This is the first step in defining a dma buffer sharing mechanism.
A new buffer object dma_buf is added, with operations and API to allow easy
sharing of this buffer object across devices.
The framework allows:
- creation of a buffer object, its association with a file pointer, and
associated allocator-defined operations on that buffer. This operation is
called the 'export' operation.
- different devices to 'attach' themselves to this exported buffer object, to
facilitate backing storage negotiation, using dma_buf_attach() API.
- the exported buffer object to be shared with the other entity by asking for
its 'file-descriptor (fd)', and sharing the fd across.
- a received fd to get the buffer object back, where it can be accessed using
the associated exporter-defined operations.
- the exporter and user to share the scatterlist associated with this buffer
object using map_dma_buf and unmap_dma_buf operations.
Atleast one 'attach()' call is required to be made prior to calling the
map_dma_buf() operation.
Couple of building blocks in map_dma_buf() are added to ease introduction
of sync'ing across exporter and users, and late allocation by the exporter.
For this first version, this framework will work with certain conditions:
- *ONLY* exporter will be allowed to mmap to userspace (outside of this
framework - mmap is not a buffer object operation),
- currently, *ONLY* users that do not need CPU access to the buffer are
allowed.
More details are there in the documentation patch.
This is based on design suggestions from many people at the mini-summits[1],
most notably from Arnd Bergmann <arnd@arndb.de>, Rob Clark <rob@ti.com> and
Daniel Vetter <daniel@ffwll.ch>.
The implementation is inspired from proof-of-concept patch-set from
Tomasz Stanislawski <t.stanislaws@samsung.com>, who demonstrated buffer sharing
between two v4l2 devices. [2]
[1]: https://wiki.linaro.org/OfficeofCTO/MemoryManagement
[2]: http://lwn.net/Articles/454389
Change-Id: I8ebd858ad86242ee7b02d5f42bb25c3edbd64fca
Signed-off-by: Sumit Semwal <sumit.semwal@linaro.org>
Signed-off-by: Sumit Semwal <sumit.semwal@ti.com>
Reviewed-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Reviewed-by: Dave Airlie <airlied@redhat.com>
Reviewed-and-Tested-by: Rob Clark <rob.clark@linaro.org>
Signed-off-by: Hiroshi DOYU <hdoyu@nvidia.com>
[Hiroshi DOYU: Backported from v3.3-rc1]
Reviewed-on: http://git-master/r/78384
Reviewed-by: Varun Wadekar <vwadekar@nvidia.com>
Reviewed-by: Ken Adams <kadams@nvidia.com>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6
* 'driver-core-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6:
updated Documentation/ja_JP/SubmittingPatches
debugfs: add documentation for debugfs_create_x64
uio: uio_pdrv_genirq: Add OF support
firmware: gsmi: remove sysfs entries when unload the module
Documentation/zh_CN: Fix messy code file email-clients.txt
driver core: add more help description for "path to uevent helper"
driver-core: modify FIRMWARE_IN_KERNEL help message
driver-core: Kconfig grammar corrections in firmware configuration
DOCUMENTATION: Replace create_device() with device_create().
DOCUMENTATION: Update overview.txt in Doc/driver-model.
pti: pti_tty_install documentation mispelling.
There are many places in the tree where we implement register access for
devices on non-memory mapped buses, especially I2C and SPI. Since hardware
designers seem to have settled on a relatively consistent set of register
interfaces this can be effectively factored out into shared code. There
are a standard set of formats for marshalling data for exchange with the
device, with the actual I/O mechanisms generally being simple byte
streams.
We create an abstraction for marshaling data into formats which can be
sent on the control interfaces, and create a standard method for
plugging in actual transport underneath that.
This is mostly a refactoring and renaming of the bottom level of the
existing code for sharing register I/O which we have in ASoC. A
subsequent patch in this series converts ASoC to use this. The main
difference in interface is that reads return values by writing to a
location provided by a pointer rather than in the return value, ensuring
we can use the full range of the type for register data. We also use
unsigned types rather than ints for the same reason.
As some of the devices can have very large register maps the existing
ASoC code also contains infrastructure for managing register caches.
This cache work will be moved over in a future stage to allow for
separate review, the current patch only deals with the physical I/O.
Acked-by: Liam Girdwood <lrg@ti.com>
The kernel configuration UEVENT_HELPER_PATH is a string to
the uevent helper program. Add more description about how
to disable this feature and how to enable it again during
runtime.
Signed-off-by: Márton Németh <nm127@freemail.hu>
The help message for the configuration variable was inconsistent
with the way "make firmware_install" really works.
Signed-off-by: matt mooney <mfm@muteddisk.com>
Fix some grammatical errors and reword a few sentences.
