Rather than hard-lock the kernel, we now BUG() when a driver takes
> 3 seconds to suspend. If the underlying platform supports panic dumps,
then the data can be collected for debug.
Signed-off-by: San Mehat <san@google.com>
get_nid_for_pfn() returns int
Presumably the (nid < 0) case has never happened.
We do know that it is happening on one system while creating a symlink for
a memory section so it should also happen on the same system if
unregister_mem_sect_under_nodes() were called to remove the same symlink.
The test was actually added in response to a problem with an earlier
version reported by Yasunori Goto where one or more of the leading pages
of a memory section on the 2nd node of one of his systems was
uninitialized because I believe they coincided with a memory hole.
That earlier version did not ignore uninitialized pages and determined
the nid by considering only the 1st page of each memory section. This
caused the symlink to the 1st memory section on the 2nd node to be
incorrectly created in /sys/devices/system/node/node0 instead of
/sys/devices/system/node/node1. The problem was fixed by adding the
test to skip over uninitialized pages.
I suspect we have not seen any reports of the non-removal
of a symlink due to the incorrect declaration of the nid
variable in unregister_mem_sect_under_nodes() because
- systems where a memory section could have an uninitialized
range of leading pages are probably rare.
- memory remove is probably not done very frequently on the
systems that are capable of demonstrating the problem.
- lingering symlink(s) that should have been removed may
have simply gone unnoticed.
[garyhade@us.ibm.com: wrote changelog]
Signed-off-by: Roel Kluin <roel.kluin@gmail.com>
Cc: Gary Hade <garyhade@us.ibm.com>
Impact: module build fix
Fix:
ERROR: "sysdev_resume" [arch/x86/kernel/apm.ko] undefined!
ERROR: "sysdev_suspend" [arch/x86/kernel/apm.ko] undefined!
As these APIs are now used by the APM driver, which can be built
as a module.
Also fix a few extra (and inconsistent) newlines in comment blocks
preceding these functions.
Move the sysdev_suspend/resume from the callee to the callers, with
no real change in semantics, so that we can rework the disabling of
interrupts during suspend/hibernation.
This is based on an earlier patch from Linus.
there's a few places that currently loop over driver_probe_done(), and
I'm about to add another one. This patch abstracts it into a helper
to reduce duplication.
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
Cc: Len Brown <lenb@kernel.org>
Acked-by: Greg KH <gregkh@suse.de>
Fix function parameter name in kernel-doc:
Warning(linux-next-20090120//drivers/base/core.c:1289): No description found for parameter 'dev'
Warning(linux-next-20090120//drivers/base/core.c:1289): Excess function parameter 'root' description in 'root_device_unregister'
Acked-by: Mark McLoughlin <markmc@redhat.com>
Commit 3ada8b7e ("block: struct device - replace bus_id with dev_name(),
dev_set_name()") deleted the code in register_disk() that changed a '/'
to a '!' in the device name when registering a disk, but dev_set_name()
does not perform this conversion.
This leads to amusing problems with disks that have '/' in their names:
for example a failure to boot with the root partition on a cciss device,
even though the kernel says it knows about the root device:
VFS: Cannot open root device "cciss/c0d0p6" or unknown-block(0,0)
Please append a correct "root=" boot option; here are the available partitions:
6800 71652960 cciss/c0d0 driver: cciss
6802 1 cciss/c0d0p2
6805 2931831 cciss/c0d0p5
6806 34354908 cciss/c0d0p6
6810 71652960 cciss/c0d1 driver: cciss
Fix this by adding code to change '/' to '!' in dev_set_name() to handle
this until dev_set_name() is converted to use kobject_set_name().
Signed-off-by: Roland Dreier <rolandd@cisco.com>
Acked-by: Kay Sievers <kay.sievers@vrfy.org>
This reverts commit 2831fe6f9cc4e16c103504ee09a47a084297c0f3.
Turns out that device_initialize shouldn't fail silently.
This series needs to be reworked in order to get into proper
shape.
Reported-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
Cc: Kay Sievers <kay.sievers@vrfy.org>
This reverts commit 11c3b5c3e08f4d855cbef52883c266b9ab9df879.
shape.
