path: root/drivers/bcma/sprom.c
2019-09-13bcma: make arrays pwr_info_offset and sprom_sizes static const, shrinks ↵Colin Ian King
object size Arrays pwr_info_offset and sprom_sizes can be make static const rather than populating them on the stack. Shrinks object size by 236 bytes. Before: text data bss dec hex filename 11300 1320 64 12684 318c drivers/bcma/sprom.o After: text data bss dec hex filename 10904 1480 64 12448 30a0 drivers/bcma/sprom.o (gcc version 9.2.1, amd64) Signed-off-by: Colin Ian King <colin.king@canonical.com> Signed-off-by: Kalle Valo <kvalo@codeaurora.org>
2015-01-29bcma: detect SPROM revision 11Rafał Miłecki
Extracting values from it is still unsupported, but at least we'll display some meaningful error now. Signed-off-by: Rafał Miłecki <zajec5@gmail.com> Signed-off-by: Kalle Valo <kvalo@codeaurora.org>
2014-07-29bcma: add support for BCM43131 that was found in Tenda W311ERafał Miłecki
Signed-off-by: Rafał Miłecki <zajec5@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2014-07-18bcma: add support for BCM43217 found in Tenda W322E (14e4:43a9)Rafał Miłecki
2014-07-18bcma: extract antenna gains from SPROM correctlyRafał Miłecki
Just like in case of SSB SPROMs they are encoded in a bit tricky way. SPROM struct already uses s8 type and it's supposed to store decoded values. Signed-off-by: Rafał Miłecki <zajec5@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2013-06-27bcma: add support for BCM43142Rafał Miłecki
2013-05-22bcma: support SPROM rev 10Rafał Miłecki
This is pretty much the same as rev 9, there are just 2 extra fields we know about, but are not used/stored yet anyway. Signed-off-by: Rafał Miłecki <zajec5@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2013-05-22bcma: prepare for supporting more SPROM sizesRafał Miłecki
2013-05-22bcma: don't hardcode SPROM lengthRafał Miłecki
Pass it as an argument to all functions. This is requires as newer SPROM revisions have different lengths. Signed-off-by: Rafał Miłecki <zajec5@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2013-03-25bcma: extract board_type from SPROMRafał Miłecki
2012-10-19bcma: use fallback sprom if sprom on card was not validHauke Mehrtens
Sometimes the PCIe card indicates that it has a sprom somewhere and we are able to read the memory region, but it is empty and not valid. In these cases we should try to use the fallback sprom as a last chance. This is the case for the PCIe cards in my ASUS RT-N66U (BCM4706 + 2 times BCM4331) and I have heard of someone having the same problem with an other PCIe card connected to an other Broadcom SoC. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-09-24bcma: handle BCM43227Rafał Miłecki
Signed-off-by: Rafał Miłecki <zajec5@gmail.com> Tested-by: Jack <x6719620@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-08-02bcma: BCM43228 supportRafał Miłecki
2012-07-09bcma: use custom printing functionsRafał Miłecki
Having bus number printed makes it much easier to anaylze logs on systems with more buses. For example Netgear WNDR4500 has 3 AMBA buses in total, which makes standard log really messy. Signed-off-by: Rafał Miłecki <zajec5@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-07-09bcma: add constants for chip idsHauke Mehrtens
The chip IDs are used all over bcma and no constants where defined. This patch adds the constants and makes bcma use them. Acked-by: Arend van Spriel <arend@broadcom.com> Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-06-04bcma: add ext PA workaround for BCM4331 and BCM43431Seth Forshee
MacBook Pro models with BCM4331 wireless have been found to have the ext PA lines disabled after resuming from S3 without external power attach. This causes them to be unable to transmit. Add a workaround to ensure that the ext PA lines are enabled on BCM4331. Also extend all handling of ext PA line muxing to BCM43431 as is done in the Broadcom SDK. BugLink: http://bugs.launchpad.net/bugs/925577 Cc: Arend van Spriel <arend@broadcom.com> Cc: Hauke Mehrtens <hauke@hauke-m.de> Cc: stable@vger.kernel.org Signed-off-by: Seth Forshee <seth.forshee@canonical.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-05-16bcma/ssb: parse new attributes from spromHauke Mehrtens
These newly added attributes are used by brcmsmac. Now bcma should parse all attributes used by brcmsmac out of the sprom. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Tested-by: Arend van Spriel <arend@broadcom.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-05-16bcma: read out some additional sprom attributesHauke Mehrtens
This code is copied from the ssb sprom read code. These attributes are partly used by b43 and brcmsmac and should also be read out on bcma based devices. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Tested-by: Arend van Spriel <arend@broadcom.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-05-16ssb/bcma: fill attribute alpha2 from spromHauke Mehrtens
The attribute country_code and alpha2 are two different attributes in the sprom. country_code contains some code in an 8 bit coding and alpha2 contains two chars with the country code. The attributes where read out wrongly in the past and country_code is only available on sprom version 1. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Tested-by: Arend van Spriel <arend@broadcom.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-04-16bcma: use fallback sprom if no on chip sprom is availableHauke Mehrtens
