path: root/drivers/base
2011-04-26PM / Wakeup: Fix initialization of wakeup-related device sysfs filesRafael J. Wysocki
It turns out that some PCI devices are only found to be wakeup-capable during registration, in which case, when device_set_wakeup_capable() is called, device_is_registered() already returns 'true' for the given device, but dpm_sysfs_add() hasn't been called for it yet. This leads to situations in which the device's power.can_wakeup flag is not set as requested because of failing wakeup_sysfs_add() and its wakeup-related sysfs files are not created, although they should be present. This is a post-2.6.38 regression introduced by commit cb8f51bdadb7969139c2e39c2defd4cde98c1 (PM: Do not create wakeup sysfs files for devices that cannot wake up). To work around this problem initialize the device's power.entry field to an empty list head and make device_set_wakeup_capable() check if it is still empty before attempting to add the devices wakeup-related sysfs files with wakeup_sysfs_add(). Namely, if power.entry is still empty at this point, device_pm_add() hasn't been called yet for the device and its wakeup-related files will be created later, so device_set_wakeup_capable() doesn't have to create them. Reported-and-tested-by: Tino Keitel <tino.keitel@tikei.de> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-04-20PM: Add missing syscore_suspend() and syscore_resume() callsRafael J. Wysocki
Device suspend/resume infrastructure is used not only by the suspend and hibernate code in kernel/power, but also by APM, Xen and the kexec jump feature. However, commit 40dc166cb5dddbd36aa4ad11c03915ea (PM / Core: Introduce struct syscore_ops for core subsystems PM) failed to add syscore_suspend() and syscore_resume() calls to that code, which generally leads to breakage when the features in question are used. To fix this problem, add the missing syscore_suspend() and syscore_resume() calls to arch/x86/kernel/apm_32.c, kernel/kexec.c and drivers/xen/manage.c. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Acked-by: Ian Campbell <ian.campbell@citrix.com>
2011-04-12Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6: fix XEN_SAVE_RESTORE Kconfig dependencies PM / Hibernate: Introduce CONFIG_HIBERNATE_CALLBACKS
2011-04-12mfd: Fetch cell pointer from platform_device->mfd_cellSamuel Ortiz
In order for MFD drivers to fetch their cell pointer but also their platform data one, an mfd cell pointer is added to the platform_device structure. That allows all MFD sub devices drivers to be MFD agnostic, unless they really need to access their MFD cell data. Most of them don't, especially the ones for IPs used by both MFD and non MFD SoCs. Cc: Grant Likely <grant.likely@secretlab.ca> Acked-by: Greg KH <gregkh@suse.de> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2011-04-11PM / Hibernate: Introduce CONFIG_HIBERNATE_CALLBACKSRafael J. Wysocki
Xen save/restore is going to use hibernate device callbacks for quiescing devices and putting them back to normal operations and it would need to select CONFIG_HIBERNATION for this purpose. However, that also would cause the hibernate interfaces for user space to be enabled, which might confuse user space, because the Xen kernels don't support hibernation. Moreover, it would be wasteful, as it would make the Xen kernels include a substantial amount of code that they would never use. To address this issue introduce new power management Kconfig option CONFIG_HIBERNATE_CALLBACKS, such that it will only select the code that is necessary for the hibernate device callbacks to work and make CONFIG_HIBERNATION select it. Then, Xen save/restore will be able to select CONFIG_HIBERNATE_CALLBACKS without dragging the entire hibernate code along with it. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Tested-by: Shriram Rajagopalan <rshriram@cs.ubc.ca>
2011-03-23Introduce ARCH_NO_SYSDEV_OPS config option (v2)Rafael J. Wysocki
Introduce Kconfig option allowing architectures where sysdev operations used during system suspend, resume and shutdown have been completely replaced with struct sycore_ops operations to avoid building sysdev code that will never be used. Make callbacks in struct sys_device and struct sysdev_driver depend on ARCH_NO_SYSDEV_OPS to allows us to verify if all of the references have been actually removed from the code the given architecture depends on. Make x86 select ARCH_NO_SYSDEV_OPS. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2011-03-16Merge branch 'driver-core-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6 * 'driver-core-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6: (50 commits) printk: do not mangle valid userspace syslog prefixes efivars: Add Documentation efivars: Expose efivars functionality to external drivers. efivars: Parameterize operations. efivars: Split out variable registration efivars: parameterize efivars efivars: Make efivars bin_attributes dynamic efivars: move efivars globals into struct efivars drivers:misc: ti-st: fix debugging code kref: Fix typo in kref documentation UIO: add PRUSS UIO driver support Fix spelling mistakes in Documentation/zh_CN/SubmittingPatches firmware: Fix unaligned memory accesses in dmi-sysfs firmware: Add documentation for /sys/firmware/dmi firmware: Expose DMI type 15 System Event Log firmware: Break out system_event_log in dmi-sysfs firmware: Basic dmi-sysfs support firmware: Add DMI entry types to the headers Driver core: convert platform_{get,set}_drvdata to static inline functions Translate linux-2.6/Documentation/magic-number.txt into Chinese ...
