path: root/drivers/base
2012-03-24Merge tag 'device-for-3.4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux Pull <linux/device.h> avoidance patches from Paul Gortmaker: "Nearly every subsystem has some kind of header with a proto like: void foo(struct device *dev); and yet there is no reason for most of these guys to care about the sub fields within the device struct. This allows us to significantly reduce the scope of headers including headers. For this instance, a reduction of about 40% is achieved by replacing the include with the simple fact that the device is some kind of a struct. Unlike the much larger module.h cleanup, this one is simply two commits. One to fix the implicit <linux/device.h> users, and then one to delete the device.h includes from the linux/include/ dir wherever possible." * tag 'device-for-3.4' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux: device.h: audit and cleanup users in main include dir device.h: cleanup users outside of linux/include (C files)
2012-03-23bitops: remove for_each_set_bit_cont()Akinobu Mita
Remove for_each_set_bit_cont() after confirming that no one uses for_each_set_bit_cont() anymore. [sfr@canb.auug.org.au: regmap: cope with bitops API change] Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Robert Richter <robert.richter@amd.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-22Merge tag 'regmap-3.4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regmap Pull regmap updates from Mark Brown: "Things are really quieting down with the regmap API, while we're still seeing a trickle of new features coming in they're getting much smaller than they were. It's also nice to have some features which support other subsystems building infrastructure on top of regmap. Highlights include: - Support for padding between the register and the value when interacting with the device, sometimes needed for fast interfaces. - Support for applying register updates to the device when restoring the register state. This is intended to be used to apply updates supplied by manufacturers for tuning the performance of the device (many of which are to undocumented registers which aren't otherwise covered). - Support for multi-register operations on cached registers. - Support for syncing only part of the register cache. - Stubs and parameter query functions intended to make it easier for other subsystems to build infrastructure on top of the regmap API. plus a few driver updates making use of the new features which it was easier to merge via this tree." * tag 'regmap-3.4' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regmap: (41 commits) regmap: Fix future missing prototype of devres_alloc() and friends regmap: Rejig struct declarations for stubbed API regmap: Fix rbtree block base in sync regcache: Make sure we sync register 0 in an rbtree cache regmap: delete unused module.h from drivers/base/regmap files regmap: Add stub for regcache_sync_region() mfd: Improve performance of later WM1811 revisions regmap: Fix x86_64 breakage regmap: Allow drivers to sync only part of the register cache regmap: Supply ranges to the sync operations regmap: Add tracepoints for cache only and cache bypass regmap: Mark the cache as clean after a successful sync regmap: Remove default cache sync implementation regmap: Skip hardware defaults for LZO caches regmap: Expose the driver name in debugfs mfd: wm8400: Convert to devm_regmap_init_i2c() mfd: wm831x: Convert to devm_regmap_init() mfd: wm8994: Convert to devm_regmap_init() mfd/ASoC: Convert WM8994 driver to use regmap patches mfd: Add __devinit and __devexit annotations in wm8994 ...
2012-03-22Merge tag 'sound-3.4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound Pull updates of sound stuff from Takashi Iwai: "Here is the first big update chunk of sound stuff for 3.4-rc1. In the common sound infrastructure, there are a few changes for dynamic PCM support (used in ASoC) and a few clean-ups. Majority of changes are found, as usual, in HD-audio and ASoC. Some highlights of HD-audio changes: - All the long-standing static quirk codes for Realtek codec were finally removed by fixing and extending the Realtek auto-parser. - The mute-LED control is standardized over all HD-audio codec drivers using the extended vmaster hook. - The vmaster slave mixer elements are initialized to 0dB as default so that the user won't be annoyed by the silent output after updates, e.g. due to the additions of new elements. - Other many fix-ups for the misc HD-audio devices. In the ASoC