path: root/drivers/block/ps3vram.c
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-01block: fix for "Consolidate phys_segment and hw_segment limits"Stephen Rothwell
Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2010-02-26block: Consolidate phys_segment and hw_segment limitsMartin K. Petersen
Except for SCSI no device drivers distinguish between physical and hardware segment limits. Consolidate the two into a single segment limit. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2010-02-26block: Rename blk_queue_max_sectors to blk_queue_max_hw_sectorsMartin K. Petersen
The block layer calling convention is blk_queue_<limit name>. blk_queue_max_sectors predates this practice, leading to some confusion. Rename the function to appropriately reflect that its intended use is to set max_hw_sectors. Also introduce a temporary wrapper for backwards compability. This can be removed after the merge window is closed. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2010-02-26block: Add BLK_ prefix to definitionsMartin K. Petersen
Add a BLK_ prefix to block layer constants. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-11-04block/ps3: fix slow VRAM IOHideyuki Sasaki
The current PS3 VRAM driver uses msleep() to wait for completion of RSX DMA transfers between system memory and VRAM. Depending on the system timing, the processing delay and overhead of this msleep() call can significantly impact VRAM driver IO. To avoid the condition, add a short duration (200 usec max) udelay() polling loop before entering the msleep() polling loop. Signed-off-by: Hideyuki Sasaki <xhide@rd.scei.sony.co.jp> Signed-off-by: Geoff Levand <geoffrey.levand@am.sony.com> Acked-by: Jim Paris <jim@jtan.com> Cc: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-09-22const: make block_device_operations constAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-08-20powerpc/cell: Move CBE_IOPTE_* to <asm/cell-regs.h>Geert Uytterhoeven
As <asm/iommu.h> doesn't contain any other hardware specific definitions but only interfaces. Reported-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-06-15ps3: shorten ps3_system_bus_[gs]et_driver_data to ps3_system_bus_[gs]et_drvdataGeert Uytterhoeven
Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Cc: Geoff Levand <geoffrey.levand@am.sony.com> Cc: Jim Paris <jim@jtan.com> Acked-by: Geoff Levand <geoffrey.levand@am.sony.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-06-15block/ps3: remove driver_data direct access of struct deviceRoel Kluin
In the near future, the driver core is going to not allow direct access to the driver_data pointer in struct device. Instead, the functions dev_get_drvdata() and dev_set_drvdata() should be used. These functions have been around since the beginning, so are backwards compatible with all older kernel versions. [Geert: Use ps3_system_bus_[gs]et_driver_data() for ps3_system_bus_device] Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Cc: Jim Paris <jim@jtan.com> Cc: Jens Axboe <axboe@kernel.dk> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-06-15ps3vram: Make ps3vram_priv.reports a void *Geert Uytterhoeven
So we can kill a cast. Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Cc: Jim Paris <jim@jtan.com> Cc: Jens Axboe <axboe@kernel.dk> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-06-15ps3vram: Remove no longer used ps3vram_priv.ddr_baseGeert Uytterhoeven
2009-06-15ps3vram: Replace mutex by spinlock + bio_listGeert Uytterhoeven
Remove the mutex serializing access to the cache. Instead, queue up new requests on a bio_list if the driver is busy. This improves sequential write performance by ca. 2%. Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Cc: Jim Paris <jim@jtan.com> Cc: Jens Axboe <axboe@kernel.dk> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-06-15ps3fb/vram: Extract common GPU stuff into <asm/ps3gpu.h>Geert Uytterhoeven
Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Cc: linux-fbdev-devel@lists.sourceforge.net Cc: Jim Paris <jim@jtan.com> Cc: Jens Axboe <axboe@kernel.dk> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-06-15ps3vram: GPU memory mapping cleanupGeert Uytterhoeven
- Make the IOMMU flags used for mapping main memory into the GPU's I/O space explicit, instead of relying on the default in the hypervisor, - Add missing calls to lv1_gpu_context_iomap(..., CBE_IOPTE_M) to unmap the memory during cleanup. Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Cc: Jim Paris <jim@jtan.com> Cc: Jens Axboe <axboe@kernel.dk> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-06-15ps3vram: Correct exchanged gotos in ps3vram_probe() error pathJim Paris
2009-06-15ps3vram: Use proc_create_data() instead of proc_create()Geert Uytterhoeven
Use proc_create_data() to avoid race conditions. Reported-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Cc: Jim Paris <jim@jtan.com> Cc: Jens Axboe <axboe@kernel.dk> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-06-15ps3vram: Fix error path (return -EIO) for short read/writeGeert Uytterhoeven
2009-03-31proc 2/2: remove struct proc_dir_entry::ownerAlexey Dobriyan
Setting ->owner as done currently (pde->owner = THIS_MODULE) is racy as correctly noted at bug #12454. Someone can lookup entry with NULL ->owner, thus not pinning enything, and release it later resulting in module refcount underflow. We can keep ->owner and supply it at registration time like ->proc_fops and ->data. But this leaves ->owner as easy-manipulative field (just one C assignment) and somebody will forget to unpin previous/pin current module when switching ->owner. ->proc_fops is declared as "const" which should give some thoughts. ->read_proc/->write_proc were just fixed to not require ->owner for protection. rmmod'ed directories will be empty and return "." and ".." -- no harm. And directories with tricky enough readdir and lookup shouldn't be modular. We definitely don't want such modular code. Removing ->owner will also make PDE smaller. So, let's nuke it. Kudos to Jeff Layton for reminding about this, let's say, oversight. http://bugzilla.kernel.org/show_bug.cgi?id=12454 Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com>
2009-03-13ps3/block: Replace mtd/ps3vram by block/ps3vramGeert Uytterhoeven
Convert the PS3 Video RAM Storage Driver from an MTD driver to a plain block device driver. The ps3vram driver exposes unused video RAM on the PS3 as a block device suitable for storage or swap. Fast data transfer is achieved using a local cache in system RAM and DMA transfers via the GPU. The new driver is ca. 50% faster for reading, and ca. 10% for writing. Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Acked-by: Geoff Levand <geoffrey.levand@am.sony.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
