pci_device_id are not supposed to change at runtime. All functions
working with pci_device_id provided by <linux/pci.h> work with
const pci_device_id. So mark the non-const structs as const.
File size before:
13372 408 4 13784 35d8 drivers/atm/ambassador.o
File size After adding 'const':
13484 296 4 13784 35d8 drivers/atm/ambassador.o
Signed-off-by: Arvind Yadav <arvind.yadav.cs@gmail.com>
File size before:
23536 432 160 24128 5e40 drivers/atm/iphase.o
23632 336 160 24128 5e40 drivers/atm/iphase.o
refcount_t type and corresponding API should be
used instead of atomic_t when the variable is used as
a reference counter. This allows to avoid accidental
refcounter overflows that might lead to use-after-free
situations.
Signed-off-by: Elena Reshetova <elena.reshetova@intel.com>
Signed-off-by: Hans Liljestrand <ishkamiel@gmail.com>
Signed-off-by: David Windsor <dwindsor@gmail.com>
It seems like a historic accident that these return unsigned char *,
and in many places that means casts are required, more often than not.
Make these functions return void * and remove all the casts across
the tree, adding a (u8 *) cast only where the unsigned char pointer
was used directly, all done with the following spatch:
expression SKB, LEN;
typedef u8;
identifier fn = { skb_push, __skb_push, skb_push_rcsum };
- *(fn(SKB, LEN))
+ *(u8 *)fn(SKB, LEN)
expression E, SKB, LEN;
type T;
- E = ((T *)(fn(SKB, LEN)))
+ E = fn(SKB, LEN)
- fn(SKB, LEN)[0]
Note that the last part there converts from push(...)[0] to the
more idiomatic *(u8 *)push(...).
Make these functions (skb_put, __skb_put and pskb_put) return void *
and remove all the casts across the tree, adding a (u8 *) cast only
where the unsigned char pointer was used directly, all done with the
following spatch:
typedef u8;
identifier fn = { skb_put, __skb_put };
- *(fn(SKB, LEN))
type T;
+ E = fn(SKB, LEN)
which actually doesn't cover pskb_put since there are only three
users overall.
A handful of stragglers were converted manually, notably a macro in
drivers/isdn/i4l/isdn_bsdcomp.c and, oddly enough, one of the many
instances in net/bluetooth/hci_sock.c. In the former file, I also
had to fix one whitespace problem spatch introduced.
A common pattern with skb_put() is to just want to memcpy()
some data into the new space, introduce skb_put_data() for
this.
An spatch similar to the one for skb_put_zero() converts many
of the places using it:
identifier p, p2;
expression len, skb, data;
type t, t2;
-p = skb_put(skb, len);
+p = skb_put_data(skb, data, len);
-p = (t)skb_put(skb, len);
p2 = (t2)p;
-memcpy(p2, data, len);
-memcpy(p, data, len);
type t, t2;
identifier p, p2;
expression skb, data;
t *p;
-p = skb_put(skb, sizeof(t));
+p = skb_put_data(skb, data, sizeof(t));
-p = (t *)skb_put(skb, sizeof(t));
p2 = (t2)p;
-memcpy(p2, data, sizeof(*p));
-memcpy(p, data, sizeof(*p));
expression skb, len, data;
-memcpy(skb_put(skb, len), data, len);
+skb_put_data(skb, data, len);
(again, manually post-processed to retain some comments)
Reviewed-by: Stephen Hemminger <stephen@networkplumber.org>
Value assigned to variable _data32_ at lines 1254 and 1257 is
overwritten at line 1260 before it can be used. This makes
such variable assignments useless.
Addresses-Coverity-ID: 1227049
Signed-off-by: Gustavo A. R. Silva <garsilva@embeddedor.com>
Use setup_timer() instead of init_timer() to simplify the code.
Signed-off-by: Geliang Tang <geliangtang@gmail.com>
<linux/sched.h> into <linux/sched/signal.h>
Fix up affected files that include this signal functionality via sched.h.
