path: root/drivers/ata/pata_pdc2027x.c
2017-05-16ata: update references for libata documentationMauro Carvalho Chehab
The libata documentation is now using ReST. Update references to it to point to the new place. Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com>
2015-04-08ata: remove deprecated use of pci apiQuentin Lambert
Replace occurences of the pci api by appropriate call to the dma api. A simplified version of the semantic patch that finds this problem is as follows: (http://coccinelle.lip6.fr) @deprecated@ idexpression id; position p; @@ ( pci_dma_supported@p ( id, ...) | pci_alloc_consistent@p ( id, ...) ) @bad1@ idexpression id; position deprecated.p; @@ ...when != &id->dev when != pci_get_drvdata ( id ) when != pci_enable_device ( id ) ( pci_dma_supported@p ( id, ...) | pci_alloc_consistent@p ( id, ...) ) @depends on !bad1@ idexpression id; expression direction; position deprecated.p; @@ ( - pci_dma_supported@p ( id, + dma_supported ( &id->dev, ... + , GFP_ATOMIC ) | - pci_alloc_consistent@p ( id, + dma_alloc_coherent ( &id->dev, ... + , GFP_ATOMIC ) ) Signed-off-by: Quentin Lambert <lambert.quentin@gmail.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2015-01-27pata_pdc2027x: Use 64-bit timekeepingTina Ruchandani
Function pdc_detect_pll_input_clock uses 'struct timeval' to measure start and end times, used to compute the pll_clock value. 'struct timeval' on 32-bit systems will have its tv_sec field overflow in year 2038 and beyond. This patch uses 'ktime_t' (which uses 64 bits for seconds) for start and end times instead. Suggested-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Tina Ruchandani <ruchandani.tina@gmail.com> Reviewed-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Tejun Heo <tj@kernel.org>
2014-05-09ata: use CONFIG_PM_SLEEP instead of CONFIG_PM where applicable in host driversBartlomiej Zolnierkiewicz
This patch fixes host drivers to use CONFIG_PM_SLEEP instead of CONFIG_PM where applicable. Benefits of this change: * unused code is not being compiled in for CONFIG_PM=y, CONFIG_PM_SLEEP=n and CONFIG_PM_RUNTIME=y configurations * easier transition to use struct dev_pm_ops and SIMPLE_DEV_PM_OPS() in the future * more consistent code (there are host drivers which are using the correct CONFIG_PM_SLEEP checks already) The patch leaves the core libata code and ->port_[suspend,resume] support in sata_[inic162x,nv,sil24].c alone for now. Signed-off-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2014-02-13ata: delete non-required instances of include <linux/init.h>Paul Gortmaker
None of these files are actually using any __init type directives and hence don't need to include <linux/init.h>. Most are just a left over from __devinit and __cpuinit removal, or simply due to code getting copied from one driver to the next. Cc: linux-ide@vger.kernel.org Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2013-06-02ata: use pci_get_drvdata()Jingoo Han
Use the wrapper function for getting the driver data using pci_dev instead of using dev_get_drvdata() with &pdev->dev, so we can directly pass a struct pci_dev. This is a purely cosmetic change. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2013-04-12pata_pdc2027x: Fix compiler warningWang YanQing
Fix the follwing warnings: linux/drivers/ata/pata_pdc2027x.c:66: warning: 'pdc2027x_reinit_one' declared 'static' but never defined pdc2027x_reinit_one are defined only when CONFIG_PM is defined, thus making it conditional. Signed-off-by: Wang YanQing <udknight@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2013-01-03Drivers: ata: remove __dev* attributes.Greg Kroah-Hartman
CONFIG_HOTPLUG is going away as an option. As a result, the __dev* markings need to be removed. This change removes the use of __devinit, __devexit_p, __devinitdata, and __devexit from these drivers. Based on patches originally written by Bill Pemberton, but redone by me in order to handle some of the coding style issues better, by hand. Cc: Bill Pemberton <wfp5p@virginia.edu> Cc: Jeff Garzik <jgarzik@pobox.com> Cc: Viresh Kumar <viresh.linux@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-25ata: use module_pci_driverAxel Lin
This patch converts the drivers in drivers/ata/* to use module_pci_driver() macro which makes the code smaller and a bit simpler. Signed-off-by: Axel Lin <axel.lin@gmail.com> Cc: Alan Cox <alan@linux.intel.com> Cc: Jeff Garzik <jgarzik@pobox.com> Cc: Mikael Pettersson <mikpe@it.uu.se> Cc: Mark Lord <kernel@teksavvy.com> Cc: Jeremy Higdon <jeremy@sgi.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2011-10-14pata_pdc2027x: add Power Management supportBartlomiej Zolnierkiewicz
