path: root/drivers/base
2015-03-06Merge branches 'pm-domains' and 'pm-cpufreq'Rafael J. Wysocki
* pm-domains: PM / Domains: cleanup: rename gpd -> genpd in debugfs interface * pm-cpufreq: cpufreq: ppc: Add missing #include <asm/smp.h>
2015-03-04PM / wakeup: export pm_system_wakeup symbolBoris BREZILLON
Export pm_system_wakeup function to allow irq handlers to deal with system wakeup. This is needed for shared IRQ lines where one of the handler is registered with IRQF_NO_SUSPEND, while the other ones want to configure it as a wakeup source. In this specific case, irq core does not handle the wakeup process and leave the decision to each irq handler. Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com> Reviewed-by: Alexandre Belloni <alexandre.belloni@free-electrons.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Acked-by: Mark Rutland <mark.rutland@arm.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-03-04PM / Domains: cleanup: rename gpd -> genpd in debugfs interfaceKevin Hilman
To keep consisitency with the rest of the file, use 'genpd' as the name of the 'struct generic_pm_domain' pointer instead of 'gpd'. This is just a rename, no functional changes. Signed-off-by: Kevin Hilman <khilman@linaro.org> Acked-by: Pavel Machek <pavel@ucw.cz> Reviewed-by: Ulf Hansson <ulf.hansson@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-02-15Merge tag 'driver-core-3.20-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core patches from Greg KH: "Really tiny set of patches for this kernel. Nothing major, all described in the shortlog and have been in linux-next for a while" * tag 'driver-core-3.20-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: sysfs: fix warning when creating a sysfs group without attributes firmware_loader: handle timeout via wait_for_completion_interruptible_timeout() firmware_loader: abort request if wait_for_completion is interrupted firmware: Correct function name in comment device: Change dev_<level> logging functions to return void device: Fix dev_dbg_once macro
2015-02-14Merge branch 'akpm' (patches from Andrew)Linus Torvalds
Merge fourth set of updates from Andrew Morton: - the rest of lib/ - checkpatch updates - a few misc things - kasan: kernel address sanitizer - the rtc tree * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (108 commits) ARM: mvebu: enable Armada 38x RTC driver in mvebu_v7_defconfig ARM: mvebu: add Device Tree description of RTC on Armada 38x MAINTAINERS: add the RTC driver for the Armada38x drivers/rtc/rtc-armada38x: add a new RTC driver for recent mvebu SoCs rtc: armada38x: add the device tree binding documentation rtc: rtc-ab-b5ze-s3: add sub-minute alarm support rtc: add support for Abracon AB-RTCMC-32.768kHz-B5ZE-S3 I2C RTC chip of: add vendor prefix for Abracon Corporation drivers/rtc/rtc-rk808.c: fix rtc time reading issue drivers/rtc/rtc-isl12057.c: constify struct regmap_config drivers/rtc/rtc-at91sam9.c: constify struct regmap_config drivers/rtc/rtc-imxdi.c: add more known register bits drivers/rtc/rtc-imxdi.c: trivial clean up code ARM: mvebu: ISL12057 rtc chip can now wake up RN102, RN102 and RN2120 rtc: rtc-isl12057: add isil,irq2-can-wakeup-machine property for in-tree users drivers/rtc/rtc-isl12057.c: add alarm support to Intersil ISL12057 RTC driver drivers/rtc/rtc-pcf2123.c: add support for devicetree kprobes: makes kprobes/enabled works correctly for optimized kprobes. kprobes: set kprobes_all_disarmed earlier to enable re-optimization. init: remove CONFIG_INIT_FALLBACK ...