This reverts commit 93e746db183b3bdbbda67900f79b5835f9cb388f.
shape.
This reverts commit b9daa99ee533578e3f88231e7a16784dcb44ec42.
shape.
Due to changeset ba84be2338d3a2b6020d39279335bb06fcd332e1 ("remove
linux/hardirq.h from asm-generic/local.h") the sparc64 build started
failing on drivers/base/topology.c:
drivers/base/topology.c: In function ‘show_physical_package_id’:
drivers/base/topology.c:103: error: implicit declaration of function ‘cpu_data’
drivers/base/topology.c:103: error: request for member ‘proc_id’ in something not a structure or union
drivers/base/topology.c: In function ‘show_core_id’:
drivers/base/topology.c:106: error: request for member ‘core_id’ in something not a structure or union
Adding the obvious fix of including asm/cpudata.h into asm/topology.h on
sparc64 doesn't fix it, in fact it makes things worse because of the
header file dependency chain:
linux/gfp.h --> linux/mmzone.h --> linux/topology.h -->
asm/topology.h --> asm/cpudata.h --> linux/percpu.h -->
linux/slab.h
which results in:
include/linux/slub_def.h: In function ‘kmalloc_large’:
include/linux/slub_def.h:209: error: implicit declaration of function ‘__get_free_pages’
include/linux/slub_def.h:209: error: ‘__GFP_COMP’ undeclared (first use in this function)
include/linux/slub_def.h:209: error: (Each undeclared identifier is reported only once
include/linux/slub_def.h:209: error: for each function it appears in.)
include/linux/slub_def.h:209: warning: cast to pointer from integer of different size
The simplest thing to do is to add yet another one-off hack like parts
of the guilty changeset did, by putting an explicit linux/hardirq.h
include into drivers/base/topology.c
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (24 commits)
trivial: chack -> check typo fix in main Makefile
trivial: Add a space (and a comma) to a printk in 8250 driver
trivial: Fix misspelling of "firmware" in docs for ncr53c8xx/sym53c8xx
trivial: Fix misspelling of "firmware" in powerpc Makefile
trivial: Fix misspelling of "firmware" in usb.c
trivial: Fix misspelling of "firmware" in qla1280.c
trivial: Fix misspelling of "firmware" in a100u2w.c
trivial: Fix misspelling of "firmware" in megaraid.c
trivial: Fix misspelling of "firmware" in ql4_mbx.c
trivial: Fix misspelling of "firmware" in acpi_memhotplug.c
trivial: Fix misspelling of "firmware" in ipw2100.c
trivial: Fix misspelling of "firmware" in atmel.c
trivial: Fix misspelled firmware in Kconfig
trivial: fix an -> a typos in documentation and comments
trivial: fix then -> than typos in comments and documentation
trivial: update Jesper Juhl CREDITS entry with new email
trivial: fix singal -> signal typo
trivial: Fix incorrect use of "loose" in event.c
trivial: printk: fix indentation of new_text_line declaration
trivial: rtc-stk17ta8: fix sparse warning
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6: (60 commits)
uio: make uio_info's name and version const
UIO: Documentation for UIO ioport info handling
UIO: Pass information about ioports to userspace (V2)
UIO: uio_pdrv_genirq: allow custom irq_flags
UIO: use pci_ioremap_bar() in drivers/uio
arm: struct device - replace bus_id with dev_name(), dev_set_name()
libata: struct device - replace bus_id with dev_name(), dev_set_name()
avr: struct device - replace bus_id with dev_name(), dev_set_name()
block: struct device - replace bus_id with dev_name(), dev_set_name()
chris: struct device - replace bus_id with dev_name(), dev_set_name()
dmi: struct device - replace bus_id with dev_name(), dev_set_name()
gadget: struct device - replace bus_id with dev_name(), dev_set_name()
gpio: struct device - replace bus_id with dev_name(), dev_set_name()
gpu: struct device - replace bus_id with dev_name(), dev_set_name()
hwmon: struct device - replace bus_id with dev_name(), dev_set_name()
i2o: struct device - replace bus_id with dev_name(), dev_set_name()
IA64: struct device - replace bus_id with dev_name(), dev_set_name()
i7300_idle: struct device - replace bus_id with dev_name(), dev_set_name()
infiniband: struct device - replace bus_id with dev_name(), dev_set_name()
ISDN: struct device - replace bus_id with dev_name(), dev_set_name()
Show node to memory section relationship with symlinks in sysfs
Add /sys/devices/system/node/nodeX/memoryY symlinks for all
the memory sections located on nodeX. For example:
/sys/devices/system/node/node1/memory135 -> ../../memory/memory135
indicates that memory section 135 resides on node1.
