[ Upstream commit 427c5ce4417cba0801fbf79c8525d1330704759c ]
As of v4.20, the swim3 driver crashes when loaded on a PowerBook G3
(Wallstreet).
MacIO PCI driver attached to Gatwick chipset
MacIO PCI driver attached to Heathrow chipset
swim3 0.00015000:floppy: [fd0] SWIM3 floppy controller in media bay
0.00013020:ch-a: ttyS0 at MMIO 0xf3013020 (irq = 16, base_baud = 230400) is a Z85c30 ESCC - Serial port
0.00013000:ch-b: ttyS1 at MMIO 0xf3013000 (irq = 17, base_baud = 230400) is a Z85c30 ESCC - Infrared port
macio: fixed media-bay irq on gatwick
macio: fixed left floppy irqs
swim3 1.00015000:floppy: [fd1] Couldn't request interrupt
Unable to handle kernel paging request for data at address 0x00000024
Faulting instruction address: 0xc02652f8
Oops: Kernel access of bad area, sig: 11 [#1]
BE SMP NR_CPUS=2 PowerMac
Modules linked in:
CPU: 0 PID: 1 Comm: swapper/0 Not tainted 4.20.0 #2
NIP: c02652f8 LR: c026915c CTR: c0276d1c
REGS: df43ba10 TRAP: 0300 Not tainted (4.20.0)
MSR: 00009032 <EE,ME,IR,DR,RI> CR: 28228288 XER: 00000100
DAR: 00000024 DSISR: 40000000
GPR00: c026915c df43bac0 df439060 c0731524 df494700 00000000 c06e1c08 00000001
GPR08: 00000001 00000000 df5ff220 00001032 28228282 00000000 c0004ca4 00000000
GPR16: 00000000 00000000 00000000 c073144c dfffe064 c0731524 00000120 c0586108
GPR24: c073132c c073143c c073143c 00000000 c0731524 df67cd70 df494700 00000001
NIP [c02652f8] blk_mq_free_rqs+0x28/0xf8
LR [c026915c] blk_mq_sched_tags_teardown+0x58/0x84
Call Trace:
[df43bac0] [c0045f50] flush_workqueue_prep_pwqs+0x178/0x1c4 (unreliable)
[df43bae0] [c026915c] blk_mq_sched_tags_teardown+0x58/0x84
[df43bb00] [c02697f0] blk_mq_exit_sched+0x9c/0xb8
[df43bb20] [c0252794] elevator_exit+0x84/0xa4
[df43bb40] [c0256538] blk_exit_queue+0x30/0x50
[df43bb50] [c0256640] blk_cleanup_queue+0xe8/0x184
[df43bb70] [c034732c] swim3_attach+0x330/0x5f0
[df43bbb0] [c034fb24] macio_device_probe+0x58/0xec
[df43bbd0] [c032ba88] really_probe+0x1e4/0x2f4
[df43bc00] [c032bd28] driver_probe_device+0x64/0x204
[df43bc20] [c0329ac4] bus_for_each_drv+0x60/0xac
[df43bc50] [c032b824] __device_attach+0xe8/0x160
[df43bc80] [c032ab38] bus_probe_device+0xa0/0xbc
[df43bca0] [c0327338] device_add+0x3d8/0x630
[df43bcf0] [c0350848] macio_add_one_device+0x444/0x48c
[df43bd50] [c03509f8] macio_pci_add_devices+0x168/0x1bc
[df43bd90] [c03500ec] macio_pci_probe+0xc0/0x10c
[df43bda0] [c02ad884] pci_device_probe+0xd4/0x184
[df43bdd0] [c032ba88] really_probe+0x1e4/0x2f4
[df43be00] [c032bd28] driver_probe_device+0x64/0x204
[df43be20] [c032bfcc] __driver_attach+0x104/0x108
[df43be40] [c0329a00] bus_for_each_dev+0x64/0xb4
[df43be70] [c032add8] bus_add_driver+0x154/0x238
[df43be90] [c032ca24] driver_register+0x84/0x148
[df43bea0] [c0004aa0] do_one_initcall+0x40/0x188
[df43bf00] [c0690100] kernel_init_freeable+0x138/0x1d4
[df43bf30] [c0004cbc] kernel_init+0x18/0x10c
[df43bf40] [c00121e4] ret_from_kernel_thread+0x14/0x1c
Instruction dump:
5484d97e 4bfff4f4 9421ffe0 7c0802a6 bf410008 7c9e2378 90010024 8124005c
2f890000 419e0078 81230004 7c7c1b78 <81290024> 2f890000 419e0064 81440000
---[ end trace 12025ab921a9784c ]---
Reverting commit 8ccb8cb1892b ("swim3: convert to blk-mq") resolves the
problem.
That commit added a struct blk_mq_tag_set to struct floppy_state and
initialized it with a blk_mq_init_sq_queue() call. Unfortunately, there
is a memset() in swim3_add_device() that subsequently clears the
floppy_state struct. That means fs->tag_set->ops is a NULL pointer, and
it gets dereferenced by blk_mq_free_rqs() which gets called in the
request_irq() error path. Move the memset() to fix this bug.
BTW, the request_irq() failure for the left mediabay floppy (fd1) is not
a regression. I don't know why it happens. The right media bay floppy
(fd0) works fine however.
Reported-and-tested-by: Stan Johnson <userm57@yahoo.com>
Fixes: 8ccb8cb1892b ("swim3: convert to blk-mq")
Cc: linuxppc-dev@lists.ozlabs.org
Signed-off-by: Finn Thain <fthain@telegraphics.com.au>
[ Upstream commit 296dcc40f2f2e402facf7cd26cf3f2c8f4b17d47 ]
When the block device is opened with FMODE_EXCL, ref_count is set to -1.
This value doesn't get reset when the device is closed which means the
device cannot be opened again. Fix this by checking for refcount <= 0
in the release method.
Fixes: 1da177e4c3f4 ("Linux-2.6.12-rc2")
[ Upstream commit 3c9959e025472122a61faebb208525cf26b305d1 ]
Patch series "zram idle page writeback", v3.
Inherently, swap device has many idle pages which are rare touched since
it was allocated. It is never problem if we use storage device as swap.
However, it's just waste for zram-swap.
This patchset supports zram idle page writeback feature.
* Admin can define what is idle page "no access since X time ago"
* Admin can define when zram should writeback them
* Admin can define when zram should stop writeback to prevent wearout
Details are in each patch's description.
This patch (of 7):
WARNING: inconsistent lock state
4.19.0+ #390 Not tainted
inconsistent {SOFTIRQ-ON-W} -> {IN-SOFTIRQ-W} usage.
zram_verify/2095 [HC0[0]:SC1[1]:HE1:SE0] takes:
00000000b1828693 (&(&zram->bitmap_lock)->rlock){+.?.}, at: put_entry_bdev+0x1e/0x50
{SOFTIRQ-ON-W} state was registered at:
_raw_spin_lock+0x2c/0x40
zram_make_request+0x755/0xdc9
generic_make_request+0x373/0x6a0
submit_bio+0x6c/0x140
__swap_writepage+0x3a8/0x480
shrink_page_list+0x1102/0x1a60
shrink_inactive_list+0x21b/0x3f0
shrink_node_memcg.constprop.99+0x4f8/0x7e0
shrink_node+0x7d/0x2f0
do_try_to_free_pages+0xe0/0x300
try_to_free_pages+0x116/0x2b0
__alloc_pages_slowpath+0x3f4/0xf80
__alloc_pages_nodemask+0x2a2/0x2f0
__handle_mm_fault+0x42e/0xb50
handle_mm_fault+0x55/0xb0
__do_page_fault+0x235/0x4b0
page_fault+0x1e/0x30
irq event stamp: 228412
hardirqs last enabled at (228412): [<ffffffff98245846>] __slab_free+0x3e6/0x600
hardirqs last disabled at (228411): [<ffffffff98245625>] __slab_free+0x1c5/0x600
softirqs last enabled at (228396): [<ffffffff98e0031e>] __do_softirq+0x31e/0x427
softirqs last disabled at (228403): [<ffffffff98072051>] irq_exit+0xd1/0xe0
Possible unsafe locking scenario:
CPU0
lock(&(&zram->bitmap_lock)->rlock);
<Interrupt>
*** DEADLOCK ***
no locks held by zram_verify/2095.
