commit 328f494d95aac8bd4896aea2328bc281053bcb71 upstream.
When inserting a new register into a block at the lower end the present
bitmap is currently shifted into the wrong direction. The effect of this is
that the bitmap becomes corrupted and registers which are present might be
reported as not present and vice versa.
Fix this by shifting left rather than right.
Fixes: 472fdec7380c("regmap: rbtree: Reduce number of nodes, take 2")
Reported-by: Daniel Baluta <daniel.baluta@gmail.com>
Signed-off-by: Mark Brown <broonie@kernel.org>
commit 53974e06603977f348ed978d75c426b0532daa67 upstream.
The topology_##name() macro does not use its argument when CONFIG_SMP is not
set, as it ultimately calls the cpu_data() macro.
So we avoid maintaining a possibly unused `cpu' variable, to avoid the
following compilation warning:
drivers/base/topology.c: In function ‘show_physical_package_id’:
drivers/base/topology.c:103:118: warning: unused variable ‘cpu’ [-Wunused-variable]
define_id_show_func(physical_package_id);
drivers/base/topology.c: In function ‘show_core_id’:
drivers/base/topology.c:106:106: warning: unused variable ‘cpu’ [-Wunused-variable]
define_id_show_func(core_id);
This can be seen with e.g. x86 defconfig and CONFIG_SMP not set.
Signed-off-by: Vincent Stehlé <vincent.stehle@laposte.net>
commit bb34cb6bbd287b57e955bc5cfd42fcde6aaca279 upstream.
bus_find_device_by_name() acquires a device reference which is never
released. This results in an object leak, which on older kernels
results in failure to release all resources of PCI devices. libvirt
uses drivers_probe to re-attach devices to the host after assignment
and is therefore a common trigger for this leak.
Example:
# cd /sys/bus/pci/
# dmesg -C
# echo 1 > devices/0000\:01\:00.0/sriov_numvfs
# echo 0 > devices/0000\:01\:00.0/sriov_numvfs
# dmesg | grep 01:10
pci 0000:01:10.0: [8086:10ca] type 00 class 0x020000
kobject: '0000:01:10.0' (ffff8801d79cd0a8): kobject_add_internal: parent: '0000:00:01.0', set: 'devices'
kobject: '0000:01:10.0' (ffff8801d79cd0a8): kobject_uevent_env
kobject: '0000:01:10.0' (ffff8801d79cd0a8): fill_kobj_path: path = '/devices/pci0000:00/0000:00:01.0/0000:01:10.0'
kobject: '0000:01:10.0' (ffff8801d79cd0a8): kobject_cleanup, parent (null)
kobject: '0000:01:10.0' (ffff8801d79cd0a8): calling ktype release
kobject: '0000:01:10.0': free name
[kobject freed as expected]
# dmesg -C
# echo 0000:01:10.0 > drivers_probe
kobject: '0000:01:10.0' (ffff8801d79ce0a8): kobject_add_internal: parent: '0000:00:01.0', set: 'devices'
kobject: '0000:01:10.0' (ffff8801d79ce0a8): kobject_uevent_env
kobject: '0000:01:10.0' (ffff8801d79ce0a8): fill_kobj_path: path = '/devices/pci0000:00/0000:00:01.0/0000:01:10.0'
[no free]
Signed-off-by: Alex Williamson <alex.williamson@redhat.com>
commit e4a60d139060975eb956717e4f63ae348d4d8cc5 upstream.
There is a race condition when removing glue directory.
It can be reproduced in following test:
path 1: Add first child device
device_add()
get_device_parent()
/*find parent from glue_dirs.list*/
list_for_each_entry(k, &dev->class->p->glue_dirs.list, entry)
if (k->parent == parent_kobj) {
kobj = kobject_get(k);
break;
class_dir_create_and_add()
path2: Remove last child device under glue dir
device_del()
cleanup_device_parent()
cleanup_glue_dir()
kobject_put(glue_dir);
If path2 has been called cleanup_glue_dir(), but not
call kobject_put(glue_dir), the glue dir is still
in parent's kset list. Meanwhile, path1 find the glue
dir from the glue_dirs.list. Path2 may release glue dir
before path1 call kobject_get(). So kernel will report
the warning and bug_on.
This is a "classic" problem we have of a kref in a list
that can be found while the last instance could be removed
at the same time.
This patch reuse gdp_mutex to fix this race condition.
The following calltrace is captured in kernel 3.4, but
the latest kernel still has this bug.
<4>[ 3965.441471] WARNING: at ...include/linux/kref.h:41 kobject_get+0x33/0x40()
<4>[ 3965.441474] Hardware name: Romley
<4>[ 3965.441475] Modules linked in: isd_iop(O) isd_xda(O)...
<4>[ 3965.441605] Call Trace:
<4>[ 3965.441611] [<ffffffff8103717a>] warn_slowpath_common+0x7a/0xb0
<4>[ 3965.441615] [<ffffffff810371c5>] warn_slowpath_null+0x15/0x20
<4>[ 3965.441618] [<ffffffff81215963>] kobject_get+0x33/0x40
<4>[ 3965.441624] [<ffffffff812d1e45>] get_device_parent.isra.11+0x135/0x1f0
<4>[ 3965.441627] [<ffffffff812d22d4>] device_add+0xd4/0x6d0
<4>[ 3965.441631] [<ffffffff812d0dbc>] ? dev_set_name+0x3c/0x40
<2>[ 3965.441912] kernel BUG at ..../fs/sysfs/group.c:65!
