path: root/drivers/block
2014-01-31Merge tag 'stable/for-linus-3.14-rc0-late-tag' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip Pull Xen bugfixes from Konrad Rzeszutek Wilk: "Bug-fixes for the new features that were added during this cycle. There are also two fixes for long-standing issues for which we have a solution: grant-table operations extra work that was not needed causing performance issues and the self balloon code was too aggressive causing OOMs. Details: - Xen ARM couldn't use the new FIFO events - Xen ARM couldn't use the SWIOTLB if compiled as 32-bit with 64-bit PCIe devices. - Grant table were doing needless M2P operations. - Ratchet down the self-balloon code so it won't OOM. - Fix misplaced kfree in Xen PVH error code paths" * tag 'stable/for-linus-3.14-rc0-late-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip: xen/pvh: Fix misplaced kfree from xlated_setup_gnttab_pages drivers: xen: deaggressive selfballoon driver xen/grant-table: Avoid m2p_override during mapping xen/gnttab: Use phys_addr_t to describe the grant frame base address xen: swiotlb: handle sizeof(dma_addr_t) != sizeof(phys_addr_t) arm/xen: Initialize event channels earlier
2014-01-31xen/grant-table: Avoid m2p_override during mappingZoltan Kiss
The grant mapping API does m2p_override unnecessarily: only gntdev needs it, for blkback and future netback patches it just cause a lock contention, as those pages never go to userspace. Therefore this series does the following: - the original functions were renamed to __gnttab_[un]map_refs, with a new parameter m2p_override - based on m2p_override either they follow the original behaviour, or just set the private flag and call set_phys_to_machine - gnttab_[un]map_refs are now a wrapper to call __gnttab_[un]map_refs with m2p_override false - a new function gnttab_[un]map_refs_userspace provides the old behaviour It also removes a stray space from page.h and change ret to 0 if XENFEAT_auto_translated_physmap, as that is the only possible return value there. v2: - move the storing of the old mfn in page->index to gnttab_map_refs - move the function header update to a separate patch v3: - a new approach to retain old behaviour where it needed - squash the patches into one v4: - move out the common bits from m2p* functions, and pass pfn/mfn as parameter - clear page->private before doing anything with the page, so m2p_find_override won't race with this v5: - change return value handling in __gnttab_[un]map_refs - remove a stray space in page.h - add detail why ret = 0 now at some places v6: - don't pass pfn to m2p* functions, just get it locally Signed-off-by: Zoltan Kiss <zoltan.kiss@citrix.com> Suggested-by: David Vrabel <david.vrabel@citrix.com> Acked-by: David Vrabel <david.vrabel@citrix.com> Acked-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2014-01-30zram: remove zram->lock in read path and change it with mutexMinchan Kim
Finally, we separated zram->lock dependency from 32bit stat/ table handling so there is no reason to use rw_semaphore between read and write path so this patch removes the lock from read path totally and changes rw_semaphore with mutex. So, we could do old: read-read: OK read-write: NO write-write: NO Now: read-read: OK read-write: OK write-write: NO The below data proves mixed workload performs well 11 times and there is also enhance on write-write path because current rw-semaphore doesn't support SPIN_ON_OWNER. It's side effect but anyway good thing for us. Write-related tests perform better (from 61% to 1058%) but read path has good/bad(from -2.22% to 1.45%) but they are all marginal within stddev. CPU 12 iozone -t -T -l 12 -u 12 -r 16K -s 60M -I +Z -V 0 ==Initial write ==Initial write records: 10 records: 10 avg: 516189.16 avg: 839907.96 std: 22486.53 (4.36%) std: 47902.17 (5.70%) max: 546970.60 max: 909910.35 min: 481131.54 min: 751148.38 ==Rewrite ==Rewrite records: 10 records: 10 avg: 509527.98 avg: 1050156.37 std: 45799.94 (8.99%) std: 40695.44 (3.88%) max: 611574.27 max: 1111929.26 min: 443679.95 min: 980409.62 ==Read ==Read records: 10 records: 10 avg: 4408624.17 avg: 4472546.76 std: 281152.61 (6.38%) std: 163662.78 (3.66%) max: 4867888.66 max: 4727351.03 min: 4058347.69 min: 4126520.88 ==Re-read ==Re-read records: 10 records: 10 avg: 4462147.53 avg: 4363257.75 std: 283546.11 (6.35%) std: 247292.63 (5.67%) max: 4912894.44 max: 4677241.75 min: 4131386.50 min: 4035235.84 ==Reverse Read ==Reverse Read records: 10 records: 10 avg: 4565865.97 avg: 4485818.08 std: 313395.63 (6.86%) std: 248470.10 (5.54%) max: 5232749.16 max: 4789749.94 min: 4185809.62 min: 3963081.34 ==Stride read ==Stride read records: 10 records: 10 avg: 4515981.80 avg: 4418806.01 std: 211192.32 (4.68%) std: 212837.97 (4.82%) max: 4889287.28 max: 4686967.22 min: 4210362.00 min: 4083041.84 ==Random read ==Random read records: 10 records: 10 avg: 4410525.23 avg: 4387093.18 std: 236693.22 (5.37%) std: 235285.23 (5.36%) max: 4713698.47 max: 4669760.62 min: 4057163.62 min: 3952002.16 ==Mixed workload ==Mixed workload records: 10 records: 10 avg: 243234.25 avg: 2818677.27 std: 28505.07 (11.72%) std: 195569.70 (6.94%) max: 288905.23 max: 3126478.11 min: 212473.16 min: 2484150.69 ==Random write ==Random write records: 10 records: 10 avg: 555887.07 avg: 1053057.79 std: 70841.98 (12.74%) std: 35195.36 (3.34%) max: 683188.28 max: 1096125.73 min: 437299.57 min: 992481.93 ==Pwrite ==Pwrite records: 10 records: 10 avg: 501745.93 avg: 810363.09 std: 16373.54 (3.26%) std: 19245.01 (2.37%) max: 518724.52 max: 833359.70 min: 464208.73 min: 765501.87 ==Pread ==Pread records: 10 records: 10 avg: 4539894.60 avg: 4457680.58 std: 197094.66 (4.34%) std: 188965.60 (4.24%) max: 4877170.38 max: 4689905.53 min: 4226326.03 min: 4095739.72 Signed-off-by: Minchan Kim <minchan@kernel.org> Cc: Nitin Gupta <ngupta@vflare.org> Tested-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Cc: Jerome Marchand <jmarchan@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-30zram: remove workqueue for freeing removed pending slotMinchan Kim
