commit 667c78afaec0ac500908e191e8f236e9578d7b1f upstream.
Without this, gcc 4.5 won't compile xen-netfront and xen-blkfront, where
this is being used to specify array sizes.
Signed-off-by: Jan Beulich <jbeulich@novell.com>
Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com>
This should pass "buf" to bvec_kunmap_irq() instead of "bv". The api is
like kmap_atomic() instead of kmap().
Acked-by: Geoff Levand <geoff@infradead.org>
Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
Must drop reference taken by blk_make_request().
Signed-off-by: Mike Snitzer <snitzer@redhat.com>
Cc: stable@kernel.org # .35.x
The PKT_CTRL_CMD_STATUS device ioctl retrieves a pointer to a
pktcdvd_device from the global pkt_devs array. The index into this
array is provided directly by the user and is a signed integer, so the
comparison to ensure that it falls within the bounds of this array will
fail when provided with a negative index.
This can be used to read arbitrary kernel memory or cause a crash due to
an invalid pointer dereference. This can be exploited by users with
permission to open /dev/pktcdvd/control (on many distributions, this is
readable by group "cdrom").
Signed-off-by: Dan Rosenberg <dan.j.rosenberg@gmail.com>
[ Rather than add a cast, just make the function take the right type -Linus ]
The "h->scatter_list" is allocated inside a for loop. If any of those
allocations fail, then the rest of the list is uninitialized data. When
we free it we should start from the top and free backwards so that we
don't call kfree() on uninitialized pointers.
Also if the allocation for "h->scatter_list" fails then we would get an
Oops here. I should have noticed this when I send: 4ee69851c "cciss:
handle allocation failure." but I didn't. Sorry about that.
* 'for-linus' of git://git.kernel.dk/linux-2.6-block:
block: Range check cpu in blk_cpu_to_group
scatterlist: prevent invalid free when alloc fails
writeback: Fix lost wake-up shutting down writeback thread
writeback: do not lose wakeup events when forking bdi threads
cciss: fix reporting of max queue depth since init
block: switch s390 tape_block and mg_disk to elevator_change()
block: add function call to switch the IO scheduler from a driver
fs/bio-integrity.c: return -ENOMEM on kmalloc failure
bio-integrity.c: remove dependency on __GFP_NOFAIL
BLOCK: fix bio.bi_rw handling
block: put dev->kobj in blk_register_queue fail path
cciss: handle allocation failure
cfq-iosched: Documentation help for new tunables
cfq-iosched: blktrace print per slice sector stats
cfq-iosched: Implement tunable group_idle
cfq-iosched: Do group share accounting in IOPS when slice_idle=0
cfq-iosched: Do not idle if slice_idle=0
cciss: disable doorbell reset on reset_devices
blkio: Fix return code for mkdir calls
The ioctl path and the scsi tape path were not accounting
for their additions to the queue depth.
Signed-off-by: Stephen M. Cameron <scameron@beardog.cce.hp.com>
git://xenbits.xensource.com/people/ianc/linux-2.6
* 'for-upstream/pvhvm' of git://xenbits.xensource.com/people/ianc/linux-2.6:
xen: pvhvm: make it clearer that XEN_UNPLUG_* define bits in a bitfield
xen: pvhvm: rename xen_emul_unplug=ignore to =unnnecessary
xen: pvhvm: allow user to request no emulated device unplug
Now that we have this API, switch the two in-kernel users to it.
Resolves an oops introduced by commit
1abec4fdbb142e3ccb6ce99832fae42129134a96.
It is not immediately clear what this option causes to become
ignored. The actual meaning is that it is not necessary to unplug the
emulated devices to safely use the PV ones, even if the platform does
not support the unplug protocol. (pressumably the user will only add
this option if they have ensured that their domain configuration is
safe).
I think xen_emul_unplug=unnecessary better captures this.
