Fixes http://bugzilla.kernel.org/show_bug.cgi?id=7810 - a silly
copy-paste bug introduced by the latest change.
Signed-off-by: Gerhard Dirschl <gd@spherenet.de>
Cc: Peter Osterlund <petero2@telia.com>
/dev/sr0"
Fix http://bugzilla.kernel.org/show_bug.cgi?id=7667
This is because the packet driver tries to send down read/write BLOCK_PC
commands that don't use a bio and do not use sg lists.
The right fix is to replace all the packet_command stuff in the packet
driver by scsi_execute() which needs to be lifted from scsi code to
the block code for that.
Fix the bug for now. It's not the full way to a generic execute block pc
infrastcuture but fixes the bug for the time being.
Acked-by: Peter Osterlund <petero2@telia.com>
RAID_UNKNOWN is used even when PROC_FS=n, so move it outside of the
CONFIG_PROC_FS block.
drivers/block/cciss.c:1910: error: 'RAID_UNKNOWN' undeclared (first use in this function)
Cc: <mike.miller@hp.com>
Cc: Jens Axboe <jens.axboe@oracle.com>
Fix a bug that only appears when AoE goes over a network card that does not
support scatter-gather. The headers in the linear part of the skb appeared
to be larger than they really were, resulting in data that was offset by 24
bytes.
This patch eliminates the offset data on cards that don't support
scatter-gather or have had scatter-gather turned off. There remains an
unrelated issue that I'll address in a separate email.
Fixes bugzilla #7662
Signed-off-by: "Ed L. Cashin" <ecashin@coraid.com>
Cc: <stable@kernel.org>
Cc: Greg KH <greg@kroah.com>
Cc: <boddingt@optusnet.com.au>
* 'for-linus' of git://brick.kernel.dk/data/git/linux-2.6-block:
[PATCH] block: document io scheduler allow_merge_fn hook
[PATCH] cfq-iosched: don't allow sync merges across queues
[PATCH] Fixup blk_rq_unmap_user() API
[PATCH] __blk_rq_unmap_user() fails to return error
[PATCH] __blk_rq_map_user() doesn't need to grab the queue_lock
[PATCH] Remove queue merging hooks
[PATCH] ->nr_sectors and ->hard_nr_sectors are not used for BLOCK_PC requests
[PATCH] cciss: fix XFER_READ/XFER_WRITE in do_cciss_request
[PATCH] cciss: set default raid level when reading geometry fails
Don't initialise viodasd except on legacy iSeries.
This patch fixes a stupid bug. Sometime during the 2tb enhancement I ended up
replacing the macros XFER_READ and XFER_WRITE with h->cciss_read and
h->cciss_write respectively. It seemed to work somehow at least on x86_64 and
ia64. I don't know how. But people started complaining about command timeouts
on older controllers like the 64xx series and only on ia32. This resolves the
issue reproduced in our lab. Please consider this for inclusion.
Thanks,
mikem
Signed-off-by: Mike Miller <mike.miller@hp.com>
This patch sets a default raid level on a volume that either does not support
reading the geometry or reports an invalid geometry for whatever reason. We
were always setting some values for heads and sectors but never set a raid
level. This caused lots of problems on some buggy firmware. Please consider
this for inclusion.
Thanks,
mikem
[PATCH] Fixup cciss error handling
[PATCH] Allow as-iosched to be unloaded
[PATCH 2/2] cciss: remove calls to pci_disable_device
[PATCH 1/2] cciss: map out more memory for config table
[PATCH] Propagate down request sync flag
Resolve trivial whitespace conflict in drivers/block/cciss.c manually.
Run this:
#!/bin/sh
for f in $(grep -Erl "\([^\)]*\) *k[cmz]alloc" *) ; do
echo "De-casting $f..."
perl -pi -e "s/ ?= ?\([^\)]*\) *(k[cmz]alloc) *\(/ = \1\(/" $f
done
And then go through and reinstate those cases where code is casting pointers
to non-pointers.
And then drop a few hunks which conflicted with outstanding work.
Cc: Russell King <rmk@arm.linux.org.uk>, Ian Molton <spyro@f2s.com>
Cc: Mikael Starvik <starvik@axis.com>
Cc: Yoshinori Sato <ysato@users.sourceforge.jp>
Cc: Roman Zippel <zippel@linux-m68k.org>
Cc: Kyle McMartin <kyle@mcmartin.ca>
Cc: Jeff Dike <jdike@addtoit.com>
Cc: Paul Fulghum <paulkf@microgate.com>
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
Cc: Karsten Keil <kkeil@suse.de>
Cc: Mauro Carvalho Chehab <mchehab@infradead.org>
Cc: Jeff Garzik <jeff@garzik.org>
Cc: James Bottomley <James.Bottomley@steeleye.com>
Cc: Ian Kent <raven@themaw.net>
Cc: Steven French <sfrench@us.ibm.com>
Cc: Neil Brown <neilb@cse.unsw.edu.au>
Cc: Jaroslav Kysela <perex@suse.cz>
Cc: Takashi Iwai <tiwai@suse.de>
The BLK_DEV_SWIM_IOP driver has:
- already been marked as BROKEN in 2.6.0 three years ago and
- is still marked as BROKEN.
