Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
No need to get into the submenu to disable all BCMA-related config entries.
Signed-off-by: Vincent Legoll <vincent.legoll@gmail.com>
Signed-off-by: Kalle Valo <kvalo@codeaurora.org>
Broadcom BCM53573 SoCs actually have 32 GPIOs, and not 16.
Fixes: 3f37ec79dd21 ("bcma: support BCM53573 series of wireless SoCs")
Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
PCI devices can be described in DT as well so we should always execute
relevant code. This will make bcma e.g. set of_node for cores described
in DT.
Signed-off-by: Rafał Miłecki <rafal@milecki.pl>
A tiny code deduplication thanks to the bcma_bus_get_host_dev.
We already have the same check in bcma_of_get_irq which really calls
symbols available with CONFIG_OF_IRQ only. It appears this duplicated
check was accidentally added in commit c58d900cc96a ("bcma: fix building
without OF_IRQ"). The rest of code in bcma_of_fill_device should work
fine without CONFIG_OF_IRQ.
DT allows describing many device types, not only platform ones. If e.g.
bcma is hosted on PCI(e) and it has its of_node, let's pass it to the
GPIO subsystem. This allows GPIO code to handle more hardware details
not only for bcma on a SoC.
All merge conflicts were simple overlapping changes.
OF allows not only specifying platform devices but also describing
devices on standard buses like PCI or USB. This change will allow
reading info from DT for bcma buses hosted on PCI cards.
This allows tracking device state and e.g. makes devm work as expected.
Cc: Stable <stable@vger.kernel.org>
This reverts commit 4c81acab3816 ("bcma: init serial console directly
from ChipCommon code") as it broke IRQ assignment. Getting IRQ with
bcma_core_irq helper on SoC requires MIPS core to be set. It happens
*after* ChipCommon initialization so we can't do this so early.
This fixes a user reported regression. It wasn't critical as serial was
still somehow working but lack of IRQs was making in unreliable.
Fixes: 4c81acab3816 ("bcma: init serial console directly from ChipCommon code")
Reported-by: Felix Fietkau <nbd@nbd.name>
Cc: stable@vger.kernel.org # 4.6+
This is what is in the laptop:
01:00.0 Network controller [0280]: Broadcom Limited BCM43142 802.11b/g/n [14e4:4365] (rev 01)
Subsystem: Dell Device [1028:0018]
Flags: bus master, fast devsel, latency 0, IRQ 18
Memory at b0400000 (64-bit, non-prefetchable) [size=32K]
Capabilities: [40] Power Management version 3
Capabilities: [58] Vendor Specific Information: Len=78 <?>
Capabilities: [48] MSI: Enable- Count=1/1 Maskable- 64bit+
Capabilities: [d0] Express Endpoint, MSI 00
Capabilities: [100] Advanced Error Reporting
Capabilities: [13c] Virtual Channel
Capabilities: [160] Device Serial Number 00-00-9a-ff-ff-f3-40-b8
Capabilities: [16c] Power Budgeting <?>
With the patch, I can see:
bcma: bus0: Found chip with id 43142, rev 0x01 and package 0x08
bcma: bus0: Core 0 found: ChipCommon (manuf 0x4BF, id 0x800, rev 0x28, class 0x0)
bcma: bus0: Core 1 found: IEEE 802.11 (manuf 0x4BF, id 0x812, rev 0x21, class 0x0)
bcma: bus0: Core 2 found: PCIe (manuf 0x4BF, id 0x820, rev 0x16, class 0x0)
bcma: bus0: Core 3 found: UNKNOWN (manuf 0x43B, id 0x368, rev 0x00, class 0x0)
bcma: bus0: Bus registered
The wifi is not currently supported by brcmsmac yet:
brcmsmac bcma1:1: mfg 4bf core 812 rev 33 class 0 irq 18
brcmsmac: unknown device id 4365
So don't expect a working wifi from this patch :).
Cc: Rafał Miłecki <zajec5@gmail.com>
Cc: <linux-wireless@vger.kernel.org>
While fixing another bug, I noticed that bcma manually sets up
a dma_mask pointer for its child devices. We have a generic
helper for that now, which should be able to cope better with
any variations that might be needed to deal with cache coherency,
unusual DMA address offsets, iommus, or limited DMA masks, none
of which are currently handled here.