Commit a0c516cbfc74 ("zram: don't grab mutex in zram_slot_free_noity") introduced free request pending code to avoid scheduling by mutex under spinlock and it was a mess which made code lenghty and increased overhead. Now, we don't need zram->lock any more to free slot so this patch reverts it and then, tb_lock should protect it. Signed-off-by: Minchan Kim <minchan@kernel.org> Cc: Nitin Gupta <ngupta@vflare.org> Tested-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Cc: Jerome Marchand <jmarchan@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-30zram: introduce zram->tb_lockMinchan Kim
Currently, the zram table is protected by zram->lock but it's rather coarse-grained lock and it makes hard for scalibility. Let's use own rwlock instead of depending on zram->lock. This patch adds new locking so obviously, it would make slow but this patch is just prepartion for removing coarse-grained rw_semaphore(ie, zram->lock) which is hurdle about zram scalability. Final patch in this patchset series will remove the lock from read-path and change rw_semaphore with mutex in write path. With bonus, we could drop pending slot free mess in next patch. Signed-off-by: Minchan Kim <minchan@kernel.org> Cc: Nitin Gupta <ngupta@vflare.org> Tested-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Cc: Jerome Marchand <jmarchan@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-30zram: use atomic operation for statMinchan Kim
Some of fields in zram->stats are protected by zram->lock which is rather coarse-grained so let's use atomic operation without explict locking. This patch is ready for removing dependency of zram->lock in read path which is very coarse-grained rw_semaphore. Of course, this patch adds new atomic operation so it might make slow but my 12CPU test couldn't spot any regression. All gain/lose is marginal within stddev. iozone -t -T -l 12 -u 12 -r 16K -s 60M -I +Z -V 0 ==Initial write ==Initial write records: 50 records: 50 avg: 412875.17 avg: 415638.23 std: 38543.12 (9.34%) std: 36601.11 (8.81%) max: 521262.03 max: 502976.72 min: 343263.13 min: 351389.12 ==Rewrite ==Rewrite records: 50 records: 50 avg: 416640.34 avg: 397914.33 std: 60798.92 (14.59%) std: 46150.42 (11.60%) max: 543057.07 max: 522669.17 min: 304071.67 min: 316588.77 ==Read ==Read records: 50 records: 50 avg: 4147338.63 avg: 4070736.51 std: 179333.25 (4.32%) std: 223499.89 (5.49%) max: 4459295.28 max: 4539514.44 min: 3753057.53 min: 3444686.31 ==Re-read ==Re-read records: 50 records: 50 avg: 4096706.71 avg: 4117218.57 std: 229735.04 (5.61%) std: 171676.25 (4.17%) max: 4430012.09 max: 4459263.94 min: 2987217.80 min: 3666904.28 ==Reverse Read ==Reverse Read records: 50 records: 50 avg: 4062763.83 avg: 4078508.32 std: 186208.46 (4.58%) std: 172684.34 (4.23%) max: 4401358.78 max: 4424757.22 min: 3381625.00 min: 3679359.94 ==Stride read ==Stride read records: 50 records: 50 avg: 4094933.49 avg: 4082170.22 std: 185710.52 (4.54%) std: 196346.68 (4.81%) max: 4478241.25 max: 4460060.97 min: 3732593.23 min: 3584125.78 ==Random read ==Random read records: 50 records: 50 avg: 4031070.04 avg: 4074847.49 std: 192065.51 (4.76%) std: 206911.33 (5.08%) max: 4356931.16 max: 4399442.56 min: 3481619.62 min: 3548372.44 ==Mixed workload ==Mixed workload records: 50 records: 50 avg: 149925.73 avg: 149675.54 std: 7701.26 (5.14%) std: 6902.09 (4.61%) max: 191301.56 max: 175162.05 min: 133566.28 min: 137762.87 ==Random write ==Random write records: 50 records: 50 avg: 404050.11 avg: 393021.47 std: 58887.57 (14.57%) std: 42813.70 (10.89%) max: 601798.09 max: 524533.43 min: 325176.99 min: 313255.34 ==Pwrite ==Pwrite records: 50 records: 50 avg: 411217.70 avg: 411237.96 std: 43114.99 (10.48%) std: 33136.29 (8.06%) max: 530766.79 max: 471899.76 min: 320786.84 min: 317906.94 ==Pread ==Pread records: 50 records: 50 avg: 4154908.65 avg: 4087121.92 std: 151272.08 (3.64%) std: 219505.04 (5.37%) max: 4459478.12 max: 4435857.38 min: 3730512.41 min: 3101101.67 Signed-off-by: Minchan Kim <minchan@kernel.org> Cc: Nitin Gupta <ngupta@vflare.org> Tested-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Cc: Jerome Marchand <jmarchan@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-30zram: remove unnecessary freeMinchan Kim
Commit a0c516cbfc74 ("zram: don't grab mutex in zram_slot_free_noity") introduced pending zram slot free in zram's write path in case of missing slot free by memory allocation failure in zram_slot_free_notify but it is not necessary because we have already freed the slot right before overwriting. Signed-off-by: Minchan Kim <minchan@kernel.org> Cc: Nitin Gupta <ngupta@vflare.org> Cc: Jerome Marchand <jmarchan@redhat.com> Tested-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-30zram: delay pending free request in read pathMinchan Kim
Sergey reported we don't need to handle pending free request every I/O so that this patch removes it in read path while we remain it in write path. Let's consider below example. Swap subsystem ask to zram "A" block free by swap_slot_free_notify but zram had been pended it without real freeing. Swap subsystem allocates "A" block for new data but request pended for a long time just handled and zram blindly free new data on the "A" block. :( That's why we couldn't remove handle pending free request right before zram-write. Signed-off-by: Minchan Kim <minchan@kernel.org> Reported-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Tested-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Cc: Nitin Gupta <ngupta@vflare.org> Cc: Jerome Marchand <jmarchan@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-30zram: fix race between reset and flushing pending workMinchan Kim
