The code in __brd_direct_access multiplies the pgoff variable by page size
and divides it by 512. It can cause overflow on 32-bit architectures. The
overflow happens if we create ramdisk larger than 4G and use it as a
sparse device.
This patch replaces multiplication and division with multiplication by the
number of sectors per page.
Reviewed-by: Dan Williams <dan.j.williams@intel.com>
Signed-off-by: Mikulas Patocka <mpatocka@redhat.com>
Fixes: 1647b9b959c7 ("brd: add dax_operations support")
Cc: stable@vger.kernel.org # 4.12+
Pull block layer updates from Jens Axboe:
"This is the first pull request for 4.14, containing most of the code
changes. It's a quiet series this round, which I think we needed after
the churn of the last few series. This contains:
- Fix for a registration race in loop, from Anton Volkov.
- Overflow complaint fix from Arnd for DAC960.
- Series of drbd changes from the usual suspects.
- Conversion of the stec/skd driver to blk-mq. From Bart.
- A few BFQ improvements/fixes from Paolo.
- CFQ improvement from Ritesh, allowing idling for group idle.
- A few fixes found by Dan's smatch, courtesy of Dan.
- A warning fixup for a race between changing the IO scheduler and
device remova. From David Jeffery.
- A few nbd fixes from Josef.
- Support for cgroup info in blktrace, from Shaohua.
- Also from Shaohua, new features in the null_blk driver to allow it
to actually hold data, among other things.
- Various corner cases and error handling fixes from Weiping Zhang.
- Improvements to the IO stats tracking for blk-mq from me. Can
drastically improve performance for fast devices and/or big
machines.
- Series from Christoph removing bi_bdev as being needed for IO
submission, in preparation for nvme multipathing code.
- Series from Bart, including various cleanups and fixes for switch
fall through case complaints"
* 'for-4.14/block' of git://git.kernel.dk/linux-block: (162 commits)
kernfs: checking for IS_ERR() instead of NULL
drbd: remove BIOSET_NEED_RESCUER flag from drbd_{md_,}io_bio_set
drbd: Fix allyesconfig build, fix recent commit
drbd: switch from kmalloc() to kmalloc_array()
drbd: abort drbd_start_resync if there is no connection
drbd: move global variables to drbd namespace and make some static
drbd: rename "usermode_helper" to "drbd_usermode_helper"
drbd: fix race between handshake and admin disconnect/down
drbd: fix potential deadlock when trying to detach during handshake
drbd: A single dot should be put into a sequence.
drbd: fix rmmod cleanup, remove _all_ debugfs entries
drbd: Use setup_timer() instead of init_timer() to simplify the code.
drbd: fix potential get_ldev/put_ldev refcount imbalance during attach
drbd: new disk-option disable-write-same
drbd: Fix resource role for newly created resources in events2
drbd: mark symbols static where possible
drbd: Send P_NEG_ACK upon write error in protocol != C
drbd: add explicit plugging when submitting batches
drbd: change list_for_each_safe to while(list_first_entry_or_null)
drbd: introduce drbd_recv_header_maybe_unplug
The .rw_page in struct block_device_operations is used by the swap
subsystem to read/write the page contents from/into the corresponding
swap slot in the swap device. To support the THP (Transparent Huge
Page) swap optimization, the .rw_page is enhanced to support to
read/write THP if possible.
Link: http://lkml.kernel.org/r/20170724051840.2309-6-ying.huang@intel.com
Signed-off-by: "Huang, Ying" <ying.huang@intel.com>
Reviewed-by: Ross Zwisler <ross.zwisler@intel.com> [for brd.c, zram_drv.c, pmem.c]
Cc: Minchan Kim <minchan@kernel.org>
Cc: Dan Williams <dan.j.williams@intel.com>
Cc: Vishal L Verma <vishal.l.verma@intel.com>
Cc: "Kirill A . Shutemov" <kirill.shutemov@linux.intel.com>
Cc: Michal Hocko <mhocko@kernel.org>
Cc: Shaohua Li <shli@kernel.org>
This way we don't need a block_device structure to submit I/O. The
block_device has different life time rules from the gendisk and
request_queue and is usually only available when the block device node
is open. Other callers need to explicitly create one (e.g. the lightnvm
passthrough code, or the new nvme multipathing code).
For the actual I/O path all that we need is the gendisk, which exists
once per block device. But given that the block layer also does
partition remapping we additionally need a partition index, which is
used for said remapping in generic_make_request.
Note that all the block drivers generally want request_queue or
sometimes the gendisk, so this removes a layer of indirection all
over the stack.
The global variable 'rd_size' is declared as 'int' in source file
arch/arm/kernel/atags_parse.c and as 'unsigned long' in
drivers/block/brd.c. Fix this inconsistency.
Additionally, remove the declarations of rd_image_start, rd_prompt and
rd_doload from parse_tag_ramdisk() since these duplicate existing
declarations in <linux/initrd.h>.
Link: http://lkml.kernel.org/r/20170627065024.12347-1-bart.vanassche@wdc.com
Signed-off-by: Bart Van Assche <bart.vanassche@sandisk.com>
Acked-by: Russell King <rmk+kernel@armlinux.org.uk>
Cc: Jan Kara <jack@suse.cz>
Cc: Jason Yan <yanaijie@huawei.com>
Cc: Zhaohongjiang <zhaohongjiang@huawei.com>
Cc: Miao Xie <miaoxie@huawei.com>
git://git.kernel.org/pub/scm/linux/kernel/git/nvdimm/nvdimm
Pull libnvdimm updates from Dan Williams:
"libnvdimm updates for the latest ACPI and UEFI specifications. This
pull request also includes new 'struct dax_operations' enabling to
undo the abuse of copy_user_nocache() for copy operations to pmem.
The dax work originally missed 4.12 to address concerns raised by Al.
Summary:
- Introduce the _flushcache() family of memory copy helpers and use
them for persistent memory write operations on x86. The
_flushcache() semantic indicates that the cache is either bypassed
for the copy operation (movnt) or any lines dirtied by the copy
operation are written back (clwb, clflushopt, or clflush).
