cciss needs to call disk_stat_add() for iostat to work.
Signed-off-by: Chris Wright <chrisw@sous-sol.org>
cpqarray needs to call disk_stat_add() for iostat to work.
[SCSI] DAC960: PCI id table fixup
The PCI ID table in the DAC960 driver conflicts with some devices
that use the ipr driver. All ipr adapters that use this chip
have an IBM subvendor ID and all DAC960 adapters that use this
chip have a Mylex subvendor id.
Signed-off-by: Brian King <brking@us.ibm.com>
Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
Add support for new hardware and bumps the version to 3.6.10. It seems
there were several changes introduced including soft_irq. I decided to
bump the major number to reflect these changes. Since we're still
supporting older vendor kernels I need some way differentiate between
kernel versions <=2.6.10 and newer kernels >=2.6.16.
Signed-off-by: Mike Miller <mike.miller@hp.com>
Cc: Jens Axboe <axboe@suse.de>
modprobe -v floppy on a Apple G5 writes incorrect stuff to dmesg:
Floppy drive(s): fd0 is 2.88M
The reason is that the legacy io check happens very late,
when part of the floppy stuff is already initialized.
check_legacy_ioport() returns either -ENODEV right away, or it walks
the device-tree looking for a floppy node.
Signed-off-by: Olaf Hering <olaf@aepfle.de>
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
When reading from nbd device, we need to receive all the data after
receiving reply packet from the server - otherwise such request will never
be ended.
If socket is closed right after accepting reply control packet and in the
middle of waiting for read data, nbd_read_stat() returns NULL and
nbd_end_request() is not called.
This patch fixes it.
Signed-off-by: Michal Feix <michal@feix.cz>
Acked-by: Paul Clements <paul.clements@steeleye.com>
We should check magic sequence in reply packet before trying to find
request with it's request handle. This also solves the problem with
"Unexpected reply" message beeing logged, when packet with invalid magic is
received.
The pkt_*_dev functions operate on not-this-blockdevice, and that is
sufficiently checked at setup time. As a result there is a natural
hierarchy, which needs nesting annotations
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
Cc: Peter Osterlund <petero2@telia.com>
We need to postpone the queue startup until after the softirq
handler has actually finished some requests, otherwise we could
be racing with cciss_softirq_done() and not actually restart
the queue handling.
Signed-off-by: Jens Axboe <axboe@suse.de>
Acked-by: Mike Miller <mike.miller@hp.com>
Make the ramdisk blocksize configurable at kernel compilation time rather
than only at boot or module load time, like a couple of the other ramdisk
options. I found this handy awhile back but thought little of it, until
recently asked by a few of the testing folks here to be able to do the same
thing for their automated test setups.
The Kconfig comment is largely lifted from comments in rd.c, and hopefully
this will increase the chances of making folks aware that the default value
often isn't a great choice here (for increasing values of PAGE_SIZE, even
moreso).
Signed-off-by: Nathan Scott <nathans@sgi.com>
Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de>
* git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc:
powerpc: add defconfig for Freescale MPC8349E-mITX board
powerpc: Add base support for the Freescale MPC8349E-mITX eval board
Documentation: correct values in MPC8548E SEC example node
[POWERPC] Actually copy over i8259.c to arch/ppc/syslib this time
[POWERPC] Add new interrupt mapping core and change platforms to use it
[POWERPC] Copy i8259 code back to arch/ppc
[POWERPC] New device-tree interrupt parsing code
[POWERPC] Use the genirq framework
[PATCH] genirq: Allow fasteoi handler to retrigger disabled interrupts
[POWERPC] Update the SWIM3 (powermac) floppy driver
[POWERPC] Fix error handling in detecting legacy serial ports
[POWERPC] Fix booting on Momentum "Apache" board (a Maple derivative)
[POWERPC] Fix various offb and BootX-related issues
[POWERPC] Add a default config for 32-bit CHRP machines
[POWERPC] fix implicit declaration on cell.
[POWERPC] change get_property to return void *
The lock validator triggered a number of bugs in the floppy driver, all
related to the floppy driver allocating and freeing irq and dma resources from
interrupt context. The initial solution was to use schedule_work() to push
this into process context, but this caused further problems: for example the
current floppy driver in -mm2 is totally broken and all floppy commands time
out with an error. (as reported by Barry K. Nathan)
This patch tries another solution: simply get rid of all that dynamic IRQ and
DMA allocation/freeing. I doubt it made much sense back in the heydays of
floppies (if two devices raced for DMA or IRQ resources then we didnt handle
those cases too gracefully anyway), and today it makes near zero sense.
So the new code does the simplest and most straightforward thing: allocate IRQ
and DMA resources at module init time, and free them at module removal time.
Dont try to release while the driver is operational. This, besides making the
floppy driver functional again has an added bonus, floppy IRQ stats are
finally persistent and visible in /proc/interrupts:
6: 63 XT-PIC-level floppy
Besides normal floppy IO i have also tested IO error handling, motor-off
timeouts, etc. - and everything seems to be working fine.