Fixes IDE -> libata regression. There shouldn't be any problems with it as corresponding IDE's host driver (pdc202xx_new) has been supporting PCI Power Management since Oct 10 2008 (commit feb22b7f "ide: add proper PCI PM support (v2)") and IDE PM since Jun 14 2003 (patch v2.5.73 "ide: Power Management"). Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2011-07-23ata: Add and use ata_print_version_onceJoe Perches
Use a single mechanism to show driver version. Reduces text a tiny bit too. Remove uses of static int printed_version Add and use ata_print_version(const struct device *, const char *ver) and ata_print_version_once. $ size drivers/ata/built-in.* text data bss dec hex filename 544969 73893 116584 735446 b38d6 drivers/ata/built-in.allyesconfig.ata.o 543870 73893 116592 734355 b34ad drivers/ata/built-in.allyesconfig.print_once.o 141328 14689 4220 160237 271ed drivers/ata/built-in.defconfig.ata.o 141212 14689 4220 160121 27179 drivers/ata/built-in.defconfig.print_once.o Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2011-07-23ata: Convert dev_printk(KERN_<LEVEL> to dev_<level>(Joe Perches
Saves a bit of text as the call takes fewer args. Coalesce a few formats. Convert a few bare printks to pr_cont. $ size drivers/ata/built-in.o* text data bss dec hex filename 558429 73893 117864 750186 b726a drivers/ata/built-in.o.allyesconfig.new 559574 73893 117888 751355 b76fb drivers/ata/built-in.o.allyesconfig.old 149567 14689 4220 168476 2921c drivers/ata/built-in.o.defconfig.new 149851 14689 4220 168760 29338 drivers/ata/built-in.o.defconfig.old Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2011-03-02libata: remove ATA_FLAG_NO_LEGACYSergei Shtylyov
All checks of ATA_FLAG_NO_LEGACY have been removed by the commits c791c30670ea61f19eec390124128bf278e854fe ([libata] minor PCI IDE probe fixes and cleanups) and f0d36efdc624beb3d9e29b9ab9e9537bf0f25d5b (libata: update libata core layer to use devres), so I think it's time to finally get rid of this flag... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2011-03-02libata: remove ATA_FLAG_MMIOSergei Shtylyov
Commit 0d5ff566779f894ca9937231a181eb31e4adff0e (libata: convert to iomap) removed all checks of ATA_FLAG_MMIO but neglected to remove the flag itself. Do it now, at last... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-05-25libata-sff: separate out BMDMA irq handlerTejun Heo
Separate out BMDMA irq handler from SFF irq handler. The misnamed host_intr() functions are renamed to ata_sff_port_intr() and ata_bmdma_port_intr(). Common parts are factored into __ata_sff_port_intr() and __ata_sff_interrupt() and used by sff and bmdma interrupt routines. All BMDMA drivers now use ata_bmdma_interrupt() or ata_bmdma_port_intr() while all non-BMDMA SFF ones use ata_sff_interrupt() or ata_sff_port_intr(). For now, ata_pci_sff_init_one() uses ata_bmdma_interrupt() as it's used by both SFF and BMDMA drivers. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-05-19libata-sff: clean up BMDMA initializationTejun Heo
When BMDMA initialization failed or BMDMA was not available for whatever reason, bmdma_addr was left at zero and used as an indication that BMDMA shouldn't be used. This leads to the following problems. p1. For BMDMA drivers which don't use traditional BMDMA register, ata_bmdma_mode_filter() incorrectly inhibits DMA modes. Those drivers either have to inherit from ata_sff_port_ops or clear ->mode_filter explicitly. p2. non-BMDMA drivers call into BMDMA PRD table allocation. It doesn't actually allocate PRD table if bmdma_addr is not initialized but is still confusing. p3. For BMDMA drivers which don't use traditional BMDMA register, some methods might not be invoked as expected (e.g. bmdma_stop from ata_sff_post_internal_cmd()). p4. SFF drivers w/ custom DMA interface implement noop BMDMA ops worrying libata core might call into one of them. These problems are caused by the muddy line between SFF and BMDMA and the assumption that all BMDMA controllers initialize bmdma_addr. This patch fixes p1 and p2 by removing the bmdma_addr assumption and moving prd allocation to BMDMA port start. Later patches will fix the remaining issues. This patch improves BMDMA initialization such that * When BMDMA register initialization fails, falls back to PIO instead of failing. ata_pci_bmdma_init() never fails now. * When ata_pci_bmdma_init() falls back to PIO, it clears ap->mwdma_mask and udma_mask instead of depending on ata_bmdma_mode_filter(). This makes ata_bmdma_mode_filter() unnecessary thus