path: root/drivers/ata/sata_sil24.c
2011-07-23ata: Add and use ata_print_version_onceJoe Perches
Use a single mechanism to show driver version. Reduces text a tiny bit too. Remove uses of static int printed_version Add and use ata_print_version(const struct device *, const char *ver) and ata_print_version_once. $ size drivers/ata/built-in.* text data bss dec hex filename 544969 73893 116584 735446 b38d6 drivers/ata/built-in.allyesconfig.ata.o 543870 73893 116592 734355 b34ad drivers/ata/built-in.allyesconfig.print_once.o 141328 14689 4220 160237 271ed drivers/ata/built-in.defconfig.ata.o 141212 14689 4220 160121 27179 drivers/ata/built-in.defconfig.print_once.o Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2011-07-23ata: Convert ata_<foo>_printk(KERN_<LEVEL> to ata_<foo>_<level>Joe Perches
Saves text by removing nearly duplicated text format strings by creating ata_<foo>_printk functions and printf extension %pV. ata defconfig size shrinks ~5% (~8KB), allyesconfig ~2.5% (~13KB) Format string duplication comes from: #define ata_link_printk(link, lv, fmt, args...) do { \ if (sata_pmp_attached((link)->ap) || (link)->ap->slave_link) \ printk("%sata%u.%02u: "fmt, lv, (link)->ap->print_id, \ (link)->pmp , ##args); \ else \ printk("%sata%u: "fmt, lv, (link)->ap->print_id , ##args); \ } while(0) Coalesce long formats. $ size drivers/ata/built-in.* text data bss dec hex filename 544969 73893 116584 735446 b38d6 drivers/ata/built-in.allyesconfig.ata.o 558429 73893 117864 750186 b726a drivers/ata/built-in.allyesconfig.dev_level.o 141328 14689 4220 160237 271ed drivers/ata/built-in.defconfig.ata.o 149567 14689 4220 168476 2921c drivers/ata/built-in.defconfig.dev_level.o Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2011-07-23ata: Convert dev_printk(KERN_<LEVEL> to dev_<level>(Joe Perches
Saves a bit of text as the call takes fewer args. Coalesce a few formats. Convert a few bare printks to pr_cont. $ size drivers/ata/built-in.o* text data bss dec hex filename 558429 73893 117864 750186 b726a drivers/ata/built-in.o.allyesconfig.new 559574 73893 117888 751355 b76fb drivers/ata/built-in.o.allyesconfig.old 149567 14689 4220 168476 2921c drivers/ata/built-in.o.defconfig.new 149851 14689 4220 168760 29338 drivers/ata/built-in.o.defconfig.old Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2011-03-02libata: remove ATA_FLAG_NO_LEGACYSergei Shtylyov
All checks of ATA_FLAG_NO_LEGACY have been removed by the commits c791c30670ea61f19eec390124128bf278e854fe ([libata] minor PCI IDE probe fixes and cleanups) and f0d36efdc624beb3d9e29b9ab9e9537bf0f25d5b (libata: update libata core layer to use devres), so I think it's time to finally get rid of this flag... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2011-03-02libata: remove ATA_FLAG_MMIOSergei Shtylyov
Commit 0d5ff566779f894ca9937231a181eb31e4adff0e (libata: convert to iomap) removed all checks of ATA_FLAG_MMIO but neglected to remove the flag itself. Do it now, at last... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-10-21libata: add @ap to ata_wait_register() and introduce ata_msleep()Tejun Heo
Add optional @ap argument to ata_wait_register() and replace msleep() calls with ata_msleep() which take optional @ap in addition to the duration. These will be used to implement EH exclusion. This patch doesn't cause any behavior difference. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-06-10sata_sil24: Use memory barriers before issuing commandsCatalin Marinas
The data in the cmd_block buffers may reach the main memory after the writel() to the device ports. This patch introduces two calls to wmb() to ensure the relative ordering. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Tested-by: Colin Tuckley <colin.tuckley@arm.com> Cc: Tejun Heo <tj@kernel.org> Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-06-10sata_sil24: memset() overflowDan Carpenter
cb->atapi.cdb is an array of 16 u8 elements. The call too memset() would set the first part of the sge array to zero as well. It's not a packed struct. This one has been around for five years. I found it with Smatch. I think the reason no one has seen it before is because we normally call sil24_fill_sg() and that overwrites sge with proper information? Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-06-07sata_sil24: fix kernel panic on ARM caused by unaligned access in sata_sil24Colin Tuckley
The sata_sil24 driver has six 16-bit registers that are initialised with 32-bit writes. This cause a kernel panic on ARM due to the unaligned accesses which result. This patch changes the accesses to the correct 16-bit ones. Signed-off-by: Colin Tuckley <colin.tuckley@arm.com> Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-05-17libata: kill ATA_FLAG_DISABLEDTejun Heo
