path: root/drivers/bluetooth/btuart_cs.c
2013-03-15drivers/bluetooth: use module_pcmcia_driver() in pcmcia driversH Hartley Sweeten
Use the new module_pcmcia_driver() macro to remove the boilerplate module init/exit code in the pcmcia drivers. Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-09-18Bluetooth: btuart_cs.c: removes unnecessary semicolonPeter Senna Tschudin
removes unnecessary semicolon Found by Coccinelle: http://coccinelle.lip6.fr/ Signed-off-by: Peter Senna Tschudin <peter.senna@gmail.com> Acked-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Gustavo Padovan <gustavo.padovan@collabora.co.uk>
2012-08-06Bluetooth: Use devm_kzalloc in btuart_cs.c fileSachin Kamat
devm_kzalloc() eliminates the need to free memory explicitly thereby saving some cleanup code. Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Acked-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Gustavo Padovan <gustavo.padovan@collabora.co.uk>
2012-06-30Bluetooth: Fix warning: using int as NULL pointerAndrei Emeltchenko
Fix for warnings below: ... drivers/bluetooth/bt3c_cs.c:667:20: warning: Using plain integer as NULL pointer drivers/bluetooth/btuart_cs.c:596:20: warning: Using plain integer as NULL pointer ... Signed-off-by: Andrei Emeltchenko <andrei.emeltchenko@intel.com> Signed-off-by: Gustavo Padovan <gustavo.padovan@collabora.co.uk>
2012-06-05Bluetooth: Remove 'register' usage from the subsystemGustavo Padovan
Let the compiler chooses what is best. Signed-off-by: Gustavo Padovan <gustavo.padovan@collabora.co.uk> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2012-03-28Remove all #inclusions of asm/system.hDavid Howells
Remove all #inclusions of asm/system.h preparatory to splitting and killing it. Performed with the following command: perl -p -i -e 's!^#\s*include\s*<asm/system[.]h>.*\n!!' `grep -Irl '^#\s*include\s*<asm/system[.]h>' *` Signed-off-by: David Howells <dhowells@redhat.com>
2012-02-13Bluetooth: Remove hci_dev->driver_dataDavid Herrmann
The linux device model provides dev_set/get_drvdata so we can use this to save private driver data. This also removes several unnecessary casts. Signed-off-by: David Herrmann <dh.herrmann@googlemail.com> Acked-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Johan Hedberg <johan.hedberg@intel.com>
2012-02-13Bluetooth: Remove HCI-owner fieldDavid Herrmann
After unregistering an hci_dev object a bluetooth driver does not have any callbacks in the hci_dev structure left over. Therefore, there is no need to keep a reference to the module. Previously, we needed this to protect the hci-destruct callback. However, this callback is no longer available so we do not need this owner field, anymore. Drivers now call hci_unregister_dev() and they are done with the object. Signed-off-by: David Herrmann <dh.herrmann@googlemail.com> Acked-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Johan Hedberg <johan.hedberg@intel.com>
2012-02-13Bluetooth: btuart-cs: Remove empty destruct cbDavid Herrmann
The destruct callback is optional and we provide an empty callback so remove it. Signed-off-by: David Herrmann <dh.herrmann@googlemail.com> Acked-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Johan Hedberg <johan.hedberg@intel.com>
2011-11-07Bluetooth: Ignore hci_unregister_dev return valueDavid Herrmann
Make all bluetooth drivers ignore the return value of hci_unregister_dev as it always returns 0. In the next step, hci_unregister_dev can be modified to return void. Some of the drivers already ignore the return value (including btusb), hence, this will increase consitency in the bluetooth drivers. Signed-off-by: David Herrmann <dh.herrmann@googlemail.com> Acked-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Gustavo F. Padovan <padovan@profusion.mobi>
2011-05-06pcmcia: Convert pcmcia_device_id declarations to constJoe Perches
Saves about 50KB of data. Old/new size of all objects: text data bss dec hex filename 563015 80096 130684 773795 bcea3 (TOTALS) 610916 32256 130632 773804 bceac (TOTALS) Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Kurt Van Dijck <kurt.van.dijck@eia.be> (for drivers/net/can/softing/softing_cs.c) Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-09-29pcmcia: move driver name to struct pcmcia_driverDominik Brodowski