This changes the core to use the of_dma_configure(), like
we do for platform devices that are probed directly from
DT.
BCM53573 seems to be the first series of Northstar family with wireless
on the chip. The base models are BCM53573-s (A0, A1) and there is also
BCM47189B0 which seems to be some small modification.
The only problem with these chipsets seems to be watchdog. It's totally
unavailable on 53573A0 / 53573A1 and preferable PMU watchdog is broken
on 53573B0 / 53573B1.
Signed-off-by: Rafał Miłecki <zajec5@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/kvalo/wireless-drivers-next
Kalle Valo says:
pull-request: wireless-drivers-next 2016-07-22
I'm sick so I have to keep this short, but here's the last pull request
to net-next. This time there's a trivial conflict with mtd tree:
http://lkml.kernel.org/g/20160720123133.44dab209@canb.auug.org.au
We concluded with Brian (CCed) that it's best that we ask Linus to fix
this. The patches have been in linux-next for a couple of days. This
time I haven't done any merge tests so I don't know if there are any
other conflicts etc.
Please let me know if there are any problems.
wireless-drivers-next patches for 4.8
Major changes:
wl18xx
* add initial mesh support
bcma
* serial flash support on non-MIPS SoCs
ath10k
* enable support for QCA9888
* disable wake_tx_queue() mac80211 op for older devices to workaround
throughput regression
ath9k
* implement temperature compensation support for AR9003+
We don't have access to datasheets to document all the bits but we can
name these registers at least.
So far we had only MIPS devices with serial flash connected to the SoC's
ChipCommon. ARM devices got a separated SPI controller and weere using
standard SPI drivers.
This has changed with the wireless SoC BCM47189B0. It's ARM based but
has serial flash attached just like older devices. This allows using
existing driver with these devices.
After discovering there are 2 very different 14e4:4365 PCI devices we
made ID tables less generic. Back then we believed there are only 2 such
devices:
1) 14e4:4365 1028:0016 with SoftMAC BCM43142 chipset
2) 14e4:4365 14e4:4365 with FullMAC BCM4366 chipset
>From the recent report it appears there is also 14e4:4365 105b:e092
which should be claimed by bcma. Add back support for it.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=121881
Fixes: 515b399c9a20 ("bcma: claim only 14e4:4365 PCI Dell card with SoftMAC BCM43142")
Reported-by: Igor Mammedov <imammedo@redhat.com>
Cc: Stable <stable@vger.kernel.org> [4.6+]
Tested-by: Igor Mammedov <imammedo@redhat.com>
The EFI firmware on Macs contains a full-fledged network stack for
downloading OS X images from osrecovery.apple.com. Unfortunately
on Macs introduced 2011 and 2012, EFI brings up the Broadcom 4331
wireless card on every boot and leaves it enabled even after
ExitBootServices has been called. The card continues to assert its IRQ
line, causing spurious interrupts if the IRQ is shared. It also corrupts
memory by DMAing received packets, allowing for remote code execution
over the air. This only stops when a driver is loaded for the wireless
card, which may be never if the driver is not installed or blacklisted.
The issue seems to be constrained to the Broadcom 4331. Chris Milsted
has verified that the newer Broadcom 4360 built into the MacBookPro11,3
(2013/2014) does not exhibit this behaviour. The chances that Apple will
ever supply a firmware fix for the older machines appear to be zero.
The solution is to reset the card on boot by writing to a reset bit in
its mmio space. This must be done as an early quirk and not as a plain
vanilla PCI quirk to successfully combat memory corruption by DMAed
packets: Matthew Garrett found out in 2012 that the packets are written
to EfiBootServicesData memory (http://mjg59.dreamwidth.org/11235.html).
This type of memory is made available to the page allocator by
efi_free_boot_services(). Plain vanilla PCI quirks run much later, in
subsys initcall level. In-between a time window would be open for memory
corruption. Random crashes occurring in this time window and attributed
to DMAed packets have indeed been observed in the wild by Chris
Bainbridge.