- Extend dax_operations with ->copy_from_iter() and ->flush()
operations. These operations and other infrastructure updates allow
all persistent memory specific dax functionality to be pushed into
libnvdimm and the pmem driver directly. It also allows dax-specific
sysfs attributes to be linked to a host device, for example:
/sys/block/pmem0/dax/write_cache
- Add support for the new NVDIMM platform/firmware mechanisms
introduced in ACPI 6.2 and UEFI 2.7. This support includes the v1.2
namespace label format, extensions to the address-range-scrub
command set, new error injection commands, and a new BTT
(block-translation-table) layout. These updates support inter-OS
and pre-OS compatibility.
- Fix a longstanding memory corruption bug in nfit_test.
- Make the pmem and nvdimm-region 'badblocks' sysfs files poll(2)
capable.
- Miscellaneous fixes and small updates across libnvdimm and the nfit
driver.
Acknowledgements that came after the branch was pushed: commit
6aa734a2f38e ("libnvdimm, region, pmem: fix 'badblocks'
sysfs_get_dirent() reference lifetime") was reviewed by Toshi Kani
<toshi.kani@hpe.com>"
* tag 'libnvdimm-for-4.13' of git://git.kernel.org/pub/scm/linux/kernel/git/nvdimm/nvdimm: (42 commits)
libnvdimm, namespace: record 'lbasize' for pmem namespaces
acpi/nfit: Issue Start ARS to retrieve existing records
libnvdimm: New ACPI 6.2 DSM functions
acpi, nfit: Show bus_dsm_mask in sysfs
libnvdimm, acpi, nfit: Add bus level dsm mask for pass thru.
acpi, nfit: Enable DSM pass thru for root functions.
libnvdimm: passthru functions clear to send
libnvdimm, btt: convert some info messages to warn/err
libnvdimm, region, pmem: fix 'badblocks' sysfs_get_dirent() reference lifetime
libnvdimm: fix the clear-error check in nsio_rw_bytes
libnvdimm, btt: fix btt_rw_page not returning errors
acpi, nfit: quiet invalid block-aperture-region warnings
libnvdimm, btt: BTT updates for UEFI 2.7 format
acpi, nfit: constify *_attribute_group
libnvdimm, pmem: disable dax flushing when pmem is fronting a volatile region
libnvdimm, pmem, dax: export a cache control attribute
dax: convert to bitmask for flags
dax: remove default copy_from_iter fallback
libnvdimm, nfit: enable support for volatile ranges
libnvdimm, pmem: fix persistence warning
Require all dax-drivers to register a ->copy_from_iter() operation so
that it is clear which dax_operations are optional and which must be
implemented for filesystem-dax to operate.
Cc: Gerald Schaefer <gerald.schaefer@de.ibm.com>
Suggested-by: Christoph Hellwig <hch@lst.de>
We only call blk_queue_bounce for request-based drivers, so stop messing
with it for make_request based drivers.
"The bulk of this has been in multiple -next releases. There were a few
late breaking fixes and small features that got added in the last
couple days, but the whole set has received a build success
notification from the kbuild robot.
Change summary:
- Region media error reporting: A libnvdimm region device is the
parent to one or more namespaces. To date, media errors have been
reported via the "badblocks" attribute attached to pmem block
devices for namespaces in "raw" or "memory" mode. Given that
namespaces can be in "device-dax" or "btt-sector" mode this new
interface reports media errors generically, i.e. independent of
namespace modes or state.
This subsequently allows userspace tooling to craft "ACPI 6.1
Section 9.20.7.6 Function Index 4 - Clear Uncorrectable Error"
requests and submit them via the ioctl path for NVDIMM root bus
devices.
- Introduce 'struct dax_device' and 'struct dax_operations': Prompted
by a request from Linus and feedback from Christoph this allows for
dax capable drivers to publish their own custom dax operations.
This fixes the broken assumption that all dax operations are
related to a persistent memory device, and makes it easier for
other architectures and platforms to add customized persistent
memory support.
- 'libnvdimm' core updates: A new "deep_flush" sysfs attribute is
available for storage appliance applications to manually trigger
memory controllers to drain write-pending buffers that would
otherwise be flushed automatically by the platform ADR
(asynchronous-DRAM-refresh) mechanism at a power loss event.
Support for "locked" DIMMs is included to prevent namespaces from
surfacing when the namespace label data area is locked. Finally,
fixes for various reported deadlocks and crashes, also tagged for
-stable.
- ACPI / nfit driver updates: General updates of the nfit driver to
add DSM command overrides, ACPI 6.1 health state flags support, DSM
payload debug available by default, and various fixes.
- commmit 565851c972b5 "device-dax: fix sysfs attribute deadlock":
Tested-by: Yi Zhang <yizhan@redhat.com>
- commit 23f498448362 "libnvdimm: rework region badblocks clearing"
Tested-by: Toshi Kani <toshi.kani@hpe.com>"
* tag 'libnvdimm-for-4.12' of git://git.kernel.org/pub/scm/linux/kernel/git/nvdimm/nvdimm: (52 commits)
libnvdimm, pfn: fix 'npfns' vs section alignment
libnvdimm: handle locked label storage areas
libnvdimm: convert NDD_ flags to use bitops, introduce NDD_LOCKED
brd: fix uninitialized use of brd->dax_dev
block, dax: use correct format string in bdev_dax_supported
libnvdimm: restore "libnvdimm: band aid btt vs clear poison locking"
libnvdimm: fix nvdimm_bus_lock() vs device_lock() ordering
acpi, nfit: kill ACPI_NFIT_DEBUG
libnvdimm: fix clear length of nvdimm_forget_poison()
libnvdimm, pmem: fix a NULL pointer BUG in nd_pmem_notify
libnvdimm, region: sysfs trigger for nvdimm_flush()
libnvdimm: fix phys_addr for nvdimm_clear_poison
x86, dax, pmem: remove indirection around memcpy_from_pmem()
block: remove block_device_operations ->direct_access()
block, dax: convert bdev_dax_supported() to dax_direct_access()
filesystem-dax: convert to dax_direct_access()
Revert "block: use DAX for partition table reads"
ext2, ext4, xfs: retrieve dax_device for iomap operations
commit 1647b9b9 "brd: add dax_operations support" introduced the allocation
and freeing of a dax_device, but the allocated dax_device is not stored
into the brd_device, so brd_del_one() will eventually operate on an
uninitialized brd->dax_dev.