<4>[ 3965.441915] invalid opcode: 0000 [#1] SMP
<4>[ 3965.686743] [<ffffffff811a677e>] sysfs_create_group+0xe/0x10
<4>[ 3965.686748] [<ffffffff810cfb04>] blk_trace_init_sysfs+0x14/0x20
<4>[ 3965.686753] [<ffffffff811fcabb>] blk_register_queue+0x3b/0x120
<4>[ 3965.686756] [<ffffffff812030bc>] add_disk+0x1cc/0x490
Signed-off-by: Yijing Wang <wangyijing@huawei.com>
Signed-off-by: Weng Meiling <wengmeiling.weng@huawei.com>
If val_count is zero we return -EINVAL with map->lock_arg locked, which
will deadlock the kernel next time we try to acquire this lock.
In 3.12, this was introduced by a0b8d8d906d267987d507138003048c5fdf774
("regmap: fix possible ZERO_SIZE_PTR pointer dereferencing error.")
which improperly back-ported d6b41cb06044a7d895db82bdd54f6e4219970510.
This issue was found during review of Ubuntu Trusty 3.13.0-40.68 kernel to
prepare Ksplice rebootless updates.
Fixes: f5942dd ("regmap: fix possible ZERO_SIZE_PTR pointer dereferencing error.")
Signed-off-by: Quentin Casasnovas <quentin.casasnovas@oracle.com>
commit 471b095dfe0d693a8d624cbc716d1ee4d74eb437 upstream.
An empty firmware request name will trigger warnings when building
device names. Make sure this is caught earlier and rejected.
The warning was visible via the test_firmware.ko module interface:
echo -ne "\x00" > /sys/devices/virtual/misc/test_firmware/trigger_request
Reported-by: Sasha Levin <sasha.levin@oracle.com>
Tested-by: Sasha Levin <sasha.levin@oracle.com>
commit d6b41cb06044a7d895db82bdd54f6e4219970510 upstream.
Since we cannot make sure the 'val_count' will always be none zero
here, and then if it equals to zero, the kmemdup() will return
ZERO_SIZE_PTR, which equals to ((void *)16).
So this patch fix this with just doing the zero check before calling
kmemdup().
Signed-off-by: Xiubo Li <Li.Xiubo@freescale.com>
commit 5336be8416a71b5568d2cf54a2f2066abe9f2a53 upstream.
If LOG_DEVICE is defined and map->dev is NULL it will lead to NULL
pointer dereference. This patch fixes this issue by adding check for
dev->NULL in all such places in regmap.c
Signed-off-by: Pankaj Dubey <pankaj.dubey@samsung.com>
commit 2c98e0c1cc6b8e86f1978286c3d4e0769ee9d733 upstream.
If 'map->dev' is NULL and there will lead dev_name() to be NULL pointer
dereference. So before dev_name(), we need to have check of the map->dev
pionter.
We also should make sure that the 'name' pointer shouldn't be NULL for
debugfs_create_dir(). So here using one default "dummy" debugfs name when
the 'name' pointer and 'map->dev' are both NULL.
commit 5c1ebe7f73f9166893c3459915db8a09d6d1d715 upstream.
If the device can't support block writes then don't attempt to use raw
syncing which will automatically generate block writes for adjacent
registers, use the existing _single() block syncing implementation.
Reported-by: Jarkko Nikula <jarkko.nikula@linux.intel.com>
Tested-by: Jarkko Nikula <jarkko.nikula@linux.intel.com>
Signed-off-by: Mark Brown <broonie@linaro.org>
commit 5844a8b9d98ec11ce1d77610daacf3f0a0e14715 upstream.
A previous over-zealous factorisation of code means that we only treat
registers as volatile if they are readable. For most devices this is fine
since normally most registers can be read and volatility implies
readability but for format_write() devices where there is no readback from
the hardware and we use volatility to mean simply uncacheability this means
that we end up treating all registers as cacheble.
A bigger refactoring of the code to clarify this is in order but as a fix
make a minimal change and only check readability when checking volatility
if there is no format_write() operation defined for the device.
Tested-by: Lars-Peter Clausen <lars@metafoo.de>
commit fe8eea4f4a3f299ef83ed090d5354698ebe4fda8 upstream.
We should free memory for bitmap when we find zone mismatch, otherwise
this memory will leak.
Additionally, I copy code comment from PPC KVM's CMA code to inform why
we need to check zone mis-match.
Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com>
Acked-by: Zhang Yanfei <zhangyanfei@cn.fujitsu.com>
Reviewed-by: Michal Nazarewicz <mina86@mina86.com>
Reviewed-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
Acked-by: Minchan Kim <minchan@kernel.org>
Cc: "Aneesh Kumar K.V" <aneesh.kumar@linux.vnet.ibm.com>
Cc: Marek Szyprowski <m.szyprowski@samsung.com>
Cc: Michal Nazarewicz <mina86@mina86.com>
Cc: Gleb Natapov <gleb@kernel.org>
Cc: Alexander Graf <agraf@suse.de>
commit 58b116bce13612e5aa6fcd49ecbd4cf8bb59e835 upstream.
