This is the 4.9.220 stable release
arch/arm/Kconfig.debug
arch/arm/boot/dts/imx7s.dtsi
arch/arm/mach-imx/common.h
arch/arm/mach-imx/cpuidle-imx6q.c
arch/arm/mach-imx/cpuidle-imx6sx.c
arch/arm/mach-imx/suspend-imx6.S
block/blk-core.c
drivers/crypto/caam/caamalg.c
drivers/crypto/mxs-dcp.c
drivers/dma/imx-sdma.c
drivers/gpu/drm/bridge/adv7511/adv7511_drv.c
drivers/input/keyboard/imx_keypad.c
drivers/input/keyboard/snvs_pwrkey.c
drivers/mmc/host/sdhci.c
drivers/net/can/flexcan.c
drivers/net/ethernet/freescale/fec_main.c
drivers/net/phy/phy_device.c
drivers/net/wireless/ath/ath10k/pci.c
drivers/tty/serial/imx.c
drivers/usb/dwc3/gadget.c
drivers/usb/host/xhci.c
include/linux/blkdev.h
include/linux/cpu.h
include/linux/platform_data/dma-imx-sdma.h
kernel/cpu.c
net/wireless/util.c
sound/soc/fsl/Kconfig
sound/soc/fsl/fsl_esai.c
sound/soc/fsl/fsl_sai.c
sound/soc/fsl/imx-sgtl5000.c
commit f5f6b95c72f7f8bb46eace8c5306c752d0133daa upstream.
Since nobody else is going to restart our hw_queue for us, the
blk_mq_start_stopped_hw_queues() is in virtblk_done() is not sufficient
necessarily sufficient to ensure that the queue will get started again.
In case of global resource outage (-ENOMEM because mapping failure,
because of swiotlb full) our virtqueue may be empty and we can get
stuck with a stopped hw_queue.
Let us not stop the queue on arbitrary errors, but only on -EONSPC which
indicates a full virtqueue, where the hw_queue is guaranteed to get
started by virtblk_done() before when it makes sense to carry on
submitting requests. Let us also remove a stale comment.
Signed-off-by: Halil Pasic <pasic@linux.ibm.com>
Fixes: f7728002c1c7 ("virtio_ring: fix return code on DMA mapping fails")
Link: https://lore.kernel.org/r/20200213123728.61216-2-pasic@linux.ibm.com
Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
Reviewed-by: Stefan Hajnoczi <stefanha@redhat.com>
commit 2e90ca68b0d2f5548804f22f0dd61145516171e3 upstream.
Jordy Zomer reported a KASAN out-of-bounds read in the floppy driver in
wait_til_ready().
Which on the face of it can't happen, since as Willy Tarreau points out,
the function does no particular memory access. Except through the FDCS
macro, which just indexes a static allocation through teh current fdc,
which is always checked against N_FDC.
Except the checking happens after we've already assigned the value.
The floppy driver is a disgrace (a lot of it going back to my original
horrd "design"), and has no real maintainer. Nobody has the hardware,
and nobody really cares. But it still gets used in virtual environment
because it's one of those things that everybody supports.
The whole thing should be re-written, or at least parts of it should be
seriously cleaned up. The 'current fdc' index, which is used by the
FDCS macro, and which is often shadowed by a local 'fdc' variable, is a
prime example of how not to write code.
But because nobody has the hardware or the motivation, let's just fix up
the immediate problem with a nasty band-aid: test the fdc index before
actually assigning it to the static 'fdc' variable.
Reported-by: Jordy Zomer <jordy@simplyhacker.com>
Cc: Willy Tarreau <w@1wt.eu>
Cc: Dan Carpenter <dan.carpenter@oracle.com>
[ Upstream commit c8ab422553c81a0eb070329c63725df1cd1425bc ]
In brd_init func, rd_nr num of brd_device are firstly allocated
and add in brd_devices, then brd_devices are traversed to add each
brd_device by calling add_disk func. When allocating brd_device,
the disk->first_minor is set to i * max_part, if rd_nr * max_part
is larger than MINORMASK, two different brd_device may have the same
devt, then only one of them can be successfully added.
when rmmod brd.ko, it will cause oops when calling brd_exit.
Follow those steps:
# modprobe brd rd_nr=3 rd_size=102400 max_part=1048576
# rmmod brd
then, the oops will appear.
Oops log:
[ 726.613722] Call trace:
[ 726.614175] kernfs_find_ns+0x24/0x130
[ 726.614852] kernfs_find_and_get_ns+0x44/0x68
[ 726.615749] sysfs_remove_group+0x38/0xb0
[ 726.616520] blk_trace_remove_sysfs+0x1c/0x28
[ 726.617320] blk_unregister_queue+0x98/0x100
[ 726.618105] del_gendisk+0x144/0x2b8
[ 726.618759] brd_exit+0x68/0x560 [brd]
[ 726.619501] __arm64_sys_delete_module+0x19c/0x2a0
[ 726.620384] el0_svc_common+0x78/0x130
[ 726.621057] el0_svc_handler+0x38/0x78
[ 726.621738] el0_svc+0x8/0xc
[ 726.622259] Code: aa0203f6 aa0103f7 aa1e03e0 d503201f (7940e260)
Here, we add brd_check_and_reset_par func to check and limit max_part par.