Also revises documentation to cover this change as well as updating
Documentation/ABI/testing/sysfs-devices-memory to include descriptions
of memory hotremove files 'phys_device', 'phys_index', and 'state'
that were previously not described there.
In addition to it always being a good policy to provide users with
the maximum possible amount of physical location information for
resources that can be hot-added and/or hot-removed, the following
are some (but likely not all) of the user benefits provided by
this change.
Immediate:
- Provides information needed to determine the specific node
on which a defective DIMM is located. This will reduce system
downtime when the node or defective DIMM is swapped out.
- Prevents unintended onlining of a memory section that was
previously offlined due to a defective DIMM. This could happen
during node hot-add when the user or node hot-add assist script
onlines _all_ offlined sections due to user or script inability
to identify the specific memory sections located on the hot-added
node. The consequences of reintroducing the defective memory
could be ugly.
- Provides information needed to vary the amount and distribution
of memory on specific nodes for testing or debugging purposes.
Future:
- Will provide information needed to identify the memory
sections that need to be offlined prior to physical removal
of a specific node.
Symlink creation during boot was tested on 2-node x86_64, 2-node
ppc64, and 2-node ia64 systems. Symlink creation during physical
memory hot-add tested on a 2-node x86_64 system.
Signed-off-by: Gary Hade <garyhade@us.ibm.com>
Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com>
Add support for allocating root device objects which group
device objects under /sys/devices directories.
Also add a sysfs 'module' symlink which points to the owner
of the root device object. This symlink will be used in virtio
to allow userspace to determine which virtio bus implementation
a given device is associated with.
[Includes suggestions from Cornelia Huck]
Signed-off-by: Mark McLoughlin <markmc@redhat.com>
In __device_release_driver(),driver_sysfs_remove() has removed the
driver link under device dir in sysfs, but sysfs_remove_link() is
called again to do such thing. Remove the duplicate call to
sys_remove_link().
Signed-off-by: Ming Lei <tom.leiming@gmail.com>
This patch (as1184) changes the location of the notifications in
device_add() and device_del(). Now the BUS_NOTIFY_ADD_DEVICE message
is sent after dpm_sysfs_add(), which is necessary for clients that
want to add attributes to the power/ subdirectory. The
BUS_NOTIFY_DEL_DEVICE message is correspondingly moved before
dpm_sysfs_remove().
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
Nothing outside of the driver core should ever touch knode_bus, so
move it out of the public eye.
Nothing outside of the driver core should ever touch knode_driver, so
Nothing outside of the driver core should ever touch klist_children, or
knode_parent, so move them out of the public eye.
This is to be used to move things out of struct device that no code
outside of the driver core should ever touch.
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
PM: Simplify the new suspend/hibernation framework for devices
Following the discussion at the Kernel Summit, simplify the new
device PM framework by merging 'struct pm_ops' and
'struct pm_ext_ops' and removing pointers to 'struct pm_ext_ops'
from 'struct platform_driver' and 'struct pci_driver'.
After this change, the suspend/hibernation callbacks will only
reside in 'struct device_driver' as well as at the bus type/
device class/device type level. Accordingly, PCI and platform
device drivers are now expected to put their suspend/hibernation
callbacks into the 'struct device_driver' embedded in
'struct pci_driver' or 'struct platform_driver', respectively.
Acked-by: Pavel Machek <pavel@suse.cz>
Cc: Jesse Barnes <jbarnes@virtuousgeek.org>
It's spelled "firmware".