When the kernel is built with CONFIG_PREEMPT it is possible to reach a state
when all modules loaded but some driver still stuck in the deferred list
and there is a need for external event to kick the deferred queue to probe
these drivers.
The issue has been observed on embedded systems with CONFIG_PREEMPT enabled,
audio support built as modules and using nfsroot for root filesystem.
The following log fragment shows such sequence when all audio modules
were loaded but the sound card is not present since the machine driver has
failed to probe due to missing dependency during it's probe.
The board is am335x-evmsk (McASP<->tlv320aic3106 codec) with davinci-evm
machine driver:
[ 12.615118] davinci-mcasp 4803c000.mcasp: davinci_mcasp_probe: ENTER
[ 12.719969] davinci_evm sound.3: davinci_evm_probe: ENTER
[ 12.725753] davinci_evm sound.3: davinci_evm_probe: snd_soc_register_card
[ 12.753846] davinci-mcasp 4803c000.mcasp: davinci_mcasp_probe: snd_soc_register_component
[ 12.922051] davinci-mcasp 4803c000.mcasp: davinci_mcasp_probe: snd_soc_register_component DONE
[ 12.950839] davinci_evm sound.3: ASoC: platform (null) not registered
[ 12.957898] davinci_evm sound.3: davinci_evm_probe: snd_soc_register_card DONE (-517)
[ 13.099026] davinci-mcasp 4803c000.mcasp: Kicking the deferred list
[ 13.177838] davinci-mcasp 4803c000.mcasp: really_probe: probe_count = 2
[ 13.194130] davinci_evm sound.3: snd_soc_register_card failed (-517)
[ 13.346755] davinci_mcasp_driver_init: LEAVE
[ 13.377446] platform sound.3: Driver davinci_evm requests probe deferral
[ 13.592527] platform sound.3: really_probe: probe_count = 0
In the log the machine driver enters it's probe at 12.719969 (this point it
has been removed from the deferred lists). McASP driver already executing
it's probing (since 12.615118).
The machine driver tries to construct the sound card (12.950839) but did
not found one of the components so it fails. After this McASP driver
registers all the ASoC components (the machine driver still in it's probe
function after it failed to construct the card) and the deferred work is
prepared at 13.099026 (note that this time the machine driver is not in the
lists so it is not going to be handled when the work is executing).
Lastly the machine driver exit from it's probe and the core places it to
the deferred list but there will be no other driver going to load and the
deferred queue is not going to be kicked again - till we have external event
like connecting USB stick, etc.
The proposed solution is to try the deferred queue once more when the last
driver is asking for deferring and we had drivers loaded while this last
driver was probing.
This way we can avoid drivers stuck in the deferred queue.
Signed-off-by: Grant Likely <grant.likely@linaro.org>
Reviewed-by: Peter Ujfalusi <peter.ujfalusi@ti.com>
Tested-by: Peter Ujfalusi <peter.ujfalusi@ti.com>
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Cc: Mark Brown <broonie@kernel.org>
commit f8d5b9e9e5372f0deb7bc1ab1088a9b60b0a793d upstream.
During restore, pm_notifier chain are called with
PM_RESTORE_PREPARE. The firmware_class driver handler
fw_pm_notify does not have a handler for this. As a result,
it keeps a reader on the kmod.c umhelper_sem. During
freeze_processes, the call to __usermodehelper_disable tries to
take a write lock on this semaphore and hangs waiting.
Signed-off-by: Sebastian Capella <sebastian.capella@linaro.org>
Acked-by: Ming Lei <ming.lei@canonical.com>
commit baab52ded242c35a2290e1fa82e0cc147d0d8c1a upstream.
Commit fa180eb448fa (PM / Runtime: Idle devices asynchronously after
probe|release) modified __device_release_driver() to call
pm_runtime_put(dev) instead of pm_runtime_put_sync(dev) before
detaching the driver from the device. However, that was a mistake,
because pm_runtime_put(dev) causes rpm_idle() to be queued up and
the driver may be gone already when that function is executed.
That breaks the assumptions the drivers have the right to make
about the core's behavior on the basis of the existing documentation
and actually causes problems to happen, so revert that part of
commit fa180eb448fa and restore the previous behavior of
__device_release_driver().
Reported-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
Fixes: fa180eb448fa (PM / Runtime: Idle devices asynchronously after probe|release)
Acked-by: Kevin Hilman <khilman@linaro.org>
Acked-by: Ulf Hansson <ulf.hansson@linaro.org>
When inserting a wrong value to /sys/devices/system/memory/memoryX/state file,
following messages are shown. And device_hotplug_lock is never released.
[ BUG: lock held when returning to user space! ]
3.12.0-rc4-debug+ #3 Tainted: G W
bash/6442 is leaving the kernel with locks still held!
1 lock held by bash/6442:
#0: (device_hotplug_lock){+.+.+.}, at: [<ffffffff8146cbb5>] lock_device_hotplug_sysfs+0x15/0x50
This issue was introdued by commit fa2be40 (drivers: base: use standard
device online/offline for state change).
This patch releases device_hotplug_lcok when store_mem_state returns EINVAL.