resolving p1. * ata_port_start() which actually is BMDMA specific is moved to ata_bmdma_port_start(). ata_port_start() and ata_sff_port_start() are killed. * ata_sff_port_start32() is moved and renamed to ata_bmdma_port_start32(). Drivers which no longer call into PRD table allocation are... pdc_adma, sata_inic162x, sata_qstor, sata_sx4, pata_cmd640 and all drivers which inherit from ata_sff_port_ops. pata_icside sets ->port_start to ATA_OP_NULL as it doesn't need PRD but is a BMDMA controller and doesn't have custom port_start like other such controllers. Note that with the previous patch which makes all and only BMDMA drivers inherit from ata_bmdma_port_ops, this change doesn't break drivers which need PRD table. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-03-24[libata] convert drivers to use ata.h mode mask definesErik Inge Bolsø
No functional changes in this patch. Signed-off-by: Erik Inge Bolsø <knan-lkml@anduin.net> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-12-28[libata] Update kernel-doc comments to match source codeQinghuang Feng
Signed-off-by: Qinghuang Feng <qhfeng.kernel@gmail.com>
2008-12-28libata: beef up iteratorsTejun Heo
There currently are the following looping constructs. * __ata_port_for_each_link() for all available links * ata_port_for_each_link() for edge links * ata_link_for_each_dev() for all devices * ata_link_for_each_dev_reverse() for all devices in reverse order Now there's a need for looping construct which is similar to __ata_port_for_each_link() but iterates over PMP links before the host link. Instead of adding another one with long name, do the following cleanup. * Implement and export ata_link_next() and ata_dev_next() which take @mode parameter and can be used to build custom loop. * Implement ata_for_each_link() and ata_for_each_dev() which take looping mode explicitly. The following iteration modes are implemented. * ATA_LITER_EDGE : loop over edge links * ATA_LITER_HOST_FIRST : loop over all links, host link first * ATA_LITER_PMP_FIRST : loop over all links, PMP links first * ATA_DITER_ENABLED : loop over enabled devices * ATA_DITER_ENABLED_REVERSE : loop over enabled devices in reverse order * ATA_DITER_ALL : loop over all devices * ATA_DITER_ALL_REVERSE : loop over all devices in reverse order This change removes exlicit device enabledness checks from many loops and makes it clear which ones are iterated over in which direction. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-17libata: rename SFF functionsTejun Heo
SFF functions have confusing names. Some have sff prefix, some have bmdma, some std, some pci and some none. Unify the naming by... * SFF functions which are common to both BMDMA and non-BMDMA are prefixed with ata_sff_. * SFF functions which are specific to BMDMA are prefixed with ata_bmdma_. * SFF functions which are specific to PCI but apply to both BMDMA and non-BMDMA are prefixed with ata_pci_sff_. * SFF functions which are specific to PCI and BMDMA are prefixed with ata_pci_bmdma_. * Drop generic prefixes from LLD specific routines. For example, bfin_std_dev_select -> bfin_dev_select. The following renames are noteworthy. ata_qc_issue_prot() -> ata_sff_qc_issue() ata_pci_default_filter() -> ata_bmdma_mode_filter() ata_dev_try_classify() -> ata_sff_dev_classify() This rename is in preparation of separating SFF support out of libata core layer. This patch strictly renames functions and doesn't introduce any behavior difference. Signed-off-by: Tejun Heo <htejun@gmail.com>
2008-04-17libata: make reset related methods proper port operationsTejun Heo
Currently reset methods are not specified directly in the ata_port_operations table. If a LLD wants to use custom reset methods, it should construct and use a error_handler which uses those reset methods. It's done this way for two reasons. First, the ops table already contained too many methods and adding four more of them would noticeably increase the amount of necessary boilerplate code all over low level drivers. Second, as ->error_handler uses those reset methods, it can get confusing. ie. By overriding ->error_handler, those reset ops can be made useless making layering a bit hazy. Now that ops table uses inheritance, the first problem doesn't exist anymore. The second isn't completely solved but is relieved by providing default values - most drivers can just override what it has implemented and don't have to concern itself about higher level callbacks. In fact, there currently is no driver which actually modifies error handling behavior. Drivers which override ->error_handler