- Fix a bug in ahci-tegra.c when checking if SATA is on when resuming
- Add codes to support PM315 which uses LDO1 regulator for SATA rails
bug 1206518
Change-Id: Iaa910b1948fbcf5e45491977fd8ed0b313d2e0ae
Signed-off-by: Yen Lin <yelin@nvidia.com>
Reviewed-on: http://git-master/r/188441
(cherry picked from commit c319d0e904e6bff6e6c89d3c8cf651949c379925)
Signed-off-by: Bryan Wu <pengw@nvidia.com>
Change-Id: Ib1ec166c1140a5162e0bca163c1e2857c734d587
Reviewed-on: http://git-master/r/226765
GVS: Gerrit_Virtual_Submit
Reviewed-by: Matthew Pedro <mapedro@nvidia.com>
Reviewed-by: Eric Brower <ebrower@nvidia.com>
Reviewed-by: Allen Martin <amartin@nvidia.com>
Bug 1243631
Change-Id: I915826047b2e20f0ad0a7d75df295c6cbf6e5b0a
commit 3aee8bc52c415aba8148f144e5e5359b0fd75dd1 upstream.
This patch adds the IDE-mode SATA Device IDs for the Intel Wellsburg PCH
Signed-off-by: James Ralston <james.d.ralston@intel.com>
commit aaa515277db9585eeb4fdeb4637b9f9df50a1dd9 upstream.
This patch adds the IDE-mode SATA DeviceIDs for the Intel Avoton SOC.
Signed-off-by: Seth Heasley <seth.heasley@intel.com>
commit 7b4f6ecacb14f384adc1a5a67ad95eb082c02bd1 upstream.
They don't always appear as AHCI class devices but instead as IDE class.
Based on an initial patch by Hiroaki Nito
Resolves-bug: https://bugzilla.kernel.org/show_bug.cgi?id=42804
Signed-off-by: Alan Cox <alan@linux.intel.com>
Signed-off-by: Abdallah Chatila <abdallah.chatila@ericsson.com>
commit 7f9c9f8e24590e7dcd26ca408458c43df5b83e61 upstream.
Silicon does not support standard AHCI BAR assignment. Add
vendor/device exception to force BAR 2.
Signed-off-by: Hugh Daschbach <hugh.daschbach@enmotus.com>
commit 26cd4d65deba587f3cf2329b6869ce02bcbe68ec upstream.
Following oops were observed when disk error happened:
[ 4272.896937] sd 0:0:0:0: [sda] Unhandled error code
[ 4272.896939] sd 0:0:0:0: [sda] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[ 4272.896942] sd 0:0:0:0: [sda] CDB: Read(10): 28 00 00 5a de a7 00 00 08 00
[ 4272.896951] end_request: I/O error, dev sda, sector 5955239
[ 4291.574947] BUG: unable to handle kernel NULL pointer dereference at (null)
[ 4291.658305] IP: [] ahci_activity_show+0x1/0x40
[ 4291.730090] PGD 76dbbc067 PUD 6c4fba067 PMD 0
[ 4291.783408] Oops: 0000 [#1] SMP
[ 4291.822100] last sysfs file: /sys/devices/pci0000:00/0000:00:1f.2/host0/target0:0:0/0:0:0:0/sw_activity
[ 4291.934235] CPU 9
[ 4291.958301] Pid: 27942, comm: hwinfo ......
ata_scsi_find_dev could return NULL, so ata_scsi_activity_{show,store} should check if atadev is NULL.
Signed-off-by: Xiaotian Feng <dannyfeng@tencent.com>
Cc: James Bottomley <JBottomley@Parallels.com>
commit 5416912af75de9cba5d1c75b99a7888b0bbbd2fb upstream.
ata_device->dma_mode's initial value is zero, which is not a valid dma
mode, but ata_dma_enabled will return true for this value. This patch
sets dma_mode to 0xff in reset function, so that ata_dma_enabled will
not return true for this case, or it will cause problem for pata_acpi.
The corrsponding bugzilla page is at:
https://bugzilla.kernel.org/show_bug.cgi?id=49151
Reported-by: Phillip Wood <phillip.wood@dunelm.org.uk>
Signed-off-by: Aaron Lu <aaron.lu@intel.com>
Tested-by: Szymon Janc <szymon@janc.net.pl>
Tested-by: Dutra Julio <dutra.julio@gmail.com>
Acked-by: Alan Cox <alan@linux.intel.com>
commit 3100d49d3cd236443faae9d81137c81b22d36003 upstream.
sata_promise's pdc_hard_reset_port() needs to serialize because it
flips a port-specific bit in controller register that's shared by
all ports. The code takes the ata host lock for this, but that's
broken because an interrupt may arrive on our irq during the hard
reset sequence, and that too will take the ata host lock. With
lockdep enabled a big nasty warning is seen.