Dan and Sergey reported that there is a racy between reset and flushing of pending work so that it could make oops by freeing zram->meta in reset while zram_slot_free can access zram->meta if new request is adding during the race window. This patch moves flush after taking init_lock so it prevents new request so that it closes the race. Signed-off-by: Minchan Kim <minchan@kernel.org> Reported-by: Dan Carpenter <dan.carpenter@oracle.com> Cc: Nitin Gupta <ngupta@vflare.org> Cc: Jerome Marchand <jmarchan@redhat.com> Tested-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-30zram: add copyrightMinchan Kim
Add my copyright to the zram source code which I maintain. Signed-off-by: Minchan Kim <minchan@kernel.org> Cc: Nitin Gupta <ngupta@vflare.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-30zram: remove old private project commentMinchan Kim
Remove the old private compcache project address so upcoming patches should be sent to LKML because we Linux kernel community will take care. Signed-off-by: Minchan Kim <minchan@kernel.org> Cc: Nitin Gupta <ngupta@vflare.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-30zram: promote zram from stagingMinchan Kim
Zram has lived in staging for a LONG LONG time and have been fixed/improved by many contributors so code is clean and stable now. Of course, there are lots of product using zram in real practice. The major TV companys have used zram as swap since two years ago and recently our production team released android smart phone with zram which is used as swap, too and recently Android Kitkat start to use zram for small memory smart phone. And there was a report Google released their ChromeOS with zram, too and cyanogenmod have been used zram long time ago. And I heard some disto have used zram block device for tmpfs. In addition, I saw many report from many other peoples. For example, Lubuntu start to use it. The benefit of zram is very clear. With my experience, one of the benefit was to remove jitter of video application with backgroud memory pressure. It would be effect of efficient memory usage by compression but more issue is whether swap is there or not in the system. Recent mobile platforms have used JAVA so there are many anonymous pages. But embedded system normally are reluctant to use eMMC or SDCard as swap because there is wear-leveling and latency issues so if we do not use swap, it means we can't reclaim anoymous pages and at last, we could encounter OOM kill. :( Although we have real storage as swap, it was a problem, too. Because it sometime ends up making system very unresponsible caused by slow swap storage performance. Quote from Luigi on Google "Since Chrome OS was mentioned: the main reason why we don't use swap to a disk (rotating or SSD) is because it doesn't degrade gracefully and leads to a bad interactive experience. Generally we prefer to manage RAM at a higher level, by transparently killing and restarting processes. But we noticed that zram is fast enough to be competitive with the latter, and it lets us make more efficient use of the available RAM. " and he announced. http://www.spinics.net/lists/linux-mm/msg57717.html Other uses case is to use zram for block device. Zram is block device so anyone can format the block device and mount on it so some guys on the internet start zram as /var/tmp. http://forums.gentoo.org/viewtopic-t-838198-start-0.html Let's promote zram and enhance/maintain it instead of removing. Signed-off-by: Minchan Kim <minchan@kernel.org> Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Acked-by: Nitin Gupta <ngupta@vflare.org> Acked-by: Pekka Enberg <penberg@kernel.org> Cc: Bob Liu <bob.liu@oracle.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Hugh Dickins <hughd@google.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: Luigi Semenzato <semenzato@google.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Rik van Riel <riel@redhat.com> Cc: Seth Jennings <sjenning@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-30Merge branch 'for-3.14/drivers' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull block IO driver changes from Jens Axboe: - bcache update from Kent Overstreet. - two bcache fixes from Nicholas Swenson. - cciss pci init error fix from Andrew. - underflow fix in the parallel IDE pg_write code from Dan Carpenter. I'm sure the 1 (or 0) users of that are now happy. - two PCI related fixes for sx8 from Jingoo Han. - floppy init fix for first block read from Jiri Kosina. - pktcdvd error return miss fix from Julia Lawall. - removal of IRQF_SHARED from the SEGA Dreamcast CD-ROM code from Michael Opdenacker. - comment typo fix for the loop driver from Olaf Hering. - potential oops fix for null_blk from Raghavendra K T. - two fixes from Sam Bradshaw (Micron) for the mtip32xx driver, fixing an OOM problem and a problem with handling security locked conditions * 'for-3.14/drivers' of git://git.kernel.dk/linux-block: (47 commits) mg_disk: Spelling s/finised/finished/ null_blk: Null pointer deference problem in alloc_page_buffers mtip32xx: Correctly handle security locked condition mtip32xx: Make SGL container per-command to eliminate high order dma allocation drivers/block/loop.c: fix comment typo in loop_config_discard drivers/block/cciss.c:cciss_init_one(): use proper errnos drivers/block/paride/pg.c: underflow bug in pg_write() drivers/block/sx8.c: remove unnecessary pci_set_drvdata() drivers/block/sx8.c: use module_pci_driver() floppy: bail out in open() if drive is not responding to block0 read bcache: Fix auxiliary search trees for key size > cacheline size bcache: Don't return -EINTR when insert finished bcache: Improve bucket_prio() calculation bcache: Add bch_bkey_equal_header() bcache: update bch_bkey_try_merge bcache: Move insert_fixup() to btree_keys_ops bcache: Convert sorting to btree_keys bcache: Convert debug code to btree_keys bcache: Convert btree_iter to struct btree_keys bcache: Refactor bset_tree sysfs stats ...