stack backtrace:
CPU: 5 PID: 2095 Comm: zram_verify Not tainted 4.19.0+ #390
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.10.2-1 04/01/2014
Call Trace:
<IRQ>
dump_stack+0x67/0x9b
print_usage_bug+0x1bd/0x1d3
mark_lock+0x4aa/0x540
__lock_acquire+0x51d/0x1300
lock_acquire+0x90/0x180
zram_free_page+0xf6/0x110
zram_slot_free_notify+0x42/0xa0
end_swap_bio_read+0x5b/0x170
blk_update_request+0x8f/0x340
scsi_end_request+0x2c/0x1e0
scsi_io_completion+0x98/0x650
blk_done_softirq+0x9e/0xd0
__do_softirq+0xcc/0x427
irq_exit+0xd1/0xe0
do_IRQ+0x93/0x120
common_interrupt+0xf/0xf
</IRQ>
With writeback feature, zram_slot_free_notify could be called in softirq
context by end_swap_bio_read. However, bitmap_lock is not aware of that
so lockdep yell out:
get_entry_bdev
spin_lock(bitmap->lock);
irq
softirq
end_swap_bio_read
zram_slot_lock <-- deadlock prone
zram_free_page
put_entry_bdev
spin_lock(bitmap->lock); <-- deadlock prone
With akpm's suggestion (i.e. bitmap operation is already atomic), we
could remove bitmap lock. It might fail to find a empty slot if serious
contention happens. However, it's not severe problem because huge page
writeback has already possiblity to fail if there is severe memory
pressure. Worst case is just keeping the incompressible in memory, not
storage.
The other problem is zram_slot_lock in zram_slot_slot_free_notify. To
make it safe is this patch introduces zram_slot_trylock where
zram_slot_free_notify uses it. Although it's rare to be contented, this
patch adds new debug stat "miss_free" to keep monitoring how often it
happens.
Link: http://lkml.kernel.org/r/20181127055429.251614-2-minchan@kernel.org
Signed-off-by: Minchan Kim <minchan@kernel.org>
Reviewed-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com>
Reviewed-by: Joey Pabalinas <joeypabalinas@gmail.com>
[ Upstream commit 9848b6ddd8c92305252f94592c5e278574e7a6ac ]
If you try to promote a Secondary while connected to a Primary
and allow-two-primaries is NOT set, we will wait for "ping-timeout"
to give this node a chance to detect a dead primary,
in case the cluster manager noticed faster than we did.
But if we then are *still* connected to a Primary,
we fail (after an additional timeout of ping-timout).
This change skips the spurious second timeout.
Most people won't notice really,
since "ping-timeout" by default is half a second.
But in some installations, ping-timeout may be 10 or 20 seconds or more,
and spuriously delaying the error return becomes annoying.
Signed-off-by: Lars Ellenberg <lars.ellenberg@linbit.com>
[ Upstream commit b17b59602b6dcf8f97a7dc7bc489a48388d7063a ]
With "on-no-data-accessible suspend-io", DRBD requires the next attach
or connect to be to the very same data generation uuid tag it lost last.
If we first lost connection to the peer,
then later lost connection to our own disk,
we would usually refuse to re-connect to the peer,
because it presents the wrong data set.
However, if the peer first connects without a disk,
and then attached its disk, we accepted that same wrong data set,
which would be "unexpected" by any user of that DRBD
and cause "undefined results" (read: very likely data corruption).
The fix is to forcefully disconnect as soon as we notice that the peer
attached to the "wrong" dataset.
[ Upstream commit d29e89e34952a9ad02c77109c71a80043544296e ]
So far there was the possibility that we called
genlmsg_new(GFP_NOIO)/mutex_lock() while holding an rcu_read_lock().
This included cases like:
drbd_sync_handshake (acquire the RCU lock)
drbd_asb_recover_1p
drbd_khelper
drbd_bcast_event
genlmsg_new(GFP_NOIO) --> may sleep
drbd_asb_recover_1p
drbd_khelper
notify_helper
drbd_asb_recover_1p
drbd_khelper
notify_helper
mutex_lock --> may sleep
While using GFP_ATOMIC whould have been possible in the first two cases,
the real fix is to narrow the rcu_read_lock.
Reported-by: Jia-Ju Bai <baijiaju1990@163.com>
Reviewed-by: Lars Ellenberg <lars.ellenberg@linbit.com>
Signed-off-by: Roland Kammerer <roland.kammerer@linbit.com>
[ Upstream commit a11f6ca9aef989b56cd31ff4ee2af4fb31a172ec ]
__vdc_tx_trigger should only loop on EAGAIN a finite
number of times.
See commit adddc32d6fde ("sunvnet: Do not spin in an
infinite loop when vio_ldc_send() returns EAGAIN") for detail.
Signed-off-by: Young Xiao <YangX92@hotmail.com>
commit c8a83a6b54d0ca078de036aafb3f6af58c1dc5eb upstream.
NBD can update block device block size implicitely through
bd_set_size(). Make it explicitely set blocksize with set_blocksize() as
this behavior of bd_set_size() is going away.
CC: Josef Bacik <jbacik@fb.com>
commit 5db470e229e22b7eda6e23b5566e532c96fb5bc3 upstream.
If we don't drop caches used in old offset or block_size, we can get old data
from new offset/block_size, which gives unexpected data to user.
For example, Martijn found a loopback bug in the below scenario.
1) LOOP_SET_FD loads first two pages on loop file
2) LOOP_SET_STATUS64 changes the offset on the loop file
3) mount is failed due to the cached pages having wrong superblock
Cc: linux-block@vger.kernel.org
Reported-by: Martijn Coenen <maco@google.com>
Reviewed-by: Bart Van Assche <bvanassche@acm.org>
Signed-off-by: Jaegeuk Kim <jaegeuk@kernel.org>
commit 628bd85947091830a8c4872adfd5ed1d515a9cf2 upstream.
Commit 0a42e99b58a20883 ("loop: Get rid of loop_index_mutex") forgot to
remove mutex_unlock(&loop_ctl_mutex) from loop_control_ioctl() when
replacing loop_index_mutex with loop_ctl_mutex.
Fixes: 0a42e99b58a20883 ("loop: Get rid of loop_index_mutex")
Reported-by: syzbot <syzbot+c0138741c2290fc5e63f@syzkaller.appspotmail.com>
Reviewed-by: Ming Lei <ming.lei@redhat.com>
commit c28445fa06a3a54e06938559b9514c5a7f01c90f upstream.
The nested acquisition of loop_ctl_mutex (->lo_ctl_mutex back then) has
been introduced by commit f028f3b2f987e "loop: fix circular locking in
loop_clr_fd()" to fix lockdep complains about bd_mutex being acquired
after lo_ctl_mutex during partition rereading. Now that these are
properly fixed, let's stop fooling lockdep.
commit 1dded9acf6dc9a34cd27fcf8815507e4e65b3c4f upstream.
