's list: drivers/ata/sata_sil.c +535 sil_interrupt(13) warning: variable derefenced before check 'ap' drivers/ata/sata_mv.c +2517 mv_unexpected_intr(6) warning: variable derefenced before check 'ap' and of another needless NULL pointer check in pata_octeon_cf.c. Reported-by: Dan Carpenter <error27@gmail.com> Cc: corbet@lwn.net Cc: eteo@redhat.com Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-04-06libata: Remove some redundant casts from pata_octeon_cf.cDavid Daney
Signed-off-by: David Daney <ddaney@caviumnetworks.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-03-24[libata] convert drivers to use ata.h mode mask definesErik Inge Bolsø
No functional changes in this patch. Signed-off-by: Erik Inge Bolsø <knan-lkml@anduin.net> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-01-16libata: New driver for OCTEON SOC Compact Flash interface (v7).David Daney
Cavium OCTEON processor support was recently merged, so now we have this CF driver for your consideration. Most OCTEON variants have *no* DMA or interrupt support on the CF interface so for these, only PIO is supported. Although if DMA is available, we do take advantage of it. Signed-off-by: David Daney <ddaney@caviumnetworks.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