2014-01-30Merge branch 'for-3.14/core' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull core block IO changes from Jens Axboe: "The major piece in here is the immutable bio_ve series from Kent, the rest is fairly minor. It was supposed to go in last round, but various issues pushed it to this release instead. The pull request contains: - Various smaller blk-mq fixes from different folks. Nothing major here, just minor fixes and cleanups. - Fix for a memory leak in the error path in the block ioctl code from Christian Engelmayer. - Header export fix from CaiZhiyong. - Finally the immutable biovec changes from Kent Overstreet. This enables some nice future work on making arbitrarily sized bios possible, and splitting more efficient. Related fixes to immutable bio_vecs: - dm-cache immutable fixup from Mike Snitzer. - btrfs immutable fixup from Muthu Kumar. - bio-integrity fix from Nic Bellinger, which is also going to stable" * 'for-3.14/core' of git://git.kernel.dk/linux-block: (44 commits) xtensa: fixup simdisk driver to work with immutable bio_vecs block/blk-mq-cpu.c: use hotcpu_notifier() blk-mq: for_each_* macro correctness block: Fix memory leak in rw_copy_check_uvector() handling bio-integrity: Fix bio_integrity_verify segment start bug block: remove unrelated header files and export symbol blk-mq: uses page->list incorrectly blk-mq: use __smp_call_function_single directly btrfs: fix missing increment of bi_remaining Revert "block: Warn and free bio if bi_end_io is not set" block: Warn and free bio if bi_end_io is not set blk-mq: fix initializing request's start time block: blk-mq: don't export blk_mq_free_queue() block: blk-mq: make blk_sync_queue support mq block: blk-mq: support draining mq queue dm cache: increment bi_remaining when bi_end_io is restored block: fixup for generic bio chaining block: Really silence spurious compiler warnings block: Silence spurious compiler warnings block: Kill bio_pair_split() ...
2014-01-28Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client Pull ceph updates from Sage Weil: "This is a big batch. From Ilya we have: - rbd support for more than ~250 mapped devices (now uses same scheme that SCSI does for device major/minor numbering) - crush updates for new mapping behaviors (will be needed for coming erasure coding support, among other things) - preliminary support for tiered storage pools There is also a big series fixing a pile cephfs bugs with clustered MDSs from Yan Zheng, ACL support for cephfs from Guangliang Zhao, ceph fscache improvements from Li Wang, improved behavior when we get ENOSPC from Josh Durgin, some readv/writev improvements from Majianpeng, and the usual mix of small cleanups" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client: (76 commits) ceph: cast PAGE_SIZE to size_t in ceph_sync_write() ceph: fix dout() compile warnings in ceph_filemap_fault() libceph: support CEPH_FEATURE_OSD_CACHEPOOL feature libceph: follow redirect replies from osds libceph: rename ceph_osd_request::r_{oloc,oid} to r_base_{oloc,oid} libceph: follow {read,write}_tier fields on osd request submission libceph: add ceph_pg_pool_by_id() libceph: CEPH_OSD_FLAG_* enum update libceph: replace ceph_calc_ceph_pg() with ceph_oloc_oid_to_pg() libceph: introduce and start using oid abstraction libceph: rename MAX_OBJ_NAME_SIZE to CEPH_MAX_OID_NAME_LEN libceph: move ceph_file_layout helpers to ceph_fs.h libceph: start using oloc abstraction libceph: dout() is missing a newline libceph: add ceph_kv{malloc,free}() and switch to them libceph: support CEPH_FEATURE_EXPORT_PEER ceph: add imported caps when handling cap export message ceph: add open export target session helper ceph: remove exported caps when handling cap import message ceph: handle session flush message ...
2014-01-27libceph: rename ceph_osd_request::r_{oloc,oid} to r_base_{oloc,oid}Ilya Dryomov
Rename ceph_osd_request::r_{oloc,oid} to r_base_{oloc,oid} before introducing r_target_{oloc,oid} needed for redirects. Signed-off-by: Ilya Dryomov <ilya.dryomov@inktank.com> Reviewed-by: Sage Weil <sage@inktank.com>
2014-01-27libceph: introduce and start using oid abstractionIlya Dryomov
In preparation for tiering support, which would require having two (base and target) object names for each osd request and also copying those names around, introduce struct ceph_object_id (oid) and a couple helpers to facilitate those copies and encapsulate the fact that object name is not necessarily a NUL-terminated string. Signed-off-by: Ilya Dryomov <ilya.dryomov@inktank.com> Reviewed-by: Sage Weil <sage@inktank.com>
2014-01-27libceph: rename MAX_OBJ_NAME_SIZE to CEPH_MAX_OID_NAME_LENIlya Dryomov
In preparation for adding oid abstraction, rename MAX_OBJ_NAME_SIZE to CEPH_MAX_OID_NAME_LEN. Signed-off-by: Ilya Dryomov <ilya.dryomov@inktank.com> Reviewed-by: Sage Weil <sage@inktank.com>
2014-01-27libceph: start using oloc abstractionIlya Dryomov
Instead of relying on pool fields in ceph_file_layout (for mapping) and ceph_pg (for enconding), start using ceph_object_locator (oloc) abstraction. Note that userspace oloc currently consists of pool, key, nspace and hash fields, while this one contains only a pool. This is OK, because at this point we only send (i.e. encode) olocs and never have to receive (i.e. decode) them. This makes keeping a copy of ceph_file_layout in every osd request unnecessary, so ceph_osd_request::r_file_layout field is nuked. Signed-off-by: Ilya Dryomov <ilya.dryomov@inktank.com> Reviewed-by: Sage Weil <sage@inktank.com>
2014-01-23drivers/block/Kconfig: update RAM block device module nameFabian Frederick