Code in loop_change_fd() drops reference to the old file (and also the
new file in a failure case) under loop_ctl_mutex. Similarly to a
situation in loop_set_fd() this can create a circular locking dependency
if this was the last reference holding the file open. Delay dropping of
the file reference until we have released loop_ctl_mutex.
Reported-by: Tetsuo Handa <penguin-kernel@i-love.sakura.ne.jp>
commit 0da03cab87e6323ff2e05b14bc7d5c6fcc531efd upstream.
Calling blkdev_reread_part() under loop_ctl_mutex causes lockdep to
complain about circular lock dependency between bdev->bd_mutex and
lo->lo_ctl_mutex. The problem is that on loop device open or close
lo_open() and lo_release() get called with bdev->bd_mutex held and they
need to acquire loop_ctl_mutex. OTOH when loop_reread_partitions() is
called with loop_ctl_mutex held, it will call blkdev_reread_part() which
acquires bdev->bd_mutex. See syzbot report for details [1].
Move call to blkdev_reread_part() in __loop_clr_fd() from under
loop_ctl_mutex to finish fixing of the lockdep warning and the possible
deadlock.
[1] https://syzkaller.appspot.com/bug?id=bf154052f0eea4bc7712499e4569505907d1588
Reported-by: syzbot <syzbot+4684a000d5abdade83fac55b1e7d1f935ef1936e@syzkaller.appspotmail.com>
commit 85b0a54a82e4fbceeb1aebb7cb6909edd1a24668 upstream.
Calling loop_reread_partitions() under loop_ctl_mutex causes lockdep to
Move all calls of loop_rescan_partitions() out of loop_ctl_mutex to
avoid lockdep warning and fix deadlock possibility.
commit d57f3374ba4817f7c8d26fae8a13d20ac8d31b92 upstream.
The call of __blkdev_reread_part() from loop_reread_partition() happens
only when we need to invalidate partitions from loop_release(). Thus
move a detection for this into loop_clr_fd() and simplify
loop_reread_partition().
This makes loop_reread_partition() safe to use without loop_ctl_mutex
because we use only lo->lo_number and lo->lo_file_name in case of error
for reporting purposes (thus possibly reporting outdate information is
not a big deal) and we are safe from 'lo' going away under us by
elevated lo->lo_refcnt.
commit c371077000f4138ee3c15fbed50101ff24bdc91d upstream.
Push loop_ctl_mutex down to loop_change_fd(). We will need this to be
able to call loop_reread_partitions() without loop_ctl_mutex.
commit 757ecf40b7e029529768eb5f9562d5eeb3002106 upstream.
Push lo_ctl_mutex down to loop_set_fd(). We will need this to be able to
call loop_reread_partitions() without lo_ctl_mutex.
commit 550df5fdacff94229cde0ed9b8085155654c1696 upstream.
Push loop_ctl_mutex down to loop_set_status(). We will need this to be
commit 4a5ce9ba5877e4640200d84a735361306ad1a1b8 upstream.
Push loop_ctl_mutex down to loop_get_status() to avoid the unusual
convention that the function gets called with loop_ctl_mutex held and
releases it.
commit 7ccd0791d98531df7cd59e92d55e4f063d48a070 upstream.
loop_clr_fd() has a weird locking convention that is expects
loop_ctl_mutex held, releases it on success and keeps it on failure.
Untangle the mess by moving locking of loop_ctl_mutex into
loop_clr_fd().
commit a2505b799a496b7b84d9a4a14ec870ff9e42e11b upstream.
Move setting of lo_state to Lo_rundown out into the callers. That will
allow us to unlock loop_ctl_mutex while the loop device is protected
from other changes by its special state.
commit a13165441d58b216adbd50252a9cc829d78a6bce upstream.
Push acquisition of lo_ctl_mutex down into individual ioctl handling
branches. This is a preparatory step for pushing the lock down into
individual ioctl handling functions so that they can release the lock as
they need it. We also factor out some simple ioctl handlers that will
not need any special handling to reduce unnecessary code duplication.
commit 0a42e99b58a208839626465af194cfe640ef9493 upstream.
Now that loop_ctl_mutex is global, just get rid of loop_index_mutex as
there is no good reason to keep these two separate and it just
complicates the locking.
commit 967d1dc144b50ad005e5eecdfadfbcfb399ffff6 upstream.
__loop_release() has a single call site. Fold it there. This is
currently not a huge win but it will make following replacement of
loop_index_mutex more obvious.
commit 310ca162d779efee8a2dc3731439680f3e9c1e86 upstream.
syzbot is reporting NULL pointer dereference [1] which is caused by
race condition between ioctl(loop_fd, LOOP_CLR_FD, 0) versus
ioctl(other_loop_fd, LOOP_SET_FD, loop_fd) due to traversing other
loop devices at loop_validate_file() without holding corresponding
lo->lo_ctl_mutex locks.
Since ioctl() request on loop devices is not frequent operation, we don't
need fine grained locking. Let's use global lock in order to allow safe
traversal at loop_validate_file().
Note that syzbot is also reporting circular locking dependency between
bdev->bd_mutex and lo->lo_ctl_mutex [2] which is caused by calling
blkdev_reread_part() with lock held. This patch does not address it.
[1] https://syzkaller.appspot.com/bug?id=f3cfe26e785d85f9ee259f385515291d21bd80a3
[2] https://syzkaller.appspot.com/bug?id=bf154052f0eea4bc7712499e4569505907d15889
Reported-by: syzbot <syzbot+bf89c128e05dd6c62523@syzkaller.appspotmail.com>
commit b1ab5fa309e6c49e4e06270ec67dd7b3e9971d04 upstream.
vfs_getattr() needs "struct path" rather than "struct file".
Let's use path_get()/path_put() rather than get_file()/fput().
commit 85f5a4d666fd9be73856ed16bb36c5af5b406b29 upstream.
There is a window between when RBD_DEV_FLAG_REMOVING is set and when
the device is removed from rbd_dev_list. During this window, we set
"already" and return 0.
Returning 0 from write(2) can confuse userspace tools because
0 indicates that nothing was written. In particular, "rbd unmap"
will retry the write multiple times a second:
10:28:05.463299 write(4, "0", 1) = 0
10:28:05.463509 write(4, "0", 1) = 0
10:28:05.463720 write(4, "0", 1) = 0
10:28:05.463942 write(4, "0", 1) = 0
10:28:05.464155 write(4, "0", 1) = 0
Cc: stable@vger.kernel.org
Signed-off-by: Ilya Dryomov <idryomov@gmail.com>
Tested-by: Dongsheng Yang <dongsheng.yang@easystack.cn>
commit 5547932dc67a48713eece4fa4703bfdf0cfcb818 upstream.
If blkdev_get fails, we shouldn't do blkdev_put. Otherwise, kernel emits
below log. This patch fixes it.