When Matthew Garrett analyzed the memory corruption issue in 2012, he
sought to fix it with a grub quirk which transitions the card to D3hot:
http://git.savannah.gnu.org/cgit/grub.git/commit/?id=9d34bb85da56
This approach does not help users with other bootloaders and while it
may prevent DMAed packets, it does not cure the spurious interrupts
emanating from the card. Unfortunately the card's mmio space is
inaccessible in D3hot, so to reset it, we have to undo the effect of
Matthew's grub patch and transition the card back to D0.
Note that the quirk takes a few shortcuts to reduce the amount of code:
The size of BAR 0 and the location of the PM capability is identical
on all affected machines and therefore hardcoded. Only the address of
BAR 0 differs between models. Also, it is assumed that the BCMA core
currently mapped is the 802.11 core. The EFI driver seems to always take
care of this.
Michael Büsch, Bjorn Helgaas and Matt Fleming contributed feedback
towards finding the best solution to this problem.
The following should be a comprehensive list of affected models:
iMac13,1 2012 21.5" [Root Port 00:1c.3 = 8086:1e16]
iMac13,2 2012 27" [Root Port 00:1c.3 = 8086:1e16]
Macmini5,1 2011 i5 2.3 GHz [Root Port 00:1c.1 = 8086:1c12]
Macmini5,2 2011 i5 2.5 GHz [Root Port 00:1c.1 = 8086:1c12]
Macmini5,3 2011 i7 2.0 GHz [Root Port 00:1c.1 = 8086:1c12]
Macmini6,1 2012 i5 2.5 GHz [Root Port 00:1c.1 = 8086:1e12]
Macmini6,2 2012 i7 2.3 GHz [Root Port 00:1c.1 = 8086:1e12]
MacBookPro8,1 2011 13" [Root Port 00:1c.1 = 8086:1c12]
MacBookPro8,2 2011 15" [Root Port 00:1c.1 = 8086:1c12]
MacBookPro8,3 2011 17" [Root Port 00:1c.1 = 8086:1c12]
MacBookPro9,1 2012 15" [Root Port 00:1c.1 = 8086:1e12]
MacBookPro9,2 2012 13" [Root Port 00:1c.1 = 8086:1e12]
MacBookPro10,1 2012 15" [Root Port 00:1c.1 = 8086:1e12]
MacBookPro10,2 2012 13" [Root Port 00:1c.1 = 8086:1e12]
For posterity, spurious interrupts caused by the Broadcom 4331 wireless
card resulted in splats like this (stacktrace omitted):
irq 17: nobody cared (try booting with the "irqpoll" option)
handlers:
[<ffffffff81374370>] pcie_isr
[<ffffffffc0704550>] sdhci_irq [sdhci] threaded [<ffffffffc07013c0>] sdhci_thread_irq [sdhci]
[<ffffffffc0a0b960>] azx_interrupt [snd_hda_codec]
Disabling IRQ #17
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=79301
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=111781
Bugzilla: https://bugzilla.redhat.com/show_bug.cgi?id=728916
Bugzilla: https://bugzilla.redhat.com/show_bug.cgi?id=895951#c16
Bugzilla: https://bugzilla.redhat.com/show_bug.cgi?id=1009819
Bugzilla: https://bugzilla.redhat.com/show_bug.cgi?id=1098621
Bugzilla: https://bugzilla.redhat.com/show_bug.cgi?id=1149632#c5
Bugzilla: https://bugzilla.redhat.com/show_bug.cgi?id=1279130
Bugzilla: https://bugzilla.redhat.com/show_bug.cgi?id=1332732
Tested-by: Konstantin Simanov <k.simanov@stlk.ru> # [MacBookPro8,1]
Tested-by: Lukas Wunner <lukas@wunner.de> # [MacBookPro9,1]
Tested-by: Bryan Paradis <bryan.paradis@gmail.com> # [MacBookPro9,2]
Tested-by: Andrew Worsley <amworsley@gmail.com> # [MacBookPro10,1]
Tested-by: Chris Bainbridge <chris.bainbridge@gmail.com> # [MacBookPro10,2]
Signed-off-by: Lukas Wunner <lukas@wunner.de>
