Since the version of the imx6qp's ahci controller
is same to the version of imx6q ahci controller.
So, this work-around should be applied to imx6qp
ahci too.
Signed-off-by: Richard Zhu <Richard.Zhu@freescale.com>
errata:
When a read command returns less data than specified in the PRDs (for
example, there are two PRDs for this command, but the device returns a
number of bytes which is less than in the first PRD), the second PRD of
this command is not read out of the PRD FIFO, causing the next command
to use this PRD erroneously.
workaround
- forces sg_tablesize = 1
- modified the sg_io function in block/scsi_ioctl.c to use a 64k buffer
allocated with dma_alloc_coherent during the probe in ahci_imx
- In order to fix the scsi/sata hang, when CD_ROM and HDD are
accessed simultaneously after the workaround is applied.
Do not go to sleep in scsi_eh_handler, when there is host failed.
- add the sata phy power down and phy reset for 6qp
sata
This patch moves force_port_map and mask_port_map into the
ahci_host_priv structure. This allows to modify them into the AHCI
framework. This is needed by the new dt bindings representing ports as
the port_map mask is computed automatically.
Parameters modifying force_port_map, mask_port_map and flags have been
removed from the ahci_platform_init_host() function, and inputs in the
ahci_host_priv structure are now directly filed.
Signed-off-by: Antoine Ténart <antoine.tenart@free-electrons.com>
(cherry picked from commit 725c7b570fda4207e465ff8856c2c12c2645a685)
Add the missing clk_disable_unprepare() before return from
imx_sata_enable() in the phy reset error handling case.
Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
Acked-by: Shawn Guo <shawn.guo@freescale.com>
(cherry picked from commit 19f5be0f40922717e2b6e39a9822e7e7f30fd81f)
Host controller driver.
APM X-Gene SoC AHCI SATA Host controller driver requires
some correction of Phy Control OOB timing for the
COMINIT/COMWAKE parameters to correctly interoperate with
different kinds of disks.
Signed-off-by: Loc Ho <lho@apm.com>
Signed-off-by: Suman Tripathi <stripathi@apm.com>
(cherry picked from commit 0185b1b787962db38fdf74e1cab9b7a2619490a1)
controller driver.
As per SATA IO specification, when Host sends HOLD, the device takes
about 20DW latency to reply to HOLDA. In some case, device doesn't
response to HOLDA over 20DW and causes FIFO goes into over flow
condition. Due to this condition, device enumerations fails with
those devices. This patch adjust the watermark FIFO by increasing
the FIFO depth from 0x16(default) to 0x30 to address this issue.
(cherry picked from commit aeae4dcac5a91de9546c42a3be09c96479bfc3ff)
This adds support for the integrated AHCI-compliant Serial ATA
controller present on the NVIDIA Tegra124 system-on-chip.
Signed-off-by: Mikko Perttunen <mperttunen@nvidia.com>
Acked-by: Hans de Goede <hdegoede@redhat.com>
(cherry picked from commit ccfde50810ae916564765a2f8ee6d7163b025594)
The Tegra124 SATA controller requires 4 clocks. Increase this constant
to be able to use them all.
(cherry picked from commit 0e38699387fd2fd433618bb67612f3aae676fbae)
libata-eh.c should handle AMNF error condition (error byte bit 0,
usually code 0x01) in libata-eh.c along with UNC as a media error so
SCSI stack can handle it properly (translation code 0x01 is already
present in libata-scsi.c) but was never passed down due to lack of
handling in EH.
While using linux-based machine (AMD 6550M-based notebook, PCI IDs for the
controller are 1022:7801 subsys 1025:059d) and ddrescue to salvage data
from failing hard drive (WD7500BPVT 2.5" 750G SATA2), I've found that pure
AMNF 0x01 error code generates generic "device error" that is retried
several times by SCSI stack instead of "media error" that is passed up to
software.
So we may assume deprecated AMNF error code is surely not dead yet, and
it's better for it to be handled properly. As we may see it is used by
modern enough devices, and used properly: drive returned AMNF only when IDs
for track cannot be read completely due to dying head or positioning,
otherwise it returned UNC(orrectables).