Signed-off-by: Nick Andrew <nick@nick-andrew.net>
* 'cpus4096-for-linus-3' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (77 commits)
x86: setup_per_cpu_areas() cleanup
cpumask: fix compile error when CONFIG_NR_CPUS is not defined
cpumask: use alloc_cpumask_var_node where appropriate
cpumask: convert shared_cpu_map in acpi_processor* structs to cpumask_var_t
x86: use cpumask_var_t in acpi/boot.c
x86: cleanup some remaining usages of NR_CPUS where s/b nr_cpu_ids
sched: put back some stack hog changes that were undone in kernel/sched.c
x86: enable cpus display of kernel_max and offlined cpus
ia64: cpumask fix for is_affinity_mask_valid()
cpumask: convert RCU implementations, fix
xtensa: define __fls
mn10300: define __fls
m32r: define __fls
h8300: define __fls
frv: define __fls
cris: define __fls
cpumask: CONFIG_DISABLE_OBSOLETE_CPUMASK_FUNCTIONS
cpumask: zero extra bits in alloc_cpumask_var_node
cpumask: replace for_each_cpu_mask_nr with for_each_cpu in kernel/time/
cpumask: convert mm/
CONFIG_NR_CPUS will be defined for all arch's whether SMP or not, but
it may not have made it into all arches yet.
Signed-off-by: Mike Travis <travis@sgi.com>
These two IOMMUs can implement the current version of this API. So
select the API if one or both of these IOMMU drivers is selected.
Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
This API can be used by KVM for accessing different types of IOMMUs to
do device passthrough to guests. Beside that this API can also be used
by device drivers to map non-linear host memory into dma-linear
addresses to prevent sgather-gather DMA. UIO may be another user for
this API.
Impact: add new sysfs files.
Add sysfs files "kernel_max" and "offline" to display the max CPU index
allowed (NR_CPUS-1), and the map of cpus that are offline.
Cpus can be offlined via HOTPLUG, disabled by the BIOS ACPI tables, or
if they exceed the number of cpus allowed by the NR_CPUS config option,
or the "maxcpus=NUM" kernel start parameter.
The "possible_cpus=NUM" parameter can also extend the number of possible
cpus allowed, in which case the cpus not present at startup will be
in the offline state. (These cpus can be HOTPLUGGED ON after system
startup [pending a follow-on patch to provide the capability via the
/sys/devices/sys/cpu/cpuN/online mechanism to bring them online.])
By design, the "offlined cpus > possible cpus" display will always
use the following formats:
* all possible cpus online: "x$" or "x-y$"
* some possible cpus offline: ".*,x$" or ".*,x-y$"
where:
x == number of possible cpus (nr_cpu_ids); and
y == number of cpus >= NR_CPUS or maxcpus (if y > x).
One use of this feature is for distros to select (or configure) the
appropriate kernel to install for the resident system.
Notes:
* cpus offlined <= possible cpus will be printed for all architectures.
* cpus offlined > possible cpus will only be printed for arches that
set 'total_cpus' [X86 only in this patch].
Based on tip/cpus4096 + .../rusty/linux-2.6-for-ingo.git/master +
x86-only-patches sent 12/15.
cpulist_scnprintf to take pointers.
Impact: change calling convention of existing cpumask APIs
Most cpumask functions started with cpus_: these have been replaced by
cpumask_ ones which take struct cpumask pointers as expected.
These four functions don't have good replacement names; fortunately
they're rarely used, so we just change them over.
Cc: paulus@samba.org
Cc: mingo@redhat.com
Cc: tony.luck@intel.com
Cc: ralf@linux-mips.org
Cc: Greg Kroah-Hartman <gregkh@suse.de>
Cc: cl@linux-foundation.org
Cc: srostedt@redhat.com
SYSFS: Fix return values for sysdev_store_{ulong,int}
Always return the full size instead of the consumed
length of the string in sysdev_store_{ulong,int}
This avoids EINVAL errors in some echo versions.
Cc: stable <stable@kernel.org>
There are no functions named sys_device_shutdown or sys_device_suspend
in the kernel.
They should be fixed to sysdev_shutdown and sysdev_suspend respectively.
Signed-off-by: Qinghuang Feng <qhfeng.kernel@gmail.com>
This attribute just has a write operation.