RAM block device support module name changed to brd.ko some years ago with an "rd" alias to match previous module implementation. This patch updates its Kconfig definition. Signed-off-by: Fabian Frederick <fabf@skynet.be> Acked-by: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-22Merge tag 'stable/for-linus-3.14-rc0-tag' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip Pull Xen updates from Konrad Rzeszutek Wilk: "Two major features that Xen community is excited about: The first is event channel scalability by David Vrabel - we switch over from an two-level per-cpu bitmap of events (IRQs) - to an FIFO queue with priorities. This lets us be able to handle more events, have lower latency, and better scalability. Good stuff. The other is PVH by Mukesh Rathor. In short, PV is a mode where the kernel lets the hypervisor program page-tables, segments, etc. With EPT/NPT capabilities in current processors, the overhead of doing this in an HVM (Hardware Virtual Machine) container is much lower than the hypervisor doing it for us. In short we let a PV guest run without doing page-table, segment, syscall, etc updates through the hypervisor - instead it is all done within the guest container. It is a "hybrid" PV - hence the 'PVH' name - a PV guest within an HVM container. The major benefits are less code to deal with - for example we only use one function from the the pv_mmu_ops (which has 39 function calls); faster performance for syscall (no context switches into the hypervisor); less traps on various operations; etc. It is still being baked - the ABI is not yet set in stone. But it is pretty awesome and we are excited about it. Lastly, there are some changes to ARM code - you should get a simple conflict which has been resolved in #linux-next. In short, this pull has awesome features. Features: - FIFO event channels. Key advantages: support for over 100,000 events (2^17), 16 different event priorities, improved fairness in event latency through the use of FIFOs. - Xen PVH support. "It’s a fully PV kernel mode, running with paravirtualized disk and network, paravirtualized interrupts and timers, no emulated devices of any kind (and thus no qemu), no BIOS or legacy boot — but instead of requiring PV MMU, it uses the HVM hardware extensions to virtualize the pagetables, as well as system calls and other privileged operations." (from "The Paravirtualization Spectrum, Part 2: From poles to a spectrum") Bug-fixes: - Fixes in balloon driver (refactor and make it work under ARM) - Allow xenfb to be used in HVM guests. - Allow xen_platform_pci=0 to work properly. - Refactors in event channels" * tag 'stable/for-linus-3.14-rc0-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip: (52 commits) xen/pvh: Set X86_CR0_WP and others in CR0 (v2) MAINTAINERS: add git repository for Xen xen/pvh: Use 'depend' instead of 'select'. xen: delete new instances of __cpuinit usage xen/fb: allow xenfb initialization for hvm guests xen/evtchn_fifo: fix error return code in evtchn_fifo_setup() xen-platform: fix error return code in platform_pci_init() xen/pvh: remove duplicated include from enlighten.c xen/pvh: Fix compile issues with xen_pvh_domain() xen: Use dev_is_pci() to check whether it is pci device xen/grant-table: Force to use v1 of grants. xen/pvh: Support ParaVirtualized Hardware extensions (v3). xen/pvh: Piggyback on PVHVM XenBus. xen/pvh: Piggyback on PVHVM for grant driver (v4) xen/grant: Implement an grant frame array struct (v3). xen/grant-table: Refactor gnttab_init xen/grants: Remove gnttab_max_grant_frames dependency on gnttab_init. xen/pvh: Piggyback on PVHVM for event channels (v2) xen/pvh: Update E820 to work with PVH (v2) xen/pvh: Secondary VCPU bringup (non-bootup CPUs) ...
2014-01-22Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial tree updates from Jiri Kosina: "Usual rocket science stuff from trivial.git" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits) neighbour.h: fix comment sched: Fix warning on make htmldocs caused by wait.h slab: struct kmem_cache is protected by slab_mutex doc: Fix typo in USB Gadget Documentation of/Kconfig: Spelling s/one/once/ mkregtable: Fix sscanf handling lp5523, lp8501: comment improvements thermal: rcar: comment spelling treewide: fix comments and printk msgs IXP4xx: remove '1 &&' from a condition check in ixp4xx_restart() Documentation: update /proc/uptime field description Documentation: Fix size parameter for snprintf arm: fix comment header and macro name asm-generic: uaccess: Spelling s/a ny/any/ mtd: onenand: fix comment header doc: driver-model/platform.txt: fix a typo drivers: fix typo in DEVTMPFS_MOUNT Kconfig help text doc: Fix typo (acces_process_vm -> access_process_vm) treewide: Fix typos in printk drivers/gpu/drm/qxl/Kconfig: reformat the help text ...
2014-01-21mg_disk: Spelling s/finised/finished/Geert Uytterhoeven
Signed-off-by: Geert Uytterhoeven <geert+renesas@linux-m68k.org> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2014-01-21null_blk: Null pointer deference problem in alloc_page_buffersRaghavendra K T
If we load the null_blk module with bs=8k we get following oops: [ 3819.812190] BUG: unable to handle kernel NULL pointer dereference at 0000000000000008 [ 3819.812387] IP: [<ffffffff81170aa5>] create_empty_buffers+0x28/0xaf [ 3819.812527] PGD 219244067 PUD 215a06067 PMD 0 [ 3819.812640] Oops: 0000 [#1] SMP [ 3819.812772] Modules linked in: null_blk(+) Fix that by resetting block size to PAGE_SIZE if it is greater than PAGE_SIZE Reported-by: Sumanth <sumantk2@linux.vnet.ibm.com> Signed-off-by: Raghavendra K T <raghavendra.kt@linux.vnet.ibm.com> Reviewed-by: Matias Bjorling <m@bjorling.me> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2014-01-21mtip32xx: Correctly handle security locked conditionSam Bradshaw
If power is removed during a secure erase, the drive will end up in a security locked condition. This patch causes the driver to identify, log, and flag the security lock state. IOs are prevented from submission to the drive until the locked state is addressed with a secure erase. Bumped version number to reflect this capability. Signed-off-by: Sam Bradshaw <sbradshaw@micron.com> Signed-off-by: Asai Thambi S P <asamymuthupa@micron.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2014-01-21mtip32xx: Make SGL container per-command to eliminate high order dma allocationSam Bradshaw
