path: root/drivers/block/rbd.c
2013-01-17rbd: do not allow remove of mounted-on imageAlex Elder
There is no check in rbd_remove() to see if anybody holds open the image being removed. That's not cool. Add a simple open count that goes up and down with opens and closes (releases) of the device, and don't allow an rbd image to be removed if the count is non-zero. Protect the updates of the open count value with ctl_mutex to ensure the underlying rbd device doesn't get removed while concurrently being opened. Signed-off-by: Alex Elder <elder@inktank.com> Reviewed-by: Sage Weil <sage@inktank.com> (based on commit 42382b709bd1d143b9f0fa93e0a3a1f2f4210707)
2013-01-17rbd: fix bug in rbd_dev_id_put()Alex Elder
In rbd_dev_id_put(), there's a loop that's intended to determine the maximum device id in use. But it isn't doing that at all, the effect of how it's written is to simply use the just-put id number, which ignores whole purpose of this function. Fix the bug. Signed-off-by: Alex Elder <elder@inktank.com> Reviewed-by: Josh Durgin <josh.durgin@inktank.com> (cherry picked from commit b213e0b1a62637b2a9395a34349b13d73ca2b90a) Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-17rbd: BUG on invalid layoutSage Weil
This shouldn't actually be possible because the layout struct is constructed from the RBD header and validated then. [elder@inktank.com: converted BUG() call to equivalent rbd_assert()] Signed-off-by: Sage Weil <sage@inktank.com> Reviewed-by: Alex Elder <elder@inktank.com> (based on commit 6cae3717cddaf8e5e96e304733dca66e40d56f89)
2013-01-17rbd: kill notify_timeout optionAlex Elder
The "notify_timeout" rbd device option is never used, so get rid of it. Signed-off-by: Alex Elder <elder@inktank.com> Reviewed-by: Yehuda Sadeh <yehuda@inktank.com> (cherry picked from commit 84d34dcc116e117a41c6fc8be13430529fc2d9e7) Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-17rbd: add read_only rbd map optionAlex Elder
Add the ability to map an rbd image read-only, by specifying either "read_only" or "ro" as an option on the rbd "command line." Also allow the inverse to be explicitly specified using "read_write" or "rw". Signed-off-by: Alex Elder <elder@inktank.com> Reviewed-by: Yehuda Sadeh <yehuda@inktank.com> (based on commit cc0538b62c839c2df7b9f8378bb37e3b35faa608)
2013-01-17rbd: kill create_snap sysfs entryAlex Elder
Josh proposed the following change, and I don't think I could explain it any better than he did: From: Josh Durgin <josh.durgin@inktank.com> Date: Tue, 24 Jul 2012 14:22:11 -0700 To: ceph-devel <ceph-devel@vger.kernel.org> Message-ID: <500F1203.9050605@inktank.com> From: Josh Durgin <josh.durgin@inktank.com> Right now the kernel still has one piece of rbd management duplicated from the rbd command line tool: snapshot creation. There's nothing special about snapshot creation that makes it advantageous to do from the kernel, so I'd like to remove the create_snap sysfs interface. That is, /sys/bus/rbd/devices/<id>/create_snap would be removed. Does anyone rely on the sysfs interface for creating rbd snapshots? If so, how hard would it be to replace with: rbd snap create pool/image@snap Is there any benefit to the sysfs interface that I'm missing? Josh This patch implements this proposal, removing the code that implements the "snap_create" sysfs interface for rbd images. As a result, quite a lot of other supporting code goes away. [elder@inktank.com: commented out rbd_req_sync_exec() to avoid warning] Suggested-by: Josh Durgin <josh.durgin@inktank.com> Signed-off-by: Alex Elder <elder@inktank.com> Reviewed-by: Josh Durgin <josh.durgin@inktank.com> (based on commit 02cdb02ceab1f3dd9ac2bc899fc51f0e0e744782)
2013-01-17rbd: drop dev reference on error in rbd_open()Alex Elder
