[ Upstream commit dc351d4c5f4fe4d0f274d6d660227be0c3a03317 ]
The dev->power.direct_complete flag may become set in device_prepare() in
case the device don't have any PM callbacks (dev->power.no_pm_callbacks is
set). This leads to a broken behaviour, when there is child having wakeup
enabled and relies on its parent to be used in the wakeup path.
More precisely, when the direct complete path becomes selected for the
child in __device_suspend(), the propagation of the dev->power.wakeup_path
becomes skipped as well.
Let's address this problem, by checking if the device is a part the wakeup
path or has wakeup enabled, then prevent the direct complete path from
being used.
Reported-by: Loic Pallardy <loic.pallardy@st.com>
Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
[ rjw: Comment cleanup ]
commit 0b777eee88d712256ba8232a9429edb17c4f9ceb upstream.
In commit 376991db4b64 ("driver core: Postpone DMA tear-down until after
devres release"), we changed the ordering of tearing down the device DMA
ops and releasing all the device's resources; this was because the DMA ops
should be maintained until we release the device's managed DMA memories.
However, we have seen another crash on an arm64 system when a
device driver probe fails:
hisi_sas_v3_hw 0000:74:02.0: Adding to iommu group 2
scsi host1: hisi_sas_v3_hw
BUG: Bad page state in process swapper/0 pfn:313f5
page:ffff7e0000c4fd40 count:1 mapcount:0
mapping:0000000000000000 index:0x0
flags: 0xfffe00000001000(reserved)
raw: 0fffe00000001000 ffff7e0000c4fd48 ffff7e0000c4fd48
0000000000000000
raw: 0000000000000000 0000000000000000 00000001ffffffff
0000000000000000
page dumped because: PAGE_FLAGS_CHECK_AT_FREE flag(s) set
bad because of flags: 0x1000(reserved)
Modules linked in:
CPU: 49 PID: 1 Comm: swapper/0 Not tainted
5.1.0-rc1-43081-g22d97fd-dirty #1433
Hardware name: Huawei D06/D06, BIOS Hisilicon D06 UEFI
RC0 - V1.12.01 01/29/2019
Call trace:
dump_backtrace+0x0/0x118
show_stack+0x14/0x1c
dump_stack+0xa4/0xc8
bad_page+0xe4/0x13c
free_pages_check_bad+0x4c/0xc0
__free_pages_ok+0x30c/0x340
__free_pages+0x30/0x44
__dma_direct_free_pages+0x30/0x38
dma_direct_free+0x24/0x38
dma_free_attrs+0x9c/0xd8
dmam_release+0x20/0x28
release_nodes+0x17c/0x220
devres_release_all+0x34/0x54
really_probe+0xc4/0x2c8
driver_probe_device+0x58/0xfc
device_driver_attach+0x68/0x70
__driver_attach+0x94/0xdc
bus_for_each_dev+0x5c/0xb4
driver_attach+0x20/0x28
bus_add_driver+0x14c/0x200
driver_register+0x6c/0x124
__pci_register_driver+0x48/0x50
sas_v3_pci_driver_init+0x20/0x28
do_one_initcall+0x40/0x25c
kernel_init_freeable+0x2b8/0x3c0
kernel_init+0x10/0x100
ret_from_fork+0x10/0x18
Disabling lock debugging due to kernel taint
BUG: Bad page state in process swapper/0 pfn:313f6
page:ffff7e0000c4fd80 count:1 mapcount:0
[ 89.322983] flags: 0xfffe00000001000(reserved)
raw: 0fffe00000001000 ffff7e0000c4fd88 ffff7e0000c4fd88
0000000000000000
0000000000000000
The crash occurs for the same reason.
In this case, on the really_probe() failure path, we are still clearing
the DMA ops prior to releasing the device's managed memories.
This patch fixes this issue by reordering the DMA ops teardown and the
call to devres_release_all() on the failure path.
Reported-by: Xiang Chen <chenxiang66@hisilicon.com>
Tested-by: Xiang Chen <chenxiang66@hisilicon.com>
Signed-off-by: John Garry <john.garry@huawei.com>
Reviewed-by: Robin Murphy <robin.murphy@arm.com>
[jpg: backport to 4.19.x and earlier]
commit 8a4b06d391b0a42a373808979b5028f5c84d9c6a upstream
Add the sysfs reporting file for MDS. It exposes the vulnerability and
mitigation state similar to the existing files for the other speculative
hardware vulnerabilities.
Reviewed-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Reviewed-by: Borislav Petkov <bp@suse.de>
Reviewed-by: Jon Masters <jcm@redhat.com>
Tested-by: Jon Masters <jcm@redhat.com>
In upstream branch this fixed by commit b29940c1abd7 ("mm: rename and
change semantics of nr_indirectly_reclaimable_bytes").
This fixes /sys/devices/system/node/node*/vmstat format:
nr_dirtied 6613155
nr_written 5796802
11089216
Cc: <stable@vger.kernel.org> # 4.19.y
Fixes: 7aaf77272358 ("mm: don't show nr_indirectly_reclaimable in /proc/vmstat")
Signed-off-by: Konstantin Khlebnikov <khlebnikov@yandex-team.ru>
Cc: Roman Gushchin <guro@fb.com>
[ Upstream commit 2071ac985d37efe496782c34318dbead93beb02f ]
Lockdep warns that prepare_lock and genpd->mlock can cause a deadlock
the deadlock scenario is like following:
First thread is probing cs2000
cs2000_probe()
clk_register()
__clk_core_init()
clk_prepare_lock() ----> acquires prepare_lock
cs2000_recalc_rate()
i2c_smbus_read_byte_data()
rcar_i2c_master_xfer()
dma_request_chan()
rcar_dmac_of_xlate()
rcar_dmac_alloc_chan_resources()
pm_runtime_get_sync()
__pm_runtime_resume()
rpm_resume()
rpm_callback()
genpd_runtime_resume() ----> acquires genpd->mlock
Second thread is attaching any device to the same PM domain
genpd_add_device()
genpd_lock() ----> acquires genpd->mlock
cpg_mssr_attach_dev()
of_clk_get_from_provider()
__of_clk_get_from_provider()
__clk_create_clk()
Since currently no PM provider access genpd's critical section
in .attach_dev, and .detach_dev callbacks, so there is no need to protect
these two callbacks with genpd->mlock.
This patch avoids a potential deadlock by moving out .attach_dev and .detach_dev
from genpd->mlock, so that genpd->mlock won't be held when prepare_lock is acquired
in .attach_dev and .detach_dev
Signed-off-by: Jiada Wang <jiada_wang@mentor.com>
Reviewed-by: Ulf Hansson <ulf.hansson@linaro.org>
Tested-by: Geert Uytterhoeven <geert+renesas@glider.be>
Reviewed-by: Geert Uytterhoeven <geert+renesas@glider.be>
commit 1fad17fb1bbcd73159c2b992668a6957ecc5af8a upstream.
