path: root/drivers/block/cciss.c
2014-08-08block: use pci_zalloc_consistentJoe Perches
Remove the now unnecessary memset too. Signed-off-by: Joe Perches <joe@perches.com> Mike Miller <mike.miller@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-21cciss: Use pci_enable_msix_exact() instead of pci_enable_msix()Alexander Gordeev
As result of deprecation of MSI-X/MSI enablement functions pci_enable_msix() and pci_enable_msi_block() all drivers using these two interfaces need to be updated to use the new pci_enable_msi_range() or pci_enable_msi_exact() and pci_enable_msix_range() or pci_enable_msix_exact() interfaces. Signed-off-by: Alexander Gordeev <agordeev@redhat.com> Cc: Mike Miller <mike.miller@hp.com> Cc: iss_storagedev@hp.com Cc: Jens Axboe <axboe@kernel.dk> Cc: linux-pci@vger.kernel.org Signed-off-by: Jens Axboe <axboe@fb.com>
2014-03-13cciss: Fallback to MSI rather than to INTx if MSI-X failedAlexander Gordeev
Currently the driver falls back to INTx mode when MSI-X initialization failed. This is a suboptimal behaviour for chips that also support MSI. This update changes that behaviour and falls back to MSI mode in case MSI-X mode initialization failed. Signed-off-by: Alexander Gordeev <agordeev@redhat.com> Cc: Mike Miller <mike.miller@hp.com> Cc: iss_storagedev@hp.com Cc: Jens Axboe <axboe@kernel.dk> Cc: linux-pci@vger.kernel.org Signed-off-by: Jens Axboe <axboe@fb.com>
2014-01-21drivers/block/cciss.c:cciss_init_one(): use proper errnosAndrew Morton
pci_driver.probe should return a meaningful errno, not -1. Cc: Jens Axboe <axboe@kernel.dk> Cc: Stephen M. Cameron <scameron@beardog.cce.hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2013-11-15tree-wide: use reinit_completion instead of INIT_COMPLETIONWolfram Sang
Use this new function to make code more comprehensible, since we are reinitialzing the completion, not initializing. [akpm@linux-foundation.org: linux-next resyncs] Signed-off-by: Wolfram Sang <wsa@the-dreams.de> Acked-by: Linus Walleij <linus.walleij@linaro.org> (personally at LCE13) Cc: Ingo Molnar <mingo@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-11-08cciss: return 0 from driver probe function on success, not 1Stephen M. Cameron
A return value of 1 is interpreted as an error Signed-off-by: Stephen M. Cameron <scameron@beardog.cce.hp.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2013-09-24cciss: fix info leak in cciss_ioctl32_passthru()Dan Carpenter
The arg64 struct has a hole after ->buf_size which isn't cleared. Or if any of the calls to copy_from_user() fail then that would cause an information leak as well. This was assigned CVE-2013-2147. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Acked-by: Mike Miller <mike.miller@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-11cciss: set max scatter gather entries to 32 on P600Mike Miller
At one time we used to set the maximum number of scatter gather elements on all Smart Array controllers to 32. At some point in time the firmware began to write the "appropriate" value for each controller into the config table. The cciss driver would then read that and set h->maxsgentries. h->maxsgentries = readl(&(h->cfgtable->MaxSGElements); On the P600 that value is 544. Under some workloads a significant performance reduction may result. This patch forces the P600 to use only 32 scatter gather elements. Other controllers are not affected. Signed-off-by: Mike Miller <mike.miller@hp.com> Signed-off-by: Dwight (Bud) Brown <bubrown@redhat.com> Signed-off-by: Tomas Henzl <thenzl@redhat.com> Acked-by: Stephen M. Cameron <steve.cameron@hp.com> Cc: Jens Axboe <axboe@kernel.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-06-12cciss: fix broken mutex usage in ioctlStephen M. Cameron