Drivers that had been marked as BROKEN for such a long time seem to be
unlikely to be revived in the forseeable future.
But if anyone wants to ever revive this driver, the code is still
present in the older kernel releases.
Acked-by: Geert Uytterhoeven <geert@linux-m68k.org>
Remove calls to pci_disable_device except in fail_all_cmds. The
pci_disable_device function does something nasty to Smart Array controllers
that pci_enable_device does not undo. So if the driver is unloaded it
cannot be reloaded.
Also, customers can disable any pci device via the ROM Based Setup Utility
(RBSU). If the customer has disabled the controller we should not try to
blindly enable the card from the driver. Please consider this for
inclusion.
Acked-by: Alan Cox <alan@redhat.com>
Map out more memory for our config table. It's required to reach offset
0x214 to disable DMA on the P600. I'm not sure how I lost this hunk.
The previous cciss commit removed the err_out_disable_pdev label, but
there was still a user of that. Fix that up.
This patch removes calls to pci_disable_device except in fail_all_cmds. The
that pci_enable_device does not undo. So if the driver is unloaded it cannot be
reloaded.
blindly enable the card from the driver. Please consider this for inclusion.
This patch maps out more memory for our config table. It's required to reach
offset 0x214 to disable DMA on the P600. I'm not sure how I lost this hunk.
Signed-off-by: Josef Sipek <jsipek@fsl.cs.sunysb.edu>
Add a sysfs and debugfs interface to the pktcdvd driver.
Look into the Documentation/ABI/testing/* files in the patch for more info.
Signed-off-by: Thomas Maier <balagi@justmail.de>
Signed-off-by: Peter Osterlund <petero2@telia.com>
This adds a bio write queue congestion control to the pktcdvd driver with
fixed on/off marks. It prevents that the driver consumes a unlimited
amount of write requests.
[akpm@osdl.org: sync with congestion_wait() renaming]
pktcdvd: Update Kconfig help text.
This patch makes some of the procfs functions reusable (for
coming sysfs patch e.g.):
pkt_setup_dev()
pkt_remove_dev()
* master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6: (48 commits)
[NETFILTER]: Fix non-ANSI func. decl.
[TG3]: Identify Serdes devices more clearly.
[TG3]: Use msleep.
[TG3]: Use netif_msg_*.
[TG3]: Allow partial speed advertisement.
[TG3]: Add TG3_FLG2_IS_NIC flag.
[TG3]: Add 5787F device ID.
[TG3]: Fix Phy loopback.
[WANROUTER]: Kill kmalloc debugging code.
[TCP] inet_twdr_hangman: Delete unnecessary memory barrier().
[NET]: Memory barrier cleanups
[IPSEC]: Fix inetpeer leak in ipv4 xfrm dst entries.
audit: disable ipsec auditing when CONFIG_AUDITSYSCALL=n
audit: Add auditing to ipsec
[IRDA] irlan: Fix compile warning when CONFIG_PROC_FS=n
[IrDA]: Incorrect TTP header reservation
[IrDA]: PXA FIR code device model conversion
[GENETLINK]: Fix misplaced command flags.
[NETLIK]: Add a pointer to the Generic Netlink wiki page.
[IPV6] RAW: Don't release unlocked sock.
Allow nbd to expose the nbd-client daemon's PID in /sys/block/nbd<x>/pid.
This is helpful for tracking connection status of a device and for
determining which nbd devices are currently in use.
Signed-off-by: Paul Clements <paul.clements@steeleye.com>
Let's remove this pre-historic paride building script.
CONFIG_PARIDE depends on CONFIG_PARPORT_PC, so there's no reason for
these #ifdef's.
Building CCISS SCSI tape support in-kernel when SCSI=m causes build errors,
so require SCSI support to be =y or same as CCISS SCSI tape support.
drivers/built-in.o: In function `cciss_remove_one':
cciss.c:(.text+0x79d4c): undefined reference to `scsi_remove_host'
cciss.c:(.text+0x79d55): undefined reference to `scsi_host_put'
drivers/built-in.o: In function `cciss_update_non_disk_devices':
cciss.c:(.text+0x7bb54): undefined reference to `scsi_device_type'
cciss.c:(.text+0x7bcc8): undefined reference to `scsi_device_type'
cciss.c:(.text+0x7be81): undefined reference to `scsi_device_type'
cciss.c:(.text+0x7bf81): undefined reference to `scsi_device_type'
drivers/built-in.o: In function `cciss_proc_write':
cciss.c:(.text+0x7c175): undefined reference to `scsi_host_alloc'
cciss.c:(.text+0x7c1ed): undefined reference to `scsi_add_host'
cciss.c:(.text+0x7c1f9): undefined reference to `scsi_scan_host'
cciss.c:(.text+0x7c206): undefined reference to `scsi_host_put'
make: *** [.tmp_vmlinux1] Error 1
Acked-by: Mike Miller <mike.miller@hp.com>
This patch makes module init return proper value instead of -1 (-EPERM).