Fix this by storing the allocated dax_device to brd->dax_dev.
Signed-off-by: Gerald Schaefer <gerald.schaefer@de.ibm.com>
Now that all the producers and consumers of dax interfaces have been
converted to using dax_operations on a dax_device, remove the block
device direct_access enabling.
Setup a dax_inode to have the same lifetime as the brd block device and
add a ->direct_access() method that is equivalent to
brd_direct_access(). Once fs/dax.c has been converted to use
dax_operations the old brd_direct_access() will be removed.
It's just a in-driver reimplementation of writing zeroes to the pages,
which fails if the discards aren't page aligned.
Reviewed-by: Hannes Reinecke <hare@suse.com>
Signed-off-by: Jens Axboe <axboe@fb.com>
This was entirely automated, using the script by Al:
PATT='^[[:blank:]]*#[[:blank:]]*include[[:blank:]]*<asm/uaccess.h>'
sed -i -e "s!$PATT!#include <linux/uaccess.h>!" \
$(git grep -l "$PATT"|grep -v ^include/linux/uaccess.h)
to do the replacement at the end of the merge window.
Requested-by: Al Viro <viro@zeniv.linux.org.uk>
Discontinue having the brd driver destructively free all pages in the
ramdisk in response to the BLKFLSBUF ioctl. Doing so allows a BLKFLSBUF
ioctl issued to a logical partition to destroy pages of the parent brd
device (and all other partitions of that brd device).
This change breaks compatibility - but in this case the compatibility
breaks more than it helps.
Reported-by: Mikulas Patocka <mpatocka@redhat.com>
Suggested-by: Christoph Hellwig <hch@infradead.org>
Signed-off-by: Mike Snitzer <snitzer@redhat.com>
Currently rd_size was int which lead to overflow and bogus device size
once the requested ramdisk size was 1 TB or more. Although these days
ramdisks with 1 TB size are mostly a mistake, the days when they are
useful are not far.
Reported-by: Bart Van Assche <bart.vanassche@sandisk.com>
Commit abf545484d31 changed it from an 'rw' flags type to the
newer ops based interface, but now we're effectively leaking
some bdev internals to the rest of the kernel. Since we only
care about whether it's a read or a write at that level, just
pass in a bool 'is_write' parameter instead.
Then we can also move op_is_write() and friends back under
CONFIG_BLOCK protection.
Reviewed-by: Mike Christie <mchristi@redhat.com>
The rw_page users were not converted to use bio/req ops. As a result
bdev_write_page is not passing down REQ_OP_WRITE and the IOs will
be sent down as reads.
Signed-off-by: Mike Christie <mchristi@redhat.com>
Fixes: 4e1b2d52a80d ("block, fs, drivers: remove REQ_OP compat defs and related code")
Modified by me to:
1) Drop op_flags passing into ->rw_page(), as we don't use it.
2) Make op_is_write() and friends safe to use for !CONFIG_BLOCK
- Replace pcommit with ADR / directed-flushing.
The pcommit instruction, which has not shipped on any product, is
deprecated. Instead, the requirement is that platforms implement
either ADR, or provide one or more flush addresses per nvdimm.
ADR (Asynchronous DRAM Refresh) flushes data in posted write buffers
to the memory controller on a power-fail event.
Flush addresses are defined in ACPI 6.x as an NVDIMM Firmware
Interface Table (NFIT) sub-structure: "Flush Hint Address Structure".
A flush hint is an mmio address that when written and fenced assures
that all previous posted writes targeting a given dimm have been
flushed to media.
- On-demand ARS (address range scrub).
Linux uses the results of the ACPI ARS commands to track bad blocks
in pmem devices. When latent errors are detected we re-scrub the
media to refresh the bad block list, userspace can also request a
re-scrub at any time.
- Support for the Microsoft DSM (device specific method) command
format.
- Support for EDK2/OVMF virtual disk device memory ranges.
- Various fixes and cleanups across the subsystem.
* tag 'libnvdimm-for-4.8' of git://git.kernel.org/pub/scm/linux/kernel/git/nvdimm/nvdimm: (41 commits)
libnvdimm-btt: Delete an unnecessary check before the function call "__nd_device_register"
nfit: do an ARS scrub on hitting a latent media error
nfit: move to nfit/ sub-directory
nfit, libnvdimm: allow an ARS scrub to be triggered on demand
libnvdimm: register nvdimm_bus devices with an nd_bus driver
pmem: clarify a debug print in pmem_clear_poison
x86/insn: remove pcommit
Revert "KVM: x86: add pcommit support"
nfit, tools/testing/nvdimm/: unify shutdown paths
libnvdimm: move ->module to struct nvdimm_bus_descriptor
nfit: cleanup acpi_nfit_init calling convention
nfit: fix _FIT evaluation memory leak + use after free
tools/testing/nvdimm: add manufacturing_{date|location} dimm properties
tools/testing/nvdimm: add virtual ramdisk range
acpi, nfit: treat virtual ramdisk SPA as pmem region
pmem: kill __pmem address space
pmem: kill wmb_pmem()
libnvdimm, pmem: use nvdimm_flush() for namespace I/O writes
fs/dax: remove wmb_pmem()
libnvdimm, pmem: flush posted-write queues on shutdown
Pull block driver updates from Jens Axboe:
"This branch also contains core changes. I've come to the conclusion
that from 4.9 and forward, I'll be doing just a single branch. We
often have dependencies between core and drivers, and it's hard to
always split them up appropriately without pulling core into drivers
when that happens.
That said, this contains:
- separate secure erase type for the core block layer, from
Christoph.
- set of discard fixes, from Christoph.
- bio shrinking fixes from Christoph, as a followup up to the
op/flags change in the core branch.
- map and append request fixes from Christoph.