ATA_FLAG_DISABLED is only used by drivers which don't use ->error_handler framework and is largely broken. Its only meaningful function is to make irq handlers skip processing if the flag is set, which is largely useless and even harmful as it makes those ports more likely to cause IRQ storms. Kill ATA_FLAG_DISABLED and makes the callers disable attached devices instead. ata_port_probe() and ata_port_disable() which manipulate the flag are also killed. This simplifies condition check in IRQ handlers. While updating IRQ handlers, remove ap NULL check as libata guarantees consecutive port allocation (unoccupied ports are initialized with dummies) and long-obsolete ATA_QCFLAG_ACTIVE check (checked by ata_qc_from_tag()). Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-12-03sata_sil24: MSI support, disabled by defaultVivek Mahajan
The following patch adds MSI support. Some platforms may have broken MSI, so those are defaulted to use legacy PCI interrupts. Signed-off-by: Vivek Mahajan <vivek.mahajan@freescale.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-09-01sata_sil24: always set protocol override for non-ATAPI data commandsRobert Hancock
The sil24 hardware has a built-in list of commands and associated protocols that gets used by default to decide how to handle a given command. However, if the command is not known to the controller then it presumably assumes it to be a non-data command which then causes protocol mismatch errors if the device ends up requesting data transfer. The new DATA SET MANAGEMENT - Trim command causes this issue since it's a DMA data-out command. Since we should always know best what protocol the command should be using, let's just set the override flag to inform the controller what protocol to use for all non-ATAPI commands with data transfer. Signed-off-by: Robert Hancock <hancockrwd@gmail.com> Tested-by: Mark Lord <liml@rtr.ca> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-04-07dma-mapping: replace all DMA_32BIT_MASK macro with DMA_BIT_MASK(32)Yang Hongyang
Replace all DMA_32BIT_MASK macro with DMA_BIT_MASK(32) Signed-off-by: Yang Hongyang<yanghy@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07dma-mapping: replace all DMA_64BIT_MASK macro with DMA_BIT_MASK(64)Yang Hongyang
Replace all DMA_64BIT_MASK macro with DMA_BIT_MASK(64) Signed-off-by: Yang Hongyang<yanghy@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-24[libata] convert drivers to use ata.h mode mask definesErik Inge Bolsø
No functional changes in this patch. Signed-off-by: Erik Inge Bolsø <knan-lkml@anduin.net> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-01-08sata_sil24: remove unused sil24_port_multiplierGrant Grundler
AFAICT, struct sil24_port_multiplier isn't used anywhere. Remove it. Signed-off-by: Grant Grundler <grundler@google.com> Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-10-27sata_sil24: configure max read request size to 4kTejun Heo
Due to request posting limitations, bandwidth of sil3132 is limited to around 120MB/s with the minimum pci-e payload size (128bytes) which is used by most consumer systems. However, write throughput can be slightly (~3%) increased by increasing the max read requeset size. Configure it to 4k which is the maximum supported. This optimization is also done by SIMG's windows driver. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-09-29libata: make SCR access ops per-linkTejun Heo
Logically, SCR access ops should take @link; however, there was no compelling reason to convert all SCR access ops when adding @link abstraction as there's one-to-one mapping between a port and a non-PMP link. However, that assumption won't hold anymore with the scheduled addition of slave link. Make SCR access ops per-link. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-07-04sata_sil24: add DID for another adaptec flavorTejun Heo
There's another DID used for Adaptec card. Add it. Reported by Travis Read. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Travis Read <ics@dark.net.au> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-05-19sata_sil24: don't use NCQ if marvell 4140 PMP is attachedTejun Heo
When 4140 PMP is attached to sil24, NCQ commands to fan out port 1 and 2 (0 based) often stall if commands are in progress to other ports. I've tried a number of things but can't tell what's going on. It never happens w/ ahci and reportedly sata_mv which can issue NCQ commands to multiple devices simultaneously like sil24 does. Disable NCQ for devices behind 4140 PMP for the time being. Signed-off-by: Tejun Heo <htejun@gmail.com> Cc: Mark Lord <liml@rtr.ca> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-17libata: move link onlineness check out of softreset methodsTejun Heo