V5->V6:
- remove useless code
V4->V5:(suggested by Ming Lei)
- make sure max_part is not larger than DISK_MAX_PARTS
V3->V4:(suggested by Ming Lei)
- remove useless change
- add one limit of max_part
V2->V3: (suggested by Ming Lei)
- clear .minors when running out of consecutive minor space in brd_alloc
- remove limit of rd_nr
V1->V2:
- add more checks in brd_check_par_valid as suggested by Ming Lei.
Signed-off-by: Zhiqiang Liu <liuzhiqiang26@huawei.com>
Reviewed-by: Bob Liu <bob.liu@oracle.com>
Reviewed-by: Ming Lei <ming.lei@redhat.com>
[ Upstream commit 33da8e7c814f77310250bb54a9db36a44c5de784 ]
My recent to change to only use force_sig for a synchronous events
wound up breaking signal reception cifs and drbd. I had overlooked
the fact that by default kthreads start out with all signals set to
SIG_IGN. So a change I thought was safe turned out to have made it
impossible for those kernel thread to catch their signals.
Reverting the work on force_sig is a bad idea because what the code
was doing was very much a misuse of force_sig. As the way force_sig
ultimately allowed the signal to happen was to change the signal
handler to SIG_DFL. Which after the first signal will allow userspace
to send signals to these kernel threads. At least for
wake_ack_receiver in drbd that does not appear actively wrong.
So correct this problem by adding allow_kernel_signal that will allow
signals whose siginfo reports they were sent by the kernel through,
but will not allow userspace generated signals, and update cifs and
drbd to call allow_kernel_signal in an appropriate place so that their
thread can receive this signal.
Fixing things this way ensures that userspace won't be able to send
signals and cause problems, that it is clear which signals the
threads are expecting to receive, and it guarantees that nothing
else in the system will be affected.
This change was partly inspired by similar cifs and drbd patches that
added allow_signal.
Reported-by: ronnie sahlberg <ronniesahlberg@gmail.com>
Reported-by: Christoph Böhmwalder <christoph.boehmwalder@linbit.com>
Tested-by: Christoph Böhmwalder <christoph.boehmwalder@linbit.com>
Cc: Steve French <smfrench@gmail.com>
Cc: Philipp Reisner <philipp.reisner@linbit.com>
Cc: David Laight <David.Laight@ACULAB.COM>
Fixes: 247bc9470b1e ("cifs: fix rmmod regression in cifs.ko caused by force_sig changes")
Fixes: 72abe3bcf091 ("signal/cifs: Fix cifs_put_tcp_session to call send_sig instead of force_sig")
Fixes: fee109901f39 ("signal/drbd: Use send_sig not force_sig")
Fixes: 3cf5d076fb4d ("signal: Remove task parameter from force_sig")
commit 589b72894f53124a39d1bb3c0cecaf9dcabac417 upstream.
Clang warns:
../drivers/block/xen-blkfront.c:1117:4: warning: misleading indentation;
statement is not part of the previous 'if' [-Wmisleading-indentation]
nr_parts = PARTS_PER_DISK;
../drivers/block/xen-blkfront.c:1115:3: note: previous statement is here
if (err)
This is because there is a space at the beginning of this line; remove
it so that the indentation is consistent according to the Linux kernel
coding style and clang no longer warns.
While we are here, the previous line has some trailing whitespace; clean
that up as well.
Fixes: c80a420995e7 ("xen-blkfront: handle Xen major numbers other than XENVBD")
Link: https://github.com/ClangBuiltLinux/linux/issues/791
Signed-off-by: Nathan Chancellor <natechancellor@gmail.com>
Reviewed-by: Juergen Gross <jgross@suse.com>
Acked-by: Roger Pau Monné <roger.pau@citrix.com>
Signed-off-by: Juergen Gross <jgross@suse.com>
[ Upstream commit f9bd84a8a845d82f9b5a081a7ae68c98a11d2e84 ]
For each I/O request, blkback first maps the foreign pages for the
request to its local pages. If an allocation of a local page for the
mapping fails, it should unmap every mapping already made for the
request.
However, blkback's handling mechanism for the allocation failure does
not mark the remaining foreign pages as unmapped. Therefore, the unmap
function merely tries to unmap every valid grant page for the request,
including the pages not mapped due to the allocation failure. On a
system that fails the allocation frequently, this problem leads to
following kernel crash.
[ 372.012538] BUG: unable to handle kernel NULL pointer dereference at 0000000000000001
[ 372.012546] IP: [<ffffffff814071ac>] gnttab_unmap_refs.part.7+0x1c/0x40
[ 372.012557] PGD 16f3e9067 PUD 16426e067 PMD 0
[ 372.012562] Oops: 0002 [#1] SMP
[ 372.012566] Modules linked in: act_police sch_ingress cls_u32
[ 372.012746] Call Trace:
[ 372.012752] [<ffffffff81407204>] gnttab_unmap_refs+0x34/0x40
[ 372.012759] [<ffffffffa0335ae3>] xen_blkbk_unmap+0x83/0x150 [xen_blkback]
[ 372.012802] [<ffffffffa0336c50>] dispatch_rw_block_io+0x970/0x980 [xen_blkback]
Decompressing Linux... Parsing ELF... done.
