path: root/drivers/ata/pata_scc.c
2008-06-04libata-sff: Fix oops reported in kerneloops.org for pnp devices with no ctlAlan Cox
- Make ata_sff_altstatus private so nobody uses it by mistake - Drop the 400nS delay from it Add ata_sff_irq_status - encapsulates the IRQ check logic This function keeps the existing behaviour for altstatus using devices. I actually suspect the logic was wrong before the changes but -rc isn't the time to play with that ata_sff_sync - ensure writes hit the device Really we want an io* operation for 'is posted' eg ioisposted(ioaddr) so that we can fix the nasty delay this causes on most systems. - ata_sff_pause - 400nS delay Ensure the command hit the device and delay 400nS - ata_sff_dma_pause Ensure the I/O hit the device and enforce an HDMA1:0 transition delay. Requires altstatus register exists, BUG if not so we don't risk corruption in MWDMA modes. (UDMA the checksum will save your backside in theory) The only other complication then is devices with their own handlers. rb532 can use dma_pause but scc needs to access its own altstatus register for internal errata workarounds so directly call the drivers own altstatus function. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-17libata: move link onlineness check out of softreset methodsTejun Heo
Currently, SATA softresets should do link onlineness check before actually performing SRST protocol but it doesn't really belong to softreset. This patch moves onlineness check in softreset to ata_eh_reset() and ata_eh_followup_srst_needed() to clean up code and help future sata_mv changes which need clear separation between SCR and TF accesses. sata_fsl is peculiar in that its softreset really isn't softreset but combination of hardreset and softreset. This patch adds dummy private ->prereset to keep the current behavior but the driver really should implement separate hard and soft resets and return -EAGAIN from hardreset if it should be follwed by softreset. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-17pata_scc: fix build breakageStephen Rothwell
drivers/ata/pata_scc.c: In function 'scc_bus_softreset': drivers/ata/pata_scc.c:594: error: 'deadlien' undeclared (first use in this function) drivers/ata/pata_scc.c:594: error: (Each undeclared identifier is reported only once drivers/ata/pata_scc.c:594: error: for each function it appears in.) Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-04-17libata: restructure SFF post-reset readiness waitsTejun Heo
Previously, post-softreset readiness is waited as follows. 1. ata_sff_wait_after_reset() waits for 150ms and then for ATA_TMOUT_FF_WAIT if status is 0xff and other conditions meet. 2. ata_bus_softreset() finishes with -ENODEV if status is still 0xff. If not, continue to #3. 3. ata_bus_post_reset() waits readiness of dev0 and/or dev1 depending on devmask using ata_sff_wait_ready(). And for post-hardreset readiness, 1. ata_sff_wait_after_reset() waits for 150ms and then for ATA_TMOUT_FF_WAIT if status is 0xff and other conditions meet. 2. sata_sff_hardreset waits for device readiness using ata_sff_wait_ready(). This patch merges and unifies post-reset readiness waits into ata_sff_wait_ready() and ata_sff_wait_after_reset(). ATA_TMOUT_FF_WAIT handling is merged into ata_sff_wait_ready(). If TF status is 0xff, link status is unknown and the port is SATA, it will continue polling till ATA_TMOUT_FF_WAIT. ata_sff_wait_after_reset() is updated to perform the following steps. 1. waits for 150ms. 2. waits for dev0 readiness using ata_sff_wait_ready(). Note that this is done regardless of devmask, as ata_sff_wait_ready() handles 0xff status correctly, this preserves the original behavior except that it may wait longer after softreset if link is online but status is 0xff. This behavior change is very unlikely to cause any actual difference and is intended. It brings softreset behavior to that of hardreset. 3. waits for dev1 readiness just the same way ata_bus_post_reset() did. Now both soft and hard resets call ata_sff_wait_after_reset() after reset to wait for readiness after resets. As ata_sff_wait_after_reset() contains calls to ->sff_dev_select(), explicit call near the end of sata_sff_hardreset() is removed. This change makes reset implementation simpler and more consistent. While at it, make the magical 150ms wait post-reset wait duration a constant and ata_sff_wait_ready() and ata_sff_wait_after_reset() take @link instead of @ap. This is to make them consistent with other reset helpers and ease core changes. pata_scc is updated accordingly. Signed-off-by: Tejun Heo <htejun@gmail.com>
2008-04-17libata: rename SFF port opsTejun Heo
