path: root/drivers/ata/pdc_adma.c
2008-04-17libata: rename SFF functionsTejun Heo
SFF functions have confusing names. Some have sff prefix, some have bmdma, some std, some pci and some none. Unify the naming by... * SFF functions which are common to both BMDMA and non-BMDMA are prefixed with ata_sff_. * SFF functions which are specific to BMDMA are prefixed with ata_bmdma_. * SFF functions which are specific to PCI but apply to both BMDMA and non-BMDMA are prefixed with ata_pci_sff_. * SFF functions which are specific to PCI and BMDMA are prefixed with ata_pci_bmdma_. * Drop generic prefixes from LLD specific routines. For example, bfin_std_dev_select -> bfin_dev_select. The following renames are noteworthy. ata_qc_issue_prot() -> ata_sff_qc_issue() ata_pci_default_filter() -> ata_bmdma_mode_filter() ata_dev_try_classify() -> ata_sff_dev_classify() This rename is in preparation of separating SFF support out of libata core layer. This patch strictly renames functions and doesn't introduce any behavior difference. Signed-off-by: Tejun Heo <htejun@gmail.com>
2008-04-17pdc_adma: kill adma_host_stop()Tejun Heo
adma_host_stop() does the same thing that adma_port_stop() does. Kill it. Signed-off-by: Tejun Heo <htejun@gmail.com> Cc: Mark Lord <liml@rtr.ca> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-04-17pdc_adma: inherit ata_sff_port_opsTejun Heo
With the previous ops standardization, pdc_adma now can inherit ata_sff_port_ops instead of ata_base_port_ops. Make the change. Signed-off-by: Tejun Heo <htejun@gmail.com> Cc: Mark Lord <liml@rtr.ca> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-04-17libata/pdc_adma: make SFF EH handle non-bmdma SFF drivers and standardize ↵Tejun Heo
pdc_adma ops pdc_adma has interface similar to SFF but has its own DMA interface. It currently implements noop bmdma ops to avoid crashing ata_bmdma_error_handler() which BTW actually is EH for SFF drivers. This patch makes ata_bmdma_error_handler() dereference bmdma ops iff bmdma_addr is initialized as done in ata_bmdma_post_internal_cmd. This change allows pdc_adma to standardize ops and use SFF error_handler and post_internal_cmd. Signed-off-by: Tejun Heo <htejun@gmail.com> Cc: Mark Lord <liml@rtr.ca> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-04-17libata: make reset related methods proper port operationsTejun Heo
Currently reset methods are not specified directly in the ata_port_operations table. If a LLD wants to use custom reset methods, it should construct and use a error_handler which uses those reset methods. It's done this way for two reasons. First, the ops table already contained too many methods and adding four more of them would noticeably increase the amount of necessary boilerplate code all over low level drivers. Second, as ->error_handler uses those reset methods, it can get confusing. ie. By overriding ->error_handler, those reset ops can be made useless making layering a bit hazy. Now that ops table uses inheritance, the first problem doesn't exist anymore. The second isn't completely solved but is relieved by providing default values - most drivers can just override what it has implemented and don't have to concern itself about higher level callbacks. In fact, there currently is no driver which actually modifies error handling behavior. Drivers which override ->error_handler just wraps the standard error handler only to prepare the controller for EH. I don't think making ops layering strict has any noticeable benefit. This patch makes ->prereset, ->softreset, ->hardreset, ->postreset and their PMP counterparts propoer ops. Default ops are provided in the base ops tables and drivers are converted to override individual reset methods instead of creating custom error_handler. * ata_std_error_handler() doesn't use sata_std_hardreset() if SCRs aren't accessible. sata_promise doesn't need to use separate error_handlers for PATA and SATA anymore. * softreset is broken for sata_inic162x and sata_sx4. As libata now always prefers hardreset, this doesn't really matter but the ops are forced to NULL using ATA_OP_NULL for documentation purpose. * pata_hpt374 needs to use different prereset for the first and second PCI functions. This used to be done by branching from hpt374_error_handler(). The proper way to do this is to use separate ops and port_info tables for each function. Converted. Signed-off-by: Tejun Heo <htejun@gmail.com>
2008-04-17libata: implement and use ops inheritanceTejun Heo
