path: root/drivers/ata/pata_pdc2027x.c
2008-04-17libata: rename SFF functionsTejun Heo
SFF functions have confusing names. Some have sff prefix, some have bmdma, some std, some pci and some none. Unify the naming by... * SFF functions which are common to both BMDMA and non-BMDMA are prefixed with ata_sff_. * SFF functions which are specific to BMDMA are prefixed with ata_bmdma_. * SFF functions which are specific to PCI but apply to both BMDMA and non-BMDMA are prefixed with ata_pci_sff_. * SFF functions which are specific to PCI and BMDMA are prefixed with ata_pci_bmdma_. * Drop generic prefixes from LLD specific routines. For example, bfin_std_dev_select -> bfin_dev_select. The following renames are noteworthy. ata_qc_issue_prot() -> ata_sff_qc_issue() ata_pci_default_filter() -> ata_bmdma_mode_filter() ata_dev_try_classify() -> ata_sff_dev_classify() This rename is in preparation of separating SFF support out of libata core layer. This patch strictly renames functions and doesn't introduce any behavior difference. Signed-off-by: Tejun Heo <htejun@gmail.com>
2008-04-17libata: make reset related methods proper port operationsTejun Heo
Currently reset methods are not specified directly in the ata_port_operations table. If a LLD wants to use custom reset methods, it should construct and use a error_handler which uses those reset methods. It's done this way for two reasons. First, the ops table already contained too many methods and adding four more of them would noticeably increase the amount of necessary boilerplate code all over low level drivers. Second, as ->error_handler uses those reset methods, it can get confusing. ie. By overriding ->error_handler, those reset ops can be made useless making layering a bit hazy. Now that ops table uses inheritance, the first problem doesn't exist anymore. The second isn't completely solved but is relieved by providing default values - most drivers can just override what it has implemented and don't have to concern itself about higher level callbacks. In fact, there currently is no driver which actually modifies error handling behavior. Drivers which override ->error_handler just wraps the standard error handler only to prepare the controller for EH. I don't think making ops layering strict has any noticeable benefit. This patch makes ->prereset, ->softreset, ->hardreset, ->postreset and their PMP counterparts propoer ops. Default ops are provided in the base ops tables and drivers are converted to override individual reset methods instead of creating custom error_handler. * ata_std_error_handler() doesn't use sata_std_hardreset() if SCRs aren't accessible. sata_promise doesn't need to use separate error_handlers for PATA and SATA anymore. * softreset is broken for sata_inic162x and sata_sx4. As libata now always prefers hardreset, this doesn't really matter but the ops are forced to NULL using ATA_OP_NULL for documentation purpose. * pata_hpt374 needs to use different prereset for the first and second PCI functions. This used to be done by branching from hpt374_error_handler(). The proper way to do this is to use separate ops and port_info tables for each function. Converted. Signed-off-by: Tejun Heo <htejun@gmail.com>
2008-04-17libata: implement and use ops inheritanceTejun Heo
libata lets low level drivers build ata_port_operations table and register it with libata core layer. This allows low level drivers high level of flexibility but also burdens them with lots of boilerplate entries. This becomes worse for drivers which support related similar controllers which differ slightly. They share most of the operations except for a few. However, the driver still needs to list all operations for each variant. This results in large number of duplicate entries, which is not only inefficient but also error-prone as it becomes very difficult to tell what the actual differences are. This duplicate boilerplates all over the low level drivers also make updating the core layer exteremely difficult and error-prone. When compounded with multi-branched development model, it ends up accumulating inconsistencies over time. Some of those inconsistencies cause immediate problems and fixed. Others just remain there dormant making maintenance increasingly difficult. To rectify the problem, this patch implements ata_port_operations inheritance. To allow LLDs to easily re-use their own ops tables overriding only specific methods, this patch implements poor man's class inheritance. An ops table has ->inherits field which can be set to any ops table as long as it doesn't create a loop. When the host is started, the inheritance chain is followed and any operation which isn't specified is taken from the nearest ancestor which has it specified. This operation is called finalization and done only once per an ops table and the LLD doesn't have to do anything special about it other than making the ops table non-const such that libata can update it. libata provides four base ops tables lower drivers can inherit from - base, sata, pmp, sff and bmdma. To avoid overriding these ops accidentaly, these ops are declared const and LLDs should always inherit these instead of using them directly. After finalization, all the ops table are identical before and after the patch except for setting .irq_handler to ata_interrupt in drivers which didn't use to. The .irq_handler doesn't have any actual effect and the field will soon be removed by later patch. * sata_sx4 is still using old style EH and currently doesn't take advantage of ops inheritance. Signed-off-by: Tejun Heo <htejun@gmail.com>