Add sff_ prefix to SFF specific port ops. This rename is in preparation of separating SFF support out of libata core layer. This patch strictly renames ops and doesn't introduce any behavior difference. Signed-off-by: Tejun Heo <htejun@gmail.com>
2008-04-17libata: rename SFF functionsTejun Heo
SFF functions have confusing names. Some have sff prefix, some have bmdma, some std, some pci and some none. Unify the naming by... * SFF functions which are common to both BMDMA and non-BMDMA are prefixed with ata_sff_. * SFF functions which are specific to BMDMA are prefixed with ata_bmdma_. * SFF functions which are specific to PCI but apply to both BMDMA and non-BMDMA are prefixed with ata_pci_sff_. * SFF functions which are specific to PCI and BMDMA are prefixed with ata_pci_bmdma_. * Drop generic prefixes from LLD specific routines. For example, bfin_std_dev_select -> bfin_dev_select. The following renames are noteworthy. ata_qc_issue_prot() -> ata_sff_qc_issue() ata_pci_default_filter() -> ata_bmdma_mode_filter() ata_dev_try_classify() -> ata_sff_dev_classify() This rename is in preparation of separating SFF support out of libata core layer. This patch strictly renames functions and doesn't introduce any behavior difference. Signed-off-by: Tejun Heo <htejun@gmail.com>
2008-04-17libata annotationsAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-04-17pata_scc: fix compile warningTejun Heo
Missed one during mass conversion (dc14c0c5). Fix it. Spotted by Stephen Rothwell. Signed-off-by: Tejun Heo <htejun@gmail.com> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-04-17libata: kill ata_chk_status()Tejun Heo
ata_chk_status() just calls ops->check_status and it only adds confusion with other status functions. Kill it. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-04-17libata: make reset related methods proper port operationsTejun Heo
Currently reset methods are not specified directly in the ata_port_operations table. If a LLD wants to use custom reset methods, it should construct and use a error_handler which uses those reset methods. It's done this way for two reasons. First, the ops table already contained too many methods and adding four more of them would noticeably increase the amount of necessary boilerplate code all over low level drivers. Second, as ->error_handler uses those reset methods, it can get confusing. ie. By overriding ->error_handler, those reset ops can be made useless making layering a bit hazy. Now that ops table uses inheritance, the first problem doesn't exist anymore. The second isn't completely solved but is relieved by providing default values - most drivers can just override what it has implemented and don't have to concern itself about higher level callbacks. In fact, there currently is no driver which actually modifies error handling behavior. Drivers which override ->error_handler just wraps the standard error handler only to prepare the controller for EH. I don't think making ops layering strict has any noticeable benefit. This patch makes ->prereset, ->softreset, ->hardreset, ->postreset and their PMP counterparts propoer ops. Default ops are provided in the base ops tables and drivers are converted to override individual reset methods instead of creating custom error_handler. * ata_std_error_handler() doesn't use sata_std_hardreset() if SCRs aren't accessible. sata_promise doesn't need to use separate error_handlers for PATA and SATA anymore. * softreset is broken for sata_inic162x and sata_sx4. As libata now always prefers hardreset, this doesn't really matter but the ops are forced to NULL using ATA_OP_NULL for documentation purpose. * pata_hpt374 needs to use different prereset for the first and second PCI functions. This used to be done by branching from hpt374_error_handler(). The proper way to do this is to use separate ops and port_info tables for each function. Converted. Signed-off-by: Tejun Heo <htejun@gmail.com>
2008-04-17libata: implement and use ops inheritanceTejun Heo
libata lets low level drivers build ata_port_operations table and register it with libata core layer. This allows low level drivers high level of flexibility but also burdens them with lots of boilerplate entries. This becomes worse for drivers which support related similar controllers which differ slightly. They share most of the operations except for a few. However, the driver still needs to list all operations for each variant. This results in large number of duplicate entries, which is not only inefficient but also error-prone as it becomes very difficult to tell what the actual differences are. This duplicate boilerplates all over the low level drivers also make updating the core layer exteremely difficult and error-prone. When compounded with multi-branched development model, it