- NVMeF (NVMe over Fabrics) code from Christoph. This is pretty
exciting!
- nvme-loop fixes from Arnd.
- removal of ->driverfs_dev from Dan, after providing a
device_add_disk() helper.
- bcache fixes from Bhaktipriya and Yijing.
- cdrom subchannel read fix from Vchannaiah.
- set of lightnvm updates from Wenwei, Matias, Johannes, and Javier.
- set of drbd updates and fixes from Fabian, Lars, and Philipp.
- mg_disk error path fix from Bart.
- user notification for failed device add for loop, from Minfei.
- NVMe in general:
+ NVMe delay quirk from Guilherme.
+ SR-IOV support and command retry limits from Keith.
+ fix for memory-less NUMA node from Masayoshi.
+ use UINT_MAX for discard sectors, from Minfei.
+ cancel IO fixes from Ming.
+ don't allocate unused major, from Neil.
+ error code fixup from Dan.
+ use constants for PSDT/FUSE from James.
+ variable init fix from Jay.
+ fabrics fixes from Ming, Sagi, and Wei.
+ various fixes"
* 'for-4.8/drivers' of git://git.kernel.dk/linux-block: (115 commits)
nvme/pci: Provide SR-IOV support
nvme: initialize variable before logical OR'ing it
block: unexport various bio mapping helpers
scsi/osd: open code blk_make_request
target: stop using blk_make_request
block: simplify and export blk_rq_append_bio
block: ensure bios return from blk_get_request are properly initialized
virtio_blk: use blk_rq_map_kern
memstick: don't allow REQ_TYPE_BLOCK_PC requests
block: shrink bio size again
block: simplify and cleanup bvec pool handling
block: get rid of bio_rw and READA
block: don't ignore -EOPNOTSUPP blkdev_issue_write_same
block: introduce BLKDEV_DISCARD_ZERO to fix zeroout
NVMe: don't allocate unused nvme_major
nvme: avoid crashes when node 0 is memoryless node.
nvme: Limit command retries
loop: Make user notify for adding loop device failed
nvme-loop: fix nvme-loop Kconfig dependencies
nvmet: fix return value check in nvmet_subsys_alloc()
Currently, presence of direct_access() in block_device_operations
indicates support of DAX on its block device. Because
block_device_operations is instantiated with 'const', this DAX
capablity may not be enabled conditinally.
In preparation for supporting DAX to device-mapper devices, add
QUEUE_FLAG_DAX to request_queue flags to advertise their DAX
support. This will allow to set the DAX capability based on how
mapped device is composed.
Signed-off-by: Toshi Kani <toshi.kani@hpe.com>
Acked-by: Dan Williams <dan.j.williams@intel.com>
Cc: Ross Zwisler <ross.zwisler@linux.intel.com>
Cc: <linux-s390@vger.kernel.org>
These two are confusing leftover of the old world order, combining
values of the REQ_OP_ and REQ_ namespaces. For callers that don't
special case we mostly just replace bi_rw with bio_data_dir or
op_is_write, except for the few cases where a switch over the REQ_OP_
values makes more sense. Any check for READA is replaced with an
explicit check for REQ_RAHEAD. Also remove the READA alias for
REQ_RAHEAD.
Reviewed-by: Johannes Thumshirn <jthumshirn@suse.de>
The __pmem address space was meant to annotate codepaths that touch
persistent memory and need to coordinate a call to wmb_pmem(). Now that
wmb_pmem() is gone, there is little need to keep this annotation.
This patch converts the simple bi_rw use cases in the block,
drivers, mm and fs code to set/get the bio operation using
bio_set_op_attrs/bio_op
These should be simple one or two liner cases, so I just did them
in one patch. The next patches handle the more complicated
cases in a module per patch.
1/ If a mapping overlaps a bad sector fail the request.
2/ Do not opportunistically report more dax-capable capacity than is
requested when errors present.
Reviewed-by: Jeff Moyer <jmoyer@redhat.com>
[vishal: fix a conflict with system RAM collision patches]
[vishal: add a 'size' parameter to ->direct_access]
[vishal: fix a conflict with DAX alignment check patches]
Signed-off-by: Vishal Verma <vishal.l.verma@intel.com>
PAGE_CACHE_{SIZE,SHIFT,MASK,ALIGN} macros were introduced *long* time
ago with promise that one day it will be possible to implement page
cache with bigger chunks than PAGE_SIZE.
This promise never materialized. And unlikely will.
We have many places where PAGE_CACHE_SIZE assumed to be equal to
PAGE_SIZE. And it's constant source of confusion on whether
PAGE_CACHE_* or PAGE_* constant should be used in a particular case,
especially on the border between fs and mm.
Global switching to PAGE_CACHE_SIZE != PAGE_SIZE would cause to much
breakage to be doable.
Let's stop pretending that pages in page cache are special. They are
not.
The changes are pretty straight-forward:
- <foo> << (PAGE_CACHE_SHIFT - PAGE_SHIFT) -> <foo>;
- <foo> >> (PAGE_CACHE_SHIFT - PAGE_SHIFT) -> <foo>;
- PAGE_CACHE_{SIZE,SHIFT,MASK,ALIGN} -> PAGE_{SIZE,SHIFT,MASK,ALIGN};
- page_cache_get() -> get_page();
- page_cache_release() -> put_page();
This patch contains automated changes generated with coccinelle using
script below. For some reason, coccinelle doesn't patch header files.
I've called spatch for them manually.
The only adjustment after coccinelle is revert of changes to
PAGE_CAHCE_ALIGN definition: we are going to drop it later.
There are few places in the code where coccinelle didn't reach. I'll
fix them manually in a separate patch. Comments and documentation also
will be addressed with the separate patch.
virtual patch
expression E;
- E << (PAGE_CACHE_SHIFT - PAGE_SHIFT)
+ E
expression E;
- E >> (PAGE_CACHE_SHIFT - PAGE_SHIFT)
+ E
- PAGE_CACHE_SHIFT
+ PAGE_SHIFT
- PAGE_CACHE_SIZE
+ PAGE_SIZE
- PAGE_CACHE_MASK
+ PAGE_MASK
expression E;
- PAGE_CACHE_ALIGN(E)
+ PAGE_ALIGN(E)
expression E;
- page_cache_get(E)
+ get_page(E)
expression E;
- page_cache_release(E)
+ put_page(E)
Avoid that discard requests with size => PAGE_SIZE fail with
-EIO. Refuse discard requests if the discard size is not a
multiple of the page size.
