path: root/drivers/atm
2011-07-26atomic: use <linux/atomic.h>Arun Sharma
This allows us to move duplicated code in <asm/atomic.h> (atomic_inc_not_zero() for now) to <linux/atomic.h> Signed-off-by: Arun Sharma <asharma@fb.com> Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Miller <davem@davemloft.net> Cc: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-12lanai: use pci_dev->subsystem_deviceSergei Shtylyov
The driver reads PCI subsystem IDs from the PCI configuration registers while it is already stored by the PCI subsystem in the 'subsystem_device' field of 'struct pci_dev'... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-08ATM: Delete no use FILL_RX_POOLS_IN_BH marcoWang Shaoyan
The macro FILL_RX_POOLS_IN_BH is never been used, in order to avoid the compiler reports error because of the usage of function INIT_WORK, we just delete the marco. Cc: Chas Williams <chas@cmf.nrl.navy.mil> Cc: linux-atm-general@lists.sourceforge.net Signed-off-by: Wang Shaoyan <wangshaoyan.pt@taobao.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-06net: remove interrupt.h inclusion from netdevice.hAlexey Dobriyan
* remove interrupt.g inclusion from netdevice.h -- not needed * fixup fallout, add interrupt.h and hardirq.h back where needed. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-20Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1446 commits) macvlan: fix panic if lowerdev in a bond tg3: Add braces around 5906 workaround. tg3: Fix NETIF_F_LOOPBACK error macvlan: remove one synchronize_rcu() call networking: NET_CLS_ROUTE4 depends on INET irda: Fix error propagation in ircomm_lmp_connect_response() irda: Kill set but unused variable 'bytes' in irlan_check_command_param() irda: Kill set but unused variable 'clen' in ircomm_connect_indication() rxrpc: Fix set but unused variable 'usage' in rxrpc_get_transport() be2net: Kill set but unused variable 'req' in lancer_fw_download() irda: Kill set but unused vars 'saddr' and 'daddr' in irlan_provider_connect_indication() atl1c: atl1c_resume() is only used when CONFIG_PM_SLEEP is defined. rxrpc: Fix set but unused variable 'usage' in rxrpc_get_peer(). rxrpc: Kill set but unused variable 'local' in rxrpc_UDP_error_handler() rxrpc: Kill set but unused variable 'sp' in rxrpc_process_connection() rxrpc: Kill set but unused variable 'sp' in rxrpc_rotate_tx_window() pkt_sched: Kill set but unused variable 'protocol' in tc_classify() isdn: capi: Use pr_debug() instead of ifdefs. tg3: Update version to 3.119 tg3: Apply rx_discards fix to 5719/5720 ... Fix up trivial conflicts in arch/x86/Kconfig and net/mac80211/agg-tx.c as per Davem.
2011-05-18drivercore: revert addition of of_match to struct deviceGrant Likely
Commit b826291c, "drivercore/dt: add a match table pointer to struct device" added an of_match pointer to struct device to cache the of_match_table entry discovered at driver match time. This was unsafe because matching is not an atomic operation with probing a driver. If two or more drivers are attempted to be matched to a driver at the same time, then the cached matching entry pointer could get overwritten. This patch reverts the of_match cache pointer and reworks all users to call of_match_device() directly instead. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-04-17atm: solos-pci: Fix set-but-unused variable.David S. Miller
This is just a readback to entire completion of a register write, keep the readback but kill the unused variable. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-17atm: idt77252: Fix set-but-unused variables.David S. Miller
Two cases here: 1) idt77252_rx_raw() really does not make any use of the extracted PTI field of the atm header. 2) idt77252_collect_stat() only uses the register values in code which has been compiled out by a "NOTDEF" cpp test for more than 10 years. Just kill this NOTDEF code entirely, but keep the register reads in case they have side effects. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-17atm: he: Fix undefined sequence points.David S. Miller
GCC complains in these queue index operations because we perform operations of the form: x = some_operation(++x); which is undefined. Replace with: x = some_operation(x + 1); which is well defined and provides the intended operation. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-17atm: eni: Kill set-but-unused variables.David S. Miller
The variable eni_dev is initialized but never subsequently used in these two functions. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-12atm: iphase: Fix set-but-not-used warnings.David S. Miller
The "iavcc" and "iadev" cases are obvious. The intr_status and frmr_intr cases are reading a register to clear the chip status. This driver is pretty old and creaky, and uses volatile pointer dereferences to do register I/O when it should be using readl() and friends. However that it outside of the scope of these changes. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-07Merge branch 'for-linus2' of git://git.profusion.mobi/users/lucas/linux-2.6Linus Torvalds
* 'for-linus2' of git://git.profusion.mobi/users/lucas/linux-2.6: Fix common misspellings