Acked-by: Rafał Miłecki <zajec5@gmail.com>
Acked-by: Matt Fleming <matt@codeblueprint.co.uk>
Cc: Bjorn Helgaas <bhelgaas@google.com>
Cc: Brian Gerst <brgerst@gmail.com>
Cc: Chris Milsted <cmilsted@redhat.com>
Cc: Denys Vlasenko <dvlasenk@redhat.com>
Cc: Josh Poimboeuf <jpoimboe@redhat.com>
Cc: Matthew Garrett <mjg59@srcf.ucam.org>
Cc: Michael Buesch <m@bues.ch>
Cc: Yinghai Lu <yinghai@kernel.org>
Cc: b43-dev@lists.infradead.org
Cc: linux-pci@vger.kernel.org
Cc: linux-wireless@vger.kernel.org
Cc: stable@vger.kernel.org # 123456789abc: x86/quirks: Apply nvidia_bugs quirk only on root bus
Cc: stable@vger.kernel.org # 123456789abc: x86/quirks: Reintroduce scanning of secondary buses
Link: http://lkml.kernel.org/r/48d0972ac82a53d460e5fce77a07b2560db95203.1465690253.git.lukas@wunner.de
[ Did minor readability edits. ]
Pull MTD updates from Brian Norris:
"First cycle with Boris as NAND maintainer! Many (most) bullets stolen
from him.
Generic:
- Migrated NAND LED trigger to be a generic MTD trigger
NAND:
- Introduction of the "ECC algorithm" concept, to avoid overloading
the ECC mode field too much more
- Replaced the nand_ecclayout infrastructure with something a little
more flexible (finally!) and future proof
- Rework of the OMAP GPMC and NAND drivers; the TI folks pulled some
of this into their own tree as well
- Prepare the sunxi NAND driver to receive DMA support
- Handle bitflips in erased pages on GPMI revisions that do not
support this in hardware.
SPI NOR:
- Start using the spi_flash_read() API for SPI drivers that support
it (i.e., SPI drivers with special memory-mapped flash modes)
And other small scattered improvments"
* tag 'for-linus-20160523' of git://git.infradead.org/linux-mtd: (155 commits)
mtd: spi-nor: support GigaDevice gd25lq64c
mtd: nand_bch: fix spelling of "probably"
mtd: brcmnand: respect ECC algorithm set by NAND subsystem
gpmi-nand: Handle ECC Errors in erased pages
Documentation: devicetree: deprecate "soft_bch" nand-ecc-mode value
mtd: nand: add support for "nand-ecc-algo" DT property
mtd: mtd: drop NAND_ECC_SOFT_BCH enum value
mtd: drop support for NAND_ECC_SOFT_BCH as "soft_bch" mapping
mtd: nand: read ECC algorithm from the new field
mtd: nand: fsmc: validate ECC setup by checking algorithm directly
mtd: nand: set ECC algorithm to Hamming on fallback
staging: mt29f_spinand: set ECC algorithm explicitly
CRIS v32: nand: set ECC algorithm explicitly
mtd: nand: atmel: set ECC algorithm explicitly
mtd: nand: davinci: set ECC algorithm explicitly
mtd: nand: bf5xx: set ECC algorithm explicitly
mtd: nand: omap2: Fix high memory dma prefetch transfer
mtd: nand: omap2: Start dma request before enabling prefetch
mtd: nandsim: add __init attribute
mtd: nand: move of_get_nand_xxx() helpers into nand_base.c
Using KSEG0ADDR makes code highly MIPS dependent and not portable.
Thanks to the fix a68f376 ("MIPS: io.h: Define `ioremap_cache'") we can
use ioremap_cache which is generic and supported on MIPS as well now.
KSEG0ADDR was translating 0x1c000000 into 0x9c000000. With ioremap_cache
we use MIPS's __ioremap (and then remap_area_pages). This results in
different address (e.g. 0xc0080000) but it still should be cached as
expected and it was successfully tested with BCM47186B0.
