when doing write barrier, the data of the bio is NULL, it's OK for ramdisk
doing nothing, So the result of the bio must be success.
Signed-off-by: Hu Hui <b29976@freescale.com>
Support discard requests in brd by zeroing or deleting the underlying backing
pages. This is simply to help with testing and documentation nature of
brd code.
Signed-off-by: Nick Piggin <npiggin@suse.de>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
The block layer calling convention is blk_queue_<limit name>.
blk_queue_max_sectors predates this practice, leading to some confusion.
Rename the function to appropriately reflect that its intended use is to
set max_hw_sectors.
Also introduce a temporary wrapper for backwards compability. This can
be removed after the merge window is closed.
The "ramdisk" parameter was removed from the defunct rd.c file quite some
time ago, in favour of the more specific "ramdisk_size" parameter so, for
consistency, the same should be done here.
Acked-by: Nick Piggin <nickpiggin@yahoo.com.au>
brd is missing a flush_dcache_page. On 2nd thoughts, perhaps it is the
pagecache's responsibility to flush user virtual aliases (the driver of
course should flush kernel virtual mappings)... but anyway, there
already exists cache flushing for one direction of transfer, so we
should add the other.
brd is always ordered (not that it matters, as it is defined not to
survive when the system goes down). So tell the block layer it is
ordered, which might be of help with testing filesystems.
To keep the size of changesets sane we split the switch by drivers;
to keep the damn thing bisectable we do the following:
1) rename the affected methods, add ones with correct
prototypes, make (few) callers handle both. That's this changeset.
2) for each driver convert to new methods. *ALL* drivers
are converted in this series.
3) kill the old (renamed) methods.
Note that it _is_ a flagday; all in-tree drivers are converted and by the
end of this series no trace of old methods remain. The only reason why
we do that this way is to keep the damn thing bisectable and allow per-driver
debugging if anything goes wrong.
New methods:
open(bdev, mode)
release(disk, mode)
ioctl(bdev, mode, cmd, arg) /* Called without BKL */
compat_ioctl(bdev, mode, cmd, arg)
locked_ioctl(bdev, mode, cmd, arg) /* Called with BKL, legacy */
The name of brd block device is "ramdisk", it's not "brd".
(The block device is registered by register_blkdev(RAMDISK_MAJOR, "ramdisk")
So it should be unregistered by unregister_blkdev(RAMDISK_MAJOR, "ramdisk")
Acked-by: Nick Piggin <npiggin@suse.de>
Alias brd to rd in the hope of helping legacy users. Suggested by Jan.
In 2.6.25, ramdisk devices show up in /proc/partitions, which is a
behaviour change from the old rd.c. Add GENHD_FL_SUPPRESS_PARTITION_INFO,
which was present in rd.c.
All kernels prior to 2.6.25 weren't displaying ramdisks in
/proc/partitions. Since there are many userspace tools using information
from /proc/partitions some of them may now behave incorrectly (I didn't
tested any though). For example before 2.6.25 /proc/partitions was empty
if no block devices like hard disks and such were detected by kernel. Now
all 16 ramdisks are always visible there. Some software may rely on such
information (I mean, on empty /proc/partitions).
There was quite similar situation back in 2004, and ramdisks were excluded
back from displaying. Thats why I called this a regression (maybe a bit
unfortunate). See this patch for info:
http://kernel.org/pub/linux/kernel/people/akpm/patches/2.6/2.6.3-rc2/2.6.3-rc2-mm1/broken-out/nbd-proc-partitions-fix.patch
I also think that someone somewhere (long time ago) excluded ramdisks from
/proc/partitions for good reasons. It is possible that now such new
"feature" is harmless, but I think there are more chances that someone
will say "hey, /proc/partitions has changed, now my software doesn't work"
then "hey where did my new 2.6.25 feature go". nbd devices are also
excluded, maybe for very same (unknown to me) reasons.
Signed-off-by: Marcin Krol <hawk@pld-linux.org>
Cc: <stable@kernel.org>
This patch adds partition management for Block RAM Device (BRD).
This patch is done to keep in sync BRD and loop device drivers.
This patch adds a parameter to the module, max_part, to specify
the maximum number of partitions per RAM device.
Example:
# modprobe brd max_part=63
# ls -l /dev/ram*
brw-rw---- 1 root disk 1, 0 2008-04-03 13:39 /dev/ram0
brw-rw---- 1 root disk 1, 64 2008-04-03 13:39 /dev/ram1
brw-rw---- 1 root disk 1, 640 2008-04-03 13:39 /dev/ram10
brw-rw---- 1 root disk 1, 704 2008-04-03 13:39 /dev/ram11
brw-rw---- 1 root disk 1, 768 2008-04-03 13:39 /dev/ram12
brw-rw---- 1 root disk 1, 832 2008-04-03 13:39 /dev/ram13
brw-rw---- 1 root disk 1, 896 2008-04-03 13:39 /dev/ram14
brw-rw---- 1 root disk 1, 960 2008-04-03 13:39 /dev/ram15
brw-rw---- 1 root disk 1, 128 2008-04-03 13:39 /dev/ram2
brw-rw---- 1 root disk 1, 192 2008-04-03 13:39 /dev/ram3
brw-rw---- 1 root disk 1, 256 2008-04-03 13:39 /dev/ram4
brw-rw---- 1 root disk 1, 320 2008-04-03 13:39 /dev/ram5
brw-rw---- 1 root disk 1, 384 2008-04-03 13:39 /dev/ram6
brw-rw---- 1 root disk 1, 448 2008-04-03 13:39 /dev/ram7
brw-rw---- 1 root disk 1, 512 2008-04-03 13:39 /dev/ram8
brw-rw---- 1 root disk 1, 576 2008-04-03 13:39 /dev/ram9
# fdisk /dev/ram0
Device contains neither a valid DOS partition table, nor Sun, SGI or OSF disklabel
Building a new DOS disklabel. Changes will remain in memory only,
until you decide to write them. After that, of course, the previous
content won't be recoverable.