2008-04-17libata: implement and use SHT initializersTejun Heo
libata lets low level drivers build scsi_host_template and register it to the SCSI layer. This allows low level drivers high level of flexibility but also burdens them with lots of boilerplate entries. This patch implements SHT initializers which can be used to initialize all the boilerplate entries in a sht. Three variants of them are implemented - BASE, BMDMA and NCQ - for different types of drivers. Note that entries can be overriden by putting individual initializers after the helper macro. All sht tables are identical before and after this patch. Signed-off-by: Tejun Heo <htejun@gmail.com>
2008-03-10ata: replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-01-23libata annotations and fixesAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-29[libata] fix 'if(' and similar areas that lack whitespaceJeff Garzik
2007-10-12pdc2027x: Switch properly to ioread/iowriteAlan Cox
Some iomap functions were still using readl/writel and friends which happens to work on most platforms but is not correct. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-12libata: implement and use ata_port_desc() to report port configurationTejun Heo
Currently, port configuration reporting has the following problems. * iomapped address is reported instead of raw address * report contains irrelevant fields or lacks necessary fields for non-SFF controllers. * host->irq/irq2 are there just for reporting and hacky. This patch implements and uses ata_port_desc() and ata_port_pbar_desc(). ata_port_desc() is almost identical to ata_ehi_push_desc() except that it takes @ap instead of @ehi, has no locking requirement, can only be used during host initialization and " " is used as separator instead of ", ". ata_port_pbar_desc() is a helper to ease reporting of a PCI BAR or an offsetted address into it. LLD pushes whatever description it wants using the above two functions. The accumulated description is printed on host registration after "[S/P]ATA max MAX_XFERMODE ". SFF init helpers and ata_host_activate() automatically add descriptions for addresses and irq respectively, so only LLDs which isn't standard SFF need to add custom descriptions. In many cases, such controllers need to report different things anyway. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-12libata: pata_pdc2027x PLL detection minor cleanupAlbert Lee
Minor cleanup to remove the unneeded rmb()s per Jeff's advice. Also removed the pll_clock < 0 check since pll_clock now guaranteed to be >= 0 after Mikael's patch. Signed-off-by: Albert Lee <albertcc@tw.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-12libata: Switch most of the remaining SFF drivers to ata_sff_port_startAlan Cox
This avoids allocating DMA buffers if not needed but at the moment is mostly just a neatness item. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-12[libata] Remove ->port_disable() hookJeff Garzik
It was always set to ata_port_disable(). Removed the hook, and replaced the very few ap->ops->port_disable() callsites with direct calls to ata_port_disable(). Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-12[libata] Remove ->irq_ack() hook, and ata_dummy_irq_on()Jeff Garzik
* ->irq_ack() is redundant to what the irq handler already performs... chk-status + irq-clear. Furthermore, it is only called in one place, when screaming-irq-debugging is enabled, so we don't want to bother with a hook just for that. * ata_dummy_irq_on() is only ever used in drivers that have no callpath reaching ->irq_on(). Remove .irq_on hook from those drivers, and the now-unused ata_dummy_irq_on() Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-12libata-link: linkify config/EH related functionsTejun Heo
Make the following functions deal with ata_link instead of ata_port. * ata_set_mode() * ata_eh_autopsy() and related functions * ata_eh_report() and related functions * suspend/resume related functions * ata_eh_recover() and related functions Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-12libata-link: linkify resetTejun Heo
Make reset methods and related functions deal with ata_link instead of ata_port. * ata_do_reset() * ata_eh_reset() * all prereset/reset/postreset methods and related functions This patch introduces no behavior change. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-12libata-link: implement and use link/device iteratorsTejun Heo
Multiple links and different number of devices per link should be considered to iterate over links and devices. This patch implements and uses link and device iterators - ata_port_for_each_link() and ata_link_for_each_dev() - and ata_link_max_devices(). This change makes a lot of functions iterate over only possible devices instead of from dev 0 to dev ATA_MAX_DEVICES. All such changes have been examined and nothing should be broken. While at it, add a separating comment before device helpers to distinguish them better from link helpers and others. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-12libata-link: introduce ata_linkTejun Heo