If wakeup_source_add() is called right after wakeup_source_remove()
for the same wakeup source, timer_setup() may be called for a
potentially scheduled timer which is incorrect.
To avoid that, move the wakeup source timer cancellation from
wakeup_source_drop() to wakeup_source_remove().
Moreover, make wakeup_source_remove() clear the timer function after
canceling the timer to let wakeup_source_not_registered() treat
unregistered wakeup sources in the same way as the ones that have
never been registered.
Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org>
Cc: 4.4+ <stable@vger.kernel.org> # 4.4+
[ rjw: Subject, changelog, merged two patches together ]
commit 376991db4b6464e906d699ef07681e2ffa8ab08c upstream.
When unbinding the (IOMMU-enabled) R-Car SATA device on Salvator-XS
(R-Car H3 ES2.0), in preparation of rebinding against vfio-platform for
device pass-through for virtualization:
echo ee300000.sata > /sys/bus/platform/drivers/sata_rcar/unbind
the kernel crashes with:
Unable to handle kernel paging request at virtual address ffffffbf029ffffc
Mem abort info:
ESR = 0x96000006
Exception class = DABT (current EL), IL = 32 bits
SET = 0, FnV = 0
EA = 0, S1PTW = 0
Data abort info:
ISV = 0, ISS = 0x00000006
CM = 0, WnR = 0
swapper pgtable: 4k pages, 39-bit VAs, pgdp = 000000007e8c586c
[ffffffbf029ffffc] pgd=000000073bfc6003, pud=000000073bfc6003, pmd=0000000000000000
Internal error: Oops: 96000006 [#1] SMP
Modules linked in:
CPU: 0 PID: 1098 Comm: bash Not tainted 5.0.0-rc5-salvator-x-00452-g37596f884f4318ef #287
Hardware name: Renesas Salvator-X 2nd version board based on r8a7795 ES2.0+ (DT)
pstate: 60400005 (nZCv daif +PAN -UAO)
pc : __free_pages+0x8/0x58
lr : __dma_direct_free_pages+0x50/0x5c
sp : ffffff801268baa0
x29: ffffff801268baa0 x28: 0000000000000000
x27: ffffffc6f9c60bf0 x26: ffffffc6f9c60bf0
x25: ffffffc6f9c60810 x24: 0000000000000000
x23: 00000000fffff000 x22: ffffff8012145000
x21: 0000000000000800 x20: ffffffbf029fffc8
x19: 0000000000000000 x18: ffffffc6f86c42c8
x17: 0000000000000000 x16: 0000000000000070
x15: 0000000000000003 x14: 0000000000000000
x13: ffffff801103d7f8 x12: 0000000000000028
x11: ffffff8011117604 x10: 0000000000009ad8
x9 : ffffff80110126d0 x8 : ffffffc6f7563000
x7 : 6b6b6b6b6b6b6b6b x6 : 0000000000000018
x5 : ffffff8011cf3cc8 x4 : 0000000000004000
x3 : 0000000000080000 x2 : 0000000000000001
x1 : 0000000000000000 x0 : ffffffbf029fffc8
Process bash (pid: 1098, stack limit = 0x00000000c38e3e32)
Call trace:
arch_dma_free+0x1c/0x98
dma_direct_free+0x14/0x24
dma_free_attrs+0x9c/0xdc
dmam_release+0x18/0x20
release_nodes+0x25c/0x28c
devres_release_all+0x48/0x4c
device_release_driver_internal+0x184/0x1f0
device_release_driver+0x14/0x1c
unbind_store+0x70/0xb8
drv_attr_store+0x24/0x34
sysfs_kf_write+0x4c/0x64
kernfs_fop_write+0x154/0x1c4
__vfs_write+0x34/0x164
vfs_write+0xb4/0x16c
ksys_write+0x5c/0xbc
__arm64_sys_write+0x14/0x1c
el0_svc_common+0x98/0x114
el0_svc_handler+0x1c/0x24
el0_svc+0x8/0xc
Code: d51b4234 17fffffa a9bf7bfd 910003fd (b9403404)
---[ end trace 8c564cdd3a1a840f ]---
While I've bisected this to commit e8e683ae9a736407 ("iommu/of: Fix
probe-deferral"), and reverting that commit on post-v5.0-rc4 kernels
does fix the problem, this turned out to be a red herring.
On arm64, arch_teardown_dma_ops() resets dev->dma_ops to NULL.
Hence if a driver has used a managed DMA allocation API, the allocated
DMA memory will be freed using the direct DMA ops, while it may have
been allocated using a custom DMA ops (iommu_dma_ops in this case).
Fix this by reversing the order of the calls to devres_release_all() and
arch_teardown_dma_ops().
Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be>
Acked-by: Christoph Hellwig <hch@lst.de>
Reviewed-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
Cc: stable <stable@vger.kernel.org>
[rm: backport for 4.12-4.19 - kernels before 5.0 will not see
the crash above, but may get silent memory corruption instead]
Signed-off-by: Robin Murphy <robin.murphy@arm.com>
commit 3a34c986324c07dde32903f7bb262e6138e77c2a upstream.
Commit 448a5a552f336bd7b847b1951 ("drivers: base: cacheinfo: use OF
property_read_u32 instead of get_property,read_number") makes cache
size and number_of_sets be 0 if DT doesn't provide there values. I
think this is unreasonable so make them keep the old values, which is
the same as old kernels.
Fixes: 448a5a552f33 ("drivers: base: cacheinfo: use OF property_read_u32 instead of get_property,read_number")
Cc: stable@vger.kernel.org
Signed-off-by: Huacai Chen <chenhc@lemote.com>
Reviewed-by: Sudeep Holla <sudeep.holla@arm.com>
[ Upstream commit df44b479654f62b478c18ee4d8bc4e9f897a9844 ]
Propagate error code back to userspace if writing the /sys/.../uevent
file fails. Before, the write operation always returned with success,
even if we failed to recognize the input string or if we failed to
generate the uevent itself.
With the error codes properly propagated back to userspace, we are
able to react in userspace accordingly by not assuming and awaiting
a uevent that is not delivered.
Signed-off-by: Peter Rajnoha <prajnoha@redhat.com>
[ Upstream commit c37d721c68ad88925ba0e72f6e14acb829a8c6bb ]
Move the async_synchronize_full call out of __device_release_driver and
into driver_detach.
The idea behind this is that the async_synchronize_full call will only
guarantee that any existing async operations are flushed. This doesn't do
anything to guarantee that a hotplug event that may occur while we are
doing the release of the driver will not be asynchronously scheduled.
By moving this into the driver_detach path we can avoid potential deadlocks
as we aren't holding the device lock at this point and we should not have
the driver we want to flush loaded so the flush will take care of any
asynchronous events the driver we are detaching might have scheduled.
