That update broke build of pata_atiixp as it requires some PCI IDs
and other updates which have not been merged. Better remove it
from 2.6.20.
This reverts commit f327bcd16db3128a6c1885e03109361e167d1a56.
Signed-off-by: Willy Tarreau <w@1wt.eu>
[libata] pata_atiixp: add SB700 PCI ID
From AMD.
Signed-off-by: Jeff Garzik <jeff@garzik.org>
Cc: Chuck Ebbert <cebbert@redhat.com>
Fix map entry 10b for ich8. It's [P0 P2 IDE IDE] like ich6 / ich6m.
Signed-off-by: Tejun Heo <htejun@gmail.com>
Acked-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com>
Cc: Jeff Garzik <jeff@garzik.org>
For some reason, sata_via is missing PM hooks. Add them. Spotted by
Jeroen Janssen <jeroen.janssen@gmail.com>.
Cc: Jeroen Janssen <jeroen.janssen@gmail.com>
Signed-off-by: Chris Wright <chrisw@sous-sol.org>
Update libata drive blacklist to the latest from 2.6.21
Removes one duplicate entry from blacklist table, adds several
entries for drives with broken NCQ.
[diff between 2.6.20 and 2.6.21-rc6, with one entry removed
that required new libata features]
Signed-off-by: Chuck Ebbert <cebbert@redhat.com>
libata: Clear tf before doing request sense (take 3)
patch 2/4:
Clear tf before doing request sense.
This fixes the AOpen 56X/AKH timeout problem.
(http://bugzilla.kernel.org/show_bug.cgi?id=8244)
Signed-off-by: Albert Lee <albertcc@tw.ibm.com>
2.6.21 fix lba48 bug in libata fill_result_tf()
Current 2.6.21 libata does the following:
void ata_tf_read(struct ata_port *ap, struct ata_taskfile *tf)
struct ata_ioports *ioaddr = &ap->ioaddr;
tf->command = ata_check_status(ap);
if (tf->flags & ATA_TFLAG_LBA48) {
iowrite8(tf->ctl | ATA_HOB, ioaddr->ctl_addr);
tf->hob_feature = ioread8(ioaddr->error_addr);
static void fill_result_tf(struct ata_queued_cmd *qc)
struct ata_port *ap = qc->ap;
ap->ops->tf_read(ap, &qc->result_tf);
qc->result_tf.flags = qc->tf.flags;
Based on this, those last two statements fill_result_tf()
appear to me to be in the wrong order, in that the tf->flags
are uninitialized at the point where tf_read() is invoked.
So for lba48 commands, tf_read() won't be reading back the
full lba48 register contents..
Correct?
This patch corrects fill_result_tf() so that the flags
get copied to result_tf before they are used by tf_read().
Signed-off-by: Mark Lord <mlord@pobox.com>
ahci.c: walkaround for SB600 SATA internal error issue
There is a HW issue in ATI SB600 SATA that PxSERR.E should not be
set on some conditions, for example, when there is no media in SATA
CD/DVD drive or media is not ready, AHCI controller fails to execute
ATAPI commands and reports PORT_IRQ_TF_ERR, but ATI SB600 SATA
controller sets PxSERR.E at the
same time, which is not necessary.
This patch is just to ignore the INTERNAL ERROR in such case.
Without this patch, ahci error handler will report many errors as
below:
----------- cut from dmesg -----------
ata9: soft resetting port
ata9: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
ata9.00: configured for UDMA/33
ata9: EH complete
ata9.00: exception Emask 0x40 SAct 0x0 SErr 0x800 action 0x2
ata9.00: (irq_stat 0x40000001)
ata9.00: cmd a0/00:00:00:00:20/00:00:00:00:00/a0 tag 0 cdb 0x0 data 0
res 51/24:03:00:00:20/00:00:00:00:00/a0 Emask 0x40 (internal error)
ata9: EH complete
ata9.00: cmd a0/01:00:00:00:00/00:00:00:00:00/a0 tag 0 cdb 0x43 data 12 in
res 51/24:03:00:00:00/00:00:00:00:00/a0 Emask 0x40 (internal error)
-------- end cut ---------
Signed-off-by: Conke Hu <conke.hu@amd.com>
libata bugfix: preserve LBA bit for HDIO_DRIVE_TASK
Preserve the LBA bit in the DevSel/Head register for HDIO_DRIVE_TASK.
