path: root/drivers/ata
2014-08-18libata: widen Crucial M550 blacklist matchingTejun Heo
Crucial M550 may cause data corruption on queued trims and is blacklisted. The pattern used for it fails to match 1TB one as the capacity section will be four chars instead of three. Widen the pattern. Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: Charles Reiss <woggling@gmail.com> Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=81071 Cc: stable@vger.kernel.org
2014-08-18pata_scc: propagate return value of scc_wait_after_resetArjun Sreedharan
scc_bus_softreset not necessarily should return zero. Propagate the error code. Signed-off-by: Arjun Sreedharan <arjun024@gmail.com> Signed-off-by: Tejun Heo <tj@kernel.org> Cc: stable@vger.kernel.org
2014-08-17ata: ahci_tegra: Change include to fix compilationMikko Perttunen
Before this patch, the driver included <linux/tegra-powergate.h>, which was effectively renamed to <soc/tegra/pmc.h> at about the same time the ahci_tegra series landed. Fix the include path so that the driver compiles. Signed-off-by: Mikko Perttunen <mperttunen@nvidia.com> Acked-by: Thierry Reding <treding@nvidia.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2014-08-17pata_samsung_cf: change ret type to signedArjun Sreedharan
Change return type to signed int since it could be a negative errno. Signed-off-by: Arjun Sreedharan <arjun024@gmail.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2014-08-17ahci_xgene: Removing NCQ support from the APM X-Gene SoC AHCI SATA Host ↵Suman Tripathi
Controller driver. This patch removes the NCQ support from the APM X-Gene SoC AHCI Host Controller driver as it doesn't support it. Signed-off-by: Loc Ho <lho@apm.com> Signed-off-by: Suman Tripathi <stripathi@apm.com> Signed-off-by: Tejun Heo <tj@kernel.org> Cc: stable@vger.kernel.org
2014-08-06Merge branch 'akpm' (patchbomb from Andrew Morton)Linus Torvalds
Merge incoming from Andrew Morton: - Various misc things. - arch/sh updates. - Part of ocfs2. Review is slow. - Slab updates. - Most of -mm. - printk updates. - lib/ updates. - checkpatch updates. * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (226 commits) checkpatch: update $declaration_macros, add uninitialized_var checkpatch: warn on missing spaces in broken up quoted checkpatch: fix false positives for --strict "space after cast" test checkpatch: fix false positive MISSING_BREAK warnings with --file checkpatch: add test for native c90 types in unusual order checkpatch: add signed generic types checkpatch: add short int to c variable types checkpatch: add for_each tests to indentation and brace tests checkpatch: fix brace style misuses of else and while checkpatch: add --fix option for a couple OPEN_BRACE misuses checkpatch: use the correct indentation for which() checkpatch: add fix_insert_line and fix_delete_line helpers checkpatch: add ability to insert and delete lines to patch/file checkpatch: add an index variable for fixed lines checkpatch: warn on break after goto or return with same tab indentation checkpatch: emit a warning on file add/move/delete checkpatch: add test for commit id formatting style in commit log checkpatch: emit fewer kmalloc_array/kcalloc conversion warnings checkpatch: improve "no space after cast" test checkpatch: allow multiple const * types ...
2014-08-06Merge tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsiLinus Torvalds
Pull SCSI updates from James Bottomley: "This patch set consists of the usual driver updates (ufs, storvsc, pm8001 hpsa). It also has removal of the user space target driver code (everyone is using LIO now), a partial PCI MSI-X update, more multi-queue updates, conversion to 64 bit LUNs (so we could theoretically cope with any LUN returned by a device) and placeholder support for the ZBC device type (Shingle drives), plus an assortment of minor updates and bug fixes" * tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: (143 commits) scsi: do not issue SCSI RSOC command to Promise Vtrak E610f vmw_pvscsi: Use pci_enable_msix_exact() instead of pci_enable_msix() pm8001: Fix invalid return when request_irq() failed lpfc: Remove superfluous call to pci_disable_msix() isci: Use pci_enable_msix_exact() instead of pci_enable_msix() bfa: Use pci_enable_msix_exact() instead of pci_enable_msix() bfa: Cleanup bfad_setup_intr() function bfa: Do not call pci_enable_msix() after it failed once fnic: Use pci_enable_msix_exact() instead of pci_enable_msix() scsi: use short driver name for per-driver cmd slab caches scsi_debug: support scsi-mq, queues and locks Drivers: add blist flags scsi: ufs: fix endianness sparse warnings scsi: ufs: make undeclared functions static bnx2i: Update driver version to 2.7.10.1 pm8001: fix a memory leak in nvmd_resp pm8001: fix update_flash pm8001: fix a memory leak in flash_update pm8001: Cleaning up uninitialized variables pm8001: Fix to remove null pointer checks that could never happen ...