2011-03-30atm/solos-pci: Don't flap VCs when carrier state changesPhilip A. Prindeville
Don't flap VCs when carrier state changes; higher-level protocols can detect loss of connectivity and act accordingly. This is more consistent with how other network interfaces work. We no longer use release_vccs() so we can delete it. release_vccs() was duplicated from net/atm/common.c; make the corresponding function exported, since other code duplicates it and could leverage it if it were public. Signed-off-by: Philip A. Prindeville <philipp@redfish-solutions.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-30atm/solos-pci: Don't include frame pseudo-header on transmit hex-dumpPhilip A. Prindeville
Omit pkt_hdr preamble when dumping transmitted packet as hex-dump; we can pull this up because the frame has already been sent, and dumping it is the last thing we do with it before freeing it. Also include the size, vpi, and vci in the debug as is done on receive. Use "port" consistently instead of "device" intermittently. Signed-off-by: Philip Prindeville <philipp@redfish-solutions.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-30atm/solos-pci: Use VPI.VCI notation uniformly.Philip A. Prindeville
Use VPI.VCI notation consistently throughout the module. This is the one remaining place where the VCI is used before the VPI in any output. Signed-off-by: Philip Prindeville <philipp@redfish-solutions.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-18Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (47 commits) doc: CONFIG_UNEVICTABLE_LRU doesn't exist anymore Update cpuset info & webiste for cgroups dcdbas: force SMI to happen when expected arch/arm/Kconfig: remove one to many l's in the word. asm-generic/user.h: Fix spelling in comment drm: fix printk typo 'sracth' Remove one to many n's in a word Documentation/filesystems/romfs.txt: fixing link to genromfs drivers:scsi Change printk typo initate -> initiate serial, pch uart: Remove duplicate inclusion of linux/pci.h header fs/eventpoll.c: fix spelling mm: Fix out-of-date comments which refers non-existent functions drm: Fix printk typo 'failled' coh901318.c: Change initate to initiate. mbox-db5500.c Change initate to initiate. edac: correct i82975x error-info reported edac: correct i82975x mci initialisation edac: correct commented info fs: update comments to point correct document target: remove duplicate include of target/target_core_device.h from drivers/target/target_core_hba.c ... Trivial conflict in fs/eventpoll.c (spelling vs addition)
2011-02-28dt: Eliminate of_platform_{,un}register_driverGrant Likely
Final step to eliminate of_platform_bus_type. They're all just platform drivers now. v2: fix type in pasemi_nand.c (thanks to Stephen Rothwell) Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-02-15Merge branch 'master' into for-nextJiri Kosina
2011-02-13ATM, Solos PCI ADSL2+: Don't deref NULL pointer if net_ratelimit() and ↵Jesper Juhl
alloc_skb() interact badly. If alloc_skb() fails to allocate memory and returns NULL then we want to return -ENOMEM from drivers/atm/solos-pci.c::popen() regardless of the value of net_ratelimit(). The way the code is today, we may not return if net_ratelimit() returns 0, then we'll proceed to pass a NULL pointer to skb_put() which will blow up in our face. This patch ensures that we always return -ENOMEM on alloc_skb() failure and only let the dev_warn() be controlled by the value of net_ratelimit(). Signed-off-by: Jesper Juhl <jj@chaosbits.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-02fix typos 'comamnd' -> 'command' in commentsJustin P. Mattock
2011-01-24Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/torvalds/linux-2.6
2011-01-21atm: idt77105: fix fetch_stats() resultVasiliy Kulikov
copy_to_user() used PRIV(dev)->stats instead of local stats variable. Zero stats were returned to user in case of (zero != 0), also memcpy() was pointless. Signed-off-by: Vasiliy Kulikov <segoon@openwall.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-13Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits) Documentation/trace/events.txt: Remove obsolete sched_signal_send. writeback: fix global_dirty_limits comment runtime -> real-time ppc: fix comment typo singal -> signal drivers: fix comment typo diable -> disable. m68k: fix comment typo diable -> disable. wireless: comment typo fix diable -> disable. media: comment typo fix diable -> disable. remove doc for obsolete dynamic-printk kernel-parameter remove extraneous 'is' from Documentation/iostats.txt Fix spelling milisec -> ms in snd_ps3 module parameter description Fix spelling mistakes in comments Revert conflicting V4L changes i7core_edac: fix typos in comments mm/rmap.c: fix comment sound, ca0106: Fix assignment to 'channel'. hrtimer: fix a typo in comment init/Kconfig: fix typo anon_inodes: fix wrong function name in comment fix comment typos concerning "consistent" poll: fix a typo in comment ... Fix up trivial conflicts in: - drivers/net/wireless/iwlwifi/iwl-core.c (moved to iwl-legacy.c) - fs/ext4/ext4.h Also fix missed 'diabled' typo in drivers/net/bnx2x/bnx2x.h while at it.