Tested-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-09-29pcmcia: use autoconfiguration feature for ioports and iomemDominik Brodowski
When CONF_AUTO_SET_IO or CONF_AUTO_SET_IOMEM are set, the corresponding fields in struct pcmcia_device *p_dev->resource[0,1,2] are set accordinly. Drivers wishing to override certain settings may do so in the callback function, but they no longer need to parse the CIS entries stored in cistpl_cftable_entry_t themselves. CC: netdev@vger.kernel.org CC: linux-wireless@vger.kernel.org CC: linux-ide@vger.kernel.org CC: linux-usb@vger.kernel.org CC: laforge@gnumonks.org CC: linux-mtd@lists.infradead.org CC: linux-bluetooth@vger.kernel.org CC: alsa-devel@alsa-project.org CC: linux-serial@vger.kernel.org CC: Jiri Kosina <jkosina@suse.cz> CC: linux-scsi@vger.kernel.org Tested-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-09-29pcmcia: introduce autoconfiguration featureDominik Brodowski
Introduce an autoconfiguration feature to set certain values in pcmcia_loop_config(), instead of copying the same code over and over in each PCMCIA driver. At first, introduce the following options: CONF_AUTO_CHECK_VCC check or matching Vcc entry CONF_AUTO_SET_VPP set Vpp CONF_AUTO_AUDIO enable the speaker line CC: netdev@vger.kernel.org CC: linux-wireless@vger.kernel.org CC: linux-ide@vger.kernel.org CC: linux-usb@vger.kernel.org CC: laforge@gnumonks.org CC: linux-mtd@lists.infradead.org CC: alsa-devel@alsa-project.org CC: linux-serial@vger.kernel.org CC: Jiri Kosina <jkosina@suse.cz> CC: linux-scsi@vger.kernel.org Acked-by: Gustavo F. Padovan <padovan@profusion.mobi> (for drivers/bluetooth) Tested-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-09-29pcmcia: convert pcmcia_request_configuration to pcmcia_enable_deviceDominik Brodowski
pcmcia_enable_device() now replaces pcmcia_request_configuration(). Instead of config_req_t, all necessary flags are either passed as a parameter to pcmcia_enable_device(), or (in rare circumstances) set in struct pcmcia_device -> flags. With the last remaining user of include/pcmcia/cs.h gone, remove all references. CC: netdev@vger.kernel.org CC: linux-wireless@vger.kernel.org CC: linux-ide@vger.kernel.org CC: linux-usb@vger.kernel.org CC: laforge@gnumonks.org CC: linux-mtd@lists.infradead.org CC: alsa-devel@alsa-project.org CC: linux-serial@vger.kernel.org CC: Jiri Kosina <jkosina@suse.cz> CC: linux-scsi@vger.kernel.org Acked-by: Gustavo F. Padovan <padovan@profusion.mobi> (for drivers/bluetooth) Tested-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-09-29pcmcia: simplify IntTypeDominik Brodowski
IntType was only set to INT_MEMORY (driver pcmciamtd) or INT_MEMORY_AND_IO (all other drivers). As this flags seems to relate to ioport access, make it conditional to the driver having requested IO port access. There are two drivers which do not request IO ports, but did set INT_MEMORY_AND_IO: ray_cs and b43. For those, we consistently only set INT_MEMORY in future. CC: netdev@vger.kernel.org CC: linux-wireless@vger.kernel.org CC: linux-ide@vger.kernel.org CC: linux-usb@vger.kernel.org CC: laforge@gnumonks.org CC: linux-mtd@lists.infradead.org CC: alsa-devel@alsa-project.org CC: linux-serial@vger.kernel.org CC: Jiri Kosina <jkosina@suse.cz> CC: linux-scsi@vger.kernel.org Acked-by: Gustavo F. Padovan <padovan@profusion.mobi> (for drivers/bluetooth) Tested-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-09-29pcmcia: move Vpp setup to struct pcmcia_deviceDominik Brodowski
Some drivers prefer to explicitly set Vpp. Instead of passing the voltage inside config_req_t, store it in struct pcmcia_device. CC: linux-ide@vger.kernel.org CC: netdev@vger.kernel.org CC: linux-mtd@lists.infradead.org CC: linux-wireless@vger.kernel.org CC: linux-serial@vger.kernel.org CC: linux-usb@vger.kernel.org CC: linux-scsi@vger.kernel.org Acked-by: Gustavo F. Padovan <padovan@profusion.mobi> (for drivers/bluetooth) Tested-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-08-03pcmcia: do not use io_req_t when calling pcmcia_request_io()Dominik Brodowski
