path: root/drivers/atm
2009-09-30net: Make setsockopt() optlen be unsigned.David S. Miller
This provides safety against negative optlen at the type level instead of depending upon (sometimes non-trivial) checks against this sprinkled all over the the place, in each and every implementation. Based upon work done by Arjan van de Ven and feedback from Linus Torvalds. Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-28atm: dereference of he_dev->rbps_virt in he_init_group()Juha Leppanen
The prefix decrement causes a very long loop if pci_pool_alloc() failed in the first iteration. Also I swapped rbps and rbpl arguments. Reported-by: Juha Leppanen <juha_motorsportcom@luukku.com> Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-22Merge branch 'master' of git://git.infradead.org/users/dwmw2/solos-2.6David S. Miller
2009-09-22atm: dereference of he_dev->rbps_virt in he_init_group()roel kluin
he_dev->rbps_virt or he_dev->rbpl_virt allocation may fail, s them. Make sure that he_init_group() cleans up after errors. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-02drivers/atm: Use DIV_ROUND_CLOSESTJulia Lawall
The kernel.h macro DIV_ROUND_CLOSEST performs the computation (x + d/2)/d but is perhaps more readable. The semantic patch that makes this change is as follows: (http://www.emn.fr/x-info/coccinelle/) // <smpl> @haskernel@ @@ #include <linux/kernel.h> @depends on haskernel@ expression x,__divisor; @@ - (((x) + ((__divisor) / 2)) / (__divisor)) + DIV_ROUND_CLOSEST(x,__divisor) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-27drivers/atm: Correct redundant testJulia Lawall
str has already been tested. It seems that this test should be on the recently returned value snr. A simplified version of the semantic match that finds this problem is as follows: (http://www.emn.fr/x-info/coccinelle/) // <smpl> @r exists@ local idexpression x; expression E; @@ if (x == NULL || ...) { ... when forall return ...; } ... when != \(x=E\|x--\|x++\|--x\|++x\|x-=E\|x+=E\|x|=E\|x&=E\|&x\) ( *x == NULL | *x != NULL ) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-05-07solos: Show Interleaving details for ADSL2 and 2+Simon Farnsworth
InterleaveRDn and InterleaveRUp only apply to G.dmt. The equivalents for ADSL2 and 2+ are BisRDn and BisRUp. In addition, the INPdown and INPup statuses are useful when trying to track down instability on a line. Signed-off-by: Simon Farnsworth <simon@farnz.org.uk> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-04-30solos: Add some margin-related parametersDavid Woodhouse
2009-04-13Replace all DMA_nBIT_MASK macro with DMA_BIT_MASK(n)Yang Hongyang
This is the second go through of the old DMA_nBIT_MASK macro,and there're not so many of them left,so I put them into one patch.I hope this is the last round. After this the definition of the old DMA_nBIT_MASK macro could be removed. Signed-off-by: Yang Hongyang <yanghy@cn.fujitsu.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Tony Lindgren <tony@atomide.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: Greg KH <greg@kroah.com> Cc: Takashi Iwai <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07dma-mapping: replace all DMA_32BIT_MASK macro with DMA_BIT_MASK(32)Yang Hongyang
Replace all DMA_32BIT_MASK macro with DMA_BIT_MASK(32) Signed-off-by: Yang Hongyang<yanghy@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-25solos: Check for rogue received packetsNathan Williams
Sometimes there can be received packets with the size field set to 0xFFFF. This seems to only occur after an FPGA or firmware upgrade. This patch discards packets with an invalid size. Signed-off-by: Nathan Williams <nathan@traverse.com.au> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-03-25solos: support new FPGA RAM layoutNathan Williams
Buffer sizes have been changed to 2048 bytes. Flash upgrades use a dedicated RAM block. Add support for daughterboard. Signed-off-by: Nathan Williams <nathan@traverse.com.au> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-03-21atm: fix non-const printk argumentStephen Hemminger
Change printk() argument to fix compiler warning. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-21Merge branch 'master' of git://git.infradead.org/~dwmw2/solos-2.6David S. Miller
2009-03-17solos: Disable DMA until we have an FPGA update with it actually implemented.David Woodhouse
2009-03-17solos: Automatically determine number of portsNathan Williams
2009-03-17solos: Reset device on unload, free pending skbsDavid Woodhouse
2009-02-24Merge branch 'master' of /home/davem/src/GIT/linux-2.6/David S. Miller
2009-02-18atm: Add missing parenthesesRoel Kluin
2009-02-18ATM: misplaced parentheses?Roel Kluin
Add missing parentheses Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-10fore200: fix oops on failed firmware loadMeelis Roos