[libata] sata_mv: Fix 50xx irq mask
IRQ mask bits assumed a 60xx or newer generation chip, which is very
wrong for the 50xx series. Luckily both generations shared the per-port
interrupt mask bits, leaving only the "misc chip features" bits to be
completely mismatched.
Fix 50xx by ensuring we only program bits that exist.
[libata] sata_mv: don't touch reserved bits in EDMA config register
The code in mv_edma_cfg() reflected its 60xx origins, by doing things
[slightly] incorrectly on the older 50xx and newer 6042/7042 chips.
Clean up the EDMA configuration setup such that, each chip family
carefully initializes its own EDMA setup.
libata bugfix: HDIO_DRIVE_TASK
I was trying to use HDIO_DRIVE_TASK for something today,
and discovered that the libata implementation does not copy
over the upper four LBA bits from args[6].
This is serious, as any tools using this ioctl would have their
commands applied to the wrong sectors on the drive, possibly resulting
in disk corruption.
Ideally, newer apps should use SG_IO/ATA_16 directly,
avoiding this bug. But with libata poised to displace drivers/ide,
better compatibility here is a must.
This patch fixes libata to use the upper four LBA bits passed
in from the ioctl.
The original drivers/ide implementation copies over all bits
except for the master/slave select bit. With this patch,
libata will copy only the four high-order LBA bits,
just in case there are assumptions elsewhere in libata (?).
libata: clear TF before IDENTIFYing
Some devices chock if Feature is not clear when IDENTIFY is issued.
Set ATA_TFLAG_ISADDR | ATA_TFLAG_DEVICE for IDENTIFY such that whole
TF is cleared when reading ID data.
Kudos to Art Haas for testing various futile patches over several
months and Mark Lord for pointing out the fix.
Cc: Art Haas <ahaas@airmail.net>
Cc: Mark Lord <mlord@pobox.com>
sata_nv: delay on switching between NCQ and non-NCQ commands
This patch appears to solve some problems with commands timing out in
cases where an NCQ command is immediately followed by a non-NCQ command
(or possibly vice versa). This is a rather ugly solution, but until we
know more about why this is needed, this is about all we can do.
[backport to 2.6.20 by Chuck Ebbert <cebbert@redhat.com>]
Signed-off-by: Robert Hancock <hancockr@shaw.ca>
Add missing #ifdef CONFIG_PM conditionals around all PM related parts
in libata LLDs.
Some LLDs were missing scsi device PM callbacks while having host/port
suspend support. Add missing ones.
sata_sil used to trigger HSM error if IRQ occurs during polling
command. This didn't matter because polling wasn't used in sata_sil.
However, as of 2.6.20, all IDENTIFYs are performed by polling and
device detection sometimes fails due to spurious IRQ. This patch
makes sata_sil ignore and clear spurious IRQ while executing commands
by polling.
This fixes bug#7996 and IMHO should also be included in -stable.
80c test mask is at bits 18 and 19 of EIDE Controller Configuration
not 22 and 23. Fix it.
Acked-by: Alan Cox <alan@lxorguk.ukuu.org.uk>
Some LLDDs, like ipr, use nbytes and pad_len to determine
the total data transfer length of a command. Make sure
nbytes gets initialized for internally generated commands.
Signed-off-by: Brian King <brking@linux.vnet.ibm.com>
The 8237S was added to the chipsets but not to the comments. Fix this
Signed-off-by: Alan Cox <alan@redhat.com>
For all JMicrons except for 361 and 368, AHCI mode enable bits in the
Control(1) should be set. This used to be done in both ahci and
pata_jmicron but while moving programming to PCI quirk, it was removed
from ahci part while still left in pata_jmicron.
The implemented JMicron PCI quirk was incorrect in that it didn't
program AHCI mode enable bits. If pata_jmicron is loaded first and
programs those bits, the ahci ports work; otherwise, ahci device
detection fails miserably.
This patch makes JMicron PCI quirk clear SATA IDE mode bits and set
AHCI mode bits and remove the respective part from pata_jmicron.
Tested on JMB361, 363 and 368.