WARNING: CPU: 0 PID: 1893 at fs/block_dev.c:1828 blkdev_put+0x105/0x120
Modules linked in:
CPU: 0 PID: 1893 Comm: swapoff Not tainted 4.19.0+ #453
RIP: 0010:blkdev_put+0x105/0x120
Call Trace:
__x64_sys_swapoff+0x46d/0x490
do_syscall_64+0x5a/0x190
entry_SYSCALL_64_after_hwframe+0x49/0xbe
irq event stamp: 4466
hardirqs last enabled at (4465): __free_pages_ok+0x1e3/0x490
hardirqs last disabled at (4466): trace_hardirqs_off_thunk+0x1a/0x1c
softirqs last enabled at (3420): __do_softirq+0x333/0x446
softirqs last disabled at (3407): irq_exit+0xd1/0xe0
Link: http://lkml.kernel.org/r/20181127055429.251614-3-minchan@kernel.org
Cc: <stable@vger.kernel.org> [4.14+]
Pull block fixes from Jens Axboe:
- Discard loop fix, caused by integer overflow (Dave)
- Blacklist of Samsung drive that hangs with power management (Diego)
- Copy bio priority when cloning it (Hannes)
- Fix race condition exposed in floppy (me)
- Fix SCSI queue cleanup regression. While elusive, it caused oopses in
queue running (Ming)
- Fix bad string copy in kyber tracing (Omar)
* tag 'for-linus-20181115' of git://git.kernel.dk/linux-block:
SCSI: fix queue cleanup race before queue initialization is done
block: fix 32 bit overflow in __blkdev_issue_discard()
libata: blacklist SAMSUNG MZ7TD256HAFV-000L9 SSD
block: copy ioprio in __bio_clone_fast() and bounce
kyber: fix wrong strlcpy() size in trace_kyber_latency()
floppy: fix race condition in __floppy_read_block_0()
LKP recently reported a hang at bootup in the floppy code:
[ 245.678853] INFO: task mount:580 blocked for more than 120 seconds.
[ 245.679906] Tainted: G T 4.19.0-rc6-00172-ga9f38e1 #1
[ 245.680959] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[ 245.682181] mount D 6372 580 1 0x00000004
[ 245.683023] Call Trace:
[ 245.683425] __schedule+0x2df/0x570
[ 245.683975] schedule+0x2d/0x80
[ 245.684476] schedule_timeout+0x19d/0x330
[ 245.685090] ? wait_for_common+0xa5/0x170
[ 245.685735] wait_for_common+0xac/0x170
[ 245.686339] ? do_sched_yield+0x90/0x90
[ 245.686935] wait_for_completion+0x12/0x20
[ 245.687571] __floppy_read_block_0+0xfb/0x150
[ 245.688244] ? floppy_resume+0x40/0x40
[ 245.688844] floppy_revalidate+0x20f/0x240
[ 245.689486] check_disk_change+0x43/0x60
[ 245.690087] floppy_open+0x1ea/0x360
[ 245.690653] __blkdev_get+0xb4/0x4d0
[ 245.691212] ? blkdev_get+0x1db/0x370
[ 245.691777] blkdev_get+0x1f3/0x370
[ 245.692351] ? path_put+0x15/0x20
[ 245.692871] ? lookup_bdev+0x4b/0x90
[ 245.693539] blkdev_get_by_path+0x3d/0x80
[ 245.694165] mount_bdev+0x2a/0x190
[ 245.694695] squashfs_mount+0x10/0x20
[ 245.695271] ? squashfs_alloc_inode+0x30/0x30
[ 245.695960] mount_fs+0xf/0x90
[ 245.696451] vfs_kern_mount+0x43/0x130
[ 245.697036] do_mount+0x187/0xc40
[ 245.697563] ? memdup_user+0x28/0x50
[ 245.698124] ksys_mount+0x60/0xc0
[ 245.698639] sys_mount+0x19/0x20
[ 245.699167] do_int80_syscall_32+0x61/0x130
[ 245.699813] entry_INT80_32+0xc7/0xc7
showing that we never complete that read request. The reason is that
the completion setup is racy - it initializes the completion event
AFTER submitting the IO, which means that the IO could complete
before/during the init. If it does, we are passing garbage to
complete() and we may sleep forever waiting for the event to
occur.
Fixes: 7b7b68bba5ef ("floppy: bail out in open() if drive is not responding to block0 read")
Reviewed-by: Omar Sandoval <osandov@fb.com>
git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip
Pull xen fixes from Juergen Gross:
"Several fixes, mostly for rather recent regressions when running under
Xen"
* tag 'for-linus-4.20a-rc2-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip:
xen: remove size limit of privcmd-buf mapping interface
xen: fix xen_qlock_wait()
x86/xen: fix pv boot
xen-blkfront: fix kernel panic with negotiate_mq error path
xen/grant-table: Fix incorrect gnttab_dma_free_pages() pr_debug message
CONFIG_XEN_PV breaks xen_create_contiguous_region on ARM
info->nr_rings isn't adjusted in case of ENOMEM error from
negotiate_mq(). This leads to kernel panic in error path.
Typical call stack involving panic -
#8 page_fault at ffffffff8175936f
[exception RIP: blkif_free_ring+33]
RIP: ffffffffa0149491 RSP: ffff8804f7673c08 RFLAGS: 00010292
#9 blkif_free at ffffffffa0149aaa [xen_blkfront]
#10 talk_to_blkback at ffffffffa014c8cd [xen_blkfront]
#11 blkback_changed at ffffffffa014ea8b [xen_blkfront]
#12 xenbus_otherend_changed at ffffffff81424670
#13 backend_changed at ffffffff81426dc3
#14 xenwatch_thread at ffffffff81422f29
#15 kthread at ffffffff810abe6a
#16 ret_from_fork at ffffffff81754078
Fixes: 7ed8ce1c5fc7 ("xen-blkfront: move negotiate_mq to cover all cases of new VBDs")
Signed-off-by: Manjunath Patil <manjunath.b.patil@oracle.com>
Acked-by: Roger Pau Monné <roger.pau@citrix.com>
Signed-off-by: Juergen Gross <jgross@suse.com>
Pull block layer fixes from Jens Axboe:
"The biggest part of this pull request is the revert of the blkcg
cleanup series. It had one fix earlier for a stacked device issue, but
another one was reported. Rather than play whack-a-mole with this,
revert the entire series and try again for the next kernel release.
Apart from that, only small fixes/changes.
Summary:
- Indentation fixup for mtip32xx (Colin Ian King)
- The blkcg cleanup series revert (Dennis Zhou)
- Two NVMe fixes. One fixing a regression in the nvme request
initialization in this merge window, causing nvme-fc to not work.
The other is a suspend/resume p2p resource issue (James, Keith)
- Fix sg discard merge, allowing us to merge in cases where we didn't
before (Jianchao Wang)
- Call rq_qos_exit() after the queue is frozen, preventing a hang
(Ming)
- Fix brd queue setup, fixing an oops if we fail setting up all
devices (Ming)"
* tag 'for-linus-20181102' of git://git.kernel.dk/linux-block:
nvme-pci: fix conflicting p2p resource adds
nvme-fc: fix request private initialization
blkcg: revert blkcg cleanups series
block: brd: associate with queue until adding disk
block: call rq_qos_exit() after queue is frozen
mtip32xx: clean an indentation issue, remove extraneous tabs
block: fix the DISCARD request merge
Pull AFS updates from Al Viro:
"AFS series, with some iov_iter bits included"
* 'work.afs' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (26 commits)
missing bits of "iov_iter: Separate type from direction and use accessor functions"
afs: Probe multiple fileservers simultaneously
afs: Fix callback handling
afs: Eliminate the address pointer from the address list cursor
afs: Allow dumping of server cursor on operation failure
afs: Implement YFS support in the fs client
afs: Expand data structure fields to support YFS
afs: Get the target vnode in afs_rmdir() and get a callback on it
afs: Calc callback expiry in op reply delivery
afs: Fix FS.FetchStatus delivery from updating wrong vnode
afs: Implement the YFS cache manager service
afs: Remove callback details from afs_callback_break struct
afs: Commit the status on a new file/dir/symlink
afs: Increase to 64-bit volume ID and 96-bit vnode ID for YFS
afs: Don't invoke the server to read data beyond EOF
afs: Add a couple of tracepoints to log I/O errors
afs: Handle EIO from delivery function
afs: Fix TTL on VL server and address lists
afs: Implement VL server rotation
afs: Improve FS server rotation error handling
This reverts a series committed earlier due to null pointer exception
bug report in [1]. It seems there are edge case interactions that I did
not consider and will need some time to understand what causes the
adverse interactions.