Fixes: 765230b5f084 ("driver-core: add asynchronous probing support for drivers")
Reviewed-by: Bart Van Assche <bvanassche@acm.org>
Reviewed-by: Dan Williams <dan.j.williams@intel.com>
Signed-off-by: Alexander Duyck <alexander.h.duyck@linux.intel.com>
Reviewed-by: Luis Chamberlain <mcgrof@kernel.org>
commit a66d972465d15b1d89281258805eb8b47d66bd36 upstream.
Initially we bumped into problem with 32-bit aligned atomic64_t
on ARC, see [1]. And then during quite lengthly discussion Peter Z.
mentioned ARCH_KMALLOC_MINALIGN which IMHO makes perfect sense.
If allocation is done by plain kmalloc() obtained buffer will be
ARCH_KMALLOC_MINALIGN aligned and then why buffer obtained via
devm_kmalloc() should have any other alignment?
This way we at least get the same behavior for both types of
allocation.
[1] http://lists.infradead.org/pipermail/linux-snps-arc/2018-July/004009.html
[2] http://lists.infradead.org/pipermail/linux-snps-arc/2018-July/004036.html
Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
Cc: David Laight <David.Laight@ACULAB.COM>
Cc: Vineet Gupta <vgupta@synopsys.com>
Cc: Greg KH <greg@kroah.com>
Cc: <stable@vger.kernel.org> # 4.8+
[ Upstream commit 4f4b374332ec0ae9c738ff8ec9bed5cd97ff9adc ]
This is the much more correct fix for my earlier attempt at:
https://lkml.org/lkml/2018/12/10/118
Short recap:
- There's not actually a locking issue, it's just lockdep being a bit
too eager to complain about a possible deadlock.
- Contrary to what I claimed the real problem is recursion on
kn->count. Greg pointed me at sysfs_break_active_protection(), used
by the scsi subsystem to allow a sysfs file to unbind itself. That
would be a real deadlock, which isn't what's happening here. Also,
breaking the active protection means we'd need to manually handle
all the lifetime fun.
- With Rafael we discussed the task_work approach, which kinda works,
but has two downsides: It's a functional change for a lockdep
annotation issue, and it won't work for the bind file (which needs
to get the errno from the driver load function back to userspace).
- Greg also asked why this never showed up: To hit this you need to
unregister a 2nd driver from the unload code of your first driver. I
guess only gpus do that. The bug has always been there, but only
with a recent patch series did we add more locks so that lockdep
built a chain from unbinding the snd-hda driver to the
acpi_video_unregister call.
Full lockdep splat:
[12301.898799] ============================================
[12301.898805] WARNING: possible recursive locking detected
[12301.898811] 4.20.0-rc7+ #84 Not tainted
[12301.898815] --------------------------------------------
[12301.898821] bash/5297 is trying to acquire lock:
[12301.898826] 00000000f61c6093 (kn->count#39){++++}, at: kernfs_remove_by_name_ns+0x3b/0x80
[12301.898841] but task is already holding lock:
[12301.898847] 000000005f634021 (kn->count#39){++++}, at: kernfs_fop_write+0xdc/0x190
[12301.898856] other info that might help us debug this:
[12301.898862] Possible unsafe locking scenario:
[12301.898867] CPU0
[12301.898870] ----
[12301.898874] lock(kn->count#39);
[12301.898879] lock(kn->count#39);
[12301.898883] *** DEADLOCK ***
[12301.898891] May be due to missing lock nesting notation
[12301.898899] 5 locks held by bash/5297:
[12301.898903] #0: 00000000cd800e54 (sb_writers#4){.+.+}, at: vfs_write+0x17f/0x1b0
[12301.898915] #1: 000000000465e7c2 (&of->mutex){+.+.}, at: kernfs_fop_write+0xd3/0x190
[12301.898925] #2: 000000005f634021 (kn->count#39){++++}, at: kernfs_fop_write+0xdc/0x190
[12301.898936] #3: 00000000414ef7ac (&dev->mutex){....}, at: device_release_driver_internal+0x34/0x240
[12301.898950] #4: 000000003218fbdf (register_count_mutex){+.+.}, at: acpi_video_unregister+0xe/0x40
[12301.898960] stack backtrace:
[12301.898968] CPU: 1 PID: 5297 Comm: bash Not tainted 4.20.0-rc7+ #84
[12301.898974] Hardware name: Hewlett-Packard HP EliteBook 8460p/161C, BIOS 68SCF Ver. F.01 03/11/2011
[12301.898982] Call Trace:
[12301.898989] dump_stack+0x67/0x9b
[12301.898997] __lock_acquire+0x6ad/0x1410
[12301.899003] ? kernfs_remove_by_name_ns+0x3b/0x80
[12301.899010] ? find_held_lock+0x2d/0x90
[12301.899017] ? mutex_spin_on_owner+0xe4/0x150
[12301.899023] ? find_held_lock+0x2d/0x90
[12301.899030] ? lock_acquire+0x90/0x180
[12301.899036] lock_acquire+0x90/0x180
[12301.899042] ? kernfs_remove_by_name_ns+0x3b/0x80
[12301.899049] __kernfs_remove+0x296/0x310
[12301.899055] ? kernfs_remove_by_name_ns+0x3b/0x80
[12301.899060] ? kernfs_name_hash+0xd/0x80
[12301.899066] ? kernfs_find_ns+0x6c/0x100
[12301.899073] kernfs_remove_by_name_ns+0x3b/0x80
[12301.899080] bus_remove_driver+0x92/0xa0
[12301.899085] acpi_video_unregister+0x24/0x40
[12301.899127] i915_driver_unload+0x42/0x130 [i915]
[12301.899160] i915_pci_remove+0x19/0x30 [i915]
[12301.899169] pci_device_remove+0x36/0xb0
[12301.899176] device_release_driver_internal+0x185/0x240
[12301.899183] unbind_store+0xaf/0x180
[12301.899189] kernfs_fop_write+0x104/0x190
[12301.899195] __vfs_write+0x31/0x180
[12301.899203] ? rcu_read_lock_sched_held+0x6f/0x80
[12301.899209] ? rcu_sync_lockdep_assert+0x29/0x50
[12301.899216] ? __sb_start_write+0x13c/0x1a0
[12301.899221] ? vfs_write+0x17f/0x1b0
[12301.899227] vfs_write+0xb9/0x1b0
[12301.899233] ksys_write+0x50/0xc0
[12301.899239] do_syscall_64+0x4b/0x180
[12301.899247] entry_SYSCALL_64_after_hwframe+0x49/0xbe
[12301.899253] RIP: 0033:0x7f452ac7f7a4
[12301.899259] Code: 00 f7 d8 64 89 02 48 c7 c0 ff ff ff ff eb b7 0f 1f 80 00 00 00 00 8b 05 aa f0 2c 00 48 63 ff 85 c0 75 13 b8 01 00 00 00 0f 05 <48> 3d 00 f0 ff ff 77 54 f3 c3 66 90 55 53 48 89 d5 48 89 f3 48 83
[12301.899273] RSP: 002b:00007ffceafa6918 EFLAGS: 00000246 ORIG_RAX: 0000000000000001
[12301.899282] RAX: ffffffffffffffda RBX: 000000000000000d RCX: 00007f452ac7f7a4
[12301.899288] RDX: 000000000000000d RSI: 00005612a1abf7c0 RDI: 0000000000000001
[12301.899295] RBP: 00005612a1abf7c0 R08: 000000000000000a R09: 00005612a1c46730
[12301.899301] R10: 000000000000000a R11: 0000000000000246 R12: 000000000000000d
[12301.899308] R13: 0000000000000001 R14: 00007f452af4a740 R15: 000000000000000d
Looking around I've noticed that usb and i2c already handle similar
recursion problems, where a sysfs file can unbind the same type of
sysfs somewhere else in the hierarchy. Relevant commits are:
commit 356c05d58af05d582e634b54b40050c73609617b
Author: Alan Stern <stern@rowland.harvard.edu>
Date: Mon May 14 13:30:03 2012 -0400
sysfs: get rid of some lockdep false positives
commit e9b526fe704812364bca07edd15eadeba163ebfb
Author: Alexander Sverdlin <alexander.sverdlin@nsn.com>
Date: Fri May 17 14:56:35 2013 +0200
i2c: suppress lockdep warning on delete_device
Implement the same trick for driver bind/unbind.