Other than that drivers/bcma/driver_chipcommon_sflash.c nicely setups a
struct resource for access window, but we wren't using it. Use it now
and drop duplicated info.
Signed-off-by: Brian Norris <computersforpeace@gmail.com>
The bcma driver core can be built with or without DT support, but
it fails to build when CONFIG_OF=y and CONFIG_OF_IRQ=n, which
can happen on platforms that do not support IRQ domains.
ERROR: "irq_create_of_mapping" [drivers/bcma/bcma.ko] undefined!
ERROR: "of_irq_parse_raw" [drivers/bcma/bcma.ko] undefined!
ERROR: "of_irq_parse_one" [drivers/bcma/bcma.ko] undefined!
This adds another compile-time check for OF_IRQ, but also
gets rid of now unneeded #ifdef checks: Using the simpler
IS_ENABLED() check for OF_IRQ also covers the case of not
having CONFIG_OF enabled. The check for CONFIG_OF_ADDRESS
was added to allow building on architectures without
OF_ADDRESS, but that has been addressed already in
b1d06b60e90c ("of: Provide static inline function for
of_translate_address if needed").
Flashes are attached and accessible through ChipCommon core, they aren't
connected to MIPS one. Moreover some new ARM devices (e.g. BCM47189) may
have serial flash accessibility using ChipCommon registers as well. To
support them we can't keep this code in MIPS core driver.
This follows the way of handling other flashes and cleans code a bit. As
next task we will want to move flash code to ChipCommon driver as:
1) Flash controllers are accesible using ChipCommon registers
2) This code isn't MIPS specific
This change prepares bcma for that.
Most of info stored in this struct wasn't really used anywhere as we put
all that data in platform data & resource as well.
Kalle Valo says:
Major changes:
wl12xx
* add device tree support for SPI
mwifiex
* add debugfs file to read chip information
* add MSIx support for newer pcie chipsets (8997 onwards)
* add schedule scan support
* add WoWLAN net-detect support
* firmware dump support for w8997 chipset
iwlwifi
* continue the work on multiple Rx queues
* add support for beacon storing used in low power states
* use the regular firmware image of WoWLAN
* fix 8000 devices for Big Endian machines
* more firmware debug hooks
* add support for P2P Client snoozing
* make the beacon filtering for AP mode configurable
* fix transmit queues overflow with LSO
libertas
* add support for setting power save via cfg80211
It seems 14e4:4365 pattern is too generic as there are two devices:
The later one was found in D-Link DIR-885L router and we want to let
brcmfmac handle it.
It's another SoC with 32 GPIOs and simplified watchdog handling. It was
tested on D-Link DIR-885L.
UART is connected to and controlled over ChipCommon core. It doesn't
have much to do with MIPS core (where we initialize it currently)
except just existing on embedded systemms. There isn't point of such
cross-core initialization (and we needed #ifdef anyway) so just handle
it in ChipCommon.
On recent Broadcom chipsets PMU is present as separated core and it
can't be accessed using ChipCommon anymore as it fails with e.g.:
[ 0.000577] Unhandled fault: external abort on non-linefetch (0x1008) at 0xf1000604
Solve it by using a new (PMU) core pointer set to ChipCommon or PMU
depending on the hardware capabilities.
PMU (Power Management Unit) seems to be a separated piece of hardware,
just accessed using ChipCommon core registers. In recent Broadcom
chipsets PMU is not bounded to CC but available as separated core.
To make code cleaner & easier to review (for a correct R/W access) use
clearer names.
Both cores are another exceptions. They are not accessed in a standard
way and to they don't need or have wrapping addresses.
This fixes bus scanning after finding such core.
Add missing defines and print proper names.
It's a Macronix 32 MiB flash found on board with BCM47189 SoC.
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio
Pull GPIO updates from Linus Walleij:
"Here is the bulk of GPIO changes for v4.5.
Notably there are big refactorings mostly by myself, aimed at getting
the gpio_chip into a shape that makes me believe I can proceed to
preserve state for a proper userspace ABI (character device) that has
already been proposed once, but resulted in the feedback that I need
to go back and restructure stuff. So I've been restructuring stuff.