Instead of io_req_t, drivers are now requested to fill out struct pcmcia_device *p_dev->resource[0,1] for up to two ioport ranges. After a call to pcmcia_request_io(), the ports found there are reserved, after calling pcmcia_request_configuration(), they may be used. CC: netdev@vger.kernel.org CC: linux-wireless@vger.kernel.org CC: linux-ide@vger.kernel.org CC: linux-usb@vger.kernel.org CC: laforge@gnumonks.org CC: linux-mtd@lists.infradead.org CC: alsa-devel@alsa-project.org CC: linux-serial@vger.kernel.org CC: Michael Buesch <mb@bu3sch.de> Acked-by: Marcel Holtmann <marcel@holtmann.org> (for drivers/bluetooth/) Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-08-03pcmcia: do not use io_req_t after call to pcmcia_request_io()Dominik Brodowski
After pcmcia_request_io(), do not make use of the values stored in io_req_t, but instead use those found in struct pcmcia_device->resource[]. CC: netdev@vger.kernel.org CC: linux-wireless@vger.kernel.org CC: linux-ide@vger.kernel.org CC: linux-usb@vger.kernel.org CC: laforge@gnumonks.org CC: linux-mtd@lists.infradead.org CC: alsa-devel@alsa-project.org CC: linux-serial@vger.kernel.org Acked-by: Marcel Holtmann <marcel@holtmann.org> (for drivers/bluetooth/) Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-07-30pcmcia: remove cs_types.hDominik Brodowski
Remove cs_types.h which is no longer needed: Most definitions aren't used at all, a few can be made away with, and two remaining definitions (typedefs, unfortunatley) may be moved to more specific places. CC: linux-ide@vger.kernel.org CC: linux-usb@vger.kernel.org CC: laforge@gnumonks.org CC: linux-mtd@lists.infradead.org CC: alsa-devel@alsa-project.org CC: linux-serial@vger.kernel.org Acked-by: Marcel Holtmann <marcel@holtmann.org> (for drivers/bluetooth/) Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-05-10pcmcia: dev_node removal (write-only drivers)Dominik Brodowski
dev_node_t was only used to transport some minor/major numbers from the PCMCIA device drivers to deprecated userspace helpers. However, only a few drivers made use of it, and the userspace helpers are deprecated anyways. Therefore, get rid of dev_node_t . As a first step, remove any usage of dev_node_t from drivers which only wrote to this typedef/struct, but did not make use of it. CC: linux-bluetooth@vger.kernel.org CC: Harald Welte <laforge@gnumonks.org> CC: linux-mtd@lists.infradead.org CC: linux-wireless@vger.kernel.org CC: netdev@vger.kernel.org CC: linux-serial@vger.kernel.org CC: alsa-devel@alsa-project.org Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-05-10pcmcia: re-work pcmcia_request_irq()Dominik Brodowski
Instead of the old pcmcia_request_irq() interface, drivers may now choose between: - calling request_irq/free_irq directly. Use the IRQ from *p_dev->irq. - use pcmcia_request_irq(p_dev, handler_t); the PCMCIA core will clean up automatically on calls to pcmcia_disable_device() or device ejection. - drivers still not capable of IRQF_SHARED (or not telling us so) may use the deprecated pcmcia_request_exclusive_irq() for the time being; they might receive a shared IRQ nonetheless. CC: linux-bluetooth@vger.kernel.org CC: netdev@vger.kernel.org CC: linux-wireless@vger.kernel.org CC: linux-serial@vger.kernel.org CC: alsa-devel@alsa-project.org CC: linux-usb@vger.kernel.org CC: linux-ide@vger.kernel.org Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-02-27Bluetooth: Convert controller hdev->type to hdev->busMarcel Holtmann
The hdev->type is misnamed and should be actually hdev->bus instead. So convert it now. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2010-01-30Bluetooth: Redo checks in IRQ handler for shared IRQ supportMike Frysinger
Commit ac019360fe3 changed the irq handler logic to BUG_ON rather than returning IRQ_NONE when the incoming argument is invalid. While this works in most cases, it doesn't work when the IRQ is shared with other devices (or when DEBUG_SHIRQ is enabled). So revert the previous change and replace the warning message with a comment explaining that we want this behavior. Signed-off-by: Michael Hennerich <michael.hennerich@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2009-11-28pcmcia: rework the irq_req_t typedefDominik Brodowski