v2: Put the macro into bus.c (Greg).
Cc: Ramalingam C <ramalingam.c@intel.com>
Cc: Arend van Spriel <aspriel@gmail.com>
Cc: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
Cc: Geert Uytterhoeven <geert+renesas@glider.be>
Cc: Bartosz Golaszewski <brgl@bgdev.pl>
Cc: Heikki Krogerus <heikki.krogerus@linux.intel.com>
Cc: Vivek Gautam <vivek.gautam@codeaurora.org>
Cc: Joe Perches <joe@perches.com>
Signed-off-by: Daniel Vetter <daniel.vetter@intel.com>
commit e121a833745b4708b660e3fe6776129c2956b041 upstream.
__device_release_driver() has to check dev->bus->need_parent_lock
before dropping the parent lock and acquiring it again as it may
attempt to drop a lock that hasn't been acquired or lock a device
that shouldn't be locked and create a lock imbalance.
Fixes: 8c97a46af04b (driver core: hold dev's parent lock when needed)
Reviewed-by: Daniel Vetter <daniel.vetter@ffwll.ch>
commit 81b1e6e6a8590a19257e37a1633bec098d499c57 upstream.
Since the addition of platform MSI support, there were two helpers
supposed to allocate/free IRQs for a device:
platform_msi_domain_alloc_irqs()
platform_msi_domain_free_irqs()
In these helpers, IRQ descriptors are allocated in the "alloc" routine
while they are freed in the "free" one.
Later, two other helpers have been added to handle IRQ domains on top
of MSI domains:
platform_msi_domain_alloc()
platform_msi_domain_free()
Seen from the outside, the logic is pretty close with the former
helpers and people used it with the same logic as before: a
platform_msi_domain_alloc() call should be balanced with a
platform_msi_domain_free() call. While this is probably what was
intended to do, the platform_msi_domain_free() does not remove/free
the IRQ descriptor(s) created/inserted in
platform_msi_domain_alloc().
One effect of such situation is that removing a module that requested
an IRQ will let one orphaned IRQ descriptor (with an allocated MSI
entry) in the device descriptors list. Next time the module will be
inserted back, one will observe that the allocation will happen twice
in the MSI domain, one time for the remaining descriptor, one time for
the new one. It also has the side effect to quickly overshoot the
maximum number of allocated MSI and then prevent any module requesting
an interrupt in the same domain to be inserted anymore.
This situation has been met with loops of insertion/removal of the
mvpp2.ko module (requesting 15 MSIs each time).
Fixes: 552c494a7666 ("platform-msi: Allow creation of a MSI-based stacked irq domain")
Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc
I wrote:
"Char/Misc fixes for 4.19-rc7
Here are 8 small fixes for some char/misc driver issues
Included here are:
- fpga driver fixes
- thunderbolt bugfixes
- firmware core revert/fix
- hv core fix
- hv tool fix
All of these have been in linux-next with no reported issues."
* tag 'char-misc-4.19-rc7' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc:
thunderbolt: Initialize after IOMMUs
thunderbolt: Do not handle ICM events after domain is stopped
firmware: Always initialize the fw_priv list object
docs: fpga: document fpga manager flags
fpga: bridge: fix obvious function documentation error
tools: hv: fcopy: set 'error' in case an unknown operation was requested
fpga: do not access region struct after fpga_region_unregister
Drivers: hv: vmbus: Use get/put_cpu() in vmbus_connect()
If __device_suspend() runs asynchronously (in which case the device
passed to it is in dpm_suspended_list at that point) and it returns
early on an error or pending wakeup, and the power.direct_complete
flag has been set for the device already, the subsequent
device_resume() will be confused by that and it will call
pm_runtime_enable() incorrectly, as runtime PM has not been
disabled for the device by __device_suspend().
To avoid that, clear power.direct_complete if __device_suspend()
is not going to disable runtime PM for the device before returning.
Fixes: aae4518b3124 (PM / sleep: Mechanism to avoid resuming runtime-suspended devices unnecessarily)
Reported-by: Al Cooper <alcooperx@gmail.com>
Tested-by: Al Cooper <alcooperx@gmail.com>
Cc: 3.16+ <stable@vger.kernel.org> # 3.16+
When freeing the fw_priv the item is taken off the list. This causes an
oops in the FW_OPT_NOCACHE case as the list object is not initialized.
Make sure to initialize the list object regardless of this flag.
Fixes: 422b3db2a503 ("firmware: Fix security issue with request_firmware_into_buf()")
Cc: Rishabh Bhatnagar <rishabhb@codeaurora.org>
Signed-off-by: Bjorn Andersson <bjorn.andersson@linaro.org>
When calling request_firmware_into_buf() with the FW_OPT_NOCACHE flag
it is expected that firmware is loaded into buffer from memory.
But inside alloc_lookup_fw_priv every new firmware that is loaded is
added to the firmware cache (fwc) list head. So if any driver requests
a firmware that is already loaded the code iterates over the above
mentioned list and it can end up giving a pointer to other device driver's
firmware buffer.
Also the existing copy may either be modified by drivers, remote processors
or even freed. This causes a potential security issue with batched requests
when using request_firmware_into_buf.
Fix alloc_lookup_fw_priv to not add to the fwc head list if FW_OPT_NOCACHE
is set, and also don't do the lookup in the list.