On the way I ran into brokenness (return code from the get_value()
callback) and had to fix it. Also, refactored generic GPIO to be
simpler.
Some of that is still waiting to trickle down from the subsystems all
over the kernel that provide random gpio_chips, I've touched every
single GPIO driver in the kernel now, oh man I didn't know I was
responsible for so much...
Apart from that we're churning along as usual.
I took some effort to test and retest so it should merge nicely and we
shook out a couple of bugs in -next.
Infrastructural changes:
- In struct gpio_chip, rename the .dev node to .parent to better
reflect the fact that this is not the GPIO struct device
abstraction. We will add that soon so this would be totallt
confusing.
- It was noted that the driver .get_value() callbacks was sometimes
reporting negative -ERR values to the gpiolib core, expecting them
to be propagated to consumer gpiod_get_value() and gpio_get_value()
calls. This was not happening, so as there was a mess of drivers
returning negative errors and some returning "anything else than
zero" to indicate that a line was active. As some would have bit
31 set to indicate "line active" it clashed with negative error
codes. This is fixed by the largeish series clamping values in all
drivers with !!value to [0,1] and then augmenting the code to
propagate error codes to consumers. (Includes some ACKed patches
in other subsystems.)
- Add a void *data pointer to struct gpio_chip. The container_of()
design pattern is indeed very nice, but we want to reform the
struct gpio_chip to be a non-volative, stateless business, and keep
states internal to the gpiolib to be able to hold on to the state
when adding a proper userspace ABI (character device) further down
the road. To achieve this, drivers need a handle at the internal
state that is not dependent on their struct gpio_chip() so we add
gpiochip_add_data() and gpiochip_get_data() following the pattern
of many other subsystems. All the "use gpiochip data pointer"
patches transforms drivers to this scheme.
- The Generic GPIO chip header has been merged into the general
<linux/gpio/driver.h> header, and the custom header for that
removed. Instead of having a separate mm_gpio_chip struct for
these generic drivers, merge that into struct gpio_chip,
simplifying the code and removing the need for separate and
confusing includes.
Misc improvements:
- Stabilize the way GPIOs are looked up from the ACPI legacy
specification.
- Incremental driver features for PXA, PCA953X, Lantiq (patches from
the OpenWRT community), RCAR, Zynq, PL061, 104-idi-48
New drivers:
- Add a GPIO chip to the ALSA SoC AC97 driver.
- Add a new Broadcom NSP SoC driver (this lands in the pinctrl dir,
but the branch is merged here too to account for infrastructural
changes).
- The sx150x driver now supports the sx1502"
* tag 'gpio-v4.5-1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio: (220 commits)
gpio: generic: make bgpio_pdata always visible
gpiolib: fix chip order in gpio list
gpio: mpc8xxx: Do not use gpiochip_get_data() in mpc8xxx_gpio_save_regs()
gpio: mm-lantiq: Do not use gpiochip_get_data() in ltq_mm_save_regs()
gpio: brcmstb: Allow building driver for BMIPS_GENERIC
gpio: brcmstb: Set endian flags for big-endian MIPS
gpio: moxart: fix build regression
gpio: xilinx: Do not use gpiochip_get_data() in xgpio_save_regs()
leds: pca9532: use gpiochip data pointer
leds: tca6507: use gpiochip data pointer
hid: cp2112: use gpiochip data pointer
bcma: gpio: use gpiochip data pointer
avr32: gpio: use gpiochip data pointer
video: fbdev: via: use gpiochip data pointer
gpio: pch: Optimize pch_gpio_get()
Revert "pinctrl: lantiq: Implement gpio_chip.to_irq"
pinctrl: nsp-gpio: use gpiochip data pointer
pinctrl: vt8500-wmt: use gpiochip data pointer
pinctrl: exynos5440: use gpiochip data pointer
pinctrl: at91-pio4: use gpiochip data pointer
This makes the driver use the data pointer added to the gpio_chip
to store a pointer to the state container instead of relying on
container_of().