The mtip32xx driver makes a high order dma memory allocation to store a command index table, some dedicated buffers, and a command header & SGL blob. This allocation can fail with a surprise insert under low & fragmented memory conditions. This patch breaks these regions up into separate low order allocations and increases the maximum number of segments a single command SGL can have. We wanted to allow at least 256 segments for 1 MB direct IO. Since the command header occupies the first 0x80 bytes of the SGL blob, that meant we needed two 4k pages to contain the header and SGL. The two pages allow up to 504 SGL segments. Signed-off-by: Sam Bradshaw <sbradshaw@micron.com> Signed-off-by: Asai Thambi S P <asamymuthupa@micron.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2014-01-21Merge branch 'for-jens' of ↵Jens Axboe
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/linux-block into for-3.14/drivers
2014-01-21drivers/block/loop.c: fix comment typo in loop_config_discardOlaf Hering
Discard requests are ignored if the encryption is enabled for the given loop device. Update comment to match the code, and similar comments elsewhere in the file. Signed-off-by: Olaf Hering <olaf@aepfle.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2014-01-21drivers/block/cciss.c:cciss_init_one(): use proper errnosAndrew Morton
pci_driver.probe should return a meaningful errno, not -1. Cc: Jens Axboe <axboe@kernel.dk> Cc: Stephen M. Cameron <scameron@beardog.cce.hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2014-01-21drivers/block/paride/pg.c: underflow bug in pg_write()Dan Carpenter
The test here can underflow so we pass bogus lengths to the hardware. It's a static checker fix and I don't know the impact. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Cc: Jens Axboe <axboe@kernel.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2014-01-21drivers/block/sx8.c: remove unnecessary pci_set_drvdata()Jingoo Han
The driver core clears the driver data to NULL after device_release or on probe failure. Thus, it is not needed to manually clear the device driver data to NULL. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Cc: Jens Axboe <axboe@kernel.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2014-01-21drivers/block/sx8.c: use module_pci_driver()Jingoo Han
Use module_pci_driver() macro which makes the code smaller and simpler. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Cc: Jens Axboe <axboe@kernel.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2014-01-20Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/geert/linux-m68k Pull m68k updates from Geert Uytterhoeven: - Zorro bus cleanups and UAPI revival - Bootinfo cleanups and UAPI revival - Kexec support - Memory size reductions and bug fixes for multi-platform kernels - Polled interrupt support for Atari EtherNAT, EtherNEC and NetUSBee - Machine-specific random_get_entropy() - Defconfig updates and cleanups * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/geert/linux-m68k: (46 commits) m68k/mac: Make SCC reset work more reliably m68k/irq - Use polled IRQ flag for MFP timer cascaded interrupts m68k: Update defconfigs for v3.13-rc1 m68k/defconfig: Enable EARLY_PRINTK m68k/mm: kmap spelling/grammar fixes m68k: Convert arch/m68k/kernel/traps.c to pr_*() m68k: Convert arch/m68k/mm/fault.c to pr_*() m68k/mm: Check for mm != NULL in do_page_fault() debug code m68k/defconfig: Disable /sbin/hotplug fork-bomb by default m68k/atari: Hide RTC_PORT() macro from rtc-cmos m68k/amiga,atari: Fix specifying multiple debug= parameters m68k/defconfig: Use ext4 for ext2/ext3 file systems m68k: Add support to export bootinfo in procfs m68k: Add kexec support m68k/mac: Mark Mac IIsi ADB driver BROKEN m68k/amiga: Provide mach_random_get_entropy() m68k: Add infrastructure for machine-specific random_get_entropy() m68k/atari: Call paging_init() before nf_init() m68k: Remove superfluous inclusions of <asm/bootinfo.h> m68k/UAPI: Use proper types (endianness/size) in <asm/bootinfo*.h> ...
2014-01-17floppy: bail out in open() if drive is not responding to block0 readJiri Kosina
In case reading of block 0 during open() fails, it is not the right thing to let open() succeed. Fix this by introducing FD_OPEN_SHOULD_FAIL_BIT flag, and setting it in case the bio callback encounters an error while trying to read block 0. As a bonus, this works around certain broken userspace (blkid), which is not able to properly handle read()s returning IO errors. Hence be nice to those, and bail out during open() already; if block 0 is not readable, read()s are not going to provide any meaningful data anyway. Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2014-01-12block: null_blk: fix queue leak inside removing deviceMing Lei
When queue_mode is NULL_Q_MQ and null_blk is being removed, blk_cleanup_queue() isn't called to cleanup queue, so the queue allocated won't be freed. This patch calls blk_cleanup_queue() for MQ to drain all pending requests first and release the reference counter of queue kobject, then blk_mq_free_queue() will be called in queue kobject's release handler when queue kobject's reference counter drops to zero. Signed-off-by: Ming Lei <tom.leiming@gmail.com> Signed-off-by: Jens Axboe <axboe@kernel.dk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-08Merge branch 'for-3.14/core' into for-3.14/driversJens Axboe
We need the updated code to make bcache easier to merge.
2014-01-03xen/pvhvm: If xen_platform_pci=0 is set don't blow up (v4).Konrad Rzeszutek Wilk