Fixes: 0e742e9275 ("firmware: provide infrastructure to make fw caching optional")
[mcgrof: broken since feature introduction on v4.8]
Cc: stable@vger.kernel.org # v4.8+
Signed-off-by: Vikram Mulukutla <markivx@codeaurora.org>
Signed-off-by: Rishabh Bhatnagar <rishabhb@codeaurora.org>
Signed-off-by: Luis Chamberlain <mcgrof@kernel.org>
Within show_valid_zones() the function test_pages_in_a_zone() should be
called for online memory blocks only.
Otherwise it might lead to the VM_BUG_ON due to uninitialized struct
pages (when CONFIG_DEBUG_VM_PGFLAGS kernel option is set):
page dumped because: VM_BUG_ON_PAGE(PagePoisoned(p))
Call Trace:
([<000000000038f91e>] test_pages_in_a_zone+0xe6/0x168)
[<0000000000923472>] show_valid_zones+0x5a/0x1a8
[<0000000000900284>] dev_attr_show+0x3c/0x78
[<000000000046f6f0>] sysfs_kf_seq_show+0xd0/0x150
[<00000000003ef662>] seq_read+0x212/0x4b8
[<00000000003bf202>] __vfs_read+0x3a/0x178
[<00000000003bf3ca>] vfs_read+0x8a/0x148
[<00000000003bfa3a>] ksys_read+0x62/0xb8
[<0000000000bc2220>] system_call+0xdc/0x2d8
That VM_BUG_ON was triggered by the page poisoning introduced in
mm/sparse.c with the git commit d0dc12e86b31 ("mm/memory_hotplug:
optimize memory hotplug").
With the same commit the new 'nid' field has been added to the struct
memory_block in order to store and later on derive the node id for
offline pages (instead of accessing struct page which might be
uninitialized). But one reference to nid in show_valid_zones() function
has been overlooked. Fixed with current commit. Also, nr_pages will
not be used any more after test_pages_in_a_zone() call, do not update
it.
Link: http://lkml.kernel.org/r/20180828090539.41491-1-zaslonko@linux.ibm.com
Fixes: d0dc12e86b31 ("mm/memory_hotplug: optimize memory hotplug")
Signed-off-by: Mikhail Zaslonko <zaslonko@linux.ibm.com>
Reviewed-by: Pavel Tatashin <pavel.tatashin@microsoft.com>
Cc: <stable@vger.kernel.org> [4.17+]
"count" needs to be signed for the error handling to work. I made "i"
signed as well so they match.
Fixes: 02113ba93ea4 (PM / clk: Add support for obtaining clocks from device-tree)
Cc: 4.6+ <stable@vger.kernel.org> # 4.6+
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core
Pull driver core updates from Greg KH:
"Here are all of the driver core and related patches for 4.19-rc1.
Nothing huge here, just a number of small cleanups and the ability to
now stop the deferred probing after init happens.
All of these have been in linux-next for a while with only a merge
issue reported"
* tag 'driver-core-4.19-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (21 commits)
base: core: Remove WARN_ON from link dependencies check
drivers/base: stop new probing during shutdown
drivers: core: Remove glue dirs from sysfs earlier
driver core: remove unnecessary function extern declare
sysfs.h: fix non-kernel-doc comment
PM / Domains: Stop deferring probe at the end of initcall
iommu: Remove IOMMU_OF_DECLARE
iommu: Stop deferring probe at end of initcalls
pinctrl: Support stopping deferred probe after initcalls
dt-bindings: pinctrl: add a 'pinctrl-use-default' property
driver core: allow stopping deferred probe after init
driver core: add a debugfs entry to show deferred devices
sysfs: Fix internal_create_group() for named group updates
base: fix order of OF initialization
linux/device.h: fix kernel-doc notation warning
Documentation: update firmware loader fallback reference
kobject: Replace strncpy with memcpy
kernfs: Replace strncpy with memcpy
device: Add #define dev_fmt similar to #define pr_fmt
Some architectures do not define certain PAGE_KERNEL_* flags, this is
either because:
a) The way to implement some of these flags is *not yet ported*, or
b) The architecture *has no way* to describe them
Over time we have accumulated a few PAGE_KERNEL_* fallback workarounds
for architectures in the kernel which do not define them using
*relatively safe* equivalents. Move these scattered fallback hacks into
asm-generic.
We start off with PAGE_KERNEL_RO using PAGE_KERNEL as a fallback. This
has been in place on the firmware loader for years. Move the fallback
into the respective asm-generic header.
Link: http://lkml.kernel.org/r/20180510185507.2439-2-mcgrof@kernel.org
Signed-off-by: Luis R. Rodriguez <mcgrof@kernel.org>
Reviewed-by: Andrew Morton <akpm@linux-foundation.org>
Cc: Matthew Wilcox <willy@infradead.org>
Callers of register_mem_sect_under_node() are always passing a valid
memory_block (not NULL), so we can safely drop the check for NULL.
In the same way, register_mem_sect_under_node() is only called in case
the node is online, so we can safely remove that check as well.
Link: http://lkml.kernel.org/r/20180622111839.10071-5-osalvador@techadventures.net
Signed-off-by: Oscar Salvador <osalvador@suse.de>
Reviewed-by: Pavel Tatashin <pasha.tatashin@oracle.com>
Tested-by: Reza Arbab <arbab@linux.vnet.ibm.com>
Tested-by: Jonathan Cameron <Jonathan.Cameron@huawei.com>
Cc: Pasha Tatashin <Pavel.Tatashin@microsoft.com>
Cc: Michal Hocko <mhocko@suse.com>
walk_memory_range()
link_mem_sections() and walk_memory_range() share most of the code, so
we can use convert link_mem_sections() into a dummy function that calls
walk_memory_range() with a callback to register_mem_sect_under_node().
This patch converts register_mem_sect_under_node() in order to match a
walk_memory_range's callback, getting rid of the check_nid argument and
checking instead if the system is still boothing, since we only have to
check for the nid if the system is in such state.
Link: http://lkml.kernel.org/r/20180622111839.10071-4-osalvador@techadventures.net
Suggested-by: Pavel Tatashin <pasha.tatashin@oracle.com>
When hotplugging memory, it is possible that two calls are being made to
One comes from __add_section()->hotplug_memory_register() and the other
from add_memory_resource()->link_mem_sections() if we had to register a
new node.
In case we had to register a new node, hotplug_memory_register() will
only handle/allocate the memory_block's since
register_mem_sect_under_node() will return right away because the node
it is not online yet.
I think it is better if we leave hotplug_memory_register() to
handle/allocate only memory_block's and make link_mem_sections() to call
So this patch removes the call to register_mem_sect_under_node() from
hotplug_memory_register(), and moves the call to link_mem_sections() out
of the condition, so it will always be called. In this way we only have
one place where the memory sections are registered.