Currently, SATA softresets should do link onlineness check before actually performing SRST protocol but it doesn't really belong to softreset. This patch moves onlineness check in softreset to ata_eh_reset() and ata_eh_followup_srst_needed() to clean up code and help future sata_mv changes which need clear separation between SCR and TF accesses. sata_fsl is peculiar in that its softreset really isn't softreset but combination of hardreset and softreset. This patch adds dummy private ->prereset to keep the current behavior but the driver really should implement separate hard and soft resets and return -EAGAIN from hardreset if it should be follwed by softreset. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-17libata: kill dead code paths in reset pathTejun Heo
Some code paths which had been made obsolete by recent reset simplification were still around. Kill them. * ata_eh_reset() checked for ATA_DEV_UNKNOWN to determine classification failure. This is no longer applicable. * ata_do_reset() should convert ATA_DEV_UNKNOWN to ATA_DEV_NONE regardless of reset result (e.g. -EAGAIN). * LLDs don't need to convert ATA_DEV_UNKNOWN to ATA_DEV_NONE. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-17libata: implement PMP helpersTejun Heo
Implement helpers to test whether PMP is supported, attached and determine pmp number to use when issuing SRST to a link. While at it, move ata_is_host_link() so that it's together with the two new PMP helpers. This change simplifies LLDs and helps making PMP support optional. Signed-off-by: Tejun Heo <htejun@gmail.com>
2008-04-17libata: don't use ap->ioaddr in non-SFF driversTejun Heo
ap->ioaddr is to carry addresses for TF and BMDMA registers of a SFF controller, don't abuse it in non-SFF controllers. Signed-off-by: Tejun Heo <htejun@gmail.com>
2008-04-17libata: remove check_status from non-SFF driversTejun Heo
Now that all SFF stuff is separated out of core layer, core layer doesn't call ops->[alt_]check_status(). In fact, no one calls them for non-SFF drivers anymore. Kill them. Signed-off-by: Tejun Heo <htejun@gmail.com>
2008-04-17libata: replace tf_read with qc_fill_rtf for non-SFF driversTejun Heo
Now that all SFF stuff is separated out of core layer, core layer doesn't call ops->tf_read directly. It gets called only via ops->qc_fill_rtf() for non-SFF drivers. This patch directly implements private ops->qc_fill_rtf() for non-SFF controllers and kill ops->tf_read(). This is much cleaner for non-SFF controllers as some of them have to cache SFF register values in private data structure and report the cached values via ops->tf_read(). Also, ops->tf_read() gets nasty for controllers which don't have clear notion of TF registers when operation is not in progress. As this change makes default ops->qc_fill_rtf unnecessary, move ata_sff_qc_fill_rtf() form ata_base_port_ops to ata_sff_port_ops where it belongs. Signed-off-by: Tejun Heo <htejun@gmail.com>
2008-04-17libata: drop @finish_qc from ata_qc_complete_multiple()Tejun Heo
ata_qc_complete_multiple() took @finish_qc and called it on every qc before completing it. This was to give opportunity to update TF cache before ata_qc_complete() tries to fill result_tf. Now that result TF is a separate operation, this is no longer necessary. Update sata_sil24, which was the only user of this mechanism, such that it implements its own ops->qc_fill_rtf() and drop @finish_qc from ata_qc_complete_multiple(). Signed-off-by: Tejun Heo <htejun@gmail.com>
2008-04-17libata: move PMP SCR access failure during reset to ata_eh_reset()Tejun Heo
If PMP fan-out reset fails and SCR isn't accessible, PMP should be reset. This used to be tested by sata_pmp_std_hardreset() and communicated to EH by -ERESTART. However, this logic is generic and doesn't really have much to do with specific hardreset implementation. This patch moves SCR access failure detection logic to ata_eh_reset() where it belongs. As this makes sata_pmp_std_hardreset() identical to sata_std_hardreset(), the function is killed and replaced with the standard method. Signed-off-by: Tejun Heo <htejun@gmail.com>
2008-04-17libata: rename SFF port opsTejun Heo
Add sff_ prefix to SFF specific port ops. This rename is in preparation of separating SFF support out of libata core layer. This patch strictly renames ops and doesn't introduce any behavior difference. Signed-off-by: Tejun Heo <htejun@gmail.com>
