path: root/drivers/ata/sata_fsl.c
2009-01-16sata_fsl: Return non-zero on error in probe()Michal Sojka
while I was looking over kernel sources I've found this small bug. Formerly, zero was returned even if an error happened. Signed-off-by: Michal Sojka <sojkam1@fel.cvut.cz> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-09-29libata: make SCR access ops per-linkTejun Heo
Logically, SCR access ops should take @link; however, there was no compelling reason to convert all SCR access ops when adding @link abstraction as there's one-to-one mapping between a port and a non-PMP link. However, that assumption won't hold anymore with the scheduled addition of slave link. Make SCR access ops per-link. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-05-30[libata] sata_fsl: Fix broken driver, add port multiplier (PMP) supportAshish Kalra
The following commit (4c9bf4e799ce06a7378f1196587084802a414c03): libata: replace tf_read with qc_fill_rtf for non-SFF drivers Broke the sata_fsl.c driver in 2.6.26-rc. I know the following patch fixes the issue, it clearly also adds port multipler support. The current 2.6.26-rc driver is broken. On boot with debug enabled we get something like (w/o this patch): spurious interrupt!!, CC = 0x1 interrupt status 0x1 xx_scr_read, reg_in = 1 spurious interrupt!!, CC = 0x1 interrupt status 0x1 xx_scr_read, reg_in = 1 spurious interrupt!!, CC = 0x1 interrupt status 0x1 xx_scr_read, reg_in = 1 .. continues for ever. This change fixes this as a side effect of adding port multiplier support. Signed-off-by: Ashish Kalra <ashish.kalra@freescale.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-28typo in sata_fslAl Viro
it's ata_link, not ata_linke Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-17libata: move link onlineness check out of softreset methodsTejun Heo
Currently, SATA softresets should do link onlineness check before actually performing SRST protocol but it doesn't really belong to softreset. This patch moves onlineness check in softreset to ata_eh_reset() and ata_eh_followup_srst_needed() to clean up code and help future sata_mv changes which need clear separation between SCR and TF accesses. sata_fsl is peculiar in that its softreset really isn't softreset but combination of hardreset and softreset. This patch adds dummy private ->prereset to keep the current behavior but the driver really should implement separate hard and soft resets and return -EAGAIN from hardreset if it should be follwed by softreset. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-17libata: don't use ap->ioaddr in non-SFF driversTejun Heo
ap->ioaddr is to carry addresses for TF and BMDMA registers of a SFF controller, don't abuse it in non-SFF controllers. Signed-off-by: Tejun Heo <htejun@gmail.com>
2008-04-17libata: remove check_status from non-SFF driversTejun Heo
Now that all SFF stuff is separated out of core layer, core layer doesn't call ops->[alt_]check_status(). In fact, no one calls them for non-SFF drivers anymore. Kill them. Signed-off-by: Tejun Heo <htejun@gmail.com>
2008-04-17libata: replace tf_read with qc_fill_rtf for non-SFF driversTejun Heo
Now that all SFF stuff is separated out of core layer, core layer doesn't call ops->tf_read directly. It gets called only via ops->qc_fill_rtf() for non-SFF drivers. This patch directly implements private ops->qc_fill_rtf() for non-SFF controllers and kill ops->tf_read(). This is much cleaner for non-SFF controllers as some of them have to cache SFF register values in private data structure and report the cached values via ops->tf_read(). Also, ops->tf_read() gets nasty for controllers which don't have clear notion of TF registers when operation is not in progress. As this change makes default ops->qc_fill_rtf unnecessary, move ata_sff_qc_fill_rtf() form ata_base_port_ops to ata_sff_port_ops where it belongs. Signed-off-by: Tejun Heo <htejun@gmail.com>
2008-04-17libata: rename SFF port opsTejun Heo
Add sff_ prefix to SFF specific port ops. This rename is in preparation of separating SFF support out of libata core layer. This patch strictly renames ops and doesn't introduce any behavior difference. Signed-off-by: Tejun Heo <htejun@gmail.com>
2008-04-17libata: make reset related methods proper port operationsTejun Heo