2014-08-06libata: Use glob_match from lib/glob.cGeorge Spelvin
The function may be useful for other drivers, so export it. (Suggested by Tejun Heo.) Note that I inverted the return value of glob_match; returning true on match seemed to make more sense. Signed-off-by: George Spelvin <linux@horizon.com> Cc: Randy Dunlap <rdunlap@infradead.org> Cc: Tejun Heo <tj@kernel.org> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-08-01ata: libahci: Silence compiler warning on 64-bitThierry Reding
Commit 725c7b570fda (ata: libahci_platform: move port_map parameters into the AHCI structure) moves flags into the struct ahci_host_priv's .flags field, which causes compiler warnings on 64-bit builds when that value is cast to a void * pointer. Cast to an unsigned long so that the subsequent cast to a pointer doesn't produce a warning. Signed-off-by: Thierry Reding <treding@nvidia.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2014-07-30ata: ahci_platform: add a generic AHCI compatibleAntoine Ténart
The ahci_platform driver is a generic driver using the libahci_platform functions. Add a generic compatible to avoid having an endless list of compatibles with no differences for the same driver. Signed-off-by: Antoine Ténart <antoine.tenart@free-electrons.com>
2014-07-30ata: libahci: allow to use multiple PHYsAntoine Ténart
The current implementation of the libahci does not allow to use multiple PHYs. This patch adds the support of multiple PHYs by the libahci while keeping the old bindings valid for device tree compatibility. This introduce a new way of defining SATA ports in the device tree, with one port per sub-node. This as the advantage of allowing a per port configuration. Because some ports may be accessible but disabled in the device tree, the port_map mask is computed automatically when using this. Signed-off-by: Antoine Ténart <antoine.tenart@free-electrons.com> Acked-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Kishon Vijay Abraham I <kishon@ti.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2014-07-30ata: libahci_platform: move port_map parameters into the AHCI structureAntoine Ténart
This patch moves force_port_map and mask_port_map into the ahci_host_priv structure. This allows to modify them into the AHCI framework. This is needed by the new dt bindings representing ports as the port_map mask is computed automatically. Parameters modifying force_port_map, mask_port_map and flags have been removed from the ahci_platform_init_host() function, and inputs in the ahci_host_priv structure are now directly filed. Signed-off-by: Antoine Ténart <antoine.tenart@free-electrons.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2014-07-30Merge branch 'for-3.16-fixes' of ↵Tejun Heo
git://git.kernel.org/pub/scm/linux/kernel/git/tj/libata into for-3.17 The scheduled ahci platform patches depend on change in for-3.16-fixes. Pull it into for-3.17. Signed-off-by: Tejun Heo <tj@kernel.org>
2014-07-30ahci: imx: add missing clk_disable_unprepare() on error in imx_sata_enable()Wei Yongjun
Add the missing clk_disable_unprepare() before return from imx_sata_enable() in the phy reset error handling case. Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Acked-by: Shawn Guo <shawn.guo@freescale.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2014-07-29ahci_xgene: Use correct OOB tunning parameters for APM X-Gene SoC AHCI SATA ↵Suman Tripathi
Host controller driver. APM X-Gene SoC AHCI SATA Host controller driver requires some correction of Phy Control OOB timing for the COMINIT/COMWAKE parameters to correctly interoperate with different kinds of disks. Signed-off-by: Loc Ho <lho@apm.com> Signed-off-by: Suman Tripathi <stripathi@apm.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2014-07-29ahci_xgene: Fix the watermark threshold for the APM X-Gene SATA host ↵Suman Tripathi