2008-04-17libata: make reset related methods proper port operationsTejun Heo
Currently reset methods are not specified directly in the ata_port_operations table. If a LLD wants to use custom reset methods, it should construct and use a error_handler which uses those reset methods. It's done this way for two reasons. First, the ops table already contained too many methods and adding four more of them would noticeably increase the amount of necessary boilerplate code all over low level drivers. Second, as ->error_handler uses those reset methods, it can get confusing. ie. By overriding ->error_handler, those reset ops can be made useless making layering a bit hazy. Now that ops table uses inheritance, the first problem doesn't exist anymore. The second isn't completely solved but is relieved by providing default values - most drivers can just override what it has implemented and don't have to concern itself about higher level callbacks. In fact, there currently is no driver which actually modifies error handling behavior. Drivers which override ->error_handler just wraps the standard error handler only to prepare the controller for EH. I don't think making ops layering strict has any noticeable benefit. This patch makes ->prereset, ->softreset, ->hardreset, ->postreset and their PMP counterparts propoer ops. Default ops are provided in the base ops tables and drivers are converted to override individual reset methods instead of creating custom error_handler. * ata_std_error_handler() doesn't use sata_std_hardreset() if SCRs aren't accessible. sata_promise doesn't need to use separate error_handlers for PATA and SATA anymore. * softreset is broken for sata_inic162x and sata_sx4. As libata now always prefers hardreset, this doesn't really matter but the ops are forced to NULL using ATA_OP_NULL for documentation purpose. * pata_hpt374 needs to use different prereset for the first and second PCI functions. This used to be done by branching from hpt374_error_handler(). The proper way to do this is to use separate ops and port_info tables for each function. Converted. Signed-off-by: Tejun Heo <htejun@gmail.com>
2008-04-17libata: implement and use ops inheritanceTejun Heo
libata lets low level drivers build ata_port_operations table and register it with libata core layer. This allows low level drivers high level of flexibility but also burdens them with lots of boilerplate entries. This becomes worse for drivers which support related similar controllers which differ slightly. They share most of the operations except for a few. However, the driver still needs to list all operations for each variant. This results in large number of duplicate entries, which is not only inefficient but also error-prone as it becomes very difficult to tell what the actual differences are. This duplicate boilerplates all over the low level drivers also make updating the core layer exteremely difficult and error-prone. When compounded with multi-branched development model, it ends up accumulating inconsistencies over time. Some of those inconsistencies cause immediate problems and fixed. Others just remain there dormant making maintenance increasingly difficult. To rectify the problem, this patch implements ata_port_operations inheritance. To allow LLDs to easily re-use their own ops tables overriding only specific methods, this patch implements poor man's class inheritance. An ops table has ->inherits field which can be set to any ops table as long as it doesn't create a loop. When the host is started, the inheritance chain is followed and any operation which isn't specified is taken from the nearest ancestor which has it specified. This operation is called finalization and done only once per an ops table and the LLD doesn't have to do anything special about it other than making the ops table non-const such that libata can update it. libata provides four base ops tables lower drivers can inherit from - base, sata, pmp, sff and bmdma. To avoid overriding these ops accidentaly, these ops are declared const and LLDs should always inherit these instead of using them directly. After finalization, all the ops table are identical before and after the patch except for setting .irq_handler to ata_interrupt in drivers which didn't use to. The .irq_handler doesn't have any actual effect and the field will soon be removed by later patch. * sata_sx4 is still using old style EH and currently doesn't take advantage of ops inheritance. Signed-off-by: Tejun Heo <htejun@gmail.com>
2008-04-17libata: implement and use SHT initializersTejun Heo