2011-03-15PM / Core: Introduce struct syscore_ops for core subsystems PMRafael J. Wysocki
Some subsystems need to carry out suspend/resume and shutdown operations with one CPU on-line and interrupts disabled. The only way to register such operations is to define a sysdev class and a sysdev specifically for this purpose which is cumbersome and inefficient. Moreover, the arguments taken by sysdev suspend, resume and shutdown callbacks are practically never necessary. For this reason, introduce a simpler interface allowing subsystems to register operations to be executed very late during system suspend and shutdown and very early during resume in the form of strcut syscore_ops objects. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-03-15PM / OPP: opp_find_freq_exact() documentation fixNishanth Menon
opp_find_freq_exact() documentation has is_available instead of available. This also fixes warning with the kernel-doc: scripts/kernel-doc drivers/base/power/opp.c >/dev/null Warning(drivers/base/power/opp.c:246): No description found for parameter 'available' Warning(drivers/base/power/opp.c:246): Excess function parameter 'is_available' description in 'opp_find_freq_exact' Signed-off-by: Nishanth Menon <nm@ti.com> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2011-03-15PM: Make system-wide PM and runtime PM treat subsystems consistentlyRafael J. Wysocki
The code handling system-wide power transitions (eg. suspend-to-RAM) can in theory execute callbacks provided by the device's bus type, device type and class in each phase of the power transition. In turn, the runtime PM core code only calls one of those callbacks at a time, preferring bus type callbacks to device type or class callbacks and device type callbacks to class callbacks. It seems reasonable to make them both behave in the same way in that respect. Moreover, even though a device may belong to two subsystems (eg. bus type and device class) simultaneously, in practice power management callbacks for system-wide power transitions are always provided by only one of them (ie. if the bus type callbacks are defined, the device class ones are not and vice versa). Thus it is possible to modify the code handling system-wide power transitions so that it follows the core runtime PM code (ie. treats the subsystem callbacks as mutually exclusive). On the other hand, the core runtime PM code will choose to execute, for example, a runtime suspend callback provided by the device type even if the bus type's struct dev_pm_ops object exists, but the runtime_suspend pointer in it happens to be NULL. This is confusing, because it may lead to the execution of callbacks from different subsystems during different operations (eg. the bus type suspend callback may be executed during runtime suspend of the device, while the device type callback will be executed during system suspend). Make all of the power management code treat subsystem callbacks in a consistent way, such that: (1) If the device's type is defined (eg. dev->type is not NULL) and its pm pointer is not NULL, the callbacks from dev->type->pm will be used. (2) If dev->type is NULL or dev->type->pm is NULL, but the device's class is defined (eg. dev->class is not NULL) and its pm pointer is not NULL, the callbacks from dev->class->pm will be used. (3) If dev->type is NULL or dev->type->pm is NULL and dev->class is NULL or dev->class->pm is NULL, the callbacks from dev->bus->pm will be used provided that both dev->bus and dev->bus->pm are not NULL. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Kevin Hilman <khilman@ti.com> Reasoning-sounds-sane-to: Grant Likely <grant.likely@secretlab.ca> Acked-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-03-15PM: Add support for device power domainsRafael J. Wysocki
The platform bus type is often used to handle Systems-on-a-Chip (SoC) where all devices are represented by objects of type struct platform_device. In those cases the same "platform" device driver may be used with multiple different system configurations, but the actions needed to put the devices it handles into a low-power state and back into the full-power state may depend on the design of the given SoC. The driver, however, cannot possibly include all the information necessary for the power management of its device on all the systems it is used with. Moreover, the device hierarchy in its current form also is not suitable for representing this kind of information. The patch below attempts to address this problem by introducing objects of type struct dev_power_domain that can be used for representing power domains within a SoC. Every struct dev_power_domain object provides a sets of device power management callbacks that can be used to perform what's needed for device power management in addition to the operations carried out by the device's driver and subsystem. Namely, if a struct dev_power_domain object is pointed to by the pwr_domain field in a struct device, the callbacks provided by its ops member will be executed in addition to the corresponding callbacks provided by the device's subsystem and driver during all power transitions. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Tested-and-acked-by: Kevin Hilman <khilman@ti.com>