side, this is a very active release, including a quite a few framework enhancements. Some highlights: - Support for widgets not associated with a CODEC, an important part of the dynamic PCM framework. - A library factoring out the common code shared by dmaengine based DMA drivers contributed by Lars-Peter Clausen. This will save a lot of code and make it much easier to deploy enhancements to dmaengine. - Support for binary controls, used for providing runtime configuration of algorithm coefficients. - A new DAPM widget type for regulator supplies allowing drivers for devices that can power down unused supplies while active to do without any per-driver code. - DAPM widgets for DAIs, initially giving a speed boost for playback startup and shutdown and also the basis for CODEC<->CODEC DAI link support. - Support for specifying the number of significant bits on audio interfaces, useful for allowing applications to know how much effort to put into generating data for a larger sample format. - Conversion of the FSI driver used on some SH processors to DMAEngine. - Conversion of EP93xx drivers to DMAEngine. - New CODEC drivers for Maxim MAX9768 and Wolfson Microelectronics WM2200. - Move audmux driver from arc/arm to sound/soc - McBSP move from arch/ to sound/ and updates Also, a few small updates and fixes for other drivers like au88x0, ymfpci, USB 6fire, USB usx2yaudio are included." * tag 'sound-3.4' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (446 commits) ASoC: wm8994: Provide VMID mode control and fix default sequence ASoC: wm8994: Add missing break in resume ASoC: wm_hubs: Don't actively manage LINEOUT_VMID_BUF ASoC: pxa-ssp: atomically set stream active masks ASoC: fsl: p1022ds: tell the WM8776 codec driver that it's the master ASoC: Samsung: Added to support mono recording ALSA: hda - Fix build with CONFIG_PM=n ALSA: au88x0 - Avoid possible Oops at unbinding ALSA: usb-audio - Fix build error by consitification of rate list ASoC: core: Fix obscure leak of runtime array ALSA: pcm - Avoid GFP_ATOMIC in snd_pcm_link() ALSA: pcm: Constify the list in snd_pcm_hw_constraint_list ASoC: wm8996: Add 44.1kHz support ALSA: hda - Fix build of patch_sigmatel.c without CONFIG_SND_HDA_POWER_SAVE ASoC: mx27vis-aic32x4: Convert it to platform driver ALSA: hda - fix printing of high HDMI sample rates ALSA: ymfpci - Fix legacy registers on S3/S4 resume ALSA: control - Fixe a trailing white space error ALSA: hda - Add expose_enum_ctl flag to snd_hda_add_vmaster_hook() ALSA: hda - Add "Mute-LED Mode" enum control ...
2012-03-22Merge branch 'x86-mce-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull MCE changes from Ingo Molnar. * 'x86-mce-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86/mce: Fix return value of mce_chrdev_read() when erst is disabled x86/mce: Convert static array of pointers to per-cpu variables x86/mce: Replace hard coded hex constants with symbolic defines x86/mce: Recognise machine check bank signature for data path error x86/mce: Handle "action required" errors x86/mce: Add mechanism to safely save information in MCE handler x86/mce: Create helper function to save addr/misc when needed HWPOISON: Add code to handle "action required" errors. HWPOISON: Clean up memory_failure() vs. __memory_failure()
2012-03-21Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc Pull powerpc merge from Benjamin Herrenschmidt: "Here's the powerpc batch for this merge window. It is going to be a bit more nasty than usual as in touching things outside of arch/powerpc mostly due to the big iSeriesectomy :-) We finally got rid of the bugger (legacy iSeries support) which was a PITA to maintain and that nobody really used anymore. Here are some of the highlights: - Legacy iSeries is gone. Thanks Stephen ! There's still some bits and pieces remaining if you do a grep -ir series arch/powerpc but they are harmless and will be removed in the next few weeks hopefully. - The 'fadump' functionality (Firmware Assisted Dump) replaces the previous (equivalent) "pHyp assisted dump"... it's a rewrite of a mechanism to get the hypervisor to do crash dumps on pSeries, the new implementation hopefully being much more reliable. Thanks Mahesh Salgaonkar. - The "EEH" code (pSeries PCI error handling & recovery) got a big spring cleaning, motivated by the need to be able to implement a new backend for it on top of some new different type of firwmare. The work isn't complete yet, but a good chunk of the cleanups is there. Note that this adds a field to struct