If a read-only rbd device is opened for writing in rbd_open(), it returns without dropping the just-acquired device reference. Fix this by moving the read-only check before getting the reference. Signed-off-by: Alex Elder <elder@inktank.com> Reviewed-by: Yehuda Sadeh <yehuda@inktank.com> Reviewed-by: Josh Durgin <josh.durgin@inktank.com> (cherry picked from commit 340c7a2b2c9a2da640af28a8c196356484ac8b50) Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-17rbd: send header version when notifyingJosh Durgin
Previously the original header version was sent. Now, we update it when the header changes. Signed-off-by: Josh Durgin <josh.durgin@dreamhost.com> Reviewed-by: Alex Elder <elder@inktank.com> (cherry picked from commit a71b891bc7d77a070e723c8c53d1dd73cf931555) Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-17rbd: use reference counting for the snap contextJosh Durgin
This prevents a race between requests with a given snap context and header updates that free it. The osd client was already expecting the snap context to be reference counted, since it get()s it in ceph_osdc_build_request and put()s it when the request completes. Also remove the second down_read()/up_read() on header_rwsem in rbd_do_request, which wasn't actually preventing this race or protecting any other data. Signed-off-by: Josh Durgin <josh.durgin@dreamhost.com> Reviewed-by: Alex Elder <elder@inktank.com> (cherry picked from commit d1d25646543134d756a02ffe4e02073faa761f2c) Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-17rbd: set image size when header is updatedJosh Durgin
The image may have been resized. Signed-off-by: Josh Durgin <josh.durgin@dreamhost.com> Reviewed-by: Alex Elder <elder@inktank.com> (cherry picked from commit 93a24e084d67ba2fcb9a4c289135825b623ec864) Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-17rbd: expose the correct size of the device in sysfsJosh Durgin
If an image was mapped to a snapshot, the size of the head version would be shown. Protect capacity with header_rwsem, since it may change. Signed-off-by: Josh Durgin <josh.durgin@dreamhost.com> Reviewed-by: Alex Elder <elder@inktank.com> (cherry picked from commit a51aa0c042fa39946dd017d5f91a073300a71577) Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-17rbd: only reset capacity when pointing to headJosh Durgin
Snapshots cannot be resized, and the new capacity of head should not be reflected by the snapshot. Signed-off-by: Josh Durgin <josh.durgin@inktank.com> Reviewed-by: Alex Elder <elder@inktank.com> (cherry picked from commit 474ef7ce832d471148f63a9d07f67fc5564834f1) Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-17rbd: return errors for mapped but deleted snapshotJosh Durgin
When a snapshot is deleted, the OSD will return ENOENT when reading from it. This is normally interpreted as a hole by rbd, which will return zeroes. To minimize the time in which this can happen, stop requests early when we are notified that our snapshot no longer exists. [elder@inktank.com: updated __rbd_init_snaps_header() logic] Signed-off-by: Josh Durgin <josh.durgin@inktank.com> Reviewed-by: Alex Elder <elder@inktank.com> (cherry picked from commit e88a36ec961b8c1899c59c5e4ae35a318c0209d3) Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Conflicts: drivers/block/rbd.c
2012-11-26rbd: Fix ceph_snap_context size calculationYan, Zheng
(cherry picked from commit f9f9a1904467816452fc70740165030e84c2c659) ceph_snap_context->snaps is an u64 array Signed-off-by: Zheng Yan <zheng.z.yan@intel.com> Reviewed-by: Alex Elder <elder@inktank.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-26rbd: store snapshot id instead of indexJosh Durgin
(cherry picked from commit 77dfe99fe3cb0b2b0545e19e2d57b7a9134ee3c0) When a device was open at a snapshot, and snapshots were deleted or added, data from the wrong snapshot could be read. Instead of assuming the snap context is constant, store the actual snap id when the device is initialized, and rely on the OSDs to signal an error if we try reading from a snapshot that was deleted. Signed-off-by: Josh Durgin <josh.durgin@dreamhost.com> Reviewed-by: Alex Elder <elder@dreamhost.com> Reviewed-by: Yehuda Sadeh <yehuda@hq.newdream.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-26rbd: protect read of snapshot sequence numberJosh Durgin
