Currently, error handling code in this function calls the function
sata_dwc_port_stop, but this function has essentially no effect if hsdevp
has not been stored in ap, which is the case throughout this function. The
only effect is to print a debugging message including ap->print_id.
The code is rewritten to not call sata_dwc_port_stop, but instead to jump
to a local label that prints the original error message and the print_id
information. In the case where hsdevp has been already allocated (but not
yet stored in ap), this value is freed as well.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
// <smpl>
@exists@
local idexpression x;
statement S,S1;
expression E;
identifier fl;
expression *ptr != NULL;
x = \(kmalloc\|kzalloc\|kcalloc\)(...);
if (x == NULL) S
<... when != x
when != if (...) { <+...kfree(x)...+> }
when any
when != true x == NULL
x->fl
if (x == NULL) S1
if (...) { ... when != x
when forall
return \(0\|<+...x...+>\|ptr\);
* return ...;
// </smpl>
Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
Signed-off-by: Rakib Mullick <rakib.mullick@gmail.com>
Cc: Jeff Garzik <jgarzik@pobox.com>
Cc: David Airlie <airlied@linux.ie>
Cc: Tejun Heo <tj@kernel.org>
Cc: Joe Perches <joe@perches.com>
Fixed hsdev memleak on sata_dwc_probe() error.
As dma_dwc_exit() can be called multiple times without sata_dma_regs and
irq_dma changes, it might lead to double free on sequential
dma_dwc_exit() calls. So, zero these fields after free calls.
Signed-off-by: Vasiliy Kulikov <segoon@openwall.com>
The patch below fixes a typo.
* 'devicetree/next' of git://git.secretlab.ca/git/linux-2.6: (21 commits)
tty: serial: altera_jtaguart: Add device tree support
tty: serial: altera_uart: Add devicetree support
dt: eliminate of_platform_driver shim code
dt: Eliminate of_platform_{,un}register_driver
dt/serial: Eliminate users of of_platform_{,un}register_driver
dt/usb: Eliminate users of of_platform_{,un}register_driver
dt/video: Eliminate users of of_platform_{,un}register_driver
dt/net: Eliminate users of of_platform_{,un}register_driver
dt/sound: Eliminate users of of_platform_{,un}register_driver
dt/spi: Eliminate users of of_platform_{,un}register_driver
dt: uartlite: merge platform and of_platform driver bindings
dt: xilinx_hwicap: merge platform and of_platform driver bindings
ipmi: convert OF driver to platform driver
leds/leds-gpio: merge platform_driver with of_platform_driver
dt/sparc: Eliminate users of of_platform_{,un}register_driver
dt/powerpc: Eliminate users of of_platform_{,un}register_driver
dt/powerpc: move of_bus_type infrastructure to ibmebus
drivercore/dt: add a match table pointer to struct device
dt: Typo fix.
altera_ps2: Add devicetree support
All checks of ATA_FLAG_NO_LEGACY have been removed by the commits
c791c30670ea61f19eec390124128bf278e854fe ([libata] minor PCI IDE probe
fixes and cleanups) and f0d36efdc624beb3d9e29b9ab9e9537bf0f25d5b (libata:
update libata core layer to use devres), so I think it's time to finally
get rid of this flag...
Commit 0d5ff566779f894ca9937231a181eb31e4adff0e (libata: convert to iomap)
removed all checks of ATA_FLAG_MMIO but neglected to remove the flag itself.
Do it now, at last...
The driver erroneously uses ata_get_cmd_descript() not only for printing out
the ATA commands but also the protocol and DMA direction enums. Add functions
for properly printing those out...
The caller expects this function to return the DMA channel number on success,
while it returns 0...
Fix the following compilation errors/warnings:
drivers/ata/sata_dwc_460ex.c:43:1: warning: "DRV_NAME" redefined
In file included from drivers/ata/sata_dwc_460ex.c:38:
drivers/ata/libata.h:31:1: warning: this is the location of the previous
definition
drivers/ata/sata_dwc_460ex.c:44:1: warning: "DRV_VERSION" redefined
drivers/ata/libata.h:32:1: warning: this is the location of the previous
definition
drivers/ata/sata_dwc_460ex.c: In function `sata_dwc_exec_command_by_tag':
drivers/ata/sata_dwc_460ex.c:1356: warning: passing argument 1 of
`ata_get_cmd_descript' makes integer from pointer without a cast
drivers/ata/sata_dwc_460ex.c: In function `sata_dwc_qc_issue':
drivers/ata/sata_dwc_460ex.c:1476: warning: `err' is used uninitialized in this
function
drivers/ata/sata_dwc_460ex.c:1465: note: `err' was declared here
drivers/ata/sata_dwc_460ex.c:1493: warning: passing argument 1 of
drivers/ata/sata_dwc_460ex.c: In function `sata_dwc_qc_prep':
drivers/ata/sata_dwc_460ex.c:1537: error: `tag' undeclared (first use in this
function)
drivers/ata/sata_dwc_460ex.c:1537: error: (Each undeclared identifier is
reported only once
drivers/ata/sata_dwc_460ex.c:1537: error: for each function it appears in.)
NB: error only happens if DEBUG_NCQ macro is defined...
Somehow the driver was committed with a bare number for the PIO mask, instead
of ATA_PIO4...
Final step to eliminate of_platform_bus_type. They're all just
platform drivers now.
v2: fix type in pasemi_nand.c (thanks to Stephen Rothwell)
dma_dwc_xfer_setup() returns an int and "dma_chan" needs to be signed
for the error handling to work.
This patch enables the on-chip DWC SATA controller of the AppliedMicro
processor 460EX.
Signed-off-by: Rupjyoti Sarmah <rsarmah@appliedmicro.com>
Signed-off-by: Mark Miesfeld <mmiesfeld@appliedmicro.com>
Signed-off-by: Prodyut Hazarika <phazarika@appliedmicro.com>