libata lets low level drivers build ata_port_operations table and register it with libata core layer. This allows low level drivers high level of flexibility but also burdens them with lots of boilerplate entries. This becomes worse for drivers which support related similar controllers which differ slightly. They share most of the operations except for a few. However, the driver still needs to list all operations for each variant. This results in large number of duplicate entries, which is not only inefficient but also error-prone as it becomes very difficult to tell what the actual differences are. This duplicate boilerplates all over the low level drivers also make updating the core layer exteremely difficult and error-prone. When compounded with multi-branched development model, it ends up accumulating inconsistencies over time. Some of those inconsistencies cause immediate problems and fixed. Others just remain there dormant making maintenance increasingly difficult. To rectify the problem, this patch implements ata_port_operations inheritance. To allow LLDs to easily re-use their own ops tables overriding only specific methods, this patch implements poor man's class inheritance. An ops table has ->inherits field which can be set to any ops table as long as it doesn't create a loop. When the host is started, the inheritance chain is followed and any operation which isn't specified is taken from the nearest ancestor which has it specified. This operation is called finalization and done only once per an ops table and the LLD doesn't have to do anything special about it other than making the ops table non-const such that libata can update it. libata provides four base ops tables lower drivers can inherit from - base, sata, pmp, sff and bmdma. To avoid overriding these ops accidentaly, these ops are declared const and LLDs should always inherit these instead of using them directly. After finalization, all the ops table are identical before and after the patch except for setting .irq_handler to ata_interrupt in drivers which didn't use to. The .irq_handler doesn't have any actual effect and the field will soon be removed by later patch. * sata_sx4 is still using old style EH and currently doesn't take advantage of ops inheritance. Signed-off-by: Tejun Heo <htejun@gmail.com>
2008-04-17libata: implement and use SHT initializersTejun Heo
libata lets low level drivers build scsi_host_template and register it to the SCSI layer. This allows low level drivers high level of flexibility but also burdens them with lots of boilerplate entries. This patch implements SHT initializers which can be used to initialize all the boilerplate entries in a sht. Three variants of them are implemented - BASE, BMDMA and NCQ - for different types of drivers. Note that entries can be overriden by putting individual initializers after the helper macro. All sht tables are identical before and after this patch. Signed-off-by: Tejun Heo <htejun@gmail.com>
2008-04-17libata: implement and use ata_noop_irq_clear()Tejun Heo
->irq_clear() is used to clear IRQ bit of a SFF controller and isn't useful for drivers which don't use libata SFF HSM implementation. However, it's a required callback and many drivers implement their own noop version as placeholder. This patch implements ata_noop_irq_clear and use it to replace those custom placeholders. Also, SFF drivers which don't support BMDMA don't need to use ata_bmdma_irq_clear(). It becomes noop if BMDMA address isn't initialized. Convert them to use ata_noop_irq_clear(). Signed-off-by: Tejun Heo <htejun@gmail.com>
2008-01-23libata: convert to chained sgTejun Heo
libata used private sg iterator to handle padding sg. Now that sg can be chained, padding can be handled using standard sg ops. Convert to chained sg. * s/qc->__sg/qc->sg/ * s/qc->pad_sgent/qc->extra_sg[]/. Because chaining consumes one sg entry. There need to be two extra sg entries. The renaming is also for future addition of other extra sg entries. * Padding setup is moved into ata_sg_setup_extra() which is organized in a way that future addition of other extra sg entries is easy. * qc->orig_n_elem is unused and removed. * qc->n_elem now contains the number of sg entries that LLDs should map. qc->mapped_n_elem is added to carry the original number of mapped sgs for unmapping. * The last sg of the original sg list is used to chain to extra sg list. The original last sg is pointed to by qc->last_sg and the content is stored in qc->saved_last_sg. It's restored during ata_sg_clean(). * All sg walking code has been updated. Unnecessary assertions and checks for conditions the core layer already guarantees are removed. Signed-off-by: Tejun Heo <htejun@gmail.com> Cc: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-01-23libata: rename ATA_PROT_ATAPI_* to ATAPI_PROT_*Tejun Heo
ATA_PROT_ATAPI_* are ugly and naming schemes between ATA_PROT_* and ATA_PROT_ATAPI_* are inconsistent causing confusion. Rename them to ATAPI_PROT_* and make them consistent with ATA counterpart. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2007-10-29[libata] Address some checkpatch-spotted issuesJeff Garzik
2007-10-18[libata] kill ata_sg_is_last()Jeff Garzik