Not handling it causes wrong generic error code ("device error") reporting
down the stack, can damage failing drives further because of excessive
retries, and slows salvaging down a lot. Also, there is handling code in
libata-scsi.c for 0x01 AMNF error already.
https://bugzilla.kernel.org/show_bug.cgi?id=80031
tj: Shortened $SUBJ and moved its content to the first paragraph.
Signed-off-by: Alexey Asemov <alex@alex-at.ru>
(cherry picked from commit eec7e1c16d2b65e38137686dd9b7e102c2150905)
mode command.
This patch fixes the dma state machine lockup due to the processing
of IDENTIFY DEVICE PIO mode command. The X-Gene AHCI controller
has an errata in which it cannot clear the BSY bit after the PIO setup
FIS. The dma state machine enters CMFatalErrorUpdate state and locks
up. This patch also removes the dma restart workaround from the read_id
function as the read_id function is only called by libata layer for
ATA_INTERNAL commands. But for some cases eg: PORT MULTIPLIER
and udev, the framework will enumerate using SCSI commands and it will
not call read_id function.
(cherry picked from commit 2a0bdff6b958d1b2523d2754b6cd5e0ea4053016)
The subsequent patch will make use of them.
(cherry picked from commit 39e0ee9964b1245b79ec89f6b89d8ec4ef672524)
Spread-spectrum doesn't work with Cubox-i hardware, so we have to
disable this feature. Add a DT property so that platforms can
indicate that this feature should not be enabled.
Having it as a negative property keeps existing DT files working.
Reviewed-by: Shawn Guo <shawn.guo@freescale.com>
(cherry picked from commit a6e726244c78e04d0af754c625036be8f92a9afd)
Various SATA phy parameters are board specific, and therefore need to
be configured.
(cherry picked from commit 29e69413666f085d9eb79b29ebfedb163e0e8ef2)
This patch removes support for s5pc100 ata because of no more support
S5PC100 SoC in mainline.
Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
(cherry picked from commit a1a6cc1d2ea9e3adf81faab87b834bc903856207)
When the AHCI link is disabled, it can't be re-enabled except by
resetting the entire SoC. Rather than doing this silently print
some kernel messages to inform the user, along with how to avoid
this.
tj: Put a long printf format string on a single line.
(cherry picked from commit f118ae5901172dacc4f272acf5eccfba06e8d221)
NCQ feature is unsupported on hisilicon sata controller, so disable
it. This version of IP is used by hip04 and hix5hd2 soc.
tj: "|=" was replaced with "=" for no reason. Restored "|=".
Signed-off-by: Kefeng Wang <kefeng.wang@linaro.org>
Sigend-off-by: Tejun Heo <tj@kernel.org>
(cherry picked from commit 72cbaa3d2f563d7b48c9f8aef47ec9aa3a31adf2)
Doing suspend/resume on imx6q and imx53 boards with no SATA disk
attached will trigger the following warning.
WARNING: CPU: 0 PID: 661 at drivers/ata/libahci.c:224 ahci_enable_ahci+0x74/0x8)
Modules linked in:
CPU: 0 PID: 661 Comm: sh Tainted: G W 3.15.0-rc5-next-20140521-000027
Backtrace:
[<80011c90>] (dump_backtrace) from [<80011e2c>] (show_stack+0x18/0x1c)
r6:803a22f4 r5:00000000 r4:00000000 r3:00000000
[<80011e14>] (show_stack) from [<80661e60>] (dump_stack+0x88/0xa4)
[<80661dd8>] (dump_stack) from [<80028fdc>] (warn_slowpath_common+0x70/0x94)
r5:00000009 r4:00000000
[<80028f6c>] (warn_slowpath_common) from [<80029024>] (warn_slowpath_null+0x24/)
r8:808f68c4 r7:00000000 r6:00000000 r5:00000000 r4:e0810004
[<80029000>] (warn_slowpath_null) from [<803a22f4>] (ahci_enable_ahci+0x74/0x80)
[<803a2280>] (ahci_enable_ahci) from [<803a2324>] (ahci_reset_controller+0x24/0)
r8:ddcd9410 r7:80351178 r6:ddcd9444 r5:dde8b850 r4:e0810000 r3:ddf35e90
[<803a2300>] (ahci_reset_controller) from [<803a2c68>] (ahci_platform_resume_ho)
r7:80351178 r6:ddcd9444 r5:dde8b850 r4:ddcd9410
[<803a2c30>] (ahci_platform_resume_host) from [<803a38f0>] (imx_ahci_resume+0x2)
r5:00000000 r4:ddcd9410
[<803a38c4>] (imx_ahci_resume) from [<803511ac>] (platform_pm_resume+0x34/0x54)
The reason is that the SATA controller has no working clock at this
point, and thus ahci_enable_ahci() fails to enable the controller. In
case that there is no SATA disk attached, the imx_sata_disable() gets
called in ahci_imx_error_handler(), and both sata_clk and sata_ref_clk
will be disabled there. Because all the imx_sata_enable() calls
afterward will return immediately due to imxpriv->no_device check, the
SATA controller working clock sata_clk will never get any chance to be
enabled again.