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/libata-dev
* 'upstream-linus' of master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/libata-dev:
libata: fix translation for START STOP UNIT
libata-scsi: ata_task_ioctl should return ATA registers from sense data
pata_platform: set_mode fix
ata_if_xfermask() word 51 fix
pata_sil680: PIO1 taskfile transfers overclocking fix (repost)
libata: fix ata_eh_suspend() return value
ahci: port_no should be used when clearing IRQ in ahci_thaw()
Fix trivial conflict in drivers/ata/pata_platform.c manually
* master.kernel.org:/pub/scm/linux/kernel/git/bart/ide-2.6:
via82cxxx/pata_via: correct PCI_DEVICE_ID_VIA_SATA_EIDE ID and add support for CX700 and 8237S
ide: unregister idepnp driver on unload
ide: add missing __init tags to IDE PCI host drivers
ia64: add pci_get_legacy_ide_irq()
ide/generic: Jmicron has its own drivers now
atiixp.c: add cable detection support for ATI IDE
atiixp.c: sb600 ide only has one channel
atiixp.c: remove unused code
jmicron: fix warning
ide: update MAINTAINERS entry
libata's SCSI translation for the SCSI START STOP UNIT command with the
START bit clear (i.e. stopping the drive) appears to be incorrect. It
sends an ATA STANDBY command with the time period set to 0, which the code
comment says means "now", but the ATA standard says this means disable the
standby timer, which effectively does nothing. Change this to issue a
STANDBY IMMEDIATE command which will actually spin the drive down. The SAT
(SCSI/ATA Translation) standard revision 9 concurs with this choice.
User applications using the HDIO_DRIVE_TASK ioctl through libata expect
specific ATA registers to be returned to userspace. Verified that
ata_task_ioctl correctly returns register values to the smartctl
application.
Signed-off-by: David Milburn <dmilburn@redhat.com>
Acked-by: Tejun Heo <htejun@gmail.com>
drivers/ata/pata_platform.c:85: warning: initialization from incompatible pointer type
Cc: Tejun Heo <htejun@gmail.com>
If word 53 bit 1 isn't set, the maximum PIO mode is indicated by
the upper 8 bits of word 51, not the lower 8 bits. Fixes PIO mode
detection on old Compact Flash cards.
Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org>
Fix PIO mode 1 overclocked taskfile transfers -- probably a typo carried over
from drivers/ide/pci/siimage.c where I've found it by documentation check...
for CX700 and 8237S
This patch:
* Corrects the wrong device ID of PCI_DEVICE_ID_VIA_SATA_EIDE
from 0x0581 to 0x5324.
* Adds VIA CX700 and VT8237S support in drivers/ide/pci/via82cxxx.c
* Adds VIA VT8237S support in drivers/ata/pata_via.c
Signed-off-by: Josepch Chan <josephchan@via.com.tw>
Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
ata_eh_suspend() was returning 0 regardless of failure. This bug has
potential to lose data on suspend. Fix it.
ap->id is logcial port ID which is unique among all ATA ports and
doesn't have anything to do with hardware port index. ap->port_no is
the hardware port index and thus should be used when clearing IRQ mask
in ahci_thaw().
This problem has been spotted by Jeff Garzik <jgarzik@pobox.com>.
On the Maple board, the AMD8111 IDE is in legacy mode... except that it
appears on IRQ 20 instead of IRQ 15. For drivers/ide this was handled by
the architecture's "pci_get_legacy_ide_irq()" function, but in libata we
just hard-code the numbers 14 and 15.
This patch provides asm-powerpc/libata-portmap.h which maps the IRQ as
appropriate, having added a pci_dev argument to the
ATA_{PRIM,SECOND}ARY_IRQ macros.
There's probably a better way to do this -- especially if we observe
that the _only_ case in which this seemingly-generic
"pci_get_legacy_ide_irq()" function returns anything other than 14 and
15 for primary and secondary respectively is the case of the AMD8111 on
the Maple board -- couldn't we handle that with a special case in the
pata_amd driver, or perhaps with a PCI quirk for Maple to switch it into
native mode during early boot and assign resources properly?
Before hardreset, ahci initialized stat part of received FIS area to
0xff to wait for the first D2H Reg FIS which would change the value to
device ready state. This used to work but now libata considers status
value of 0xff as device not present making this wait prone to failure.