Signed-off-by: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com>
Reviewed-by: Toshi Kani <toshi.kani@hp.com>
CC: Seth Jennings <sjenning@linux.vnet.ibm.com>
The put_device(dev) at the bottom of the loop of device_shutdown
may result in the dev being cleaned up. In device_create_release,
the dev is kfreed.
However, device_shutdown attempts to use the dev pointer again after
put_device by referring to dev->parent.
Copy the parent pointer instead to avoid this condition.
This bug was found on Chromium OS's chromeos-3.8, which is based on v3.8.11.
See bug report : https://code.google.com/p/chromium/issues/detail?id=297842
This can easily be reproduced when shutting down with
hidraw devices that report battery condition.
Two examples are the HP Bluetooth Mouse X4000b and the Apple Magic Mouse.
For example, with the magic mouse :
The dev in question is "hidraw0"
dev->parent is "magicmouse"
In the course of the shutdown for this device, the input event cleanup calls
a put on hidraw0, decrementing its reference count.
When we finally get to put_device(dev) in device_shutdown, kobject_cleanup
is called and device_create_release does kfree(dev).
dev->parent is no longer valid, and we may crash in
put_device(dev->parent).
This change should be applied on any kernel with this change :
d1c6c030fcec6f860d9bb6c632a3ebe62e28440b
Cc: stable@vger.kernel.org
Signed-off-by: Benson Leung <bleung@chromium.org>
Reviewed-by: Ming Lei <ming.lei@canonical.com>
We use NR_ANON_PAGES as base for reporting AnonPages to user. There's
not much sense in not accounting transparent huge pages there, but add
them on printing to user.
Let's account transparent huge pages in NR_ANON_PAGES in the first place.
Acked-by: Dave Hansen <dave.hansen@linux.intel.com>
Cc: Wu Fengguang <fengguang.wu@intel.com>
Cc: Jan Kara <jack@suse.cz>
Cc: Matthew Wilcox <willy@linux.intel.com>
Cc: Hillf Danton <dhillf@gmail.com>
Cc: Ning Qu <quning@google.com>
Each dma-buf has an associated size and it's reasonable for userspace
to want to know what it is.
Since userspace already has an fd, expose the size using the
size = lseek(fd, SEEK_END, 0); lseek(fd, SEEK_CUR, 0);
idiom.
v2: Added Daniel's sugeested documentation, with minor fixups
Signed-off-by: Christopher James Halse Rogers <christopher.halse.rogers@canonical.com>
Reviewed-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Tested-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Signed-off-by: Sumit Semwal <sumit.semwal@linaro.org>
anon_inode_getfile might fail, so check its return value.
Signed-off-by: Tuomas Tynkkynen <ttynkkynen@nvidia.com>
git://git.linaro.org/people/mszyprowski/linux-dma-mapping
Pull DMA mapping update from Marek Szyprowski:
"This contains an addition of Device Tree support for reserved memory
regions (Contiguous Memory Allocator is one of the drivers for it) and
changes required by the KVM extensions for PowerPC architectue"
* 'for-v3.12' of git://git.linaro.org/people/mszyprowski/linux-dma-mapping:
ARM: init: add support for reserved memory defined by device tree
drivers: of: add initialization code for dma reserved memory
drivers: of: add function to scan fdt nodes given by path
drivers: dma-contiguous: clean source code and prepare for device tree
Pull KVM updates from Gleb Natapov:
"The highlights of the release are nested EPT and pv-ticketlocks
support (hypervisor part, guest part, which is most of the code, goes
through tip tree). Apart of that there are many fixes for all arches"
Fix up semantic conflicts as discussed in the pull request thread..
* 'next' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (88 commits)
ARM: KVM: Add newlines to panic strings
ARM: KVM: Work around older compiler bug
ARM: KVM: Simplify tracepoint text
ARM: KVM: Fix kvm_set_pte assignment
ARM: KVM: vgic: Bump VGIC_NR_IRQS to 256
ARM: KVM: Bugfix: vgic_bytemap_get_reg per cpu regs
ARM: KVM: vgic: fix GICD_ICFGRn access
ARM: KVM: vgic: simplify vgic_get_target_reg
KVM: MMU: remove unused parameter
KVM: PPC: Book3S PR: Rework kvmppc_mmu_book3s_64_xlate()
KVM: PPC: Book3S PR: Make instruction fetch fallback work for system calls
KVM: PPC: Book3S PR: Don't corrupt guest state when kernel uses VMX
KVM: x86: update masterclock when kvmclock_offset is calculated (v2)
KVM: PPC: Book3S: Fix compile error in XICS emulation
KVM: PPC: Book3S PR: return appropriate error when allocation fails
arch: powerpc: kvm: add signed type cast for comparation
KVM: x86: add comments where MMIO does not return to the emulator
KVM: vmx: count exits to userspace during invalid guest emulation
KVM: rename __kvm_io_bus_sort_cmp to kvm_io_bus_cmp
kvm: optimize away THP checks in kvm_is_mmio_pfn()
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux
Pull PTR_RET() removal patches from Rusty Russell:
"PTR_RET() is a weird name, and led to some confusing usage. We ended
up with PTR_ERR_OR_ZERO(), and replacing or fixing all the usages.