[akpm@linux-foundation.org: use S_IWUSR as suggested by Randy]
Signed-off-by: Shaohua Li <shaohua.li@intel.com>
Cc: Randy Dunlap <randy.dunlap@oracle.com>
This patch adds a function to scan individual or all zones' unevictable
lists and move any pages that have become evictable onto the respective
zone's inactive list, where shrink_inactive_list() will deal with them.
Adds sysctl to scan all nodes, and per node attributes to individual
nodes' zones.
Kosaki: If evictable page found in unevictable lru when write
/proc/sys/vm/scan_unevictable_pages, print filename and file offset of
these pages.
[akpm@linux-foundation.org: fix one CONFIG_MMU=n build error]
[kosaki.motohiro@jp.fujitsu.com: adapt vmscan-unevictable-lru-scan-sysctl.patch to new sysfs API]
Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com>
Signed-off-by: Rik van Riel <riel@redhat.com>
Signed-off-by: Hugh Dickins <hugh@veritas.com>
Add NR_MLOCK zone page state, which provides a (conservative) count of
mlocked pages (actually, the number of mlocked pages moved off the LRU).
Reworked by lts to fit in with the modified mlock page support in the
Reclaim Scalability series.
[kosaki.motohiro@jp.fujitsu.com: fix incorrect Mlocked field of /proc/meminfo]
[lee.schermerhorn@hp.com: mlocked-pages: add event counting with statistics]
Signed-off-by: Nick Piggin <npiggin@suse.de>
Report unevictable pages per zone and system wide.
Kosaki Motohiro added support for memory controller unevictable
statistics.
[riel@redhat.com: fix printk in show_free_areas()]
[akpm@linux-foundation.org: fix units in /proc/vmstats]
Debugged-by: Hiroshi Shimamoto <h-shimamoto@ct.jp.nec.com>
Split the LRU lists in two, one set for pages that are backed by real file
systems ("file") and one for pages that are backed by memory and swap
("anon"). The latter includes tmpfs.
The advantage of doing this is that the VM will not have to scan over lots
of anonymous pages (which we generally do not want to swap out), just to
find the page cache pages that it should evict.
This patch has the infrastructure and a basic policy to balance how much
we scan the anon lists and how much we scan the file lists. The big
policy changes are in separate patches.
[lee.schermerhorn@hp.com: collect lru meminfo statistics from correct offset]
[kosaki.motohiro@jp.fujitsu.com: prevent incorrect oom under split_lru]
[kosaki.motohiro@jp.fujitsu.com: fix pagevec_move_tail() doesn't treat unevictable page]
[hugh@veritas.com: memcg swapbacked pages active]
[hugh@veritas.com: splitlru: BDI_CAP_SWAP_BACKED]
[akpm@linux-foundation.org: fix /proc/vmstat units]
[nishimura@mxp.nes.nec.co.jp: memcg: fix handling of shmem migration]
[kosaki.motohiro@jp.fujitsu.com: adjust Quicklists field of /proc/meminfo]
[kosaki.motohiro@jp.fujitsu.com: fix style issue of get_scan_ratio()]
Signed-off-by: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp>
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6: (46 commits)
UIO: Fix mapping of logical and virtual memory
UIO: add automata sercos3 pci card support
UIO: Change driver name of uio_pdrv
UIO: Add alignment warnings for uio-mem
Driver core: add bus_sort_breadthfirst() function
NET: convert the phy_device file to use bus_find_device_by_name
kobject: Cleanup kobject_rename and !CONFIG_SYSFS
kobject: Fix kobject_rename and !CONFIG_SYSFS
sysfs: Make dir and name args to sysfs_notify() const
platform: add new device registration helper
sysfs: use ilookup5() instead of ilookup5_nowait()
PNP: create device attributes via default device attributes
Driver core: make bus_find_device_by_name() more robust
usb: turn dev_warn+WARN_ON combos into dev_WARN
debug: use dev_WARN() rather than WARN_ON() in device_pm_add()
debug: Introduce a dev_WARN() function
sysfs: fix deadlock
device model: Do a quickcheck for driver binding before doing an expensive check
Driver core: Fix cleanup in device_create_vargs().
Driver core: Clarify device cleanup.
Add resource_type() and IORESOURCE_TYPE_BITS. They make it easier to add
more resource types without having to rewrite tons of code.