This is a regression caused by commit 90870d79d4f2 (ahci-imx: Port to
library-ised ahci_platform). Before the commit, only sata_ref_clk is
managed by the driver in enable/disable function. But after the commit,
all the clocks are enabled/disabled in a row by ahci platform helpers
ahci_platform_enable[disable]_clks. Since ahb_clk is a bus clock which
does not have gate at all, and i.MX low-power hardware module already
manages sata_clk across suspend/resume cycle, the only clock that needs
to be managed by software is sata_ref_clk.
So instead of using ahci_platform_enable[disable]_clks to manage all
the clocks in a row from imx_sata_enable[disable], we should manage
only sata_ref_clk in there.
Reported-by: Fabio Estevam <fabio.estevam@freescale.com>
Fixes: 90870d79d4f2 (ahci-imx: Port to library-ised ahci_platform)
Signed-off-by: Shawn Guo <shawn.guo@freescale.com>
(cherry picked from commit e6dd42a917e62d916c6e513dbf87a4dec8cf3a1c)
Instead of doing the check here, this should be handled
in the common AHCI platform code.
Signed-off-by: Suravee Suthikulpanit <Suravee.Suthikulpanit@amd.com>
Suggested-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com>
Cc: Loc Ho <lho@apm.com>
Cc: Tuan Phan <tphan@apm.com>
Cc: Suman Triphati <stripathi@apm.com>
(cherry picked from commit be64beb40df808385f7883d2e6f01ff7c79eeae4)
The current platform AHCI driver does not set the dma_mask correctly
for 64-bit DMA capable AHCI controller. This patch checks the AHCI
capability bit and set the dma_mask and coherent_dma_mask accordingly.
Reviewed-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com>
Reviewed-by: Hans de Goede <hdegoede@redhat.com>
Tested-by: Hans de Goede <hdegoede@redhat.com>
Tested-by: Suman Tripathi <stripathi@apm.com>
(cherry picked from commit cc7a9e27562cd78a1dc885504086fab24addce40)
ahci_platform_get_resources handles resource management for
platform AHCI drivers, including getting a possible PHY
from the device tree. Since not all drivers need a PHY, it
ignores -ENODEV and -ENOSYS from devm_get_phy. However, when
the PHY subsystem is mistakenly disabled, -ENOSYS can be
returned even when a PHY is needed.
This patch modifies the -ENOSYS case to check if a "phys"
device tree node exists. If it exists, then clearly the PHY
subsystem is mistakenly disabled and the driver cannot work,
ahci_platform_get_resources will fail and propagate the error.
Acked-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com>
(cherry picked from commit acbd573354bb7b7b7a3891018a39f4b3976b0c43)
Use the zeroing function instead of dma_alloc_coherent & memset(,0,)
(cherry picked from commit 94463a9cadc7f72a70ec6ee801109c2f1e44a123)
it is better to use generic api instead of calling an internal callback
like channel->device->device_prep_slave_sg().
Signed-off-by: Barry Song <Baohua.Song@csr.com>
(cherry picked from commit 69493e0b0a8b5d4a0df7df82bad49ad07ae6921d)
A check for CONFIG_MPC8315_DS was added in v2.6.24. But the related
Kconfig symbol was never added to the tree. So the code behind this
check has effectively been dead for over six years. Remove it.