This has been sitting in linux-next for a whole cycle"
[ There are still some PTR_RET users scattered about, with some of them
possibly being new, but most of them existing in Rusty's tree too. We
have that
#define PTR_RET(p) PTR_ERR_OR_ZERO(p)
thing in <linux/err.h>, so they continue to work for now - Linus ]
* tag 'PTR_RET-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux:
GFS2: Replace PTR_RET with PTR_ERR_OR_ZERO
Btrfs: volume: Replace PTR_RET with PTR_ERR_OR_ZERO
drm/cma: Replace PTR_RET with PTR_ERR_OR_ZERO
sh_veu: Replace PTR_RET with PTR_ERR_OR_ZERO
dma-buf: Replace PTR_RET with PTR_ERR_OR_ZERO
drivers/rtc: Replace PTR_RET with PTR_ERR_OR_ZERO
mm/oom_kill: remove weird use of ERR_PTR()/PTR_ERR().
staging/zcache: don't use PTR_RET().
remoteproc: don't use PTR_RET().
pinctrl: don't use PTR_RET().
acpi: Replace weird use of PTR_RET.
s390: Replace weird use of PTR_RET.
PTR_RET is now PTR_ERR_OR_ZERO(): Replace most.
Pull ACPI and power management updates from Rafael Wysocki:
1) ACPI-based PCI hotplug (ACPIPHP) subsystem rework and introduction
of Intel Thunderbolt support on systems that use ACPI for signalling
Thunderbolt hotplug events. This also should make ACPIPHP work in
some cases in which it was known to have problems. From
Rafael J Wysocki, Mika Westerberg and Kirill A Shutemov.
2) ACPI core code cleanups and dock station support cleanups from
Jiang Liu and Rafael J Wysocki.
3) Fixes for locking problems related to ACPI device hotplug from
Rafael J Wysocki.
4) ACPICA update to version 20130725 includig fixes, cleanups, support
for more than 256 GPEs per GPE block and a change to make the ACPI
PM Timer optional (we've seen systems without the PM Timer in the
field already). One of the fixes, related to the DeRefOf operator,
is necessary to prevent some Windows 8 oriented AML from causing
problems to happen. From Bob Moore, Lv Zheng, and Jung-uk Kim.
5) Removal of the old and long deprecated /proc/acpi/event interface
and related driver changes from Thomas Renninger.
6) ACPI and Xen changes to make the reduced hardware sleep work with
the latter from Ben Guthro.
7) ACPI video driver cleanups and a blacklist of systems that should
not tell the BIOS that they are compatible with Windows 8 (or ACPI
backlight and possibly other things will not work on them). From
Felipe Contreras.
8) Assorted ACPI fixes and cleanups from Aaron Lu, Hanjun Guo,
Kuppuswamy Sathyanarayanan, Lan Tianyu, Sachin Kamat, Tang Chen,
Toshi Kani, and Wei Yongjun.
9) cpufreq ondemand governor target frequency selection change to
reduce oscillations between min and max frequencies (essentially,
it causes the governor to choose target frequencies proportional
to load) from Stratos Karafotis.
10) cpufreq fixes allowing sysfs attributes file permissions to be
preserved over suspend/resume cycles Srivatsa S Bhat.
11) Removal of Device Tree parsing for CPU device nodes from multiple
cpufreq drivers that required some changes related to
of_get_cpu_node() to be made in a few architectures and in the
driver core. From Sudeep KarkadaNagesha.
12) cpufreq core fixes and cleanups related to mutual exclusion and
driver module references from Viresh Kumar, Lukasz Majewski and
Rafael J Wysocki.
13) Assorted cpufreq fixes and cleanups from Amit Daniel Kachhap,
Bartlomiej Zolnierkiewicz, Hanjun Guo, Jingoo Han, Joseph Lo,
Julia Lawall, Li Zhong, Mark Brown, Sascha Hauer, Stephen Boyd,
Stratos Karafotis, and Viresh Kumar.
14) Fixes to prevent race conditions in coupled cpuidle from happening
from Colin Cross.
15) cpuidle core fixes and cleanups from Daniel Lezcano and
Tuukka Tikkanen.
16) Assorted cpuidle fixes and cleanups from Daniel Lezcano,
Geert Uytterhoeven, Jingoo Han, Julia Lawall, Linus Walleij,
and Sahara.
17) System sleep tracing changes from Todd E Brandt and Shuah Khan.
18) PNP subsystem conversion to using struct dev_pm_ops for power
management from Shuah Khan.
* tag 'pm+acpi-3.12-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (217 commits)
cpufreq: Don't use smp_processor_id() in preemptible context
cpuidle: coupled: fix race condition between pokes and safe state
cpuidle: coupled: abort idle if pokes are pending
cpuidle: coupled: disable interrupts after entering safe state
ACPI / hotplug: Remove containers synchronously
driver core / ACPI: Avoid device hot remove locking issues
cpufreq: governor: Fix typos in comments
cpufreq: governors: Remove duplicate check of target freq in supported range
cpufreq: Fix timer/workqueue corruption due to double queueing
ACPI / EC: Add ASUSTEK L4R to quirk list in order to validate ECDT
ACPI / thermal: Add check of "_TZD" availability and evaluating result
cpufreq: imx6q: Fix clock enable balance
ACPI: blacklist win8 OSI for buggy laptops
cpufreq: tegra: fix the wrong clock name
cpuidle: Change struct menu_device field types
cpuidle: Add a comment warning about possible overflow
cpuidle: Fix variable domains in get_typical_interval()
cpuidle: Fix menu_device->intervals type
cpuidle: CodingStyle: Break up multiple assignments on single line
cpuidle: Check called function parameter in get_typical_interval()
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core
Pull driver core patches from Greg KH:
"Here's the big driver core pull request for 3.12-rc1.