Fixed by adding private state to the ata host structure, containing
a second lock used only for serializing the hard reset sequences.
This eliminated the lockdep warnings both on my test rig and on
the original reporter's machine.
Signed-off-by: Mikael Pettersson <mikpe@it.uu.se>
Tested-by: Adko Branil <adkobranil@yahoo.com>
commit b03e66a6be91f8389fcd902ab6c1563db1c9c06b upstream.
If kdump is triggered with pending IO, controller may not respond causing
kdump to fail.
http://marc.info/?l=linux-ide&m=133032255424658&w=2
During error recovery ata_do_dev_read_id never completes due hang
in mmio_insw.
ata_do_dev_read_id
ata_sff_data_xfer
ioread16_rep
mmio_insw
if DMA start bit is cleared before reset, PIO command is successful
and kdump succeeds.
Signed-off-by: David Milburn <dmilburn@redhat.com>
Cc: CAI Qian <caiqian@redhat.com>
If the board has sata support, then only add platform device
Also move slumber code to Idle powergate section to
avoid build failure.
Bug 1157036
Change-Id: I6128f451f348a7fad41fc52579b18939c8a2efcd
Original-author: Mike Thompson <mikthompson@nvidia.com>
Signed-off-by: Mike Thompson <mikthompson@nvidia.com>
Signed-off-by: Bibek Basu <bbasu@nvidia.com>
Signed-off-by: Syed Rafiuddin <srafiuddin@nvidia.com>
Reviewed-on: http://git-master/r/143984
Reviewed-by: Simone Willett <swillett@nvidia.com>
commit c531077f40abc9f2129c4c83a30b3f8d6ce1c0e7 upstream.
When using my Seagate FreeAgent GoFlex eSATAp external disk enclosure,
interface errors are always seen until 1.5Gbps is negotiated [1]. This
occurs using any disk in the enclosure, and when the disk is connected
directly with a generic passive eSATAp cable, we see stable 3Gbps
operation as expected.
Blacklist 3Gbps mode to avoid dataloss and the ~30s delay bus reset
and renegotiation incurs.
Signed-off-by: Daniel J Blueman <daniel@quora.org>
commit 17c60c6b763cb5b83b0185e7d38d01d18e55a05a upstream.
This can also appear as 0x9192. Reported in bugzilla and confirmed with the
board documentation for these boards.
Resolves-bug: https://bugzilla.kernel.org/show_bug.cgi?id=42970
arch/arm/boot/compressed/Makefile
arch/arm/boot/compressed/atags_to_fdt.c
arch/arm/boot/compressed/head.S
arch/arm/boot/dts/tegra30.dtsi
arch/arm/include/asm/bug.h
arch/arm/kernel/traps.c
arch/arm/mach-tegra/Makefile.boot
arch/arm/mach-tegra/board-cardhu-sdhci.c
arch/arm/mach-tegra/board-cardhu.c
arch/arm/mach-tegra/board-enterprise-sdhci.c
arch/arm/mach-tegra/board-enterprise.c
arch/arm/mach-tegra/board-harmony.c
arch/arm/mach-tegra/board-kai-sdhci.c
arch/arm/mach-tegra/board-ventana.c
arch/arm/mach-tegra/board-whistler.c
arch/arm/mach-tegra/clock.h
arch/arm/mach-tegra/fuse.h
arch/arm/mach-tegra/tegra2_usb_phy.c
arch/arm/mach-tegra/tegra3_clocks.c
arch/arm/mach-tegra/tegra3_dvfs.c
arch/arm/mach-tegra/tegra3_speedo.c
arch/arm/mach-tegra/timer.c
arch/arm/mach-tegra/usb_phy.c
arch/arm/mach-tegra/wakeups-t3.c
drivers/cpufreq/cpufreq_interactive.c
drivers/input/touchscreen/atmel_mxt_ts.c
drivers/mfd/tps65090.c
drivers/mmc/core/mmc.c
drivers/mmc/host/sdhci-tegra.c
drivers/mmc/host/sdhci.c
drivers/net/wireless/bcmdhd/bcmsdh_sdmmc_linux.c
drivers/regulator/Kconfig
drivers/regulator/core.c
drivers/regulator/tps80031-regulator.c
drivers/spi/Makefile
drivers/staging/nvec/nvec.c
drivers/tty/serial/Makefile
include/linux/mmc/card.h
sound/soc/tegra/tegra_max98095.c
sound/usb/card.c
Change-Id: I65043bc6ce9e97d0592683462215a39e50f403fd
Reviewed-on: http://git-master/r/121392
Reviewed-by: Bo Yan <byan@nvidia.com>
Tested-by: Bo Yan <byan@nvidia.com>
commit cd006086fa5d91414d8ff9ff2b78fbb593878e3c upstream.