Booting the kernel.
[ 0.000000] Initializing cgroup subsys cpuset
This commit fixes this problem by marking the grant pages of the given
request that didn't mapped due to the allocation failure as invalid.
Fixes: c6cc142dac52 ("xen-blkback: use balloon pages for all mappings")
Reviewed-by: David Woodhouse <dwmw@amazon.de>
Reviewed-by: Maximilian Heyne <mheyne@amazon.de>
Reviewed-by: Paul Durrant <pdurrant@amazon.co.uk>
Reviewed-by: Roger Pau Monné <roger.pau@citrix.com>
Signed-off-by: SeongJae Park <sjpark@amazon.de>
[ Upstream commit fa2ac657f9783f0891b2935490afe9a7fd29d3fa ]
Objects allocated by xen_blkif_alloc come from the 'blkif_cache' kmem
cache. This cache is destoyed when xen-blkif is unloaded so it is
necessary to wait for the deferred free routine used for such objects to
complete. This necessity was missed in commit 14855954f636 "xen-blkback:
allow module to be cleanly unloaded". This patch fixes the problem by
taking/releasing extra module references in xen_blkif_alloc/free()
respectively.
Signed-off-by: Paul Durrant <pdurrant@amazon.com>
[ Upstream commit dcb77e4b274b8f13ac6482dfb09160cd2fae9a40 ]
The driver misses calling destroy_workqueue in remove like what is done
when probe fails.
Add the missed calls to fix it.
Signed-off-by: Chuhong Yuan <hslester96@gmail.com>
[ Upstream commit 2c38f035117331eb78d0504843c79ea7c7fabf37 ]
print_st_err() is defined with its 4th argument taking an
'enum drbd_state_rv' but its prototype use an int for it.
Fix this by using 'enum drbd_state_rv' in the prototype too.
Signed-off-by: Luc Van Oostenryck <luc.vanoostenryck@gmail.com>
Signed-off-by: Roland Kammerer <roland.kammerer@linbit.com>
Signed-off-by: Lars Ellenberg <lars.ellenberg@linbit.com>
[ Upstream commit f708bd08ecbdc23d03aaedf5b3311ebe44cfdb50 ]
"suspending" IO is overloaded.
It can mean "do not allow new requests" (obviously),
but it also may mean "must not complete pending IO",
for example while the fencing handlers do their arbitration.
When adjusting disk options, we suspend io (disallow new requests), then
wait for the activity-log to become unused (drain all IO completions),
and possibly replace it with a new activity log of different size.
If the other "suspend IO" aspect is active, pending IO completions won't
happen, and we would block forever (unkillable drbdsetup process).
Fix this by skipping the activity log adjustment if the "al-extents"
setting did not change. Also, in case it did change, fail early without
blocking if it looks like we would block forever.
[ Upstream commit fe43ed97bba3b11521abd934b83ed93143470e4f ]
Multiple failure scenario:
a) all good
Connected Primary/Secondary UpToDate/UpToDate
b) lose disk on Primary,
Connected Primary/Secondary Diskless/UpToDate
c) continue to write to the device,
changes only make it to the Secondary storage.
d) lose disk on Secondary,
Connected Primary/Secondary Diskless/Diskless
e) now try to re-attach on Primary
This would have succeeded before, even though that is clearly the
wrong data set to attach to (missing the modifications from c).
Because we only compared our "effective" and the "to-be-attached"
data generation uuid tags if (device->state.conn < C_CONNECTED).
Fix: change that constraint to (device->state.pdsk != D_UP_TO_DATE)
compare the uuids, and reject the attach.
This patch also tries to improve the reverse scenario:
first lose Secondary, then Primary disk,
then try to attach the disk on Secondary.
Before this patch, the attach on the Secondary succeeds, but since commit
drbd: disconnect, if the wrong UUIDs are attached on a connected peer
the Primary will notice unsuitable data, and drop the connection hard.
Though unfortunately at a point in time during the handshake where
we cannot easily abort the attach on the peer without more
refactoring of the handshake.
We now reject any attach to "unsuitable" uuids,
as long as we can see a Primary role,
unless we already have access to "good" data.
[ Upstream commit 94c43a13b8d6e3e0dd77b3536b5e04a84936b762 ]
During handshake, if we are diskless ourselves, we used to accept any size
presented by the peer.
Which could be zero if that peer was just brought up and connected
to us without having a disk attached first, in which case both
peers would just "flip" their volume sizes.
Now, even a diskless node will ignore "zero" sizes
presented by a diskless peer.
Also a currently Diskless Primary will refuse to shrink during handshake:
it may be frozen, and waiting for a "suitable" local disk or peer to
re-appear (on-no-data-accessible suspend-io). If the peer is smaller
than what we used to be, it is not suitable.