The original series can be found in [2] with a follow up series in [3].
[1] https://www.spinics.net/lists/cgroups/msg20719.html
[2] https://lore.kernel.org/lkml/20180911184137.35897-1-dennisszhou@gmail.com/
[3] https://lore.kernel.org/lkml/20181020185612.51587-1-dennis@kernel.org/
This reverts the following commits:
d459d853c2ed, b2c3fa546705, 101246ec02b5, b3b9f24f5fcc, e2b0989954ae,
f0fcb3ec89f3, c839e7a03f92, bdc2491708c4, 74b7c02a9bc1, 5bf9a1f3b4ef,
a7b39b4e961c, 07b05bcc3213, 49f4c2dc2b50, 27e6fa996c53
Signed-off-by: Dennis Zhou <dennis@kernel.org>
brd_free() may be called in failure path on one brd instance which
disk isn't added yet, so release handler of gendisk may free the
associated request_queue early and causes the following use-after-free[1].
This patch fixes this issue by associating gendisk with request_queue
just before adding disk.
[1] KASAN: use-after-free Read in del_timer_syncNon-volatile memory driver v1.3
Linux agpgart interface v0.103
[drm] Initialized vgem 1.0.0 20120112 for virtual device on minor 0
usbcore: registered new interface driver udl
BUG: KASAN: use-after-free in __lock_acquire+0x36d9/0x4c20
kernel/locking/lockdep.c:3218
Read of size 8 at addr ffff8801d1b6b540 by task swapper/0/1
CPU: 0 PID: 1 Comm: swapper/0 Not tainted 4.19.0+ #88
Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS
Google 01/01/2011
Call Trace:
__dump_stack lib/dump_stack.c:77 [inline]
dump_stack+0x244/0x39d lib/dump_stack.c:113
print_address_description.cold.7+0x9/0x1ff mm/kasan/report.c:256
kasan_report_error mm/kasan/report.c:354 [inline]
kasan_report.cold.8+0x242/0x309 mm/kasan/report.c:412
__asan_report_load8_noabort+0x14/0x20 mm/kasan/report.c:433
__lock_acquire+0x36d9/0x4c20 kernel/locking/lockdep.c:3218
lock_acquire+0x1ed/0x520 kernel/locking/lockdep.c:3844
del_timer_sync+0xb7/0x270 kernel/time/timer.c:1283
blk_cleanup_queue+0x413/0x710 block/blk-core.c:809
brd_free+0x5d/0x71 drivers/block/brd.c:422
brd_init+0x2eb/0x393 drivers/block/brd.c:518
do_one_initcall+0x145/0x957 init/main.c:890
do_initcall_level init/main.c:958 [inline]
do_initcalls init/main.c:966 [inline]
do_basic_setup init/main.c:984 [inline]
kernel_init_freeable+0x5c6/0x6b9 init/main.c:1148
kernel_init+0x11/0x1ae init/main.c:1068
ret_from_fork+0x3a/0x50 arch/x86/entry/entry_64.S:350
Reported-by: syzbot+3701447012fe951dabb2@syzkaller.appspotmail.com
Signed-off-by: Ming Lei <ming.lei@redhat.com>
Pull ceph updates from Ilya Dryomov:
"The highlights are:
- a series that fixes some old memory allocation issues in libceph
(myself). We no longer allocate memory in places where allocation
failures cannot be handled and BUG when the allocation fails.
- support for copy_file_range() syscall (Luis Henriques). If size and
alignment conditions are met, it leverages RADOS copy-from
operation. Otherwise, a local copy is performed.
- a patch that reduces memory requirement of ceph_sync_read() from
the size of the entire read to the size of one object (Zheng Yan).
- fallocate() syscall is now restricted to FALLOC_FL_PUNCH_HOLE (Luis
Henriques)"
* tag 'ceph-for-4.20-rc1' of git://github.com/ceph/ceph-client: (25 commits)
ceph: new mount option to disable usage of copy-from op
ceph: support copy_file_range file operation
libceph: support the RADOS copy-from operation
ceph: add non-blocking parameter to ceph_try_get_caps()
libceph: check reply num_data_items in setup_request_data()
libceph: preallocate message data items
libceph, rbd, ceph: move ceph_osdc_alloc_messages() calls
libceph: introduce alloc_watch_request()
libceph: assign cookies in linger_submit()
libceph: enable fallback to ceph_msg_new() in ceph_msgpool_get()
ceph: num_ops is off by one in ceph_aio_retry_work()
libceph: no need to call osd_req_opcode_valid() in osd_req_encode_op()
ceph: set timeout conditionally in __cap_delay_requeue
libceph: don't consume a ref on pagelist in ceph_msg_data_add_pagelist()
libceph: introduce ceph_pagelist_alloc()
libceph: osd_req_op_cls_init() doesn't need to take opcode
libceph: bump CEPH_MSG_MAX_DATA_LEN
ceph: only allow punch hole mode in fallocate
ceph: refactor ceph_sync_read()
ceph: check if LOOKUPNAME request was aborted when filling trace
Trivial fix to clean up an indentation issue, remove tabs
git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux
Pull powerpc updates from Michael Ellerman:
"Notable changes:
- A large series to rewrite our SLB miss handling, replacing a lot of
fairly complicated asm with much fewer lines of C.
- Following on from that, we now maintain a cache of SLB entries for
each process and preload them on context switch. Leading to a 27%
speedup for our context switch benchmark on Power9.
- Improvements to our handling of SLB multi-hit errors. We now print
more debug information when they occur, and try to continue running
by flushing the SLB and reloading, rather than treating them as
fatal.
- Enable THP migration on 64-bit Book3S machines (eg. Power7/8/9).
- Add support for physical memory up to 2PB in the linear mapping on
64-bit Book3S. We only support up to 512TB as regular system
memory, otherwise the percpu allocator runs out of vmalloc space.
- Add stack protector support for 32 and 64-bit, with a per-task
canary.
- Add support for PTRACE_SYSEMU and PTRACE_SYSEMU_SINGLESTEP.
- Support recognising "big cores" on Power9, where two SMT4 cores are
presented to us as a single SMT8 core.
- A large series to cleanup some of our ioremap handling and PTE
flags.
- Add a driver for the PAPR SCM (storage class memory) interface,
allowing guests to operate on SCM devices (acked by Dan).
- Changes to our ftrace code to handle very large kernels, where we
need to use a trampoline to get to ftrace_caller().
And many other smaller enhancements and cleanups.