libata lets low level drivers build scsi_host_template and register it to the SCSI layer. This allows low level drivers high level of flexibility but also burdens them with lots of boilerplate entries. This patch implements SHT initializers which can be used to initialize all the boilerplate entries in a sht. Three variants of them are implemented - BASE, BMDMA and NCQ - for different types of drivers. Note that entries can be overriden by putting individual initializers after the helper macro. All sht tables are identical before and after this patch. Signed-off-by: Tejun Heo <htejun@gmail.com>
2008-04-17libata: implement and use ata_noop_irq_clear()Tejun Heo
->irq_clear() is used to clear IRQ bit of a SFF controller and isn't useful for drivers which don't use libata SFF HSM implementation. However, it's a required callback and many drivers implement their own noop version as placeholder. This patch implements ata_noop_irq_clear and use it to replace those custom placeholders. Also, SFF drivers which don't support BMDMA don't need to use ata_bmdma_irq_clear(). It becomes noop if BMDMA address isn't initialized. Convert them to use ata_noop_irq_clear(). Signed-off-by: Tejun Heo <htejun@gmail.com>
2008-04-17libata: kill ATA_LFLAG_SKIP_D2H_BSYTejun Heo
Some controllers can't reliably record the initial D2H FIS after SATA link is brought online for whatever reason. Advanced controllers which don't have traditional TF register based interface often have this problem as they don't really have the TF registers to update while the controller and link are being initialized. SKIP_D2H_BSY works around the problem by skipping the wait for device readiness before issuing SRST, so for such controllers libata issues SRST blindly and hopes for the best. Now that libata defaults to hardreset, this workaround is no longer necessary. For controllers which have support for hardreset, SRST is never issued by itself. It is only issued as follow-up SRST for device classification and PMP initialization, so there's no need to wait for it from prereset. Kill ATA_LFLAG_SKIP_D2H_BSY. Signed-off-by: Tejun Heo <htejun@gmail.com>
2008-04-17libata: prefer hardresetTejun Heo
When both soft and hard resets are available, libata preferred softreset till now. The logic behind it was to be softer to devices; however, this doesn't really help much. Rationales for the change: * BIOS may freeze lock certain things during boot and softreset can't unlock those. This by itself is okay but during operation PHY event or other error conditions can trigger hardreset and the device may end up with different configuration. For example, after a hardreset, previously unlockable HPA can be unlocked resulting in different device size and thus revalidation failure. Similar condition can occur during or after resume. * Certain ATAPI devices require hardreset to recover after certain error conditions. On PATA, this is done by issuing the DEVICE RESET command. On SATA, COMRESET has equivalent effect. The problem is that DEVICE RESET needs its own execution protocol. For SFF controllers with bare TF access, it can be easily implemented but more advanced controllers (e.g. ahci and sata_sil24) require specialized implementations. Simply using hardreset solves the problem nicely. * COMRESET initialization sequence is the norm in SATA land and many SATA devices don't work properly if only SRST is used. For example, some PMPs behave this way and libata works around by always issuing hardreset if the host supports PMP. Like the above example, libata has developed a number of mechanisms aiming to promote softreset to hardreset if softreset is not going to work. This approach is time consuming and error prone. Also, note that, dependingon how you read the specs, it could be argued that PMP fan-out ports require COMRESET to start operation. In fact, all the PMPs on the market except one don't work properly if COMRESET is not issued to fan-out ports after PMP reset. * COMRESET is an integral part of SATA connection and any working device should be able to handle COMRESET properly. After all, it's the way to signal hardreset during reboot. This is the most used and recommended (at least by the ahci spec) method of resetting devices. So, this patch makes libata prefer hardreset over softreset by making the following changes. * Rename ATA_EH_RESET_MASK to ATA_EH_RESET and use it whereever ATA_EH_{SOFT|HARD}RESET used to be used. ATA_EH_{SOFT|HARD}RESET is now only used to tell prereset whether soft or hard reset will be issued. * Strip out now unneeded promote-to-hardreset logics from ata_eh_reset(), ata_std_prereset(), sata_pmp_std_prereset() and other places. Signed-off-by: Tejun Heo <htejun@gmail.com>