controller driver. As per SATA IO specification, when Host sends HOLD, the device takes about 20DW latency to reply to HOLDA. In some case, device doesn't response to HOLDA over 20DW and causes FIFO goes into over flow condition. Due to this condition, device enumerations fails with those devices. This patch adjust the watermark FIFO by increasing the FIFO depth from 0x16(default) to 0x30 to address this issue. Signed-off-by: Loc Ho <lho@apm.com> Signed-off-by: Suman Tripathi <stripathi@apm.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2014-07-23libata: introduce ata_host->n_tags to avoid oops on SAS controllersTejun Heo
1871ee134b73 ("libata: support the ata host which implements a queue depth less than 32") directly used ata_port->scsi_host->can_queue from ata_qc_new() to determine the number of tags supported by the host; unfortunately, SAS controllers doing SATA don't initialize ->scsi_host leading to the following oops. BUG: unable to handle kernel NULL pointer dereference at 0000000000000058 IP: [<ffffffff814e0618>] ata_qc_new_init+0x188/0x1b0 PGD 0 Oops: 0002 [#1] SMP Modules linked in: isci libsas scsi_transport_sas mgag200 drm_kms_helper ttm CPU: 1 PID: 518 Comm: udevd Not tainted 3.16.0-rc6+ #62 Hardware name: Intel Corporation S2600CO/S2600CO, BIOS SE5C600.86B.02.02.0002.122320131210 12/23/2013 task: ffff880c1a00b280 ti: ffff88061a000000 task.ti: ffff88061a000000 RIP: 0010:[<ffffffff814e0618>] [<ffffffff814e0618>] ata_qc_new_init+0x188/0x1b0 RSP: 0018:ffff88061a003ae8 EFLAGS: 00010012 RAX: 0000000000000001 RBX: ffff88000241ca80 RCX: 00000000000000fa RDX: 0000000000000020 RSI: 0000000000000020 RDI: ffff8806194aa298 RBP: ffff88061a003ae8 R08: ffff8806194a8000 R09: 0000000000000000 R10: 0000000000000000 R11: ffff88000241ca80 R12: ffff88061ad58200 R13: ffff8806194aa298 R14: ffffffff814e67a0 R15: ffff8806194a8000 FS: 00007f3ad7fe3840(0000) GS:ffff880627620000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 CR2: 0000000000000058 CR3: 000000061a118000 CR4: 00000000001407e0 Stack: ffff88061a003b20 ffffffff814e96e1 ffff88000241ca80 ffff88061ad58200 ffff8800b6bf6000 ffff880c1c988000 ffff880619903850 ffff88061a003b68 ffffffffa0056ce1 ffff88061a003b48 0000000013d6e6f8 ffff88000241ca80 Call Trace: [<ffffffff814e96e1>] ata_sas_queuecmd+0xa1/0x430 [<ffffffffa0056ce1>] sas_queuecommand+0x191/0x220 [libsas] [<ffffffff8149afee>] scsi_dispatch_cmd+0x10e/0x300 [<ffffffff814a3bc5>] scsi_request_fn+0x2f5/0x550 [<ffffffff81317613>] __blk_run_queue+0x33/0x40 [<ffffffff8131781a>] queue_unplugged+0x2a/0x90 [<ffffffff8131ceb4>] blk_flush_plug_list+0x1b4/0x210 [<ffffffff8131d274>] blk_finish_plug+0x14/0x50 [<ffffffff8117eaa8>] __do_page_cache_readahead+0x198/0x1f0 [<ffffffff8117ee21>] force_page_cache_readahead+0x31/0x50 [<ffffffff8117ee7e>] page_cache_sync_readahead+0x3e/0x50 [<ffffffff81172ac6>] generic_file_read_iter+0x496/0x5a0 [<ffffffff81219897>] blkdev_read_iter+0x37/0x40 [<ffffffff811e307e>] new_sync_read+0x7e/0xb0 [<ffffffff811e3734>] vfs_read+0x94/0x170 [<ffffffff811e43c6>] SyS_read+0x46/0xb0 [<ffffffff811e33d1>] ? SyS_lseek+0x91/0xb0 [<ffffffff8171ee29>] system_call_fastpath+0x16/0x1b Code: 00 00 00 88 50 29 83 7f 08 01 19 d2 83 e2 f0 83 ea 50 88 50 34 c6 81 1d 02 00 00 40 c6 81 17 02 00 00 00 5d c3 66 0f 1f 44 00 00 <89> 14 25 58 00 00 00 Fix it by introducing ata_host->n_tags which is initialized to ATA_MAX_QUEUE - 1 in ata_host_init() for SAS controllers and set to scsi_host_template->can_queue in ata_host_register() for !SAS ones. As SAS hosts are never registered, this will give them the same ATA_MAX_QUEUE - 1 as before. Note that we can't use scsi_host->can_queue directly for SAS hosts anyway as they can go higher than the libata maximum. Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: Mike Qiu <qiudayu@linux.vnet.ibm.com> Reported-by: Jesse Brandeburg <jesse.brandeburg@gmail.com> Reported-by: Peter Hurley <peter@hurleysoftware.com> Reported-by: Peter Zijlstra <peterz@infradead.org> Tested-by: Alexey Kardashevskiy <aik@ozlabs.ru> Fixes: 1871ee134b73 ("libata: support the ata host which implements a queue depth less than 32") Cc: Kevin Hao <haokexin@gmail.com> Cc: Dan Williams <dan.j.williams@intel.com> Cc: stable@vger.kernel.org