If a new logical drive is added and the CCISS_REGNEWD ioctl is invoked (as is normal with the Array Configuration Utility) the process will hang as below. It attempts to acquire the same mutex twice, once in do_ioctl() and once in cciss_unlocked_open(). The BKL was recursive, the mutex isn't. Linux version 3.10.0-rc2 (scameron@localhost.localdomain) (gcc version 4.4.7 20120313 (Red Hat 4.4.7-3) (GCC) ) #1 SMP Fri May 24 14:32:12 CDT 2013 [...] acu D 0000000000000001 0 3246 3191 0x00000080 Call Trace: schedule+0x29/0x70 schedule_preempt_disabled+0xe/0x10 __mutex_lock_slowpath+0x17b/0x220 mutex_lock+0x2b/0x50 cciss_unlocked_open+0x2f/0x110 [cciss] __blkdev_get+0xd3/0x470 blkdev_get+0x5c/0x1e0 register_disk+0x182/0x1a0 add_disk+0x17c/0x310 cciss_add_disk+0x13a/0x170 [cciss] cciss_update_drive_info+0x39b/0x480 [cciss] rebuild_lun_table+0x258/0x370 [cciss] cciss_ioctl+0x34f/0x470 [cciss] do_ioctl+0x49/0x70 [cciss] __blkdev_driver_ioctl+0x28/0x30 blkdev_ioctl+0x200/0x7b0 block_ioctl+0x3c/0x40 do_vfs_ioctl+0x89/0x350 SyS_ioctl+0xa1/0xb0 system_call_fastpath+0x16/0x1b This mutex usage was added into the ioctl path when the big kernel lock was removed. As it turns out, these paths are all thread safe anyway (or can easily be made so) and we don't want ioctl() to be single threaded in any case. Signed-off-by: Stephen M. Cameron <scameron@beardog.cce.hp.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: Mike Miller <mike.miller@hp.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-05-08Merge branch 'for-3.10/drivers' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull block driver updates from Jens Axboe: "It might look big in volume, but when categorized, not a lot of drivers are touched. The pull request contains: - mtip32xx fixes from Micron. - A slew of drbd updates, this time in a nicer series. - bcache, a flash/ssd caching framework from Kent. - Fixes for cciss" * 'for-3.10/drivers' of git://git.kernel.dk/linux-block: (66 commits) bcache: Use bd_link_disk_holder() bcache: Allocator cleanup/fixes cciss: bug fix to prevent cciss from loading in kdump crash kernel cciss: add cciss_allow_hpsa module parameter drivers/block/mg_disk.c: add CONFIG_PM_SLEEP to suspend/resume functions mtip32xx: Workaround for unaligned writes bcache: Make sure blocksize isn't smaller than device blocksize bcache: Fix merge_bvec_fn usage for when it modifies the bvm bcache: Correctly check against BIO_MAX_PAGES bcache: Hack around stuff that clones up to bi_max_vecs bcache: Set ra_pages based on backing device's ra_pages bcache: Take data offset from the bdev superblock. mtip32xx: mtip32xx: Disable TRIM support mtip32xx: fix a smatch warning bcache: Disable broken btree fuzz tester bcache: Fix a format string overflow bcache: Fix a minor memory leak on device teardown bcache: Documentation updates bcache: Use WARN_ONCE() instead of __WARN() bcache: Add missing #include <linux/prefetch.h> ...
2013-05-07block_device_operations->release() should return voidAl Viro
The value passed is 0 in all but "it can never happen" cases (and those only in a couple of drivers) *and* it would've been lost on the way out anyway, even if something tried to pass something meaningful. Just don't bother. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-05-01Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull VFS updates from Al Viro, Misc cleanups all over the place, mainly wrt /proc interfaces (switch create_proc_entry to proc_create(), get rid of the deprecated create_proc_read_entry() in favor of using proc_create_data() and seq_file etc). 7kloc removed. * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (204 commits) don't bother with deferred freeing of fdtables proc: Move non-public stuff from linux/proc_fs.h to fs/proc/internal.h proc: Make the PROC_I() and PDE() macros internal to procfs proc: Supply a function to remove a proc entry by PDE take cgroup_open() and cpuset_open() to fs/proc/base.c ppc: Clean up scanlog ppc: Clean up rtas_flash driver somewhat hostap: proc: Use remove_proc_subtree() drm: proc: Use remove_proc_subtree() drm: proc: Use minor->index to label things, not PDE->name drm: Constify drm_proc_list[] zoran: Don't print proc_dir_entry data in debug reiserfs: Don't access the proc_dir_entry in r_open(), r_start() r_show() proc: Supply an accessor for getting the data from a PDE's parent airo: Use remove_proc_subtree() rtl8192u: Don't need to save device proc dir PDE rtl8187se: Use a dir under /proc/net/r8180/ proc: Add proc_mkdir_data() proc: Move some bits from linux/proc_fs.h to linux/{of.h,signal.h,tty.h} proc: Move PDE_NET() to fs/proc/proc_net.c ...
