path: root/drivers/bluetooth/btmrvl_main.c
2013-06-13Bluetooth: btmrvl: fix thread stopping raceDaniel Drake
There is currently a race condition in the btmrvl_remove_card() which is causing hangs on suspend for OLPC. When the race occurs, kthread_stop() never returns. The problem is that btmrvl_service_main_thread() calls kthread_should_stop() and then does a fair number of things before restarting the loop and sleeping. If the thread gets stopped after kthread_should_stop() is checked, but before the sleep happens, the thread will go to sleep and won't necessarily be woken up. Move the kthread_should_stop() check into a race-free place. Signed-off-by: Daniel Drake <dsd@laptop.org> Signed-off-by: Gustavo Padovan <gustavo.padovan@collabora.co.uk> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-07-09Bluetooth: btmrvl: trivial style fixesAndrei Emeltchenko
Patch shortens locals scope and adds missing braces. This is a diff between v1 which was applied and v2 of patch "Bluetooth: btmrvl: Do not send vendor events to bluetooth stack". Signed-off-by: Andrei Emeltchenko <andrei.emeltchenko@intel.com> Signed-off-by: Gustavo Padovan <gustavo.padovan@collabora.co.uk>
2012-06-19Bluetooth: btmrvl: Do not send vendor events to bluetooth stackAndrei Emeltchenko
Vendor-specific events shall be processed in driver and not sent to bluetooth stack where they screw up HCI command countings. Signed-off-by: Andrei Emeltchenko <andrei.emeltchenko@intel.com> Signed-off-by: Gustavo Padovan <gustavo.padovan@collabora.co.uk>
2012-05-09Bluetooth: btmrvl: add support for SDIO suspend/resume callbacksAmitkumar Karwar
Host sleep is activated using already configured host sleep parameters in suspend handler and it is cancelled in resume handler. Signed-off-by: Amitkumar Karwar <akarwar@marvell.com> Signed-off-by: Bing Zhao <bzhao@marvell.com> Acked-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Gustavo Padovan <gustavo@padovan.org>
2012-05-09Bluetooth: btmrvl: configure default host sleep parametersAmitkumar Karwar
Currently debugfs commands "hscfgcmd" and "gpiogap" are provided for host sleep configuration. But if user doesn't configure host sleep parameters using these commands, host sleep activation is failed during suspend (support for suspend and resume handlers is added in next patch). Default host sleep configuration is done during driver initialisation in this patch. Signed-off-by: Amitkumar Karwar <akarwar@marvell.com> Signed-off-by: Bing Zhao <bzhao@marvell.com> Signed-off-by: Gustavo Padovan <gustavo@padovan.org>
2012-02-13Bluetooth: Remove hci_dev->driver_dataDavid Herrmann
The linux device model provides dev_set/get_drvdata so we can use this to save private driver data. This also removes several unnecessary casts. Signed-off-by: David Herrmann <dh.herrmann@googlemail.com> Acked-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Johan Hedberg <johan.hedberg@intel.com>
2012-02-13Bluetooth: Remove HCI-owner fieldDavid Herrmann
After unregistering an hci_dev object a bluetooth driver does not have any callbacks in the hci_dev structure left over. Therefore, there is no need to keep a reference to the module. Previously, we needed this to protect the hci-destruct callback. However, this callback is no longer available so we do not need this owner field, anymore. Drivers now call hci_unregister_dev() and they are done with the object. Signed-off-by: David Herrmann <dh.herrmann@googlemail.com> Acked-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Johan Hedberg <johan.hedberg@intel.com>
2012-02-13Bluetooth: btmrvl: Remove empty destruct cbDavid Herrmann
The callback is optional and we provide an empty callback so remove it entirely. Signed-off-by: David Herrmann <dh.herrmann@googlemail.com> Acked-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Johan Hedberg <johan.hedberg@intel.com>
2011-11-21freezer: don't unnecessarily set PF_NOFREEZE explicitlyTejun Heo
Some drivers set PF_NOFREEZE in their kthread functions which is completely unnecessary and racy - some part of freezer code doesn't consider cases where PF_NOFREEZE is set asynchronous to freezer operations. In general, there's no reason to allow setting PF_NOFREEZE explicitly. Remove them and change the documentation to note that setting PF_NOFREEZE directly isn't allowed. -v2: Dropped change to twl4030-irq.c as it no longer uses PF_NOFREEZE. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: "Gustavo F. Padovan" <padovan@profusion.mobi> Acked-by: Samuel Ortiz <sameo@linux.intel.com> Cc: Marcel Holtmann <marcel@holtmann.org> Cc: wwang <wei_wang@realsil.com.cn>
2011-10-31bluetooth: add module.h to drivers/bluetooth files as required.Paul Gortmaker
2010-10-12Bluetooth: HCI devices are either BR/EDR or AMP radiosDavid Vrabel
HCI transport drivers may not know what type of radio an AMP device has so only say whether they're BR/EDR or AMP devices. Signed-off-by: David Vrabel <david.vrabel@csr.com> Signed-off-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Gustavo F. Padovan <padovan@profusion.mobi>