2014-07-22ahci: st: Make of_device_id array constKiran Padwal
Make of_device_id array const, because all OF functions handle it as const. Signed-off-by: Kiran Padwal <kiran.padwal21@gmail.com> Acked-by: Lee Jones <lee.jones@linaro.org> Signed-off-by: Tejun Heo <tj@kernel.org>
2014-07-22sata_sil24: Identify which card suffered IRQ status errorTim Small
In machines with multiple Silicon Image 3124 and/or 3132 cards, there is no way to tell which card is the culprit when the sata_sil24 interrupt handler gets a bad status. Tested-by: Tim Small <tim@seoss.co.uk> Signed-off-by: Tim Small <tim@seoss.co.uk> Signed-off-by: Tejun Heo <tj@kernel.org>
2014-07-18ahci: add support for the Promise FastTrak TX8660 SATA HBA (ahci mode)Romain Degez
Add support of the Promise FastTrak TX8660 SATA HBA in ahci mode by registering the board in the ahci_pci_tbl[]. Note: this HBA also provide a hardware RAID mode when activated in BIOS but specific drivers from the manufacturer are required in this case. Signed-off-by: Romain Degez <romain.degez@gmail.com> Tested-by: Romain Degez <romain.degez@gmail.com> Signed-off-by: Tejun Heo <tj@kernel.org> Cc: stable@vger.kernel.org
2014-07-18ata: Add support for the Tegra124 SATA controllerMikko Perttunen
This adds support for the integrated AHCI-compliant Serial ATA controller present on the NVIDIA Tegra124 system-on-chip. Signed-off-by: Mikko Perttunen <mperttunen@nvidia.com> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2014-07-18ata: ahci_platform: Increase AHCI_MAX_CLKS to 4Mikko Perttunen
The Tegra124 SATA controller requires 4 clocks. Increase this constant to be able to use them all. Signed-off-by: Mikko Perttunen <mperttunen@nvidia.com> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2014-07-17scsi: use 64-bit LUNsHannes Reinecke
The SCSI standard defines 64-bit values for LUNs, and large arrays employing large or hierarchical LUN numbers become more and more common. So update the linux SCSI stack to use 64-bit LUN numbers. Signed-off-by: Hannes Reinecke <hare@suse.de> Reviewed-by: Christoph Hellwig <hch@infradead.org> Reviewed-by: Ewan Milne <emilne@redhat.com> Signed-off-by: Christoph Hellwig <hch@lst.de>
2014-07-17drivers/ata/pata_ep93xx.c: use signed int type for result of platform_get_irq()Andrey Utkin
[linux-3.16-rc5/drivers/ata/pata_ep93xx.c:929]: (style) Checking if unsigned variable 'irq' is less than zero. Source code is irq = platform_get_irq(pdev, 0); if (irq < 0) { but unsigned int irq; $ fgrep platform_get_irq `find . -name \*.h -print` ./include/linux/platform_device.h:extern int platform_get_irq(struct platform_device *, unsigned int); Now using "int" type instead of "unsigned int" for "irq" variable. Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=80401 Reported-by: David Binderman <dcb314@hotmail.com> Signed-off-by: Andrey Utkin <andrey.krieger.utkin@gmail.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2014-07-15libata: EH should handle AMNF error condition as a media errorAlexey Asemov
libata-eh.c should handle AMNF error condition (error byte bit 0, usually code 0x01) in libata-eh.c along with UNC as a media error so SCSI stack can handle it properly (translation code 0x01 is already present in libata-scsi.c) but was never passed down due to lack of handling in EH. While using linux-based machine (AMD 6550M-based notebook, PCI IDs for the controller are 1022:7801 subsys 1025:059d) and ddrescue to salvage data from failing hard drive (WD7500BPVT 2.5" 750G SATA2), I've found that pure AMNF 0x01 error code generates generic "device error" that is retried several times by SCSI stack instead of "media error" that is passed up to software. So we may assume deprecated AMNF error code is surely not