2013-04-29cciss: bug fix to prevent cciss from loading in kdump crash kernelMike Miller
By default the cciss driver supports all "older" HP Smart Array controllers and hpsa supports all controllers starting with the G6 family. There are module parameters that allow a user to override those defaults and use hpsa for any HP Smart Array controller. If the user does override the default behavior and uses hpsa for older controllers it is possible that cciss may try to load in a kdump crash kernel. This may happen if cciss is loaded first from the kdump initrd image. If cciss does load rather than hpsa and reset_devices is true we immediately call cciss_hard_reset_controller. This will result in a kernel panic and the core file cannot be created. This patch prevents cciss from trying to load in this scenario. Signed-off-by: Mike Miller <mike.miller@hp.com> Cc: Jens Axboe <axboe@kernel.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2013-04-29cciss: add cciss_allow_hpsa module parameterMike Miller
Add the cciss_allow_hpsa modules parameter. This allows users to use the hpsa driver instead of cciss for older controllers. Signed-off-by: Mike Miller <mike.miller@hp.com> Cc: Jens Axboe <axboe@kernel.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2013-04-09procfs: new helper - PDE_DATA(inode)Al Viro
The only part of proc_dir_entry the code outside of fs/proc really cares about is PDE(inode)->data. Provide a helper for that; static inline for now, eventually will be moved to fs/proc, along with the knowledge of struct proc_dir_entry layout. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-03-22cciss: fix invalid use of sizeof in cciss_find_cfgtables()Wei Yongjun
sizeof() when applied to a pointer typed expression gives the size of the pointer, not that of the pointed data. Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Acked-by: scameron@beardog.cce.hp.com Signed-off-by: Jens Axboe <axboe@kernel.dk>
2013-01-03Drivers: block: remove __dev* attributes.Greg Kroah-Hartman
CONFIG_HOTPLUG is going away as an option. As a result, the __dev* markings need to be removed. This change removes the use of __devinit, __devexit_p, __devinitdata, __devinitconst, and __devexit from these drivers. Based on patches originally written by Bill Pemberton, but redone by me in order to handle some of the coding style issues better, by hand. Cc: Bill Pemberton <wfp5p@virginia.edu> Cc: Mike Miller <mike.miller@hp.com> Cc: Chirag Kantharia <chirag.kantharia@hp.com> Cc: Geoff Levand <geoff@infradead.org> Cc: Jim Paris <jim@jtan.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: "Michael S. Tsirkin" <mst@redhat.com> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Matthew Wilcox <matthew.r.wilcox@intel.com> Cc: Keith Busch <keith.busch@intel.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: NeilBrown <neilb@suse.de> Cc: Jens Axboe <axboe@kernel.dk> Cc: Tao Guo <Tao.Guo@emc.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-17Merge branch 'for-3.8/drivers' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull block driver update from Jens Axboe: "Now that the core bits are in, here are the driver bits for 3.8. The branch contains: - A huge pile of drbd bits that were dumped from the 3.7 merge window. Following that, it was both made perfectly clear that there is going to be no more over-the-wall pulls and how the situation on individual pulls can be improved. - A few cleanups from Akinobu Mita for drbd and cciss. - Queue improvement for loop from Lukas. This grew into adding a generic interface for waiting/checking an even with a specific lock, allowing this to be pulled out of md and now loop and drbd is also using it. - A few fixes for xen back/front block driver from Roger Pau Monne. - Partition improvements from Stephen Warren, allowing partiion UUID to be used as an identifier." * 'for-3.8/drivers' of git://git.kernel.dk/linux-block: (609 commits) drbd: update Kconfig to match current dependencies drbd: Fix drbdsetup wait-connect, wait-sync etc... commands drbd: close race between drbd_set_role and drbd_connect drbd: respect no-md-barriers setting also when changed online via disk-options drbd: Remove obsolete check drbd: fixup after wait_even_lock_irq() addition to generic code loop: Limit the number of requests in the bio list wait: add wait_event_lock_irq() interface xen-blkfront: free allocated page xen-blkback: move free persistent grants code block: partition: msdos: provide UUIDs for partitions init: reduce PARTUUID min length to 1 from 36 block: store partition_meta_info.uuid as a string cciss: use check_signature() cciss: cleanup bitops usage drbd: use copy_highpage drbd: if the replication link breaks during handshake, keep retrying drbd: check return of kmalloc in receive_uuids drbd: Broadcast sync progress no more often than once per second drbd: don't try to clear bits once the disk has failed ...