(cherry picked from commit 403f24d3d51760a8b9368d595fa5f48c309f1a0f) This is updated whenever a snapshot is added or deleted, and the snapc pointer is changed with every refresh of the header. Signed-off-by: Josh Durgin <josh.durgin@dreamhost.com> Reviewed-by: Alex Elder <elder@dreamhost.com> Reviewed-by: Yehuda Sadeh <yehuda@hq.newdream.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-26rbd: don't hold spinlock during messenger flushAlex Elder
(cherry picked from commit cd9d9f5df6098c50726200d4185e9e8da32785b3) A recent change made changes to the rbd_client_list be protected by a spinlock. Unfortunately in rbd_put_client(), the lock is taken before possibly dropping the last reference to an rbd_client, and on the last reference that eventually calls flush_workqueue() which can sleep. The problem was flagged by a debug spinlock warning: BUG: spinlock wrong CPU on CPU#3, rbd/27814 The solution is to move the spinlock acquisition and release inside rbd_client_release(), which is the spot where it's really needed for protecting the removal of the rbd_client from the client list. Signed-off-by: Alex Elder <elder@dreamhost.com> Reviewed-by: Sage Weil <sage@newdream.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-22rbd: move snap_rwsem to the device, rename to header_rwsemJosh Durgin
A new temporary header is allocated each time the header changes, but only the changed properties are copied over. We don't need a new semaphore for each header update. This addresses http://tracker.newdream.net/issues/2174 Signed-off-by: Josh Durgin <josh.durgin@dreamhost.com> Reviewed-by: Alex Elder <elder@dreamhost.com>
2012-03-22rbd: don't drop the rbd_id too earlyAlex Elder
Currently an rbd device's id is released when it is removed, but it is done before the code is run to clean up sysfs-related files (such as /sys/bus/rbd/devices/1). It's possible that an rbd is still in use after the rbd_remove() call has been made. It's essentially the same as an active inode that stays around after it has been removed--until its final close operation. This means that the id shows up as free for reuse at a time it should not be. The effect of this was seen by Jens Rehpoehler, who: - had a filesystem mounted on an rbd device - unmapped that filesystem (without unmounting) - found that the mount still worked properly - but hit a panic when he attempted to re-map a new rbd device This re-map attempt found the previously-unmapped id available. The subsequent attempt to reuse it was met with a panic while attempting to (re-)install the sysfs entry for the new mapped device. Fix this by holding off "putting" the rbd id, until the rbd_device release function is called--when the last reference is finally dropped. Note: This fixes: http://tracker.newdream.net/issues/1907 Signed-off-by: Alex Elder <elder@dreamhost.com> Signed-off-by: Sage Weil <sage@newdream.net>
2012-03-22rbd: small changesAlex Elder
Here is another set of small code tidy-ups: - Define SECTOR_SHIFT and SECTOR_SIZE, and use these symbolic names throughout. Tell the blk_queue system our physical block size, in the (unlikely) event we want to use something other than the default. - Delete the definition of struct rbd_info, which is never used. - Move the definition of dev_to_rbd() down in its source file, just above where it gets first used, and change its name to dev_to_rbd_dev(). - Replace an open-coded operation in rbd_dev_release() to use dev_to_rbd_dev() instead. - Calculate the segment size for a given rbd_device just once in rbd_init_disk(). - Use the '%zd' conversion specifier in rbd_snap_size_show(), since the value formatted is a size_t. - Switch to the '%llu' conversion specifier in rbd_snap_id_show(). since the value formatted is unsigned. Signed-off-by: Alex Elder <elder@dreamhost.com>