2015-02-13drivers/base: use %*pb[l] to print bitmaps including cpumasks and nodemasksTejun Heo
printk and friends can now format bitmaps using '%*pb[l]'. cpumask and nodemask also provide cpumask_pr_args() and nodemask_pr_args() respectively which can be used to generate the two printf arguments necessary to format the specified cpu/nodemask. * Line termination only requires one extra space at the end of the buffer. Use PAGE_SIZE - 1 instead of PAGE_SIZE - 2 when formatting. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-13Merge branches 'pm-cpufreq', 'pm-cpuidle', 'pm-devfreq', 'pm-opp' and 'pm-tools'Rafael J. Wysocki
* pm-cpufreq: cpufreq: speedstep-smi: enable interrupts when waiting * pm-cpuidle: intel_idle: support additional Broadwell model * pm-devfreq: PM / devfreq: event: testing the wrong variable * pm-opp: PM / OPP / clk: Remove unnecessary OOM message * pm-tools: tools/power turbostat: support additional Broadwell model tools/power turbostat: update parameters, documentation tools/power turbostat: Skip printing disabled package C-states
2015-02-12PM / OPP / clk: Remove unnecessary OOM messageQuentin Lambert
This patch reduces the kernel size by removing error messages that duplicate the normal OOM message. A simplified version of the semantic patch that finds this problem is as follows: (http://coccinelle.lip6.fr) @@ identifier f,print,l; expression e; constant char[] c; @@ e = \(kzalloc\|kmalloc\|devm_kzalloc\|devm_kmalloc\)(...); if (e == NULL) { <+... - print(...,c,...); ... when any ( goto l; | return ...; ) ...+> } Signed-off-by: Quentin Lambert <lambert.quentin@gmail.com> Acked-by: Nishanth Menon <nm@ti.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-02-10Merge tag 'pm+acpi-3.20-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull ACPI and power management updates from Rafael Wysocki: "We have a few new features this time, including a new SFI-based cpufreq driver, a new devfreq driver for Tegra Activity Monitor, a new devfreq class for providing its governors with raw utilization data and a new ACPI driver for AMD SoCs. Still, the majority of changes here are reworks of existing code to make it more straightforward or to prepare it for implementing new features on top of it. The primary example is the rework of ACPI resources handling from Jiang Liu, Thomas Gleixner and Lv Zheng with support for IOAPIC hotplug implemented on top of it, but there is quite a number of changes of this kind in the cpufreq core, ACPICA, ACPI EC driver, ACPI processor driver and the generic power domains core code too. The most active developer is Viresh Kumar with his cpufreq changes. Specifics: - Rework of the core ACPI resources parsing code to fix issues in it and make using resource offsets more convenient and consolidation of some resource-handing code in a couple of places that have grown analagous data structures and code to cover the the same gap in the core (Jiang Liu, Thomas Gleixner, Lv Zheng). - ACPI-based IOAPIC hotplug support on top of the resources handling rework (Jiang Liu, Yinghai Lu). - ACPICA update to upstream release 20150204 including an interrupt handling rework that allows drivers to install raw handlers for ACPI GPEs which then become entirely responsible for the given GPE and the ACPICA core code won't touch it (Lv Zheng, David E Box, Octavian Purdila). - ACPI EC driver rework to fix several concurrency issues and other problems related to events handling on top of the ACPICA's new support for raw GPE handlers (Lv Zheng). - New ACPI driver for AMD SoCs analogous to the LPSS (Low-Power Subsystem) driver for Intel chips (Ken Xue). - Two minor fixes of the ACPI LPSS driver (Heikki Krogerus, Jarkko Nikula). - Two new blacklist entries for machines (Samsung 730U3E/740U3E and 510R) where the native backlight interface doesn't work correctly while the ACPI one does (Hans de Goede). - Rework of the ACPI processor driver's handling of idle states to make the code more straightforward and less bloated overall (Rafael J Wysocki). - Assorted minor fixes related to ACPI and SFI (Andreas Ruprecht, Andy Shevchenko, Hanjun Guo, Jan Beulich, Rafael J Wysocki, Yaowei Bai). - PCI core power management modification to avoid resuming (some) runtime-suspended devices during system suspend if they are in the right states already (Rafael J Wysocki). - New SFI-based cpufreq driver for Intel platforms using SFI (Srinidhi Kasagar). - cpufreq core fixes, cleanups and simplifications (Viresh Kumar, Doug Anderson, Wolfram Sang). - SkyLake CPU support and other updates for the intel_pstate driver (Kristen Carlson Accardi, Srinivas Pandruvada). - cpufreq-dt driver cleanup (Markus Elfring). - Init fix for the ARM big.LITTLE cpuidle driver (Sudeep Holla). - Generic power domains core code fixes and cleanups (Ulf Hansson). - Operating Performance Points (OPP) core code cleanups and kernel documentation update (Nishanth Menon). - New dabugfs interface to make the list of PM QoS constraints available to user space (Nishanth Menon). - New devfreq driver for Tegra Activity Monitor (Tomeu Vizoso). - New devfreq class (devfreq_event) to provide raw utilization data to devfreq governors (Chanwoo Choi). - Assorted minor fixes and cleanups related to power management (Andreas Ruprecht, Krzysztof Kozlowski, Rickard Strandqvist, Pavel Machek, Todd E Brandt, Wonhong Kwon). - turbostat updates (Len Brown) and cpupower Makefile improvement (Sriram Raghunathan)" * tag 'pm+acpi-3.20-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (151 commits) tools/power turbostat: relax dependency on APERF_MSR tools/power turbostat: relax dependency on invariant TSC Merge branch 'pci/host-generic' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci into acpi-resources tools/power turbostat: decode MSR_*_PERF_LIMIT_REASONS tools/power turbostat: relax dependency on root permission ACPI / video: Add disable_native_backlight quirk for Samsung 510R ACPI / PM: Remove unneeded nested #ifdef USB / PM: Remove unneeded #ifdef and associated dead code intel_pstate: provide option to only use intel_pstate with HWP ACPI / EC: Add GPE reference counting debugging messages ACPI / EC: Add query flushing support ACPI / EC: Refine command storm prevention support ACPI / EC: Add command flushing support. ACPI / EC: Introduce STARTED/STOPPED flags to replace BLOCKED flag ACPI: add AMD ACPI2Platform device support for x86 system ACPI / table: remove duplicate NULL check for the handler of acpi_table_parse() ACPI / EC: Update revision due to raw handler mode. ACPI / EC: Reduce ec_poll() by referencing the last register access timestamp. ACPI / EC: Fix several GPE handling issues by deploying ACPI_GPE_DISPATCH_RAW_HANDLER mode. ACPICA: Events: Enable APIs to allow interrupt/polling adaptive request based GPE handling model ...