Most of the irq_req_t typedef'd struct can be re-worked quite easily: (1) IRQInfo2 was unused in any case, so drop it. (2) IRQInfo1 was used write-only, so drop it. (3) Instance (private data to be passed to the IRQ handler): Most PCMCIA drivers using pcmcia_request_irq() to actually register an IRQ handler set the "dev_id" to the same pointer as the "priv" pointer in struct pcmcia_device. Modify the two exceptions (ipwireless, ibmtr_cs) to also work this waym and set the IRQ handler's "dev_id" to p_dev->priv unconditionally. (4) Handler is to be of type irq_handler_t. (5) Handler != NULL already tells whether an IRQ handler is present. Therefore, we do not need the IRQ_HANDLER_PRESENT flag in irq_req_t.Attributes. CC: netdev@vger.kernel.org CC: linux-bluetooth@vger.kernel.org CC: linux-ide@vger.kernel.org CC: linux-wireless@vger.kernel.org CC: linux-scsi@vger.kernel.org CC: alsa-devel@alsa-project.org CC: Jaroslav Kysela <perex@perex.cz> CC: Jiri Kosina <jkosina@suse.cz> CC: Karsten Keil <isdn@linux-pingi.de> for the Bluetooth parts: Acked-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2009-11-08pcmcia: deprecate CS_CHECK (bluetooth)Dominik Brodowski
Remove all usages of the CS_CHECK macro and replace them with proper Linux style calling and return value checking. The extra error reporting may be dropped, as the PCMCIA core already complains about any (non-driver-author) errors. CC: linux-bluetooth@vger.kernel.org Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2008-10-17pcmcia: IRQ_TYPE_EXCLUSIVE is long obsoletedAlan Cox
Switch more drivers to dynamic sharing after checking their IRQ handlers use dev_id and are robust Signed-off-by: Alan Cox <alan@redhat.com> Acked-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2008-08-23pcmcia: deprecate CS_SUCCESSDominik Brodowski
Instead of using own error or success codes, the PCMCIA code should rely on the generic return values. Therefore, replace all occurrences of CS_SUCCESS with 0. CC: netdev@vger.kernel.org Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2008-08-23pcmcia: pcmcia_config_loop() improvement by passing vccDominik Brodowski
By passing the current Vcc setting to the pcmcia_config_loop callback function, we can remove pcmcia_get_configuration_info() calls from many drivers. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2008-08-23pcmcia: pcmcia_config_loop() default CIS entry handlingDominik Brodowski
Many drivers use the default CIS entry within their pcmcia_config_loop() callback function. Therefore, factor the default CIS entry handling out. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2008-08-23pcmcia: pcmcia_config_loop() ConfigIndex unificationDominik Brodowski
Almost all drivers set p_dev->conf.ConfigIndex to cfg->index in the pcmcia_config_loop() callback function. Therefore, factor it out. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2008-08-23pcmcia: use pcmcia_loop_config in bluetooth driversDominik Brodowski
Use the config loop helper in bluetooth pcmcia drivers. CC: Marcel Holtmann <marcel@holtmann.org> CC: linux-bluetooth@vger.kernel.org Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2008-02-05pcmcia: replace kio_addr_t with unsigned int everywhereOlof Johansson
Remove kio_addr_t, and replace it with unsigned int. No known architecture needs more than 32 bits for IO addresses and ports and having a separate type for it is just messy. Signed-off-by: Olof Johansson <olof@lixom.net> Cc: Christoph Hellwig <hch@lst.de> Cc: Matthew Wilcox <matthew@wil.cx> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Dominik Brodowski <linux@dominikbrodowski.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-03drivers/bluetooth/: Spelling fixesJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-22[Bluetooth] Eliminate checks for impossible conditions in IRQ handlerJeff Garzik
Our info structure and info->hdev is always passed to the IRQ handler, so we don't have to worry about these checks in every interrupt. Leave a BUG_ON() just to help unwary programmers, but these could probably be removed as well. Signed-off-by: Jeff Garzik <jgarzik@redhat.com> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2007-04-25[BLUETOOTH]: Introduce skb->data accessor methods for hci_{acl,event,sco}_hdrArnaldo Carvalho de Melo