Cc: Kalle Valo <kvalo@codeaurora.org>
Acked-by: Hauke Mehrtens <hauke@hauke-m.de>
So far we were using fs_initcall. It was (and still is) needed because
struct bus_type has to be registered early. However main bus
initialization has to happen later as it requires SPROM which depends on
NVRAM which depends on mtd.
Solve it by using fs_initcall only for bus_register call and module_init
for the rest. It affects bcma only when built-in obviously.
This was tested with BCM4706 and BCM5357C0 (BCM47XX), BCM4708A0
(ARCH_BCM_5301X) and BCM43225 (PCIe card with bcma as module).
The name .dev in a struct is normally reserved for a struct device
that is let us say a superclass to the thing described by the struct.
struct gpio_chip stands out by confusingly using a struct device *dev
to point to the parent device (such as a platform_device) that
represents the hardware. As we want to give gpio_chip:s real devices,
this is not working. We need to rename this member to parent.
This was done by two coccinelle scripts, I guess it is possible to
combine them into one, but I don't know such stuff. They look like
this:
struct gpio_chip *var;
-var->dev
+var->parent
and:
struct gpio_chip var;
-var.dev
+var.parent
and:
struct bgpio_chip *var;
-var->gc.dev
+var->gc.parent
Plus a few instances of bgpio that I couldn't figure out how
to teach Coccinelle to rewrite.
This patch hits all over the place, but I *strongly* prefer this
solution to any piecemal approaches that just exercise patch
mechanics all over the place. It mainly hits drivers/gpio and
drivers/pinctrl which is my own backyard anyway.
Cc: Haavard Skinnemoen <hskinnemoen@gmail.com>
Cc: Richard Purdie <rpurdie@rpsys.net>
Cc: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
Cc: Alek Du <alek.du@intel.com>
Cc: Jaroslav Kysela <perex@perex.cz>
Cc: Takashi Iwai <tiwai@suse.com>
Acked-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Acked-by: Lee Jones <lee.jones@linaro.org>
Acked-by: Jiri Kosina <jkosina@suse.cz>
Acked-by: Hans-Christian Egtvedt <egtvedt@samfundet.no>
Acked-by: Jacek Anaszewski <j.anaszewski@samsung.com>
of_default_bus_match_table was not exported earlier, so it could only
be accessed by code compiled into the kernel. A new function
of_platform_default_populate() was added which uses
of_default_bus_match_table and this function is also exported. This way
it is possible to create a bus with the content of
of_default_bus_match_table and we can remove the hacks from bcma.
Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
This switches the BCMA GPIO driver to use GPIOLIB_IRQCHIP to
handle its interrupts instead of rolling its own copy of the
irqdomain handling etc.
bus->host_pdev is part of a union so bus->host_pdev != NULL is probably
also true for PCIe devices, because there it accesses bus->host_pci. If
we access the dev member at the offset defined in struct
platform_device in struct pci_dev instead we probably get something
else.
This patch adds a new function which returns the host dev struct and
NULL if we do not have a host dev. When this gets registered on MIPS
brcm47xx we do not have a host dev in some situations.
This function could also be used in other places.
This problem was introduced in this commit:
commit cae761b5a6bdc597ba476a040fdcd5b4bc559b85
Author: Rafa? Mi?ecki <zajec5@gmail.com>
Date: Sun Jun 28 17:17:13 2015 +0200
bcma: populate bus DT subnodes as platform_device-s
Currently of_default_bus_match_table is not exported so we can only use
this feature when bcma is build into the kernel. This patch removes
support for child buses when bcma is build as a module as a temporary
fix for a build problem introduces in this commit:
Author: Rafał Miłecki <zajec5@gmail.com>
Fixes: cae761b5a6bd ("bcma: populate bus DT subnodes as platform_device-s")
Our bus should allow defining children nodes as we may want to specify
devices attached to the bus. This is required e.g. to specify NAND or
ChipCommon cores and use bus's address and IRQ mappings.
This extension of BCMA_DRIVER_PCI has no reason to depend on
BCMA_HOST_PCI. User may just want to have PCI device attached to SoC
registered without enabling any extra client mode code.
This can be useful when having non-bcma PCI device attached or when
using other PCI driver.