Fixes: 2dbe54957636 ("brd: Refuse improperly aligned discard requests")
Reviewed-by: Jan Kara <jack@suse.com>
Cc: Robert Elliot <elliott@hp.com>
Cc: stable <stable@vger.kernel.org> # v4.4+
For the purpose of communicating the optional presence of a 'struct
page' for the pfn returned from ->direct_access(), introduce a type that
encapsulates a page-frame-number plus flags. These flags contain the
historical "page_link" encoding for a scatterlist entry, but can also
denote "device memory". Where "device memory" is a set of pfns that are
not part of the kernel's linear mapping by default, but are accessed via
the same memory controller as ram.
The motivation for this new type is large capacity persistent memory
that needs struct page entries in the 'memmap' to support 3rd party DMA
(i.e. O_DIRECT I/O with a persistent memory source/target). However,
we also need it in support of maintaining a list of mapped inodes which
need to be unmapped at driver teardown or freeze_bdev() time.
Cc: Dave Hansen <dave@sr71.net>
Currently when improperly aligned discard request is submitted, we just
silently discard more / less data which results in filesystem corruption
in some cases. Refuse such misaligned requests.
Signed-off-by: Jan Kara <jack@suse.com>
No functional changes in this patch, but it prepares us for returning
a more useful cookie related to the IO that was queued up.
Acked-by: Christoph Hellwig <hch@lst.de>
Acked-by: Keith Busch <keith.busch@intel.com>
"This update has successfully completed a 0day-kbuild run and has
appeared in a linux-next release. The changes outside of the typical
drivers/nvdimm/ and drivers/acpi/nfit.[ch] paths are related to the
removal of IORESOURCE_CACHEABLE, the introduction of memremap(), and
the introduction of ZONE_DEVICE + devm_memremap_pages().
Summary:
- Introduce ZONE_DEVICE and devm_memremap_pages() as a generic
mechanism for adding device-driver-discovered memory regions to the
kernel's direct map.
This facility is used by the pmem driver to enable pfn_to_page()
operations on the page frames returned by DAX ('direct_access' in
'struct block_device_operations').
For now, the 'memmap' allocation for these "device" pages comes
from "System RAM". Support for allocating the memmap from device
memory will arrive in a later kernel.
- Introduce memremap() to replace usages of ioremap_cache() and
ioremap_wt(). memremap() drops the __iomem annotation for these
mappings to memory that do not have i/o side effects. The
replacement of ioremap_cache() with memremap() is limited to the
pmem driver to ease merging the api change in v4.3.
Completion of the conversion is targeted for v4.4.
- Similar to the usage of memcpy_to_pmem() + wmb_pmem() in the pmem
driver, update the VFS DAX implementation and PMEM api to provide
persistence guarantees for kernel operations on a DAX mapping.
- Convert the ACPI NFIT 'BLK' driver to map the block apertures as
cacheable to improve performance.
- Miscellaneous updates and fixes to libnvdimm including support for
issuing "address range scrub" commands, clarifying the optimal
'sector size' of pmem devices, a clarification of the usage of the
ACPI '_STA' (status) property for DIMM devices, and other minor
fixes"
* tag 'libnvdimm-for-4.3' of git://git.kernel.org/pub/scm/linux/kernel/git/nvdimm/nvdimm: (34 commits)
libnvdimm, pmem: direct map legacy pmem by default
libnvdimm, pmem: 'struct page' for pmem
libnvdimm, pfn: 'struct page' provider infrastructure
x86, pmem: clarify that ARCH_HAS_PMEM_API implies PMEM mapped WB
add devm_memremap_pages
mm: ZONE_DEVICE for "device memory"
mm: move __phys_to_pfn and __pfn_to_phys to asm/generic/memory_model.h
dax: drop size parameter to ->direct_access()
nd_blk: change aperture mapping from WC to WB
nvdimm: change to use generic kvfree()
pmem, dax: have direct_access use __pmem annotation
dax: update I/O path to do proper PMEM flushing
pmem: add copy_from_iter_pmem() and clear_pmem()
pmem, x86: clean up conditional pmem includes
pmem: remove layer when calling arch_has_wmb_pmem()
pmem, x86: move x86 PMEM API to new pmem.h header
libnvdimm, e820: make CONFIG_X86_PMEM_LEGACY a tristate option
pmem: switch to devm_ allocations
devres: add devm_memremap
libnvdimm, btt: write and validate parent_uuid
None of the implementations currently use it. The common
bdev_direct_access() entry point handles all the size checks before
calling ->direct_access().
Update the annotation for the kaddr pointer returned by direct_access()
so that it is a __pmem pointer. This is consistent with the PMEM driver
and with how this direct_access() pointer is used in the DAX code.
Signed-off-by: Ross Zwisler <ross.zwisler@linux.intel.com>
Currently we have two different ways to signal an I/O error on a BIO:
(1) by clearing the BIO_UPTODATE flag
(2) by returning a Linux errno value to the bi_end_io callback
The first one has the drawback of only communicating a single possible
error (-EIO), and the second one has the drawback of not beeing persistent
when bios are queued up, and are not passed along from child to parent
bio in the ever more popular chaining scenario. Having both mechanisms
available has the additional drawback of utterly confusing driver authors
and introducing bugs where various I/O submitters only deal with one of
them, and the others have to add boilerplate code to deal with both kinds
of error returns.
So add a new bi_error field to store an errno value directly in struct
bio and remove the existing mechanisms to clean all this up.
Reviewed-by: Hannes Reinecke <hare@suse.de>
Reviewed-by: NeilBrown <neilb@suse.com>
Some drivers use it now, others just set the limits field manually.
But in preparation for splitting this into a hard and soft limit,
ensure that they all call the proper function for setting the hw
limit for discards.