2011-03-15PM: Allow pm_runtime_suspend() to succeed during system suspendRafael J. Wysocki
The dpm_prepare() function increments the runtime PM reference counters of all devices to prevent pm_runtime_suspend() from executing subsystem-level callbacks. However, this was supposed to guard against a specific race condition that cannot happen, because the power management workqueue is freezable, so pm_runtime_suspend() can only be called synchronously during system suspend and we can rely on subsystems and device drivers to avoid doing that unnecessarily. Make dpm_prepare() drop the runtime PM reference to each device after making sure that runtime resume is not pending for it. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Kevin Hilman <khilman@ti.com>
2011-03-15PM: Remove CONFIG_PM_OPSRafael J. Wysocki
After redefining CONFIG_PM to depend on (CONFIG_PM_SLEEP || CONFIG_PM_RUNTIME) the CONFIG_PM_OPS option is redundant and can be replaced with CONFIG_PM. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2011-03-15PM: Do not create wakeup sysfs files for devices that cannot wake upRafael J. Wysocki
Currently, wakeup sysfs attributes are created for all devices, regardless of whether or not they are wakeup-capable. This is excessive and complicates wakeup device identification from user space (i.e. to identify wakeup-capable devices user space has to read /sys/devices/.../power/wakeup for all devices and see if they are not empty). Fix this issue by avoiding to create wakeup sysfs files for devices that cannot wake up the system from sleep states (i.e. whose power.can_wakeup flags are unset during registration) and modify device_set_wakeup_capable() so that it adds (or removes) the relevant sysfs attributes if a device's wakeup capability status is changed. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2011-03-15PM: Use appropriate printk() priority level in trace.cMandeep Singh Baines
printk()s without a priority level default to KERN_WARNING. To reduce noise at KERN_WARNING, this patch sets the priority level appriopriately for unleveled printks()s. This should be useful to folks that look at dmesg warnings closely. Changed these messages to pr_info(). Signed-off-by: Mandeep Singh Baines <msb@chromium.org> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2011-03-15PM / Wakeup: Don't update events_check_enabled in pm_get_wakeup_count()Rafael J. Wysocki
Since pm_save_wakeup_count() has just been changed to clear events_check_enabled unconditionally before checking if there are any new wakeup events registered since the last read from /sys/power/wakeup_count, the detection of wakeup events during suspend may be disabled, after it's been enabled, by writing a "wrong" value back to /sys/power/wakeup_count. For this reason, it is not necessary to update events_check_enabled in pm_get_wakeup_count() any more. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2011-03-15PM / Wakeup: Make pm_save_wakeup_count() work as documentedRafael J. Wysocki
According to Documentation/ABI/testing/sysfs-power, the /sys/power/wakeup_count interface should only make the kernel react to wakeup events during suspend if the last write to it has been successful. However, if /sys/power/wakeup_count is written to two times in a row, where the first write is successful and the second is not, the kernel will still react to wakeup events during suspend due to a bug in pm_save_wakeup_count(). Fix the bug by making pm_save_wakeup_count() clear events_check_enabled unconditionally before checking if there are any new wakeup events registered since the previous read from /sys/power/wakeup_count. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2011-03-15PM / Wakeup: Combine atomic counters to avoid reordering issuesRafael J. Wysocki
