path: root/drivers/base/power/runtime.c
2006-01-06[PATCH] pcmcia: merge suspend into device modelDominik Brodowski
Merge the suspend and resume methods for 16-bit PCMCIA cards into the device model -- for both runtime power management and suspend to ram/disk. Bugfix in ds.c by Richard Purdie Signed-Off-By: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-01-04[PATCH] drivers/base/power/runtime.c: #if 0 dpm_set_power_state()Adrian Bunk
This patch #if 0's an unused global function. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-28[PATCH] root hub changes (lesser half)David Brownell
This patch collects various small updates related to root hubs, to shrink later patches which build on them. - For root hub suspend/resume support: * Make the existing usb_hcd_resume_root_hub() routine respect pmcore locking, exporting and using the dpm_runtime_resume() method. * Add a new usb_hcd_suspend_root_hub() to pair with that routine. (Essential to make OHCI autosuspend behave again...) * HC_SUSPENDED by itself only refers to the root hub's downstream ports. So let HCDs see root hub URBs unless the parent device is suspended. - Remove an assertion we no longer need (and now, also don't want). - Generic suspend/resume updates to work better with swsusp. * Ignore the FREEZE vs SUSPEND distinction for hardware; trying to use it breaks the swsusp snapshots it's supposed to help (sigh). * On resume, mark devices as resumed right away, but then do nothing else if the device is marked NOTATTACHED. These changes shouldn't be very noticable by themselves. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> drivers/base/power/runtime.c | 1 drivers/usb/core/hcd.c | 64 ++++++++++++++++++++++++++++++++++++++----- drivers/usb/core/hcd.h | 1 drivers/usb/core/hub.c | 45 ++++++++++++++++++++++++------ drivers/usb/core/usb.c | 20 +++++++++---- drivers/usb/core/usb.h | 1 6 files changed, 111 insertions(+), 21 deletions(-)
2005-09-05[PATCH] swsusp: switch pm_message_t to structPavel Machek
This adds type-checking to pm_message_t, so that people can't confuse it with int or u32. It also allows us to fix "disk yoyo" during suspend (disk spinning down/up/down). [We've tried that before; since that cpufreq problems were fixed and I've tried make allyes config and fixed resulting damage.] Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Alexander Nyberg <alexn@telia.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