ends up accumulating inconsistencies over time. Some of those inconsistencies cause immediate problems and fixed. Others just remain there dormant making maintenance increasingly difficult. To rectify the problem, this patch implements ata_port_operations inheritance. To allow LLDs to easily re-use their own ops tables overriding only specific methods, this patch implements poor man's class inheritance. An ops table has ->inherits field which can be set to any ops table as long as it doesn't create a loop. When the host is started, the inheritance chain is followed and any operation which isn't specified is taken from the nearest ancestor which has it specified. This operation is called finalization and done only once per an ops table and the LLD doesn't have to do anything special about it other than making the ops table non-const such that libata can update it. libata provides four base ops tables lower drivers can inherit from - base, sata, pmp, sff and bmdma. To avoid overriding these ops accidentaly, these ops are declared const and LLDs should always inherit these instead of using them directly. After finalization, all the ops table are identical before and after the patch except for setting .irq_handler to ata_interrupt in drivers which didn't use to. The .irq_handler doesn't have any actual effect and the field will soon be removed by later patch. * sata_sx4 is still using old style EH and currently doesn't take advantage of ops inheritance. Signed-off-by: Tejun Heo <htejun@gmail.com>
2008-04-17libata: implement and use SHT initializersTejun Heo
libata lets low level drivers build scsi_host_template and register it to the SCSI layer. This allows low level drivers high level of flexibility but also burdens them with lots of boilerplate entries. This patch implements SHT initializers which can be used to initialize all the boilerplate entries in a sht. Three variants of them are implemented - BASE, BMDMA and NCQ - for different types of drivers. Note that entries can be overriden by putting individual initializers after the helper macro. All sht tables are identical before and after this patch. Signed-off-by: Tejun Heo <htejun@gmail.com>
2008-02-15pata_scc.c: add thaw opsAkira Iguchi
This patch adds default thaw ops and fixes the freeze/thaw inconsistency. Signed-off-by: Kou Ishizaki <kou.ishizaki@toshiba.co.jp> Signed-off-by: Akira Iguchi <akira2.iguchi@toshiba.co.jp> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-01-23libata: update ->data_xfer hook for ATAPITejun Heo
Depending on how many bytes are transferred as a unit, PIO data transfer may consume more bytes than requested. Knowing how much data is consumed is necessary to determine how much is left for draining. This patch update ->data_xfer such that it returns the number of consumed bytes. While at it, it also makes the following changes. * s/adev/dev/ * use READ/WRITE constants for rw indication * misc clean ups Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-29libata: implement ata_wait_after_reset()Tejun Heo
On certain device/controller combination, 0xff status is asserted after reset and doesn't get cleared during 150ms post-reset wait. As 0xff status is interpreted as no device (for good reasons), this can lead to misdetection on such cases. This patch implements ata_wait_after_reset() which replaces the 150ms sleep and waits upto ATA_TMOUT_FF_WAIT if status is 0xff. ATA_TMOUT_FF_WAIT is currently 800ms which is enough for HHD424020F7SV00 to get detected but not enough for Quantum GoVault drive which is known to take upto 2s. Without parallel probing, spending 2s on 0xff port would incur too much delay on ata_piix's which use 0xff to indicate empty port and doesn't have SCR register, so GoVault needs to wait till parallel probing. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-12libata: Fix build failure on ppc64 drivers/ata/pata_scc.cSatyam Sharma
Little fixlets, that the build started erroring / warning about: drivers/ata/pata_scc.c: In function 'scc_bmdma_status': drivers/ata/pata_scc.c:734: error: structure has no member named 'active_tag' drivers/ata/pata_scc.c: In function 'scc_pata_prereset': drivers/ata/pata_scc.c:866: warning: passing arg 1 of 'ata_std_prereset' from incompatible pointer type drivers/ata/pata_scc.c: In function 'scc_error_handler': drivers/ata/pata_scc.c:908: warning: passing arg 2 of 'ata_bmdma_drive_eh' from incompatible pointer type drivers/ata/pata_scc.c:908: warning: passing arg 3 of 'ata_bmdma_drive_eh' from incompatible pointer type drivers/ata/pata_scc.c:908: warning: passing arg 5 of 'ata_bmdma_drive_eh' from incompatible pointer type make[2]: *** [drivers/ata/pata_scc.o] Error 1 Signed-off-by: Satyam Sharma <satyam@infradead.org> Cc: Alan Cox <alan@redhat.com> Cc: Mel Gorman <mel@skynet.ie> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-12libata: update ata_dev_try_classify() argumentsTejun Heo