2015-02-10Merge branch 'pm-domains'Rafael J. Wysocki
* pm-domains: PM: Convert dev_pm_put_subsys_data() into a void function PM: Update function header for dev_pm_get_subsys_data() PM / Domains: Handle errors from genpd's ->attach_dev() callback PM / Domains: Re-order initialization of generic_pm_domain_data PM / Domains: Free pm_subsys_data in error path in __pm_genpd_add_device() PM / Domains: Eliminate the mutex for the generic_pm_domain_data PM / Domains: Don't check for an existing device when adding a new PM / Domains: Don't allow an existing generic_pm_domain_data PM / Domains: Remove reference counting for the generic_pm_domain_data PM / Domains: Rename __pm_genpd_alloc|free_dev_data() PM / Domains: Remove pm_genpd_dev_need_restore() API
2015-02-10Merge branches 'pm-qos', 'pm-opp' and 'pm-devfreq'Rafael J. Wysocki
* pm-qos: PM / QoS: Use lockdep asserts to find missing hold of power.lock PM / QoS: Add debugfs support to view the list of constraints * pm-opp: PM / OPP: Assert RCU lock in exported functions PM / OPP: Update kernel documentation PM / OPP: Ensure consistent naming of static functions PM / OPP: export dev_pm_opp_get_notifier * pm-devfreq: PM / devfreq: event: Add documentation for exynos-ppmu devfreq-event driver devfreq: Fix build break of devfreq-event class PM / devfreq: event: Add devfreq_event class PM / devfreq: tegra: add devfreq driver for Tegra Activity Monitor
2015-02-08Merge remote-tracking branches 'regmap/topic/ac97', 'regmap/topic/doc' and ↵Mark Brown
'regmap/topic/smbus' into regmap-next
2015-02-08Merge remote-tracking branch 'regmap/topic/core' into regmap-nextMark Brown
2015-02-04regmap: Fix i2c word access when using SMBus access functionsGuenter Roeck
SMBus access functions assume that 16-bit values are formatted as little endian numbers. The direct i2c access functions in regmap, however, assume that 16-bit values are formatted as big endian numbers. As a result, the current code returns different values if an i2c chip's 16-bit registers are accessed through i2c access functions vs. SMBus access functions. Use regmap_smbus_read_word_swapped and regmap_smbus_write_word_swapped for 16-bit SMBus accesses if a chip is configured as REGMAP_ENDIAN_BIG. If the chip is configured as REGMAP_ENDIAN_LITTLE, keep using regmap_smbus_write_word_data and regmap_smbus_read_word_data. Otherwise reject registration if the controller does not support direct i2c accesses. Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Mark Brown <broonie@kernel.org>
2015-02-04regmap: Export regmap_get_val_endianGuenter Roeck
We'll need to call it from regmap-i2c.c, which can be built as module. Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Mark Brown <broonie@kernel.org>
2015-02-03firmware_loader: handle timeout via wait_for_completion_interruptible_timeout()Ming Lei
It is simpler to handle timeout by wait_for_completion_interruptible_timeout(), so remove previous delay work for timeout. Signed-off-by: Ming Lei <ming.lei@canonical.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-02-03firmware_loader: abort request if wait_for_completion is interruptedMing Lei
If current request is interrupted by signal, such as 'ctrl + c', this request has to be aborted for the following reasons: - the buf need to be removed from pending list - same requests from other contexts need to be completed Reported-by: Sasha Levin <sasha.levin@oracle.com> Signed-off-by: Ming Lei <ming.lei@canonical.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-02-03firmware: Correct function name in commentBorislav Petkov
Use the correct function name in the kernel-doc comment above it. Signed-off-by: Borislav Petkov <bp@suse.de> Acked-by: Ming Lei <ming.lei@canonical.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-02-03PM: Convert dev_pm_put_subsys_data() into a void functionUlf Hansson
Clients using the dev_pm_put_subsys_data() API isn't interested of a return value. They care only of decreasing a reference to the device's pm_subsys_data. So, let's convert the API to a void function, which anyway seems like reasonable thing to do. Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-02-03PM: Update function header for dev_pm_get_subsys_data()Ulf Hansson
The commit "PM: Make dev_pm_get_subsys_data() always return 0 on success" changed the return value from dev_pm_get_subsys_data(). Let's update the comment in the function header to reflect this change as well. Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Acked-by: Geert Uytterhoeven <geert+renesas@glider.be> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-02-03PM / Domains: Handle errors from genpd's ->attach_dev() callbackUlf Hansson
The optional genpd's ->attach_dev() callback is invoked from __pm_genpd_add_device(). Let's add error handling from the response from this callback and propagate the error code. When __pm_genpd_add_device() is invoked through the generic OF-based PM domain look-up path, the device is being probed. Returning an error will mean the device won't be attached to its PM domain. Errors of -EPROBE_DEFER get special treatment and is propagated to the driver core. Therefore this change also enables the ->attach_dev() callback to be able to request for a deferred probe sequence. Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-02-03PM / Domains: Re-order initialization of generic_pm_domain_dataUlf Hansson