Link: http://lkml.kernel.org/r/20180622111839.10071-3-osalvador@techadventures.net
Pull networking updates from David Miller:
"Highlights:
- Gustavo A. R. Silva keeps working on the implicit switch fallthru
changes.
- Support 802.11ax High-Efficiency wireless in cfg80211 et al, From
Luca Coelho.
- Re-enable ASPM in r8169, from Kai-Heng Feng.
- Add virtual XFRM interfaces, which avoids all of the limitations of
existing IPSEC tunnels. From Steffen Klassert.
- Convert GRO over to use a hash table, so that when we have many
flows active we don't traverse a long list during accumluation.
- Many new self tests for routing, TC, tunnels, etc. Too many
contributors to mention them all, but I'm really happy to keep
seeing this stuff.
- Hardware timestamping support for dpaa_eth/fsl-fman from Yangbo Lu.
- Lots of cleanups and fixes in L2TP code from Guillaume Nault.
- Add IPSEC offload support to netdevsim, from Shannon Nelson.
- Add support for slotting with non-uniform distribution to netem
packet scheduler, from Yousuk Seung.
- Add UDP GSO support to mlx5e, from Boris Pismenny.
- Support offloading of Team LAG in NFP, from John Hurley.
- Allow to configure TX queue selection based upon RX queue, from
Amritha Nambiar.
- Support ethtool ring size configuration in aquantia, from Anton
Mikaev.
- Support DSCP and flowlabel per-transport in SCTP, from Xin Long.
- Support list based batching and stack traversal of SKBs, this is
very exciting work. From Edward Cree.
- Busyloop optimizations in vhost_net, from Toshiaki Makita.
- Introduce the ETF qdisc, which allows time based transmissions. IGB
can offload this in hardware. From Vinicius Costa Gomes.
- Add parameter support to devlink, from Moshe Shemesh.
- Several multiplication and division optimizations for BPF JIT in
nfp driver, from Jiong Wang.
- Lots of prepatory work to make more of the packet scheduler layer
lockless, when possible, from Vlad Buslov.
- Add ACK filter and NAT awareness to sch_cake packet scheduler, from
Toke Høiland-Jørgensen.
- Support regions and region snapshots in devlink, from Alex Vesker.
- Allow to attach XDP programs to both HW and SW at the same time on
a given device, with initial support in nfp. From Jakub Kicinski.
- Add TLS RX offload and support in mlx5, from Ilya Lesokhin.
- Use PHYLIB in r8169 driver, from Heiner Kallweit.
- All sorts of changes to support Spectrum 2 in mlxsw driver, from
Ido Schimmel.
- PTP support in mv88e6xxx DSA driver, from Andrew Lunn.
- Make TCP_USER_TIMEOUT socket option more accurate, from Jon
Maxwell.
- Support for templates in packet scheduler classifier, from Jiri
Pirko.
- IPV6 support in RDS, from Ka-Cheong Poon.
- Native tproxy support in nf_tables, from Máté Eckl.
- Maintain IP fragment queue in an rbtree, but optimize properly for
in-order frags. From Peter Oskolkov.
- Improvde handling of ACKs on hole repairs, from Yuchung Cheng"
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1996 commits)
bpf: test: fix spelling mistake "REUSEEPORT" -> "REUSEPORT"
hv/netvsc: Fix NULL dereference at single queue mode fallback
net: filter: mark expected switch fall-through
xen-netfront: fix warn message as irq device name has '/'
cxgb4: Add new T5 PCI device ids 0x50af and 0x50b0
net: dsa: mv88e6xxx: missing unlock on error path
rds: fix building with IPV6=m
inet/connection_sock: prefer _THIS_IP_ to current_text_addr
net: dsa: mv88e6xxx: bitwise vs logical bug
net: sock_diag: Fix spectre v1 gadget in __sock_diag_cmd()
ieee802154: hwsim: using right kind of iteration
net: hns3: Add vlan filter setting by ethtool command -K
net: hns3: Set tx ring' tc info when netdev is up
net: hns3: Remove tx ring BD len register in hns3_enet
net: hns3: Fix desc num set to default when setting channel
net: hns3: Fix for phy link issue when using marvell phy driver
net: hns3: Fix for information of phydev lost problem when down/up
net: hns3: Fix for command format parsing error in hclge_is_all_function_id_zero
net: hns3: Add support for serdes loopback selftest
bnxt_en: take coredump_record structure off stack
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security
Pull security subsystem updates from James Morris:
- kstrdup() return value fix from Eric Biggers
- Add new security_load_data hook to differentiate security checking of
kernel-loaded binaries in the case of there being no associated file
descriptor, from Mimi Zohar.
- Add ability to IMA to specify a policy at build-time, rather than
just via command line params or by loading a custom policy, from
Mimi.
- Allow IMA and LSMs to prevent sysfs firmware load fallback (e.g. if
using signed firmware), from Mimi.
- Allow IMA to deny loading of kexec kernel images, as they cannot be
measured by IMA, from Mimi.
* 'next-general' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security:
security: check for kstrdup() failure in lsm_append()
security: export security_kernel_load_data function
ima: based on policy warn about loading firmware (pre-allocated buffer)
module: replace the existing LSM hook in init_module
ima: add build time policy
ima: based on policy require signed firmware (sysfs fallback)
firmware: add call to LSM hook before firmware sysfs fallback
ima: based on policy require signed kexec kernel images
kexec: add call to LSM hook in original kexec_load syscall
security: define new LSM hook named security_kernel_load_data
MAINTAINERS: remove the outdated "LINUX SECURITY MODULE (LSM) FRAMEWORK" entry
Pull power management updates from Rafael Wysocki:
"These add a new framework for CPU idle time injection, to be used by
all of the idle injection code in the kernel in the future, fix some
issues and add a number of relatively small extensions in multiple
places.
Specifics:
- Add a new framework for CPU idle time injection (Daniel Lezcano).
- Add AVS support to the armada-37xx cpufreq driver (Gregory
CLEMENT).
- Add support for current CPU frequency reporting to the ACPI CPPC
cpufreq driver (George Cherian).
- Rework the cooling device registration in the imx6q/thermal driver
(Bastian Stender).
- Make the pcc-cpufreq driver refuse to work with dynamic scaling
governors on systems with many CPUs to avoid scalability issues
with it (Rafael Wysocki).
- Fix the intel_pstate driver to report different maximum CPU
frequencies on systems where they really are different and to
ignore the turbo active ratio if hardware-managend P-states (HWP)
are in use; make it use the match_string() helper (Xie Yisheng,
Srinivas Pandruvada).
- Fix a minor deferred probe issue in the qcom-kryo cpufreq driver
(Niklas Cassel).
- Add a tracepoint for the tracking of frequency limits changes (from
Andriod) to the cpufreq core (Ruchi Kandoi).