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
Pull IDR rewrite from Matthew Wilcox:
"The most significant part of the following is the patch to rewrite the
IDR & IDA to be clients of the radix tree. But there's much more,
including an enhancement of the IDA to be significantly more space
efficient, an IDR & IDA test suite, some improvements to the IDR API
(and driver changes to take advantage of those improvements), several
improvements to the radix tree test suite and RCU annotations.
The IDR & IDA rewrite had a good spin in linux-next and Andrew's tree
for most of the last cycle. Coupled with the IDR test suite, I feel
pretty confident that any remaining bugs are quite hard to hit. 0-day
did a great job of watching my git tree and pointing out problems; as
it hit them, I added new test-cases to be sure not to be caught the
same way twice"
Willy goes on to expand a bit on the IDR rewrite rationale:
"The radix tree and the IDR use very similar data structures.
Merging the two codebases lets us share the memory allocation pools,
and results in a net deletion of 500 lines of code. It also opens up
the possibility of exposing more of the features of the radix tree to
users of the IDR (and I have some interesting patches along those
lines waiting for 4.12)
It also shrinks the size of the 'struct idr' from 40 bytes to 24 which
will shrink a fair few data structures that embed an IDR"
* 'idr-4.11' of git://git.infradead.org/users/willy/linux-dax: (32 commits)
radix tree test suite: Add config option for map shift
idr: Add missing __rcu annotations
radix-tree: Fix __rcu annotations
radix-tree: Add rcu_dereference and rcu_assign_pointer calls
radix tree test suite: Run iteration tests for longer
radix tree test suite: Fix split/join memory leaks
radix tree test suite: Fix leaks in regression2.c
radix tree test suite: Fix leaky tests
radix tree test suite: Enable address sanitizer
radix_tree_iter_resume: Fix out of bounds error
radix-tree: Store a pointer to the root in each node
radix-tree: Chain preallocated nodes through ->parent
radix tree test suite: Dial down verbosity with -v
radix tree test suite: Introduce kmalloc_verbose
idr: Return the deleted entry from idr_remove
radix tree test suite: Build separate binaries for some tests
ida: Use exceptional entries for small IDAs
ida: Move ida_bitmap to a percpu variable
Reimplement IDR and IDA using the radix tree
radix-tree: Add radix_tree_iter_delete
Now that %z is standartised in C99 there is no reason to support %Z.
Unlike %L it doesn't even make format strings smaller.
Use BUILD_BUG_ON in a couple ATM drivers.
In case anyone didn't notice lib/vsprintf.o is about half of SLUB which
is in my opinion is quite an achievement. Hopefully this patch inspires
someone else to trim vsprintf.c more.
Link: http://lkml.kernel.org/r/20170103230126.GA30170@avx2
Cc: Andy Shevchenko <andy.shevchenko@gmail.com>
Cc: Rasmus Villemoes <linux@rasmusvillemoes.dk>
Fix typos and add the following to the scripts/spelling.txt:
followings||following
While we are here, add a missing colon in the boilerplate in DT binding
documents. The "you SoC" in allwinner,sunxi-pinctrl.txt was fixed as
well.
I reworded "as the followings:" to "as follows:" for
drivers/usb/gadget/udc/renesas_usb3.c.
Link: http://lkml.kernel.org/r/1481573103-11329-32-git-send-email-yamada.masahiro@socionext.com
Stop accessing timer struct members directly and use setup_timer and
mod_timer helpers intended for that use. It makes the code cleaner and
will allow for easier change of the timer struct internals.
Signed-off-by: Jan Koniarik <jan.koniarik@trustica.cz>
Cc: Chas Williams <3chas3@gmail.com>
Cc: <linux-atm-general@lists.sourceforge.net>
Cc: <netdev@vger.kernel.org>
It is a relatively common idiom (8 instances) to first look up an IDR
entry, and then remove it from the tree if it is found, possibly doing
further operations upon the entry afterwards. If we change idr_remove()
to return the removed object, all of these users can save themselves a
walk of the IDR tree.