Signed-off-by: Ian Campbell <ian.campbell@citrix.com>
Acked-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com>
Acked-by: Stefano Stabellini <Stefano.Stabellini@eu.citrix.com>
Return of the bi_rw tests is no longer bool after commit 74450be1. But
results of such tests are stored in bools. This doesn't fit in there
for some compilers (gcc 4.5 here), so either use !! magic to get real
bools or use ulong where the result is assigned somewhere.
Reviewed-by: Jeff Moyer <jmoyer@redhat.com>
If kmalloc() fails then cleanup and return failure (-1).
Acked-by: Stephen M. Cameron <scameron@beardog.cce.hp.com>
The doorbell reset initially appears to work correctly,
the controller resets, comes up, some i/o can even be
done, but on at least some Smart Arrays in some servers,
it eventually causes a subsequent controller lockup due
to some kind of PCIe error, and kdump can end up leaving
the root filesystem in an unbootable state. For this
reason, until the problem is fixed, or at least isolated
to certain hardware enough to be avoided, the doorbell
reset should not be used at all.
The drivers for Xilinx' SystemACE and physically mapped MTDs were missing
prototypes for of_address_to_resource(). This patch adds the necessary
headers.
Signed-off-by: Graeme Smecher <graeme.smecher@mail.mcgill.ca>
* 'next-devicetree' of git://git.secretlab.ca/git/linux-2.6:
mmc_spi: Fix unterminated of_match_table
of/sparc: fix build regression from of_device changes
of/device: Replace struct of_device with struct platform_device
* 'for-2.6.36' of git://git.kernel.dk/linux-2.6-block: (149 commits)
block: make sure that REQ_* types are seen even with CONFIG_BLOCK=n
xen-blkfront: fix missing out label
blkdev: fix blkdev_issue_zeroout return value
block: update request stacking methods to support discards
block: fix missing export of blk_types.h
writeback: fix bad _bh spinlock nesting
drbd: revert "delay probes", feature is being re-implemented differently
drbd: Initialize all members of sync_conf to their defaults [Bugz 315]
drbd: Disable delay probes for the upcomming release
writeback: cleanup bdi_register
writeback: add new tracepoints
writeback: remove unnecessary init_timer call
writeback: optimize periodic bdi thread wakeups
writeback: prevent unnecessary bdi threads wakeups
writeback: move bdi threads exiting logic to the forker thread
writeback: restructure bdi forker loop a little
writeback: move last_active to bdi
writeback: do not remove bdi from bdi_list
writeback: simplify bdi code a little
writeback: do not lose wake-ups in bdi threads
Fixed up pretty trivial conflicts in drivers/block/virtio_blk.c and
drivers/scsi/scsi_error.c as per Jens.
It was a now abandoned attempt to throttle resync bandwidth
based on the delay it causes on the bulk data socket.
It has no userbase yet, and has been disabled by
9173465ccb51c09cc3102a10af93e9f469a0af6f already.
This removes the now unused code.
The basic feature, namely using up "idle" bandwith
of network and disk IO subsystem, with minimal impact
to application IO, is being reimplemented differently.
Signed-off-by: Philipp Reisner <philipp.reisner@linbit.com>
Signed-off-by: Lars Ellenberg <lars.ellenberg@linbit.com>
put_user() may fail, if so return -EFAULT.
Signed-off-by: Kulikov Vasiliy <segooon@gmail.com>
Acked-by: Mike Miller <mike.miller@hp.com>
If there's no feature-barrier key in xenstore, then it means its a fairly
old backend which does uncached in-order writes, which means ORDERED_DRAIN
is appropriate.
When barriers are supported, then use QUEUE_ORDERED_TAG to tell the block
subsystem that it doesn't need to do anything else with the barriers.
Previously we used ORDERED_DRAIN which caused the block subsystem to
drain all pending IO before submitting the barrier, which would be
very expensive.
The struct cont_t is just a set of virtual function pointers.
Use memdup_user when user data is immediately copied into the
allocated region. Some checkpatch cleanups in nearby code.