The logic for a diskless node during handshake is now supposed to be:
believe the peer, if
- I don't have a current size myself
- we agree on the size anyways
- I do have a current size, am Secondary, and he has the only disk
- I do have a current size, am Primary, and he has the only disk,
which is larger than my current size
[ Upstream commit 8e9c523016cf9983b295e4bc659183d1fa6ef8e0 ]
There are two callers of this function and they both unlock the mutex so
this ends up being a double unlock.
Fixes: 44ed167da748 ("drbd: rcu_read_lock() and rcu_dereference() for tconn->net_conf")
[ Upstream commit 53d0f8dbde89cf6c862c7a62e00c6123e02cba41 ]
The error handling in fd_probe_drives() doesn't clean up at all. Fix it
up in preparation for converting to blk-mq. While we're here, get rid of
the commented out amiga_floppy_remove().
Signed-off-by: Omar Sandoval <osandov@fb.com>
[ Upstream commit fdbe4eeeb1aac219b14f10c0ed31ae5d1123e9b8 ]
Enabling Direct I/O with loop devices helps reducing memory usage by
avoiding double caching. 32 bit applications running on 64 bits systems
are currently not able to request direct I/O because is missing from the
lo_compat_ioctl.
This patch fixes the compatibility issue mentioned above by exporting
LOOP_SET_DIRECT_IO as additional lo_compat_ioctl() entry.
The input argument for this ioctl is a single long converted to a 1-bit
boolean, so compatibility is preserved.
Signed-off-by: Alessio Balsini <balsini@android.com>
commit 52f6f9d74f31078964ca1574f7bb612da7877ac8 upstream.
As sparse points out, these two copy_from_user() should actually be
copy_to_user().
Fixes: 229b53c9bf4e ("take floppy compat ioctls to sodding floppy.c")
Cc: stable@vger.kernel.org
Acked-by: Alexander Popov <alex.popov@linux.com>
Reviewed-by: Mukesh Ojha <mojha@codeaurora.org>
Signed-off-by: Jann Horn <jannh@google.com>
[ Upstream commit ae78ca3cf3d9e9f914bfcd0bc5c389ff18b9c2e0 ]
In read_per_ring_refs(), after 'req' and related memory regions are
allocated, xen_blkif_map() is invoked to map the shared frame, irq, and
etc. However, if this mapping process fails, no cleanup is performed,
leading to memory leaks. To fix this issue, invoke the cleanup before
returning the error.
Reviewed-by: Boris Ostrovsky <boris.ostrovsky@oracle.com>
Signed-off-by: Wenwen Wang <wenwen@cs.uga.edu>
[ Upstream commit 77ce56e2bfaa64127ae5e23ef136c0168b818777 ]
Building with clang and KASAN, we get a warning about an overly large
stack frame on 32-bit architectures:
drivers/block/drbd/drbd_receiver.c:921:31: error: stack frame size of 1280 bytes in function 'conn_connect'
[-Werror,-Wframe-larger-than=]
We already allocate other data dynamically in this function, so
just do the same for the shash descriptor, which makes up most of
this memory.
Link: https://lore.kernel.org/lkml/20190617132440.2721536-1-arnd@arndb.de/
Reviewed-by: Roland Kammerer <roland.kammerer@linbit.com>
[ Upstream commit da99466ac243f15fbba65bd261bfc75ffa1532b6 ]
This fixes a global out-of-bounds read access in the copy_buffer
function of the floppy driver.
The FDDEFPRM ioctl allows one to set the geometry of a disk. The sect
and head fields (unsigned int) of the floppy_drive structure are used to
compute the max_sector (int) in the make_raw_rw_request function. It is
possible to overflow the max_sector. Next, max_sector is passed to the
copy_buffer function and used in one of the memcpy calls.
An unprivileged user could trigger the bug if the device is accessible,
but requires a floppy disk to be inserted.
The patch adds the check for the .sect * .head multiplication for not
overflowing in the set_geometry function.
The bug was found by syzkaller.
Signed-off-by: Denis Efremov <efremov@ispras.ru>
Tested-by: Willy Tarreau <w@1wt.eu>
[ Upstream commit 9b04609b784027968348796a18f601aed9db3789 ]
This fixes the invalid pointer dereference in the drive_name function of
the floppy driver.
The native_format field of the struct floppy_drive_params is used as
floppy_type array index in the drive_name function. Thus, the field
should be checked the same way as the autodetect field.
To trigger the bug, one could use a value out of range and set the drive
parameters with the FDSETDRVPRM ioctl. Next, FDGETDRVTYP ioctl should
be used to call the drive_name. A floppy disk is not required to be
inserted.
CAP_SYS_ADMIN is required to call FDSETDRVPRM.
The patch adds the check for a value of the native_format field to be in
the '0 <= x < ARRAY_SIZE(floppy_type)' range of the floppy_type array
indices.
[ Upstream commit 5635f897ed83fd539df78e98ba69ee91592f9bb8 ]
This fixes a global out-of-bounds read access in the next_valid_format
The values from autodetect field of the struct floppy_drive_params are
used as indices for the floppy_type array in the next_valid_format
function 'floppy_type[DP->autodetect[probed_format]].sect'.
parameters with the FDSETDRVPRM ioctl. A floppy disk is not required to
be inserted.