Signed-off-by: Matthew Wilcox <mawilcox@microsoft.com>
Rename DAUGTHER_ID to DAUGHTER_ID to fix spelling mistake
This was entirely automated, using the script by Al:
PATT='^[[:blank:]]*#[[:blank:]]*include[[:blank:]]*<asm/uaccess.h>'
sed -i -e "s!$PATT!#include <linux/uaccess.h>!" \
$(git grep -l "$PATT"|grep -v ^include/linux/uaccess.h)
to do the replacement at the end of the merge window.
Requested-by: Al Viro <viro@zeniv.linux.org.uk>
It returns variable "error" when ioremap_nocache() returns a NULL
pointer. The value of "error" is 0 then, which will mislead the callers
to believe that there is no error. This patch fixes the bug, returning
"-ENOMEM".
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=189021
Signed-off-by: Pan Bian <bianpan2016@163.com>
In function lanai_dev_open(), when the call to ioremap() fails, the
value of return variable result is 0. 0 means no error in this context.
This patch fixes the bug, assigning "-ENOMEM" to result when ioremap()
returns a NULL pointer.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=188791
Use DEVICE_ATTR_RW for read-write attributes. This simplifies the
source code, improves readbility, and reduces the chance of
inconsistencies.
The semantic patch that makes this change is as follows:
(http://coccinelle.lip6.fr/)
// <smpl>
@rw@
declarer name DEVICE_ATTR;
identifier x,x_show,x_store;
DEVICE_ATTR(x, \(0644\|S_IRUGO|S_IWUSR\), x_show, x_store);
@script:ocaml@
x << rw.x;
x_show << rw.x_show;
x_store << rw.x_store;
if not (x^"_show" = x_show && x^"_store" = x_store)
then Coccilib.include_match false
declarer name DEVICE_ATTR_RW;
identifier rw.x,rw.x_show,rw.x_store;
- DEVICE_ATTR(x, \(0644\|S_IRUGO|S_IWUSR\), x_show, x_store);
+ DEVICE_ATTR_RW(x);
// </smpl>
Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr>
The newline escape is incorrect and needs fixing. Also adjust source
formatting / indentation and add { } to trailing else.
Adjust the indentation for a call of the macro "DPRINTK" in this function.
Signed-off-by: Markus Elfring <elfring@users.sourceforge.net>
* The script "checkpatch.pl" can point information out like the following.
WARNING: Prefer kcalloc over kzalloc with multiply
Thus fix the affected source code place.
* Replace the specification of a data type by a pointer dereference
to make the corresponding size determination a bit safer according to
the Linux coding style convention.
* Delete the local variable "size" which became unnecessary with
this refactoring.
Replace the specification of a data structure by a pointer dereference
as the parameter for the operator "sizeof" to make the corresponding size
determination a bit safer according to the Linux coding style convention.
* A multiplication for the size determination of a memory allocation
indicated that an array data structure should be processed.
Thus use the corresponding function "kmalloc_array".
This issue was detected by using the Coccinelle software.
The script "checkpatch.pl" can point out that assignments should usually
not be performed within condition checks.
Thus move an assignment for a local variable to a separate statement
in this function.
* The script "checkpatch.pl" can point out that assignments should usually
in this function.
* Replace the specification of a data structure by a pointer dereference
Replace the specification of a data structure by a reference for a field
in a local variable as the parameter for the operator "sizeof" to make
* Multiplications for the size determination of memory allocations
indicated that array data structures should be processed.
* Replace the specification of data types by pointer dereferences
The data member of structure firmware is const and this constness is
dropped by some cast.
This patch add some const for keeping the const information.
Signed-off-by: LABBE Corentin <clabbe.montjoie@gmail.com>
In 'get_scq', 'dma_alloc_coherent' has been used to allocate some
resources, so we need to free them using 'dma_free_coherent' instead
of 'kfree'.
Signed-off-by: Christophe JAILLET <christophe.jaillet@wanadoo.fr>
Convert a call to init_timer and accompanying intializations of
the timer's data and function fields to a call to setup_timer.