device_node which is not very nice and which Grant objects to. I will have a patch soon that moves that to a powerpc private data structure (hopefully before rc1) and we'll improve things further later on (hopefully getting rid of the need for that pointer completely). Thanks Gavin Shan. - I dug into our exception & interrupt handling code to improve the way we do lazy interrupt handling (and make it work properly with "edge" triggered interrupt sources), and while at it found & fixed a wagon of issues in those areas, including adding support for page fault retry & fatal signals on page faults. - Your usual random batch of small fixes & updates, including a bunch of new embedded boards, both Freescale and APM based ones, etc..." I fixed up some conflicts with the generalized irq-domain changes from Grant Likely, hopefully correctly. * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (141 commits) powerpc/ps3: Do not adjust the wrapper load address powerpc: Remove the rest of the legacy iSeries include files powerpc: Remove the remaining CONFIG_PPC_ISERIES pieces init: Remove CONFIG_PPC_ISERIES powerpc: Remove FW_FEATURE ISERIES from arch code tty/hvc_vio: FW_FEATURE_ISERIES is no longer selectable powerpc/spufs: Fix double unlocks powerpc/5200: convert mpc5200 to use of_platform_populate() powerpc/mpc5200: add options to mpc5200_defconfig powerpc/mpc52xx: add a4m072 board support powerpc/mpc5200: update mpc5200_defconfig to fit for charon board Documentation/powerpc/mpc52xx.txt: Checkpatch cleanup powerpc/44x: Add additional device support for APM821xx SoC and Bluestone board powerpc/44x: Add support PCI-E for APM821xx SoC and Bluestone board MAINTAINERS: Update PowerPC 4xx tree powerpc/44x: The bug fixed support for APM821xx SoC and Bluestone board powerpc: document the FSL MPIC message register binding powerpc: add support for MPIC message register API powerpc/fsl: Added aliased MSIIR register address to MSI node in dts powerpc/85xx: mpc8548cds - add 36-bit dts ...
2012-03-21Merge tag 'dt-for-linus' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
Pull core device tree changes for Linux v3.4 from Grant Likely: "This branch contains a minor documentation addition, a utility function for parsing string properties needed by some of the new ARM platforms, disables dynamic DT code that isn't used anywhere but on a few PPC machines, and exports DT node compatible data to userspace via UEVENT properties. Nothing earth shattering here." * tag 'dt-for-linus' of git://git.secretlab.ca/git/linux-2.6: of: Only compile OF_DYNAMIC on PowerPC pseries and iseries arm/dts: OMAP3: Add omap3evm and am335xevm support drivercore: Output common devicetree information in uevent of: Add of_property_match_string() to find index into a string list
2012-03-21Merge tag 'pm-for-3.4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull power management updates for 3.4 from Rafael Wysocki: "Assorted extensions and fixes including: * Introduction of early/late suspend/hibernation device callbacks. * Generic PM domains extensions and fixes. * devfreq updates from Axel Lin and MyungJoo Ham. * Device PM QoS updates. * Fixes of concurrency problems with wakeup sources. * System suspend and hibernation fixes." * tag 'pm-for-3.4' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (43 commits) PM / Domains: Check domain status during hibernation restore of devices PM / devfreq: add relation of recommended frequency. PM / shmobile: Make MTU2 driver use pm_genpd_dev_always_on() PM / shmobile: Make CMT driver use pm_genpd_dev_always_on() PM / shmobile: Make TMU driver use pm_genpd_dev_always_on() PM / Domains: Introduce "always on" device flag PM / Domains: Fix hibernation restore of devices, v2 PM / Domains: Fix handling of wakeup devices during system resume sh_mmcif / PM: Use PM QoS latency constraint tmio_mmc / PM: Use PM QoS latency constraint PM / QoS: Make it possible to expose PM QoS latency constraints PM / Sleep: JBD and JBD2 missing set_freezable() PM / Domains: Fix include for PM_GENERIC_DOMAINS=n case PM / Freezer: Remove references to TIF_FREEZE in comments PM / Sleep: Add more wakeup source initialization routines PM / Hibernate: Enable usermodehelpers in hibernate() error path PM / Sleep: Make __pm_stay_awake() delete wakeup source timers PM / Sleep: Fix race conditions related to wakeup source timer function PM / Sleep: Fix possible infinite loop during wakeup source destruction PM / Hibernate: print physical addresses consistently with other parts of kernel ...