2008-02-19libata: eliminate the home grown dma padding in favour ofJames Bottomley
that provided by the block layer ATA requires that all DMA transfers begin and end on word boundaries. Because of this, a large amount of machinery grew up in ide to adjust scatterlists on this basis. However, as of 2.5, the block layer has a dma_alignment variable which ensures both the beginning and length of a DMA transfer are aligned on the dma_alignment boundary. Although the block layer does adjust the beginning of the transfer to ensure this happens, it doesn't actually adjust the length, it merely makes sure that space is allocated for transfers beyond the declared length. The upshot of this is that scatterlists may be padded to any size between the actual length and the length adjusted to the dma_alignment safely knowing that memory is allocated in this region. Right at the moment, SCSI takes the default dma_aligment which is on a 512 byte boundary. Note that this aligment only applies to transfers coming in from user space. However, since all kernel allocations are automatically aligned on a minimum of 32 byte boundaries, it is safe to adjust them in this manner as well. tj: * Adjusting sg after padding is done in block layer. Make libata set queue alignment correctly for ATAPI devices and drop broken sg mangling from ata_sg_setup(). * Use request->raw_data_len for ATAPI transfer chunk size. * Killed qc->raw_nbytes. * Separated out killing qc->n_iter. Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-01-23libata: convert to chained sgTejun Heo
libata used private sg iterator to handle padding sg. Now that sg can be chained, padding can be handled using standard sg ops. Convert to chained sg. * s/qc->__sg/qc->sg/ * s/qc->pad_sgent/qc->extra_sg[]/. Because chaining consumes one sg entry. There need to be two extra sg entries. The renaming is also for future addition of other extra sg entries. * Padding setup is moved into ata_sg_setup_extra() which is organized in a way that future addition of other extra sg entries is easy. * qc->orig_n_elem is unused and removed. * qc->n_elem now contains the number of sg entries that LLDs should map. qc->mapped_n_elem is added to carry the original number of mapped sgs for unmapping. * The last sg of the original sg list is used to chain to extra sg list. The original last sg is pointed to by qc->last_sg and the content is stored in qc->saved_last_sg. It's restored during ata_sg_clean(). * All sg walking code has been updated. Unnecessary assertions and checks for conditions the core layer already guarantees are removed. Signed-off-by: Tejun Heo <htejun@gmail.com> Cc: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-01-23libata: implement protocol testsTejun Heo
Implement protocol tests - ata_is_atapi(), ata_is_nodata(), ata_is_pio(), ata_is_dma(), ata_is_ncq() and ata_is_data() and use them to replace is_atapi_taskfile() and hard coded protocol tests. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-01-14sata_sil24: freeze on non-dev errors reported via CERRTejun Heo
CERR reports errors detected during executing a command. This doesn't mean the error is tied to the command and can be recovered by just issuing it again. Many of the errors are fatal port-wide connditions including HSM violation, host bus error and ATA bus error and require freezing and port reset. The freezing part wasn't implemented previously. This used to be okay because port resets were scheduled anyway and EH eventually resets and recovers the port. With PMP support added, this is no longer true. The error condition and recover actions are attributed to the fan-out port and the host port condition isn't properly recovered leading to EH failures. This patch makes CERR errors which require resets to freeze the port. This will force host port reset and proper recovery. Signed-off-by: Tejun Heo <htejun@gmail.com> Cc: Andrew Ryder <tireman@shaw.ca> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-01-14sata_sil24: fix stupid typoTejun Heo
Fix stupid typo. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-01-10sata_sil24: prevent hba lockup when pass-through ATA commands are usedGwendal Grignou
Fix commands timeout with Sil3124/3132 based HBA when pass-through ATA commands [where ATA_QCFLAG_RESULT_TF is set] are used while other commands are active on other devices connected to the same port with a Port Multiplier. Due to a hardware bug, these commands must be sent alone, like ATAPI commands. Signed-off-by: Gwendal Grignou <gwendal@google.com> Acked-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-11-23sata_sil24: fix sg table sizingTejun Heo