Cc: Tim Waugh <tim@cyberelk.net>
paride_register() returns 1 on success, 0 on failure and module init
code looks like
static int __init foo_init(void)
return paride_register(&foo) - 1;
which is not what one get used to. Converted to usual 0/-E convention.
In case of kbic driver, unwind registration. It was just
return (paride_register(&k951)||paride_register(&k971))-1;
We're about to change the semantics of pi_register()'s return value, so
rename it to something else first, so that any unconverted code reliaby
breaks.
A pretty simple cleanup for cciss_interrupt_mode.
Add the support for a large number of logical volumes. We will soon have
hardware that support up to 1024 logical volumes.
Remove the no longer used revalidate_allvol function. It was replaced by
rebuild_lun_table.
Acked-by: Jens Axboe <jens.axboe@oracle.com>
Change our open to test for drv->heads like we do in other places in the
driver. Mostly for consistency.
Change the blk_queue_max_sectors from 512 to 2048. This helps increase
performance.
[akpm@osdl.org: s/sector_size/max_sectors/]
Unconditionally disable DMA prefetch on the P600 controller. An ASIC bug may
result in prefetching beyond the end of physical memory.
Change the SSID on the E500 as a workaround for a firmware bug. It looks like
the original patch was backed out between rc2 and rc4.
Remove #define NR_CMDS and replace it w/hba[i]->nr_cmds. Most Smart Array
controllers can support up to 1024 commands but the E200 family can only
support 128. To prevent annoying "fifo full" messages we define nr_cmds on a
per controller basis by adding it the product table.
Add the support to fire up on any HP RAID class device that has a valid cciss
signature.
Change the cciss version number to 3.6.14 to reflect the following
functionality changes added by the rest of the set. They include:
- Support to fire up on any HP RAID class controller
- Increase nr_cmds to 512 for most controllers by adding it to the product table
- PCI subsystem ID fix fix was pulled
- Disable DMA prefetch for the P600 on IPF platforms
- Change from 512 to 2048 sector_size for performance
- Fix in cciss_open for consistency
- Remove the no longer used revalidate_allvol function
- Bug fix for busy configuring
- Support for more than 16 logical volumes
- Cleanups in cciss_interrupt_mode
- Fix for iostats, it's been broken for several kernel releases
Move process freezing functions from include/linux/sched.h to freezer.h, so
that modifications to the freezer or the kernel configuration don't require
recompiling just about everything.
[akpm@osdl.org: fix ueagle driver]
Signed-off-by: Nigel Cunningham <nigel@suspend2.net>
Cc: "Rafael J. Wysocki" <rjw@sisk.pl>
Cc: Pavel Machek <pavel@ucw.cz>
Replace all uses of kmem_cache_t with struct kmem_cache.
The patch was generated using the following script:
#!/bin/sh
# Replace one string by another in all the kernel sources.
set -e
for file in `find * -name "*.c" -o -name "*.h"|xargs grep -l $1`; do
quilt add $file
sed -e "1,\$s/$1/$2/g" $file >/tmp/$$
mv /tmp/$$ $file
quilt refresh
done
The script was run like this
sh replace kmem_cache_t "struct kmem_cache"
Signed-off-by: Christoph Lameter <clameter@sgi.com>
SLAB_ATOMIC is an alias of GFP_ATOMIC
As CBC is the default chaining method for cryptoloop, we should select
it from cryptoloop to ease the transition.
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6
drivers/ata/libata-scsi.c
include/linux/libata.h
Futher merge of Linus's head and compilation fixups.
Signed-Off-By: David Howells <dhowells@redhat.com>
On error, make sure that we undo all necessary operations.
This also gets rid of a must_check warning.
Fix up for make allyesconfig.
Pass the work_struct pointer to the work function rather than context data.
The work function can use container_of() to work out the data.
For the cases where the container of the work_struct may go away the moment the
pending bit is cleared, it is made possible to defer the release of the
structure by deferring the clearing of the pending bit.
To make this work, an extra flag is introduced into the management side of the
work_struct. This governs auto-release of the structure upon execution.
Ordinarily, the work queue executor would release the work_struct for further
scheduling or deallocation by clearing the pending bit prior to jumping to the
work function. This means that, unless the driver makes some guarantee itself
that the work_struct won't go away, the work function may not access anything
else in the work_struct or its container lest they be deallocated.. This is a
problem if the auxiliary data is taken away (as done by the last patch).
However, if the pending bit is *not* cleared before jumping to the work
function, then the work function *may* access the work_struct and its container
with no problems. But then the work function must itself release the
work_struct by calling work_release().
In most cases, automatic release is fine, so this is the default. Special
initiators exist for the non-auto-release case (ending in _NAR).
Reclaim a word from the size of the work_struct by folding the pending bit and
the wq_data pointer together. This shouldn't cause misalignment problems as
all pointers should be at least 4-byte aligned.
Define a type for the work function prototype. It's not only kept in the
work_struct struct, it's also passed as an argument to several functions.
This makes it easier to change it.