Make ata_dev_try_classify() take a pointer to ata_device instead of ata_port/port_number combination for consistency and add @present argument. @present indicates whether the device seems present during reset. It's the result of TF access during softreset and link onlineness during hardreset. @present will be used to improve diagnostic failure handling. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-12libata: implement and use ata_port_desc() to report port configurationTejun Heo
Currently, port configuration reporting has the following problems. * iomapped address is reported instead of raw address * report contains irrelevant fields or lacks necessary fields for non-SFF controllers. * host->irq/irq2 are there just for reporting and hacky. This patch implements and uses ata_port_desc() and ata_port_pbar_desc(). ata_port_desc() is almost identical to ata_ehi_push_desc() except that it takes @ap instead of @ehi, has no locking requirement, can only be used during host initialization and " " is used as separator instead of ", ". ata_port_pbar_desc() is a helper to ease reporting of a PCI BAR or an offsetted address into it. LLD pushes whatever description it wants using the above two functions. The accumulated description is printed on host registration after "[S/P]ATA max MAX_XFERMODE ". SFF init helpers and ata_host_activate() automatically add descriptions for addresses and irq respectively, so only LLDs which isn't standard SFF need to add custom descriptions. In many cases, such controllers need to report different things anyway. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-12[libata] Remove ->port_disable() hookJeff Garzik
It was always set to ata_port_disable(). Removed the hook, and replaced the very few ap->ops->port_disable() callsites with direct calls to ata_port_disable(). Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-12[libata] Remove ->irq_ack() hook, and ata_dummy_irq_on()Jeff Garzik
* ->irq_ack() is redundant to what the irq handler already performs... chk-status + irq-clear. Furthermore, it is only called in one place, when screaming-irq-debugging is enabled, so we don't want to bother with a hook just for that. * ata_dummy_irq_on() is only ever used in drivers that have no callpath reaching ->irq_on(). Remove .irq_on hook from those drivers, and the now-unused ata_dummy_irq_on() Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-12libata-link: linkify PHY-related functionsTejun Heo
Make the following PHY-related functions to deal with ata_link instead of ata_port. * sata_print_link_status() * sata_down_spd_limit() * ata_set_sata_spd_limit() and friends * sata_link_debounce/resume() * sata_scr_valid/read/write/write_flush() * ata_link_on/offline() This patch introduces no behavior change. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-12libata-link: introduce ata_linkTejun Heo
Introduce ata_link. It abstracts PHY and sits between ata_port and ata_device. This new level of abstraction is necessary to support SATA Port Multiplier, which basically adds a bunch of links (PHYs) to a ATA host port. Fields related to command execution, spd_limit and EH are per-link and thus moved to ata_link. This patch only defines the host link. Multiple link handling will be added later. Also, a lot of ap->link derefences are added but many of them will be removed as each part is converted to deal directly with ata_link instead of ata_port. This patch introduces no behavior change. Signed-off-by: Tejun Heo <htejun@gmail.com> Cc: James Bottomley <James.Bottomley@SteelEye.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-08-31[libata] Bump driver versionsJeff Garzik
Bump the versions for drivers that were modified, but had not already had a version number bump. Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-20[libata] Fix reported task file values in sense dataPetr Vandrovec
ata_tf_read was setting HOB bit when lba48 command was submitted, but was not clearing it before reading "normal" data. As it is only place which sets HOB bit in control register, and register reads should not be affected by other bits, let's just clear it when we are done with reading upper bytes so non-48bit commands do not have to touch ctl at all. pata_scc suffered from same problem... Signed-off-by: Petr Vandrovec <petr@vandrovec.name> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-20pata_scc.c: small fixes (Workaround for errata A308)Akira Iguchi