Short term, this works around a bug introduced by early sg-chaining work. Long term, removing this function eliminates a branch from a hot path loop in each scatter/gather table build. Also, as this code demonstrates, we don't need to _track_ the end of the s/g list, as long as we mark it in some way. And doing so programatically is nice. So its a useful cleanup, regardless of its short term effects. Based conceptually on a quick patch by Jens Axboe. Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2007-10-12libata: implement and use ata_port_desc() to report port configurationTejun Heo
Currently, port configuration reporting has the following problems. * iomapped address is reported instead of raw address * report contains irrelevant fields or lacks necessary fields for non-SFF controllers. * host->irq/irq2 are there just for reporting and hacky. This patch implements and uses ata_port_desc() and ata_port_pbar_desc(). ata_port_desc() is almost identical to ata_ehi_push_desc() except that it takes @ap instead of @ehi, has no locking requirement, can only be used during host initialization and " " is used as separator instead of ", ". ata_port_pbar_desc() is a helper to ease reporting of a PCI BAR or an offsetted address into it. LLD pushes whatever description it wants using the above two functions. The accumulated description is printed on host registration after "[S/P]ATA max MAX_XFERMODE ". SFF init helpers and ata_host_activate() automatically add descriptions for addresses and irq respectively, so only LLDs which isn't standard SFF need to add custom descriptions. In many cases, such controllers need to report different things anyway. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-12[libata] Remove ->port_disable() hookJeff Garzik
It was always set to ata_port_disable(). Removed the hook, and replaced the very few ap->ops->port_disable() callsites with direct calls to ata_port_disable(). Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-12[libata] Remove ->irq_ack() hook, and ata_dummy_irq_on()Jeff Garzik
* ->irq_ack() is redundant to what the irq handler already performs... chk-status + irq-clear. Furthermore, it is only called in one place, when screaming-irq-debugging is enabled, so we don't want to bother with a hook just for that. * ata_dummy_irq_on() is only ever used in drivers that have no callpath reaching ->irq_on(). Remove .irq_on hook from those drivers, and the now-unused ata_dummy_irq_on() Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-12libata-link: linkify config/EH related functionsTejun Heo
Make the following functions deal with ata_link instead of ata_port. * ata_set_mode() * ata_eh_autopsy() and related functions * ata_eh_report() and related functions * suspend/resume related functions * ata_eh_recover() and related functions Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-12libata-link: introduce ata_linkTejun Heo
Introduce ata_link. It abstracts PHY and sits between ata_port and ata_device. This new level of abstraction is necessary to support SATA Port Multiplier, which basically adds a bunch of links (PHYs) to a ATA host port. Fields related to command execution, spd_limit and EH are per-link and thus moved to ata_link. This patch only defines the host link. Multiple link handling will be added later. Also, a lot of ap->link derefences are added but many of them will be removed as each part is converted to deal directly with ata_link instead of ata_port. This patch introduces no behavior change. Signed-off-by: Tejun Heo <htejun@gmail.com> Cc: James Bottomley <James.Bottomley@SteelEye.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-12[libata] pdc_adma: convert to new exception handling (EH) frameworkJeff Garzik
2007-08-31[libata] Bump driver versionsJeff Garzik
Bump the versions for drivers that were modified, but had not already had a version number bump. Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-09[libata] Use ATA_UDMAx standard masks when filling driver's udma_mask infoJeff Garzik
The ATA_UDMAx masks are self-documenting, and far better than manually writing in the hex mask. Note that pata_it8213 mask differed from the comment. Added a FIXME there. Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-09[libata] pdc_adma: Reorder initializers with a couple structsJeff Garzik
Make it easier to verify which struct initializers are present, by presenting them in the order in which they are defined in the API header. Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-05-21libata: bump versionsJeff Garzik
2007-04-28libata: convert the remaining PATA drivers to new init modelTejun Heo