2012-03-22rbd: do some refactoringAlex Elder
A few blocks of code are rearranged a bit here: - In rbd_header_from_disk(): - Don't bother computing snap_count until we're sure the on-disk header starts with a good signature. - Move a few independent lines of code so they are *after* a check for a failed memory allocation. - Get rid of unnecessary local variable "ret". - Make a few other changes in rbd_read_header(), similar to the above--just moving things around a bit while preserving the functionality. - In rbd_rq_fn(), just assign rq in the while loop's controlling expression rather than duplicating it before and at the end of the loop body. This allows the use of "continue" rather than "goto next" in a number of spots. - Rearrange the logic in snap_by_name(). End result is the same. Signed-off-by: Alex Elder <elder@dreamhost.com>
2012-03-22rbd: fix module sysfs setup/teardown codeAlex Elder
Once rbd_bus_type is registered, it allows an "add" operation via the /sys/bus/rbd/add bus attribute, and adding a new rbd device that way establishes a connection between the device and rbd_root_dev. But rbd_root_dev is not registered until after the rbd_bus_type registration is complete. This could (in principle anyway) result in an invalid state. Since rbd_root_dev has no tie to rbd_bus_type we can reorder these two initializations and never be faced with this scenario. In addition, unregister the device in the event the bus registration fails at module init time. Signed-off-by: Alex Elder <elder@dreamhost.com> Signed-off-by: Sage Weil <sage@newdream.net>
2012-03-22rbd: don't allocate mon_addrs buffer in rbd_add()Alex Elder
The mon_addrs buffer in rbd_add is used to hold a copy of the monitor IP addresses supplied via /sys/bus/rbd/add. That is passed to rbd_get_client(), which never modifies it (nor do any of the functions it gets passed to thereafter)--the mon_addr parameter to rbd_get_client() is a pointer to constant data, so it can't be modifed. Furthermore, rbd_get_client() has the length of the mon_addrs buffer and that is used to ensure nothing goes beyond its end. Based on all this, there is no reason that a buffer needs to be used to hold a copy of the mon_addrs provided via /sys/bus/rbd/add. Instead, the location within that passed-in buffer can be provided, along with the length of the "token" therein which represents the monitor IP's. A small change to rbd_add_parse_args() allows the address within the buffer to be passed back, and the length is already returned. This now means that, at least from the perspective of this interface, there is no such thing as a list of monitor addresses that is too long. Signed-off-by: Alex Elder <elder@dreamhost.com>
2012-03-22rbd: have rbd_parse_args() report found mon_addrs sizeAlex Elder
The argument parsing routine already computes the size of the mon_addrs buffer it extracts from the "command." Pass it to the caller so it can use it to provide the length to rbd_get_client(). Signed-off-by: Alex Elder <elder@dreamhost.com>
2012-03-22rbd: do a few checks at build timeAlex Elder
This is a bit gratuitous, but there are a few things that can be verified at build time rather than run time, so do that. Signed-off-by: Alex Elder <elder@dreamhost.com>
2012-03-22rbd: don't use sscanf() in rbd_add_parse_args()Alex Elder
Make use of a few simple helper routines to parse the arguments rather than sscanf(). This will treat both missing and too-long arguments as invalid input (rather than silently truncating the input in the too-long case). In time this can also be used by rbd_add() to use the passed-in buffer in place, rather than copying its contents into new buffers. It appears to me that the sscanf() previously used would not correctly handle a supplied snapshot--the two final "%s" conversion specifications were not separated by a space, and I'm not sure how sscanf() handles that situation. It may not be well-defined. So that may be a bug this change fixes (but I didn't verify that). The sizes of the mon_addrs and options buffers are now passed to rbd_add_parse_args(), so they can be supplied to copy_token(). Signed-off-by: Alex Elder <elder@dreamhost.com>