Move the initialization of the struct generic_pm_domain_data into genpd_alloc_dev_data(), including the assignment of the device's ->pm_domain() callback. Make corresponding changes to genpd_free_dev_data(). These changes will make the related code more readable. It will also decrease the critical regions for where genpd's mutex is being held and for where the device's power related spinlock is being held. Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-02-03PM / Domains: Free pm_subsys_data in error path in __pm_genpd_add_device()Ulf Hansson
The error path in __pm_genpd_add_device() didn't decrease the reference to the struct pm_subsys_data. Let's move the calls to dev_pm_get|put_subsys_data() into genpd_alloc|free_dev_data() to fix this issue and thus prevent a potential memory leakage. Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-02-03PM / Domains: Eliminate the mutex for the generic_pm_domain_dataUlf Hansson
While adding devices to their PM domains, dev_pm_qos_add_notifier() was invoked while allocating the generic_pm_domain_data for the device. Since the generic_pm_domain_data's device pointer will be assigned after allocation, the ->genpd_dev_pm_qos_notifier() callback could be called prior having a valid pointer to the device. Similar scenario existed while removing a device from a genpd. To cope with these scenarios a mutex was used to protect the pointer to the device. By re-order the sequence for when dev_pm_qos_add|remove_notifier() are invoked, we make sure the ->genpd_dev_pm_qos_notifier() callback are always called with a valid device pointer available. In this way, we eliminate the need for protecting the pointer and thus we can remove the mutex from the struct generic_pm_domain_data. Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-02-03PM / Domains: Don't check for an existing device when adding a newUlf Hansson
When adding a device to a genpd, we no longer need to walk genpd's list of existing devices to verify it hasn't already been added. Instead we can now rely on the verification of not allowing existing generic_pm_domain_data for a device, since that has the same meaning. Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-02-03PM / Domains: Don't allow an existing generic_pm_domain_dataUlf Hansson
When adding a device to a genpd, a struct generic_pm_domain_data is allocated per device. Verify that there are no existing generic_pm_domain_data for the device we are about to add, since that tells us it has already been added to a genpd. When genpd supported PM domain device callbacks, this was a valid scenario. Now it isn't so let's return an error code. Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-02-03PM / Domains: Remove reference counting for the generic_pm_domain_dataUlf Hansson
The reference counting was needed when genpd supported PM domain device callbacks. Since this option has been removed, let's also remove the reference counting of the struct generic_pm_domain_data. Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-02-03PM / Domains: Rename __pm_genpd_alloc|free_dev_data()Ulf Hansson
In a step to get consistent names of functions in genpd, rename the internal __pm_genpd_alloc|free_dev_data() into gendp_alloc|free_dev_data(). As discussed on the linux-pm list, let's move towards the following name rules: Internal functions: genpd_* _genpd_* __genpd_* External functions: pm_genpd_* _pm_genpd_* __pm_genpd_* Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-02-02regmap: ac97: Clean up indentationMark Brown
2015-01-26device: Change dev_<level> logging functions to return voidJoe Perches
No caller or macro uses the return value so make all the functions return void. Compiled x86 allyesconfig and defconfig w/o CONFIG_PRINTK Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-23PM / Domains: Remove pm_genpd_dev_need_restore() APIUlf Hansson
There are currently no users of this API, let's remove it. Additionally, if such feature would be needed future wise, a better option is likely use pm_runtime_set_active|suspended() in some form. Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Acked-by: Geert Uytterhoeven <geert+renesas@glider.be> Acked-by: Kevin Hilman <khilman@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-01-23PM / OPP: Assert RCU lock in exported functionsKrzysztof Kozlowski
Add lockdep asserts for holding the RCU lock when calling dev_pm_opp_get_freq() and dev_pm_opp_get_voltage() to aid in detecting RCU misuses. These are called often after dev_pm_opp_find_freq_ceil/exact() which already asserts for RCU lock. However one could make an error by releasing lock too early - just after dev_pm_opp_find_freq_ceil(). Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-01-23PM / QoS: Use lockdep asserts to find missing hold of power.lockKrzysztof Kozlowski
Add lockdep asserts for holding the dev->power.lock to non-static functions which require this. They could be used outside of the file so asserts may help in detecting locking misuse. Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-01-23PM / OPP: Update kernel documentationNishanth Menon