Signed-off-by: Paul Bolle <pebolle@tiscali.nl>
(cherry picked from commit d0f5aa9cf6a479884cda95018363ba9ed31d9cbd)
The commit e783c51 (ahci: imx: software workaround for phy reset issue
in resume) calls imx_sata_phy_reset() to reset phy immediately after
SATA MPLL is enabled. It seems working fine mostly, but fails in some
case as below.
ahci-imx 2200000.sata: failed to reset phy: -110
ahci-imx: probe of 2200000.sata failed with error -110
After talking to the designer, we learnt that when enabling i.MX6Q SATA
MPLL, we need to wait 100us for it to settle down for safety. Add this
required delay to fix above failure.
Tested-by: Fabio Estevam <fabio.estevam@freescale.com>
(cherry picked from commit 3685f2516116c5f3b9d498d531955ad70216ad84)
The hip04 SoC of hisilicon has an AHCI compliant SATA controller,
and it is compliant with the ahci 1.3 and sata 3.0 specification.
There is a wrong bit in HOST_CAP of hip04 sata controller, which
enable unsupported feature of FBS, use AHCI_HFLAG_NO_FBS hflag to
disable it.
(cherry picked from commit a1a205df6ee224f62c6d21cedebcb723db17fe0d)
Add a dynamic host_flags argument to make ahci_platform_init_host more flexible,
then remove the AHCI_HFLAGS(...) argument from some driver's ata_port_info,
and pass that in as the new argument.
Cc: Hans de Geode <hdegoede@redhat.com>
(cherry picked from commit f9f36917903b57c571b1ddcfc6bc794ca4dd8232)
Append AHCI_HFLAG_NO_FBS to force turning off FBS flag.
Signed-off-by: Haojian Zhuang <haojian.zhuang@linaro.org>
(cherry picked from commit 888d91a08fa8e2be4cb0eef1e5736ef68b8f77f0)
This patch fixes host drivers to use CONFIG_PM_SLEEP instead of CONFIG_PM
where applicable. Benefits of this change:
* unused code is not being compiled in for CONFIG_PM=y, CONFIG_PM_SLEEP=n
and CONFIG_PM_RUNTIME=y configurations
* easier transition to use struct dev_pm_ops and SIMPLE_DEV_PM_OPS() in
the future
* more consistent code (there are host drivers which are using the correct
CONFIG_PM_SLEEP checks already)
The patch leaves the core libata code and ->port_[suspend,resume] support
in sata_[inic162x,nv,sil24].c alone for now.
Signed-off-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com>
(cherry picked from commit 58eb8cd565af4a104395e3c10443951c1f73dafe)
The smc driver used by pata_at91 is at91sam9 specific, so building
this driver on another at91 platform results in this error:
ERROR: "sam9_smc_configure" [drivers/ata/pata_at91.ko] undefined!
ERROR: "sam9_smc_write_mode" [drivers/ata/pata_at91.ko] undefined!
ERROR: "sam9_smc_read_mode" [drivers/ata/pata_at91.ko] undefined!
This patch changes the Kconfig dependency to ensure it always works.
Cc: linux-ide@vger.kernel.org
Cc: Jean-Christophe Plagniol-Villard <plagnioj@jcrosoft.com>
Cc: Nicolas Ferre <nicolas.ferre@atmel.com>
(cherry picked from commit 2af89a3cde1beb88a2c65e0558d828c1a9e4677f)
The Marvell Armada 380 SoC includes two AHCI compatible
interfaces. However, like all DMA-capable Marvell interface, they
require special handling to configure MBus windows. Therefore, this
commit adds a new ahci_mvebu driver, which relies on the
libahci_platform.c code recently introduced.
Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Acked-by: Jason Cooper <jason@lakedaemon.net>
(cherry picked from commit a3464ed2f14d19ba923930f7c0c284499d64eb5b)
When suspending imx6q systems which have rootfs on SATA, the following
error will likely be seen in resume. The SATA link will fail to come
up, and it results in an unusable system across the suspend/resume
cycle.
$ echo mem > /sys/power/state
PM: Syncing filesystems ... done.
PM: Preparing system for mem sleep
Freezing user space processes ... (elapsed 0.002 seconds) done.
Freezing remaining freezable tasks ... (elapsed 0.002 seconds) done.