2012-11-23cciss: use check_signature()Akinobu Mita
Use check_signature() to find a signature in the mmio address. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Mike Miller <mike.miller@hp.com> Cc: Stephen M. Cameron <scameron@beardog.cce.hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2012-11-23cciss: cleanup bitops usageAkinobu Mita
- Remove unnecessary correction of bit and address - Use BITS_TO_LONGS macro to calculate bitmap size - Use bitmap_zero() Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Mike Miller <mike.miller@hp.com> Cc: Stephen M. Cameron <scameron@beardog.cce.hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2012-10-30cciss: remove unneeded memset()Wei Yongjun
The memory return by kzalloc() or kmem_cache_zalloc() has already be set to zero, so remove useless memset(0). spatch with a semantic match is used to found this problem. (http://coccinelle.lip6.fr/) Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Cc: Mike Miller <mike.miller@hp.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: Stephen M. Cameron <scameron@beardog.cce.hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2012-01-14block: add and use scsi_blk_cmd_ioctlPaolo Bonzini
Introduce a wrapper around scsi_cmd_ioctl that takes a block device. The function will then be enhanced to detect partition block devices and, in that case, subject the ioctls to whitelisting. Cc: linux-scsi@vger.kernel.org Cc: Jens Axboe <axboe@kernel.dk> Cc: James Bottomley <JBottomley@parallels.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-11-28cciss: fix flush cache transfer lengthStephen M. Cameron
We weren't filling in the transfer length of the flush cache command (it transfers 4 bytes of zeroes). Firmware didn't seem to be bothered by this, but it should be fixed. Signed-off-by: Stephen M. Cameron <scameron@beardog.cce.hp.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2011-11-28cciss: Add IRQF_SHARED back in for the non-MSI(X) interrupt handlerStephen M. Cameron
IRQF_SHARED is required for older controllers that don't support MSI(X) and which may end up sharing an interrupt. Also remove deprecated IRQF_DISABLED. Signed-off-by: Stephen M. Cameron <scameron@beardog.cce.hp.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2011-11-16cciss: auto engage SCSI mid layer at driver load timeStephen M. Cameron
A long time ago, probably in 2002, one of the distros, or maybe more than one, loaded block drivers prior to loading the SCSI mid layer. This meant that the cciss driver, being a block driver, could not engage the SCSI mid layer at init time without panicking, and relied on being poked by a userland program after the system was up (and the SCSI mid layer was therefore present) to engage the SCSI mid layer. This is no longer the case, and cciss can safely rely on the SCSI mid layer being present at init time and engage the SCSI mid layer straight away. This means that users will see their tape drives and medium changers at driver load time without need for a script in /etc/rc.d that does this: for x in /proc/driver/cciss/cciss* do echo "engage scsi" > $x done However, if no tape drives or medium changers are detected, the SCSI mid layer will not be engaged. If a tape drive or medium change is later hot-added to the system it will then be necessary to use the above script or similar for the device(s) to be acceesible. Signed-off-by: Stephen M. Cameron <scameron@beardog.cce.hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2011-11-11The Windows driver .inf disables ASPM on all cciss devices. Do the same.Matthew Garrett
Signed-off-by: Matthew Garrett <mjg@redhat.com> Cc: iss_storagedev@hp.com Acked-by: Mike Miller <mike.miller@hp.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2011-10-20cciss: add small delay when using PCI Power Management to reset for kumpMike Miller
The P600 requires a small delay when changing states. Otherwise we may think the board did not reset and we bail. This for kdump only and is particular to the P600. Cc: stable@kernel.org Signed-off-by: Jens Axboe <axboe@kernel.dk>
2011-08-08cciss: add transport mode attribute to sysJoe Handzik
Signed-off-by: Joseph Handzik <joseph.t.handzik@beardog.cce.hp.com> Acked-by: Stephen M. Cameron <scameron@beardog.cce.hp.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-08-08cciss: Adds simple mode functionalityJoseph Handzik
2011-05-06cciss: fix compile issueJens Axboe
drivers/block/cciss.c: In function ‘cciss_send_reset’: drivers/block/cciss.c:2515:2: error: implicit declaration of function ‘fill_cmd’ drivers/block/cciss.c: At top level: drivers/block/cciss.c:2531:12: error: conflicting types for ‘fill_cmd’ drivers/block/cciss.c:2534:1: note: an argument type that has a default promotion can’t match an empty parameter name list declaration drivers/block/cciss.c:2515:18: note: previous implicit declaration of ‘fill_cmd’ was here make[1]: *** [drivers/block/cciss.o] Error 1 make: *** [drivers/block/cciss.o] Error 2 Move fill_cmd() to above where it is first used. Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-05-06cciss: add cciss_tape_cmds module paramterStephen M. Cameron