Thanks to: Alan Modra, Alistair Popple, Aneesh Kumar K.V, Anton
Blanchard, Aravinda Prasad, Bartlomiej Zolnierkiewicz, Benjamin
Herrenschmidt, Breno Leitao, Cédric Le Goater, Christophe Leroy,
Christophe Lombard, Dan Carpenter, Daniel Axtens, Finn Thain, Gautham
R. Shenoy, Gustavo Romero, Haren Myneni, Hari Bathini, Jia Hongtao,
Joel Stanley, John Allen, Laurent Dufour, Madhavan Srinivasan, Mahesh
Salgaonkar, Mark Hairgrove, Masahiro Yamada, Michael Bringmann,
Michael Neuling, Michal Suchanek, Murilo Opsfelder Araujo, Nathan
Fontenot, Naveen N. Rao, Nicholas Piggin, Nick Desaulniers, Oliver
O'Halloran, Paul Mackerras, Petr Vorel, Rashmica Gupta, Reza Arbab,
Rob Herring, Sam Bobroff, Samuel Mendoza-Jonas, Scott Wood, Stan
Johnson, Stephen Rothwell, Stewart Smith, Suraj Jitindar Singh, Tyrel
Datwyler, Vaibhav Jain, Vasant Hegde, YueHaibing, zhong jiang"
* tag 'powerpc-4.20-1' of git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux: (221 commits)
Revert "selftests/powerpc: Fix out-of-tree build errors"
powerpc/msi: Fix compile error on mpc83xx
powerpc: Fix stack protector crashes on CPU hotplug
powerpc/traps: restore recoverability of machine_check interrupts
powerpc/64/module: REL32 relocation range check
powerpc/64s/radix: Fix radix__flush_tlb_collapsed_pmd double flushing pmd
selftests/powerpc: Add a test of wild bctr
powerpc/mm: Fix page table dump to work on Radix
powerpc/mm/radix: Display if mappings are exec or not
powerpc/mm/radix: Simplify split mapping logic
powerpc/mm/radix: Remove the retry in the split mapping logic
powerpc/mm/radix: Fix small page at boundary when splitting
powerpc/mm/radix: Fix overuse of small pages in splitting logic
powerpc/mm/radix: Fix off-by-one in split mapping logic
powerpc/ftrace: Handle large kernel configs
powerpc/mm: Fix WARN_ON with THP NUMA migration
powerpc/time: no steal_time when CONFIG_PPC_SPLPAR is not selected
powerpc/time: Only set CONFIG_ARCH_HAS_SCALED_CPUTIME on PPC64
powerpc/time: isolate scaled cputime accounting in dedicated functions.
Pull more block layer updates from Jens Axboe:
- Set of patches improving support for zoned devices. This was ready
before the merge window, but I was late in picking it up and hence it
missed the original pull request (Damien, Christoph)
- libata no link power management quirk addition for a Samsung drive
(Diego Viola)
- Fix for a performance regression in BFQ that went into this merge
window (Federico Motta)
- Fix for a missing dma mask setting return value check (Gustavo)
- Typo in the gdrom queue failure case (me)
- NULL pointer deref fix for xen-blkfront (Vasilis Liaskovitis)
- Fixing the get_rq trace point placement in blk-mq (Xiaoguang Wang)
- Removal of a set-but-not-read variable in cdrom (zhong jiang)
* tag 'for-linus-20181026' of git://git.kernel.dk/linux-block:
libata: Apply NOLPM quirk for SAMSUNG MZ7TD256HAFV-000L9
block, bfq: fix asymmetric scenarios detection
gdrom: fix mistake in assignment of error
blk-mq: place trace_block_getrq() in correct place
block: Introduce blk_revalidate_disk_zones()
block: add a report_zones method
block: Expose queue nr_zones in sysfs
block: Improve zone reset execution
block: Introduce BLKGETNRZONES ioctl
block: Introduce BLKGETZONESZ ioctl
block: Limit allocation of zone descriptors for report zones
block: Introduce blkdev_nr_zones() helper
scsi: sd_zbc: Fix sd_zbc_check_zones() error checks
scsi: sd_zbc: Reduce boot device scan and revalidate time
scsi: sd_zbc: Rearrange code
cdrom: remove set but not used variable 'tocuse'
skd: fix unchecked return values
xen/blkfront: avoid NULL blkfront_info dereference on device removal
git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6
Pull crypto updates from Herbert Xu:
"API:
- Remove VLA usage
- Add cryptostat user-space interface
- Add notifier for new crypto algorithms
Algorithms:
- Add OFB mode
- Remove speck
Drivers:
- Remove x86/sha*-mb as they are buggy
- Remove pcbc(aes) from x86/aesni
- Improve performance of arm/ghash-ce by up to 85%
- Implement CTS-CBC in arm64/aes-blk, faster by up to 50%
- Remove PMULL based arm64/crc32 driver
- Use PMULL in arm64/crct10dif
- Add aes-ctr support in s5p-sss
- Add caam/qi2 driver
Others:
- Pick better transform if one becomes available in crc-t10dif"
* 'linus' of git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (124 commits)
crypto: chelsio - Update ntx queue received from cxgb4
crypto: ccree - avoid implicit enum conversion
crypto: caam - add SPDX license identifier to all files
crypto: caam/qi - simplify CGR allocation, freeing
crypto: mxs-dcp - make symbols 'sha1_null_hash' and 'sha256_null_hash' static
crypto: arm64/aes-blk - ensure XTS mask is always loaded
crypto: testmgr - fix sizeof() on COMP_BUF_SIZE
crypto: chtls - remove set but not used variable 'csk'
crypto: axis - fix platform_no_drv_owner.cocci warnings
crypto: x86/aes-ni - fix build error following fpu template removal
crypto: arm64/aes - fix handling sub-block CTS-CBC inputs
crypto: caam/qi2 - avoid double export
crypto: mxs-dcp - Fix AES issues
crypto: mxs-dcp - Fix SHA null hashes and output length
crypto: mxs-dcp - Implement sha import/export
crypto: aegis/generic - fix for big endian systems
crypto: morus/generic - fix for big endian systems
crypto: lrw - fix rebase error after out of bounds fix
crypto: cavium/nitrox - use pci_alloc_irq_vectors() while enabling MSI-X.
crypto: cavium/nitrox - NITROX command queue changes.
Drivers exposing zoned block devices have to initialize and maintain
correctness (i.e. revalidate) of the device zone bitmaps attached to
the device request queue (seq_zones_bitmap and seq_zones_wlock).
To simplify coding this, introduce a generic helper function
blk_revalidate_disk_zones() suitable for most (and likely all) cases.
This new function always update the seq_zones_bitmap and seq_zones_wlock
bitmaps as well as the queue nr_zones field when called for a disk
using a request based queue. For a disk using a BIO based queue, only
the number of zones is updated since these queues do not have
schedulers and so do not need the zone bitmaps.
With this change, the zone bitmap initialization code in sd_zbc.c can be
replaced with a call to this function in sd_zbc_read_zones(), which is
called from the disk revalidate block operation method.
A call to blk_revalidate_disk_zones() is also added to the null_blk
driver for devices created with the zoned mode enabled.
Finally, to ensure that zoned devices created with dm-linear or
dm-flakey expose the correct number of zones through sysfs, a call to
blk_revalidate_disk_zones() is added to dm_table_set_restrictions().
The zone bitmaps allocated and initialized with
blk_revalidate_disk_zones() are freed automatically from
__blk_release_queue() using the block internal function
blk_queue_free_zone_bitmaps().
Reviewed-by: Hannes Reinecke <hare@suse.com>
Reviewed-by: Martin K. Petersen <martin.petersen@oracle.com>
Reviewed-by: Mike Snitzer <snitzer@redhat.com>
Signed-off-by: Damien Le Moal <damien.lemoal@wdc.com>
Dispatching a report zones command through the request queue is a major
pain due to the command reply payload rewriting necessary. Given that
blkdev_report_zones() is executing everything synchronously, implement
report zones as a block device file operation instead, allowing major
simplification of the code in many places.
sd, null-blk, dm-linear and dm-flakey being the only block device
drivers supporting exposing zoned block devices, these drivers are
modified to provide the device side implementation of the
report_zones() block device file operation.
For device mappers, a new report_zones() target type operation is
defined so that the upper block layer calls blkdev_report_zones() can
be propagated down to the underlying devices of the dm targets.
Implementation for this new operation is added to the dm-linear and
dm-flakey targets.
[Damien]
* Changed method block_device argument to gendisk
* Various bug fixes and improvements
* Added support for null_blk, dm-linear and dm-flakey.
Check return values of dma_set_mask_and_coherent().