2012-03-19Merge branch 'pm-domains'Rafael J. Wysocki
* pm-domains: PM / Domains: Check domain status during hibernation restore of devices
2012-03-19PM / Domains: Check domain status during hibernation restore of devicesRafael J. Wysocki
Power domains that were off before hibernation shouldn't be turned on during device restore, so prevent that from happening. This change fixes up commit 65533bbf63b4f37723fdfedc73d0653958973323 PM / Domains: Fix hibernation restore of devices, v2 that didn't include it by mistake. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2012-03-16Merge branch 'pm-domains'Rafael J. Wysocki
* pm-domains: PM / shmobile: Make MTU2 driver use pm_genpd_dev_always_on() PM / shmobile: Make CMT driver use pm_genpd_dev_always_on() PM / shmobile: Make TMU driver use pm_genpd_dev_always_on() PM / Domains: Introduce "always on" device flag PM / Domains: Fix hibernation restore of devices, v2 PM / Domains: Fix handling of wakeup devices during system resume
2012-03-16Merge branch 'pm-qos'Rafael J. Wysocki
* pm-qos: sh_mmcif / PM: Use PM QoS latency constraint tmio_mmc / PM: Use PM QoS latency constraint PM / QoS: Make it possible to expose PM QoS latency constraints
2012-03-16PM / Domains: Introduce "always on" device flagRafael J. Wysocki
The TMU device on the Mackerel board belongs to the A4R power domain and loses power when the domain is turned off. Unfortunately, the TMU driver is not prepared to cope with such situations and crashes the system when that happens. To work around this problem introduce a new helper function, pm_genpd_dev_always_on(), allowing a device driver to mark its device as "always on" in case it belongs to a PM domain, which will make the generic PM domains core code avoid powering off the domain containing the device, both at run time and during system suspend. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Tested-by: Simon Horman <horms@verge.net.au> Acked-by: Paul Mundt <lethal@linux-sh.org> Cc: stable@vger.kernel.org
2012-03-16PM / Domains: Fix hibernation restore of devices, v2Rafael J. Wysocki
During resume from hibernation pm_genpd_restore_noirq() should only power off domains whose suspend_power_off flags are set once and not every time it is called for a device in the given domain. Moreover, it shouldn't decrement genpd->suspended_count, because that field is not touched during device freezing and therefore it is always equal to 0 when pm_genpd_restore_noirq() runs for the first device in the given domain. This means pm_genpd_restore_noirq() may use genpd->suspended_count to determine whether or not it it has been called for the domain in question already in this cycle (it only needs to increment that field every time it runs for this purpose) and whether or not it should check if the domain needs to be powered off. For that to work, though, pm_genpd_prepare() has to clear genpd->suspended_count when it runs for the first device in the given domain (in which case that flag need not be cleared during domain initialization). Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Cc: stable@vger.kernel.org
2012-03-16PM / Domains: Fix handling of wakeup devices during system resumeRafael J. Wysocki
During system suspend pm_genpd_suspend_noirq() checks if the given device is in a wakeup path (i.e. it appears to be needed for one or more wakeup devices to work or is a wakeup device itself) and if it needs to be "active" for wakeup to work. If that is the case, the function returns 0 without incrementing the device domain's counter of suspended devices and without executing genpd_stop_dev() for the device. In consequence, the device is not stopped (e.g. its clock isn't disabled) and power is always supplied to its domain in the resulting system sleep state. However, pm_genpd_resume_noirq() doesn't repeat that check and it runs genpd_start_dev() and decrements the domain's counter of suspended devices even for the wakeup device that weren't stopped by pm_genpd_suspend_noirq(). As a result, the start callback may be run unnecessarily for them and their domains' counters of suspended devices may become negative. Both outcomes aren't desirable, so fix pm_genpd_resume_noirq() to look for wakeup devices that might not be stopped by during system suspend. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Tested-by: Simon Horman <horms@verge.net.au> Cc: stable@vger.kernel.org
2012-03-14Merge remote-tracking branch 'regmap/topic/bulk' into regmap-nextMark Brown
2012-03-14Merge remote-tracking branch 'regmap/topic/introspection' into regmap-nextMark Brown
Simple add/add conflict: drivers/base/regmap/regmap.c
2012-03-14Merge remote-tracking branches 'regmap/topic/patch' and 'regmap/topic/sync' ↵Mark Brown
into regmap-next
2012-03-14Merge remote-tracking branch 'regmap/topic/drivers' into regmap-nextMark Brown
Resolved simple add/add conflicts: drivers/base/regmap/internal.h drivers/base/regmap/regmap.c
2012-03-14Merge remote-tracking branches 'regmap/topic/core' and 'regmap/topic/devm' ↵Mark Brown
into regmap-next
2012-03-14Merge tag 'v3.3-rc7' into x86/mceIngo Molnar