Currently reset methods are not specified directly in the ata_port_operations table. If a LLD wants to use custom reset methods, it should construct and use a error_handler which uses those reset methods. It's done this way for two reasons. First, the ops table already contained too many methods and adding four more of them would noticeably increase the amount of necessary boilerplate code all over low level drivers. Second, as ->error_handler uses those reset methods, it can get confusing. ie. By overriding ->error_handler, those reset ops can be made useless making layering a bit hazy. Now that ops table uses inheritance, the first problem doesn't exist anymore. The second isn't completely solved but is relieved by providing default values - most drivers can just override what it has implemented and don't have to concern itself about higher level callbacks. In fact, there currently is no driver which actually modifies error handling behavior. Drivers which override ->error_handler just wraps the standard error handler only to prepare the controller for EH. I don't think making ops layering strict has any noticeable benefit. This patch makes ->prereset, ->softreset, ->hardreset, ->postreset and their PMP counterparts propoer ops. Default ops are provided in the base ops tables and drivers are converted to override individual reset methods instead of creating custom error_handler. * ata_std_error_handler() doesn't use sata_std_hardreset() if SCRs aren't accessible. sata_promise doesn't need to use separate error_handlers for PATA and SATA anymore. * softreset is broken for sata_inic162x and sata_sx4. As libata now always prefers hardreset, this doesn't really matter but the ops are forced to NULL using ATA_OP_NULL for documentation purpose. * pata_hpt374 needs to use different prereset for the first and second PCI functions. This used to be done by branching from hpt374_error_handler(). The proper way to do this is to use separate ops and port_info tables for each function. Converted. Signed-off-by: Tejun Heo <htejun@gmail.com>
2008-04-17libata: implement and use ops inheritanceTejun Heo
libata lets low level drivers build ata_port_operations table and register it with libata core layer. This allows low level drivers high level of flexibility but also burdens them with lots of boilerplate entries. This becomes worse for drivers which support related similar controllers which differ slightly. They share most of the operations except for a few. However, the driver still needs to list all operations for each variant. This results in large number of duplicate entries, which is not only inefficient but also error-prone as it becomes very difficult to tell what the actual differences are. This duplicate boilerplates all over the low level drivers also make updating the core layer exteremely difficult and error-prone. When compounded with multi-branched development model, it ends up accumulating inconsistencies over time. Some of those inconsistencies cause immediate problems and fixed. Others just remain there dormant making maintenance increasingly difficult. To rectify the problem, this patch implements ata_port_operations inheritance. To allow LLDs to easily re-use their own ops tables overriding only specific methods, this patch implements poor man's class inheritance. An ops table has ->inherits field which can be set to any ops table as long as it doesn't create a loop. When the host is started, the inheritance chain is followed and any operation which isn't specified is taken from the nearest ancestor which has it specified. This operation is called finalization and done only once per an ops table and the LLD doesn't have to do anything special about it other than making the ops table non-const such that libata can update it. libata provides four base ops tables lower drivers can inherit from - base, sata, pmp, sff and bmdma. To avoid overriding these ops accidentaly, these ops are declared const and LLDs should always inherit these instead of using them directly. After finalization, all the ops table are identical before and after the patch except for setting .irq_handler to ata_interrupt in drivers which didn't use to. The .irq_handler doesn't have any actual effect and the field will soon be removed by later patch. * sata_sx4 is still using old style EH and currently doesn't take advantage of ops inheritance. Signed-off-by: Tejun Heo <htejun@gmail.com>
2008-04-17libata: implement and use SHT initializersTejun Heo
libata lets low level drivers build scsi_host_template and register it to the SCSI layer. This allows low level drivers high level of flexibility but also burdens them with lots of boilerplate entries. This patch implements SHT initializers which can be used to initialize all the boilerplate entries in a sht. Three variants of them are implemented - BASE, BMDMA and NCQ - for different types of drivers. Note that entries can be overriden by putting individual initializers after the helper macro. All sht tables are identical before and after this patch. Signed-off-by: Tejun Heo <htejun@gmail.com>