When we are hosted on a Microsoft Hyper-V hypervisor the guest disks
are exposed both via the Hyper-V paravirtualised drivers and via an
emulated SATA disk drive. In this case we want to use the paravirtualised
drivers if we can as they are much more efficient. Note that the Hyper-V
paravirtualised drivers only expose the virtual hard disk devices, the
CDROM/DVD devices must still be enumerated.
Mark the host controller ATA_HOST_IGNORE_ATA to prevent enumeration of
disk devices.
BugLink: http://bugs.launchpad.net/bugs/929545
BugLink: http://bugs.launchpad.net/bugs/942316
Signed-off-by: Andy Whitcroft <apw@canonical.com>
Cc: Victor Miasnikov <vvm@tut.by>
commit db63a4c8115a0bb904496e1cdd3e7488e68b0d06 upstream.
Where devices are visible via more than one host we sometimes wish to
indicate that cirtain devices should be ignored on a specific host. Add a
host flag indicating that this host wishes to ignore ATA specific devices.
Upgrade the Tegra 3 SATA driver to support kernel 3.1.
The driver supports runtime_pm when doing power-gating during idle.
A new CONFIG_TEGRA_SATA_IDLE_POWERGATE is provided to enable/disable
When sata clocks (sata, sata-oob and pll_e clocks) are in the
core_dvfs_table[] table, CONFIG_TEGRA_SATA_IDLE_POWERGATE must not
be enabled.
Currently, sata clocks are in the core_dvfs_table[]. Those clocks
will not be in that table in the future. By then,
CONFIG_TEGRA_SATA_IDLE_POWERGATE can then be enabled.
Change-Id: I15b585713bfd891f8827fd028b21bf3e5c2b80d9
Reviewed-on: http://git-master/r/89614
Reviewed-by: Jon Mayo <jmayo@nvidia.com>
Reviewed-by: Yu-Huan Hsu <yhsu@nvidia.com>
SPEAr13xx series of SoCs contain Synopsys AHCI SATA Controller which shares
ahci_platform driver with other controller versions.
This patch updates DT compatible list for ahci_platform. It also updates and
renames binding documentation to more generic name.
Signed-off-by: Viresh Kumar <viresh.kumar@st.com>
Cc: Rob Herring <rob.herring@calxeda.com>
#ifdef, #endif is not required in definition/usage of arasan_cf_pm_ops. So, move
this definition and its usage outside of them.
When comparing the dmesg between 3.4-rc3 and 3.4-rc4 I found the
following differences:
-ata1: SATA max UDMA/133 abar m2048@0xf9fff000 port 0xf9fff100 irq 47
-ata2: SATA max UDMA/133 abar m2048@0xf9fff000 port 0xf9fff180 irq 47
-ata3: DUMMY
+ata2: SATA max UDMA/133 abar m2048@0xf9fff000 port 0xf9fff100 irq 47
+ata3: SATA max UDMA/133 abar m2048@0xf9fff000 port 0xf9fff180 irq 47
ata4: DUMMY
ata5: DUMMY
-ata6: SATA max UDMA/133 abar m2048@0xf9fff000 port 0xf9fff380 irq 47
+ata6: DUMMY
+ata7: SATA max UDMA/133 abar m2048@0xf9fff000 port 0xf9fff380 irq 47
The change of numbering comes from commit 85d6725b7c0d7e3f ("libata:
make ata_print_id atomic") that changed lines like
ap->print_id = ata_print_id++;
to
ap->print_id = atomic_inc_return(&ata_print_id);
As the latter behaves like ++ata_print_id, we must initialize
it to zero to start the numbering from one.
Signed-off-by: Tero Roponen <tero.roponen@gmail.com>
Acked-by: Dan Williams <dan.j.williams@intel.com>
The Marvell 88SE9172 SATA controller (PCI ID 1b4b 917a) already worked
once it was detected, but was missing an ahci_pci_tbl entry.
Boot tested on a Gigabyte Z68X-UD3H-B3 motherboard.