kernel doc has gotten bit-rotted over time. Re-sync with Locking and Return information. document all functions properly and ensure that ./scripts/kernel-doc -v ./drivers/base/power/opp.c >/dev/null returns no errors Signed-off-by: Nishanth Menon <nm@ti.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-01-23PM / OPP: Ensure consistent naming of static functionsNishanth Menon
All exported functions use dev_pm_* prefix and all static functions are now standardized with _ prefix. This is better than having to deal with multiple function naming styles within the same file. Signed-off-by: Nishanth Menon <nm@ti.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-01-23PM / OPP: export dev_pm_opp_get_notifierNishanth Menon
Allows user drivers such as devfreq to be modules. Signed-off-by: Nishanth Menon <nm@ti.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-12-29Merge branches 'pm-domains', 'powercap' and 'pm-tools'Rafael J. Wysocki
* pm-domains: PM / Domains: Export of_genpd_get_from_provider function * powercap: powercap / RAPL: add IDs for future Xeon CPUs * pm-tools: tools / cpupower: Fix no idle state information return value tools / cpupower: Correctly detect if running as root
2014-12-29Merge branch 'pm-opp'Rafael J. Wysocki
* pm-opp: PM / OPP: take RCU lock in dev_pm_opp_get_opp_count PM / OPP: fix warning in of_free_opp_table() PM / OPP: add some lockdep annotations
2014-12-18Merge tag 'pm+acpi-3.19-rc1-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull more ACPI and power management updates from Rafael Wysocki: "These are regression fixes (leds-gpio, ACPI backlight driver, operating performance points library, ACPI device enumeration messages, cpupower tool), other bug fixes (ACPI EC driver, ACPI device PM), some cleanups in the operating performance points (OPP) framework, continuation of CONFIG_PM_RUNTIME elimination, a couple of minor intel_pstate driver changes, a new MAINTAINERS entry for it and an ACPI fan driver change needed for better support of thermal management in user space. Specifics: - Fix a regression in leds-gpio introduced by a recent commit that inadvertently changed the name of one of the properties used by the driver (Fabio Estevam). - Fix a regression in the ACPI backlight driver introduced by a recent fix that missed one special case that had to be taken into account (Aaron Lu). - Drop the level of some new kernel messages from the ACPI core introduced by a recent commit to KERN_DEBUG which they should have used from the start and drop some other unuseful KERN_ERR messages printed by ACPI (Rafael J Wysocki). - Revert an incorrect commit modifying the cpupower tool (Prarit Bhargava). - Fix two regressions introduced by recent commits in the OPP library and clean up some existing minor issues in that code (Viresh Kumar). - Continue to replace CONFIG_PM_RUNTIME with CONFIG_PM throughout the tree (or drop it where that can be done) in order to make it possible to eliminate CONFIG_PM_RUNTIME (Rafael J Wysocki, Ulf Hansson, Ludovic Desroches). There will be one more "CONFIG_PM_RUNTIME removal" batch after this one, because some new uses of it have been introduced during the current merge window, but that should be sufficient to finally get rid of it. - Make the ACPI EC driver more robust against race conditions related to GPE handler installation failures (Lv Zheng). - Prevent the ACPI device PM core code from attempting to disable GPEs that it has not enabled which confuses ACPICA and makes it report errors unnecessarily (Rafael J Wysocki). - Add a "force" command line switch to the intel_pstate driver to make it possible to override the blacklisting of some systems in that driver if needed (Ethan Zhao). - Improve intel_pstate code documentation and add a MAINTAINERS entry for it (Kristen Carlson Accardi). - Make the ACPI fan driver create cooling device interfaces witn names that reflect the IDs of the ACPI device objects they are associated with, except for "generic" ACPI fans (PNP ID "PNP0C0B"). That's necessary for user space thermal management tools to be able to connect the fans with the parts of the system they are supposed to be cooling properly. From Srinivas Pandruvada" * tag 'pm+acpi-3.19-rc1-2' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (32 commits) MAINTAINERS: add entry for intel_pstate ACPI / video: update the skip case for acpi_video_device_in_dod() power / PM: Eliminate CONFIG_PM_RUNTIME NFC / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM SCSI / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM ACPI / EC: Fix unexpected ec_remove_handlers() invocations Revert "tools: cpupower: fix return checks for sysfs_get_idlestate_count()" tracing / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM x86 / PM: Replace CONFIG_PM_RUNTIME in io_apic.c PM: Remove the SET_PM_RUNTIME_PM_OPS() macro mmc: atmel-mci: use SET_RUNTIME_PM_OPS() macro PM / Kconfig: Replace PM_RUNTIME with PM in dependencies ARM / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM sound / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM phy / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM video / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM tty / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM spi: Replace CONFIG_PM_RUNTIME with CONFIG_PM ACPI / PM: Do not disable wakeup GPEs that have not been enabled ACPI / utils: Drop error messages from acpi_evaluate_reference() ...