2008-04-17libata: normalize port_info, port_operations and sht tablesTejun Heo
Over the time, port info, ops and sht structures developed quite a bit of inconsistencies. This patch updates drivers. * Enable/disable_pm callbacks added to all ahci ops tables. * Every driver for SFF controllers now uses ata_sff_port_start() instead of ata_port_start() unless the driver has custom implementation. * Every driver for SFF controllers now uses ata_pci_default_filter() unless the driver has custom implementation. * Removed an odd port_info->sht initialization from ata_piix.c. Likely a merge byproduct. * A port which has ATA_FLAG_SATA set doesn't need to set cable_detect to ata_cable_sata(). Remove it from via and mv port ops. * Some drivers had unnecessary .max_sectors initialization which is ignored and was missing .slave_destroy callback. Fixed. * Removed unnecessary sht initializations port_info's. * Removed onsolete scsi device suspend/resume callbacks from pata_bf54x. * No reason to set ata_pci_default_filter() and bmdma functions for PIO-only drivers. Remove those callbacks and replace ata_bmdma_irq_clear with ata_noop_irq_clear. * pata_platform sets port_start to ata_dummy_ret0. port_start can just be set to NULL. * sata_fsl supports NCQ but was missing qc_defer. Fixed. * pata_rb600_cf implements dummy port_start. Removed. Signed-off-by: Tejun Heo <htejun@gmail.com>
2008-04-17libata: implement and use ata_noop_irq_clear()Tejun Heo
->irq_clear() is used to clear IRQ bit of a SFF controller and isn't useful for drivers which don't use libata SFF HSM implementation. However, it's a required callback and many drivers implement their own noop version as placeholder. This patch implements ata_noop_irq_clear and use it to replace those custom placeholders. Also, SFF drivers which don't support BMDMA don't need to use ata_bmdma_irq_clear(). It becomes noop if BMDMA address isn't initialized. Convert them to use ata_noop_irq_clear(). Signed-off-by: Tejun Heo <htejun@gmail.com>
2008-04-17libata: kill ATA_LFLAG_SKIP_D2H_BSYTejun Heo
Some controllers can't reliably record the initial D2H FIS after SATA link is brought online for whatever reason. Advanced controllers which don't have traditional TF register based interface often have this problem as they don't really have the TF registers to update while the controller and link are being initialized. SKIP_D2H_BSY works around the problem by skipping the wait for device readiness before issuing SRST, so for such controllers libata issues SRST blindly and hopes for the best. Now that libata defaults to hardreset, this workaround is no longer necessary. For controllers which have support for hardreset, SRST is never issued by itself. It is only issued as follow-up SRST for device classification and PMP initialization, so there's no need to wait for it from prereset. Kill ATA_LFLAG_SKIP_D2H_BSY. Signed-off-by: Tejun Heo <htejun@gmail.com>
2008-04-17libata: prefer hardresetTejun Heo
When both soft and hard resets are available, libata preferred softreset till now. The logic behind it was to be softer to devices; however, this doesn't really help much. Rationales for the change: * BIOS may freeze lock certain things during boot and softreset can't unlock those. This by itself is okay but during operation PHY event or other error conditions can trigger hardreset and the device may end up with different configuration. For example, after a hardreset, previously unlockable HPA can be unlocked resulting in different device size and thus revalidation failure. Similar condition can occur during or after resume. * Certain ATAPI devices require hardreset to recover after certain error conditions. On PATA, this is done by issuing the DEVICE RESET command. On SATA, COMRESET has equivalent effect. The problem is that DEVICE RESET needs its own execution protocol. For SFF controllers with bare TF access, it can be easily implemented but more advanced controllers (e.g. ahci and sata_sil24) require specialized implementations. Simply using hardreset solves the problem nicely. * COMRESET initialization sequence is the norm in SATA land and many SATA devices don't work properly if only SRST is used. For example, some PMPs behave this way and libata works around by always issuing