Merge reason: Update from an ancient -rc1 base to an almost-final stable kernel. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2012-03-13PM / QoS: Make it possible to expose PM QoS latency constraintsRafael J. Wysocki
A runtime suspend of a device (e.g. an MMC controller) belonging to a power domain or, in a more complicated scenario, a runtime suspend of another device in the same power domain, may cause power to be removed from the entire domain. In that case, the amount of time necessary to runtime-resume the given device (e.g. the MMC controller) is often substantially greater than the time needed to run its driver's runtime resume callback. That may hurt performance in some situations, because user data may need to wait for the device to become operational, so we should make it possible to prevent that from happening. For this reason, introduce a new sysfs attribute for devices, power/pm_qos_resume_latency_us, allowing user space to specify the upper bound of the time necessary to bring the (runtime-suspended) device up after the resume of it has been requested. However, make that attribute appear only for the devices whose drivers declare support for it by calling the (new) dev_pm_qos_expose_latency_limit() helper function with the appropriate initial value of the attribute. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Reviewed-by: Kevin Hilman <khilman@ti.com> Reviewed-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Linus Walleij <linus.walleij@linaro.org>
2012-03-11device.h: cleanup users outside of linux/include (C files)Paul Gortmaker
For files that are actively using linux/device.h, make sure that they call it out. This will allow us to clean up some of the implicit uses of linux/device.h within include/* without introducing build regressions. Yes, this was created by "cheating" -- i.e. the headers were cleaned up, and then the fallout was found and fixed, and then the two commits were reordered. This ensures we don't introduce build regressions into the git history. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2012-03-11regmap: Fix future missing prototype of devres_alloc() and friendsStephen Warren
[Fix for breakage which will be introduced during the merge window via header reworks in another tree, the regmap tree does include device.h but Paul's tree breaks that. Reworded subject to reflect -- broonie] regmap.s uses devres_alloc() and others that are prototyped in device.h. Include that to solve the following: drivers/base/regmap/regmap.c: In function 'devm_regmap_init': drivers/base/regmap/regmap.c:331:2: error: implicit declaration of function 'devres_alloc' [-Werror=implicit-function-declaration] drivers/base/regmap/regmap.c:338:3: error: implicit declaration of function 'devres_add' [-Werror=implicit-function-declaration] drivers/base/regmap/regmap.c:340:3: error: implicit declaration of function 'devres_free' [-Werror=implicit-function-declaration] drivers/base/regmap/regmap.c: In function '_regmap_raw_write': drivers/base/regmap/regmap.c:421:5: error: implicit declaration of function 'dev_err' [-Werror=implicit-function-declaration] Signed-off-by: Stephen Warren <swarren@wwwdotorg.org> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-03-09Merge 3.3-rc6 into driver-core-nextGreg Kroah-Hartman
This was done to resolve a conflict in the drivers/base/cpu.c file. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-09driver-core: remove legacy iSeries hackStephen Rothwell
The PowerPC legacy iSeries plateform is being removed along with the "one looney iseries driver", so this code can now be removed as well. cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2012-03-08driver core: minor comment formatting cleanupsGreg Kroah-Hartman
Came in in the deferred probe patch, quick, clean them up before a kernel janitor finds them and sends me 4 individual patches to fix them up... Cc: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-08driver core: move the deferred probe pointer into the private areaGreg Kroah-Hartman
Nothing outside of the driver core needs to get to the deferred probe pointer, so move it inside the private area of 'struct device' so no one tries to mess around with it. Cc: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-08drivercore: Add driver probe deferral mechanismGrant Likely
Allow drivers to report at probe time that they cannot get all the resources required by the device, and should be retried at a later time. This should completely solve the problem of getting devices initialized in the right order. Right now this is mostly handled by mucking about with initcall ordering which is a complete hack, and doesn't even remotely handle the case where device drivers are in modules. This approach completely sidesteps the issues by allowing driver registration to occur in any order, and any driver can request to be retried after a few more other drivers get probed. v4: - Integrate Manjunath's addition of a separate workqueue - Change -EAGAIN to -EPROBE_DEFER for drivers to trigger deferral - Update comment blocks to reflect how the code really works v3: - Hold off workqueue scheduling until late_initcall so that the bulk of driver probes are complete before we start retrying deferred devices. - Tested with simple use cases. Still needs more testing though. Using it to get rid of the gpio early_initcall madness, or to replace the ASoC internal probe deferral code would be ideal. v2: - added locking so it should no longer be utterly broken in that regard - remove device from deferred list at device_del time. - Still completely untested with any real use case, but has been boot tested. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Cc: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Dilan Lee <dilee@nvidia.com> Cc: Manjunath GKondaiah <manjunath.gkondaiah@linaro.org> Cc: Alan Stern <stern@rowland.harvard.edu> Cc: Tony Lindgren <tony@atomide.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Reviewed-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: David Daney <david.daney@cavium.com> Reviewed-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-05regmap: Fix rbtree block base in syncMark Brown
Otherwise we'll end up running with bogus register numbers. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-03-05regcache: Make sure we sync register 0 in an rbtree cacheMark Brown
Most of the current users have register 0 as a volatile register or don't have a register 0 so it's not been apparent that it's not getting synced. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-03-04Merge branch 'pm-domains'Rafael J. Wysocki
* pm-domains: PM / Domains: Fix include for PM_GENERIC_DOMAINS=n case PM / Domains: Provide a dummy dev_gpd_data() when generic domains are not used PM / Domains: Run late/early device suspend callbacks at the right time ARM: EXYNOS: Hook up power domains to generic power domain infrastructure PM / Domains: Add OF support
2012-03-04Merge branch 'pm-sleep'Rafael J. Wysocki
* pm-sleep: PM / Freezer: Remove references to TIF_FREEZE in comments PM / Sleep: Add more wakeup source initialization routines PM / Hibernate: Enable usermodehelpers in hibernate() error path PM / Sleep: Make __pm_stay_awake() delete wakeup source timers PM / Sleep: Fix race conditions related to wakeup source timer function PM / Sleep: Fix possible infinite loop during wakeup source destruction PM / Hibernate: print physical addresses consistently with other parts of kernel PM: Add comment describing relationships between PM callbacks to pm.h PM / Sleep: Drop suspend_stats_update() PM / Sleep: Make enter_state() in kernel/power/suspend.c static PM / Sleep: Unify kerneldoc comments in kernel/power/suspend.c PM / Sleep: Remove unnecessary label from suspend_freeze_processes() PM / Sleep: Do not check wakeup too often in try_to_freeze_tasks() PM / Sleep: Initialize wakeup source locks in wakeup_source_add() PM / Hibernate: Refactor and simplify freezer_test_done PM / Hibernate: Thaw kernel threads in hibernation_snapshot() in error/test path PM / Freezer / Docs: Document the beauty of freeze/thaw semantics PM / Suspend: Avoid code duplication in suspend statistics update PM / Sleep: Introduce generic callbacks for new device PM phases PM / Sleep: Introduce "late suspend" and "early resume" of devices
2012-03-04PM / Sleep: Add more wakeup source initialization routinesRafael J. Wysocki
The existing wakeup source initialization routines are not particularly useful for wakeup sources that aren't created by wakeup_source_create(), because their users have to open code filling the objects with zeros and setting their names. For this reason, introduce routines that can be used for initializing, for example, static wakeup source objects. Requested-by: Arve Hjønnevåg <arve@android.com> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2012-03-04PM / Sleep: Make __pm_stay_awake() delete wakeup source timersRafael J. Wysocki
If __pm_stay_awake() is called after __pm_wakeup_event() for the same wakep source object before its timer expires, it won't cancel the timer, so the wakeup source will be deactivated from the timer function as scheduled by __pm_wakeup_event(). In that case __pm_stay_awake() doesn't have any effect beyond incrementing the wakeup source's event_count field, although it should cancel the timer and make the wakeup source stay active until __pm_relax() is called for it. To fix this problem make __pm_stay_awake() delete the wakeup source's timer and ensure that it won't be deactivated from the timer funtion afterwards by clearing its timer_expires field. Reported-by: Arve Hjønnevåg <arve@android.com> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2012-03-04PM / Sleep: Fix race conditions related to wakeup source timer functionRafael J. Wysocki