Since suspend, resume and shutdown operations in struct sysdev_class
and struct sysdev_driver are not used any more, remove them. Also
drop sysdev_suspend(), sysdev_resume() and sysdev_shutdown() used
for executing those operations and modify all of their users
accordingly. This reduces kernel code size quite a bit and reduces
its complexity.
Introduce Kconfig option allowing architectures where sysdev
operations used during system suspend, resume and shutdown have been
completely replaced with struct sycore_ops operations to avoid
building sysdev code that will never be used.
Make callbacks in struct sys_device and struct sysdev_driver depend
on ARCH_NO_SYSDEV_OPS to allows us to verify if all of the references
have been actually removed from the code the given architecture
depends on.
Make x86 select ARCH_NO_SYSDEV_OPS.
The meaning of CONFIG_EMBEDDED has long since been obsoleted; the option
is used to configure any non-standard kernel with a much larger scope than
only small devices.
This patch renames the option to CONFIG_EXPERT in init/Kconfig and fixes
references to the option throughout the kernel. A new CONFIG_EMBEDDED
option is added that automatically selects CONFIG_EXPERT when enabled and
can be used in the future to isolate options that should only be
considered for embedded systems (RISC architectures, SLOB, etc).
Calling the option "EXPERT" more accurately represents its intention: only
expert users who understand the impact of the configuration changes they
are making should enable it.
Reviewed-by: Ingo Molnar <mingo@elte.hu>
Acked-by: David Woodhouse <david.woodhouse@intel.com>
Signed-off-by: David Rientjes <rientjes@google.com>
Cc: Greg KH <gregkh@suse.de>
Cc: Robin Holt <holt@sgi.com>
Cc: <linux-arch@vger.kernel.org>
Fix kconfig dependency warning for FW_LOADER.
Lots of drivers select FW_LOADER without bothering to depend on
HOTPLUG and/or without selecting HOTPLUG. A kernel builds fine
when FW_LOADER is enabled, whether HOTPLUG is enabled or not, and
a kernel config file (make oldconfig) is not changed by this patch.
(Yes, drivers/base/firmware_class.c uses interfaces from linux/kobject.h,
which does have some CONFIG_HOTPLUG dependencies, but this patch does
not change that.)
warning: (MICROCODE || MICROCODE_INTEL && MICROCODE || MICROCODE_AMD && MICROCODE || PCMCIA_LOAD_CIS && PCCARD && PCMCIA && EXPERIMENTAL || USB_IRDA && NET && IRDA && USB || BT_HCIBCM203X && NET && BT && USB || BT_HCIBFUSB && NET && BT && USB || BT_HCIBT3C && NET && BT && PCMCIA || BT_MRVL_SDIO && NET
!STAGING_EXCLUDE_BUILD && USB && (X86 || ARM) && WLAN || DRM_NOUVEAU && STAGING && !STAGING_EXCLUDE_BUILD && DRM && PCI || TI_ST && STAGING && !STAGING_EXCLUDE_BUILD && RFKILL || DELL_RBU && X86) selects FW_LOADER which has unmet direct dependencies (HOTPLUG)
(5200 byte line reduced a lot)
Make devtmpfs available on (embedded) configurations without SHMEM/TMPFS,
using ramfs instead.
Saves ~15KB.
Signed-off-by: Peter Korsgaard <jacmet@sunsite.dk>
Acked-by: Kay Sievers <kay.sievers@vrfy.org>
No recent mainstream system uses the /sbin/hotplug fork-bomb any more.
Disable it by default to reflect how it is used these days.
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
All major distros enable devtmpfs on recent systems, so remove
the EXPERIMENTAL flag, and make the description a bit more instructive.
Devtmpfs lets the kernel create a tmpfs instance called devtmpfs
very early at kernel initialization, before any driver-core device
is registered. Every device with a major/minor will provide a
device node in devtmpfs.
Devtmpfs can be changed and altered by userspace at any time,
and in any way needed - just like today's udev-mounted tmpfs.
Unmodified udev versions will run just fine on top of it, and will
recognize an already existing kernel-created device node and use it.
The default node permissions are root:root 0600. Proper permissions
and user/group ownership, meaningful symlinks, all other policy still
needs to be applied by userspace.
If a node is created by devtmps, devtmpfs will remove the device node
when the device goes away. If the device node was created by
userspace, or the devtmpfs created node was replaced by userspace, it
will no longer be removed by devtmpfs.
If it is requested to auto-mount it, it makes init=/bin/sh work
without any further userspace support. /dev will be fully populated
and dynamic, and always reflect the current device state of the kernel.
With the commonly used dynamic device numbers, it solves the problem
where static devices nodes may point to the wrong devices.
It is intended to make the initial bootup logic simpler and more robust,
by de-coupling the creation of the inital environment, to reliably run
userspace processes, from a complex userspace bootstrap logic to provide
a working /dev.
