Initramfs initrd images do not need a ramdisk device, so remove this
restriction in Kconfig. BLK_DEV_RAM=n saves about 13k on i386. Also
without ramdisk device there's no need for "dry run", so initramfs unpacks
much faster.
People using cramfs, squashfs, or gzipped ext2/minix initrd images are
probably smart enough not to turn off ramdisk support by accident.
Cc: Al Viro <viro@ftp.linux.org.uk>
Allocate memory for read-gathering at open time, when it is known just how
much memory is needed. This avoids wasting kernel memory when the real packet
size is smaller than the maximum packet size supported by the driver. This is
always the case when using DVD discs.
Signed-off-by: Peter Osterlund <petero2@telia.com>
Unless the help text is outdated, this seems to be logical.
Make drivers that use directly PC parport HW depend on PARPORT_PC rather than
HW independent PARPORT.
Signed-off-by: Marko Kohtala <marko.kohtala@gmail.com>
This patch adds a shim driver libusual, which routes devices between
usb-storage and ub according to the common table, based on unusual_devs.h.
The help and example syntax is in Kconfig.
Signed-off-by: Pete Zaitcev <zaitcev@redhat.com>
drivers/block/ is right now a mix of core and driver parts. Lets move
the core parts to a new top level directory. Al will move the fs/
related block parts to block/ next.
Signed-off-by: Jens Axboe <axboe@suse.de>
Sanitized and fixed floppy dependencies: split the messy dependencies for
BLK_DEV_FD by introducing a new symbol (ARCH_MAY_HAVE_PC_FDC), making
BLK_DEV_FD depend on that one and taking declarations of ARCH_MAY_HAVE_PC_FDC
to arch/*/Kconfig. While we are at it, fixed several obvious cases when
BLK_DEV_FD should have been excluded (architectures lacking asm/floppy.h
are *not* going to have floppy.c compile, let alone work).
If you can come up with better name for that ("this architecture might
have working PC-compatible floppy disk controller"), you are more than
welcome - just s/ARCH_MAY_HAVE_PC_FDC/your_prefered_name/g in the patch
below...
Start cleaning 32-bit vs. 64-bit configuration.
Move initramfs options from Device Drivers | Block Drivers to General Setup
This is a more natural place for this option.
Furthermore separate out intramfs options to usr/Kconfig
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
Drivers that expect ISA DMA API are marked as such in Kconfig.
Signed-off-by: Al Viro <viro@parcelfarce.linux.theplanet.co.uk>
(!ARCH_S390 && !M68K && !IA64 && !UML) is obviously always true on ARM.
Intended behaviour for ARM is "absent unless we are on RiscPC or
EBSA285". So what we want is added && !ARM in the first term - without
it the last part (|| ARCH_RPC || ARCH_EBSA285, that is) doesn't do
anything.
Both the RiscPC and (optionally) EBSA285 have floppy disk support. Allow this
option to be selected on these ARM platforms again.
Signed-off-by: Russell King <rmk@arm.linux.org.uk>
infrastructure for it.
Let it rip!