Since this is relating to FS_XIP, not KERNEL_XIP, it should be called
DAX instead of XIP.
Signed-off-by: Matthew Wilcox <matthew.r.wilcox@intel.com>
Cc: Andreas Dilger <andreas.dilger@intel.com>
Cc: Boaz Harrosh <boaz@plexistor.com>
Cc: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
Cc: Mathieu Desnoyers <mathieu.desnoyers@efficios.com>
Cc: Randy Dunlap <rdunlap@infradead.org>
Cc: Theodore Ts'o <tytso@mit.edu>
Because of the direct_access() API which returns a PFN. partitions
better start on 4K boundary, else offset ZERO of a partition will
not be aligned and blk_direct_access() will fail the call.
By setting blk_queue_physical_block_size(PAGE_SIZE) we can communicate
this to fdisk and friends.
The call to blk_queue_physical_block_size() is harmless and will
not affect the Kernel behavior in any way. It is only for
communication to user-mode.
before this patch running fdisk on a default size brd of 4M
the first sector offered is 34 (BAD), but after this patch it
will be 40, ie 8 sectors aligned. Also when entering some random
partition sizes the next partition-start sector is offered 8 sectors
aligned after this patch. (Please note that with fdisk the user
can still enter bad values, only the offered default values will
be correct)
Note that with bdev-size > 4M fdisk will try to align on a 1M
boundary (above first-sector will be 2048), in any case.
CC: Martin K. Petersen <martin.petersen@oracle.com>
Signed-off-by: Boaz Harrosh <boaz@plexistor.com>
Reviewed-by: Martin K. Petersen <martin.petersen@oracle.com>
This patch fixes up brd's partitions scheme, now enjoying all worlds.
The MAIN fix here is that currently, if one fdisks some partitions,
a BAD bug will make all partitions point to the same start-end sector
ie: 0 - brd_size And an mkfs of any partition would trash the partition
table and the other partition.
Another fix is that "mount -U uuid" will not work if show_part was not
specified, because of the GENHD_FL_SUPPRESS_PARTITION_INFO flag.
We now always load without it and remove the show_part parameter.
[We remove Dmitry's new module-param part_show it is now always
show]
So NOW the logic goes like this:
* max_part - Just says how many minors to reserve between ramX
devices. In any way, there can be as many partition as requested.
If minors between devices ends, then dynamic 259-major ids will
be allocated on the fly.
The default is now max_part=1, which means all partitions devt(s)
will be from the dynamic (259) major-range.
(If persistent partition minors is needed use max_part=X)
For example with /dev/sdX max_part is hard coded 16.
* Creation of new devices on the fly still/always work:
mknod /path/devnod b 1 X
fdisk -l /path/devnod
Will create a new device if [X / max_part] was not already
created before. (Just as before)
partitions on the dynamically created device will work as well
Same logic applies with minors as with the pre-created ones.
TODO: dynamic grow of device size. So each device can have it's
own size.
CC: Dmitry Monakhov <dmonakhov@openvz.org>
Tested-by: Ross Zwisler <ross.zwisler@linux.intel.com>
In order to support accesses to larger chunks of memory, pass in a
'size' parameter (counted in bytes), and return the amount available at
that address.
Add a new helper function, bdev_direct_access(), to handle common
functionality including partition handling, checking the length requested
is positive, checking for the sector being page-aligned, and checking
the length of the request does not pass the end of the partition.
Reviewed-by: Boaz Harrosh <boaz@plexistor.com>
Currenly ram disk is not visiable inside /proc/partitions. This was
done for compatibility reasons here: 53978d0a7a27. But some utilities
expect disk presents in /proc/partitions.
Let's add module's option and let's administrator chose visibility behaviour.
By default, old behaviour preserved.
Signed-off-by: Dmitry Monakhov <dmonakhov@openvz.org>
brd is effectively a thinly provisioned device. Thinly provisioned
devices return -ENOSPC when they can't write a new block. -ENOMEM is an
implementation detail that callers shouldn't know.
Acked-by: Dave Chinner <david@fromorbit.com>
Cc: Dheeraj Reddy <dheeraj.reddy@intel.com>
More prep work for immutable biovecs - with immutable bvecs drivers
won't be able to use the biovec directly, they'll need to use helpers
that take into account bio->bi_iter.bi_bvec_done.
This updates callers for the new usage without changing the
implementation yet.