PM: Entering mem sleep
sd 0:0:0:0: [sda] Synchronizing SCSI cache
sd 0:0:0:0: [sda] Stopping disk
PM: suspend of devices complete after 61.914 msecs
PM: suspend devices took 0.070 seconds
PM: late suspend of devices complete after 4.906 msecs
PM: noirq suspend of devices complete after 4.521 msecs
Disabling non-boot CPUs ...
CPU1: shutdown
CPU2: shutdown
CPU3: shutdown
Enabling non-boot CPUs ...
CPU1: Booted secondary processor
CPU1 is up
CPU2: Booted secondary processor
CPU2 is up
CPU3: Booted secondary processor
CPU3 is up
PM: noirq resume of devices complete after 10.486 msecs
PM: early resume of devices complete after 4.679 msecs
sd 0:0:0:0: [sda] Starting disk
PM: resume of devices complete after 22.674 msecs
PM: resume devices took 0.030 seconds
PM: Finishing wakeup.
Restarting tasks ... done.
$ ata1: SATA link down (SStatus 1 SControl 300)
ata1: limiting SATA link speed to 1.5 Gbps
ata1: SATA link down (SStatus 1 SControl 310)
ata1.00: disabled
ata1: exception Emask 0x10 SAct 0x0 SErr 0x4040000 action 0xe frozen t4
ata1: irq_stat 0x00000040, connection status changed
ata1: SError: { CommWake DevExch }
ata1: hard resetting link
sd 0:0:0:0: rejecting I/O to offline device
sd 0:0:0:0: killing request
Aborting journal on device sda2-8.
EXT4-fs warning (device sda2): ext4_end_bio:317: I/O error writing to inode 132577 (offset 0 size 0 starting block 26235)
Buffer I/O error on device sda2, logical block 10169
It's caused by a silicon issue that SATA phy does not get reset by
controller when coming back from LPM. The patch adds a software
workaround for this issue. It enforces a software reset on SATA phy
in imx_sata_enable() function, so that we can ensure SATA link will
come up properly in both power-on and resume.
The software reset is implemented by writing phy reset register through
the phy control register bus interface. Functions
imx_phy_reg_[addressing|write|read]() implement this bus interface, while
imx_sata_phy_reset() performs the actually reset operation.
Signed-off-by: Richard Zhu <r65037@freescale.com>
(cherry picked from commit e783c51cce94521c10e599e991acdcfd9a996c4a)
Update register enums a little bit to add proper namespace prefix, and
have the names match i.MX reference manual.
(cherry picked from commit 24a9ad5b82929cdeaff70018d82263de0c34c45d)
Ever since v2.6.19 the code contains a check for CONFIG_NO_ATA_LEGACY.
But that macro has never been defined. Apparently no one ran into
problems on platforms that do not support compatibility mode. So remove
this code that has been dead for over seven years.
(cherry picked from commit 8612b4b4f964b935029c3388c8484a66e41bf71e)
The SCSI-to-ATA Translation standard says to use data words 25 and 26
unless they are spaces. For devices that use these words in the firmware
field, they are generally more useful anyway.
Signed-off-by: Keith Busch <keith.busch@intel.com>
(cherry picked from commit c49a6bf5eecd31f335df1a3700c92be1a824c6f0)
The AHCI specification allows hardware to choose to revert to
single MSI mode when fewer messages are allocated than requested.
Yet, at least ICH10 chipset reverts to single MSI mode even when
enough messages are allocated in some cases (see below).
This update forces the driver to not rely on initialization of
multiple MSIs mode alone and always check if "MSI Revert to
Single Message" (MRSM) mode was enforced by the controller and
fallback to the single MSI mode in case it did.
That prevents a situation when the driver configured multiple
per-port IRQ handlers, but the controller sends all port's
interrupts to a single IRQ, which could easily screw up the
interrupt handling and lead to delays and possibly crashes.