2014-12-18Merge branches 'pm-opp', 'pm-cpufreq' and 'pm-tools'Rafael J. Wysocki
* pm-opp: PM / OPP: do error handling at the bottom of dev_pm_opp_add_dynamic() PM / OPP: handle allocation of device_opp in a separate routine PM / OPP: reuse find_device_opp() instead of duplicating code PM / OPP: Staticize __dev_pm_opp_remove() PM / OPP: replace kfree with kfree_rcu while freeing 'struct device_opp' * pm-cpufreq: MAINTAINERS: add entry for intel_pstate intel_pstate: Add a few comments intel_pstate: add kernel parameter to force loading * pm-tools: Revert "tools: cpupower: fix return checks for sysfs_get_idlestate_count()"
2014-12-18PM / OPP: take RCU lock in dev_pm_opp_get_opp_countDmitry Torokhov
A lot of callers are missing the fact that dev_pm_opp_get_opp_count needs to be called under RCU lock. Given that RCU locks can safely be nested, instead of providing *_locked() API, let's take RCU lock inside dev_pm_opp_get_opp_count() and leave callers as is. Signed-off-by: Dmitry Torokhov <dtor@chromium.org> Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-12-18PM / OPP: fix warning in of_free_opp_table()Dmitry Torokhov
Not having OPP defined for a device is not a crime, we should not splat warning in this case. Also, it seems that we are ready to accept invalid dev (find_device_opp will return ERR_PTR(-EINVAL) then) so let's not crash in dev_name() in such case. Signed-off-by: Dmitry Torokhov <dtor@chromium.org> Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-12-18PM / OPP: add some lockdep annotationsDmitry Torokhov
Certain OPP APIs need to be called under RCU lock; let's add a few rcu_lockdep_assert() calls to warn about potential misuse. Signed-off-by: Dmitry Torokhov <dtor@chromium.org> Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-12-17PM / Domains: Export of_genpd_get_from_provider functionAmit Daniel Kachhap
This function looks up a PM domain form the provider. This will be useful to add parent/child domain relationship from the SoC specific code. The caller of the function must make sure that PM domain provider is already registered. Reviewed-by: Ulf Hansson <ulf.hansson@linaro.org> Signed-off-by: Amit Daniel Kachhap <amit.daniel@samsung.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-12-15regmap: Move spinlock_flags into the unionWang, Yalin
This patch move struct regmap.spinlock_flags into the union of spinlock, so that we can shrink struct regmap size. Signed-off-by: Yalin Wang <yalin.wang@sonymobile.com> Signed-off-by: Mark Brown <broonie@kernel.org>
2014-12-14Merge tag 'driver-core-3.19-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core update from Greg KH: "Here's the set of driver core patches for 3.19-rc1. They are dominated by the removal of the .owner field in platform drivers. They touch a lot of files, but they are "simple" changes, just removing a line in a structure. Other than that, a few minor driver core and debugfs changes. There are some ath9k patches coming in through this tree that have been acked by the wireless maintainers as they relied on the debugfs changes. Everything has been in linux-next for a while" * tag 'driver-core-3.19-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (324 commits) Revert "ath: ath9k: use debugfs_create_devm_seqfile() helper for seq_file entries" fs: debugfs: add forward declaration for struct device type firmware class: Deletion of an unnecessary check before the function call "vunmap" firmware loader: fix hung task warning dump devcoredump: provide a one-way disable function device: Add dev_<level>_once variants ath: ath9k: use debugfs_create_devm_seqfile() helper for seq_file entries ath: use seq_file api for ath9k debugfs files debugfs: add helper function to create device related seq_file drivers/base: cacheinfo: remove noisy error boot message Revert "core: platform: add warning if driver has no owner" drivers: base: support cpu cache information interface to userspace via sysfs drivers: base: add cpu_device_create to support per-cpu devices topology: replace custom attribute macros with standard DEVICE_ATTR* cpumask: factor out show_cpumap into separate helper function driver core: Fix unbalanced device reference in drivers_probe driver core: fix race with userland in device_add() sysfs/kernfs: make read requests on pre-alloc files use the buffer. sysfs/kernfs: allow attributes to request write buffer be pre-allocated. fs: sysfs: return EGBIG on write if offset is larger than file size ...
2014-12-13memory-hotplug: remove redundant call of page_to_pfnZhang Zhen
This is just a small optimization. The start_pfn can be obtained directly by phys_index << PFN_SECTION_SHIFT. So the call of page_to_pfn() is redundant and remove it. Signed-off-by: Zhang Zhen <zhenzhang.zhang@huawei.com> Acked-by: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com> Acked-by: David Rientjes <rientjes@google.com> Cc: Dave Hansen <dave@sr71.net> Cc: Wang Nan <wangnan0@huawei.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-12-11Merge tag 'devicetree-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/glikely/linux Pull devicetree changes from Grant Likely: "Lots of activity in the devicetree code for v3.18. Most of it is related to getting all of the overlay support code in place, but there are other important things in there. Highlights: - OF_RECONFIG notifiers for SPI, I2C and Platform devices. Those subsystems can now respond to live changes to the device tree. - CONFIG_OF_OVERLAY method for applying live changes to the device tree - Removal of the of_allnodes list. This used to be used to iterate over all the nodes in the device tree, but it is unnecessary because the same thing can be done by iterating over the list of child pointers. Getting rid of of_allnodes saves some memory and avoids the possibility of of_allnodes being sorted differently from the child lists. - Support for retrieving original DTB blob via sysfs. Needed by kexec. - More unittests - Documentation and minor bug fixes" * tag 'devicetree-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/glikely/linux: (42 commits) of: Delete unnecessary check before calling "of_node_put()" of: Drop ->next pointer from struct device_node spi: Check for spi_of_notifier when CONFIG_OF_DYNAMIC=y of: support passing console options with stdout-path of: add optional options parameter to of_find_node_by_path() of: Add bindings for chosen node, stdout-path of: Remove unneeded and incorrect MODULE_DEVICE_TABLE ARM: dt: fix up PL011 device tree bindings of: base, fix of_property_read_string_helper kernel-doc of: remove select of non-existant OF_DEVICE config symbol spi/of: Add OF notifier handler spi/of: Create new device registration method and accessors i2c/of: Add OF_RECONFIG notifier handler i2c/of: Factor out Devicetree registration code of/overlay: Add overlay unittests of/overlay: Introduce DT overlay support of/reconfig: Add OF_DYNAMIC notifier for platform_bus_type of/reconfig: Always use the same structure for notifiers of/reconfig: Add debug output for OF_RECONFIG notifiers of/reconfig: Add empty stubs for the of_reconfig methods ...