The patch adds the check for values of the autodetect field to be in the
'0 <= x < ARRAY_SIZE(floppy_type)' range of the floppy_type array indices.
[ Upstream commit f3554aeb991214cbfafd17d55e2bfddb50282e32 ]
This fixes a divide by zero error in the setup_format_params function of
the floppy driver.
Two consecutive ioctls can trigger the bug: The first one should set the
drive geometry with such .sect and .rate values for the F_SECT_PER_TRACK
to become zero. Next, the floppy format operation should be called.
A floppy disk is not required to be inserted. An unprivileged user
could trigger the bug if the device is accessible.
The patch checks F_SECT_PER_TRACK for a non-zero value in the
set_geometry function. The proper check should involve a reasonable
upper limit for the .sect and .rate fields, but it could change the
UAPI.
The patch also checks F_SECT_PER_TRACK in the setup_format_params, and
cancels the formatting operation in case of zero.
[ Upstream commit 229b53c9bf4e1132a4aa6feb9632a7a1f1d08c5c ]
all other drivers recognizing those ioctls are very much *not*
biarch.
[ Upstream commit bf348f9b78d413e75bb079462751a1d86b6de36c ]
When tag_set->nr_maps is 1, the block layer limits the number of hw queues
by nr_cpu_ids. No matter how many hw queues are used by virtio-blk, as it
has (tag_set->nr_maps == 1), it can use at most nr_cpu_ids hw queues.
In addition, specifically for pci scenario, when the 'num-queues' specified
by qemu is more than maxcpus, virtio-blk would not be able to allocate more
than maxcpus vectors in order to have a vector for each queue. As a result,
it falls back into MSI-X with one vector for config and one shared for
queues.
Considering above reasons, this patch limits the number of hw queues used
by virtio-blk by nr_cpu_ids.
Signed-off-by: Dongli Zhang <dongli.zhang@oracle.com>
[ Upstream commit 47b16820c490149c2923e8474048f2c6e7557cab ]
If xace hardware reports a bad version number, the error handling code
in ace_setup() calls put_disk(), followed by queue cleanup. However, since
the disk data structure has the queue pointer set, put_disk() also
cleans and releases the queue. This results in blk_cleanup_queue()
accessing an already released data structure, which in turn may result
in a crash such as the following.
[ 10.681671] BUG: Kernel NULL pointer dereference at 0x00000040
[ 10.681826] Faulting instruction address: 0xc0431480
[ 10.682072] Oops: Kernel access of bad area, sig: 11 [#1]
[ 10.682251] BE PAGE_SIZE=4K PREEMPT Xilinx Virtex440
[ 10.682387] Modules linked in:
[ 10.682528] CPU: 0 PID: 1 Comm: swapper Tainted: G W 5.0.0-rc6-next-20190218+ #2
[ 10.682733] NIP: c0431480 LR: c043147c CTR: c0422ad8
[ 10.682863] REGS: cf82fbe0 TRAP: 0300 Tainted: G W (5.0.0-rc6-next-20190218+)
[ 10.683065] MSR: 00029000 <CE,EE,ME> CR: 22000222 XER: 00000000
[ 10.683236] DEAR: 00000040 ESR: 00000000
[ 10.683236] GPR00: c043147c cf82fc90 cf82ccc0 00000000 00000000 00000000 00000002 00000000
[ 10.683236] GPR08: 00000000 00000000 c04310bc 00000000 22000222 00000000 c0002c54 00000000
[ 10.683236] GPR16: 00000000 00000001 c09aa39c c09021b0 c09021dc 00000007 c0a68c08 00000000
[ 10.683236] GPR24: 00000001 ced6d400 ced6dcf0 c0815d9c 00000000 00000000 00000000 cedf0800
[ 10.684331] NIP [c0431480] blk_mq_run_hw_queue+0x28/0x114
[ 10.684473] LR [c043147c] blk_mq_run_hw_queue+0x24/0x114
[ 10.684602] Call Trace:
[ 10.684671] [cf82fc90] [c043147c] blk_mq_run_hw_queue+0x24/0x114 (unreliable)
[ 10.684854] [cf82fcc0] [c04315bc] blk_mq_run_hw_queues+0x50/0x7c
[ 10.685002] [cf82fce0] [c0422b24] blk_set_queue_dying+0x30/0x68
[ 10.685154] [cf82fcf0] [c0423ec0] blk_cleanup_queue+0x34/0x14c
[ 10.685306] [cf82fd10] [c054d73c] ace_probe+0x3dc/0x508
[ 10.685445] [cf82fd50] [c052d740] platform_drv_probe+0x4c/0xb8
[ 10.685592] [cf82fd70] [c052abb0] really_probe+0x20c/0x32c
[ 10.685728] [cf82fda0] [c052ae58] driver_probe_device+0x68/0x464
[ 10.685877] [cf82fdc0] [c052b500] device_driver_attach+0xb4/0xe4
[ 10.686024] [cf82fde0] [c052b5dc] __driver_attach+0xac/0xfc
[ 10.686161] [cf82fe00] [c0528428] bus_for_each_dev+0x80/0xc0
[ 10.686314] [cf82fe30] [c0529b3c] bus_add_driver+0x144/0x234
[ 10.686457] [cf82fe50] [c052c46c] driver_register+0x88/0x15c
[ 10.686610] [cf82fe60] [c09de288] ace_init+0x4c/0xac
[ 10.686742] [cf82fe80] [c0002730] do_one_initcall+0xac/0x330
[ 10.686888] [cf82fee0] [c09aafd0] kernel_init_freeable+0x34c/0x478
[ 10.687043] [cf82ff30] [c0002c6c] kernel_init+0x18/0x114
[ 10.687188] [cf82ff40] [c000f2f0] ret_from_kernel_thread+0x14/0x1c
[ 10.687349] Instruction dump:
[ 10.687435] 3863ffd4 4bfffd70 9421ffd0 7c0802a6 93c10028 7c9e2378 93e1002c 38810008
[ 10.687637] 7c7f1b78 90010034 4bfffc25 813f008c <81290040> 75290100 4182002c 80810008
[ 10.688056] ---[ end trace 13c9ff51d41b9d40 ]---
Fix the problem by setting the disk queue pointer to NULL before calling
put_disk(). A more comprehensive fix might be to rearrange the code
to check the hardware version before initializing data structures,
but I don't know if this would have undesirable side effects, and
it would increase the complexity of backporting the fix to older kernels.