The fix was tested on a 6-port controller that successfully
reverted to the single MSI mode:
00:1f.2 SATA controller: Intel Corporation 82801JI (ICH10 Family) SATA
AHCI Controller (prog-if 01 [AHCI 1.0])
Subsystem: Super Micro Computer Inc Device 10a7
Flags: bus master, 66MHz, medium devsel, latency 0, IRQ 101
I/O ports at f110 [size=8]
I/O ports at f100 [size=4]
I/O ports at f0f0 [size=8]
I/O ports at f0e0 [size=4]
I/O ports at f020 [size=32]
Memory at fbf00000 (32-bit, non-prefetchable) [size=2K]
Capabilities: [80] MSI: Enable+ Count=1/16 Maskable- 64bit-
Capabilities: [70] Power Management version 3
Capabilities: [a8] SATA HBA v1.0
Capabilities: [b0] PCI Advanced Features
Kernel driver in use: ahci
With 6 ports just 8 MSI vectors should be enough, but the adapter
enforces the MRSM mode when less than 16 vectors are written to
the Multiple Messages Enable PCI register. I instigated MRSM mode
by forcing @nvec to 8 in ahci_init_interrupts().
Signed-off-by: Alexander Gordeev <agordeev@redhat.com>
Cc: stable@vger.kernel.org
(cherry picked from commit ab0f9e78b97f5193dd38b3757b42b6fbded05fb7)
The ahci_imx driver is only needed on Freescale i.MX platforms so
don't let it be built on other platforms, except for build test
purpose.
Signed-off-by: Jean Delvare <jdelvare@suse.de>
Cc: Tejun Heo <tj@kernel.org>
Cc: Richard Zhu <r65037@freescale.com>
(cherry picked from commit f5f85ee065f2e243f4165d7dd7d1a4a95daa1801)
AHCI_XGENE is only applicable on ARM64 but it can also be enabled for
compile testing; however, AHCI_XGENE selects PHY_XGENE which has other
arch specific dependencies. This leads to the following warning when
enabling it on other archs for compile testing.
warning: (AHCI_XGENE) selects PHY_XGENE which has unmet direct
dependencies (HAS_IOMEM && OF && (ARM64 || COMPILE_TEST))
Selecting a config option which itself has dependencies can easily
lead to broken configurations. For now, let's just make AHCI_XGENE
depend on PHY_XGENE which has all the necessary dependencies already.
Reported-by: Linus Torvalds <torvalds@linux-foundation.org>
Cc: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com>
Cc: Kishon Vijay Abraham I <kishon@ti.com>
(cherry picked from commit 74c03eb63061c834893e7ebf8d298573bdccfd08)
Make pata_arasan_cf host driver depend on ARCH_SPEAR13XX config
option as ARASAN CompactFlash PATA support is specific to ST
SPEAr13xx SoCs and the driver to work requires suitable device
tree node (or platform device) to be defined. Additionally
allow the driver build if COMPILE_TEST config option is set.
Cc: Viresh Kumar <viresh.linux@gmail.com>
Cc: Shiraz Hashim <shiraz.hashim@st.com>
(cherry picked from commit e638433b5021f59aacbfe15597beca1e706773fb)
Unreferenced casts of void * types are unnecessary so remove them.
(cherry picked from commit d5185d655c1fc4dfd467303f45ba4496ad84ddf9)
Make sata_highbank host driver depend on ARCH_HIGHBANK config option
as Calxeda Highbank SATA support is specific to Calxeda Highbank
SoCs and the driver to work requires suitable device tree node to
be defined. Additionally allow the driver build if COMPILE_TEST
Cc: Mark Langsdorf <mark.langsdorf@calxeda.com>
Cc: Rob Herring <robh@kernel.org>
(cherry picked from commit 0b99f8648eb1814d787db3981ad93e6bc343b3f6)
Make sata_rcar host driver depend on ARCH_SHMOBILE config option as
Renesas R-Car SATA support is specific to Renesas SoCs and the driver
to work requires suitable device tree node (or platform device) to be
defined. Additionally allow the driver build if COMPILE_TEST config
option is set.
Cc: Simon Horman <horms@verge.net.au>
Cc: Magnus Damm <magnus.damm@gmail.com>
(cherry picked from commit 7596d93d8dfa7a508ca52c7d9b7db763eb5b0715)
Add the new ahci_da850 host driver.
Platform changes needed to make DaVinci DA850 SATA AHCI support
fully functional are in the separate "ARM: davinci: da850: update
SATA AHCI support" commit.
Please note that this driver doesn't have the superfluous clock
control code as clock is already handled by the generic AHCI
platform library code.