Introduce ata_link. It abstracts PHY and sits between ata_port and ata_device. This new level of abstraction is necessary to support SATA Port Multiplier, which basically adds a bunch of links (PHYs) to a ATA host port. Fields related to command execution, spd_limit and EH are per-link and thus moved to ata_link. This patch only defines the host link. Multiple link handling will be added later. Also, a lot of ap->link derefences are added but many of them will be removed as each part is converted to deal directly with ata_link instead of ata_port. This patch introduces no behavior change. Signed-off-by: Tejun Heo <htejun@gmail.com> Cc: James Bottomley <James.Bottomley@SteelEye.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-08-31[libata] Bump driver versionsJeff Garzik
Bump the versions for drivers that were modified, but had not already had a version number bump. Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-08-23pata_pdc2027x: PLL detection fixesMikael Pettersson
Previously I reported that the pata_pdc2027x PLL detection changes in kernel 2.6.22 broke the driver on my PowerMac: >pata_pdc2027x: Invalid PLL input clock 1691742kHz, give up! This is followed by a number of errors and speed reduction steps on the affected ports. There are two bugs in pata_pdc2027x's PLL detection code: 1. The PLL counter's start value is read before the chip is put in "test mode". Outside of test mode the counter is halted, and on the PowerMac the counter is zero because the chip hasn't been initialised by its BIOS. The fix is to move the read of the start value to after test mode is started, but before the mdelay() in test mode. This also improves the precision of the PLL detection. 2. The code to compute the number of PLL decrements during the mdelay() in test mode fails to consider that the PLL counter only is 30 bits wide. If there is a wraparound, it will compute an incorrect and much too large value. On the PowerMac, the start count is zero, the end count is a large 30-bit value, so wraparound occurs and an out of bounds PLL clock is detected. The fix is to mask the (start - end) computation to 30 bits. While debugging this I also noticed that pdc_read_counter() reads the two halves of the 30-bit PLL counter as 16-bit values, and then combines them as if the halves only are 15 bits wide. To avoid confusion, the halves should be read as 15-bit values. This patch implements all three changes. It fixes the PLL detection failure on my PowerMac, and doesn't cause any regressions on an x86 with an identical card. Signed-off-by: Mikael Pettersson <mikpe@it.uu.se> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-02libata: pata_pdc2027x PLL input clock fixAlbert Lee
Recently the PLL input clock of pata_pdc2027x is sometimes detected higer than expected (e.g. 20.027 MHz compared to 16.714 MHz). It seems sometimes the mdelay() function is not as precise as it used to be. Per Alan's advice, HT or power management might affect the precision of mdelay(). This patch calls gettimeofday() to mesure the time elapsed and calculate the PLL input clock accordingly. Signed-off-by: Albert Lee <albertcc@tw.ibm.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-05-01libata: add deadline support to prereset and reset methodsTejun Heo
Add @deadline to prereset and reset methods and make them honor it. ata_wait_ready() which directly takes @deadline is implemented to be used as the wait function. This patch is in preparation for EH timing improvements. * ata_wait_ready() never does busy sleep. It's only used from EH and no wait in EH is that urgent. This function also prints 'be patient' message automatically after 5 secs of waiting if more than 3 secs is remaining till deadline. * ata_bus_post_reset() now fails with error code if any of its wait fails. This is important because earlier reset tries will have shorter timeout than the spec requires. If a device fails to respond before the short timeout, reset should be retried with longer timeout rather than silently ignoring the device. There are three behavior differences. 1. Timeout is applied to both devices at once, not separately. This is more consistent with what the spec says. 2. When a device passes devchk but fails to become ready before deadline. Previouly, post_reset would just succeed and let device classification remove the device. New code fails the reset thus causing reset retry. After a few times, EH will give up disabling the port. 3. When slave device passes devchk but fails to become accessible (TF-wise) after reset. Original code disables dev1 after 30s timeout and continues as if the device doesn't exist, while the patched code fails reset. When this happens, new code fails reset on whole port rather than proceeding with only the primary device. If the failing device is suffering transient problems, new code retries reset which is a better behavior. If the failing device is actually broken, the net effect is identical to it, but not to the other device sharing the channel. In the previous code, reset would have succeeded after 30s thus detecting the working one. In the new code, reset fails and whole port gets disabled. IMO, it's a pathological case anyway (broken device sharing bus with working one) and doesn't really matter. * ata_bus_softreset() is changed to return error code from ata_bus_post_reset(). It used to return 0 unconditionally. * Spin up waiting is to be removed and not converted to honor deadline. * To be on the safe side, deadline is set to 40s for the time being. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-04-28libata: convert the remaining PATA drivers to new init modelTejun Heo