dead yet, and it's better for it to be handled properly. As we may see it is used by modern enough devices, and used properly: drive returned AMNF only when IDs for track cannot be read completely due to dying head or positioning, otherwise it returned UNC(orrectables). Not handling it causes wrong generic error code ("device error") reporting down the stack, can damage failing drives further because of excessive retries, and slows salvaging down a lot. Also, there is handling code in libata-scsi.c for 0x01 AMNF error already. https://bugzilla.kernel.org/show_bug.cgi?id=80031 tj: Shortened $SUBJ and moved its content to the first paragraph. Signed-off-by: Alexey Asemov <alex@alex-at.ru> Signed-off-by: Tejun Heo <tj@kernel.org>
2014-07-14libata: support the ata host which implements a queue depth less than 32Kevin Hao
The sata on fsl mpc8315e is broken after the commit 8a4aeec8d2d6 ("libata/ahci: accommodate tag ordered controllers"). The reason is that the ata controller on this SoC only implement a queue depth of 16. When issuing the commands in tag order, all the commands in tag 16 ~ 31 are mapped to tag 0 unconditionally and then causes the sata malfunction. It makes no senses to use a 32 queue in software while the hardware has less queue depth. So consider the queue depth implemented by the hardware when requesting a command tag. Fixes: 8a4aeec8d2d6 ("libata/ahci: accommodate tag ordered controllers") Cc: stable@vger.kernel.org Signed-off-by: Kevin Hao <haokexin@gmail.com> Acked-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2014-07-08ahci_xgene: fix the dma state machine lockup for the IDENTIFY DEVICE PIO ↵Suman Tripathi
mode command. This patch fixes the dma state machine lockup due to the processing of IDENTIFY DEVICE PIO mode command. The X-Gene AHCI controller has an errata in which it cannot clear the BSY bit after the PIO setup FIS. The dma state machine enters CMFatalErrorUpdate state and locks up. This patch also removes the dma restart workaround from the read_id function as the read_id function is only called by libata layer for ATA_INTERNAL commands. But for some cases eg: PORT MULTIPLIER and udev, the framework will enumerate using SCSI commands and it will not call read_id function. Signed-off-by: Loc Ho <lho@apm.com> Signed-off-by: Suman Tripathi <stripathi@apm.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2014-07-08libahci: export ahci_qc_issue() and ahci_start_fix_rx()Suman Tripathi
The subsequent patch will make use of them. Signed-off-by: Loc Ho <lho@apm.com> Signed-off-by: Suman Tripathi <stripathi@apm.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2014-07-01ata: ahci_imx: add disable for spread-spectrumRussell King
Spread-spectrum doesn't work with Cubox-i hardware, so we have to disable this feature. Add a DT property so that platforms can indicate that this feature should not be enabled. Having it as a negative property keeps existing DT files working. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Reviewed-by: Shawn Guo <shawn.guo@freescale.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2014-07-01ata: ahci_imx: allow hardware parameters to be specified in DTRussell King
Various SATA phy parameters are board specific, and therefore need to be configured. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Reviewed-by: Shawn Guo <shawn.guo@freescale.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2014-06-30ata: pata_samsung_cf: removes s5pc100 related ata codesKukjin Kim
This patch removes support for s5pc100 ata because of no more support S5PC100 SoC in mainline. Signed-off-by: Kukjin Kim <kgene.kim@samsung.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2014-06-24ata: ahci_imx: warn when disabling ahci linkRussell King
When the AHCI link is disabled, it can't be re-enabled except by resetting the entire SoC. Rather than doing this silently print some kernel messages to inform the user, along with how to avoid this. tj: Put a long printf format string on a single line. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Tejun Heo <tj@kernel.org>