The memory barrier in wakeup_source_deactivate() is supposed to prevent the callers of pm_wakeup_pending() and pm_get_wakeup_count() from seeing the new value of events_in_progress (0, in particular) and the old value of event_count at the same time. However, if wakeup_source_deactivate() is executed by CPU0 and, for instance, pm_wakeup_pending() is executed by CPU1, where both processors can reorder operations, the memory barrier in wakeup_source_deactivate() doesn't affect CPU1 which can reorder reads. In that case CPU1 may very well decide to fetch event_count before it's modified and events_in_progress after it's been updated, so pm_wakeup_pending() may fail to detect a wakeup event. This issue can be addressed by using a single atomic variable to store both events_in_progress and event_count, so that they can be updated together in a single atomic operation. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2011-02-03driver core: Replace the dangerous to_root_device macro with an inline functionFerenc Wagner
The original macro worked only when applied to variables named 'dev'. While this could have been fixed by simply renaming the macro argument, a more type-safe replacement by an inline function is preferred. Signed-off-by: Ferenc Wagner <wferi@niif.hu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-03memory hotplug: sysfs probe routine should add all memory sectionsNathan Fontenot
As a follow-on to the recent patches I submitted that allowed for a sysfs memory block to span multiple memory sections, we should also update the probe routine to online all of the memory sections in a memory block. Without this patch the current code will only add a single memory section. I think the probe routine should add all of the memory sections in the specified memory block so that its behavior is in line with memory hotplug actions through the sysfs interfaces. This patch applies on top of the previous sysfs memory updates to allow a sysfs directory o span multiple memory sections. https://lkml.org/lkml/2011/1/20/245 Signed-off-by: Nathan Fontenot <nfont@austin.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-03memory hotplug: Update phys_index to [start|end]_section_nrNathan Fontenot
Update the 'phys_index' property of a the memory_block struct to be called start_section_nr, and add a end_section_nr property. The data tracked here is the same but the updated naming is more in line with what is stored here, namely the first and last section number that the memory block spans. The names presented to userspace remain the same, phys_index for start_section_nr and end_phys_index for end_section_nr, to avoid breaking anything in userspace. This also updates the node sysfs code to be aware of the new capability for a memory block to contain multiple memory sections and be aware of the memory block structure name changes (start_section_nr). This requires an additional parameter to unregister_mem_sect_under_nodes so that we know which memory section of the memory block to unregister. Signed-off-by: Nathan Fontenot <nfont@austin.ibm.com> Reviewed-by: Robin Holt <holt@sgi.com> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-03memory hotplug: Allow memory blocks to span multiple memory sectionsNathan Fontenot
Update the memory sysfs code such that each sysfs memory directory is now considered a memory block that can span multiple memory sections per memory block. The default size of each memory block is SECTION_SIZE_BITS to maintain the current behavior of having a single memory section per memory block (i.e. one sysfs directory per memory section). For architectures that want to have memory blocks span multiple memory sections they need only define their own memory_block_size_bytes() routine. Update the memory hotplug documentation to reflect the new behaviors of memory blocks reflected in sysfs. Signed-off-by: Nathan Fontenot <nfont@austin.ibm.com> Reviewed-by: Robin Holt <holt@sgi.com> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-03sysdev: Do not register with sysdev when erroring on addBorislav Petkov
When encountering an error while executing the driver's ->add method, we should cancel registration and unwind what we've regged so far. The low level ->add methods do return proper error codes but those aren't looked at in sysdev_driver_register(). Fix that by sharing the unregistering code. Signed-off-by: Borislav Petkov <borislav.petkov@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-03sysdev: Fixup warning messageBorislav Petkov
Use gcc's __func__ instead of the function name. Signed-off-by: Borislav Petkov <borislav.petkov@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-03firmware_classs: change val uevent's type to boolBob Liu
Some place in firmware_class.c using "int uevent" define, but others use "bool uevent". This patch replace all int uevent define to bool. Signed-off-by: Bob Liu <lliubbo@gmail.com> Acked-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-03driver-core: document restrictions on device_rename()Timur Tabi
Add text, courtesy of Kay Sievers, that provides some background on device_rename() and why it shouldn't be used. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-01-25PM / Runtime: Don't enable interrupts while running in_interruptAlan Stern