Signed-off-by: Magnus Damm <damm@igel.co.jp>
Cc: Ben Dooks <ben-linux@fluff.org>
Cc: Jean Delvare <khali@linux-fr.org>
Convert printks to use dev_printk().
Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com>
Signed-off-by: Alberto Bertogli <albertito@blitiri.com.ar>
Use the '%pF' format to get rid of an "#ifdef DEBUG" and make some printks
atomic.
This removes the last in-tree uses of print_fn_descriptor_symbol(). I
marked print_fn_descriptor_symbol() deprecated and scheduled it for
removal next year to give time for out-of-tree modules to be updated.
parisc's print_fn_descriptor_symbol() is currently broken there (it needs
to dereference the function pointer similar to ia64 and power). This
patch shouldn't make anything worse, but it means we need to fix
dereference_function_descriptor() instead of print_fn_descriptor_symbol()
to get meaningful initcall_debug output.
Cc: Kyle McMartin <kyle@mcmartin.ca>
Cc: "Rafael J. Wysocki" <rjw@sisk.pl>
Cc: Greg KH <greg@kroah.com>
The PCI core wants to reorder the devices in the bus list. So move this
functionality out of the pci core and into the driver core so that
anyone else can also do this if needed. This also lets us change how
struct device is attached to drivers in the future without messing with
the PCI core.
Acked-by: Jesse Barnes <jbarnes@virtuousgeek.org>
When looking at kobject_rename I found two bugs with
that exist when sysfs support is disabled in the kernel.
kobject_rename does not change the name on the kobject when
sysfs support is not compiled in.
kobject_rename without locking attempts to check the
validity of a rename operation, which the kobject layer
simply does not have the infrastructure to do.
This patch documents the previously unstated requirement of
kobject_rename that is the responsibility of the caller to
provide mutual exclusion and to be certain that the new_name
for the kobject is valid.
This patch modifies sysfs_rename_dir in !CONFIG_SYSFS case
to call kobject_set_name to actually change the kobject_name.
This patch removes the bogus and misleading check in kobject_rename
that attempts to see if a rename is valid. The check is bogus
because we do not have the proper locking. The check is misleading
because it looks like we can and do perform checking at the kobject
level that we don't.
Add a helper that registers simple platform_device w/o resources but with
parent and device data.
This is usefull to cleanup platform code from code that registers such
simple devices as leds-gpio, generic-bl, etc.
Signed-off-by: Dmitry Baryshkov <dbaryshkov@gmail.com>
Cc: David Brownell <dbrownell@users.sourceforge.net>
Use sysfs_streq() in bus_find_device_by_name() so trailing newlines
are ignored (E.G. in bind/unbind).
Signed-off-by: Peter Korsgaard <jacmet@sunsite.dk>
device_pm_add() has a WARN_ON that is showing relatively high on
kerneloops.org, but unfortunately the WARN_ON is less than useful
in that it doesn't print any information about what device is causing
the issue.
This patch fixes this by turning the WARN_ON() into the newly
introduces dev_WARN() which will print information about the
device in question.
This patch adds a quick check for the driver<->device match before
taking the locks and doin gthe expensive checks. Taking the lock hurts
in asynchronous boot context where the device lock gets hit; one of the
init functions takes the lock and goes to do an expensive hardware init;
the other init functions walk the same PCI list and get stuck on the
lock as a result.
For the common case, we can know there's no chance whatsoever of a match
if the device isn't in the drivers ID table... so this patch does that
check as a best-effort-avoid-the-lock approach.
Bootcharts for before and after can be seen at
http://www.fenrus.org/before.svg
http://www.fenrus.org/after.svg
Note the long time "agp_ali_init" takes in the first graph; my laptop
doesn't even have an ALI chip in it! (the bootgraphs look a bit
dissimilar, but that's the point, the first one has a bunch of arbitrary
delays in it that cause it to look very different)
This reduces my kernel boot time by about 20%
Cc: Alan Stern <stern@rowland.harvard.edu>
If device_register() in device_create_vargs() fails, the device
must be cleaned up with put_device() (which is also fine on NULL)
instead of kfree().
Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com>