2014-12-11Merge branch 'fixes'Rafael J. Wysocki
* fixes: PM / OPP: remove double calls to find_device_opp() PM / OPP: set new_opp->dev_opp to a valid dev_opp leds: leds-gpio: Fix the "default-state" property check
2014-12-10Merge tag 'pm+acpi-3.19-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull ACPI and power management updates from Rafael Wysocki: "This time we have some more new material than we used to have during the last couple of development cycles. The most important part of it to me is the introduction of a unified interface for accessing device properties provided by platform firmware. It works with Device Trees and ACPI in a uniform way and drivers using it need not worry about where the properties come from as long as the platform firmware (either DT or ACPI) makes them available. It covers both devices and "bare" device node objects without struct device representation as that turns out to be necessary in some cases. This has been in the works for quite a few months (and development cycles) and has been approved by all of the relevant maintainers. On top of that, some drivers are switched over to the new interface (at25, leds-gpio, gpio_keys_polled) and some additional changes are made to the core GPIO subsystem to allow device drivers to manipulate GPIOs in the "canonical" way on platforms that provide GPIO information in their ACPI tables, but don't assign names to GPIO lines (in which case the driver needs to do that on the basis of what it knows about the device in question). That also has been approved by the GPIO core maintainers and the rfkill driver is now going to use it. Second is support for hardware P-states in the intel_pstate driver. It uses CPUID to detect whether or not the feature is supported by the processor in which case it will be enabled by default. However, it can be disabled entirely from the kernel command line if necessary. Next is support for a platform firmware interface based on ACPI operation regions used by the PMIC (Power Management Integrated Circuit) chips on the Intel Baytrail-T and Baytrail-T-CR platforms. That interface is used for manipulating power resources and for thermal management: sensor temperature reporting, trip point setting and so on. Also the ACPI core is now going to support the _DEP configuration information in a limited way. Basically, _DEP it supposed to reflect off-the-hierarchy dependencies between devices which may be very indirect, like when AML for one device accesses locations in an operation region handled by another device's driver (usually, the device depended on this way is a serial bus or GPIO controller). The support added this time is sufficient to make the ACPI battery driver work on Asus T100A, but it is general enough to be able to cover some other use cases in the future. Finally, we have a new cpufreq driver for the Loongson1B processor. In addition to the above, there are fixes and cleanups all over the place as usual and a traditional ACPICA update to a recent upstream release. As far as the fixes go, the ACPI LPSS (Low-power Subsystem) driver for Intel platforms should be able to handle power management of the DMA engine correctly, the cpufreq-dt driver should interact with the thermal subsystem in a better way and the ACPI backlight driver should handle some more corner cases, among other things. On top of the ACPICA update there are fixes for race conditions in the ACPICA's interrupt handling code which might lead to some random and strange looking failures on some systems. In the cleanups department the most visible part is the series of commits targeted at getting rid of the CONFIG_PM_RUNTIME configuration option. That was triggered by a discussion regarding the generic power domains code during which we realized that trying to support certain combinations of PM config options was painful and not really worth it, because nobody would use them in production anyway. For this reason, we decided to make CONFIG_PM_SLEEP select CONFIG_PM_RUNTIME and that lead to the conclusion that the latter became redundant and CONFIG_PM could be used instead of it. The material here makes that replacement in a major part of the tree, but there will be at least one more batch of that in the second part of the merge window. Specifics: - Support for retrieving device properties information from ACPI _DSD device configuration objects and a unified device properties interface for device drivers (and subsystems) on top of that. As stated above, this works with Device Trees and ACPI and allows device drivers to be written in a platform firmware (DT or ACPI) agnostic way. The at25, leds-gpio and gpio_keys_polled drivers are now going to use this new interface and the GPIO subsystem is additionally modified to allow device drivers to assign names to GPIO resources returned by ACPI _CRS objects (in case _DSD is not present or does not provide the expected data). The changes in this set are mostly from Mika Westerberg, Rafael J Wysocki, Aaron Lu, and Darren Hart with some fixes from others (Fabio Estevam, Geert Uytterhoeven). - Support for Hardware Managed Performance States (HWP) as described in Volume 3, section 14.4, of the Intel SDM in the intel_pstate driver. CPUID is used to detect whether or not the feature is supported by the processor. If supported, it will be enabled automatically unless the intel_pstate=no_hwp switch is present in the kernel command line. From Dirk Brandewie. - New Intel Broadwell-H ID for intel_pstate (Dirk Brandewie). - Support for firmware