2012-03-22rbd: encapsulate argument parsing for rbd_add()Alex Elder
Move the code that parses the arguments provided to rbd_add() (which are supplied via /sys/bus/rbd/add) into a separate function. Also rename the "mon_dev_name" variable in rbd_add() to be "mon_addrs". The variable represents a list of one or more comma-separated monitor IP addresses, each with an optional port number. I think "mon_addrs" captures that notion a little better. Signed-off-by: Alex Elder <elder@dreamhost.com>
2012-03-22rbd: simplify error handling in rbd_add()Alex Elder
If a couple pointers are initialized to NULL then a single "out_nomem" label can be used for all of the memory allocation failure cases in rbd_add(). Also, get rid of the "irc" local variable there. There is no real need for "rc" to be type ssize_t, and it can be used in the spot "irc" was. Signed-off-by: Alex Elder <elder@dreamhost.com> Signed-off-by: Sage Weil <sage@newdream.net>
2012-03-22rbd: reduce memory used for rbd_dev fieldsAlex Elder
The length of the string containing the monitor address specification(s) will never exceed the length of the string passed in to rbd_add(). The same holds true for the ceph + rbd options string. So reduce the amount of memory allocated for these to that length rather than the maximum (1024 bytes). Signed-off-by: Alex Elder <elder@dreamhost.com> Signed-off-by: Sage Weil <sage@newdream.net>
2012-03-22rbd: have rbd_get_client() return a rbd_clientAlex Elder
Since rbd_get_client() currently returns an error code. It assigns the rbd_client field of the rbd_device structure it is passed if successful. Instead, have it return the created rbd_client structure and return a pointer-coded error if there is an error. This makes the assignment of the client pointer more obvious at the call site. Signed-off-by: Alex Elder <elder@dreamhost.com> Signed-off-by: Sage Weil <sage@newdream.net>
2012-03-22rbd: a few simple changesAlex Elder
Here are a few very simple cleanups: - Add a "RBD_" prefix to the two driver name string definitions. - Move the definition of struct rbd_request below struct rbd_req_coll to avoid the need for an empty declaration of the latter. - Move and group the definitions of rbd_root_dev_release() and rbd_root_dev, as well as rbd_bus_type and rbd_bus_attrs[], close to the top of the file. Arrange the latter so rbd_bus_type.bus_attrs can be initialized statically. - Get rid of an unnecessary local variable in rbd_open(). - Rework some hokey logic in rbd_bus_add_dev(), so the value of "ret" at the end is either 0 or -ENOENT to avoid the need for the code duplication that was there. - Rename a goto target in rbd_add(). Signed-off-by: Alex Elder <elder@dreamhost.com> Signed-off-by: Sage Weil <sage@newdream.net>
2012-03-22rbd: rename "node_lock"Alex Elder
The spinlock used to protect rbd_client_list is named "node_lock". Rename it to "rbd_client_list_lock" to make it more obvious what it's for. Signed-off-by: Alex Elder <elder@dreamhost.com> Signed-off-by: Sage Weil <sage@newdream.net>
2012-03-22rbd: move ctl_mutex lock inside rbd_client_create()Alex Elder
Since rbd_client_create() is only called in one place, move the acquisition of the mutex around that call inside that function. Signed-off-by: Alex Elder <elder@dreamhost.com> Signed-off-by: Sage Weil <sage@newdream.net>
2012-03-22rbd: move ctl_mutex lock inside rbd_get_client()Alex Elder