Warning: invalid flag 0x0000 of partition table 4 will be corrected by w(rite)
Command (m for help): o
Command (m for help): n
Command action
e extended
p primary partition (1-4)
p
Partition number (1-4): 1
First cylinder (1-2, default 1): 1
Last cylinder or +size or +sizeM or +sizeK (1-2, default 2): 2
Command (m for help): w
The partition table has been altered!
Calling ioctl() to re-read partition table.
Syncing disks.
# ls -l /dev/ram0*
brw-rw---- 1 root disk 1, 0 2008-04-03 13:40 /dev/ram0
brw-rw---- 1 root disk 1, 1 2008-04-03 13:40 /dev/ram0p1
# mkfs /dev/ram0p1
mke2fs 1.40-WIP (14-Nov-2006)
Filesystem label=
OS type: Linux
Block size=1024 (log=0)
Fragment size=1024 (log=0)
4016 inodes, 16032 blocks
801 blocks (5.00%) reserved for the super user
First data block=1
Maximum filesystem blocks=16515072
2 block groups
8192 blocks per group, 8192 fragments per group
2008 inodes per group
Superblock backups stored on blocks:
8193
Writing inode tables: done
Writing superblocks and filesystem accounting information: done
This filesystem will be automatically checked every 26 mounts or
180 days, whichever comes first. Use tune2fs -c or -i to override.
# mount /dev/ram0p1 /mnt
df /mnt
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/ram0p1 15521 138 14582 1% /mnt
# ls -l /mnt
total 12
drwx------ 2 root root 12288 2008-04-03 13:41 lost+found
# umount /mnt
# rmmod brd
Signed-off-by: Laurent Vivier <Laurent.Vivier@bull.net>
Cc: Jens Axboe <jens.axboe@oracle.com>
Alter the block device ->direct_access() API to work with the new
get_xip_mem() API (that requires both kaddr and pfn are returned).
Some architectures will not do the right thing in their virt_to_page() for use
by XIP (to translate from the kernel virtual address returned by
direct_access(), to a user mappable pfn in XIP's page fault handler.
However, we can't switch it to just return the pfn and not the kaddr, because
we have no good way to get a kva from a pfn, and XIP requires the kva for its
read(2) and write(2) handlers. So we have to return both.
Signed-off-by: Jared Hulbert <jaredeh@gmail.com>
Cc: Carsten Otte <cotte@de.ibm.com>
Cc: linux-mm@kvack.org
While looking at the implementation of the Ram backed block device
driver, I stumbled across a write-only local variable, which makes
little sense, so I assume it should actually work like this:
Signed-off-by: Petr Tesarik <ptesarik@suse.cz>
Support direct_access XIP method with brd.
This is a rewrite of the ramdisk block device driver.
The old one is really difficult because it effectively implements a block
device which serves data out of its own buffer cache. It relies on the dirty
bit being set, to pin its backing store in cache, however there are non
trivial paths which can clear the dirty bit (eg. try_to_free_buffers()),
which had recently lead to data corruption. And in general it is completely
wrong for a block device driver to do this.
The new one is more like a regular block device driver. It has no idea about
vm/vfs stuff. It's backing store is similar to the buffer cache (a simple
radix-tree of pages), but it doesn't know anything about page cache (the pages
in the radix tree are not pagecache pages).
There is one slight downside -- direct block device access and filesystem
metadata access goes through an extra copy and gets stored in RAM twice.
However, this downside is only slight, because the real buffercache of the
device is now reclaimable (because we're not playing crazy games with it), so
under memory intensive situations, footprint should effectively be the same --
maybe even a slight advantage to the new driver because it can also reclaim
buffer heads.
The fact that it now goes through all the regular vm/fs paths makes it
much more useful for testing, too.
2837 849 384 4070 fe6 drivers/block/rd.o
3528 371 12 3911 f47 drivers/block/brd.o
Text is larger, but data and bss are smaller, making total size smaller.
A few other nice things about it:
- Similar structure and layout to the new loop device handlinag.
- Dynamic ramdisk creation.
- Runtime flexible buffer head size (because it is no longer part of the
ramdisk code).
- Boot / load time flexible ramdisk size, which could easily be extended
to a per-ramdisk runtime changeable size (eg. with an ioctl).
- Can use highmem for the backing store.
[akpm@linux-foundation.org: fix build]
[byron.bbradley@gmail.com: make rd_size non-static]
Signed-off-by: Byron Bradley <byron.bbradley@gmail.com>