Signed-off-by: Jan Blunck <jblunck@suse.de>
Tested-By: Harald Hoyer <harald@redhat.com>
Tested-By: Scott James Remnant <scott@ubuntu.com>
Fix misspelled firmware in Kconfig
It's spelled "firmware".
Signed-off-by: Nick Andrew <nick@nick-andrew.net>
Signed-off-by: Alberto Bertogli <albertito@blitiri.com.ar>
James Bottomley recently discovered that we have
{request,release}_firmware() dummies for the case of the actual
functions not being available and has a fix for the bug that was
actually causing build errors for built-in users with
CONFIG_FW_LOADER=m.
But now missing selects on FW_LOADER are no longer visible at
compile-time at all and can become runtime problems.
FW_LOADER is infrastructure with relatively small codesize we can safely
enable for everyone, and only for people who really need small kernels
(and can be expected to know what they are doing) it matters being able
to disable it.
This patch therefore always sets FW_LOADER=y and allows users only to
disable it with EMBEDDED=y.
As a bonus, we can then get rid of all "select FW_LOADER" plus the due
to it required "depends on HOTPLUG" which removes some complexity from
our Kconfig files.
Signed-off-by: Adrian Bunk <bunk@kernel.org>
This will control whether we build firmware into the kernel image for
_every_ driver which we convert to request_firmware(), to avoid a
proliferation of 'CONFIG_XXX_FIRMWARE' options for each one.
Default to 'y' for now, which is the wrong thing to do but people seem
to be insisting on it and refusing to even review patches until it's
done. And it does preserve the existing behaviour for built-in drivers.
This allows arbitrary firmware files to be included in the static kernel
where the firmware loader can find them without requiring userspace to
be alive.
(Updated and CONFIG_EXTRA_FIRMWARE_DIR added with lots of help from
Johannes Berg).
Signed-off-by: Johannes Berg <johannes@sipsolutions.net>
The kernel creates a process for every event that is send, even when
there is no binary it could execute. We are needlessly creating around
200-300 failing processes during early bootup, until we have the chance
to disable it from userspace.
This change allows us to disable /sbin/hotplug entirely, if you want to,
by setting UEVENT_HELPER_PATH="" in the kernel config.
Implement device resource management, in short, devres. A device
driver can allocate arbirary size of devres data which is associated
with a release function. On driver detach, release function is
invoked on the devres data, then, devres data is freed.
devreses are typed by associated release functions. Some devreses are
better represented by single instance of the type while others need
multiple instances sharing the same release function. Both usages are
supported.
devreses can be grouped using devres group such that a device driver
can easily release acquired resources halfway through initialization
or selectively release resources (e.g. resources for port 1 out of 4
ports).
This patch adds devres core including documentation and the following
managed interfaces.
* alloc/free : devm_kzalloc(), devm_kzfree()
* IO region : devm_request_region(), devm_release_region()
* IRQ : devm_request_irq(), devm_free_irq()
* DMA : dmam_alloc_coherent(), dmam_free_coherent(),
dmam_declare_coherent_memory(), dmam_pool_create(),
dmam_pool_destroy()
* PCI : pcim_enable_device(), pcim_pin_device(), pci_is_managed()
* iomap : devm_ioport_map(), devm_ioport_unmap(), devm_ioremap(),
devm_ioremap_nocache(), devm_iounmap(), pcim_iomap_table(),
pcim_iomap(), pcim_iounmap()
Signed-off-by: Tejun Heo <htejun@gmail.com>
Signed-off-by: Jeff Garzik <jeff@garzik.org>
Put SYS_HYPERVISOR inside the Generic Driver Config menu where it should
be. Otherwise xconfig displays it as a dangling (lost) menu item under
Device Drivers, all by itself (when all options are displayed).
Cc: <holzheu@de.ibm.com>
It's useful to be able to turn off CONFIG_HOTPLUG for compile-coverage testing
and for section-checking coverage. But a few things go and select
CONFIG_HOTPLUG, making it a royal PITA to turn the thing off.
It's only turnable offable if CONFIG_EMBEDDED anyway. So let's make those
things depend on HOTPLUG, not select it.
Cc: Greg KH <greg@kroah.com>
Cc: Dominik Brodowski <linux@dominikbrodowski.net>
To have a home for all hypervisors, this patch creates /sys/hypervisor.
A new config option SYS_HYPERVISOR is introduced, which should to be set
by architecture dependent hypervisors (e.g. s390 or Xen).
Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
Signed-off-by: Michael Holzheu <holzheu@de.ibm.com>
Leave the overloaded "hotplug" word to susbsystems which are handling
real devices. The driver core does not "plug" anything, it just exports
the state to userspace and generates events.
Signed-off-by: Kay Sievers <kay.sievers@suse.de>
infrastructure for it.
Let it rip!