Since rbd_get_client() is only called in one place, move the acquisition of the mutex around that call inside that function. Furthermore, within rbd_get_client(), it appears the mutex only needs to be held while calling rbd_client_create(). (Moving the lock inside that function will wait for the next patch.) Signed-off-by: Alex Elder <elder@dreamhost.com> Signed-off-by: Sage Weil <sage@newdream.net>
2012-03-22rbd: release client list lock soonerAlex Elder
In rbd_get_client(), if a client is reused, a number of things get done while still holding the list lock unnecessarily. This just moves a few things that need no lock protection outside the lock. Signed-off-by: Alex Elder <elder@dreamhost.com> Signed-off-by: Sage Weil <sage@newdream.net>
2012-03-22rbd: restore previous rbd id sequence behaviorAlex Elder
It used to be that selecting a new unique identifier for an added rbd device required searching all existing ones to find the highest id is used. A recent change made that unnecessary, but made it so that id's used were monotonically non-decreasing. It's a bit more pleasant to have smaller rbd id's though, and this change makes ids get allocated as they were before--each new id is one more than the maximum currently in use. Signed-off-by: Alex Elder <elder@dreamhost.com> Signed-off-by: Sage Weil <sage@newdream.net>
2012-03-22rbd: tie rbd_dev_list changes to rbd_id operationsAlex Elder
The only time entries are added to or removed from the global rbd_dev_list is exactly when a "put" or "get" operation is being performed on a rbd_dev's id. So just move the list management code into get/put routines. Signed-off-by: Alex Elder <elder@dreamhost.com> Signed-off-by: Sage Weil <sage@newdream.net>
2012-03-22rbd: protect the rbd_dev_list with a spinlockAlex Elder
The rbd_dev_list is just a simple list of all the current rbd_devices. Using the ctl_mutex as a concurrency guard is overkill. Instead, use a spinlock for that specific purpose. This also reduces the window that the ctl_mutex needs to be held in rbd_add(). Signed-off-by: Alex Elder <elder@dreamhost.com> Signed-off-by: Sage Weil <sage@newdream.net>
2012-03-22rbd: rework calculation of new rbd id'sAlex Elder
In order to select a new unique identifier for an added rbd device, the list of all existing ones is searched and a value one greater than the highest id is used. The list search can be avoided by using an atomic variable that keeps track of the current highest id. Using a get/put model for id's we can limit the boundless growth of id numbers a bit by arranging to reuse the current highest id once it gets released. Add these calls to "put" the id when an rbd is getting removed. Note that this changes the pattern of device id's used--new values will never be below the highest one seen so far (even if there exists an unused lower one). I assert this is OK because the key property of an rbd id is its uniqueness, not its magnitude. Regardless, a follow-on patch will restore the old way of doing things, I just think this commit just makes the incremental change to atomics a little easier to understand. Signed-off-by: Alex Elder <elder@dreamhost.com> Signed-off-by: Sage Weil <sage@newdream.net>
2012-03-22rbd: encapsulate new rbd id selectionAlex Elder
Move the loop that finds a new unique rbd id to use into its own helper function. Signed-off-by: Alex Elder <elder@dreamhost.com> Signed-off-by: Sage Weil <sage@newdream.net>
2012-03-22rbd: use a single value of snap_name to mean no snapJosh Durgin
There's already a constant for this anyway. Since rbd_header_set_snap() is only used to set the rbd device snap_name field, just do that within that function rather than having it take the snap_name as an argument. Signed-off-by: Alex Elder <elder@dreamhost.com> Signed-off-by: Sage Weil <sage@newdream.net> v2: Changed interface rbd_header_set_snap() so it explicitly updates the snap_name in the rbd_device. Also added a BUILD_BUG_ON() to verify the size of the snap_name field is sufficient for SNAP_HEAD_NAME.