This patch makes ahci use 0x80 for the wait stat value instead of
0xff to fix the above problem.
drivers/ata/ahci.c | 2 +-
1 file changed, 1 insertion(+), 1 deletion(-)
Call ata_bmdma_irq_clear() directly instead of through
ap->ops->irq_clear() according to libata style guideline.
Fix endianness in spurious interrupt message.
Fixes bogus accesses to ports 0-15 with a non DMA capable controller.
This I think should go in for 2.6.20
Some uli controllers have stuck SIMPLEX bit which can't be cleared
with ata_pci_clear_simplex(), but the controller is capable of doing
DMAs on both channels simultaneously. Implement ATA_FLAG_IGN_SIMPLEX
which makes libata ignore the simplex bit and use it in sata_uli.
We're still seeing a lot of issues with NCQ implementation in drive
firmwares. Sprious FISes during NCQ command phase occur on many
drives and some of them seem potentially dangerous (at least to me).
Until we find the solution, spurious messages can give us more info.
Improve and limit them such that more info can be reported while not
disturbing users too much.
vt6420 completely loses its ability to raise IRQ for ATAPI devices if
ATA_NIEN is diddled with in ->freeze. Further investigation is
necessary to determine whether this problem is shared on other
controllers but it doesn't seem to be at this point.
Make vt6420's ->freeze only clear IRQ to fix this problem. This makes
vt6420 relatively more prone to IRQ storms but the controller is way
too braindamaged to worry about that anyway.
When set_mode() changed ->set_mode didn't adapt. This makes the needed
changes and removes the relevant FIXME case.
Rather than ending up with two layers of negation jut rename the variable
and lose one.
Fixup the inialization of qc->n_elem. It currently gets
initialized to 1 for commands that do not transfer any data.
Fix this by initializing n_elem to 0 and only setting to 1
in ata_scsi_qc_new when there is data to transfer. This fixes
some problems seen with SATA devices attached to ipr adapters.
Some ATA/ATAPI devices act weirdly after the link is put into slumber
mode. Some hang completely requiring physical power removal while
others fail to wake up till the link is hardreset a couple of times.
The addition of slumber on power down was never driven by real need.
It just followed what ahci spec said literally. The spec itself seems
faulty in that it doesn't consider devices (not controllers) which
don't support link powersaving mode.
Theory never matches reality when it comes to dark allys of cheap
ATA/ATAPI world. It's just unrealistic to expect vendors to test
rarely used link powersaving feature rigorously. This patch makes
ahci more friendly to the coldness of reality.
This shouldn't have any negative effect - when suspend operation
succeeds, we power off the whole machine; otherwise, we wake up
everything. I can't see any reason to be so elaborate with powering
down the link in the first place.
Several people reported issues with certain drive commands timing out on
sata_nv controllers running in ADMA mode. The commands in question were
non-DMA-mapped commands, usually FLUSH CACHE or FLUSH CACHE EXT.
From experimentation it appears that the NV_INT_DEV indication isn't
always set when a legitimate command completion interrupt is received on
a legacy-mode command, at least not on these controllers in ADMA mode.
When a command is pending on the port, force the flag on always in the
irq_stat value before calling nv_host_intr so that the drive busy state
is always checked by ata_host_intr.
This also fixes some questionable code in nv_host_intr which called
ata_check_status when a command was pending and ata_host_intr returned
"unhandled". If the device interrupted at just the wrong time this could
cause interrupts to be lost.
As with JMicron controllers, ULi M5288 sets interface fatal error bit
on device error including ATAPI CC. This makes libata hardreset the
port on ATAPI CC thus making it impossible to use. Ignore interface
fatal error bit on ULi M5288. This fixes bugzilla bug #7837.
With the following patch, my HighPoint 2310 with a Marvell 88SX7042 on
it seems to work OK.
The controller only has 4 ports, with MV_FLAG_DUAL_HC it seems to init 8
ports and fails miserably at probe time. There are no other devices mapped
to that chip, maybe it was just incorrectly specified in the first place?
libata EH ignores port-wide actions in per-dev action mask. However,
device resume requests EH_SOFTRESET using per-dev action mask. Under
certain circumstances, this results in not resetting frozen port after
resuming which causes failure of all commands.
This patch allows port-wide actions to be requested in per-dev action
mask. Before EH recovery starts, port-wide actions will be collected.