Signed-off-by: Matt Johnson <johnso87@illinois.edu>
Commit d902747("[libata] Add ATA transport class") introduced
ATA_EFLAG_OLD_ER to mark entries in the error ring as cleared.
But ata_count_probe_trials_cb() didn't check this flag and it still
counts the old error history. So wrong probe trials count is returned
and it causes problem, for example, SATA link speed is slowed down from
3.0Gbps to 1.5Gbps.
Fix it by checking ATA_EFLAG_OLD_ER in ata_count_probe_trials_cb().
Cc: stable <stable@vger.kernel.org> # 2.6.37+
Signed-off-by: Lin Ming <ming.m.lin@intel.com>
This changes the ordering of initialization and probing events from:
1/ allocate rphy in PORTE_BYTES_DMAED, DISCE_REVALIDATE_DOMAIN
2/ allocate ata_port and schedule port probe in DISCE_PROBE
...to:
1/ allocate ata_port in PORTE_BYTES_DMAED, DISCE_REVALIDATE_DOMAIN
2/ allocate rphy in PORTE_BYTES_DMAED, DISCE_REVALIDATE_DOMAIN
3/ schedule port probe in DISCE_PROBE
This ordering prevents PHYE_SIGNAL_LOSS_EVENTS from sneaking in to
destrory ata devices before they have been fully initialized:
BUG: unable to handle kernel paging request at 0000000000003b10
IP: [<ffffffffa0053d7e>] sas_ata_end_eh+0x12/0x5e [libsas]
[<ffffffffa004d1af>] sas_unregister_common_dev+0x78/0xc9 [libsas]
[<ffffffffa004d4d4>] sas_unregister_dev+0x4f/0xad [libsas]
[<ffffffffa004d5b1>] sas_unregister_domain_devices+0x7f/0xbf [libsas]
[<ffffffffa004c487>] sas_deform_port+0x61/0x1b8 [libsas]
[<ffffffffa004bed0>] sas_phye_loss_of_signal+0x29/0x2b [libsas]
...and kills the awkward "sata domain_device briefly existing in the
domain without an ata_port" state.
Reported-by: Michal Kosciowski <michal.kosciowski@intel.com>
Acked-by: Jeff Garzik <jgarzik@redhat.com>
Signed-off-by: James Bottomley <JBottomley@Parallels.com>
Use scsi_add_host_with_dma in ata_scsi_add_hosts to pass in the
correct DMA device(ATA host).
Bug report: http://marc.info/?l=linux-ide&m=133177818318187&w=2
Reported-and-tested-by: Jörg Sommer <joerg@alea.gnuu.de>
git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev
Pull libata fixes from Jeff Garzik:
1) Fix regression that could cause a misdiagnosis, which in turn could
lead to an erroneous 3.0 Gbps -> 1.5 downshift, particularly when hotplug
and suspend/resume is involved.
2) Fix a regression that led to ata%d controller ids being numbered one
larger than in <= 3.4-rc3 (oh, the horror!). Controller ids should now be
as expected.
3) add some DT, PCI id's
4) ata/pata_arasan_cf: minor cpp fixing/cleaning
* tag 'tag/upstream-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev:
ata: ahci_platform: Add synopsys ahci controller in DT's compatible list
ata/pata_arasan_cf: Move arasan_cf_pm_ops out of #ifdef, #endif macros
libata: init ata_print_id to 0
ahci: Detect Marvell 88SE9172 SATA controller
libata: skip old error history when counting probe trials
-ata3: DUMMY
ata4: DUMMY
ata5: DUMMY
+ata6: DUMMY
to
3.0Gbps to 1.5Gbps.
Forbid port runtime pm by default because it has known hotplug issue.
User can allow it by, for example
echo auto > /sys/devices/pci0000:00/0000:00:1f.2/ata2/power/control
This variable is incremented from multiple contexts (module_init via
libata-lldds and the libsas discovery thread). Make it atomic to head
off any chance of libsas and libata creating duplicate ids.
Acked-by: Jacek Danecki <jacek.danecki@intel.com>
Gcc version 4.6.2-12 complains that if we can't find the "nr-ports"
property in of_property_read_u32_array() then "n_ports" is used
uninitialized. Let's set it to zero in that case.
This patch adds the IDE-mode SATA DeviceIDs for the Intel DH89xxCC PCH.
...to:
Change-Id: Ib3b69ffc5ac3e07c9cc44cc49e9142088eec477e
Pull libata updates from Jeff Garzik:
1) AHCI regression fix. A recent "make driver conform to spec" change
broke on deployed hardware. Make new behavior optional, rather than
default, turning it on only for specific embedded platforms that
need this.