just wraps the standard error handler only to prepare the controller for EH. I don't think making ops layering strict has any noticeable benefit. This patch makes ->prereset, ->softreset, ->hardreset, ->postreset and their PMP counterparts propoer ops. Default ops are provided in the base ops tables and drivers are converted to override individual reset methods instead of creating custom error_handler. * ata_std_error_handler() doesn't use sata_std_hardreset() if SCRs aren't accessible. sata_promise doesn't need to use separate error_handlers for PATA and SATA anymore. * softreset is broken for sata_inic162x and sata_sx4. As libata now always prefers hardreset, this doesn't really matter but the ops are forced to NULL using ATA_OP_NULL for documentation purpose. * pata_hpt374 needs to use different prereset for the first and second PCI functions. This used to be done by branching from hpt374_error_handler(). The proper way to do this is to use separate ops and port_info tables for each function. Converted. Signed-off-by: Tejun Heo <htejun@gmail.com>
2008-04-17libata: implement and use ops inheritanceTejun Heo
libata lets low level drivers build ata_port_operations table and register it with libata core layer. This allows low level drivers high level of flexibility but also burdens them with lots of boilerplate entries. This becomes worse for drivers which support related similar controllers which differ slightly. They share most of the operations except for a few. However, the driver still needs to list all operations for each variant. This results in large number of duplicate entries, which is not only inefficient but also error-prone as it becomes very difficult to tell what the actual differences are. This duplicate boilerplates all over the low level drivers also make updating the core layer exteremely difficult and error-prone. When compounded with multi-branched development model, it ends up accumulating inconsistencies over time. Some of those inconsistencies cause immediate problems and fixed. Others just remain there dormant making maintenance increasingly difficult. To rectify the problem, this patch implements ata_port_operations inheritance. To allow LLDs to easily re-use their own ops tables overriding only specific methods, this patch implements poor man's class inheritance. An ops table has ->inherits field which can be set to any ops table as long as it doesn't create a loop. When the host is started, the inheritance chain is followed and any operation which isn't specified is taken from the nearest ancestor which has it specified. This operation is called finalization and done only once per an ops table and the LLD doesn't have to do anything special about it other than making the ops table non-const such that libata can update it. libata provides four base ops tables lower drivers can inherit from - base, sata, pmp, sff and bmdma. To avoid overriding these ops accidentaly, these ops are declared const and LLDs should always inherit these instead of using them directly. After finalization, all the ops table are identical before and after the patch except for setting .irq_handler to ata_interrupt in drivers which didn't use to. The .irq_handler doesn't have any actual effect and the field will soon be removed by later patch. * sata_sx4 is still using old style EH and currently doesn't take advantage of ops inheritance. Signed-off-by: Tejun Heo <htejun@gmail.com>
2008-04-17libata: implement and use SHT initializersTejun Heo
libata lets low level drivers build scsi_host_template and register it to the SCSI layer. This allows low level drivers high level of flexibility but also burdens them with lots of boilerplate entries. This patch implements SHT initializers which can be used to initialize all the boilerplate entries in a sht. Three variants of them are implemented - BASE, BMDMA and NCQ - for different types of drivers. Note that entries can be overriden by putting individual initializers after the helper macro. All sht tables are identical before and after this patch. Signed-off-by: Tejun Heo <htejun@gmail.com>
2008-03-10ata: replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-01-23libata annotations and fixesAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-29[libata] fix 'if(' and similar areas that lack whitespaceJeff Garzik
2007-10-12pdc2027x: Switch properly to ioread/iowriteAlan Cox
Some iomap functions were still using readl/writel and friends which happens to work on most platforms but is not correct. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-12libata: implement and use ata_port_desc() to report port configurationTejun Heo