Signed-off-by: Kent Overstreet <kmo@daterainc.com>
Cc: "Ed L. Cashin" <ecashin@coraid.com>
Cc: Nick Piggin <npiggin@kernel.dk>
Cc: Lars Ellenberg <drbd-dev@lists.linbit.com>
Cc: Jiri Kosina <jkosina@suse.cz>
Cc: Paul Clements <Paul.Clements@steeleye.com>
Cc: Jim Paris <jim@jtan.com>
Cc: Geoff Levand <geoff@infradead.org>
Cc: Yehuda Sadeh <yehuda@inktank.com>
Cc: Sage Weil <sage@inktank.com>
Cc: Alex Elder <elder@inktank.com>
Cc: ceph-devel@vger.kernel.org
Cc: Joshua Morris <josh.h.morris@us.ibm.com>
Cc: Philip Kelleher <pjk1939@linux.vnet.ibm.com>
Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Cc: Neil Brown <neilb@suse.de>
Cc: linux390@de.ibm.com
Cc: Nagalakshmi Nandigama <Nagalakshmi.Nandigama@lsi.com>
Cc: Sreekanth Reddy <Sreekanth.Reddy@lsi.com>
Cc: support@lsi.com
Cc: "James E.J. Bottomley" <JBottomley@parallels.com>
Cc: Steven Whitehouse <swhiteho@redhat.com>
Cc: Herton Ronaldo Krzesinski <herton.krzesinski@canonical.com>
Cc: Tejun Heo <tj@kernel.org>
Cc: Guo Chao <yan@linux.vnet.ibm.com>
Cc: Asai Thambi S P <asamymuthupa@micron.com>
Cc: Selvan Mani <smani@micron.com>
Cc: Sam Bradshaw <sbradshaw@micron.com>
Cc: Matthew Wilcox <matthew.r.wilcox@intel.com>
Cc: Keith Busch <keith.busch@intel.com>
Cc: Stephen Hemminger <shemminger@vyatta.com>
Cc: Quoc-Son Anh <quoc-sonx.anh@intel.com>
Cc: Sebastian Ott <sebott@linux.vnet.ibm.com>
Cc: Nitin Gupta <ngupta@vflare.org>
Cc: Jerome Marchand <jmarchan@redhat.com>
Cc: Seth Jennings <sjenning@linux.vnet.ibm.com>
Cc: "Martin K. Petersen" <martin.petersen@oracle.com>
Cc: Mike Snitzer <snitzer@redhat.com>
Cc: Vivek Goyal <vgoyal@redhat.com>
Cc: "Darrick J. Wong" <darrick.wong@oracle.com>
Cc: Chris Metcalf <cmetcalf@tilera.com>
Cc: linux-m68k@lists.linux-m68k.org
Cc: linuxppc-dev@lists.ozlabs.org
Cc: drbd-user@lists.linbit.com
Cc: nbd-general@lists.sourceforge.net
Cc: cbe-oss-dev@lists.ozlabs.org
Cc: xen-devel@lists.xensource.com
Cc: virtualization@lists.linux-foundation.org
Cc: linux-raid@vger.kernel.org
Cc: linux-s390@vger.kernel.org
Cc: DL-MPTFusionLinux@lsi.com
Cc: linux-scsi@vger.kernel.org
Cc: devel@driverdev.osuosl.org
Cc: linux-fsdevel@vger.kernel.org
Cc: cluster-devel@redhat.com
Cc: linux-mm@kvack.org
Acked-by: Geoff Levand <geoff@infradead.org>
Immutable biovecs are going to require an explicit iterator. To
implement immutable bvecs, a later patch is going to add a bi_bvec_done
member to this struct; for now, this patch effectively just renames
things.
Cc: Matthew Wilcox <willy@linux.intel.com>
Cc: "Michael S. Tsirkin" <mst@redhat.com>
Cc: Alasdair Kergon <agk@redhat.com>
Cc: dm-devel@redhat.com
Cc: Boaz Harrosh <bharrosh@panasas.com>
Cc: Benny Halevy <bhalevy@tonian.com>
Cc: "Nicholas A. Bellinger" <nab@linux-iscsi.org>
Cc: Chris Mason <chris.mason@fusionio.com>
Cc: "Theodore Ts'o" <tytso@mit.edu>
Cc: Andreas Dilger <adilger.kernel@dilger.ca>
Cc: Jaegeuk Kim <jaegeuk.kim@samsung.com>
Cc: Dave Kleikamp <shaggy@kernel.org>
Cc: Joern Engel <joern@logfs.org>
Cc: Prasad Joshi <prasadjoshi.linux@gmail.com>
Cc: Trond Myklebust <Trond.Myklebust@netapp.com>
Cc: KONISHI Ryusuke <konishi.ryusuke@lab.ntt.co.jp>
Cc: Mark Fasheh <mfasheh@suse.com>
Cc: Ben Myers <bpm@sgi.com>
Cc: xfs@oss.sgi.com
Cc: Len Brown <len.brown@intel.com>
Cc: Pavel Machek <pavel@ucw.cz>
Cc: "Rafael J. Wysocki" <rjw@sisk.pl>
Cc: Ben Hutchings <ben@decadent.org.uk>
Cc: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
Cc: "Roger Pau Monné" <roger.pau@citrix.com>
Cc: Jan Beulich <jbeulich@suse.com>
Cc: Stefano Stabellini <stefano.stabellini@eu.citrix.com>
Cc: Ian Campbell <Ian.Campbell@citrix.com>
Cc: Christian Borntraeger <borntraeger@de.ibm.com>
Cc: Jiang Liu <jiang.liu@huawei.com>
Cc: Jerome Marchand <jmarchand@redhat.com>
Cc: Joe Perches <joe@perches.com>
Cc: Peng Tao <tao.peng@emc.com>
Cc: Andy Adamson <andros@netapp.com>
Cc: fanchaoting <fanchaoting@cn.fujitsu.com>
Cc: Jie Liu <jeff.liu@oracle.com>
Cc: Sunil Mushran <sunil.mushran@gmail.com>
Cc: Namjae Jeon <namjae.jeon@samsung.com>
Cc: Pankaj Kumar <pankaj.km@samsung.com>
Cc: Dan Magenheimer <dan.magenheimer@oracle.com>
Cc: Mel Gorman <mgorman@suse.de>6
The probe function is supposed to return NULL on failure (as we can see in
kobj_lookup: kobj = probe(dev, index, data); ... if (kobj) return kobj;
However, in loop and brd, it returns negative error from ERR_PTR.