Lots of tiny changes here fixing up the way sysfs attributes are
created, to try to make drivers simpler, and fix a whole class race
conditions with creations of device attributes after the device was
announced to userspace.
All the various pieces are acked by the different subsystem
maintainers"
* tag 'driver-core-3.12-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (119 commits)
firmware loader: fix pending_fw_head list corruption
drivers/base/memory.c: introduce help macro to_memory_block
dynamic debug: line queries failing due to uninitialized local variable
sysfs: sysfs_create_groups returns a value.
debugfs: provide debugfs_create_x64() when disabled
rbd: convert bus code to use bus_groups
firmware: dcdbas: use binary attribute groups
sysfs: add sysfs_create/remove_groups for when SYSFS is not enabled
driver core: add #include <linux/sysfs.h> to core files.
HID: convert bus code to use dev_groups
Input: serio: convert bus code to use drv_groups
Input: gameport: convert bus code to use drv_groups
driver core: firmware: use __ATTR_RW()
driver core: core: use DEVICE_ATTR_RO
driver core: bus: use DRIVER_ATTR_WO()
driver core: create write-only attribute macros for devices and drivers
sysfs: create __ATTR_WO()
driver-core: platform: convert bus code to use dev_groups
workqueue: convert bus code to use dev_groups
MEI: convert bus code to use dev_groups
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regmap
Pull regmap updates from Mark Brown:
"A quiet release for regmap, some cleanups, fixes and:
- Improved node coalescing for rbtree, reducing memory usage and
improving performance during syncs.
- Support for registering multiple register patches.
- A quirk for handling interrupts that need to be clear when masked
in regmap-irq"
* tag 'regmap-v3.12' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regmap:
regmap: rbtree: Make cache_present bitmap per node
regmap: rbtree: Simplify adjacent node look-up
regmap: debugfs: Fix continued read from registers file
regcache-rbtree: Fix reg_stride != 1
regmap: Allow multiple patches to be registered
regmap: regcache: allow read-only regs to be cached
regmap: fix regcache_reg_present() for empty cache
regmap: core: allow a virtual range to cover its own data window
regmap: irq: document mask/wake_invert flags
regmap: irq: make flags bool and put them in a bitfield
regmap: irq: Allow to acknowledge masked interrupts during initialization
regmap: Provide __acquires/__releases annotations
Got the following oops just before reboot:
Unable to handle kernel NULL pointer dereference at virtual address 00000000
[<8028d300>] (__list_del_entry+0x44/0xac)
[<802e3320>] (__fw_load_abort.part.13+0x1c/0x50)
[<802e337c>] (fw_shutdown_notify+0x28/0x50)
[<80034f80>] (notifier_call_chain.isra.1+0x5c/0x9c)
[<800350ec>] (__blocking_notifier_call_chain+0x44/0x58)
[<80035114>] (blocking_notifier_call_chain+0x14/0x18)
[<80035d64>] (kernel_restart_prepare+0x14/0x38)
[<80035d94>] (kernel_restart+0xc/0x50)
The following race condition triggers here:
_request_firmware_load()
device_create_file(...)
kobject_uevent(...)
(schedule)
(resume)
firmware_loading_store(1)
firmware_loading_store(0)
list_del_init(&buf->pending_list)
(schedule)
(resume)
list_add(&buf->pending_list, &pending_fw_head);
wait_for_completion(&buf->completion);
causing an oops later when walking pending_list after the firmware has
been released.
The proposed fix is to move the list_add() before sysfs attribute
creation.
Signed-off-by: Maxime Bizon <mbizon@freebox.fr>
Cc: stable <stable@vger.kernel.org>
* acpi-hotplug:
device_hotplug_lock is held around the acpi_bus_trim() call in
acpi_scan_hot_remove() which generally removes devices (it removes
ACPI device objects at least, but it may also remove "physical"
device objects through .detach() callbacks of ACPI scan handlers).
Thus, potentially, device sysfs attributes are removed under that
lock and to remove those attributes it is necessary to hold the
s_active references of their directory entries for writing.
On the other hand, the execution of a .show() or .store() callback
from a sysfs attribute is carried out with that attribute's s_active
reference held for reading. Consequently, if any device sysfs
attribute that may be removed from within acpi_scan_hot_remove()
through acpi_bus_trim() has a .store() or .show() callback which
acquires device_hotplug_lock, the execution of that callback may
deadlock with the removal of the attribute. [Unfortunately, the
"online" device attribute of CPUs and memory blocks is one of them.]
To avoid such deadlocks, make all of the sysfs attribute callbacks
that need to lock device hotplug, for example store_online(), use
a special function, lock_device_hotplug_sysfs(), to lock device
hotplug and return the result of that function immediately if it is
not zero. This will cause the s_active reference of the directory
entry in question to be released and the syscall to be restarted
if device_hotplug_lock cannot be acquired.