Currently, port configuration reporting has the following problems. * iomapped address is reported instead of raw address * report contains irrelevant fields or lacks necessary fields for non-SFF controllers. * host->irq/irq2 are there just for reporting and hacky. This patch implements and uses ata_port_desc() and ata_port_pbar_desc(). ata_port_desc() is almost identical to ata_ehi_push_desc() except that it takes @ap instead of @ehi, has no locking requirement, can only be used during host initialization and " " is used as separator instead of ", ". ata_port_pbar_desc() is a helper to ease reporting of a PCI BAR or an offsetted address into it. LLD pushes whatever description it wants using the above two functions. The accumulated description is printed on host registration after "[S/P]ATA max MAX_XFERMODE ". SFF init helpers and ata_host_activate() automatically add descriptions for addresses and irq respectively, so only LLDs which isn't standard SFF need to add custom descriptions. In many cases, such controllers need to report different things anyway. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-12libata: pata_pdc2027x PLL detection minor cleanupAlbert Lee
Minor cleanup to remove the unneeded rmb()s per Jeff's advice. Also removed the pll_clock < 0 check since pll_clock now guaranteed to be >= 0 after Mikael's patch. Signed-off-by: Albert Lee <albertcc@tw.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-12libata: Switch most of the remaining SFF drivers to ata_sff_port_startAlan Cox
This avoids allocating DMA buffers if not needed but at the moment is mostly just a neatness item. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-12[libata] Remove ->port_disable() hookJeff Garzik
It was always set to ata_port_disable(). Removed the hook, and replaced the very few ap->ops->port_disable() callsites with direct calls to ata_port_disable(). Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-12[libata] Remove ->irq_ack() hook, and ata_dummy_irq_on()Jeff Garzik
* ->irq_ack() is redundant to what the irq handler already performs... chk-status + irq-clear. Furthermore, it is only called in one place, when screaming-irq-debugging is enabled, so we don't want to bother with a hook just for that. * ata_dummy_irq_on() is only ever used in drivers that have no callpath reaching ->irq_on(). Remove .irq_on hook from those drivers, and the now-unused ata_dummy_irq_on() Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-12libata-link: linkify config/EH related functionsTejun Heo
Make the following functions deal with ata_link instead of ata_port. * ata_set_mode() * ata_eh_autopsy() and related functions * ata_eh_report() and related functions * suspend/resume related functions * ata_eh_recover() and related functions Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-12libata-link: linkify resetTejun Heo
Make reset methods and related functions deal with ata_link instead of ata_port. * ata_do_reset() * ata_eh_reset() * all prereset/reset/postreset methods and related functions This patch introduces no behavior change. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-12libata-link: implement and use link/device iteratorsTejun Heo
Multiple links and different number of devices per link should be considered to iterate over links and devices. This patch implements and uses link and device iterators - ata_port_for_each_link() and ata_link_for_each_dev() - and ata_link_max_devices(). This change makes a lot of functions iterate over only possible devices instead of from dev 0 to dev ATA_MAX_DEVICES. All such changes have been examined and nothing should be broken. While at it, add a separating comment before device helpers to distinguish them better from link helpers and others. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-12libata-link: introduce ata_linkTejun Heo
Introduce ata_link. It abstracts PHY and sits between ata_port and ata_device. This new level of abstraction is necessary to support SATA Port Multiplier, which basically adds a bunch of links (PHYs) to a ATA host port. Fields related to command execution, spd_limit and EH are per-link and thus moved to ata_link. This patch only defines the host link. Multiple link handling will be added later. Also, a lot of ap->link derefences are added but many of them will be removed as each part is converted to deal directly with ata_link instead of ata_port. This patch introduces no behavior change. Signed-off-by: Tejun Heo <htejun@gmail.com> Cc: James Bottomley <James.Bottomley@SteelEye.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-08-31[libata] Bump driver versionsJeff Garzik