- Fix a circular lock dependency between CPU hotplug and sysfs
locking in the cpufreq core reported by lockdep (Waiman Long).
- Avoid excessive error reports on driver registration failures in
the ARM cpuidle driver (Sudeep Holla).
- Add a new device links flag to the driver core to make links go
away automatically on supplier driver removal (Vivek Gautam).
- Eliminate potential race condition between system-wide power
management transitions and system shutdown (Pingfan Liu).
- Add a quirk to save NVS memory on system suspend for the ASUS 1025C
laptop (Willy Tarreau).
- Make more systems use suspend-to-idle (instead of ACPI S3) by
default (Tristian Celestin).
- Get rid of stack VLA usage in the low-level hibernation code on
64-bit x86 (Kees Cook).
- Fix error handling in the hibernation core and mark an expected
fall-through switch in it (Chengguang Xu, Gustavo Silva).
- Extend the generic power domains (genpd) framework to support
attaching a device to a power domain by name (Ulf Hansson).
- Fix device reference counting and user limits initialization in the
devfreq core (Arvind Yadav, Matthias Kaehlcke).
- Fix a few issues in the rk3399_dmc devfreq driver and improve its
documentation (Enric Balletbo i Serra, Lin Huang, Nick Milner).
- Drop a redundant error message from the exynos-ppmu devfreq driver
(Markus Elfring)"
* tag 'pm-4.19-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (35 commits)
PM / reboot: Eliminate race between reboot and suspend
PM / hibernate: Mark expected switch fall-through
cpufreq: intel_pstate: Ignore turbo active ratio in HWP
cpufreq: Fix a circular lock dependency problem
cpu/hotplug: Add a cpus_read_trylock() function
x86/power/hibernate_64: Remove VLA usage
cpufreq: trace frequency limits change
cpufreq: intel_pstate: Show different max frequency with turbo 3 and HWP
cpufreq: pcc-cpufreq: Disable dynamic scaling on many-CPU systems
cpufreq: qcom-kryo: Silently error out on EPROBE_DEFER
cpufreq / CPPC: Add cpuinfo_cur_freq support for CPPC
cpufreq: armada-37xx: Add AVS support
dt-bindings: marvell: Add documentation for the Armada 3700 AVS binding
PM / devfreq: rk3399_dmc: Fix duplicated opp table on reload.
PM / devfreq: Init user limits from OPP limits, not viceversa
PM / devfreq: rk3399_dmc: fix spelling mistakes.
PM / devfreq: rk3399_dmc: do not print error when get supply and clk defer.
dt-bindings: devfreq: rk3399_dmc: move interrupts to be optional.
PM / devfreq: rk3399_dmc: remove wait for dcf irq event.
dt-bindings: clock: add rk3399 DDR3 standard speed bins.
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regulator
Pull regulator updates from Mark Brown:
"The biggest set of changes in here is the addition of the Qualcomm
RPMH driver. As well as the regualtor driver itself being quite large
due to the usual involved Qualcomm regulator stuff there's also some
code shared with the arm-soc tree, a bus driver required to
communicate with the hardware that actually winds up being much larger
than the regulator driver itself and a LLCC driver that was part of
the same signed tag used with the arm-soc tree.
Other than that it's a fairly standard and quiet release, highlights
include:
- Addition of device links from regulator consumers to their
regulators, helping the core avoid dependency issues during
suspend.
- Support for the entertainingly innovative suspend implementation in
the BD9571MWV.
- Support for switch regulators on the PFUZE100, this required two
goes due to backwards compatibility issues with old DTs that were
discovered.
- Support for Freescale PFUZE3001 and SocioNext UniPhier.
- The aforementioned Qualcomm RPMH driver together with the driver
changes required to support it"
* tag 'regulator-v4.19' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regulator: (52 commits)
regulator: add QCOM RPMh regulator driver
regulator: dt-bindings: add QCOM RPMh regulator bindings
regulator: samsung: Add SPDX license identifiers
regulator: maxim: Add SPDX license identifiers
regulator: bd71837: adobt MFD changes to regulator driver
regulator: tps65217: Fix NULL pointer dereference on probe
regulator: Add support for CPCAP regulators on Motorola Xoom devices.
regulator: Add sw2_sw4 voltage table to cpcap regulator.
regulator: bd9571mwv: Make symbol 'dev_attr_backup_mode' static
regulator: pfuze100: add support to en-/disable switch regulators
regulator: pfuze100: add optional disable switch-regulators binding
soc: qcom: rmtfs-mem: fix memleak in probe error paths
soc: qcom: llc-slice: Add missing MODULE_LICENSE()
drivers: qcom: rpmh: fix unwanted error check for get_tcs_of_type()
drivers: qcom: rpmh-rsc: fix the loop index check in get_req_from_tcs
firmware: qcom: scm: add a dummy qcom_scm_assign_mem()
drivers: qcom: rpmh-rsc: Check cmd_db_ready() to help children
drivers: qcom: rpmh-rsc: allow active requests from wake TCS
drivers: qcom: rpmh: add support for batch RPMH request
drivers: qcom: rpmh: allow requests to be sent asynchronously
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regmap
Pull regmap updates from Mark Brown:
"Several small new features for regmap this time around:
- Support for SCCB, an I2C variant used on some media cards. This has
also pulled in an I2C commit from Peter Rosin as a dependency.
- Addition of an API for reading repeatedly from registers where the
address doesn't automatically increment like some ADC outputs or
GPIO status registers.
- Support for bulk I/O on Slimbus"
* tag 'regmap-v4.19' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regmap:
regmap: Add regmap_noinc_read API
regmap: sccb: fix typo and sort headers alphabetically
i2c: smbus: add unlocked __i2c_smbus_xfer variant
regmap: add SCCB support
regmap: slimbus: add support to multi read/write
Merge changes in the PM core, system-wide PM infrastructure, generic
power domains (genpd) framework, ACPI PM infrastructure and cpuidle
for 4.19.
* pm-core:
driver core: Add flag to autoremove device link on supplier unbind
driver core: Rename flag AUTOREMOVE to AUTOREMOVE_CONSUMER
* pm-domains:
PM / Domains: Introduce dev_pm_domain_attach_by_name()
PM / Domains: Introduce option to attach a device by name to genpd
PM / Domains: dt: Add a power-domain-names property
* pm-sleep:
PM / hibernate: cast PAGE_SIZE to int when comparing with error code
* acpi-pm:
ACPI / PM: save NVS memory for ASUS 1025C laptop
ACPI / PM: Default to s2idle in all machines supporting LP S0
* pm-cpuidle:
ARM: cpuidle: silence error on driver registration failure
regmap: Support non-incrementing registers
Some devices have individual registers that don't autoincrement the
register address during bulk reads but instead repeatedly read the same
value, for example for monitoring GPIOs or ADCs. Add support for these.