Port the PowerMac floppy driver (swim3) to use the macio device
infrastructure.
The Network Block Device driver doesn't compile if NDEBUG is defined.
Signed-off-by: Ingo van Lil <inguin@gmx.de>
Signed-off-by: Jörn Engel <joern@wohnheim.fh-wedel.de>
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/devfs-2.6: (22 commits)
[PATCH] devfs: Remove it from the feature_removal.txt file
[PATCH] devfs: Last little devfs cleanups throughout the kernel tree.
[PATCH] devfs: Rename TTY_DRIVER_NO_DEVFS to TTY_DRIVER_DYNAMIC_DEV
[PATCH] devfs: Remove the tty_driver devfs_name field as it's no longer needed
[PATCH] devfs: Remove the line_driver devfs_name field as it's no longer needed
[PATCH] devfs: Remove the videodevice devfs_name field as it's no longer needed
[PATCH] devfs: Remove the gendisk devfs_name field as it's no longer needed
[PATCH] devfs: Remove the miscdevice devfs_name field as it's no longer needed
[PATCH] devfs: Remove the devfs_fs_kernel.h file from the tree
[PATCH] devfs: Remove devfs_remove() function from the kernel tree
[PATCH] devfs: Remove devfs_mk_cdev() function from the kernel tree
[PATCH] devfs: Remove devfs_mk_bdev() function from the kernel tree
[PATCH] devfs: Remove devfs_mk_symlink() function from the kernel tree
[PATCH] devfs: Remove devfs_mk_dir() function from the kernel tree
[PATCH] devfs: Remove devfs_*_tape() functions from the kernel tree
[PATCH] devfs: Remove devfs support from the sound subsystem
[PATCH] devfs: Remove devfs support from the ide subsystem.
[PATCH] devfs: Remove devfs support from the serial subsystem
[PATCH] devfs: Remove devfs from the init code
[PATCH] devfs: Remove devfs from the partition code
* master.kernel.org:/pub/scm/linux/kernel/git/gregkh/pci-2.6:
[PATCH] i386: export memory more than 4G through /proc/iomem
[PATCH] 64bit Resource: finally enable 64bit resource sizes
[PATCH] 64bit Resource: convert a few remaining drivers to use resource_size_t where needed
[PATCH] 64bit resource: change pnp core to use resource_size_t
[PATCH] 64bit resource: change pci core and arch code to use resource_size_t
[PATCH] 64bit resource: change resource core to use resource_size_t
[PATCH] 64bit resource: introduce resource_size_t for the start and end of struct resource
[PATCH] 64bit resource: fix up printks for resources in misc drivers
[PATCH] 64bit resource: fix up printks for resources in arch and core code
[PATCH] 64bit resource: fix up printks for resources in pcmcia drivers
[PATCH] 64bit resource: fix up printks for resources in video drivers
[PATCH] 64bit resource: fix up printks for resources in ide drivers
[PATCH] 64bit resource: fix up printks for resources in mtd drivers
[PATCH] 64bit resource: fix up printks for resources in pci core and hotplug drivers
[PATCH] 64bit resource: fix up printks for resources in networks drivers
[PATCH] 64bit resource: fix up printks for resources in sound drivers
[PATCH] 64bit resource: C99 changes for struct resource declarations
Fixed up trivial conflict in drivers/ide/pci/cmd64x.c (the printk that
was changed by the 64-bit resources had been deleted in the meantime ;)
Another possible dereference detected by coverity (id #759). pf_probe()
might call pf_identify() which might call get_capacity() which dereferences
pf->disk
Same as with already do with the file operations: keep them in .rodata and
prevents people from doing runtime patching.
Cc: Steven French <sfrench@us.ibm.com>
This is needed if we wish to change the size of the resource structures.
Based on an original patch from Vivek Goyal <vgoyal@in.ibm.com>
Cc: Vivek Goyal <vgoyal@in.ibm.com>
Just removes a few unused #defines and fixes some comments due to
devfs now being gone.
And remove the now unneeded number field.
Also fixes all drivers that set these fields.
Also fixes all drivers that set this field.
Also fixes up all files that #include it.
Removes the devfs_remove() function and all callers of it.
Removes the devfs_mk_cdev() function and all callers of it.
Removes the devfs_mk_bdev() function and all callers of it.
Removes the devfs_mk_dir() function and all callers of it.
This reverts commit c7b2eff059fcc2d1b7085ee3d84b79fd657a537b.
Hugh Dickins explains:
"It seems too little tested: "losetup -d /dev/loop0" fails with
EINVAL because nothing sets lo_thread; but even when you patch
loop_thread() to set lo->lo_thread = current, it can't survive
more than a few dozen iterations of the loop below (with a tmpfs
mounted on /tst):
j=0
cp /dev/zero /tst
while :
do
let j=j+1
echo "Doing pass $j"
losetup /dev/loop0 /tst/zero
mkfs -t ext2 -b 1024 /dev/loop0 >/dev/null 2>&1
mount -t ext2 /dev/loop0 /mnt
umount /mnt
done
it collapses with failed ioctl then BUG_ON(!bio).