hardreset if the host supports PMP. Like the above example, libata has developed a number of mechanisms aiming to promote softreset to hardreset if softreset is not going to work. This approach is time consuming and error prone. Also, note that, dependingon how you read the specs, it could be argued that PMP fan-out ports require COMRESET to start operation. In fact, all the PMPs on the market except one don't work properly if COMRESET is not issued to fan-out ports after PMP reset. * COMRESET is an integral part of SATA connection and any working device should be able to handle COMRESET properly. After all, it's the way to signal hardreset during reboot. This is the most used and recommended (at least by the ahci spec) method of resetting devices. So, this patch makes libata prefer hardreset over softreset by making the following changes. * Rename ATA_EH_RESET_MASK to ATA_EH_RESET and use it whereever ATA_EH_{SOFT|HARD}RESET used to be used. ATA_EH_{SOFT|HARD}RESET is now only used to tell prereset whether soft or hard reset will be issued. * Strip out now unneeded promote-to-hardreset logics from ata_eh_reset(), ata_std_prereset(), sata_pmp_std_prereset() and other places. Signed-off-by: Tejun Heo <htejun@gmail.com>
2008-04-09ata/sata_fsl: Remove unused variable in sata_fsl_probeJohann Felix Soden
In sata_fsl_probe memory is allocated but never used or deallocated. Fixes: http://bugzilla.kernel.org/show_bug.cgi?id=10404 Thanks to Daniel Marjamäki for the bug report. Reported-by: Daniel Marjamäki <danielm77@spray.se> Signed-off-by: Johann Felix Soden <johfel@users.sourceforge.net> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-03-31[POWERPC] sata_fsl: reduce compatibility to fsl,pq-sataKim Phillips
as prescribed in Documentation/powerpc/booting-without-of.txt. Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Acked-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-02-24sata_fsl: fix build with ATA_VERBOSE_DEBUGAnton Vorontsov
This patch fixes build and few warnings when ATA_VERBOSE_DEBUG is defined: CC drivers/ata/sata_fsl.o drivers/ata/sata_fsl.c: In function ‘sata_fsl_fill_sg’: drivers/ata/sata_fsl.c:338: warning: format ‘%x’ expects type ‘unsigned int’, but argument 3 has type ‘void *’ drivers/ata/sata_fsl.c:338: warning: format ‘%x’ expects type ‘unsigned int’, but argument 4 has type ‘struct prde *’ drivers/ata/sata_fsl.c: In function ‘sata_fsl_qc_issue’: drivers/ata/sata_fsl.c:459: error: ‘csr_base’ undeclared (first use in this function) drivers/ata/sata_fsl.c:459: error: (Each undeclared identifier is reported only once drivers/ata/sata_fsl.c:459: error: for each function it appears in.) drivers/ata/sata_fsl.c: In function ‘sata_fsl_freeze’: drivers/ata/sata_fsl.c:525: error: ‘csr_base’ undeclared (first use in this function) make[2]: *** [drivers/ata/sata_fsl.o] Error 1 Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-02-19libata: eliminate the home grown dma padding in favour ofJames Bottomley
that provided by the block layer ATA requires that all DMA transfers begin and end on word boundaries. Because of this, a large amount of machinery grew up in ide to adjust scatterlists on this basis. However, as of 2.5, the block layer has a dma_alignment variable which ensures both the beginning and length of a DMA transfer are aligned on the dma_alignment boundary. Although the block layer does adjust the beginning of the transfer to ensure this happens, it doesn't actually adjust the length, it merely makes sure that space is allocated for transfers beyond the declared length. The upshot of this is that scatterlists may be padded to any size between the actual length and the length adjusted to the dma_alignment safely knowing that memory is allocated in this region. Right at the moment, SCSI takes the default dma_aligment which is on a 512 byte boundary. Note that this aligment only applies to transfers coming in from user space. However, since all kernel allocations are automatically aligned on a minimum of 32 byte boundaries, it is safe to adjust them in this manner as well. tj: * Adjusting sg after padding is done in block layer. Make libata set queue alignment correctly for ATAPI devices and drop broken sg mangling from ata_sg_setup(). * Use request->raw_data_len for ATAPI transfer chunk size. * Killed qc->raw_nbytes. * Separated out killing qc->n_iter. Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-02-06libata: kill now unused n_iter and fix sata_fslJames Bottomley