bcma should check for a fallback sprom every time it can not find a sprom on the card itself or a normal external sprom mapped into the memory of the chip. When otp sprom support was introduced it tried to read out the sprom from the wireless chip also if no otp sprom was available. This caused a Data bus error in bcma_sprom_get() when reading out the sprom for the SoC. This fixes a regression introduced in commit: commit 10d8493cd9efd38b1947b7a74276dbdc8311aa1a Author: Arend van Spriel <arend@broadcom.com> Date: Tue Mar 6 15:50:48 2012 +0100 bcma: add support for on-chip OTP memory used for SPROM storage This patch was tested on a Netgear WNDR3400 (Broadcom BCM4718 SoC). Reported-by: Nick Bowler <nbowler@elliptictech.com> Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Acked-by: Arend van Spriel <arend@broadcom.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-03-06bcma: add support for on-chip OTP memory used for SPROM storageArend van Spriel
Wireless Broadcom chips can have either their SPROM data stored on either external SPROM or on-chip OTP memory. Both are accessed through the same register space. This patch adds support for the on-chip OTP memory. Tested with: BCM43224 OTP and SPROM BCM4331 SPROM BCM4313 OTP This patch is in response to linux-wireless thread [1]. [1] http://article.gmane.org/gmane.linux.kernel.wireless.general/85426 Tested-by: Saul St. John <saul.stjohn@gmail.com> Tested-by: Rafal Milecki <zajec5@gmail.com> Tested-by: Hauke Mehrtens <hauke@hauke-m.de> Cc: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: Arend van Spriel <arend@broadcom.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-03-06bcma: return error in bcma_sprom_get() when fallback failsArend van Spriel
When not SPROM is available a fallback mechanism is used. However, when that fails the code currently continues. This patch assures that the bcma_sprom_get() function aborts when that happens. Cc: Rafal Milecki <zajec5@gmail.com> Cc: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: Arend van Spriel <arend@broadcom.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-03-05bcma: add support for sprom not found on the deviceHauke Mehrtens
On SoCs the sprom is stored in the nvram in a special partition on the flash chip. The nvram contains the sprom for the main bus, but sometimes also for a pci devices using bcma. This patch makes it possible for the arch code to register a function to fetch the needed sprom from the nvram and provide it to the bcma code. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-02-06bcma: add extra sprom checkHauke Mehrtens
This check is needed on the BCM43224 device as it says in the capabilities it has an sprom but is extra check says it has not. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-01-24bcma: Enable logging of SPROM offsetLarry Finger
The SPROM location has been relocated again for some devices. This patch will log the offset when CONFIG_BCMA_DEBUG has been selected. Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-01-24bcma: SPROM: extract power info for coresRafał Miłecki
2012-01-24bcma: SPROM: add macro for easier extractionRafał Miłecki
2011-12-13bcma: extract revision and TX power IDs from SPROMRafał Miłecki
2011-12-13bcma: extract FEM info from SPROMRafał Miłecki
2011-09-13bcma: extract some basic info about board from SPROMRafał Miłecki
2011-08-22bcma: implement BCM4331 workaround for external PA linesRafał Miłecki
We need to disable ext. PA lines for reading SPROM. It's disabled by default, but this patch allows using bcma after loading wl, which leaves workaround enabled. Cc: Arend van Spriel <arend@broadcom.com> Signed-off-by: Rafał Miłecki <zajec5@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-07-19bcma: handle alternative SPROM locationRafał Miłecki
Some cards do not use additional 0x30 offset for SPROM location. We do not know the real condition for it yet, make it BCM4331 specific for now. Signed-off-by: Rafał Miłecki <zajec5@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-07-18bcma: extract SPROM rev 9 the same way as rev 8Rafał Miłecki
SPROM rev 9 was discovered on 14e4:4331, it seems to have very similar layout to rev 8 one. Use the same extracting function until we find some differences. Signed-off-by: Rafał Miłecki <zajec5@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-07-11bcma: add check if sprom is available before accessing it.Hauke Mehrtens
The SoCs like the bcm4716 do not have a sprom on the bcma bus like a pcie device. It stores the values in some partition on flash memory. For ssb this informations are read out in the bcm47xx arch code, something like that should also be implemented for bcma. Without this patch bcma panics on SoCs. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-06-03bcma: read SPROM and extract MAC from itRafał Miłecki
In case of BCMA cards SPROM is located in the ChipCommon core, it is not mapped as separated host window. So far we have met only SPROMs rev 8. SPROM layout seems to be the same as for SSB buses, so we decided to share SPROM struct and some defines. For now we extract MAC address only, this can be improved of course. Signed-off-by: Rafał Miłecki <zajec5@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