Fixes: 74489a91dd43a ("Add support for Xilinx SystemACE CompactFlash interface")
Acked-by: Michal Simek <michal.simek@xilinx.com>
This reverts commit 3ae3d167f5ec2c7bb5fcd12b7772cfadc93b2305 which is
commit 310ca162d779efee8a2dc3731439680f3e9c1e86 upstream.
Jan Kara has reported seeing problems with this patch applied, as has
Salvatore Bonaccorso, so let's drop it for now.
Reported-by: Salvatore Bonaccorso <carnil@debian.org>
Reported-by: Jan Kara <jack@suse.cz>
Cc: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp>
This is the 4.9.166 stable release
[ Upstream commit 96d7cb932e826219ec41ac02e5af037ffae6098c ]
floppy_check_events() is supposed to return bit flags to say which
events occured. We should return zero to say that no event flags are
set. Only BIT(0) and BIT(1) are used in the caller. And .check_events
interface also expect to return an unsigned int value.
However, after commit a0c80efe5956, it may return -EINTR (-4u).
Here, both BIT(0) and BIT(1) are cleared. So this patch shouldn't
affect runtime, but it obviously is still worth fixing.
Reviewed-by: Dan Carpenter <dan.carpenter@oracle.com>
Fixes: a0c80efe5956 ("floppy: fix lock_fdc() signal handling")
Signed-off-by: Yufen Yu <yuyufen@huawei.com>
This reverts commit 7d839c10b848aa66ca1290a21ee600bd17c2dcb4 which is
commit 967d1dc144b50ad005e5eecdfadfbcfb399ffff6 upstream.
It does not work properly in the 4.9.y tree and causes more problems
than it fixes, so revert it.
Reported-by: Thomas Lindroth <thomas.lindroth@gmail.com>
This reverts commit 6a8f1d8d701462937ce01a3f2219af5435372af7 which is
commit 0a42e99b58a208839626465af194cfe640ef9493 upstream.
This reverts commit 5d3cf50105d007adc54949e0caeca1e944549723 which is
commit 628bd85947091830a8c4872adfd5ed1d515a9cf2 upstream.
Cc: syzbot <syzbot+c0138741c2290fc5e63f@syzkaller.appspotmail.com>
Cc: Ming Lei <ming.lei@redhat.com>
[ Upstream commit 296dcc40f2f2e402facf7cd26cf3f2c8f4b17d47 ]
When the block device is opened with FMODE_EXCL, ref_count is set to -1.
This value doesn't get reset when the device is closed which means the
device cannot be opened again. Fix this by checking for refcount <= 0
in the release method.
Reported-and-tested-by: Stan Johnson <userm57@yahoo.com>
Fixes: 1da177e4c3f4 ("Linux-2.6.12-rc2")
Cc: linuxppc-dev@lists.ozlabs.org
Signed-off-by: Finn Thain <fthain@telegraphics.com.au>
[ Upstream commit 9848b6ddd8c92305252f94592c5e278574e7a6ac ]
If you try to promote a Secondary while connected to a Primary
and allow-two-primaries is NOT set, we will wait for "ping-timeout"
to give this node a chance to detect a dead primary,
in case the cluster manager noticed faster than we did.
But if we then are *still* connected to a Primary,
we fail (after an additional timeout of ping-timout).
This change skips the spurious second timeout.
Most people won't notice really,
since "ping-timeout" by default is half a second.
But in some installations, ping-timeout may be 10 or 20 seconds or more,
and spuriously delaying the error return becomes annoying.
[ Upstream commit b17b59602b6dcf8f97a7dc7bc489a48388d7063a ]
With "on-no-data-accessible suspend-io", DRBD requires the next attach
or connect to be to the very same data generation uuid tag it lost last.
If we first lost connection to the peer,
then later lost connection to our own disk,
we would usually refuse to re-connect to the peer,
because it presents the wrong data set.