2011-01-09Madge Ambassador ATM Adapter driver: Always release_firmware() in ↵Jesper Juhl
ucode_init() and don't leak memory. Failure to call release_firmware() will result in memory leak in drivers/atm/ambassador.c::ucode_init(). This patch makes sure we always call release_firmware() when needed, thus removing the leak(s). Yes, I know checkpatch complains about this patch, but it was either that or completely mess up the existing style, so I opted to use the existing style and live with the checkpatch related flak. Signed-off-by: Jesper Juhl <jj@chaosbits.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-04Merge branch 'master' of ↵David S. Miller
2010-12-31drivers/atm/atmtcp.c: add missing atm_dev_putJulia Lawall
The earlier call to atm_dev_lookup increases the reference count of dev, so decrease it on the way out. The semantic match that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ expression x, E; constant C; @@ x = atm_dev_lookup(...); ... when != false x != NULL when != true x == NULL when != \(E = x\|x = E\) when != atm_dev_put(dev); *return -C; // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-22Merge branch 'master' into for-nextJiri Kosina
Conflicts: MAINTAINERS arch/arm/mach-omap2/pm24xx.c drivers/scsi/bfa/bfa_fcpim.c Needed to update to apply fixes for which the old branch was too outdated.
2010-12-17Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/bnx2x/bnx2x.h drivers/net/wireless/iwlwifi/iwl-1000.c drivers/net/wireless/iwlwifi/iwl-6000.c drivers/net/wireless/iwlwifi/iwl-core.h drivers/vhost/vhost.c
2010-12-10atm: correct sysfs 'device' link creation and parent relationshipsDan Williams
The ATM subsystem was incorrectly creating the 'device' link for ATM nodes in sysfs. This led to incorrect device/parent relationships exposed by sysfs and udev. Instead of rolling the 'device' link by hand in the generic ATM code, pass each ATM driver's bus device down to the sysfs code and let sysfs do this stuff correctly. Signed-off-by: Dan Williams <dcbw@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-08atm: lanai: use kernel's '%pM' format option to print MACAndy Shevchenko
Signed-off-by: Andy Shevchenko <andy.shevchenko@gmail.com> Cc: Chas Williams <chas@cmf.nrl.navy.mil> Cc: linux-atm-general@lists.sourceforge.net Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-18atm: fore200e: Fix build warning.David S. Miller
GCC (rightfully) complains that: drivers/atm/fore200e.c:614:5: warning: operation on 'cmdq->head' may be undefined This is due to the FORE200E_NEXT_ENTRY macro, which essentially evaluates to: i = ++i % m Make it what's explicitly intended here which is: i = (i + 1) % m and the warning goes away. Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-08solos: Refuse to upgrade firmware with older FPGA. It doesn't work.David Woodhouse
Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-08solos: Add 'Firmware' attribute for Traverse overall firmware versionDavid Woodhouse
The existing 'FirmwareVersion' attribute only covers the DSP firmware as provided by Conexant; not the overall version of the device firmware. We do want to be able to see the full version number too. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-01tree-wide: fix comment/printk typosUwe Kleine-König
"gadget", "through", "command", "maintain", "maintain", "controller", "address", "between", "initiali[zs]e", "instead", "function", "select", "already", "equal", "access", "management", "hierarchy", "registration", "interest", "relative", "memory", "offset", "already", Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-10-26drivers/atm/eni.c: Remove multiple uses of KERN_<level>Joe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-24Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits) Update broken web addresses in arch directory. Update broken web addresses in the kernel. Revert "drivers/usb: Remove unnecessary return's from void functions" for musb gadget Revert "Fix typo: configuation => configuration" partially ida: document IDA_BITMAP_LONGS calculation ext2: fix a typo on comment in ext2/inode.c drivers/scsi: Remove unnecessary casts of private_data drivers/s390: Remove unnecessary casts of private_data net/sunrpc/rpc_pipe.c: Remove unnecessary casts of private_data drivers/infiniband: Remove unnecessary casts of private_data drivers/gpu/drm: Remove unnecessary casts of private_data kernel/pm_qos_params.c: Remove unnecessary casts of private_data fs/ecryptfs: Remove unnecessary casts of private_data fs/seq_file.c: Remove unnecessary casts of private_data arm: uengine.c: remove C99 comments arm: scoop.c: remove C99 comments Fix typo configue => configure in comments Fix typo: configuation => configuration Fix typo interrest[ing|ed] => interest[ing|ed] Fix various typos of valid in comments ... Fix up trivial conflicts in: drivers/char/ipmi/ipmi_si_intf.c drivers/usb/gadget/rndis.c net/irda/irnet/irnet_ppp.c
2010-10-21Drivers: atm: Makefile: replace the use of <module>-objs with <module>-yTracey Dent
Changed <module>-objs to <module>-y in Makefile. Signed-off-by: Tracey Dent <tdent48227@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-18Update broken web addresses in the kernel.Justin P. Mattock
The patch below updates broken web addresses in the kernel Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Cc: Maciej W. Rozycki <macro@linux-mips.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Finn Thain <fthain@telegraphics.com.au> Cc: Randy Dunlap <rdunlap@xenotime.net> Cc: Matt Turner <mattst88@gmail.com> Cc: Dimitry Torokhov <dmitry.torokhov@gmail.com> Cc: Mike Frysinger <vapier.adi@gmail.com> Acked-by: Ben Pfaff <blp@cs.stanford.edu> Acked-by: Hans J. Koch <hjk@linutronix.de> Reviewed-by: Finn Thain <fthain@telegraphics.com.au> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-10-11Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: net/core/ethtool.c
2010-10-11ATM: iphase, remove sleep-inside-atomicJiri Slaby
Stanse found that ia_init_one locks a spinlock and inside of that it calls ia_start which calls: * request_irq * tx_init which does kmalloc(GFP_KERNEL) Both of them can thus sleep and result in a deadlock. I don't see a reason to have a per-device spinlock there which is used only there and inited right before the lock location. So remove it completely. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Chas Williams <chas@cmf.nrl.navy.mil> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-11ATM: solos-pci, remove use after freeJiri Slaby
Stanse found we do in console_show: kfree_skb(skb); return skb->len; which is not good. Fix that by remembering the len and use it in the function instead. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Chas Williams <chas@cmf.nrl.navy.mil> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-03drivers/atm/idt77252.c: Remove unnecessary error checkJulia Lawall
This code does not call deinit_card(card); in an error case, as done in other error-handling code in the same function. But actually, the called function init_sram can only return 0, so there is no need for the error check at all. init_sram is also given a void return type, and its single return statement at the end of the function is dropped. A simplified version of the sematic match that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @r exists@ @r@ statement S1,S2,S3; constant C1,C2,C3; @@ *if (...) {... S1 return -C1;} ... *if (...) {... when != S1 return -C2;} ... *if (...) {... S1 return -C3;} // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-21drivers: atm: use native kernel's hex_to_bin() funcAndy Shevchenko
2010-09-06drivers/atm/firestream.c: Fix unsigned return typeJulia Lawall
The function has an unsigned return type, but returns a negative constant to indicate an error condition. The result of calling the function is always stored in a variable of type (signed) int, and thus unsigned can be dropped from the return type. A sematic match that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @exists@ identifier f; constant C; @@ unsigned f(...) { <+... * return -C; ...+> } // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-16drivers/atm: Adjust confusing if indentationJulia Lawall