This is to allow number of commands reserved for use by SCSI tape drives and medium changers to be adjusted at driver load time via the kernel parameter cciss_tape_cmds, with a default value of 6, and a range of 2 - 16 inclusive. Previously, the driver limited the number of commands which could be queued to the SCSI half of the the driver to only 2. This is to fix the problem that if you had more than two tape drives, you couldn't, for example, erase or rewind them all at the same time. Signed-off-by: Stephen M. Cameron <scameron@beardog.cce.hp.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-05-06cciss: do not use bit 2 doorbell resetStephen M. Cameron
It causes NMIs which are undesirable at best, unsurvivable at worst. Prefer the soft reset instead. Signed-off-by: Stephen M. Cameron <scameron@beardog.cce.hp.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-05-06cciss: do not attempt PCI power management reset method if we know it won't ↵Stephen M. Cameron
work. Just go straight to the soft-reset method instead. Signed-off-by: Stephen M. Cameron <scameron@beardog.cce.hp.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-05-06cciss: remove superfluous sleeps around reset codeStephen M. Cameron
2011-05-06cciss: do soft reset if hard reset is brokenStephen M. Cameron
on driver load, if reset_devices is set, and the hard reset attempts fail, try to bring up the controller to the point that a command can be sent, and send it a soft reset command, then after the reset undo whatever driver initialization was done to get it to the point to take a command, and re-do it after the reset. This is to get kdump to work on all the "non-resettable" controllers (except 64xx controllers which can't be reset due to the potentially shared cache module.) Signed-off-by: Stephen M. Cameron <scameron@beardog.cce.hp.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-05-06cciss: use new doorbell-bit-5 reset methodStephen M. Cameron
The bit-2-doorbell reset method seemed to cause (survivable) NMIs on some systems and (unsurvivable) IOCK NMIs on some G7 servers. Firmware guys implemented a new doorbell method to alleviate these problems triggered by bit 5 of the doorbell register. We want to use it if it's available. Signed-off-by: Stephen M. Cameron <scameron@beardog.cce.hp.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-05-06cciss: increase timeouts for post-reset no-opsStephen M. Cameron
Just to reduce the messages about timeouts that appear. Signed-off-by: Stephen M. Cameron <scameron@beardog.cce.hp.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-05-06cciss: clarify messages around reset behaviorStephen M. Cameron
When waiting for the board to become "not ready" don't print a message saying "waiting for board to become ready" (possibly followed by a message saying "failed waiting for board to become not ready". Instead, it should be "waiting for board to reset" and "failed waiting for board to reset." Signed-off-by: Stephen M. Cameron <scameron@beardog.cce.hp.com> " Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-05-06cciss: get rid of message related magic numbersStephen M. Cameron
2011-05-06cciss: fix reply pool and block fetch table memory leaksStephen M. Cameron
2011-05-06cciss: factor out irq request codeStephen M. Cameron
2011-05-06cciss: factor out scatterlist allocation functionsStephen M. Cameron
2011-05-06cciss: factor out command pool allocation functionsStephen M. Cameron
2011-05-06cciss: do a better job of detecting controller reset failureStephen M. Cameron
Detect failure of controller reset by noticing if the 32 bytes of "driver version" we store on the hardware in the config table fail to get zeroed out. Previously we noticed if the controller did not transition to "simple mode", but this did not detect reset failure if the controller was already in simple mode prior to the reset attempt (e.g. due to module parameter hpsa_simple_mode=1). Signed-off-by: Stephen M. Cameron <scameron@beardog.cce.hp.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-03-12cciss: fix missed command status value CMD_UNABORTABLEStephen M. Cameron
and fix a nearby typo, "do" that should have been "due" Signed-off-by: Stephen M. Cameron <scameron@beardog.cce.hp.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-03-12cciss: remove unnecessary castsStephen M. Cameron
2011-03-12cciss: Mask off error bits of c->busaddr in cmd_special_free when calling ↵Stephen M. Cameron
pci_free_consistent Signed-off-by: Stephen M. Cameron <scameron@beardog.cce.hp.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-03-12cciss: Inform controller we are using 32-bit tags.Stephen M. Cameron
Controller will DMA only 32-bits of the tag per command on completion if it knows we are only using 32-bit tags. Signed-off-by: Stephen M. Cameron <scameron@beardog.cce.hp.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-03-12cciss: hoist tag masking out of loopStephen M. Cameron
In process_nonindexed_cmd, hoist figuring of masked tag out of loop since it is the same throughout. Signed-off-by: Stephen M. Cameron <scameron@beardog.cce.hp.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-03-11cciss: export resettable host attributeStephen M. Cameron
This attribute, requested by Redhat, allows kexec-tools to know whether the controller can honor the reset_devices kernel parameter and actually reset the controller. For kdump to work properly it is necessary that the reset_devices parameter be honored. This attribute enables kexec-tools to warn the user if they attempt to designate a non-resettable controller as the dump device. Signed-off-by: Stephen M. Cameron <scameron@beardog.cce.hp.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