This patch (as1445) fixes a bug in the runtime PM core left over from the addition of the no_callbacks flag. If this flag is set then it is possible for rpm_suspend() to be called in_interrupt, so when releasing spinlocks it's important not to re-enable interrupts. To avoid an unnecessary save-and-restore of the interrupt flag, the patch also inlines a pm_request_idle() call. This fixes Bugzilla #27482. (The offending code was added in 2.6.37, so it's not necessary to apply this to any earlier stable kernels.) Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Reported-by: tim blechmann <tim@klingt.org> CC: <stable@kernel.org> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2011-01-20kconfig: rename CONFIG_EMBEDDED to CONFIG_EXPERTDavid Rientjes
The meaning of CONFIG_EMBEDDED has long since been obsoleted; the option is used to configure any non-standard kernel with a much larger scope than only small devices. This patch renames the option to CONFIG_EXPERT in init/Kconfig and fixes references to the option throughout the kernel. A new CONFIG_EMBEDDED option is added that automatically selects CONFIG_EXPERT when enabled and can be used in the future to isolate options that should only be considered for embedded systems (RISC architectures, SLOB, etc). Calling the option "EXPERT" more accurately represents its intention: only expert users who understand the impact of the configuration changes they are making should enable it. Reviewed-by: Ingo Molnar <mingo@elte.hu> Acked-by: David Woodhouse <david.woodhouse@intel.com> Signed-off-by: David Rientjes <rientjes@google.com> Cc: Greg KH <gregkh@suse.de> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jens Axboe <axboe@kernel.dk> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Robin Holt <holt@sgi.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13thp: transparent hugepage sysfs meminfoDavid Rientjes
Add hugepage statistics to per-node sysfs meminfo Reviewed-by: Rik van Riel <riel@redhat.com> Signed-off-by: David Rientjes <rientjes@google.com> Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits) Documentation/trace/events.txt: Remove obsolete sched_signal_send. writeback: fix global_dirty_limits comment runtime -> real-time ppc: fix comment typo singal -> signal drivers: fix comment typo diable -> disable. m68k: fix comment typo diable -> disable. wireless: comment typo fix diable -> disable. media: comment typo fix diable -> disable. remove doc for obsolete dynamic-printk kernel-parameter remove extraneous 'is' from Documentation/iostats.txt Fix spelling milisec -> ms in snd_ps3 module parameter description Fix spelling mistakes in comments Revert conflicting V4L changes i7core_edac: fix typos in comments mm/rmap.c: fix comment sound, ca0106: Fix assignment to 'channel'. hrtimer: fix a typo in comment init/Kconfig: fix typo anon_inodes: fix wrong function name in comment fix comment typos concerning "consistent" poll: fix a typo in comment ... Fix up trivial conflicts in: - drivers/net/wireless/iwlwifi/iwl-core.c (moved to iwl-legacy.c) - fs/ext4/ext4.h Also fix missed 'diabled' typo in drivers/net/bnx2x/bnx2x.h while at it.
2011-01-10Merge branch 'driver-core-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6 * 'driver-core-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6: driver core: Document that device_rename() is only for networking sysfs: remove useless test from sysfs_merge_group driver-core: merge private parts of class and bus driver core: fix whitespace in class_attr_string
2011-01-10Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid: (34 commits) HID: roccat: Update sysfs attribute doc HID: roccat: don't use #pragma pack HID: roccat: Add support for Roccat Kone[+] v2 HID: roccat: reduce number of functions in kone and pyra drivers HID: roccat: declare meaning of pack pragma usage in driver headers HID: roccat: use class for char device for sysfs attribute creation sysfs: Introducing binary attributes for struct class HID: hidraw: add compatibility ioctl() for 32-bit applications. HID: hid-picolcd: Fix memory leak in picolcd_debug_out_report() HID: picolcd: fix misuse of logical operation in place of bitop HID: usbhid: base runtime PM on modern API HID: replace offsets values with their corresponding BTN_* defines HID: hid-mosart: support suspend/resume HID: hid-mosart: ignore buttons report HID: hid-picolcd: don't use flush_scheduled_work() HID: simplify an index check in hid_lookup_collection HID: Hoist assigns from ifs HID: Remove superfluous __inline__ HID: Use vzalloc for vmalloc/memset(,0...) HID: Add and use hid_<level>: dev_<level> equivalents ...