Cc: Sekhar Nori <nsekhar@ti.com>
Cc: Kevin Hilman <khilman@deeprootsystems.com>
Cc: Hans de Goede <hdegoede@redhat.com>
(cherry picked from commit ae8723f8a9c8e804c2b906074d7d5f1265a385bb)
Move AHCI platform library code from ahci_platform.c to
libahci_platform.c and fix dependencies for ahci_st,
ahci_imx and ahci_sunxi drivers.
(cherry picked from commit fd990556f0fa25446c6bfa9cf4c9e49d387d4472)
None of these files are actually using any __init type directives
and hence don't need to include <linux/init.h>. Most are just a
left over from __devinit and __cpuinit removal, or simply due to
code getting copied from one driver to the next.
(cherry picked from commit 1bc18086231c130895b87ec049be8ddcdab552b8)
Looking at ST SPEAr1340 AHCI code (the only user of the deprecated
pdata->suspend and pdata->resume) it is obvious the we should return
after calling pdata->suspend() only if the function have returned
non-zero return value. The code has been broken since commit 1e70c2
("ata/ahci_platform: Add clock framework support"). Fix it.
(cherry picked from commit 83b03fd67b9b3fa3795871169f3c08c35b3d6ea8)
Improve overall system resume time by making libata link recovery
actions asynchronous relative to other resume events.
Link resume operations are performed using the scsi_eh thread, so
commands, particularly the sd resume start/stop command, will be held
off until the device exits error handling. Libata already flushes eh
with ata_port_wait_eh() in the port teardown paths, so there are no
concerns with async operation colliding with the end-of-life of the
ata_port object. Also, libata-core is already careful to flush
in-flight pm operations before another round of pm starts on the given
ata_port.
Reference: https://01.org/suspendresume/blogs/tebrandt/2013/hard-disk-resume-optimization-simpler-approach
Cc: Len Brown <len.brown@intel.com>
Cc: Phillip Susi <psusi@ubuntu.com>
Cc: Alan Stern <stern@rowland.harvard.edu>
Signed-off-by: Todd Brandt <todd.e.brandt@linux.intel.com>
[djbw: rebase on cleanup patch, changelog wordsmithing]
(cherry picked from commit 200421a80f6e0a9e39d698944cc35cba103eb6ce)
Tejun says:
"At least for libata, worrying about suspend/resume failures don't make
whole lot of sense. If suspend failed, just proceed with suspend. If
the device can't be woken up afterwards, that's that. There isn't
anything we could have done differently anyway. The same for resume, if
spinup fails, the device is dud and the following commands will invoke
EH actions and will eventually fail. Again, there really isn't any
*choice* to make. Just making sure the errors are handled gracefully
(ie. don't crash) and the following commands are handled correctly
should be enough."
The only libata user that actually cares about the result from a suspend
operation is libsas. However, it only cares about whether queuing a new
operation collides with an in-flight one. All libsas does with the
error is retry, but we can just let libata wait for the previous
operation before continuing.
Other cleanups include:
1/ Unifying all ata port pm operations on an ata_port_pm_ prefix
2/ Marking all ata port pm helper routines as returning void, only
ata_port_pm_ entry points need to fake a 0 return value.
3/ Killing ata_port_{suspend|resume}_common() in favor of calling
ata_port_request_pm() directly
4/ Killing the wrappers that just do a to_ata_port() conversion
5/ Clearly marking the entry points that do async operations with an
_async suffix.
Reference: http://marc.info/?l=linux-scsi&m=138995409532286&w=2
Suggested-by: Tejun Heo <tj@kernel.org>
Signed-off-by: Todd Brandt <todd.e.brandt@intel.com>
(cherry picked from commit bc6e7c4b0d1a1f742d96556f63d68f17f4e232c3)
This patch fixes an compiler warning with APM X-Gene host controller
driver when compiled with DEBUG enabled.
(cherry picked from commit 6a96918a6aa7b434d15710fc9e06589c6c8bd3a6)
This patch adds support for the APM X-Gene SoC AHCI SATA host controller
driver. It requires the corresponding APM X-Gene SoC PHY driver. This
initial version only supports Gen3 speed.
Signed-off-by: Tuan Phan <tphan@apm.com>
(cherry picked from commit 81d01bfa51300d14191e0013856a7b25f809468f)