2014-06-24ahci: disable ncq feature for hisilicon sataKefeng Wang
NCQ feature is unsupported on hisilicon sata controller, so disable it. This version of IP is used by hip04 and hix5hd2 soc. tj: "|=" was replaced with "=" for no reason. Restored "|=". Signed-off-by: Kefeng Wang <kefeng.wang@linaro.org> Sigend-off-by: Tejun Heo <tj@kernel.org>
2014-06-19ahci: imx: manage only sata_ref_clk in imx_sata_enable[disable]Shawn Guo
Doing suspend/resume on imx6q and imx53 boards with no SATA disk attached will trigger the following warning. ------------[ cut here ]------------ WARNING: CPU: 0 PID: 661 at drivers/ata/libahci.c:224 ahci_enable_ahci+0x74/0x8) Modules linked in: CPU: 0 PID: 661 Comm: sh Tainted: G W 3.15.0-rc5-next-20140521-000027 Backtrace: [<80011c90>] (dump_backtrace) from [<80011e2c>] (show_stack+0x18/0x1c) r6:803a22f4 r5:00000000 r4:00000000 r3:00000000 [<80011e14>] (show_stack) from [<80661e60>] (dump_stack+0x88/0xa4) [<80661dd8>] (dump_stack) from [<80028fdc>] (warn_slowpath_common+0x70/0x94) r5:00000009 r4:00000000 [<80028f6c>] (warn_slowpath_common) from [<80029024>] (warn_slowpath_null+0x24/) r8:808f68c4 r7:00000000 r6:00000000 r5:00000000 r4:e0810004 [<80029000>] (warn_slowpath_null) from [<803a22f4>] (ahci_enable_ahci+0x74/0x80) [<803a2280>] (ahci_enable_ahci) from [<803a2324>] (ahci_reset_controller+0x24/0) r8:ddcd9410 r7:80351178 r6:ddcd9444 r5:dde8b850 r4:e0810000 r3:ddf35e90 [<803a2300>] (ahci_reset_controller) from [<803a2c68>] (ahci_platform_resume_ho) r7:80351178 r6:ddcd9444 r5:dde8b850 r4:ddcd9410 [<803a2c30>] (ahci_platform_resume_host) from [<803a38f0>] (imx_ahci_resume+0x2) r5:00000000 r4:ddcd9410 [<803a38c4>] (imx_ahci_resume) from [<803511ac>] (platform_pm_resume+0x34/0x54) .... The reason is that the SATA controller has no working clock at this point, and thus ahci_enable_ahci() fails to enable the controller. In case that there is no SATA disk attached, the imx_sata_disable() gets called in ahci_imx_error_handler(), and both sata_clk and sata_ref_clk will be disabled there. Because all the imx_sata_enable() calls afterward will return immediately due to imxpriv->no_device check, the SATA controller working clock sata_clk will never get any chance to be enabled again. This is a regression caused by commit 90870d79d4f2 (ahci-imx: Port to library-ised ahci_platform). Before the commit, only sata_ref_clk is managed by the driver in enable/disable function. But after the commit, all the clocks are enabled/disabled in a row by ahci platform helpers ahci_platform_enable[disable]_clks. Since ahb_clk is a bus clock which does not have gate at all, and i.MX low-power hardware module already manages sata_clk across suspend/resume cycle, the only clock that needs to be managed by software is sata_ref_clk. So instead of using ahci_platform_enable[disable]_clks to manage all the clocks in a row from imx_sata_enable[disable], we should manage only sata_ref_clk in there. Reported-by: Fabio Estevam <fabio.estevam@freescale.com> Fixes: 90870d79d4f2 (ahci-imx: Port to library-ised ahci_platform) Signed-off-by: Shawn Guo <shawn.guo@freescale.com> Acked-by: Hans de Goede <hdegoede@redhat.com>
2014-06-17ahci/xgene: Remove logic to set 64-bit DMA maskSuravee Suthikulpanit
Instead of doing the check here, this should be handled in the common AHCI platform code. Signed-off-by: Suravee Suthikulpanit <Suravee.Suthikulpanit@amd.com> Suggested-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com> Cc: Loc Ho <lho@apm.com> Cc: Tuan Phan <tphan@apm.com> Cc: Suman Triphati <stripathi@apm.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2014-06-17ahci: Check and set 64-bit DMA mask for platform AHCI driverSuravee Suthikulpanit