interface based on ACPI operation regions used by the PMIC chips on the Intel Baytrail-T and Baytrail-T-CR platforms for power resource control and thermal management (Aaron Lu). - Limited support for retrieving off-the-hierarchy dependencies between devices from ACPI _DEP device configuration objects and deferred probing support for the ACPI battery driver based on the _DEP information to make that driver work on Asus T100A (Lan Tianyu). - New cpufreq driver for the Loongson1B processor (Kelvin Cheung). - ACPICA update to upstream revision 20141107 which only affects tools (Bob Moore). - Fixes for race conditions in the ACPICA's interrupt handling code and in the ACPI code related to system suspend and resume (Lv Zheng and Rafael J Wysocki). - ACPI core fix for an RCU-related issue in the ioremap() regions management code that slowed down significantly after CPUs had been allowed to enter idle states even if they'd had RCU callbakcs queued and triggered some problems in certain proprietary graphics driver (and elsewhere). The fix replaces synchronize_rcu() in that code with synchronize_rcu_expedited() which makes the issue go away. From Konstantin Khlebnikov. - ACPI LPSS (Low-Power Subsystem) driver fix to handle power management of the DMA engine included into the LPSS correctly. The problem is that the DMA engine doesn't have ACPI PM support of its own and it simply is turned off when the last LPSS device having ACPI PM support goes into D3cold. To work around that, the PM domain used by the ACPI LPSS driver is redesigned so at least one device with ACPI PM support will be on as long as the DMA engine is in use. From Andy Shevchenko. - ACPI backlight driver fix to avoid using it on "Win8-compatible" systems where it doesn't work and where it was used by default by mistake (Aaron Lu). - Assorted minor ACPI core fixes and cleanups from Tomasz Nowicki, Sudeep Holla, Huang Rui, Hanjun Guo, Fabian Frederick, and Ashwin Chaugule (mostly related to the upcoming ARM64 support). - Intel RAPL (Running Average Power Limit) power capping driver fixes and improvements including new processor IDs (Jacob Pan). - Generic power domains modification to power up domains after attaching devices to them to meet the expectations of device drivers and bus types assuming devices to be accessible at probe time (Ulf Hansson). - Preliminary support for controlling device clocks from the generic power domains core code and modifications of the ARM/shmobile platform to use that feature (Ulf Hansson). - Assorted minor fixes and cleanups of the generic power domains core code (Ulf Hansson, Geert Uytterhoeven). - Assorted minor fixes and cleanups of the device clocks control code in the PM core (Geert Uytterhoeven, Grygorii Strashko). - Consolidation of device power management Kconfig options by making CONFIG_PM_SLEEP select CONFIG_PM_RUNTIME and removing the latter which is now redundant (Rafael J Wysocki and Kevin Hilman). That is the first batch of the changes needed for this purpose. - Core device runtime power management support code cleanup related to the execution of callbacks (Andrzej Hajda). - cpuidle ARM support improvements (Lorenzo Pieralisi). - cpuidle cleanup related to the CPUIDLE_FLAG_TIME_VALID flag and a new MAINTAINERS entry for ARM Exynos cpuidle (Daniel Lezcano and Bartlomiej Zolnierkiewicz). - New cpufreq driver callback (->ready) to be executed when the cpufreq core is ready to use a given policy object and cpufreq-dt driver modification to use that callback for cooling device registration (Viresh Kumar). - cpufreq core fixes and cleanups (Viresh Kumar, Vince Hsu, James Geboski, Tomeu Vizoso). - Assorted fixes and cleanups in the cpufreq-pcc, intel_pstate, cpufreq-dt, pxa2xx cpufreq drivers (Lenny Szubowicz, Ethan Zhao, Stefan Wahren, Petr Cvek). - OPP (Operating Performance Points) framework modification to allow OPPs to be removed too and update of a few cpufreq drivers (cpufreq-dt, exynos5440, imx6q, cpufreq) to remove OPPs (added during initialization) on driver removal (Viresh Kumar). - Hibernation core fixes and cleanups (Tina Ruchandani and Markus Elfring). - PM Kconfig fix related to CPU power management (Pankaj Dubey). - cpupower tool fix (Prarit Bhargava)" * tag 'pm+acpi-3.19-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (120 commits) i2c-omap / PM: Drop CONFIG_PM_RUNTIME from i2c-omap.c dmaengine / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM tools: cpupower: fix return checks for sysfs_get_idlestate_count() drivers: sh / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM e1000e / igb / PM: Eliminate CONFIG_PM_RUNTIME MMC / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM MFD / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM misc / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM media / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM input / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM leds: leds-gpio: Fix multiple instances registration without 'label' property iio / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM hsi / OMAP / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM i2c-hid / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM drm / exynos / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM gpio / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM hwrandom / exynos / PM: Use CONFIG_PM in #ifdef block / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM USB / PM: Drop CONFIG_PM_RUNTIME from the USB core PM: Merge the SET*_RUNTIME_PM_OPS() macros ...