The user has the option of disabling the platform driver: 00:02.0 Unassigned class [ff80]: XenSource, Inc. Xen Platform Device (rev 01) which is used to unplug the emulated drivers (IDE, Realtek 8169, etc) and allow the PV drivers to take over. If the user wishes to disable that they can set: xen_platform_pci=0 (in the guest config file) or xen_emul_unplug=never (on the Linux command line) except it does not work properly. The PV drivers still try to load and since the Xen platform driver is not run - and it has not initialized the grant tables, most of the PV drivers stumble upon: input: Xen Virtual Keyboard as /devices/virtual/input/input5 input: Xen Virtual Pointer as /devices/virtual/input/input6M ------------[ cut here ]------------ kernel BUG at /home/konrad/ssd/konrad/linux/drivers/xen/grant-table.c:1206! invalid opcode: 0000 [#1] SMP Modules linked in: xen_kbdfront(+) xenfs xen_privcmd CPU: 6 PID: 1389 Comm: modprobe Not tainted 3.13.0-rc1upstream-00021-ga6c892b-dirty #1 Hardware name: Xen HVM domU, BIOS 4.4-unstable 11/26/2013 RIP: 0010:[<ffffffff813ddc40>] [<ffffffff813ddc40>] get_free_entries+0x2e0/0x300 Call Trace: [<ffffffff8150d9a3>] ? evdev_connect+0x1e3/0x240 [<ffffffff813ddd0e>] gnttab_grant_foreign_access+0x2e/0x70 [<ffffffffa0010081>] xenkbd_connect_backend+0x41/0x290 [xen_kbdfront] [<ffffffffa0010a12>] xenkbd_probe+0x2f2/0x324 [xen_kbdfront] [<ffffffff813e5757>] xenbus_dev_probe+0x77/0x130 [<ffffffff813e7217>] xenbus_frontend_dev_probe+0x47/0x50 [<ffffffff8145e9a9>] driver_probe_device+0x89/0x230 [<ffffffff8145ebeb>] __driver_attach+0x9b/0xa0 [<ffffffff8145eb50>] ? driver_probe_device+0x230/0x230 [<ffffffff8145eb50>] ? driver_probe_device+0x230/0x230 [<ffffffff8145cf1c>] bus_for_each_dev+0x8c/0xb0 [<ffffffff8145e7d9>] driver_attach+0x19/0x20 [<ffffffff8145e260>] bus_add_driver+0x1a0/0x220 [<ffffffff8145f1ff>] driver_register+0x5f/0xf0 [<ffffffff813e55c5>] xenbus_register_driver_common+0x15/0x20 [<ffffffff813e76b3>] xenbus_register_frontend+0x23/0x40 [<ffffffffa0015000>] ? 0xffffffffa0014fff [<ffffffffa001502b>] xenkbd_init+0x2b/0x1000 [xen_kbdfront] [<ffffffff81002049>] do_one_initcall+0x49/0x170 .. snip.. which is hardly nice. This patch fixes this by having each PV driver check for: - if running in PV, then it is fine to execute (as that is their native environment). - if running in HVM, check if user wanted 'xen_emul_unplug=never', in which case bail out and don't load any PV drivers. - if running in HVM, and if PCI device 5853:0001 (xen_platform_pci) does not exist, then bail out and not load PV drivers. - (v2) if running in HVM, and if the user wanted 'xen_emul_unplug=ide-disks', then bail out for all PV devices _except_ the block one. Ditto for the network one ('nics'). - (v2) if running in HVM, and if the user wanted 'xen_emul_unplug=unnecessary' then load block PV driver, and also setup the legacy IDE paths. In (v3) make it actually load PV drivers. Reported-by: Sander Eikelenboom <linux@eikelenboom.it Reported-by: Anthony PERARD <anthony.perard@citrix.com> Reported-and-Tested-by: Fabio Fantoni <fabio.fantoni@m2r.biz> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> [v2: Add extra logic to handle the myrid ways 'xen_emul_unplug' can be used per Ian and Stefano suggestion] [v3: Make the unnecessary case work properly] [v4: s/disks/ide-disks/ spotted by Fabio] Reviewed-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com> Acked-by: Bjorn Helgaas <bhelgaas@google.com> [for PCI parts] CC: stable@vger.kernel.org
2014-01-03pktcdvd: fix error return codeJulia Lawall
Set the return variable to an error code as done elsewhere in the function. A simplified version of the semantic match that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> ( if@p1 (\(ret < 0\|ret != 0\)) { ... return ret; } | ret@p1 = 0 ) ... when != ret = e1 when != &ret *if(...) { ... when != ret = e2 when forall return ret; } // </smpl> Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2013-12-31rbd: tear down watch request if rbd_dev_device_setup() failsIlya Dryomov
Tear down watch request if rbd_dev_device_setup() fails. Signed-off-by: Ilya Dryomov <ilya.dryomov@inktank.com> Reviewed-by: Josh Durgin <josh.durgin@inktank.com>
2013-12-31rbd: introduce rbd_dev_header_unwatch_sync() and switch to itIlya Dryomov
Rename rbd_dev_header_watch_sync() to __rbd_dev_header_watch_sync() and introduce two helpers: rbd_dev_header_{,un}watch_sync() to make it more clear what is going on. Signed-off-by: Ilya Dryomov <ilya.dryomov@inktank.com> Reviewed-by: Josh Durgin <josh.durgin@inktank.com>
2013-12-31rbd: enable extended devt in single-major modeIlya Dryomov
If single-major device number allocation scheme is turned on, instead of reserving 256 minors per device, which imposes a limit of 4096 images mapped at once, reserve 16 minors per device and enable extended devt feature. This results in a theoretical limit of 65536 images mapped at once, and still allows to have more than 15 partititions: partitions starting with 16th are mapped under major 259 (Block Extended Major): $ rbd showmapped id pool image snap device 0 rbd b5 - /dev/rbd0 # no partitions 1 rbd b2 - /dev/rbd1 # 40 partitions 2 rbd b3 - /dev/rbd2 # 2 partitions $ cat /proc/partitions 251 0 1024 rbd0 251 16 1024 rbd1 251 17 0 rbd1p1 251 18 0 rbd1p2 ... 251 30 0 rbd1p14 251 31 0 rbd1p15 259 0 0 rbd1p16 259 1 0 rbd1p17 ... 259 23 0 rbd1p39 259 24 0 rbd1p40 251 32 1024 rbd2 251 33 0 rbd2p1 251 34 0 rbd2p2 (major 251 was assigned dynamically at module load time) Signed-off-by: Ilya Dryomov <ilya.dryomov@inktank.com> Reviewed-by: Josh Durgin <josh.durgin@inktank.com>
2013-12-31rbd: add support for single-major device number allocation schemeIlya Dryomov