2012-03-22rbd: do not duplicate ceph_client pointer in rbd_deviceAlex Elder
The rbd_device structure maintains a duplicate copy of the ceph_client pointer maintained in its rbd_client structure. There appears to be no good reason for this, and its presence presents a risk of them getting out of synch or otherwise misused. So kill it off, and use the rbd_client copy only. Signed-off-by: Alex Elder <elder@dreamhost.com> Signed-off-by: Sage Weil <sage@newdream.net>
2012-03-22rbd: make ceph_parse_options() return a pointerAlex Elder
ceph_parse_options() takes the address of a pointer as an argument and uses it to return the address of an allocated structure if successful. With this interface is not evident at call sites that the pointer is always initialized. Change the interface to return the address instead (or a pointer-coded error code) to make the validity of the returned pointer obvious. Signed-off-by: Alex Elder <elder@dreamhost.com> Signed-off-by: Sage Weil <sage@newdream.net>
2012-03-22rbd: a few small cleanupsAlex Elder
Some minor cleanups in "drivers/block/rbd.c: - Use the more meaningful "RBD_MAX_OBJ_NAME_LEN" in place if "96" in the definition of RBD_MAX_MD_NAME_LEN. - Use DEFINE_SPINLOCK() to define and initialize node_lock. - Drop a needless (char *) cast in parse_rbd_opts_token(). - Make a few minor formatting changes. Signed-off-by: Alex Elder <elder@dreamhost.com> Signed-off-by: Sage Weil <sage@newdream.net>
2012-02-02Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client: rbd: fix safety of rbd_put_client() rbd: fix a memory leak in rbd_get_client() ceph: create a new session lock to avoid lock inversion ceph: fix length validation in parse_reply_info() ceph: initialize client debugfs outside of monc->mutex ceph: change "ceph.layout" xattr to be "ceph.file.layout"
2012-02-02rbd: fix safety of rbd_put_client()Alex Elder
The rbd_client structure uses a kref to arrange for cleaning up and freeing an instance when its last reference is dropped. The cleanup routine is rbd_client_release(), and one of the things it does is delete the rbd_client from rbd_client_list. It acquires node_lock to do so, but the way it is done is still not safe. The problem is that when attempting to reuse an existing rbd_client, the structure found might already be in the process of getting destroyed and cleaned up. Here's the scenario, with "CLIENT" representing an existing rbd_client that's involved in the race: Thread on CPU A | Thread on CPU B --------------- | --------------- rbd_put_client(CLIENT) | rbd_get_client() kref_put() | (acquires node_lock) kref->refcount becomes 0 | __rbd_client_find() returns CLIENT calls rbd_client_release() | kref_get(&CLIENT->kref); | (releases node_lock) (acquires node_lock) | deletes CLIENT from list | ...and starts using CLIENT... (releases node_lock) | and frees CLIENT | <-- but CLIENT gets freed here Fix this by having rbd_put_client() acquire node_lock. The result could still be improved, but at least it avoids this problem. Signed-off-by: Alex Elder <elder@dreamhost.com> Signed-off-by: Sage Weil <sage@newdream.net>
2012-02-02rbd: fix a memory leak in rbd_get_client()Alex Elder
If an existing rbd client is found to be suitable for use in rbd_get_client(), the rbd_options structure is not being freed as it should. Fix that. Signed-off-by: Alex Elder <elder@dreamhost.com> Signed-off-by: Sage Weil <sage@newdream.net>
2012-01-12rbd: initialize snap_rwsem in rbd_add()Alex Elder
New rbd device structures get initialized in rbd_add(). Many of the fields rely on being initially zero-filled. However we lockdep was noticing that the rw_semaphore embedded in the header field was not getting properly initialized. Fix that. Signed-off-by: Alex Elder <elder@dreamhost.com> Signed-off-by: Sage Weil <sage@newdream.net>
2011-12-07rbd: remove buggy rollback functionalityJosh Durgin
This doesn't interact with resizing well, since it doesn't set the size of the device to the size at the snapshot. It's also an expensive operation to be synchronous. Rollback can still be done with the userspace rbd tool. Signed-off-by: Josh Durgin <josh.durgin@dreamhost.com>
2011-12-07rbd: return an error when an invalid header is readJosh Durgin
This protects against opening future rbd images that have incompatible format changes. Signed-off-by: Josh Durgin <josh.durgin@dreamhost.com>