2010-07-21Bluetooth: Process interrupt in main thread of btmrvl driver as wellAmitkumar Karwar
When driver is sending a command or data and the firmware is also sending a sleep event, sometimes it is observed that driver will continue to send the command/data to firmware right after processing sleep event. Once sleep event is processed driver is not supposed to send anything because firmware is in sleep state after that. Previously interrupt processing was done in SDIO interrupt callback handler. Now it is done in btmrvl driver main thread to solve the cross-sending properly. Signed-off-by: Amitkumar Karwar <akarwar@marvell.com> Signed-off-by: Bing Zhao <bzhao@marvell.com> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2010-05-10Bluetooth: Set hdev->dev_type based on Marvell device typeBing Zhao
Get the device type from MODULE_BRINGUP_REQ command response. Signed-off-by: Bing Zhao <bzhao@marvell.com> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2010-05-10Bluetooth: Separate btmrvl_register_hdev() from btmrvl_add_card()Bing Zhao
Move btmrvl hdev registration code out of btmrvl_add_card(). New function btmrvl_register_hdev() is added. Signed-off-by: Bing Zhao <bzhao@marvell.com> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2010-05-10Bluetooth: Decode btmrvl MODULE_BRINGUP_REG response correctlyBing Zhao
The MODULE_BRINGUP_REQ command response returns success with either 0x00 or 0x0c. Signed-off-by: Bing Zhao <bzhao@marvell.com> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2010-05-10Bluetooth: Fix storing negative values as unsigned charDan Carpenter
This is mostly cleanup. There is only one caller and it just checks for non-zero return values. Still "ret" should be int because we want to return -EINVAL on errors. Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2010-02-27Bluetooth: Convert controller hdev->type to hdev->busMarcel Holtmann
The hdev->type is misnamed and should be actually hdev->bus instead. So convert it now. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2009-12-03Bluetooth: Enable auto sleep mode for btmrvl driverAmitkumar Karwar
The auto sleep mode for btmrvl driver is not enabled by default. This patch enables auto sleep mode when card is probed. Signed-off-by: Amitkumar Karwar <akarwar@marvell.com> Signed-off-by: Bing Zhao <bzhao@marvell.com> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2009-08-22Bluetooth: Remove Enter/Leave debug statements from Marvell driverMarcel Holtmann
The Marvell Bluetooth driver is full of Enter/Leave debug statements and all of them are really pointless and only clutter the code. Seems to be some left-overs when they ported the driver from Windows. For the Linux driver lets remove these. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2009-08-22Bluetooth: Fix last few compiler warning within Marvell core driverMarcel Holtmann
After fixing the driver to use skb_put properly for their HCI commands only a few compiler warnings are left. Add proper casting for them. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2009-08-22Bluetooth: Fix Marvell driver to use skb_put and hci_opcode_packMarcel Holtmann
The Marvell driver has some weird quirks on how to construct proper SKBs with Bluetooth HCI commands. Fix it to use skb_put properly and also use hci_opcode_pack instead of self-crafted macro. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2009-08-22Bluetooth: Fix module description strings for Marvell driverMarcel Holtmann
Make the module description entries for the core and also the Marvell SDIO driver match common practive inside the Bluetooth subsystem. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2009-08-22Bluetooth: Some coding style cleanup for Marvell core driverMarcel Holtmann
The Marvell core Bluetooth driver has various weird casting and unneeded braces in its code that makes it hard to read. Remove all of these to make the code a little bit simpler. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2009-08-22Bluetooth: Add debugfs support to btmrvl driverBing Zhao
/debug/btmrvl/config/ /debug/btmrvl/status/ See Documentation/btmrvl.txt for details. This patch incorporates a lot of comments given by Nicolas Pitre <nico@marvell.com>. Many thanks to Nicolas Pitre. Signed-off-by: Rahul Tank <rahult@marvell.com> Signed-off-by: Bing Zhao <bzhao@marvell.com> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2009-08-22Bluetooth: Add btmrvl driver for Marvell Bluetooth devicesBing Zhao
This driver provides basic definitions and library functions to support Marvell Bluetooth enabled devices, such as 88W8688 WLAN/BT combo chip. This patch incorporates a lot of comments given by Nicolas Pitre <nico@marvell.com>. Many thanks to Nicolas Pitre. Signed-off-by: Rahul Tank <rahult@marvell.com> Signed-off-by: Bing Zhao <bzhao@marvell.com> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