The regmap API usually assumes that bulk read operations will read a
range of registers but some I2C/SPI devices have certain registers for
which a such a read operation will return data from an internal FIFO
instead. Add an explicit API to support bulk read without range semantics.
Some linux drivers use regmap_bulk_read or regmap_raw_read for such
registers, for example mpu6050 or bmi150 from IIO. This only happens to
work because when caching is disabled a single regmap read op will map
to a single bus read op (as desired). This breaks if caching is enabled and
reg+1 happens to be a cacheable register.
Without regmap support refactoring a driver to enable regmap caching
requires separate I2C and SPI paths. This is exactly what regmap is
supposed to help avoid.
Suggested-by: Jonathan Cameron <jic23@kernel.org>
Signed-off-by: Crestez Dan Leonard <leonard.crestez@intel.com>
Signed-off-by: Stefan Popa <stefan.popa@analog.com>
Signed-off-by: Mark Brown <broonie@kernel.org>
The BTF conflicts were simple overlapping changes.
The virtio_net conflict was an overlap of a fix of statistics counter,
happening alongisde a move over to a bonafide statistics structure
rather than counting value on the stack.
We need the driver core changes in here as well for testing.
Pull driver core fix from Greg KH:
"This is a single driver core fix for 4.18-rc7. It partially reverts a
previous commit to resolve some reported issues.
It has been in linux-next for a while now with no reported issues"
* tag 'driver-core-4.18-rc7' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core:
driver core: Partially revert "driver core: correct device's shutdown order"
Fix typos 's/wit/with/' in the comments and sort headers alphabetically
in order to avoid duplicate includes in future.
Fixes: bcf7eac3d97f ("regmap: add SCCB support")
Reported-by: Wolfram Sang <wsa+renesas@sang-engineering.com>
Reviewed-by: Wolfram Sang <wsa+renesas@sang-engineering.com>
git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux into regmap-4.19 for sccb dependency
In some cases the link between between customer and supplier
already exist, for example when a device use its parent as a supplier.
Do not warn about already existing dependencies because device_link_add()
takes care of this case.
Link: http://lkml.kernel.org/r/20180709111753eucas1p1f32e66fb2f7ea3216097cd72a132355d~-rzycA5Rg0378203782eucas1p1C@eucas1p1.samsung.com
Reported-by: Marek Szyprowski <m.szyprowski@samsung.com>
Reviewed-by: Mark Brown <broonie@kernel.org>
Signed-off-by: Benjamin Gaignard <benjamin.gaignard@st.com>
Reviewed-by: Rafael J. Wysocki <rafael@kernel.org>
There is a race window in device_shutdown(), which may cause
-1. parent device shut down before child or
-2. no shutdown on a new probing device.
For 1st, taking the following scenario:
device_shutdown new plugin device
list_del_init(parent_dev);
spin_unlock(list_lock);
device_add(child)
probe child
shutdown parent_dev
--> now child is on the tail of devices_kset
For 2nd, taking the following scenario:
device_add(dev)
device_lock(dev);
device_unlock(dev);
probe dev
--> now, the new occurred dev has no opportunity to shutdown
To fix this race issue, just prevent the new probing request. With this
logic, device_shutdown() is more similar to dpm_prepare().
Signed-off-by: Pingfan Liu <kernelfans@gmail.com>
Plumb in get_ownership() callback for devices belonging to a class so that
they can be created with uid/gid different from global root. This will
allow network devices in a container to belong to container's root and not
global root.
Reviewed-by: Tyler Hicks <tyhicks@canonical.com>
https://git.kernel.org/pub/scm/linux/kernel/git/broonie/regmap into regmap-4.19
regmap: Add support for SCCB
This is an I2C subset.
This adds Serial Camera Control Bus (SCCB) support for regmap API that
is intended to be used by some of Omnivision sensor drivers.
The ov772x and ov9650 drivers are going to use this SCCB regmap API.
The ov772x driver was previously only worked with the i2c controller
drivers that support I2C_FUNC_PROTOCOL_MANGLING, because the ov772x
device doesn't support repeated starts. After commit 0b964d183cbf
("media: ov772x: allow i2c controllers without
I2C_FUNC_PROTOCOL_MANGLING"), reading ov772x register is replaced with
issuing two separated i2c messages in order to avoid repeated start.
Using this SCCB regmap hides the implementation detail.
The ov9650 driver also issues two separated i2c messages to read the
registers as the device doesn't support repeated start. So it can
make use of this SCCB regmap.
Cc: Mark Brown <broonie@kernel.org>
Cc: Peter Rosin <peda@axentia.se>
Cc: Sebastian Reichel <sebastian.reichel@collabora.co.uk>
Cc: Wolfram Sang <wsa@the-dreams.de>
Cc: Sylwester Nawrocki <s.nawrocki@samsung.com>
Cc: Jacopo Mondi <jacopo+renesas@jmondi.org>
Cc: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Cc: Hans Verkuil <hans.verkuil@cisco.com>
Cc: Sakari Ailus <sakari.ailus@linux.intel.com>
Cc: Mauro Carvalho Chehab <mchehab@s-opensource.com>
Add an LSM hook prior to allowing firmware sysfs fallback loading.
Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
Acked-by: Luis R. Rodriguez <mcgrof@kernel.org>
Signed-off-by: James Morris <james.morris@microsoft.com>
For devices with a class, we create a "glue" directory between
the parent device and the new device with the class name.
This directory is never "explicitely" removed when empty however,
this is left to the implicit sysfs removal done by kobject_release()
when the object loses its last reference via kobject_put().
This is problematic because as long as it's not been removed from
sysfs, it is still present in the class kset and in sysfs directory
structure.
The presence in the class kset exposes a use after free bug fixed
by the previous patch, but the presence in sysfs means that until
the kobject is released, which can take a while (especially with
kobject debugging), any attempt at re-creating such as binding a
new device for that class/parent pair, will result in a sysfs
duplicate file name error.
This fixes it by instead doing an explicit kobject_del() when
the glue dir is empty, by keeping track of the number of
child devices of the gluedir.
This is made easy by the fact that all glue dir operations are
done with a global mutex, and there's already a function
(cleanup_glue_dir) called in all the right places taking that
mutex that can be enhanced for this. It appears that this was
in fact the intent of the function, but the implementation was
wrong.
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
device_private_init is called only in core.c, extern declare is
unnecessary and make it static.
Cc: "Rafael J. Wysocki" <rafael@kernel.org>
Signed-off-by: Shaokun Zhang <zhangshaokun@hisilicon.com>
SLIMbus supports upto 16 bytes in value management messages,
so add support to read/writes upto 16 bytes.
This also removes redundant single register reg_read/reg_write.
Also useful for paged register access on SLIMbus interfaced codecs.
Signed-off-by: Srinivas Kandagatla <srinivas.kandagatla@linaro.org>