If __pm_wakeup_event() has been used (with a nonzero timeout) to report a wakeup event and then __pm_relax() immediately followed by __pm_stay_awake() is called or __pm_wakeup_event() is called once again for the same wakeup source object before its timer expires, the timer function pm_wakeup_timer_fn() may still be run as a result of the previous __pm_wakeup_event() call. In either of those cases it may mistakenly deactivate the wakeup source that has just been activated. To prevent that from happening, make wakeup_source_deactivate() clear the wakeup source's timer_expires field and make pm_wakeup_timer_fn() check if timer_expires is different from zero and if it's not in future before calling wakeup_source_deactivate() (if timer_expires is 0, it means that the timer has just been deleted and if timer_expires is in future, it means that the timer has just been rescheduled to a different time). Reported-by: Arve Hjønnevåg <arve@android.com> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2012-03-04PM / Sleep: Fix possible infinite loop during wakeup source destructionRafael J. Wysocki
If wakeup_source_destroy() is called for an active wakeup source that is never deactivated, it will spin forever. To prevent that from happening, make wakeup_source_destroy() call __pm_relax() for the wakeup source object it is about to free instead of waiting until it will be deactivated by someone else. However, for this to work it also needs to make sure that the timer function will not be executed after the final __pm_relax(), so make it run del_timer_sync() on the wakeup source's timer beforehand. Additionally, update the kerneldoc comment to document the requirement that __pm_stay_awake() and __pm_wakeup_event() must not be run in parallel with wakeup_source_destroy(). Reported-by: Arve Hjønnevåg <arve@android.com> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2012-03-01regmap: delete unused module.h from drivers/base/regmap filesPaul Gortmaker
Remove unused module.h and/or replace with export.h as required. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-02-27regmap: Fix x86_64 breakageMark Brown
2012-02-24regmap: Allow drivers to sync only part of the register cacheMark Brown
Provide a regcache_sync_region() operation which allows drivers to write only part of the cache back to the hardware. This is intended for use in cases like power domains or DSP memories where part of the device register map may be reset without fully resetting the device. Fully supporting these devices is likely to require additional work to make specific regions of the register map cache only while they are in reset, but this is enough for most devices. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-02-24regmap: Supply ranges to the sync operationsMark Brown
In order to allow us to support partial sync operations add minimum and maximum register arguments to the sync operation and update the rbtree and lzo caches to use this new information. The LZO implementation is obviously not good, we could exit the iteration earlier, but there may be room for more wide reaching optimisation there. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-02-23regmap: Add tracepoints for cache only and cache bypassMark Brown
Useful for figuring out where the hardware interaction went or came from. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-02-23regmap: Mark the cache as clean after a successful syncMark Brown
Previously the cache would never be marked clean, meaning syncs would never be suppressed which isn't the end of the world but could be inefficient. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-02-23regmap: Remove default cache sync implementationMark Brown
It's not used as all cache types have sync operations so it's just dead code which never gets tested. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-02-23regmap: Skip hardware defaults for LZO cachesMark Brown
Saves some I/O when resyncing; we assume that syncs start from the device reset state. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-02-22regmap: Expose the driver name in debugfsDimitris Papastamos
Add a file called 'name' containing the name of the driver. Signed-off-by: Dimitris Papastamos <dp@opensource.wolfsonmicro.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-02-22regmap: Add support for writing to regmap registers via debugfsDimitris Papastamos
To enable writing to the regmap debugfs registers file users will need to modify the source directly and #define REGMAP_ALLOW_WRITE_DEBUGFS. The reason for this is that it is dangerous to expose this functionality in general where clients could potentially be PMICs. [A couple of minor style updates -- broonie] Signed-off-by: Dimitris Papastamos <dp@opensource.wolfsonmicro.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-02-21Merge tag 'topic/introspection' of ↵Mark Brown
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regmap into HEAD New interfaces to allow other subsystems to gather information about the regmap, allowing them to build further subsystem specific generic features on top of the regmap. Merged into ASoC in order to allow us to implement SND_SOC_BYTES_MASK() controls which need to know the word size of the underlying registers.
2012-02-21regmap: Support raw reads from cached registersMark Brown
Fall back to a register by register read to do so; most likely we'll be cache only so the overhead will be low. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-02-20Merge branch 'topic/patch' of ↵Mark Brown
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regmap into regmap-drivers