Convert pdc_adma, pata_cs5520, pata_isapnp, pata_ixp4xx_cf, pata_legacy, pata_mpc52xx, pata_mpiix, pata_pcmcia, pata_pdc2027x, pata_platform, pata_qdi, pata_scc and pata_winbond to new init model. * init_one()'s now follow more consistent init order * cs5520 now registers one host with two ports, not two hosts. If any of the two ports are disabled, it's made dummy as other drivers do. Tested pdc_adma and pata_legacy. Both are as broken as before. The rest are compile tested only. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-04-28pata_pdc2027x: UpdatesAlan Cox
Signed-off-by: Alan Cox <alan@redhat.com> Correct missing modefilter (crash if BAR4 unassigned) Use Cable Detect method Wrap ->set_mode instead ready for ->post_set_mode removal Maxtor errata as per Jeff Garzik report Remove duplicated private udma_mask hacking Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-26[libata] bump versionsJeff Garzik
Bump versions based on changes submitted during 2.6.21 merge window. Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-14[PATCH] Scheduled removal of SA_xxx interrupt flags fixupsThomas Gleixner
The obsolete SA_xxx interrupt flags have been used despite the scheduled removal. Fixup the remaining users. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Jeff Garzik <jeff@garzik.org> Cc: Wim Van Sebroeck <wim@iguana.be> Cc: Roland Dreier <rolandd@cisco.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Greg KH <greg@kroah.com> Cc: Dave Airlie <airlied@linux.ie> Cc: James Simmons <jsimmons@infradead.org> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-09libata: add another IRQ calls (libata drivers)Akira Iguchi
This patch is against each libata driver. Two IRQ calls are added in ata_port_operations. - irq_on() is used to enable interrupts. - irq_ack() is used to acknowledge a device interrupt. In most drivers, ata_irq_on() and ata_irq_ack() are used for irq_on and irq_ack respectively. In some drivers (ex: ahci, sata_sil24) which cannot use them as is, ata_dummy_irq_on() and ata_dummy_irq_ack() are used. Signed-off-by: Kou Ishizaki <kou.ishizaki@toshiba.co.jp> Signed-off-by: Akira Iguchi <akira2.iguchi@toshiba.co.jp> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-09libata: convert to iomapTejun Heo
Convert libata core layer and LLDs to use iomap. * managed iomap is used. Pointer to pcim_iomap_table() is cached at host->iomap and used through out LLDs. This basically replaces host->mmio_base. * if possible, pcim_iomap_regions() is used Most iomap operation conversions are taken from Jeff Garzik <jgarzik@pobox.com>'s iomap branch. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-09libata: update libata LLDs to use devresTejun Heo
Update libata LLDs to use devres. Core layer is already converted to support managed LLDs. This patch simplifies initialization and fixes many resource related bugs in init failure and detach path. For example, all converted drivers now handle ata_device_add() failure gracefully without excessive resource rollback code. As most resources are released automatically on driver detach, many drivers don't need or can do with much simpler ->{port|host}_stop(). In general, stop callbacks are need iff port or host needs to be given commands to shut it down. Note that freezing is enough in many cases and ports are automatically frozen before being detached. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-12-03[PATCH] libata: kill unnecessary sht->max_sectors initializationsTejun Heo
sht->max_sectors is overrided unconditionally in ->slave_configure. There's no reason to set it to any value. Signed-off-by: Tejun Heo <htejun@gmail.com>
2006-12-01[PATCH] pci_module_init() conversion for pata_pdc2027xHenrik Kretzschmar
pci_module_init() conversion for pata_pdc2027x Signed-off-by: Henrik Kretzschmar <henne@nachtwindheim.de> Acked-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-11-29[PATCH] libata: add missing sht->slave_destroyTejun Heo
Many LLDs are missing sht->slave_destroy. The method is mandatory to support device warm unplugging (echo 1 > /sys/.../delete). Without it, libata might access released scsi device. Signed-off-by: Tejun Heo <htejun@gmail.com>
2006-09-28[libata] PCI ID table cleanup in various driversJeff Garzik
* Use PCI_VDEVICE() macro * const-ify pci_device_id table * standardize list terminator as "{ }" * convert spaces to tab in pci_driver struct (Alan-ism) * various minor whitespace cleanups Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-09-26[PATCH] libata-eh: Remove layering violation and duplication when handling ↵Alan Cox
absent ports This removes the layering violation where drivers have to fiddle directly with EH flags. Instead we now recognize -ENOENT means "no port" and do the handling in the core code. This also removes an instance of a call to disable the port, and an identical printk from each driver doing this. Even better - future rule changes will be in one place only. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-09-24[PATCH] pata_pdc2027x iomem annotationsAl Viro
2006-08-29[libata] Add a bunch of PATA drivers.Jeff Garzik
The vast majority of drivers and changes are from Alan Cox. Albert Lee contributed and maintains pata_pdc2027x. Adrian Bunk, Andrew Morton, and Tejun Heo contributed various minor fixes and updates. Signed-off-by: Jeff Garzik <jeff@garzik.org>