Otherwise, if dma_set_mask_and_coherent(&pdev->dev, DMA_BIT_MASK(64));
fails, the following piece of code will be executed even when the call
to dma_set_mask_and_coherent(&pdev->dev, DMA_BIT_MASK(32)); returns 0:
dev_err(&pdev->dev, "DMA mask error %d\n", rc);
goto err_out_regions;
Addresses-Coverity-ID: 1474553 ("Unchecked return value")
Fixes: 138126214868 ("skd: switch to the generic DMA API")
Signed-off-by: Gustavo A. R. Silva <gustavo@embeddedor.com>
If a block device is hot-added when we are out of grants,
gnttab_grant_foreign_access fails with -ENOSPC (log message "28
granting access to ring page") in this code path:
talk_to_blkback ->
setup_blkring ->
xenbus_grant_ring ->
and the failing path in talk_to_blkback sets the driver_data to NULL:
destroy_blkring:
blkif_free(info, 0);
mutex_lock(&blkfront_mutex);
free_info(info);
mutex_unlock(&blkfront_mutex);
dev_set_drvdata(&dev->dev, NULL);
This results in a NULL pointer BUG when blkfront_remove and blkif_free
try to access the failing device's NULL struct blkfront_info.
Cc: stable@vger.kernel.org # 4.5 and later
Signed-off-by: Vasilis Liaskovitis <vliaskovitis@suse.com>
Reviewed-by: Roger Pau Monné <roger.pau@citrix.com>
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci
Pull PCI updates from Bjorn Helgaas:
- Fix ASPM link_state teardown on removal (Lukas Wunner)
- Fix misleading _OSC ASPM message (Sinan Kaya)
- Make _OSC optional for PCI (Sinan Kaya)
- Don't initialize ASPM link state when ACPI_FADT_NO_ASPM is set
(Patrick Talbert)
- Remove x86 and arm64 node-local allocation for host bridge structures
(Punit Agrawal)
- Pay attention to device-specific _PXM node values (Jonathan Cameron)
- Support new Immediate Readiness bit (Felipe Balbi)
- Differentiate between pciehp surprise and safe removal (Lukas Wunner)
- Remove unnecessary pciehp includes (Lukas Wunner)
- Drop pciehp hotplug_slot_ops wrappers (Lukas Wunner)
- Tolerate PCIe Slot Presence Detect being hardwired to zero to
workaround broken hardware, e.g., the Wilocity switch/wireless device
(Lukas Wunner)
- Unify pciehp controller & slot structs (Lukas Wunner)
- Constify hotplug_slot_ops (Lukas Wunner)
- Drop hotplug_slot_info (Lukas Wunner)
- Embed hotplug_slot struct into users instead of allocating it
separately (Lukas Wunner)
- Initialize PCIe port service drivers directly instead of relying on
initcall ordering (Keith Busch)
- Restore PCI config state after a slot reset (Keith Busch)
- Save/restore DPC config state along with other PCI config state
(Keith Busch)
- Reference count devices during AER handling to avoid race issue with
concurrent hot removal (Keith Busch)
- If an Upstream Port reports ERR_FATAL, don't try to read the Port's
config space because it is probably unreachable (Keith Busch)
- During error handling, use slot-specific reset instead of secondary
bus reset to avoid link up/down issues on hotplug ports (Keith Busch)
- Restore previous AER/DPC handling that does not remove and
re-enumerate devices on ERR_FATAL (Keith Busch)
- Notify all drivers that may be affected by error recovery resets
(Keith Busch)
- Always generate error recovery uevents, even if a driver doesn't have
error callbacks (Keith Busch)
- Make PCIe link active reporting detection generic (Keith Busch)
- Support D3cold in PCIe hierarchies during system sleep and runtime,
including hotplug and Thunderbolt ports (Mika Westerberg)
- Handle hpmemsize/hpiosize kernel parameters uniformly, whether slots
are empty or occupied (Jon Derrick)
- Remove duplicated include from pci/pcie/err.c and unused variable
from cpqphp (YueHaibing)
- Remove driver pci_cleanup_aer_uncorrect_error_status() calls (Oza
Pawandeep)
- Uninline PCI bus accessors for better ftracing (Keith Busch)
- Remove unused AER Root Port .error_resume method (Keith Busch)
- Use kfifo in AER instead of a local version (Keith Busch)
- Use threaded IRQ in AER bottom half (Keith Busch)
- Use managed resources in AER core (Keith Busch)
- Reuse pcie_port_find_device() for AER injection (Keith Busch)
- Abstract AER interrupt handling to disconnect error injection (Keith
Busch)
- Refactor AER injection callbacks to simplify future improvments
(Keith Busch)
- Remove unused Netronome NFP32xx Device IDs (Jakub Kicinski)
- Use bitmap_zalloc() for dma_alias_mask (Andy Shevchenko)
- Add switch fall-through annotations (Gustavo A. R. Silva)
- Remove unused Switchtec quirk variable (Joshua Abraham)
- Fix pci.c kernel-doc warning (Randy Dunlap)
- Remove trivial PCI wrappers for DMA APIs (Christoph Hellwig)
- Add Intel GPU device IDs to spurious interrupt quirk (Bin Meng)
- Run Switchtec DMA aliasing quirk only on NTB endpoints to avoid
useless dmesg errors (Logan Gunthorpe)
- Update Switchtec NTB documentation (Wesley Yung)
- Remove redundant "default n" from Kconfig (Bartlomiej Zolnierkiewicz)
- Avoid panic when drivers enable MSI/MSI-X twice (Tonghao Zhang)
- Add PCI support for peer-to-peer DMA (Logan Gunthorpe)
- Add sysfs group for PCI peer-to-peer memory statistics (Logan
Gunthorpe)
- Add PCI peer-to-peer DMA scatterlist mapping interface (Logan
Gunthorpe)
- Add PCI configfs/sysfs helpers for use by peer-to-peer users (Logan
Gunthorpe)
- Add PCI peer-to-peer DMA driver writer's documentation (Logan
Gunthorpe)
- Add block layer flag to indicate driver support for PCI peer-to-peer
- Map Infiniband scatterlists for peer-to-peer DMA if they contain P2P
memory (Logan Gunthorpe)
- Register nvme-pci CMB buffer as PCI peer-to-peer memory (Logan
Gunthorpe)
- Add nvme-pci support for PCI peer-to-peer memory in requests (Logan
Gunthorpe)
- Use PCI peer-to-peer memory in nvme (Stephen Bates, Steve Wise,
Christoph Hellwig, Logan Gunthorpe)
- Cache VF config space size to optimize enumeration of many VFs
(KarimAllah Ahmed)
- Remove unnecessary <linux/pci-ats.h> include (Bjorn Helgaas)
- Fix VMD AERSID quirk Device ID matching (Jon Derrick)
- Fix Cadence PHY handling during probe (Alan Douglas)
- Signal Cadence Endpoint interrupts via AXI region 0 instead of last
region (Alan Douglas)
- Write Cadence Endpoint MSI interrupts with 32 bits of data (Alan
Douglas)
- Remove redundant controller tests for "device_type == pci" (Rob
Herring)
- Document R-Car E3 (R8A77990) bindings (Tho Vu)
- Add device tree support for R-Car r8a7744 (Biju Das)
- Drop unused mvebu PCIe capability code (Thomas Petazzoni)
- Add shared PCI bridge emulation code (Thomas Petazzoni)
- Convert mvebu to use shared PCI bridge emulation (Thomas Petazzoni)
- Add aardvark Root Port emulation (Thomas Petazzoni)
- Support 100MHz/200MHz refclocks for i.MX6 (Lucas Stach)
- Add initial power management for i.MX7 (Leonard Crestez)
- Add PME_Turn_Off support for i.MX7 (Leonard Crestez)
- Fix qcom runtime power management error handling (Bjorn Andersson)
- Update TI dra7xx unaligned access errata workaround for host mode as
well as endpoint mode (Vignesh R)