The current platform AHCI driver does not set the dma_mask correctly for 64-bit DMA capable AHCI controller. This patch checks the AHCI capability bit and set the dma_mask and coherent_dma_mask accordingly. Signed-off-by: Suravee Suthikulpanit <Suravee.Suthikulpanit@amd.com> Reviewed-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com> Reviewed-by: Hans de Goede <hdegoede@redhat.com> Tested-by: Hans de Goede <hdegoede@redhat.com> Tested-by: Suman Tripathi <stripathi@apm.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2014-06-17libahci_platform: Fail when PHY required but PHY support disabledMikko Perttunen
ahci_platform_get_resources handles resource management for platform AHCI drivers, including getting a possible PHY from the device tree. Since not all drivers need a PHY, it ignores -ENODEV and -ENOSYS from devm_get_phy. However, when the PHY subsystem is mistakenly disabled, -ENOSYS can be returned even when a PHY is needed. This patch modifies the -ENOSYS case to check if a "phys" device tree node exists. If it exists, then clearly the PHY subsystem is mistakenly disabled and the driver cannot work, ahci_platform_get_resources will fail and propagate the error. Signed-off-by: Mikko Perttunen <mperttunen@nvidia.com> Acked-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2014-06-17ata: Use dma_zalloc_coherentJoe Perches
Use the zeroing function instead of dma_alloc_coherent & memset(,0,) Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2014-06-09Merge branch 'for-3.16' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/libata Pull libata updates from Tejun Heo: "Nothing too interesting - another ahci platform driver variant, additional controller support, minor fixes and cleanups" * 'for-3.16' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/libata: ahci: Add Device ID for HighPoint RocketRaid 642L ata: ep93xx: use dmaengine_prep_slave_sg api instead of internal callback ahci: add PCI ID for Marvell 88SE91A0 SATA Controller sata_fsl: remove check for CONFIG_MPC8315_DS ahci: add support for Hisilicon sata libahci_platform: add host_flags parameter in ahci_platform_init_host() ata: ahci: append new hflag AHCI_HFLAG_NO_FBS ata: use CONFIG_PM_SLEEP instead of CONFIG_PM where applicable in host drivers ata: ahci_mvebu: new driver for Marvell Armada 380 AHCI interfaces Documentation: dt-bindings: reformat and order list of ahci-platform compatibles libata-sff: remove dead code ata: SATL compliance for Inquiry Product Revision pata_octeon_cf: use devm_kzalloc() to allocate cf_port
2014-06-03ahci: Add Device ID for HighPoint RocketRaid 642LJérôme Carretero
This device normally comes with a proprietary driver, using a web GUI to configure RAID: http://www.highpoint-tech.com/USA_new/series_rr600-download.htm But thankfully it also works out of the box with the AHCI driver, being just a Marvell 88SE9235. Devices 640L, 644L, 644LS should also be supported but not tested here. Signed-off-by: Jérôme Carretero <cJ-ko@zougloub.eu> Signed-off-by: Tejun Heo <tj@kernel.org> Cc: stable@vger.kernel.org
2014-06-02libata: Blacklist queued trim for Crucial M500Martin K. Petersen
Queued trim only works for some users with MU05 firmware. Revert to blacklisting all firmware versions. Introduced by commit d121f7d0cbb8 ("libata: Update queued trim blacklist for M5x0 drives") which this effectively reverts, while retaining the blacklisting of M550. See https://bugzilla.kernel.org/show_bug.cgi?id=71371 for reports of trouble with MU05 firmware. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Tejun Heo <tj@kernel.org> Cc: stable@vger.kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-05-27ata: ep93xx: use dmaengine_prep_slave_sg api instead of internal callbackBarry Song
it is better to use generic api instead of calling an internal callback like channel->device->device_prep_slave_sg(). Signed-off-by: Barry Song <Baohua.Song@csr.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2014-05-27ahci: add PCI ID for Marvell 88SE91A0 SATA ControllerAndreas Schrägle