Bump the versions for drivers that were modified, but had not already had a version number bump. Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-08-23pata_pdc2027x: PLL detection fixesMikael Pettersson
Previously I reported that the pata_pdc2027x PLL detection changes in kernel 2.6.22 broke the driver on my PowerMac: >pata_pdc2027x: Invalid PLL input clock 1691742kHz, give up! This is followed by a number of errors and speed reduction steps on the affected ports. There are two bugs in pata_pdc2027x's PLL detection code: 1. The PLL counter's start value is read before the chip is put in "test mode". Outside of test mode the counter is halted, and on the PowerMac the counter is zero because the chip hasn't been initialised by its BIOS. The fix is to move the read of the start value to after test mode is started, but before the mdelay() in test mode. This also improves the precision of the PLL detection. 2. The code to compute the number of PLL decrements during the mdelay() in test mode fails to consider that the PLL counter only is 30 bits wide. If there is a wraparound, it will compute an incorrect and much too large value. On the PowerMac, the start count is zero, the end count is a large 30-bit value, so wraparound occurs and an out of bounds PLL clock is detected. The fix is to mask the (start - end) computation to 30 bits. While debugging this I also noticed that pdc_read_counter() reads the two halves of the 30-bit PLL counter as 16-bit values, and then combines them as if the halves only are 15 bits wide. To avoid confusion, the halves should be read as 15-bit values. This patch implements all three changes. It fixes the PLL detection failure on my PowerMac, and doesn't cause any regressions on an x86 with an identical card. Signed-off-by: Mikael Pettersson <mikpe@it.uu.se> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-02libata: pata_pdc2027x PLL input clock fixAlbert Lee
Recently the PLL input clock of pata_pdc2027x is sometimes detected higer than expected (e.g. 20.027 MHz compared to 16.714 MHz). It seems sometimes the mdelay() function is not as precise as it used to be. Per Alan's advice, HT or power management might affect the precision of mdelay(). This patch calls gettimeofday() to mesure the time elapsed and calculate the PLL input clock accordingly. Signed-off-by: Albert Lee <albertcc@tw.ibm.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-05-01libata: add deadline support to prereset and reset methodsTejun Heo
Add @deadline to prereset and reset methods and make them honor it. ata_wait_ready() which directly takes @deadline is implemented to be used as the wait function. This patch is in preparation for EH timing improvements. * ata_wait_ready() never does busy sleep. It's only used from EH and no wait in EH is that urgent. This function also prints 'be patient' message automatically after 5 secs of waiting if more than 3 secs is remaining till deadline. * ata_bus_post_reset() now fails with error code if any of its wait fails. This is important because earlier reset tries will have shorter timeout than the spec requires. If a device fails to respond before the short timeout, reset should be retried with longer timeout rather than silently ignoring the device. There are three behavior differences. 1. Timeout is applied to both devices at once, not separately. This is more consistent with what the spec says. 2. When a device passes devchk but fails to become ready before deadline. Previouly, post_reset would just succeed and let device classification remove the device. New code fails the reset thus causing reset retry. After a few times, EH will give up disabling the port. 3. When slave device passes devchk but fails to become accessible (TF-wise) after reset. Original code disables dev1 after 30s timeout and continues as if the device doesn't exist, while the patched code fails reset. When this happens, new code fails reset on whole port rather than proceeding with only the primary device. If the failing device is suffering transient problems, new code retries reset which is a better behavior. If the failing device is actually broken, the net effect is identical to it, but not to the other device sharing the channel. In the previous code, reset would have succeeded after 30s thus detecting the working one. In the new code, reset fails and whole port gets disabled. IMO, it's a pathological case anyway (broken device sharing bus with working one) and doesn't really matter. * ata_bus_softreset() is changed to return error code from ata_bus_post_reset(). It used to return 0 unconditionally. * Spin up waiting is to be removed and not converted to honor deadline. * To be on the safe side, deadline is set to 40s for the time being. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-04-28libata: convert the remaining PATA drivers to new init modelTejun Heo