Indent the branch of an if. The semantic match that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @r disable braces4@ position p1,p2; statement S1,S2; @@ ( if (...) { ... } | if (...) S1@p1 S2@p2 ) @script:python@ p1 << r.p1; p2 << r.p2; @@ if (p1[0].column == p2[0].column): cocci.print_main("branch",p1) cocci.print_secs("after",p2) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-12Merge branch 'next-devicetree' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
* 'next-devicetree' of git://git.secretlab.ca/git/linux-2.6: mmc_spi: Fix unterminated of_match_table of/sparc: fix build regression from of_device changes of/device: Replace struct of_device with struct platform_device
2010-08-09Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (59 commits) igbvf.txt: Add igbvf Documentation igb.txt: Add igb documentation e100/e1000*/igb*/ixgb*: Add missing read memory barrier ixgbe: fix build error with FCOE_CONFIG without DCB_CONFIG netxen: protect tx timeout recovery by rtnl lock isdn: gigaset: use after free isdn: gigaset: add missing unlock solos-pci: Fix race condition in tasklet RX handling pkt_sched: Fix sch_sfq vs tcf_bind_filter oops net: disable preemption before call smp_processor_id() tcp: no md5sig option size check bug iwlwifi: fix locking assertions iwlwifi: fix TX tracer isdn: fix information leak net: Fix napi_gro_frags vs netpoll path usbnet: remove noisy and hardly useful printk rtl8180: avoid potential NULL deref in rtl8180_beacon_work ath9k: Remove myself from the MAINTAINERS list libertas: scan before assocation if no BSSID was given libertas: fix association with some APs by using extended rates ...
2010-08-07solos-pci: Fix race condition in tasklet RX handlingDavid Woodhouse
We were seeing faults in the solos-pci receive tasklet when packets arrived for a VCC which was currently being closed: [18842.727906] EIP: [<e082f490>] br2684_push+0x19/0x234 [br2684] SS:ESP 0068:dfb89d14 [18845.090712] [<c13ecff3>] ? do_page_fault+0x0/0x2e1 [18845.120042] [<e082f490>] ? br2684_push+0x19/0x234 [br2684] [18845.153530] [<e084fa13>] solos_bh+0x28b/0x7c8 [solos_pci] [18845.186488] [<e084f711>] ? solos_irq+0x2d/0x51 [solos_pci] [18845.219960] [<c100387b>] ? handle_irq+0x3b/0x48 [18845.247732] [<c10265cb>] ? irq_exit+0x34/0x57 [18845.274437] [<c1025720>] tasklet_action+0x42/0x69 [18845.303247] [<c102643f>] __do_softirq+0x8e/0x129 [18845.331540] [<c10264ff>] do_softirq+0x25/0x2a [18845.358274] [<c102664c>] _local_bh_enable_ip+0x5e/0x6a [18845.389677] [<c102666d>] local_bh_enable+0xb/0xe [18845.417944] [<e08490a8>] ppp_unregister_channel+0x32/0xbb [ppp_generic] [18845.458193] [<e08731ad>] pppox_unbind_sock+0x18/0x1f [pppox] This patch uses an RCU-inspired approach to fix it. In the RX tasklet's find_vcc() function we first refuse to use a VCC which already has the ATM_VF_READY bit cleared. And in the VCC close function, we synchronise with the tasklet to ensure that it can't still be using the VCC before we continue and allow the VCC to be destroyed. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Tested-by: Nathan Williams <nathan@traverse.com.au> Cc: stable@kernel.org Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-06of/device: Replace struct of_device with struct platform_deviceGrant Likely
of_device is just an alias for platform_device, so remove it entirely. Also replace to_of_device() with to_platform_device() and update comment blocks. This patch was initially generated from the following semantic patch, and then edited by hand to pick up the bits that coccinelle didn't catch. @@ @@ -struct of_device +struct platform_device Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Reviewed-by: David S. Miller <davem@davemloft.net>