Signed-off-by: Felix Fietkau <nbd@openwrt.org>
On some BCM5301x ARM devices, user space still needs to control some
system GPIO pins for which no driver exists. This is a lot easier to do
with a predictable GPIO base.
Pull MIPS updates from Ralf Baechle:
"This is the main pull request for MIPS for Linux 4.1. Most
noteworthy:
- Add more Octeon-optimized crypto functions
- Octeon crypto preemption and locking fixes
- Little endian support for Octeon
- Use correct CSR to soft reset Octeons
- Support LEDs on the Octeon-based DSR-1000N
- Fix PCI interrupt mapping for the Octeon-based DSR-1000N
- Mark prom_free_prom_memory() as __init for a number of systems
- Support for Imagination's Pistachio SOC. This includes arch and
CLK bits. I'd like to merge pinctrl bits later
- Improve parallelism of csum_partial for certain pipelines
- Organize DTB files in subdirs like other architectures
- Implement read_sched_clock for all MIPS platforms other than
Octeon
- Massive series of 38 fixes and cleanups for the FPU emulator /
kernel
- Further FPU remulator work to support new features. This sits on a
separate branch which also has been pulled into the 4.1 KVM branch
- Clean up and fixes for the SEAD3 eval board; remove unused file
- Various updates for Netlogic platforms
- A number of small updates for Loongson 3 platforms
- Increase the memory limit for ATH79 platforms to 256MB
- A fair number of fixes and updates for BCM47xx platforms
- Finish the implementation of XPA support
- MIPS FDC support. No, not floppy controller but Fast Debug Channel :)
- Detect the R16000 used in SGI legacy platforms
- Fix Kconfig dependencies for the SSB bus support"
* 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (265 commits)
MIPS: Makefile: Fix MIPS ASE detection code
MIPS: asm: elf: Set O32 default FPU flags
MIPS: BCM47XX: Fix detecting Microsoft MN-700 & Asus WL500G
MIPS: Kconfig: Disable SMP/CPS for 64-bit
MIPS: Hibernate: flush TLB entries earlier
MIPS: smp-cps: cpu_set FPU mask if FPU present
MIPS: lose_fpu(): Disable FPU when MSA enabled
MIPS: ralink: add missing symbol for RALINK_ILL_ACC
MIPS: ralink: Fix bad config symbol in PCI makefile.
SSB: fix Kconfig dependencies
MIPS: Malta: Detect and fix bad memsize values
Revert "MIPS: Avoid pipeline stalls on some MIPS32R2 cores."
MIPS: Octeon: Delete override of cpu_has_mips_r2_exec_hazard.
MIPS: Fix cpu_has_mips_r2_exec_hazard.
MIPS: kernel: entry.S: Set correct ISA level for mips_ihb
MIPS: asm: spinlock: Fix addiu instruction for R10000_LLSC_WAR case
MIPS: r4kcache: Use correct base register for MIPS R6 cache flushes
MIPS: Kconfig: Fix typo for the r2-to-r6 emulator kernel parameter
MIPS: unaligned: Fix regular load/store instruction emulation for EVA
MIPS: unaligned: Surround load/store macros in do {} while statements
There are two reasons for having this header in the common place:
1) Simplifying drivers that read NVRAM entries. We will be able to
safely call bcm47xx_nvram_* functions without #ifdef-s.
2) Getting NVRAM driver out of MIPS arch code. This is needed to support
BCM5301X arch which also requires this NVRAM driver. Patch for that
will follow once we get is reviewed.
Cc: linux-mips@linux-mips.org
Cc: Paul Walmsley <paul@pwsan.com>
Cc: linux-soc@vger.kernel.org
Patchwork: https://patchwork.linux-mips.org/patch/8619/
Some BCM47XX SoC routers have LEDs connected to extra PCIe bcma buses.
Handling them in arch code requires predictable GPIO numbers.
This reverts commit b09f5ec18b16b82f4db8a735e453332db7514275.
Now that we have fully working BCMA_DRIVER_PCI symbol (in can be safely
disabled), there is no risk bcma will try to use PCI code without PCI
available.