[show_online() actually doesn't need to lock device hotplug, but
it is useful to serialize it with respect to device_offline() and
device_online() for the same device (in case user space attempts to
run them concurrently) which can be done with the help of
device_lock().]
Reported-by: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com>
Reported-and-tested-by: Gu Zheng <guz.fnst@cn.fujitsu.com>
Suggested-by: Tejun Heo <tj@kernel.org>
Acked-by: Toshi Kani <toshi.kani@hp.com>
With devices which have a dense and small register map but placed at a large
offset the global cache_present bitmap imposes a huge memory overhead. Making
the cache_present per rbtree node avoids the issue and easily reduces the memory
footprint by a factor of ten. For devices with a more sparse map or without a
large base register offset the memory usage might increase slightly by a few
bytes, but not significantly. E.g. for a device which has ~50 registers at
offset 0x4000 the memory footprint of the register cache goes down form 2496
bytes to 175 bytes.
Moving the bitmap to a per node basis means that the handling of the bitmap is
now cache implementation specific and can no longer be managed by the core. The
regcache_sync_block() function is extended by a additional parameter so that the
cache implementation can tell the core which registers in the block are set and
which are not. The parameter is optional and if NULL the core assumes that all
registers are set. The rbtree cache also needs to implement its own drop
callback instead of relying on the core to handle this.
Support for reducing the number of nodes and memory consumption of the rbtree
cache by allowing for small unused holes in the node's register cache block was
initially added in commit 0c7ed856 ("regmap: Cut down on the average # of nodes
in the rbtree cache"). But the commit had problems and so its effect was
reverted again in commit 4e67fb5 ("regmap: rbtree: Fix overlapping rbnodes.").
This patch brings the feature back of reducing the average number of nodes,
which will speedup node look-up, while at the same time also reducing the memory
usage of the rbtree cache. This patch takes a slightly different approach than
the original patch though. It modifies the adjacent node look-up to not only
consider nodes that are just one to the left or the right of the register but
any node that falls in a certain range around the register. The range is
calculated based on how much memory it would take to allocate a new node
compared to how much memory it takes adding a set of unused registers to an
existing node. E.g. if a node takes up 24 bytes and each register in a block
uses 1 byte the range will be from the register address - 24 to the register
address + 24. If we find a node that falls within this range it is cheaper or as
expensive to add the register to the existing node and have a couple of unused
registers in the node's cache compared to allocating a new node.
A register which is adjacent to a node will either be left to the first
register or right to the last register. It will not be within the node's range,
so there is no point in checking for each register cached by the node whether
the new register is next to it. It is sufficient to check whether the register
comes before the first register or after the last register of the node.
"cat /sys/devices/system/memory/memory*/removable" crashed the system.
The problem is that show_mem_removable() is passing a
bad pfn to is_mem_section_removable(), which causes
if (!node_online(page_to_nid(page)))
to blow up. Why is it passing in a bad pfn?
The reason is that show_mem_removable() will loop sections_per_block
times. sections_per_block is 16, but mem->section_count is 8,
indicating holes in this memory block. Checking that the memory section
is present before checking to see if the memory section is removable
fixes the problem.
harp5-sys:~ # cat /sys/devices/system/memory/memory*/removable
0
1
1
1
1
1
1
1
1
1
1
1
1
1
BUG: unable to handle kernel paging request at ffffea00c3200000
IP: [<ffffffff81117ed1>] is_pageblock_removable_nolock+0x1/0x90
PGD 83ffd4067 PUD 37bdfce067 PMD 0
Oops: 0000 [#1] SMP
Modules linked in: autofs4 binfmt_misc rdma_ucm rdma_cm iw_cm ib_addr ib_srp scsi_transport_srp scsi_tgt ib_ipoib ib_cm ib_uverbs ib_umad iw_cxgb3 cxgb3 mdio mlx4_en mlx4_ib ib_sa mlx4_core ib_mthca ib_mad ib_core fuse nls_iso8859_1 nls_cp437 vfat fat joydev loop hid_generic usbhid hid hwperf(O) numatools(O) dm_mod iTCO_wdt ipv6 iTCO_vendor_support igb i2c_i801 ioatdma i2c_algo_bit ehci_pci pcspkr lpc_ich i2c_core ehci_hcd ptp sg mfd_core dca rtc_cmos pps_core mperf button xhci_hcd sd_mod crc_t10dif usbcore usb_common scsi_dh_emc scsi_dh_hp_sw scsi_dh_alua scsi_dh_rdac scsi_dh gru(O) xvma(O) xfs crc32c libcrc32c thermal sata_nv processor piix mptsas mptscsih scsi_transport_sas mptbase megaraid_sas fan thermal_sys hwmon ext3 jbd ata_piix ahci libahci libata scsi_mod
CPU: 4 PID: 5991 Comm: cat Tainted: G O 3.11.0-rc5-rja-uv+ #10
Hardware name: SGI UV2000/ROMLEY, BIOS SGI UV 2000/3000 series BIOS 01/15/2013
task: ffff88081f034580 ti: ffff880820022000 task.ti: ffff880820022000
RIP: 0010:[<ffffffff81117ed1>] [<ffffffff81117ed1>] is_pageblock_removable_nolock+0x1/0x90
RSP: 0018:ffff880820023df8 EFLAGS: 00010287
RAX: 0000000000040000 RBX: ffffea00c3200000 RCX: 0000000000000004
RDX: ffffea00c30b0000 RSI: 00000000001c0000 RDI: ffffea00c3200000
RBP: ffff880820023e38 R08: 0000000000000000 R09: 0000000000000001
R10: 0000000000000000 R11: 0000000000000001 R12: ffffea00c33c0000
R13: 0000160000000000 R14: 6db6db6db6db6db7 R15: 0000000000000001
FS: 00007ffff7fb2700(0000) GS:ffff88083fc80000(0000) knlGS:0000000000000000
CR2: ffffea00c3200000 CR3: 000000081b954000 CR4: 00000000000407e0
Call Trace:
show_mem_removable+0x41/0x70
dev_attr_show+0x2a/0x60
sysfs_read_file+0xf7/0x1c0
vfs_read+0xc8/0x130
SyS_read+0x5d/0xa0
system_call_fastpath+0x16/0x1b
Signed-off-by: Russ Anderson <rja@sgi.com>
Cc: "Rafael J. Wysocki" <rafael.j.wysocki@intel.com>
Cc: Yinghai Lu <yinghai@kernel.org>
Reviewed-by: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com>
Cc: <stable@vger.kernel.org>
Introduce help macro to_memory_block to hide the conversion(device-->memory_block),
just clean up.