This patch fixes some issues of the previous patch: - Use mode_filter() hook to limit ATAPI UDMA mode - "data loss" warning message - handling of udma_mask Signed-off-by: Kou Ishizaki <kou.ishizaki@toshiba.co.jp> Signed-off-by: Akira Iguchi <akira2.iguchi@toshiba.co.jp> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-12libata: remove irq_on from ata_bus_reset() and ata_std_postreset()Albert Lee
It seems irq_on() in ata_bus_reset() and ata_std_postreset() are leftover of the EDD reset. Remove them. Signed-off-by: Albert Lee <albertcc@tw.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-10pata_scc.c: Workaround for errata A308Akira Iguchi
Workaround for errata A308: turn down the UDMA mode and retry the DMA command when the data lost condition is detected. Signed-off-by: Kou Ishizaki <kou.ishizaki@toshiba.co.jp> Signed-off-by: Akira Iguchi <akira2.iguchi@toshiba.co.jp> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-05-25Fix build failure for drivers/ata/pata_scc.cTony Breeds
The commit d4b2bab4f26345ea1803feb23ea92fbe3f6b77bc added deadline support to prereset and reset methods to libbata the pata_scc driver wasn't converted. This patch is a naive attempt to bring this driver up to scratch. Build failures are: drivers/ata/pata_scc.c: In function 'scc_pata_prereset': drivers/ata/pata_scc.c:870: error: too few arguments to function 'ata_std_prereset' drivers/ata/pata_scc.c: In function 'scc_error_handler': drivers/ata/pata_scc.c:916: warning: passing argument 2 of 'ata_bmdma_drive_eh' from incompatible pointer type drivers/ata/pata_scc.c:916: warning: passing argument 3 of 'ata_bmdma_drive_eh' from incompatible pointer type drivers/ata/pata_scc.c: In function 'scc_pata_prereset': drivers/ata/pata_scc.c:871: warning: control reaches end of non-void function On a releated note scc_bus_post_reset() is (AFACT) identical to ata_bus_post_reset(), would a patch to make ata_bus_post_reset() assesable to drivers be accepted? Signed-off-by: Tony Breeds <tony@bakeyournoodle.com> Acked-by: Tejun Heo <htejun@gmail.com> Cc: Akira Iguchi <akira2.iguchi@toshiba.co.jp> Cc: Jeff Garzik <jgarzik@pobox.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-05-21libata: bump versionsJeff Garzik
2007-05-16pata_scc had been missed by ata_std_prereset() switchAl Viro
2007-05-11libata: reimplement suspend/resume support using sdev->manage_start_stopTejun Heo
Reimplement suspend/resume support using sdev->manage_start_stop. * Device suspend/resume is now SCSI layer's responsibility and the code is simplified a lot. * DPM is dropped. This also simplifies code a lot. Suspend/resume status is port-wide now. * ata_scsi_device_suspend/resume() and ata_dev_ready() removed. * Resume now has to wait for disk to spin up before proceeding. I couldn't find easy way out as libata is in EH waiting for the disk to be ready and sd is waiting for EH to complete to issue START_STOP. * sdev->manage_start_stop is set to 1 in ata_scsi_slave_config(). This fixes spindown on shutdown and suspend-to-disk. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-05-09pata_scc: fix compilationAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-04-28libata: convert the remaining PATA drivers to new init modelTejun Heo
Convert pdc_adma, pata_cs5520, pata_isapnp, pata_ixp4xx_cf, pata_legacy, pata_mpc52xx, pata_mpiix, pata_pcmcia, pata_pdc2027x, pata_platform, pata_qdi, pata_scc and pata_winbond to new init model. * init_one()'s now follow more consistent init order * cs5520 now registers one host with two ports, not two hosts. If any of the two ports are disabled, it's made dummy as other drivers do. Tested pdc_adma and pata_legacy. Both are as broken as before. The rest are compile tested only. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-03-02libata: add missing CONFIG_PM in LLDsTejun Heo
Add missing #ifdef CONFIG_PM conditionals around all PM related parts in libata LLDs. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-26[libata] Trim trailing whitespace.Jeff Garzik
No code changes. Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-23libata: fix remaining ap->idTejun Heo
Merge order left libata-acpi and pata_scc with remainling usage of ap->id. Kill superflous id printing and substitute the remaining ones with ap->print_id. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-21libata: PATA driver for CellebAkira Iguchi
This is the patch for PATA controller of Celleb. This driver uses the managed iomap (devres). Because this driver needs special taskfile accesses, there is a copy of ata_std_softreset(). ata_dev_try_classify() is exported so that it can be used in this function. Signed-off-by: Kou Ishizaki <kou.ishizaki@toshiba.co.jp> Signed-off-by: Akira Iguchi <akira2.iguchi@toshiba.co.jp> Signed-off-by: Jeff Garzik <jeff@garzik.org>