However, if the peer first connects without a disk,
and then attached its disk, we accepted that same wrong data set,
which would be "unexpected" by any user of that DRBD
and cause "undefined results" (read: very likely data corruption).
The fix is to forcefully disconnect as soon as we notice that the peer
attached to the "wrong" dataset.
[ Upstream commit d29e89e34952a9ad02c77109c71a80043544296e ]
So far there was the possibility that we called
genlmsg_new(GFP_NOIO)/mutex_lock() while holding an rcu_read_lock().
This included cases like:
drbd_sync_handshake (acquire the RCU lock)
drbd_asb_recover_1p
drbd_khelper
drbd_bcast_event
genlmsg_new(GFP_NOIO) --> may sleep
drbd_asb_recover_1p
drbd_khelper
notify_helper
drbd_asb_recover_1p
drbd_khelper
notify_helper
mutex_lock --> may sleep
While using GFP_ATOMIC whould have been possible in the first two cases,
the real fix is to narrow the rcu_read_lock.
Reported-by: Jia-Ju Bai <baijiaju1990@163.com>
Reviewed-by: Lars Ellenberg <lars.ellenberg@linbit.com>
[ Upstream commit a11f6ca9aef989b56cd31ff4ee2af4fb31a172ec ]
__vdc_tx_trigger should only loop on EAGAIN a finite
number of times.
See commit adddc32d6fde ("sunvnet: Do not spin in an
infinite loop when vio_ldc_send() returns EAGAIN") for detail.
Signed-off-by: Young Xiao <YangX92@hotmail.com>
commit c8a83a6b54d0ca078de036aafb3f6af58c1dc5eb upstream.
NBD can update block device block size implicitely through
bd_set_size(). Make it explicitely set blocksize with set_blocksize() as
this behavior of bd_set_size() is going away.
CC: Josef Bacik <jbacik@fb.com>
commit e544541b0765c341174613b416d4b074fa7571c2 upstream.
We noticed when trying to do O_DIRECT to an export on the server side
that we were getting requests smaller than the 4k sectorsize of the
device. This is because the client isn't setting the logical and
physical blocksizes properly for the underlying device. Fix this up by
setting the queue blocksizes and then calling bd_set_size.
Signed-off-by: Josef Bacik <jbacik@fb.com>
Signed-off-by: Jens Axboe <axboe@fb.com>
Commit 0a42e99b58a20883 ("loop: Get rid of loop_index_mutex") forgot to
remove mutex_unlock(&loop_ctl_mutex) from loop_control_ioctl() when
replacing loop_index_mutex with loop_ctl_mutex.
Fixes: 0a42e99b58a20883 ("loop: Get rid of loop_index_mutex")
Reported-by: syzbot <syzbot+c0138741c2290fc5e63f@syzkaller.appspotmail.com>
Now that loop_ctl_mutex is global, just get rid of loop_index_mutex as
there is no good reason to keep these two separate and it just
complicates the locking.
__loop_release() has a single call site. Fold it there. This is
currently not a huge win but it will make following replacement of
loop_index_mutex more obvious.
syzbot is reporting NULL pointer dereference [1] which is caused by
race condition between ioctl(loop_fd, LOOP_CLR_FD, 0) versus
ioctl(other_loop_fd, LOOP_SET_FD, loop_fd) due to traversing other
loop devices at loop_validate_file() without holding corresponding
lo->lo_ctl_mutex locks.
Since ioctl() request on loop devices is not frequent operation, we don't
need fine grained locking. Let's use global lock in order to allow safe
traversal at loop_validate_file().
Note that syzbot is also reporting circular locking dependency between
bdev->bd_mutex and lo->lo_ctl_mutex [2] which is caused by calling
blkdev_reread_part() with lock held. This patch does not address it.
[1] https://syzkaller.appspot.com/bug?id=f3cfe26e785d85f9ee259f385515291d21bd80a3
[2] https://syzkaller.appspot.com/bug?id=bf154052f0eea4bc7712499e4569505907d15889
Reported-by: syzbot <syzbot+bf89c128e05dd6c62523@syzkaller.appspotmail.com>
commit 85f5a4d666fd9be73856ed16bb36c5af5b406b29 upstream.
There is a window between when RBD_DEV_FLAG_REMOVING is set and when
the device is removed from rbd_dev_list. During this window, we set
"already" and return 0.
Returning 0 from write(2) can confuse userspace tools because
0 indicates that nothing was written. In particular, "rbd unmap"
will retry the write multiple times a second:
10:28:05.463299 write(4, "0", 1) = 0
10:28:05.463509 write(4, "0", 1) = 0
10:28:05.463720 write(4, "0", 1) = 0
10:28:05.463942 write(4, "0", 1) = 0
10:28:05.464155 write(4, "0", 1) = 0
Signed-off-by: Ilya Dryomov <idryomov@gmail.com>
Tested-by: Dongsheng Yang <dongsheng.yang@easystack.cn>
This is the 4.9.144 stable release
[ Upstream commit de7b75d82f70c5469675b99ad632983c50b6f7e7 ]
LKP recently reported a hang at bootup in the floppy code:
[ 245.678853] INFO: task mount:580 blocked for more than 120 seconds.