Convert pdc_adma, pata_cs5520, pata_isapnp, pata_ixp4xx_cf, pata_legacy, pata_mpc52xx, pata_mpiix, pata_pcmcia, pata_pdc2027x, pata_platform, pata_qdi, pata_scc and pata_winbond to new init model. * init_one()'s now follow more consistent init order * cs5520 now registers one host with two ports, not two hosts. If any of the two ports are disabled, it's made dummy as other drivers do. Tested pdc_adma and pata_legacy. Both are as broken as before. The rest are compile tested only. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-26[libata] bump versionsJeff Garzik
Bump versions based on changes submitted during 2.6.21 merge window. Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-21libata: s/ap->id/ap->print_id/gTejun Heo
ata_port has two different id fields - id and port_no. id is system-wide 1-based unique id for the port while port_no is 0-based host-wide port number. The former is primarily used to identify the ATA port to the user in printk messages while the latter is used in various places in libata core and LLDs to index the port inside the host. The two fields feel quite similar and sometimes ap->id is used in place of ap->port_no, which is very difficult to spot. This patch renames ap->id to ap->print_id to reduce the possibility of such bugs. Some printk messages are adjusted such that id string (ata%u[.%u]) isn't printed twice and/or to use ata_*_printk() instead of hardcoded id format. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-09libata: add another IRQ calls (libata drivers)Akira Iguchi
This patch is against each libata driver. Two IRQ calls are added in ata_port_operations. - irq_on() is used to enable interrupts. - irq_ack() is used to acknowledge a device interrupt. In most drivers, ata_irq_on() and ata_irq_ack() are used for irq_on and irq_ack respectively. In some drivers (ex: ahci, sata_sil24) which cannot use them as is, ata_dummy_irq_on() and ata_dummy_irq_ack() are used. Signed-off-by: Kou Ishizaki <kou.ishizaki@toshiba.co.jp> Signed-off-by: Akira Iguchi <akira2.iguchi@toshiba.co.jp> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-09libata: convert to iomapTejun Heo
Convert libata core layer and LLDs to use iomap. * managed iomap is used. Pointer to pcim_iomap_table() is cached at host->iomap and used through out LLDs. This basically replaces host->mmio_base. * if possible, pcim_iomap_regions() is used Most iomap operation conversions are taken from Jeff Garzik <jgarzik@pobox.com>'s iomap branch. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-09libata: update libata LLDs to use devresTejun Heo
Update libata LLDs to use devres. Core layer is already converted to support managed LLDs. This patch simplifies initialization and fixes many resource related bugs in init failure and detach path. For example, all converted drivers now handle ata_device_add() failure gracefully without excessive resource rollback code. As most resources are released automatically on driver detach, many drivers don't need or can do with much simpler ->{port|host}_stop(). In general, stop callbacks are need iff port or host needs to be given commands to shut it down. Note that freezing is enough in many cases and ports are automatically frozen before being detached. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-12-13[PATCH] Fix numerous kcalloc() calls, convert to kzalloc()Robert P. J. Day
All kcalloc() calls of the form "kcalloc(1,...)" are converted to the equivalent kzalloc() calls, and a few kcalloc() calls with the incorrect ordering of the first two arguments are fixed. Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Cc: Jeff Garzik <jeff@garzik.org> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Dominik Brodowski <linux@dominikbrodowski.net> Cc: Adam Belay <ambx1@neo.rr.com> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Greg KH <greg@kroah.com> Cc: Mark Fasheh <mark.fasheh@oracle.com> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-09-27[libata] Use new PCI_VDEVICE() macro to dramatically shorten ID listsJeff Garzik
2006-08-31[libata] Trim trailing whitespace.Jeff Garzik
2006-08-24libata: Grand renaming.Jeff Garzik
The biggest change is that ata_host_set is renamed to ata_host. * ata_host_set => ata_host * ata_probe_ent->host_flags => ata_probe_ent->port_flags * ata_probe_ent->host_set_flags => ata_probe_ent->_host_flags * ata_host_stats => ata_port_stats * ata_port->host => ata_port->scsi_host * ata_port->host_set => ata_port->host * ata_port_info->host_flags => ata_port_info->flags * ata_(.*)host_set(.*)\(\) => ata_\1host\2() The leading underscore in ata_probe_ent->_host_flags is to avoid reusing ->host_flags for different purpose. Currently, the only user of the field is libata-bmdma.c and probe_ent itself is scheduled to be removed. ata_port->host is reused for different purpose but this field is used inside libata core proper and of different type. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-08-10Move libata to drivers/ata.Jeff Garzik