Currently each rbd device is allocated its own major number, which leads to a hard limit of 230-250 images mapped at once. This commit adds support for a new single-major device number allocation scheme, which is hidden behind a new single_major boolean module parameter and is disabled by default for backwards compatibility reasons. (Old userspace cannot correctly unmap images mapped under single-major scheme and would essentially just unmap a random image, if that.) $ rbd showmapped id pool image snap device 0 rbd b100 - /dev/rbd0 1 rbd b101 - /dev/rbd1 2 rbd b102 - /dev/rbd2 3 rbd b103 - /dev/rbd3 Old scheme (modprobe rbd): $ ls -l /dev/rbd* brw-rw---- 1 root disk 253, 0 Dec 10 12:24 /dev/rbd0 brw-rw---- 1 root disk 252, 0 Dec 10 12:28 /dev/rbd1 brw-rw---- 1 root disk 252, 1 Dec 10 12:28 /dev/rbd1p1 brw-rw---- 1 root disk 252, 2 Dec 10 12:28 /dev/rbd1p2 brw-rw---- 1 root disk 252, 3 Dec 10 12:28 /dev/rbd1p3 brw-rw---- 1 root disk 251, 0 Dec 10 12:28 /dev/rbd2 brw-rw---- 1 root disk 251, 1 Dec 10 12:28 /dev/rbd2p1 brw-rw---- 1 root disk 250, 0 Dec 10 12:24 /dev/rbd3 New scheme (modprobe rbd single_major=Y): $ ls -l /dev/rbd* brw-rw---- 1 root disk 253, 0 Dec 10 12:30 /dev/rbd0 brw-rw---- 1 root disk 253, 256 Dec 10 12:30 /dev/rbd1 brw-rw---- 1 root disk 253, 257 Dec 10 12:30 /dev/rbd1p1 brw-rw---- 1 root disk 253, 258 Dec 10 12:30 /dev/rbd1p2 brw-rw---- 1 root disk 253, 259 Dec 10 12:30 /dev/rbd1p3 brw-rw---- 1 root disk 253, 512 Dec 10 12:30 /dev/rbd2 brw-rw---- 1 root disk 253, 513 Dec 10 12:30 /dev/rbd2p1 brw-rw---- 1 root disk 253, 768 Dec 10 12:30 /dev/rbd3 (major 253 was assigned dynamically at module load time) The new limit is 4096 images mapped at once, and it comes from the fact that, as before, 256 minor numbers are reserved for each mapping. (A follow-up commit changes the number of minors reserved and the way we deal with partitions over that number.) If single_major is set to true, two new sysfs interfaces show up: /sys/bus/rbd/{add,remove}_single_major. These are to be used instead of /sys/bus/rbd/{add,remove}, which are disabled for backwards compatibility reasons outlined above. Signed-off-by: Ilya Dryomov <ilya.dryomov@inktank.com> Reviewed-by: Alex Elder <elder@linaro.org> Reviewed-by: Josh Durgin <josh.durgin@inktank.com>
2013-12-31rbd: wire up is_visible() sysfs callback for rbd busIlya Dryomov
In preparation for single-major device number allocation scheme, wire up attribute_group::is_visible() callback for rbd bus. This allows us to make the new single-major attributes conditional. Signed-off-by: Ilya Dryomov <ilya.dryomov@inktank.com> Reviewed-by: Alex Elder <elder@linaro.org> Reviewed-by: Josh Durgin <josh.durgin@inktank.com>
2013-12-31rbd: add 'minor' sysfs rbd device attributeIlya Dryomov
Introduce /sys/bus/rbd/devices/<id>/minor sysfs attribute for exporting rbd whole disk minor numbers. This is a step towards single-major device number allocation scheme, but also a good thing on its own. Signed-off-by: Ilya Dryomov <ilya.dryomov@inktank.com> Reviewed-by: Alex Elder <elder@linaro.org> Reviewed-by: Josh Durgin <josh.durgin@inktank.com>
2013-12-31rbd: switch to ida for rbd id assignmentsIlya Dryomov
Currently rbd ids are allocated using an atomic variable that keeps track of the highest id currently in use and each new id is simply one more than the value of that variable. That's nice and cheap, but it does mean that rbd ids are allowed to grow boundlessly, and, more importantly, it's completely unpredictable. So, in preparation for single-major device number allocation scheme, which is going to establish and rely on a constant mapping between rbd ids and device numbers, switch to ida for rbd id assignments. Signed-off-by: Ilya Dryomov <ilya.dryomov@inktank.com> Reviewed-by: Alex Elder <elder@linaro.org> Reviewed-by: Josh Durgin <josh.durgin@inktank.com>
2013-12-31rbd: refactor rbd_init() a bitIlya Dryomov
Refactor rbd_init() a bit to make it more clear what's going on. Signed-off-by: Ilya Dryomov <ilya.dryomov@inktank.com> Reviewed-by: Alex Elder <elder@linaro.org> Reviewed-by: Josh Durgin <josh.durgin@inktank.com>
2013-12-31rbd: tweak "loaded" message and module descriptionIlya Dryomov
Tweak "loaded" message, so that it looks like [ 30.184235] rbd: loaded instead of [ 38.056564] rbd: loaded rbd (rados block device) Also move (and slightly tweak) MODULE_DESCRIPTION so that all authors are next to each other in modinfo output. Signed-off-by: Ilya Dryomov <ilya.dryomov@inktank.com> Reviewed-by: Alex Elder <elder@linaro.org> Reviewed-by: Josh Durgin <josh.durgin@inktank.com>
2013-12-31rbd: rbd_device::dev_id is an int, format it as suchIlya Dryomov
rbd_device::dev_id is an int, format it as such. Signed-off-by: Ilya Dryomov <ilya.dryomov@inktank.com> Reviewed-by: Alex Elder <elder@linaro.org> Reviewed-by: Josh Durgin <josh.durgin@inktank.com>
2013-12-31Merge tag 'v3.13-rc6' into for-3.14/coreJens Axboe
Needed to bring blk-mq uptodate, since changes have been going in since for-3.14/core was established. Fixup merge issues related to the immutable biovec changes. Signed-off-by: Jens Axboe <axboe@kernel.dk> Conflicts: block/blk-flush.c fs/btrfs/check-integrity.c fs/btrfs/extent_io.c fs/btrfs/scrub.c fs/logfs/dev_bdev.c
2013-12-24Merge branch 'for-linus' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull block fixes from Jens Axboe: - fix for a memory leak on certain unplug events - a collection of bcache fixes from Kent and Nicolas - a few null_blk fixes and updates form Matias - a marking of static of functions in the stec pci-e driver * 'for-linus' of git://git.kernel.dk/linux-block: null_blk: support submit_queues on use_per_node_hctx null_blk: set use_per_node_hctx param to false null_blk: corrections to documentation null_blk: warning on ignored submit_queues param null_blk: refactor init and init errors code paths null_blk: documentation null_blk: mem garbage on NUMA systems during init drivers: block: Mark the functions as static in skd_main.c bcache: New writeback PD controller bcache: bugfix for race between moving_gc and bucket_invalidate bcache: fix for gc and writeback race bcache: bugfix - moving_gc now moves only correct buckets bcache: fix for gc crashing when no sectors are used bcache: Fix heap_peek() macro bcache: Fix for can_attach_cache() bcache: Fix dirty_data accounting bcache: Use uninterruptible sleep in writeback bcache: kthread don't set writeback task to INTERUPTIBLE block: fix memory leaks on unplugging block device bcache: fix sparse non static symbol warning