The semantic patch that makes this change is as follows:
(http://coccinelle.lip6.fr/)
// <smpl>
expression from,to,size,flag;
position p;
identifier l1,l2;
- to = \(kmalloc@p\|kzalloc@p\)(size,flag);
+ to = memdup_user(from,size);
if (
- to==NULL
+ IS_ERR(to)
<+... when != goto l1;
- -ENOMEM
+ PTR_ERR(to)
- if (copy_from_user(to, from, size) != 0) {
- <+... when != goto l2;
- -EFAULT
// </smpl>
Cc: Chirag Kantharia <chirag.kantharia@hp.com>
cciss: cleanup interrupt_not_for_us
In the case of MSI/MSIX interrutps, we don't need to check
if the interrupt is for us, and in the case of the intx interrupt
handler, when checking if the interrupt is for us, we don't need
to check if we're using MSI/MSIX, we know we're not.
cciss: change printks to dev_warn, etc.
cciss: separate cmd_alloc() and cmd_special_alloc()
cmd_alloc() took a parameter which caused it to either allocate
from a pre-allocated pool, or allocate using pci_alloc_consistent.
This parameter is always known at compile time, so this would
be better handled by breaking the function into two functions
and differentiating the cases by function names. Same goes
for cmd_free().
cciss: use consistent variable names
"h", for the hba structure and "c" for the command structures.
and get rid of trivial CCISS_LOCK macro.
cciss: forbid hard reset of 640x boards
The 6402/6404 are two PCI devices -- two Smart Array controllers
-- that fit into one slot. It is possible to reset them independently,
however, they share a battery backed cache module. One of the pair
controls the cache and the 2nd one access the cache through the first
one. If you reset the one controlling the cache, the other one will
not be a happy camper. So we just forbid resetting this conjoined
mess.
cciss: sanitize max commands
Some controllers might try to tell us they support 0 commands
in performant mode. This is a lie told by buggy firmware.
We have to be wary of this lest we try to allocate a negative
number of command blocks, which will be treated as unsigned,
and get an out of memory condition.
cciss: Fix hard reset code.
Smart Array controllers newer than the P600 do not honor the
PCI power state method of resetting the controllers. Instead,
in these cases we can get them to reset via the "doorbell" register.
This escaped notice until we began using "performant" mode because
the fact that the controllers did not reset did not normally
impede subsequent operation, and so things generally appeared to
"work". Once the performant mode code was added, if the controller
does not reset, it remains in performant mode. The code immediately
after the reset presumes the controller is in "simple" mode
(which previously, it had remained in simple mode the whole time).
If the controller remains in performant mode any code which presumes
it is in simple mode will not work. So the reset needs to be fixed.
Unfortunately there are some controllers which cannot be reset by
either method. (eg. p800). We detect these cases by noticing that
the controller seems to remain in performant mode even after a
reset has been attempted. In those cases we ignore the controller,
as any commands outstanding on it will result in stale completions.
To sum up, we try to do a better job of resetting the controller if
"reset_devices" is set, and if it doesn't work, we ignore that
controller.
cciss: factor out cciss_reset_devices()
Rationale for this is that I will also need to use this code
in fixing kdump host reset code prior to having the hba structure.
cciss: factor out cciss_enter_performant_mode
cciss: factor out cciss_wait_for_mode_change_ack()
cciss: make cciss_put_controller_into_performant_mode as __devinit
cciss: cleanup some debug ifdefs
cciss: factor out cciss_p600_dma_prefetch_quirk()
cciss: factor out cciss_enable_scsi_prefetch()
cciss: factor out CISS_signature_present()
cciss: factor out cciss_find_board_params
cciss: fix leak of ioremapped memory
in cciss_pci_init error path.
cciss: factor out cciss_find_cfgtables
cciss: factor out cciss_wait_for_board_ready()
cciss: factor out cciss_find_memory_BAR()
cciss: remove board_id parameter from cciss_interrupt_mode()
cciss: factor out cciss_board_disabled
cciss: factor out cciss_lookup_board_id
around so much.
cciss: save pdev pointer in per hba structure early to avoid passing it around so much.