sil24 unnecessarily used LIBATA_MAX_PRD and ATAPI sg table was short by one entry which might cause very obscure problems. This patch updates sg table sizing such that * One full page is used for PRB + sg table. On 4k page, this results in 253 sg's. * Make ATAPI sg block properly sized. * Make build fail if command block size doesn't equal PAGE_SIZE. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-30libata: stop being overjealous about non-IO commandsTejun Heo
libata EH always revalidated device and retried failed command after error except for ATAPI CCs. This is unnecessary and hinders with users issuing direct commands. This patch makes the following changes. * Make sata_sil24 not request ATA_EH_REVALIDATE on device errors. sil24 is the only driver which does this. All others let libata EH core code decide. * Don't request revalidation after device error of non-IO command. Revalidation doesn't really help anybody. As ATA_EH_REVALIDATE isn't set by default, there's no reason to clear it after sense data is read. Kill ATA_EH_REVALIDATE clearing code while at it. * Don't retry non-IO command after device error. Device has rejected the command. There's no point in retrying. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-29[libata] Address some checkpatch-spotted issuesJeff Garzik
2007-10-18[libata] kill ata_sg_is_last()Jeff Garzik
Short term, this works around a bug introduced by early sg-chaining work. Long term, removing this function eliminates a branch from a hot path loop in each scatter/gather table build. Also, as this code demonstrates, we don't need to _track_ the end of the s/g list, as long as we mark it in some way. And doing so programatically is nice. So its a useful cleanup, regardless of its short term effects. Based conceptually on a quick patch by Jens Axboe. Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2007-10-12libata: use ata_exec_internal() for PMP register accessTejun Heo
PMP registers used to be accessed with dedicated accessors ->pmp_read and ->pmp_write. During reset, those callbacks are called with the port frozen so they should be able to run without depending on interrupt delivery. To achieve this, they were implemented polling. However, as resetting the host port makes the PMP to isolate fan-out ports until SError.X is cleared, resetting fan-out ports while port is frozen doesn't buy much additional safety. This patch updates libata PMP support such that PMP registers are accessed using regular ata_exec_internal() mechanism and kills ->pmp_read/write() callbacks. The following changes are made. * PMP access helpers - sata_pmp_read_init_tf(), sata_pmp_read_val(), sata_pmp_write_init_tf() are folded into sata_pmp_read/write() which are now standalone PMP register access functions. * sata_pmp_read/write() returns err_mask instead of rc. This is consistent with other functions which issue internal commands and allows more detailed error reporting. * ahci interrupt handler is modified to ignore BAD_PMP and spurious/illegal completion IRQs while reset is in progress. These conditions are expected during reset. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-12sata_sil24: implement PORT_RSTTejun Heo
As DEV_RST (hardreset) sometimes fail to recover the controller (especially after PMP DMA CS errata). In such cases, perform PORT_RST prior to DEV_RST. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-12sata_sil24: implement PMP supportTejun Heo
Implement PMP support. sil24 supports full FIS-switching. However, it has a PMP DMA CS errata which requires port-wide resetting if commands are outstanding to three or more devices when an error occurs on one of them. ATAPI commands often result in CHECK SENSE and it's crucial to not reset them before fetching sense data. Unfortunately, ATAPI CHECK SENSE causes a lot of problem if command is outstanding to any other device usually resulting in port-wide reset. So, sata_sil24 implements sil24_qc_defer() which guarantees ATAPI command is run by itself. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-12libata-pmp-prep: implement sata_async_notification()Tejun Heo
AN serves multiple purposes. For ATAPI, it's used for media change notification. For PMP, for downstream PHY status change notification. Implement sata_async_notification() which demultiplexes AN. To avoid unnecessary port events, ATAPI AN is not enabled if PMP is attached but SNTF is not available. Signed-off-by: Tejun Heo <htejun@gmail.com> Cc: Kriten Carlson Accardi <kristen.c.accardi@intel.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