qc->n_iter was used for libata's own sg walking before sg chaining replaced it. During conversion, the field and its usage in sata_fsl were left behind. Kill the filed and update sata_fsl. tj: This was part of James's libata-use-block-layer-padding patch. Separated out by me. Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Tejun Heo <htejun@gmail.com> Cc: Li Yang <leoli@freescale.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-01-23fix drivers/ata/sata_fsl.c double-declakpm@linux-foundation.org
drivers/ata/sata_fsl.c: In function 'sata_fsl_fill_sg': drivers/ata/sata_fsl.c:337: error: redeclaration of 'si' with no linkage drivers/ata/sata_fsl.c:326: error: previous declaration of 'si' was here Reported-by: Olof Johansson <olof@lixom.net> Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-01-23libata: convert to chained sgTejun Heo
libata used private sg iterator to handle padding sg. Now that sg can be chained, padding can be handled using standard sg ops. Convert to chained sg. * s/qc->__sg/qc->sg/ * s/qc->pad_sgent/qc->extra_sg[]/. Because chaining consumes one sg entry. There need to be two extra sg entries. The renaming is also for future addition of other extra sg entries. * Padding setup is moved into ata_sg_setup_extra() which is organized in a way that future addition of other extra sg entries is easy. * qc->orig_n_elem is unused and removed. * qc->n_elem now contains the number of sg entries that LLDs should map. qc->mapped_n_elem is added to carry the original number of mapped sgs for unmapping. * The last sg of the original sg list is used to chain to extra sg list. The original last sg is pointed to by qc->last_sg and the content is stored in qc->saved_last_sg. It's restored during ata_sg_clean(). * All sg walking code has been updated. Unnecessary assertions and checks for conditions the core layer already guarantees are removed. Signed-off-by: Tejun Heo <htejun@gmail.com> Cc: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-01-23libata: implement protocol testsTejun Heo
Implement protocol tests - ata_is_atapi(), ata_is_nodata(), ata_is_pio(), ata_is_dma(), ata_is_ncq() and ata_is_data() and use them to replace is_atapi_taskfile() and hard coded protocol tests. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-11-03ata/sata_fsl: Remove ata_scsi_suspend/resume callbacksashish kalra
Signed-off-by: ashish kalra <ashish.kalra@freescale.com> Signed-off-by: Li Yang <leoli@freescale.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-11-03ata/sata_fsl: Remove sending LOG EXT command in sata_fsl_softreset()ashish kalra
2007-11-03ata/sata_fsl: Move MPC8315DS link speed limit workaround to specific ifdefashish kalra
2007-11-03ata/sata_fsl: cleanup style problemLi Yang
2007-11-03ata/sata_fsl: remove unneeded sata_fsl_hardreset()Jeff Garzik
Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: Li Yang <leoli@freescale.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-11-03ata/sata_fsl: remove unneeded on-stack copy of FISJeff Garzik
Remove unneeded on-stack copy of FIS in sata_fsl_cache_taskfile_from_d2h_fis(). Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: Li Yang <leoli@freescale.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-11-03ata/sata_fsl: cleanup needless casts to/from void __iomem *Jeff Garzik
2007-11-03ata/sata_fsl: Remove unnecessary SCR casesJeff Garzik
SCRs in the driver map to the standard values found in include/linux/ata.h, so no need for individual scr_read/scr_write case statements duplicating the natural value. Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: Li Yang <leoli@freescale.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-11-03ata/sata_fsl: Kill ata_sg_is_last()Li Yang
2007-11-03ata/sata_fsl: save irq in private data for irq unmappingLi Yang
Powerpc uses virtual irq which has to be unmapped. Signed-off-by: Li Yang <leoli@freescale.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-11-03ata/sata_fsl: Remove deprecated hooksLi Yang
2007-11-03ata/sata_fsl: Update for ata_link introductionLi Yang
Update the driver to use the newly added ata_link structure. Signed-off-by: Li Yang <leoli@freescale.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-17drivers/ata: add support to Freescale 3.0Gbps SATA ControllerLi Yang
This patch adds support for Freescale 3.0Gbps SATA Controller supporting Native Command Queueing(NCQ), device hotplug, and ATAPI. This controller can be found on MPC8315 and MPC8378. Signed-off-by: Ashish Kalra <ashish.kalra@freescale.com> Signed-off-by: Li Yang <leoli@freescale.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