This causes a crash if we simulate disk allocation failure and run
less -f /dev/loop0 because the negative number is interpreted as a pointer:
BUG: unable to handle kernel NULL pointer dereference at 00000000000002b4
IP: [<ffffffff8118b188>] __blkdev_get+0x28/0x450
PGD 23c677067 PUD 23d6d1067 PMD 0
Oops: 0000 [#1] PREEMPT SMP
Modules linked in: loop hpfs nvidia(PO) ip6table_filter ip6_tables uvesafb cfbcopyarea cfbimgblt cfbfillrect fbcon font bitblit fbcon_rotate fbcon_cw fbcon_ud fbcon_ccw softcursor fb fbdev msr ipt_MASQUERADE iptable_nat nf_nat_ipv4 nf_conntrack_ipv4 nf_defrag_ipv4 xt_state ipt_REJECT xt_tcpudp iptable_filter ip_tables x_tables bridge stp llc tun ipv6 cpufreq_stats cpufreq_ondemand cpufreq_userspace cpufreq_powersave cpufreq_conservative hid_generic spadfs usbhid hid fuse raid0 snd_usb_audio snd_pcm_oss snd_mixer_oss md_mod snd_pcm snd_timer snd_page_alloc snd_hwdep snd_usbmidi_lib dmi_sysfs snd_rawmidi nf_nat_ftp nf_nat nf_conntrack_ftp nf_conntrack snd soundcore lm85 hwmon_vid ohci_hcd ehci_pci ehci_hcd serverworks sata_svw libata acpi_cpufreq freq_table mperf ide_core usbcore kvm_amd kvm tg3 i2c_piix4 libphy microcode e100 usb_common ptp skge i2c_core pcspkr k10temp evdev floppy hwmon pps_core mii rtc_cmos button processor unix [last unloaded: nvidia]
CPU: 1 PID: 6831 Comm: less Tainted: P W O 3.10.15-devel #18
Hardware name: empty empty/S3992-E, BIOS 'V1.06 ' 06/09/2009
task: ffff880203cc6bc0 ti: ffff88023e47c000 task.ti: ffff88023e47c000
RIP: 0010:[<ffffffff8118b188>] [<ffffffff8118b188>] __blkdev_get+0x28/0x450
RSP: 0018:ffff88023e47dbd8 EFLAGS: 00010286
RAX: ffffffffffffff74 RBX: ffffffffffffff74 RCX: 0000000000000000
RDX: 0000000000000000 RSI: 0000000000000000 RDI: 0000000000000001
RBP: ffff88023e47dc18 R08: 0000000000000002 R09: 0000000000000000
R10: 0000000000000000 R11: 0000000000000000 R12: ffff88023f519658
R13: ffffffff8118c300 R14: 0000000000000000 R15: ffff88023f519640
FS: 00007f2070bf7700(0000) GS:ffff880247400000(0000) knlGS:0000000000000000
CR2: 00000000000002b4 CR3: 000000023da1d000 CR4: 00000000000007e0
Stack:
0000000000000002 0000001d00000000 000000003e47dc50 ffff88023f519640
ffff88043d5bb668 ffffffff8118c300 ffff88023d683550 ffff88023e47de60
ffff88023e47dc98 ffffffff8118c10d 0000001d81605698 0000000000000292
Call Trace:
[<ffffffff8118c300>] ? blkdev_get_by_dev+0x60/0x60
[<ffffffff8118c10d>] blkdev_get+0x1dd/0x370
[<ffffffff813cea6c>] ? _raw_spin_unlock+0x2c/0x50
[<ffffffff8118c365>] blkdev_open+0x65/0x80
[<ffffffff8114d12e>] do_dentry_open.isra.18+0x23e/0x2f0
[<ffffffff8114d214>] finish_open+0x34/0x50
[<ffffffff8115e122>] do_last.isra.62+0x2d2/0xc50
[<ffffffff8115eb58>] path_openat.isra.63+0xb8/0x4d0
[<ffffffff81115a8e>] ? might_fault+0x4e/0xa0
[<ffffffff8115f4f0>] do_filp_open+0x40/0x90
[<ffffffff8116db85>] ? __alloc_fd+0xa5/0x1f0
[<ffffffff8114e45f>] do_sys_open+0xef/0x1d0
[<ffffffff8114e559>] SyS_open+0x19/0x20
[<ffffffff813cff16>] system_call_fastpath+0x1a/0x1f
Code: 44 00 00 55 48 89 e5 41 57 49 89 ff 41 56 41 89 d6 41 55 41 54 4c 8d 67 18 53 48 83 ec 18 89 75 cc e9 f2 00 00 00 0f 1f 44 00 00 <48> 8b 80 40 03 00 00 48 89 df 4c 8b 68 58 e8 d5
a4 07 00 44 89
RIP [<ffffffff8118b188>] __blkdev_get+0x28/0x450
RSP <ffff88023e47dbd8>
---[ end trace bb7f32dbf02398dc ]---
The brd change should be backported to stable kernels starting with 2.6.25.
The loop change should be backported to stable kernels starting with 2.6.22.
Acked-by: Tejun Heo <tj@kernel.org>
Cc: stable@kernel.org # 2.6.22+
The index on the page must be set before it is inserted in the radix
tree. Otherwise there is a small race which can occur during lookup
where the page can be found with the incorrect index. This will trigger
the BUG_ON() in brd_lookup_page().
Signed-off-by: Brian Behlendorf <behlendorf1@llnl.gov>
Reported-by: Chris Wedgwood <cw@f00f.org>
Cc: <stable@vger.kernel.org>
Just a little convenience macro - main reason to add it now is preparing
for immutable bio vecs, it'll reduce the size of the patch that puts
bi_sector/bi_size/bi_idx into a struct bvec_iter.
Signed-off-by: Kent Overstreet <koverstreet@google.com>
CC: Jens Axboe <axboe@kernel.dk>
CC: Lars Ellenberg <drbd-dev@lists.linbit.com>
CC: Jiri Kosina <jkosina@suse.cz>
CC: Alasdair Kergon <agk@redhat.com>
CC: dm-devel@redhat.com
CC: Neil Brown <neilb@suse.de>
CC: Martin Schwidefsky <schwidefsky@de.ibm.com>
CC: Heiko Carstens <heiko.carstens@de.ibm.com>
CC: linux-s390@vger.kernel.org
CC: Chris Mason <chris.mason@fusionio.com>
CC: Steven Whitehouse <swhiteho@redhat.com>
Acked-by: Steven Whitehouse <swhiteho@redhat.com>
Signed-off-by: Cong Wang <amwang@redhat.com>
Move invalidate_bdev, block_sync_page into fs/block_dev.c. Export
kill_bdev as well, so brd doesn't have to open code it. Reduce
buffer_head.h requirement accordingly.
Removed a rather large comment from invalidate_bdev, as it looked a bit
obsolete to bother moving. The small comment replacing it says enough.
Signed-off-by: Nick Piggin <npiggin@suse.de>
Cc: Al Viro <viro@ZenIV.linux.org.uk>
There is very little benefit in allowing to let a ->make_request
instance update the bios device and sector and loop around it in
__generic_make_request when we can archive the same through calling
generic_make_request from the driver and letting the loop in
generic_make_request handle it.
Note that various drivers got the return value from ->make_request and
returned non-zero values for errors.
Acked-by: NeilBrown <neilb@suse.de>
Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