Add support for Marvell Technology Group Ltd. 88SE91A0 SATA 6Gb/s Controller by adding its PCI ID. Signed-off-by: Andreas Schrägle <ajs124.ajs124@gmail.com> Signed-off-by: Tejun Heo <tj@kernel.org> Cc: stable@vger.kernel.org
2014-05-21sata_fsl: remove check for CONFIG_MPC8315_DSPaul Bolle
A check for CONFIG_MPC8315_DS was added in v2.6.24. But the related Kconfig symbol was never added to the tree. So the code behind this check has effectively been dead for over six years. Remove it. Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: Tejun Heo <tj@kernel.org>
2014-05-21Merge branch 'for-3.15-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/libata Pull libata fixes from Tejun Heo: "Mostly device-specific fixes. The only thing which isn't is the fix for zpodd oops-on-detach bug" * 'for-3.15-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/libata: ahci: imx: PLL clock needs 100us to settle down ata: pata_at91 only works on sam9 libata: clean up ZPODD when a port is detached ahci: imx: software workaround for phy reset issue in resume ahci: imx: add namespace for register enums ahci: disable DEVSLP for Intel Valleyview
2014-05-19ahci: imx: PLL clock needs 100us to settle downShawn Guo
The commit e783c51 (ahci: imx: software workaround for phy reset issue in resume) calls imx_sata_phy_reset() to reset phy immediately after SATA MPLL is enabled. It seems working fine mostly, but fails in some case as below. ... ahci-imx 2200000.sata: failed to reset phy: -110 ahci-imx: probe of 2200000.sata failed with error -110 After talking to the designer, we learnt that when enabling i.MX6Q SATA MPLL, we need to wait 100us for it to settle down for safety. Add this required delay to fix above failure. Signed-off-by: Shawn Guo <shawn.guo@freescale.com> Tested-by: Fabio Estevam <fabio.estevam@freescale.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2014-05-14ahci: add support for Hisilicon sataKefeng Wang
The hip04 SoC of hisilicon has an AHCI compliant SATA controller, and it is compliant with the ahci 1.3 and sata 3.0 specification. There is a wrong bit in HOST_CAP of hip04 sata controller, which enable unsupported feature of FBS, use AHCI_HFLAG_NO_FBS hflag to disable it. Reviewed-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Kefeng Wang <kefeng.wang@linaro.org> Signed-off-by: Tejun Heo <tj@kernel.org>
2014-05-14libahci_platform: add host_flags parameter in ahci_platform_init_host()Kefeng Wang
Add a dynamic host_flags argument to make ahci_platform_init_host more flexible, then remove the AHCI_HFLAGS(...) argument from some driver's ata_port_info, and pass that in as the new argument. Cc: Hans de Geode <hdegoede@redhat.com> Reviewed-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Kefeng Wang <kefeng.wang@linaro.org> Signed-off-by: Tejun Heo <tj@kernel.org>
2014-05-14ata: ahci: append new hflag AHCI_HFLAG_NO_FBSKefeng Wang
Append AHCI_HFLAG_NO_FBS to force turning off FBS flag. Reviewed-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Haojian Zhuang <haojian.zhuang@linaro.org> Signed-off-by: Kefeng Wang <kefeng.wang@linaro.org> Signed-off-by: Tejun Heo <tj@kernel.org>
2014-05-09ata: use CONFIG_PM_SLEEP instead of CONFIG_PM where applicable in host driversBartlomiej Zolnierkiewicz
This patch fixes host drivers to use CONFIG_PM_SLEEP instead of CONFIG_PM where applicable. Benefits of this change: * unused code is not being compiled in for CONFIG_PM=y, CONFIG_PM_SLEEP=n and CONFIG_PM_RUNTIME=y configurations * easier transition to use struct dev_pm_ops and SIMPLE_DEV_PM_OPS() in the future * more consistent code (there are host drivers which are using the correct CONFIG_PM_SLEEP checks already) The patch leaves the core libata code and ->port_[suspend,resume] support in sata_[inic162x,nv,sil24].c alone for now. Signed-off-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com> Signed-off-by: Tejun Heo <tj@kernel.org>