2011-01-08sysfs: Introducing binary attributes for struct classStefan Achatz
Added dev_bin_attrs to struct class similar to existing dev_attrs. Signed-off-by: Stefan Achatz <erazor_de@users.sourceforge.net> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-12-24PM / Runtime: Generic resume shouldn't set RPM_ACTIVE unconditionallyRafael J. Wysocki
The __pm_generic_resume() function changes the given device's runtime PM status to RPM_ACTIVE if its driver's callback returns 0, but it only should do that if the rumtime PM is enabled for the device. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2010-12-24PM: Use dev_name() in core device suspend and resume routinesRafael J. Wysocki
Use dev_name() wherever applicable in drivers/base/power/main.c. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2010-12-24PM: Permit registration of parentless devices during system suspendRafael J. Wysocki
The registration of a new parentless device during system suspend will not lead to any complications affecting the PM core (the device will be effectively seen after the subsequent resume has completed), so remove the code used for detection of such events. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2010-12-24PM: Replace the device power.status field with a bit fieldRafael J. Wysocki
The device power.status field is too complicated for its purpose (storing the information about whether or not the device is in the "active" state from the PM core's point of view), so replace it with a bit field and modify all of its users accordingly. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2010-12-24PM: Remove redundant checks from core device resume routinesRafael J. Wysocki
Since a separate list of devices is used to link devices that have completed each stage of suspend (or resume), it is not necessary to check dev->power.status in the core device resume routines any more. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2010-12-24PM: Use a different list of devices for each stage of device suspendRafael J. Wysocki
Instead of keeping all devices in the same list during system suspend and resume, regardless of what suspend-resume callbacks have been executed for them already, use separate lists of devices that have had their ->prepare(), ->suspend() and ->suspend_noirq() callbacks executed. This will allow us to simplify the core device suspend and resume routines. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2010-12-24PM: Avoid compiler warning in pm_noirq_op()Rafael J. Wysocki
The compiler complains that calltime may be uninitialized in pm_noirq_op(), so add extra initialization for that variable to avoid the warning. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2010-12-24PM: Use pm_wakeup_pending() in __device_suspend()Rafael J. Wysocki
Before starting to suspend a device in __device_suspend() check if there's a request to abort the power transition and return -EBUSY in that case. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2010-12-24PM / Wakeup: Replace pm_check_wakeup_events() with pm_wakeup_pending()Rafael J. Wysocki
To avoid confusion with the meaning and return value of pm_check_wakeup_events() replace it with pm_wakeup_pending() that will work the other way around (ie. return true when system-wide power transition should be aborted). Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2010-12-24PM: Prevent dpm_prepare() from returning errors unnecessarilyRafael J. Wysocki
Currently dpm_prepare() returns error code if it finds that a device being suspended has a pending runtime resume request. However, it should not do that if the checking for wakeup events is not enabled. On the other hand, if the checking for wakeup events is enabled, it can return error when a wakeup event is detected, regardless of its source. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2010-12-24PM / Runtime: Add synchronous runtime interface for interrupt handlers (v3)Alan Stern
This patch (as1431c) makes the synchronous runtime-PM interface suitable for use in interrupt handlers. Subsystems can call the new pm_runtime_irq_safe() function to tell the PM core that a device's runtime_suspend and runtime_resume callbacks should be invoked with interrupts disabled and the spinlock held. This permits the pm_runtime_get_sync() and the new pm_runtime_put_sync_suspend() routines to be called from within interrupt handlers. When a device is declared irq-safe in this way, the PM core increments the parent's usage count, so the parent will never be runtime suspended. This prevents difficult situations in which an irq-safe device can't resume because it is forced to wait for its non-irq-safe parent. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2010-12-24PM / Runtime: Fix comments to match runtime callback codeAaro Koskinen
Commit 05aa55dddb9ee4045c320661068bea78dad6a6e5 changed routines to succeed if the driver handler is not defined. Comments were not updated. Signed-off-by: Aaro Koskinen <aaro.koskinen@nokia.com> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2010-12-22Merge branch 'master' into for-nextJiri Kosina
Conflicts: MAINTAINERS arch/arm/mach-omap2/pm24xx.c drivers/scsi/bfa/bfa_fcpim.c Needed to update to apply fixes for which the old branch was too outdated.
2010-11-29driver core: Document that device_rename() is only for networkingMichael Ellerman
Document that device_rename() is not to be used by anything other than the network core. Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-11-21Fix "forcably" comment typoRobert P. J. Day
Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-11-17driver-core: merge private parts of class and busKay Sievers
As classes and busses are pretty much the same thing, and we want to merge them together into a 'subsystem' in the future, let us share the same private data parts to make that merge easier. Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