For consistency with other skb data accessors, reducing the number of direct accesses to skb->data. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2006-12-04[PATCH] pcmcia: conf.ConfigBase and conf.Present consolidationDominik Brodowski
struct pcmcia_device *p_dev->conf.ConfigBase and .Present are set in almost all PCMICA driver right at the beginning, using the same calls but slightly different implementations. Unfiy this in the PCMCIA core. Includes a small bugfix ("drivers/net/pcmcia/xirc2ps_cs.c: remove unused label") from and Signed-off-by Adrian Bunk <bunk@stusta.de> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-07-03[Bluetooth] Add platform device for virtual and serial devicesMarcel Holtmann
This patch adds a generic Bluetooth platform device that can be used as parent device by virtual and serial devices. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2006-03-31[PATCH] pcmcia: use bitfield instead of p_state and stateDominik Brodowski
Instead of the two status values struct pcmcia_device->p_state and state, use descriptive bitfields. Most value-checking in drivers was invalid, as the core now only calls the ->remove() (a.k.a. detach) function in case the attachement _and_ configuration was successful. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-03-31[PATCH] pcmcia: add return value to _config() functionsDominik Brodowski
Most of the driver initialization isn't done in the .probe function, but in the internal _config() functions. Make them return a value, so that .probe can properly report whether the probing of the device succeeded or not. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-03-31[PATCH] pcmcia: remove dev_link_t and client_handle_t indirectionDominik Brodowski
dev_link_t * and client_handle_t both mean struct pcmcai_device * by now. Therefore, remove all such indirections. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-03-31[PATCH] pcmcia: embed dev_link_t into struct pcmcia_deviceDominik Brodowski
Embed dev_link_t into struct pcmcia_device(), as they basically address the same entity. The actual contents of dev_link_t will be cleaned up step by step. This patch includes a bugfix from and signed-off-by Andrew Morton. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-03-31[PATCH] pcmcia: remove unneeded Vcc pseudo settingDominik Brodowski
As we do not allow setting Vcc in the pcmcia core, and Vpp1 and Vpp2 can only be set to the same value, a lot of code can be streamlined. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-03-31[PATCH] pcmcia: default suspend and resume handlingDominik Brodowski
In all but one case, the suspend and resume functions of PCMCIA drivers contain mostly of calls to pcmcia_release_configuration() and pcmcia_request_configuration(). Therefore, move this code out of the drivers and into the core. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-03-31[PATCH] pcmcia: add pcmcia_disable_deviceDominik Brodowski
pcmcia_disable_device(struct pcmcia_device *p_dev) performs the necessary cleanups upon device or driver removal: it calls the appropriate pcmcia_release_* functions, and can replace (most) of the current drivers' _release() functions. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-01-06[PATCH] pcmcia: unify attach, EVENT_CARD_INSERTION handlers into one probe ↵Dominik Brodowski
callback Unify the EVENT_CARD_INSERTION and "attach" callbacks to one unified probe() callback. As all in-kernel drivers are changed to this new callback, there will be no temporary backwards-compatibility. Inside a probe() function, each driver _must_ set struct pcmcia_device *p_dev->instance and instance->handle correctly. With these patches, the basic driver interface for 16-bit PCMCIA drivers now has the classic four callbacks known also from other buses: int (*probe) (struct pcmcia_device *dev); void (*remove) (struct pcmcia_device *dev); int (*suspend) (struct pcmcia_device *dev); int (*resume) (struct pcmcia_device *dev); Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-01-06[PATCH] pcmcia: remove dev_list from driversDominik Brodowski
The linked list of devices managed by each PCMCIA driver is, in very most cases, unused. Therefore, remove it from many drivers. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