Fore 200 ATM driver fails to handle request_firmware failures and oopses when no firmware file was found. Fix it by checking for the right return values and propaganting the return value up. Signed-off-by: Meelis Roos <mroos@linux.ee> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-08drivers/atm: introduce missing kfreeJulia Lawall
Error handling code following a kmalloc should free the allocated data. The semantic match that finds the problem is as follows: (http://www.emn.fr/x-info/coccinelle/) // <smpl> @r exists@ local idexpression x; statement S; expression E; identifier f,l; position p1,p2; expression *ptr != NULL; @@ ( if ((x@p1 = \(kmalloc\|kzalloc\|kcalloc\)(...)) == NULL) S | x@p1 = \(kmalloc\|kzalloc\|kcalloc\)(...); ... if (x == NULL) S ) <... when != x when != if (...) { <+...x...+> } x->f = E ...> ( return \(0\|<+...x...+>\|ptr\); | return@p2 ...; ) @script:python@ p1 << r.p1; p2 << r.p2; @@ print "* file: %s kmalloc %s return %s" % (p1[0].file,p1[0].line,p2[0].line) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-30solos: Swap upstream/downstream rates in status packet, clean up some moreDavid Woodhouse
2009-01-30solos: Set RX empty flag at startup only for !dma modeDavid Woodhouse
2009-01-30solos: Don't clear config registers at startupDavid Woodhouse
2009-01-30solos: Tidy up status interrupt handling, cope with 'ERROR' statusDavid Woodhouse
2009-01-30solos: Add 'reset' module parameter to reset the DSL chips on loadDavid Woodhouse
2009-01-29solos: Remove debugging, commented-out test codeDavid Woodhouse
2009-01-29solos: Clean up handling of card->tx_mask a littleDavid Woodhouse
2009-01-29solos: Fix various bugs in status packet handlingDavid Woodhouse
2009-01-29solos: Remove superfluous wait_queue_head_t from struct solos_paramDavid Woodhouse
2009-01-29solos: Remove IRQF_DISABLED, don't frob IRQ enable on the FPGA in solos_irq()David Woodhouse
Neither of these are necessary. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-01-29solos: Remove unused loopback debug stuffDavid Woodhouse
2009-01-29solos: Tidy up tx_mask handling for ports which need TXDavid Woodhouse
2009-01-29solos: Tidy up DMA handling a little. Still untestedDavid Woodhouse
2009-01-28solos: First attempt at DMA supportDavid Woodhouse
2009-01-28solos: Remove parameter group from sysfs on ATM dev deregisterDavid Woodhouse
2009-01-28solos: Fix under-allocation of skb size for get/set parametersDavid Woodhouse
2009-01-28solos: Add SNR and Attn to status packet, fix oops on loadDavid Woodhouse
2009-01-27solos: Reject non-AAL5 connections.... for nowDavid Woodhouse
2009-01-27solos: Kill existing connections on link down eventDavid Woodhouse
2009-01-27solos: Handle new line status change packets, hook up to ATM layer infoDavid Woodhouse
2009-01-27solos: Add initial list of parametersDavid Woodhouse
I don't much like the trick with multiple inclusions of solos-attrlist.c but don't really see a saner way to do it without repeating the list. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-01-27solos: Handle attribute show/store in kernel more sanelyDavid Woodhouse
There are still a _lot_ of attributes, but for at least the basic ones we want to be able to get/set them from the kernel. Especially the ones we want to inform the ATM core about (link state, speed). Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-01-27solos: Kill global 'opens' count.David Woodhouse
2009-01-27solos: Clean up firmware loading codeDavid Woodhouse
We no longer try to load firmware while the ATM is up and running. However, this means that we _do_ make init_module() wait for it, and it takes a long time for now (since we're using ultra-conservative code in the FPGA for that too). The inner loop which uses swahb32p() was by Simon Farnsworth. Simon has patches which migrate us to request_firmware_nowait(), for which we'll actually need to take down the ATM devices, do the upgrade, then reregister them. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-01-27solos: FPGA and firmware update support.Simon Farnsworth
This is just a straight pull in of changes, syncing us up to 0.07 from openadsl.sf.net Signed-off-by: Nathan Williams <nathan@traverse.com.au> Signed-off-by: Simon Farnsworth <simon@farnz.org.uk> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-01-27solos: Slight debugging improvementsSimon Farnsworth
Print a message if pskb_expand_head fails. Make atmdebug writable by root, so that you can turn printing of data sent to and received from the card on and off at runtime - useful for tracking corruption. Signed-off-by: Simon Farnsworth <simon@farnz.org.uk> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-01-27solos: Fix length header in FPGA transfersDavid Woodhouse
The length field shouldn't ever include the size of the header itself. This fixes the problem that some people were seeing with 1500-byte packets. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-01-08generic swap(): iphase: rename swap() to swap_byte_order()Wu Fengguang
In preparation for the introduction of a generic swap() macro. Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