Signed-off-by: Gu Zheng <guz.fnst@cn.fujitsu.com>
mm/Kconfig
CMA DMA split and ZSWAP introduction were conflicting, fix up manually.
The regmap_debugfs_get_dump_start() function maps from a file offset to the
register that can be found at that position in the file. This is done using a
look-up table. Commit d6814a7d ("regmap: debugfs: Suppress cache for partial
register files") added a check to bypass the look-up table for partial register
files, since the offsets in that table are only correct for the full register
file. The check incorrectly uses the file offset instead of the register base
address and returns it. This will cause the file offset to be interpreted as a
register address which will result in a incorrect output from the registers file
for all reads except at position 0.
The issue can easily be reproduced by doing small reads the registers file, e.g.
`dd if=registers bs=10 count=5`.
This is needed to fix the build on sh systems.
Reported-by: kbuild test robot <fengguang.wu@intel.com>
There are a couple of calculations, which convert between register addresses and
block indices, in regcache_rbtree_sync() and regcache_rbtree_node_alloc() which
assume that reg_stride is 1. This will break the rb cache for configurations
which do not use a reg_stride of 1.
Also rename 'base' in regcache_rbtree_sync() to 'start' to avoid confusion with
'base_reg'.
This patch cleans the initialization of dma contiguous framework. The
all-in-one dma_declare_contiguous() function is now separated into
dma_contiguous_reserve_area() which only steals the the memory from
memblock allocator and dma_contiguous_add_device() function, which
assigns given device to the specified reserved memory area. This improves
the flexibility in defining contiguous memory areas and assigning device
to them, because now it is possible to assign more than one device to
the given contiguous memory area. Such split in initialization procedure
is also required for upcoming device tree support.
Acked-by: Kyungmin Park <kyungmin.park@samsung.com>
Acked-by: Michal Nazarewicz <mina86@mina86.com>
Acked-by: Tomasz Figa <t.figa@samsung.com>
* pm-cpufreq: (60 commits)
cpufreq: pmac32-cpufreq: remove device tree parsing for cpu nodes
cpufreq: pmac64-cpufreq: remove device tree parsing for cpu nodes
cpufreq: maple-cpufreq: remove device tree parsing for cpu nodes
cpufreq: arm_big_little: remove device tree parsing for cpu nodes
cpufreq: kirkwood-cpufreq: remove device tree parsing for cpu nodes
cpufreq: spear-cpufreq: remove device tree parsing for cpu nodes
cpufreq: highbank-cpufreq: remove device tree parsing for cpu nodes
cpufreq: cpufreq-cpu0: remove device tree parsing for cpu nodes
cpufreq: imx6q-cpufreq: remove device tree parsing for cpu nodes
drivers/bus: arm-cci: avoid parsing DT for cpu device nodes
ARM: mvebu: remove device tree parsing for cpu nodes
ARM: topology: remove hwid/MPIDR dependency from cpu_capacity
of/device: add helper to get cpu device node from logical cpu index
driver/core: cpu: initialize of_node in cpu's device struture
ARM: DT/kernel: define ARM specific arch_match_cpu_phys_id
of: move of_get_cpu_node implementation to DT core library
powerpc: refactor of_get_cpu_node to support other architectures
openrisc: remove undefined of_get_cpu_node declaration
microblaze: remove undefined of_get_cpu_node declaration
cpufreq: fix bad unlock balance on !CONFIG_SMP
* pm-opp:
PM / OPP: Export opp_add()
* pm-sleep:
PM / Sleep: new trace event to print device suspend and resume times
PM / Sleep: increase ftrace coverage in suspend/resume
Use __ATTR_RW() instead of __ATTR() to make it more obvious what the
type of attribute is being created.