[ 245.679906] Tainted: G T 4.19.0-rc6-00172-ga9f38e1 #1
[ 245.680959] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[ 245.682181] mount D 6372 580 1 0x00000004
[ 245.683023] Call Trace:
[ 245.683425] __schedule+0x2df/0x570
[ 245.683975] schedule+0x2d/0x80
[ 245.684476] schedule_timeout+0x19d/0x330
[ 245.685090] ? wait_for_common+0xa5/0x170
[ 245.685735] wait_for_common+0xac/0x170
[ 245.686339] ? do_sched_yield+0x90/0x90
[ 245.686935] wait_for_completion+0x12/0x20
[ 245.687571] __floppy_read_block_0+0xfb/0x150
[ 245.688244] ? floppy_resume+0x40/0x40
[ 245.688844] floppy_revalidate+0x20f/0x240
[ 245.689486] check_disk_change+0x43/0x60
[ 245.690087] floppy_open+0x1ea/0x360
[ 245.690653] __blkdev_get+0xb4/0x4d0
[ 245.691212] ? blkdev_get+0x1db/0x370
[ 245.691777] blkdev_get+0x1f3/0x370
[ 245.692351] ? path_put+0x15/0x20
[ 245.692871] ? lookup_bdev+0x4b/0x90
[ 245.693539] blkdev_get_by_path+0x3d/0x80
[ 245.694165] mount_bdev+0x2a/0x190
[ 245.694695] squashfs_mount+0x10/0x20
[ 245.695271] ? squashfs_alloc_inode+0x30/0x30
[ 245.695960] mount_fs+0xf/0x90
[ 245.696451] vfs_kern_mount+0x43/0x130
[ 245.697036] do_mount+0x187/0xc40
[ 245.697563] ? memdup_user+0x28/0x50
[ 245.698124] ksys_mount+0x60/0xc0
[ 245.698639] sys_mount+0x19/0x20
[ 245.699167] do_int80_syscall_32+0x61/0x130
[ 245.699813] entry_INT80_32+0xc7/0xc7
showing that we never complete that read request. The reason is that
the completion setup is racy - it initializes the completion event
AFTER submitting the IO, which means that the IO could complete
before/during the init. If it does, we are passing garbage to
complete() and we may sleep forever waiting for the event to
occur.
Fixes: 7b7b68bba5ef ("floppy: bail out in open() if drive is not responding to block0 read")
Reviewed-by: Omar Sandoval <osandov@fb.com>
commit fef912bf860e upstream.
commit 98af4d4df889 upstream.
I got a report from Howard Chen that he saw zram and sysfs race(ie,
zram block device file is created but sysfs for it isn't yet)
when he tried to create new zram devices via hotadd knob.
v4.20 kernel fixes it by [1, 2] but it's too large size to merge
into -stable so this patch fixes the problem by registering defualt
group by Greg KH's approach[3].
This patch should be applied to every stable tree [3.16+] currently
existing from kernel.org because the problem was introduced at 2.6.37
by [4].
[1] fef912bf860e, block: genhd: add 'groups' argument to device_add_disk
[2] 98af4d4df889, zram: register default groups with device_add_disk()
[3] http://kroah.com/log/blog/2013/06/26/how-to-create-a-sysfs-file-correctly/
[4] 33863c21e69e9, Staging: zram: Replace ioctls with sysfs interface
Cc: Sergey Senozhatsky <sergey.senozhatsky@gmail.com>
Cc: Hannes Reinecke <hare@suse.com>
Tested-by: Howard Chen <howardsoc@google.com>
Signed-off-by: Minchan Kim <minchan@kernel.org>
commit f92898e7f32e3533bfd95be174044bc349d416ca upstream.
If a block device is hot-added when we are out of grants,
gnttab_grant_foreign_access fails with -ENOSPC (log message "28
granting access to ring page") in this code path:
talk_to_blkback ->
setup_blkring ->
xenbus_grant_ring ->
and the failing path in talk_to_blkback sets the driver_data to NULL:
destroy_blkring:
blkif_free(info, 0);
mutex_lock(&blkfront_mutex);
free_info(info);
mutex_unlock(&blkfront_mutex);
dev_set_drvdata(&dev->dev, NULL);
This results in a NULL pointer BUG when blkfront_remove and blkif_free
try to access the failing device's NULL struct blkfront_info.
Cc: stable@vger.kernel.org # 4.5 and later
Signed-off-by: Vasilis Liaskovitis <vliaskovitis@suse.com>
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
[ Upstream commit 1448a2a5360ae06f25e2edc61ae070dff5c0beb4 ]
If we fail to allocate the request queue for a disk, we still need to
free that disk, not just the previous ones. Additionally, we need to
cleanup the previous request queues.
[ Upstream commit 71327f547ee3a46ec5c39fdbbd268401b2578d0e ]
Move queue allocation next to disk allocation to fix a couple of issues:
- If add_disk() hasn't been called, we should clear disk->queue before
calling put_disk().
- If we fail to allocate a request queue, we still need to put all of
the disks, not just the ones that we allocated queues for.