Everybody else runs in the famous "non conformant but working" mode.
2) pata_cmd64x, pata_legacy cleanups
3) new Intel SATA PCI IDs
4) misc minor vendor feature additions
* tag 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev:
pata_cmd64x: implement sff_irq_check() method
pata_cmd64x: implement sff_irq_clear() method
pata_cmd64x: use interrupt status from MRDMODE register
pata_cmd64x: turn string of *if* statements into *switch*
drivers/ata/pata_mpc52xx.c: clean up error handling code
ahci_platform: add STRICT_AHCI platform type
ahci: move AHCI_HFLAGS() macro to ahci.h
ahci: add AHCI_HFLAG_DELAY_ENGINE host flag
sata_fsl: add support for interrupt coalsecing feature
ata/pata_arasan_cf: Add Hibernation support
pata_legacy: correctly mask recovery field for HT6560B
ata_piix: IDE-mode SATA patch for Intel Lynx Point DeviceIDs
ahci: AHCI-mode SATA patch for Intel Lynx Point DeviceIDs
git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6
SCSI updates from James Bottomley:
"The update includes the usual assortment of driver updates (lpfc,
qla2xxx, qla4xxx, bfa, bnx2fc, bnx2i, isci, fcoe, hpsa) plus a huge
amount of infrastructure work in the SAS library and transport class
as well as an iSCSI update. There's also a new SCSI based virtio
driver."
* tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (177 commits)
[SCSI] qla4xxx: Update driver version to 5.02.00-k15
[SCSI] qla4xxx: trivial cleanup
[SCSI] qla4xxx: Fix sparse warning
[SCSI] qla4xxx: Add support for multiple session per host.
[SCSI] qla4xxx: Export CHAP index as sysfs attribute
[SCSI] scsi_transport: Export CHAP index as sysfs attribute
[SCSI] qla4xxx: Add support to display CHAP list and delete CHAP entry
[SCSI] iscsi_transport: Add support to display CHAP list and delete CHAP entry
[SCSI] pm8001: fix endian issue with code optimization.
[SCSI] pm8001: Fix possible racing condition.
[SCSI] pm8001: Fix bogus interrupt state flag issue.
[SCSI] ipr: update PCI ID definitions for new adapters
[SCSI] qla2xxx: handle default case in qla2x00_request_firmware()
[SCSI] isci: improvements in driver unloading routine
[SCSI] isci: improve phy event warnings
[SCSI] isci: debug, provide state-enum-to-string conversions
[SCSI] scsi_transport_sas: 'enable' phys on reset
[SCSI] libsas: don't recover end devices attached to disabled phys
[SCSI] libsas: fixup target_port_protocols for expanders that don't report sata
[SCSI] libsas: set attached device type and target protocols for local phys
Signed-off-by: Cong Wang <amwang@redhat.com>
Implement sff_irq_check() method for both old and new chips.
Convert the driver's two bmdma_stop() methods into sff_irq_clear() methods --
they shouldn't have been bothering with clearing interrupts from the very start;
the driver will now use the standard bmdma_stop() method implementation (where
appropriate).
Start using faster version of the bmdma_stop() method for the PCI0646U and newer
chips that have the duplicate interrupt status bits in the I/O mapped MRDMODE
register. Use the old, slow bmdma_stop() method on the older chips, taking into
account that the interrupt bits are not coupled to DMA and that's enough to read
the register to clear the interrupt (on the older chips). Determine what method
to use at the driver load time.
Fix kernel-doc of the bmdma_stop() methods, while at it.
Convert string of the *if* statements all checking 'pdev->revision' into more
natural *switch* statement. While at it, somewhat clarify the comments there...
Increment the driver version, accounting for the patches that neglected to do
this in the past.
This patch makes a number of changes with respect to the error-handling
code:
* Remove cleanup calls for the devm functions in both the error handling
code and the remove function. This cleanup is done automatically.
* The previous change simplifies the cleanup code at the end of the
function such that there is nothing to do on the failure of the call to
devm_ioremap. So it is changed to just return directly.
* There is no need for the ifs in the cleanup code at the end of the
function, because in each case the cleanup needed is statically
known. Drop the ifs, add new err labels, and drop the initializations of
the tested variables to NULL.
* Change the call to request_irq to a call to devm_request_irq, so that it
is cleaned up on exit.
* Cause the return value of devm_request_irq to go into the returned
variable rv rather than the unused variable ret. Drop ret.
Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr>