I think the original lo_done completion was more subtle and safe
than the kthread conversion has allowed for."
Make each one fit on a line so it's easier to read. I re-ordered
COMPAQ_CISSC/0x4091, which was out of order. I double-checked these, but it
would be good if you'd also check them to make sure I didn't miss any.
Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com>
Cc: Jeff Garzik <jeff@garzik.org>
cciss is full of inconsistent style ("for (" vs. "for(", lines that end with
whitespace, lines beginning with a mix of spaces & tabs, etc).
This patch changes only whitespace.
Acked-by: Jeff Garzik <jeff@garzik.org>
Typical Linux style is "return -EINVAL", not "return(-EINVAL)".
Fix a few spelling errors.
It's easier to verify loop bounds if the array name is mentioned the for()
statement that steps through the array.
We already print "cciss: using DAC cycles" or similar for every adapter found:
why not just identify the device we're talking about and include other useful
information?
Jeff Garzik <jeff@garzik.org>:
Although this patch is correct, I would consider using dev_printk() rather
than referencing pci_name() in printk() arguments.
We should call pci_request_regions() to claim all resources the device
decodes. Previously, we claimed only the I/O port range.
If something fails after we call pci_enable_device(), we should call
pci_disable_device() before returning the failure.
Update loop.c to use a kthread instead of a deprecated kernel_thread for
loop devices.
[akpm@osdl.org: don't change the thread's name]
Signed-off-by: Serge E. Hallyn <serue@us.ibm.com>
WARNING: drivers/block/cpqarray.o - Section mismatch: reference to .init.text: from .text between 'cpqarray_register_ctlr' (at offset 0xe98) and 'alloc_cpqarray_hba'
WARNING: drivers/block/cpqarray.o - Section mismatch: reference to .init.text: from .text between 'cpqarray_register_ctlr' (at offset 0xe9c) and 'alloc_cpqarray_hba'
nbd abuses file header as a changelog (and obsolete one, too), and fails to
mention GPL. This fixes it.
Signed-off-by: Pavel Machek <pavel@suse.cz>
Cc: <Paul.Clements@steeleye.com>
Disk devices should use add_disk_randomness rather than SA_SAMPLE_RANDOM
Signed-off-by: Matt Mackall <mpm@selenic.com>
Cc: <mike.miller@hp.com>
Disk devices should use the add_disk_randomness API rather than
SA_SAMPLE_RANDOM.
Introduce irq controller and use it to manage auto vector interrupts.
Introduce setup_irq() which can be used for irq setup.
Signed-off-by: Roman Zippel <zippel@linux-m68k.org>
While writing a version of losetup, I ran into the problem that the loop
device was returning total garbage.
It turns out the problem was that this losetup was only issuing the
LOOP_SET_FD ioctl and not issuing a subsequent LOOP_SET_STATUS ioctl. This
losetup didn't have any special status to set, so it left out the call.
The deeper cause is that loop_set_fd sets the transfer function to NULL,
which causes no transfer to happen lo_do_transfer.
This patch fixes the problem by setting transfer to transfer_none in
loop_set_fd.
The FRV arch doesn't currently support initrd, so it should be disabled
automatically for the moment.
* git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc: (139 commits)
[POWERPC] re-enable OProfile for iSeries, using timer interrupt
[POWERPC] support ibm,extended-*-frequency properties
[POWERPC] Extra sanity check in EEH code
[POWERPC] Dont look for class-code in pci children
[POWERPC] Fix mdelay badness on shared processor partitions
[POWERPC] disable floating point exceptions for init
[POWERPC] Unify ppc syscall tables
[POWERPC] mpic: add support for serial mode interrupts
[POWERPC] pseries: Print PCI slot location code on failure
[POWERPC] spufs: one more fix for 64k pages
[POWERPC] spufs: fail spu_create with invalid flags
[POWERPC] spufs: clear class2 interrupt status before wakeup
[POWERPC] spufs: fix Makefile for "make clean"
[POWERPC] spufs: remove stop_code from struct spu
[POWERPC] spufs: fix spu irq affinity setting
[POWERPC] spufs: further abstract priv1 register access
[POWERPC] spufs: split the Cell BE support into generic and platform dependant parts
[POWERPC] spufs: dont try to access SPE channel 1 count
[POWERPC] spufs: use kzalloc in create_spu
[POWERPC] spufs: fix initial state of wbox file
Manually resolved conflicts in:
drivers/net/phy/Makefile
include/asm-powerpc/spu.h
Remove some silly messages and cast in stone "temporary" messages which
we keep around. Also, I am hesitant to remove the initialization retries
without having the hardware to test (anyone who was at KS04 has a spare?)
Signed-off-by: Pete Zaitcev <zaitcev@yahoo.com>