The Coccinelle semantic patch that fixes this problem is
as follows:
expression t,d,f,e1;
identifier x1;
statement S1;
-t.data = d;
-t.function = f;
-init_timer(&t);
+setup_timer(&t,f,d);
-init_timer_on_stack(&t);
+setup_timer_on_stack(&t,f,d);
<... when != S1
t.x1 = e1;
Signed-off-by: Amitoj Kaur Chawla <amitoj1606@gmail.com>
The iadev->rx_open[] array holds "iadev->num_vc" pointers (this code
assumes that pointers are 32 bits). So the > here should be >= or else
we could end up reading a garbage pointer from one element beyond the
end of the array.
This bug was there when the driver was first added in back in year 2000.
It causes a Smatch warning:
drivers/atm/firestream.c:849 process_incoming()
error: buffer overflow 'res_strings' 60 <= 63
There are supposed to be 64 entries in this array and the missing
strings are clearly in the 30 40 range. I added them as reserved 37 to
reserved 40. It's possible that strings are really supposed to be added
in the middle instead of at the end, but this approach is safe, in that
it fixes the bug and doesn't break anything that wasn't already broken.
Pull trivial tree updates from Jiri Kosina.
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial:
drivers/rtc: broken link fix
drm/i915 Fix typos in i915_gem_fence.c
Docs: fix missing word in REPORTING-BUGS
lib+mm: fix few spelling mistakes
MAINTAINERS: add git URL for APM driver
treewide: Fix typo in printk
This patch fix spelling typos found in printk and Kconfig.
Signed-off-by: Masanari Iida <standby24x7@gmail.com>
Acked-by: Randy Dunlap <rdunlap@infradead.org>
Use to_pci_dev() instead of open-coding it.
Signed-off-by: Geliang Tang <geliangtang@163.com>
The simple_strtol function is obsolete.
This patch replace it by kstrtoint.
This will simplify code, since some error case not handled by
simple_strtol are handled by kstrtoint.
Fix a smatch warning:
drivers/atm/iphase.c:1178 rx_pkt() warn: curly braces intended?
The code is correct, the indention is misleading. In case the allocation
of skb fails, we want to skip to the end.
Signed-off-by: Tillmann Heidsieck <theidsieck@leenox.de>
Smatch complains about returning hard coded error codes, silence this
warning.
drivers/atm/iphase.c:115 ia_enque_rtn_q() warn: returning -1 instead of -ENOMEM is sloppy
A comment in include/linux/skbuff.h says that:
* Various parts of the networking layer expect at least 32 bytes of
* headroom, you should not reduce this.
This was demonstrated by a panic when handling fragmented IPv6 packets:
http://marc.info/?l=linux-netdev&m=144236093519172&w=2
It's not entirely clear if that comment is still valid — and if it is,
perhaps netif_rx() ought to be enforcing it with a warning.
But either way, it is rather stupid from a performance point of view
for us to be receiving packets into a buffer which doesn't have enough
room to prepend an Ethernet header — it means that *every* incoming
packet is going to be need to be reallocated. So let's fix that.
Remove unneeded NULL test.
// <smpl>
@@ expression x; @@
-if (x != NULL)
\(kmem_cache_destroy\|mempool_destroy\|dma_pool_destroy\)(x);
// </smpl>
Use the timer API function setup_timer instead of structure field
assignments to initialize a timer.
A simplified version of the Coccinelle semantic patch that performs
this transformation is as follows:
@change@
expression e1, e2, a;
-init_timer(&e1);
+setup_timer(&e1, a, 0UL);
... when != a = e2
-e1.function = a;
Signed-off-by: Vaishali Thakkar <vthakkar1994@gmail.com>
API compliance scanning with coccinelle flagged:
./drivers/atm/iphase.c:2621:4-20:
WARNING: timeout (50) seems HZ dependent
Numeric constants passed to schedule_timeout() make the effective
timeout HZ dependent which does not seem intended.
Fixed up by converting the constant to jiffies with msecs_to_jiffies()
As this driver was introduced in the early 2.3 series it is most
likely assuming HZ=100 so the constant 50 is converted to 500ms.
Signed-off-by: Nicholas Mc Guire <hofrat@osadl.org>
According to <stdbool.h> false is always '0' and
Static variables are initialised to 0 by GCC.
Signed-off-by: Shailendra Verma <shailendra.capricorn@gmail.com>
The variable irq_coalesce is bool type.
So assign the value true instead of 1.