- Fix kirin section mismatch warning (Nathan Chancellor)
- Remove iproc PAXC slot check to allow VF support (Jitendra Bhivare)
- Quirk Keystone K2G to limit MRRS to 256 (Kishon Vijay Abraham I)
- Update Keystone to use MRRS quirk for host bridge instead of open
coding (Kishon Vijay Abraham I)
- Refactor Keystone link establishment (Kishon Vijay Abraham I)
- Simplify and speed up Keystone link training (Kishon Vijay Abraham I)
- Remove unused Keystone host_init argument (Kishon Vijay Abraham I)
- Merge Keystone driver files into one (Kishon Vijay Abraham I)
- Remove redundant Keystone platform_set_drvdata() (Kishon Vijay
Abraham I)
- Rename Keystone functions for uniformity (Kishon Vijay Abraham I)
- Add Keystone device control module DT binding (Kishon Vijay Abraham
I)
- Use SYSCON API to get Keystone control module device IDs (Kishon
Vijay Abraham I)
- Clean up Keystone PHY handling (Kishon Vijay Abraham I)
- Use runtime PM APIs to enable Keystone clock (Kishon Vijay Abraham I)
- Clean up Keystone config space access checks (Kishon Vijay Abraham I)
- Get Keystone outbound window count from DT (Kishon Vijay Abraham I)
- Clean up Keystone outbound window configuration (Kishon Vijay Abraham
I)
- Clean up Keystone DBI setup (Kishon Vijay Abraham I)
- Clean up Keystone ks_pcie_link_up() (Kishon Vijay Abraham I)
- Fix Keystone IRQ status checking (Kishon Vijay Abraham I)
- Add debug messages for all Keystone errors (Kishon Vijay Abraham I)
- Clean up Keystone includes and macros (Kishon Vijay Abraham I)
- Fix Mediatek unchecked return value from devm_pci_remap_iospace()
- Fix Mediatek endpoint/port matching logic (Honghui Zhang)
- Change Mediatek Root Port Class Code to PCI_CLASS_BRIDGE_PCI (Honghui
Zhang)
- Remove redundant Mediatek PM domain check (Honghui Zhang)
- Convert Mediatek to pci_host_probe() (Honghui Zhang)
- Fix Mediatek MSI enablement (Honghui Zhang)
- Add Mediatek system PM support for MT2712 and MT7622 (Honghui Zhang)
- Add Mediatek loadable module support (Honghui Zhang)
- Detach VMD resources after stopping root bus to prevent orphan
resources (Jon Derrick)
- Convert pcitest build process to that used by other tools (iio, perf,
etc) (Gustavo Pimentel)
* tag 'pci-v4.20-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (140 commits)
PCI/AER: Refactor error injection fallbacks
PCI/AER: Abstract AER interrupt handling
PCI/AER: Reuse existing pcie_port_find_device() interface
PCI/AER: Use managed resource allocations
PCI: pcie: Remove redundant 'default n' from Kconfig
PCI: aardvark: Implement emulated root PCI bridge config space
PCI: mvebu: Convert to PCI emulated bridge config space
PCI: mvebu: Drop unused PCI express capability code
PCI: Introduce PCI bridge emulated config space common logic
PCI: vmd: Detach resources after stopping root bus
nvmet: Optionally use PCI P2P memory
nvmet: Introduce helper functions to allocate and free request SGLs
nvme-pci: Add support for P2P memory in requests
nvme-pci: Use PCI p2pmem subsystem to manage the CMB
IB/core: Ensure we map P2P memory correctly in rdma_rw_ctx_[init|destroy]()
block: Add PCI P2P flag for request queue
PCI/P2PDMA: Add P2P DMA driver writer's documentation
docs-rst: Add a new directory for PCI documentation
PCI/P2PDMA: Introduce configfs/sysfs enable attribute helpers
PCI/P2PDMA: Add PCI p2pmem DMA mappings to adjust the bus offset
In the iov_iter struct, separate the iterator type from the iterator
direction and use accessor functions to access them in most places.
Convert a bunch of places to use switch-statements to access them rather
then chains of bitwise-AND statements. This makes it easier to add further
iterator types. Also, this can be more efficient as to implement a switch
of small contiguous integers, the compiler can use ~50% fewer compare
instructions than it has to use bitwise-and instructions.
Further, cease passing the iterator type into the iterator setup function.
The iterator function can set that itself. Only the direction is required.
Pull block layer updates from Jens Axboe:
"This is the main pull request for block changes for 4.20. This
contains:
- Series enabling runtime PM for blk-mq (Bart).
- Two pull requests from Christoph for NVMe, with items such as;
- Better AEN tracking
- Multipath improvements
- RDMA fixes
- Rework of FC for target removal
- Fixes for issues identified by static checkers
- Fabric cleanups, as prep for TCP transport
- Various cleanups and bug fixes
- Block merging cleanups (Christoph)
- Conversion of drivers to generic DMA mapping API (Christoph)
- Series fixing ref count issues with blkcg (Dennis)
- Series improving BFQ heuristics (Paolo, et al)
- Series improving heuristics for the Kyber IO scheduler (Omar)
- Removal of dangerous bio_rewind_iter() API (Ming)
- Apply single queue IPI redirection logic to blk-mq (Ming)
- Set of fixes and improvements for bcache (Coly et al)
- Series closing a hotplug race with sysfs group attributes (Hannes)
- Set of patches for lightnvm:
- pblk trace support (Hans)
- SPDX license header update (Javier)
- Tons of refactoring patches to cleanly abstract the 1.2 and 2.0
specs behind a common core interface. (Javier, Matias)
- Enable pblk to use a common interface to retrieve chunk metadata
(Matias)
- Bug fixes (Various)
- Set of fixes and updates to the blk IO latency target (Josef)
- blk-mq queue number updates fixes (Jianchao)
- Convert a bunch of drivers from the old legacy IO interface to
blk-mq. This will conclude with the removal of the legacy IO
interface itself in 4.21, with the rest of the drivers (me, Omar)
- Removal of the DAC960 driver. The SCSI tree will introduce two
replacement drivers for this (Hannes)"
* tag 'for-4.20/block-20181021' of git://git.kernel.dk/linux-block: (204 commits)
block: setup bounce bio_sets properly
blkcg: reassociate bios when make_request() is called recursively
blkcg: fix edge case for blk_get_rl() under memory pressure
nvme-fabrics: move controller options matching to fabrics
nvme-rdma: always have a valid trsvcid
mtip32xx: fully switch to the generic DMA API
rsxx: switch to the generic DMA API
umem: switch to the generic DMA API
sx8: switch to the generic DMA API
sx8: remove dead IF_64BIT_DMA_IS_POSSIBLE code
ubd: remove use of blk_rq_map_sg
nvme-pci: remove duplicate check
drivers/block: Remove DAC960 driver
nvme-pci: fix hot removal during error handling
nvmet-fcloop: suppress a compiler warning
nvme-core: make implicit seed truncation explicit
nvmet-fc: fix kernel-doc headers
nvme-fc: rework the request initialization code
nvme-fc: introduce struct nvme_fcp_op_w_sgl
The current requirement is that ceph_osdc_alloc_messages() should be
called after oid and oloc are known. In preparation for preallocating
message data items, move ceph_osdc_alloc_messages() further down, so
that it is called when OSD op codes are known.