Convert pdc_adma, pata_cs5520, pata_isapnp, pata_ixp4xx_cf, pata_legacy, pata_mpc52xx, pata_mpiix, pata_pcmcia, pata_pdc2027x, pata_platform, pata_qdi, pata_scc and pata_winbond to new init model. * init_one()'s now follow more consistent init order * cs5520 now registers one host with two ports, not two hosts. If any of the two ports are disabled, it's made dummy as other drivers do. Tested pdc_adma and pata_legacy. Both are as broken as before. The rest are compile tested only. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-04-28pata_pdc2027x: UpdatesAlan Cox
Signed-off-by: Alan Cox <alan@redhat.com> Correct missing modefilter (crash if BAR4 unassigned) Use Cable Detect method Wrap ->set_mode instead ready for ->post_set_mode removal Maxtor errata as per Jeff Garzik report Remove duplicated private udma_mask hacking Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-26[libata] bump versionsJeff Garzik
Bump versions based on changes submitted during 2.6.21 merge window. Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-14[PATCH] Scheduled removal of SA_xxx interrupt flags fixupsThomas Gleixner
The obsolete SA_xxx interrupt flags have been used despite the scheduled removal. Fixup the remaining users. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Jeff Garzik <jeff@garzik.org> Cc: Wim Van Sebroeck <wim@iguana.be> Cc: Roland Dreier <rolandd@cisco.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Greg KH <greg@kroah.com> Cc: Dave Airlie <airlied@linux.ie> Cc: James Simmons <jsimmons@infradead.org> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-09libata: add another IRQ calls (libata drivers)Akira Iguchi
This patch is against each libata driver. Two IRQ calls are added in ata_port_operations. - irq_on() is used to enable interrupts. - irq_ack() is used to acknowledge a device interrupt. In most drivers, ata_irq_on() and ata_irq_ack() are used for irq_on and irq_ack respectively. In some drivers (ex: ahci, sata_sil24) which cannot use them as is, ata_dummy_irq_on() and ata_dummy_irq_ack() are used. Signed-off-by: Kou Ishizaki <kou.ishizaki@toshiba.co.jp> Signed-off-by: Akira Iguchi <akira2.iguchi@toshiba.co.jp> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-09libata: convert to iomapTejun Heo
Convert libata core layer and LLDs to use iomap. * managed iomap is used. Pointer to pcim_iomap_table() is cached at host->iomap and used through out LLDs. This basically replaces host->mmio_base. * if possible, pcim_iomap_regions() is used Most iomap operation conversions are taken from Jeff Garzik <jgarzik@pobox.com>'s iomap branch. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-09libata: update libata LLDs to use devresTejun Heo
Update libata LLDs to use devres. Core layer is already converted to support managed LLDs. This patch simplifies initialization and fixes many resource related bugs in init failure and detach path. For example, all converted drivers now handle ata_device_add() failure gracefully without excessive resource rollback code. As most resources are released automatically on driver detach, many drivers don't need or can do with much simpler ->{port|host}_stop(). In general, stop callbacks are need iff port or host needs to be given commands to shut it down. Note that freezing is enough in many cases and ports are automatically frozen before being detached. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-12-03[PATCH] libata: kill unnecessary sht->max_sectors initializationsTejun Heo
sht->max_sectors is overrided unconditionally in ->slave_configure. There's no reason to set it to any value. Signed-off-by: Tejun Heo <htejun@gmail.com>
2006-12-01[PATCH] pci_module_init() conversion for pata_pdc2027xHenrik Kretzschmar
pci_module_init() conversion for pata_pdc2027x Signed-off-by: Henrik Kretzschmar <henne@nachtwindheim.de> Acked-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-11-29[PATCH] libata: add missing sht->slave_destroyTejun Heo
Many LLDs are missing sht->slave_destroy. The method is mandatory to support device warm unplugging (echo 1 > /sys/.../delete). Without it, libata might access released scsi device. Signed-off-by: Tejun Heo <htejun@gmail.com>
